[Mapbender-commits] r8613 - in trunk/mapbender/http: classes php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon May 6 01:49:02 PDT 2013
Author: armin11
Date: 2013-05-06 01:49:02 -0700 (Mon, 06 May 2013)
New Revision: 8613
   trunk/mapbender/http/classes/class_wms.php
   trunk/mapbender/http/php/mb_getWmsData.php
   trunk/mapbender/http/php/mod_updateWMS.php
Update wms enhancement. Possibility to update wms with authentication. Patch from obgr merged into trunk. See https://trac.osgeo.org/mapbender/ticket/886.
Now layer_name mapping and authentication is supported -> for 2.7.4.
Modified: trunk/mapbender/http/classes/class_wms.php
--- trunk/mapbender/http/classes/class_wms.php	2013-05-02 09:09:30 UTC (rev 8612)
+++ trunk/mapbender/http/classes/class_wms.php	2013-05-06 08:49:02 UTC (rev 8613)
@@ -2495,8 +2495,17 @@
 	function updateObjInDB($myWMS,$updateMetadataOnly=false,$changedLayers=null){ //TODO give return true or false to allow feedback to user!!!
-        $this->wms_id = $myWMS;
+        	if (func_num_args() == 4) { //new for HTTP Authentication
+			$auth = func_get_arg(3);
+			$username = $auth['username'];
+			$password = $auth['password'];
+			$authType = $auth['auth_type'];
+		} else {
+			$username = '';
+			$password = '';
+			$authType = '';
+        	$this->wms_id = $myWMS;
 		//get some things out from database if not already given thru metadata editor: wms_network_access, wms_max_imagesize, inspire_download (on layer level)
 		//they don't come from the capabilities!
 		if (!$updateMetadataOnly) {
@@ -2538,21 +2547,24 @@
 		$sql .= "wms_remotewfs = $12, ";
 		$sql .= "wms_network_access = $13, ";
 		$sql .= "wms_max_imagesize = $16, ";
-		$sql .= "fkey_mb_group_id = $14 ";
+		$sql .= "fkey_mb_group_id = $14, ";
+        	$sql .= "wms_auth_type = $17, ";
+ 		$sql .= "wms_username = $18, ";
+ 		$sql .= "wms_password = $19 ";
 		#$sql .= "uuid = $15 ";
 		$sql .= " WHERE wms_id = $15";
 		$v = array($this->wms_version,$this->wms_getcapabilities,
 			$this->wms_getmap,$this->wms_getfeatureinfo,$this->wms_getlegendurl,
 			$admin->char_encode($this->wms_getcapabilities_doc),$this->wms_upload_url,strtotime("now"),
-			$this->wms_supportsld,$this->wms_userlayer,$this->wms_userstyle,$this->wms_remotewfs,$this->wms_network_access, $this->fkey_mb_group_id ,$myWMS, $this->wms_max_imagesize);
-		$t = array('s','s','s','s','s','s','s','i','s','s','s','s','i','i','i','i');
+			$this->wms_supportsld,$this->wms_userlayer,$this->wms_userstyle,$this->wms_remotewfs,$this->wms_network_access, $this->fkey_mb_group_id ,$myWMS, $this->wms_max_imagesize, $authType, $username, $password);
+		$t = array('s','s','s','s','s','s','s','i','s','s','s','s','i','i','i','i','s','s','s');
 		$res = db_prep_query($sql,$v,$t);
 		if(!$res){
 			db_rollback();
+		//update following metadata only if intended - mapbender.conf
 		if($this->overwrite == true){
 			$sql = "UPDATE wms SET ";
 			$sql .= "wms_title  = $1 ,";
@@ -2817,7 +2829,11 @@
+		if ($authType != '') { //some authentication is needed!
+ 			$admin = new administration();
+ 			echo "WMS ID: ".$myWMS;
+ 			$admin->setWMSOWSstring($myWMS, 1);
 		return true;
Modified: trunk/mapbender/http/php/mb_getWmsData.php
--- trunk/mapbender/http/php/mb_getWmsData.php	2013-05-02 09:09:30 UTC (rev 8612)
+++ trunk/mapbender/http/php/mb_getWmsData.php	2013-05-06 08:49:02 UTC (rev 8613)
@@ -23,28 +23,43 @@
 if ($command == "getWmsData") {
 	$wms = $_POST["wmsId"];
 	$url = $_POST["wmsUrl"];
+	$authType = $_POST["authType"];
+	$authName = $_POST["authName"];
+	$authPassword = $_POST["authPassword"];
+	if ($authType !== "none") {
+		$useAuthentication = true;
+		$auth['username'] = $authName;
+ 		$auth['password'] = $authPassword;
+ 		$auth['auth_type'] = $authType;
+	} else {
+		$useAuthentication = false;
 	//get existing DB wms information
-    $sql = "SELECT * from layer WHERE fkey_wms_id = $1 ORDER BY layer_id";
-    $v = array ($wms);
-    $t = array ('i');
-    $res = db_prep_query($sql, $v, $t);
+    	$sql = "SELECT * from layer WHERE fkey_wms_id = $1 ORDER BY layer_id";
+    	$v = array ($wms);
+    	$t = array ('i');
+   	$res = db_prep_query($sql, $v, $t);
-    $dbObj = array();
+   	$dbObj = array();
 	while ($row = db_fetch_array($res)) {
-        $dbObj[] = array (
-            //"id" => $row["layer_id"],
-            "pos" => $row["layer_pos"],
-            "parent"   => $row["layer_parent"],
-            "name"   => $row["layer_name"]
-            //"title"   => $row["layer_title"]
