[Mapbender-commits] r8541 - in trunk/mapbender: conf core http/php owsproxy/http
svn_mapbender at osgeo.org
Thu Jan 17 04:51:03 PST 2013
Author: armin11
Date: 2013-01-17 04:51:03 -0800 (Thu, 17 Jan 2013)
New Revision: 8541
trunk/mapbender/conf/mapbender.conf-dist
trunk/mapbender/core/globalSettings.php
trunk/mapbender/http/php/mb_validateSession.php
trunk/mapbender/owsproxy/http/index.php
Allow a public user to use owsproxy secured services and some bugfixing.
Modified: trunk/mapbender/conf/mapbender.conf-dist
--- trunk/mapbender/conf/mapbender.conf-dist 2013-01-17 10:57:31 UTC (rev 8540)
+++ trunk/mapbender/conf/mapbender.conf-dist 2013-01-17 12:51:03 UTC (rev 8541)
@@ -60,6 +60,8 @@
define("OWSPROXY", "http://<ip or name>/owsproxy");
define("OWSPROXY_USE_LOCALHOST", false);
+# Allow OWSPROXY to serve services which are available to the public user - a new session will be set
+define("OWSPROXY_ALLOW_PUBLIC_USER", false);
# Definitions for HTTP Authentication
Modified: trunk/mapbender/core/globalSettings.php
--- trunk/mapbender/core/globalSettings.php 2013-01-17 10:57:31 UTC (rev 8540)
+++ trunk/mapbender/core/globalSettings.php 2013-01-17 12:51:03 UTC (rev 8541)
@@ -26,10 +26,10 @@
// initiates the session-handling
-session_start();
-if (defined("SESSION_NAME") && is_string(SESSION_NAME)) {
- session_name(SESSION_NAME);
+//session_start();
+//if (defined("SESSION_NAME") && is_string(SESSION_NAME)) {
+// session_name(SESSION_NAME);
// Basic Mapbender classes, for session handling etc.
Modified: trunk/mapbender/http/php/mb_validateSession.php
--- trunk/mapbender/http/php/mb_validateSession.php 2013-01-17 10:57:31 UTC (rev 8540)
+++ trunk/mapbender/http/php/mb_validateSession.php 2013-01-17 12:51:03 UTC (rev 8541)
@@ -22,11 +22,10 @@
$e = new mb_notice("mb_validateSession.php: checking file " . $_SERVER["SCRIPT_NAME"]);
// if cookies are off
-if ($_REQUEST["sessionName"] && $_REQUEST["sessionId"]) {
+if ($_REQUEST["sessionName"] && $_REQUEST["sessionId"]) { //TODO: the request parameter won't be sessionName but maybe PHPSESSID - name of cookie! See line 101 usage of SID
session_name($_REQUEST["sessionName"]);
session_id($_REQUEST["sessionId"]);
// check if user data is valid; if not, return to login screen
Modified: trunk/mapbender/owsproxy/http/index.php
--- trunk/mapbender/owsproxy/http/index.php 2013-01-17 10:57:31 UTC (rev 8540)
+++ trunk/mapbender/owsproxy/http/index.php 2013-01-17 12:51:03 UTC (rev 8541)
@@ -19,10 +19,11 @@
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
require(dirname(__FILE__) . "/../../conf/mapbender.conf");
-require(dirname(__FILE__) . "/../../http/classes/class_administration.php");
-require(dirname(__FILE__) . "/../../http/classes/class_connector.php");
+//require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+require_once(dirname(__FILE__) . "/../../http/classes/class_administration.php");
+require_once(dirname(__FILE__) . "/../../http/classes/class_connector.php");
require_once(dirname(__FILE__) . "/../../http/classes/class_mb_exception.php");
-require(dirname(__FILE__) . "/./classes/class_QueryHandler.php");
+require_once(dirname(__FILE__) . "/./classes/class_QueryHandler.php");
/***** conf *****/
$imageformats = array("image/png","image/gif","image/jpeg", "image/jpg");
@@ -38,21 +39,53 @@
$owsproxyService = $_REQUEST['wms']; //ToDo: change this to 'service' in the apache url-rewriting
$query = new QueryHandler();
-// an array with keys and values toLoserCase -> caseinsensitiv
+// an array with keys and values toLowerCase -> caseinsensitiv
$reqParams = $query->getRequestParams();
$notice = new mb_notice("owsproxy id:".$query->getOwsproxyServiceId());
// check session
-session_regenerate_id();
+//session_regenerate_id(TRUE);
+session_regenerate_id(); //it will generate a session if it does not exists without any user in it!
