[Mapbender-commits] r8692 - trunk/mapbender/http/print
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Aug 22 23:03:42 PDT 2013
Author: armin11
Date: 2013-08-22 23:03:42 -0700 (Thu, 22 Aug 2013)
New Revision: 8692
Added:
   trunk/mapbender/http/print/Dummy_A4.json
   trunk/mapbender/http/print/Dummy_A4.odg
   trunk/mapbender/http/print/Dummy_A4.pdf
One Dummy print template
Added: trunk/mapbender/http/print/Dummy_A4.json
--- trunk/mapbender/http/print/Dummy_A4.json	                        (rev 0)
+++ trunk/mapbender/http/print/Dummy_A4.json	2013-08-23 06:03:42 UTC (rev 8692)
@@ -0,0 +1,70 @@
+    "type" : "templatePDF",
+    "orientation" : "P",
+    "units" : "mm",
+    "format" : "a4",
+    "controls" : [
+            "id" : "scale",
+            "label" : "Maßstab",
+            "type" : "hidden",
+            "pageElementsLink" : {
+                "scale" : "value"
+    "pages" : [
+            "tpl" : "Dummy_A4.pdf",
+            "useTplPage" : 1,
+            "elements" : {
+                "karte" : {
+                    "type" : "map",
+                    "res_dpi" : 72,
+                    "x_ul" : 16.2,
+                    "y_ul" : 22.5,
+                    "width" : 180,
+                    "height" : 212,
+                    "coords" : 1,
+                    "coords_font_family" : "Arial",
+                    "coords_font_size" : 8
+                "minikarte" : {
+                    "type" : "overview",
+                    "res_dpi" : 72,
+                    "x_ul" : 15.6,
+                    "y_ul" : 21.8,
+                    "width" : 40,
+                    "height" : 40
+                "date" : {
+                    "type" : "text",
+                    "x_ul" : 35.5,
+                    "y_ul" : 246.0,
+                    "font_family" : "Arial",
+                    "font_size" : 11,
+                    "value" : "date"
+                "nordpfeil" : {
+                    "type" : "image",
+                    "x_ul" : 184,
+                    "y_ul" : 254,
+                    "width" : 25,
+                    "height" : 25,
+                    "angle" : 0,
+                    "filename" : "./img/northarrow.png"
Added: trunk/mapbender/http/print/Dummy_A4.odg
(Binary files differ)
Property changes on: trunk/mapbender/http/print/Dummy_A4.odg
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: trunk/mapbender/http/print/Dummy_A4.pdf
Property changes on: trunk/mapbender/http/print/Dummy_A4.pdf
More information about the Mapbender_commits mailing list
