[Mapbender-commits] r8580 - in trunk/mapbender: http/plugins http/print lib resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Mar 4 02:20:56 PST 2013
Author: verenadiewald
Date: 2013-03-04 02:20:56 -0800 (Mon, 04 Mar 2013)
New Revision: 8580
   trunk/mapbender/http/plugins/mb_print.php
   trunk/mapbender/http/print/A4_landscape_template.json
   trunk/mapbender/http/print/A4_landscape_template.odg
   trunk/mapbender/lib/printbox.js
   trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.3_to_2.7.4_pgsql_UTF-8.sql
http://trac.osgeo.org/mapbender/ticket/889 + http://trac.osgeo.org/mapbender/ticket/890
Modified: trunk/mapbender/http/plugins/mb_print.php
--- trunk/mapbender/http/plugins/mb_print.php	2013-03-04 10:19:51 UTC (rev 8579)
+++ trunk/mapbender/http/plugins/mb_print.php	2013-03-04 10:20:56 UTC (rev 8580)
@@ -179,9 +179,29 @@
     							jqForm[0].scale.value = parseInt(obj.scale / 10, 10) * 10;
     						else {
-    							$("#scale .addedScale").remove();
-    							$("#scale").append("<option selected class='addedScale' value='"+parseInt(obj.scale / 10, 10) * 10+"'>1 : " + parseInt(obj.scale / 10, 10) * 10 + "</option>");
+    							//$("#scale .addedScale").remove();
+    							//$("#scale").append("<option selected class='addedScale' value='"+parseInt(obj.scale / 10, 10) * 10+"'>1 : " + parseInt(obj.scale / 10, 10) * 10 + "</option>");
+    							var currentScale = parseInt($("#scale").val(), 10);
+    							var objScale = parseInt(obj.scale / 10, 10) * 10;
+			    				if(obj.scale != currentScale) {
+			    					var scaleOptions = [];
+	 								$("#scale option").each( function() {
+										scaleOptions.push(parseInt(this.value, 10));
+	 								var closest = getClosestNum(objScale,scaleOptions);
+			    					$("#scale option[value='"+closest+"']").attr('selected', 'selected');
+			    					if(printBox) {
+			    						if(objScale != closest) {
+			    							printBox.setScale(closest);
 						if (obj.coordinates) {
 	                        if(typeof(jqForm[0].coordinates) != "undefined") {
@@ -193,9 +213,32 @@
 			printBox.paintPoints();
 			printBox.paintBox();
+			printBox.show();
+	function getClosestNum(num, ar) {
+	    var i = 0, closest, closestDiff, currentDiff;
+	    if(ar.length)
+	        closest = ar[0];
+	        for(i;i<ar.length;i++)
+	            closestDiff = Math.abs(num - closest);
+	            currentDiff = Math.abs(num - ar[i]);
+	            if(currentDiff < closestDiff)
+	                closest = ar[i];
+	            closestDiff = null;
+	            currentDiff = null;
+	        //returns first element that is closest to number
+	        return closest;
+	    //no length
+	    return false;
  	 * Method: getPDFMapSize
@@ -228,6 +271,20 @@
+	 * Change status of printbox
+	 * @param {String} newStatus either "hide or "show"
+	var showHidePrintBox = function (newStatus) {
+		if (newStatus=="hide") {
+	    	printBox.hide();
+	    else {
+	    	printBox.show();
  	 * Method: mod_printPDF_init
 	 * initializes the print modules, generates template chooser and loads first configuration.