session_destroy();
-session_id($_REQUEST["sid"]);
-session_start();
-if(!$_SESSION['mb_user_id']){
- $notice = new mb_notice("Permission denied");
- throwE("Permission denied");
+//check if current session has the same id as the session which is requested in the owsproxy url
+//exchange them, if they differ and redirect to an new one with the current session
+if (session_id() !== $_REQUEST["sid"]) {
+ //get all request params which are original
+ //build reuquest
+ $redirectUrl = OWSPROXY."/".session_id()."/".$_REQUEST['wms'].$query->getRequest();
+ $e = new mb_notice("redirect to new owsproxy url: ".$redirectUrl);
+ header("Location: ".$redirectUrl);
die();
+} else {
+ $e = new mb_notice("Current SID identical to requested SID!");
+//this is the request which may have been redirected
+//session_id($_REQUEST["sid"]);
+//session_start();//?
+//check for given user session with user_id which can be tested again the authorization
+if(!$_SESSION['mb_user_id']){
+ $e = new mb_exception("user id not found in session");
+ //if configured in mapbender.conf, create guest session so that also proxied service can be watched in external applications when they are available to the anonymous user
+ //only possible for webapplications - in case of desktop applications the user have to use his credentials and http_auth module
+ if (defined("OWSPROXY_ALLOW_PUBLIC_USER") && OWSPROXY_ALLOW_PUBLIC_USER && defined("PUBLIC_USER") && PUBLIC_USER != "") {
+ //setSession();
+ Mapbender::session()->set("mb_user_id",PUBLIC_USER);
+ Mapbender::session()->set("external_proxy_user",true);
+ $e = new mb_notice("Permission allowed for public user with id: ".PUBLIC_USER);
+ } else {
+ $e = new mb_notice("Permission denied - public user not allowed to access ressource!");
+ //kill actual session file
+ $tmpSessionFile = ini_get('session.save_path')."/sess_".session_id();
+ $e = new mb_notice("delete temporary session file: ".$tmpSessionFile);
+ @unlink($tmpSessionFile);
+ throwE("Permission denied - no current session found and public user not allowed to acces ressource!");
+ die();
+} else {
+ $e= new mb_notice("mb_user_id found in session: ".$_SESSION['mb_user_id']);
$n = new administration;
//if($_SESSION['mb_user_ip'] != $_SERVER['REMOTE_ADDR']){
// throwE(array("No session data available.","Permission denied.","Please authenticate."));
@@ -70,6 +103,7 @@
/************* workflow ************/
$n = new administration();
switch (strtolower($reqParams['request'])) {
case 'getcapabilities':
$arrayOnlineresources = checkWmsPermission($query->getOwsproxyServiceId());
@@ -188,10 +222,19 @@
$text_color = ImageColorAllocate ($image, 233, 14, 91);
if (count($e) > 1){
for($i=0; $i<count($e); $i++){
- ImageString ($image, 3, 5, $i*20, $e[$i], $text_color);
+ $imageString = $e[$i];
+ ImageString ($image, 3, 5, $i*20, $imageString, $text_color);
} else {
- ImageString ($image, 3, 5, $i*20, $e, $text_color);
+ if (is_array($e)) {
+ $imageString = $e[0];
+ } else {
+ $imageString = $e;
+ if ($imageString == "") {
+ $imageString = "An unknown error occured!";
responseImage($image);
@@ -529,7 +572,6 @@
global $con, $n;
$myguis = $n->getGuisByPermission($_SESSION["mb_user_id"],true);
$mywms = $n->getWmsByOwnGuis($myguis);
$sql = "SELECT * FROM wms WHERE wms_owsproxy = $1";
$v = array($wms);
$t = array("s");
@@ -542,6 +584,7 @@
$service["wms_getfeatureinfo"] = $row["wms_getfeatureinfo"];
$service["wms_getcapabilities_doc"] = $row["wms_getcapabilities_doc"];
if(!$row || count($mywms) == 0){
throwE(array("No wms data available."));
die();
More information about the Mapbender_commits
