[Mapbender-commits] r8547 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Fri Jan 18 10:50:42 PST 2013
Author: armin11
Date: 2013-01-18 10:50:41 -0800 (Fri, 18 Jan 2013)
New Revision: 8547
trunk/mapbender/http/classes/class_connector.php
Allow print module to work under owsproxy and redirects with curl
Modified: trunk/mapbender/http/classes/class_connector.php
--- trunk/mapbender/http/classes/class_connector.php 2013-01-18 17:52:04 UTC (rev 8546)
+++ trunk/mapbender/http/classes/class_connector.php 2013-01-18 18:50:41 UTC (rev 8547)
@@ -35,6 +35,7 @@
private $httpContentType;
private $httpPostFieldsNumber;
private $curlSendCustomHeaders = true; //decide to send own headers or not
+ private $curlCookiesession = true;
@@ -204,8 +205,8 @@
curl_setopt($ch, CURLOPT_BINARYTRANSFER, true); //for images
curl_setopt($ch, CURLOPT_FOLLOWLOCATION, true);
curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
- //dont store and load cookies from previous sessions
- curl_setopt($ch, CURLOPT_COOKIESESSION, true);
+ //hold cookies on redirects (302) - http://stackoverflow.com/questions/1458683/how-do-i-pass-cookies-on-a-curl-redirect - needed for print via internal owsproxy!
+ curl_setopt($ch, CURLOPT_COOKIEFILE, "");
//allow https connections and handle certificates quite simply ;-)
curl_setopt($ch,CURLOPT_SSL_VERIFYHOST,0);
curl_setopt($ch, CURLOPT_SSL_VERIFYPEER, 0);
More information about the Mapbender_commits