@@ -551,8 +608,8 @@
 					stripslashes(res.outputFileName);
 			showHideWorking("hide");
-                        //remove printbox after successful print
-                        destroyPrintBox();
+            //remove printbox after successful print
+            //destroyPrintBox();
 		else {
 			/* something went wrong */
@@ -569,6 +626,9 @@
 	var buildForm = function () {
 		$(".print_option_dyn").remove();
 		var str = "";
+		str += '<input type="hidden" name="printboxScale" id="printboxScale">\n';
+		str += '<input type="hidden" name="printboxCoordinates" id="printboxCoordinates">\n';
+		str += '<input type="hidden" name="printboxAngle" id="printboxAngle">\n';
 		for (var item in actualConfig.controls) {
 			var element = actualConfig.controls[item];
 			var element_id = myId + "_" + element.id;
@@ -600,7 +660,8 @@
 					str += '<select id="'+element.id+'" name="'+element.id+'" size="1">\n';
 					for (var option_index in element.options) {
 						option = element.options[option_index];
-						str += '<option value="'+option.value+'">'+option.label+'</option>\n';
+						var selected = option.selected ? option.selected : "";
+						str += '<option '+selected+' value="'+option.value+'">'+option.label+'</option>\n';
 					str += '</select><br>\n';
 					break;
@@ -627,28 +688,28 @@
     					return false;
-                                    var scale = parseInt(this.value, 10);
+                    var scale = parseInt(this.value, 10);
     				if (isNaN(scale) || typeof printBox === "undefined") {
     					return true;
-                                    if(scale < 10) {
-                                        return true;
+                    if(scale < 10) {
+                    	return true;
     				printBox.setScale(scale);
     				return true;
 			else {
 				$("#scale").change(function (e) {
-				if (isNaN(scale) || typeof printBox === "undefined") {
-					return true;
-                if(scale < 10) {
-	                return true;
+					if (isNaN(scale) || typeof printBox === "undefined") {
+						return true;
+	                if(scale < 10) {
+		                return true;
 					return true;
@@ -692,7 +753,28 @@
 			$("#printPDF_handle").click(function () {
-				printObj.createPrintBox();
+				if (printBox) {
+					if(printBox.isVisible()) {
+						showHidePrintBox("hide");
+						$("#printboxScale").val($("#printPDF_form #scale").val());
+						$("#printboxCoordinates").val($("#printPDF_form #coordinates").val());
+						$("#printboxAngle").val($("#printPDF_form #angle").val());
+						$("#printPDF_form #scale").val("");
+						$("#printPDF_form #coordinates").val("");
+						$("#printPDF_form #angle").val("");
+					else {
+						showHidePrintBox("show");
+						$("#printPDF_form #scale").val($("#printboxScale").val());
+						$("#printPDF_form #coordinates").val($("#printboxCoordinates").val());
+						$("#printPDF_form #angle").val($("#printboxAngle").val());
+				else {
+					printObj.createPrintBox();
 			$("#printPDF_working").bgiframe({
 				src: "BLOCKED SCRIPT'<html></html>';",
Modified: trunk/mapbender/http/print/A4_landscape_template.json
--- trunk/mapbender/http/print/A4_landscape_template.json	2013-03-04 10:19:51 UTC (rev 8579)
+++ trunk/mapbender/http/print/A4_landscape_template.json	2013-03-04 10:20:56 UTC (rev 8580)
@@ -1,207 +1,237 @@
-    "type" : "templatePDF",
-    "orientation" : "L",
-    "units" : "mm",
-    "format" : "a4",
-    "controls" : [
-    		"id" : "title",
-    		"label" : "Titel",
-    		"type" : "text",
-    		"size" : 20,
-    		"pageElementsLink" : {
-    			"titel" : "value"
-    		"id" : "dpi",
-    		"label" : "DPI",
-    		"type" : "select",
-    		"size" : 20,
-    			"karte" : "res_dpi"
-    		"options" : [
-		            "value" : "72",
-		            "label" : "72 dpi"
-		            "value" : "144",
-		            "label" : "144 dpi"
-		            "value" : "288",
-		            "label" : "288 dpi"
-    		"id" : "comment1",
-    		"label" : "Kommentar1",
-    		"type" : "textarea",
-    		"size" : 5,
-    			"kommentar1" : "value"
-    		"id" : "comment2",
-    		"label" : "Kommentar 2",
-    		"size" : 5,
-    			"kommentar2" : "value"
-    		"id" : "angle",
-    		"label" : "Winkel",
-    		"type" : "text",
-    			"nordpfeil" : "angle",
-    			"karte" : "angle",
-    			"minikarte" : "angle"
-    		"id" : "coordinates",
-    		"type" : "hidden"
-    		"id" : "scale",
-    		"label" : "Maßstab",
-    		"type" : "text",
-    			"scale" : "value"
-    "pages" : [
-    	 "tpl" : "A4_landscape_template.pdf",
-    	 "useTplPage" : 1,
-    	 "elements" : {
-	    	 "karte" : {
-    			"type" : "map",
-    			"res_dpi" : 72,
-    			"x_ul" : 8.8,
-	    		"y_ul" : 13.6,
-	    		"width" : 203.5,
-    			"height" : 180.8,
-    			"coords" : 1,
-    			"coords_font_family" : "Arial",
-    			"coords_font_size" : 8
-	   		"messung" : {
-    			"type" : "measure",
-    			"do_fill" : 0,
-    			"fill_color" : {
-    				"r" : 255,
-    				"g" : 0,
-    				"b" : 0
-    			"do_stroke" : 0,
-    			"stroke_color" : {
-    				"r" : 0,
-    				"g" : 0,
-    				"b" : 0
-    			"line_style" : {
-    				"width" : 1.0
-	   		"minikarte" : {
-    			"type" : "overview",
-    			"res_dpi" : 72,
-    			"x_ul" : 222.3,
-	    		"y_ul" : 13.6,
-	    		"width" : 67.5,
-    			"height" : 60
-	   		"titel" : {
-    			"type" : "text",
-    			"x_ul" : 9,
-	    		"y_ul" : 10,
-	    		"font_family" : "Arial",
-	    		"font_size" : 14
-	   		"scale" : {
-    			"type" : "text",
-    			"x_ul" : 245,
-	    		"y_ul" : 123.8,
-	    		"font_size" : 12,
-				"value" : "scale"
-	   		"date" : {
-    			"type" : "text",
-    			"x_ul" : 245,
-	    		"y_ul" : 114,
-	    		"font_size" : 12,
-				"value" : "date"
-		        "time" : {
-		            "type" : "text",
-		            "x_ul" : 270,
-		            "y_ul" : 114,
-		            "font_size" : 11,
-		            "value" : "time"
-	   		"nordpfeil" : {
-    			"type" : "image",
-    			"x_ul" : 230,
-	    		"y_ul" : 85.5,
-	    		"width" : 16,
-	    		"height" : 16,
-	    		"angle" : 0,
-				"filename" : "./img/northarrow.png"
-	   		"kommentar1" : {
-    			"type" : "para",
-    			"x_ul" : 219,
-	    		"y_ul" : 145,
-	    		"font_size" : 12,
-	    		"width" : 45,
-	    		"height" : 7,
-	    		"align" : "L",
-	    		"border" : 0,
-	    		"fill" : 1,
-	    		"border_width" : 0.5
-	   		"kommentar2" : {
-    			"type" : "para",
-    			"x_ul" : 219,
-	    		"y_ul" : 152.5,
-	    		"font_size" : 12,
-	    		"width" : 45,
-	    		"height" : 7,
-	    		"align" : "L",
-	    		"border" : 0,
-	    		"fill" : 1,
-            "useTplPage" : 2,
-            "elements" : {
-                "legende" : {
-                    "type" : "legend",
-                    "x_ul" : 10,
-                    "y_ul" : 38,
-                    "width" : 90,
-                    "height" : 160,
-                    "font_size" : 9,
-                    "scale" : 0.5
+    "type" : "templatePDF",
+    "orientation" : "L",
+    "units" : "mm",
+    "format" : "a4",
+    "controls" : [
+            "id" : "title",
+            "label" : "Titel",
+            "type" : "text",
+            "size" : 20,
+            "pageElementsLink" : {
+                "titel" : "value"
+            "id" : "dpi",
+            "label" : "DPI",
+            "type" : "select",
+            "size" : 20,
+                "karte" : "res_dpi"
+            "options" : [
+                    "value" : "72",
+                    "label" : "72 dpi"
+                    "value" : "144",
+                    "label" : "144 dpi"
+                    "value" : "288",
+                    "label" : "288 dpi"
+            "id" : "comment1",
+            "label" : "Kommentar1",
+            "type" : "textarea",
+            "size" : 5,
+                "kommentar1" : "value"
+            "id" : "comment2",
+            "label" : "Kommentar 2",
+            "size" : 5,
+                "kommentar2" : "value"
+            "id" : "angle",
+            "label" : "Winkel",
+            "type" : "text",
+                "nordpfeil" : "angle",
+                "karte" : "angle",
+                "minikarte" : "angle"
+            "id" : "coordinates",
+            "type" : "hidden"
+            "id" : "scale",
+            "label" : "Maßstab",
+                "scale" : "value"
+            "options" : [
+                    "value" : "500",
+                    "label" : "1 : 500"
+                    "value" : "1000",
+                    "label" : "1 : 1000"
+                    "value" : "2000",
+                    "label" : "1 : 2000"
+                    "value" : "5000",
+                    "label" : "1 : 5000"
+                    "value" : "10000",
+                    "label" : "1 : 10000"
+                    "value" : "100000",
+                    "label" : "1 : 100000",
+                    "selected" : "selected"
+    "pages" : [
+         "tpl" : "A4_landscape_template.pdf",
+         "useTplPage" : 1,
+         "elements" : {
+             "karte" : {
+                "type" : "map",
+                "res_dpi" : 72,
+                "x_ul" : 8.8,
+                "y_ul" : 13.6,
+                "width" : 203.5,
+                "height" : 180.8,
+                "coords" : 1,
+                "coords_font_family" : "Arial",
+                "coords_font_size" : 8
+            "messung" : {
+                "type" : "measure",
+                "do_fill" : 0,
+                "fill_color" : {
+                    "r" : 255,
+                    "g" : 0,
+                    "b" : 0
+                "do_stroke" : 0,
+                "stroke_color" : {
+                    "r" : 0,
+                    "g" : 0,
+                    "b" : 0
+                "line_style" : {
+                    "width" : 1.0
+                        "permanentImage" : {
+                "type" : "permanentImage"
+            "minikarte" : {
+                "type" : "overview",
+                "res_dpi" : 72,
+                "x_ul" : 222.3,
+                "y_ul" : 13.6,
+                "width" : 67.5,
+                "height" : 60
+            "titel" : {
+                "type" : "text",
+                "x_ul" : 9,
+                "y_ul" : 10,
+                "font_family" : "Arial",
+                "font_size" : 14
+            "scale" : {
+                "type" : "text",
+                "x_ul" : 245,
+                "y_ul" : 123.8,
+                "font_size" : 12,
+                "value" : "scale"
+            "date" : {
+                "type" : "text",
+                "x_ul" : 245,
+                "y_ul" : 114,
+                "font_size" : 12,
+                "value" : "date"
+                "time" : {
+                    "type" : "text",
+                    "x_ul" : 270,
+                    "y_ul" : 114,
+                    "font_size" : 11,
+                    "value" : "time"
+            "nordpfeil" : {
+                "type" : "image",
+                "x_ul" : 230,
+                "y_ul" : 85.5,
+                "width" : 16,
+                "height" : 16,
+                "angle" : 0,
+                "filename" : "./img/northarrow.png"
+            "kommentar1" : {
+                "type" : "para",
+                "x_ul" : 219,
+                "y_ul" : 145,
+                "font_size" : 12,
+                "width" : 45,
+                "height" : 7,
+                "align" : "L",
+                "border" : 0,
+                "fill" : 1,
+                "border_width" : 0.5
+            "kommentar2" : {
+                "type" : "para",
+                "x_ul" : 219,
+                "y_ul" : 152.5,
+                "font_size" : 12,
+                "width" : 45,
+                "height" : 7,
+                "align" : "L",
+                "border" : 0,
+                "fill" : 1,
+            "useTplPage" : 2,
+            "elements" : {
+                "legende" : {
+                    "type" : "legend",
+                    "x_ul" : 10,
+                    "y_ul" : 38,
+                    "width" : 90,
+                    "height" : 160,
+                    "font_size" : 9,
+                    "scale" : 0.5
Modified: trunk/mapbender/http/print/A4_landscape_template.odg
(Binary files differ)
Modified: trunk/mapbender/lib/printbox.js
--- trunk/mapbender/lib/printbox.js	2013-03-04 10:19:51 UTC (rev 8579)
+++ trunk/mapbender/lib/printbox.js	2013-03-04 10:20:56 UTC (rev 8580)
@@ -642,8 +642,25 @@
 		activeCanvas.clear();
 		passiveCanvas.clear();
 		$("#" + this.id).remove();
-                $("#container_" + this.id).remove();
+        $("#container_" + this.id).remove();
+	this.hide = function () {
+		$("#container_" + this.id).hide();
+	this.show = function () {
+		$("#container_" + this.id).show();
+	this.isVisible = function () {
+		if($("#container_printbox").css("display") == "none") {
+			return false;
+		else {
+			return true;
 	var switchActiveCanvas = function () {
 		if (canvasNr == 1) {
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.3_to_2.7.4_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.3_to_2.7.4_pgsql_UTF-8.sql	2013-03-04 10:19:51 UTC (rev 8579)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.3_to_2.7.4_pgsql_UTF-8.sql	2013-03-04 10:20:56 UTC (rev 8580)
@@ -70,4 +70,5 @@
 ALTER FUNCTION f_collect_layer_keywords(integer)
   OWNER TO postgres;
+-- legend_url in e_content for printPDF template print
+UPDATE gui_element SET e_content = '<div id="printPDF_working_bg"></div><div id="printPDF_working"><img src="../img/indicator_wheel.gif" style="padding:10px 0 0 10px">Generating PDF</div><div id="printPDF_input"><form id="printPDF_form" action="../print/printFactory.php"><div id="printPDF_selector"></div><div class="print_option"><input type="hidden" id="opacity" name="opacity" value=""/><input type="hidden" id="map_url" name="map_url" value=""/><input type="hidden" id="overview_url" name="overview_url" value=""/><input type="hidden" id="legend_url" name="legend_url" value=""/><input type="hidden" id="map_scale" name="map_scale" value=""/><input type="hidden" name="measured_x_values" /><input type="hidden" name="measured_y_values" /><br /></div><div class="print_option" id="printPDF_formsubmit"><input id="submit" type="submit" value="Print"><br /></div></form><div id="printPDF_result"></div></div>' WHERE e_id = 'printPDF' and fkey_gui_id = 'template_print';
More information about the Mapbender_commits mailing list