+        	$dbObj[] = array (
+            	//"id" => $row["layer_id"],
+            	"pos" => $row["layer_pos"],
+            	"parent"   => $row["layer_parent"],
+            	"name"   => $row["layer_name"]
+            	//"title"   => $row["layer_title"]
-    //get xml wms information
+    	//get xml wms information
 	$updateWms = new wms();
-	$xml = $updateWms->createObjFromXML($url);
+	if ($useAuthentication) {
+		$xml = $updateWms->createObjFromXML($url, $auth);
+	} else {
+		$xml = $updateWms->createObjFromXML($url);
 	if($xml == "") {
 	    echo "WMS could not be loaded, no valid XML. Please check WMS GetCapabilities";
 	    die();
@@ -62,10 +77,21 @@
     header("Content-type:application/json; charset=utf-8");
     echo $layerJson;
-else if($command == "updateWMS") {
-    $myWMS = $_POST["wmsId"];
+} else if ($command == "updateWMS") {
+    	$myWMS = $_POST["wmsId"];
+	} else {
 	$changedLayerArray = array();
 	for ($i=0; $i<count($_POST['dbOldNames']); $i++) {
@@ -78,7 +104,11 @@
 	#$changedLayerObj = json_encode($changedLayerArray);
     	$mywms = new wms();
-	$mywms->createObjFromXML($url);
+		$mywms->createObjFromXML($url, $auth);
+	} else {
+		$mywms->createObjFromXML($url);
 	$mywms->optimizeWMS();
 	echo "<br />";
 	if (!MD_OVERWRITE) {
@@ -91,7 +121,11 @@
 	if(empty($_POST['rss_news'])) {
 		$mywms->setGeoRss = false;
-	$mywms->updateObjInDB($myWMS,false, $changedLayerArray);
+		$mywms->updateObjInDB($myWMS,false, $changedLayerArray, $auth);
+	} else {
+		$mywms->updateObjInDB($myWMS,false, $changedLayerArray);
 	$mywms->displayWMS();
 	// start (owners and subscribers of the updated wms will be notified by email)
Modified: trunk/mapbender/http/php/mod_updateWMS.php
--- trunk/mapbender/http/php/mod_updateWMS.php	2013-05-02 09:09:30 UTC (rev 8612)
+++ trunk/mapbender/http/php/mod_updateWMS.php	2013-05-06 08:49:02 UTC (rev 8613)
@@ -25,8 +25,20 @@
 $selWMS = $_POST["selWMS"];
 $capURL = $_POST["capURL"];
 $myWMS = $_POST["myWMS"];
+$imrAuthName = !empty($_POST['imrAuthName']) ? $_POST['imrAuthName'] : '';
+$imrAuthPassword = !empty($_POST['imrAuthPassword']) ? $_POST['imrAuthPassword'] : '';
+$imrHttpAuth = !empty($_POST['imrHttpAuth']) ? $_POST['imrHttpAuth'] : '';
+$imrOldAuthType = !empty($_POST['imrOldAuthType']) ? $_POST['imrOldAuthType'] : '';
+$imrOldAuthName = !empty($_POST['imrOldAuthName']) ? $_POST['imrOldAuthName'] : '';
+$imrOldAuthPasswword = !empty($_POST['imrOldAuthPassword']) ? $_POST['imrOldAuthPassword'] : '';
 $myURL = $_POST["myURL"];
 $secParams = SID."&guiID=".$_REQUEST["guiID"]."&elementID=".$_REQUEST["elementID"];
 $self = $_SERVER["SCRIPT_NAME"]."?".$secParams;
@@ -104,6 +116,25 @@
 <script type='text/javascript' src='../extensions/jquery-ui-1.8.16.custom/js/jquery-ui-1.8.16.custom.min.js'></script>
 <script type='text/javascript'>
+function toggleAuthDivVis() {
+	//alert(getRadioValue(document.form1.imrHttpAuth));
+ 	if (getRadioValue(document.form1.imrHttpAuth) != 'none' && getRadioValue(document.form1.imrHttpAuth) != 'keep') {
+ 		document.getElementById("imrAuthDiv").style.display = "block";
+ 	} else {
+ 		document.getElementById("imrAuthDiv").style.display = "none";
+ function getRadioValue(rObj) {
+ 	for (var i=0; i<rObj.length; i++) if (rObj[i].checked) return rObj[i].value;
+ 		return false;
+function reupload(){
+ 		document.form1.myURL.value = document.form1.capURL.value;
+ 		validate();
 function updateWms() {
 	$("#updateResult").remove();
 	var dbOldNameArray = [];
@@ -114,10 +145,26 @@
 	$(".dbCurrentName").each(function(index) {
 		dbCurrentNameArray.push($(this).val());
+	radioAuthValue = $('input:radio[name=imrHttpAuth]:checked').val();
+	if (radioAuthValue == "keep") {
+		authType = $("#imrOldAuthType").val();
+		authPassword = $("#imrOldAuthPassword").val();
+		authName = $("#imrOldAuthName").val();
+	} else {
+		$('input:radio[name=imrHttpAuth]:checked').val(radioAuthValue); //maybe 'none', 'digest' or 'basic'
+		authType = $('input:radio[name=imrHttpAuth]:checked').val();
+		authPassword = $("#imrAuthPassword").val();
+		authName = $("#imrAuthName").val();
 	var updateParams = {
+		//TODO add auth info!
 		"command": "updateWMS",
 		"wmsId": $("#myWMS").val(),
 		"wmsUrl" : $("#myURL").val(),
+		"authType" : authType,
+		"authName" : authName,
+		"authPassword" : authPassword,
 		"publishRss" : $("#rss_news").attr("checked"),
 		"publishTwitter" : $("#twitter_news").attr("checked"),
 		"dbOldNames": dbOldNameArray,
@@ -156,16 +203,30 @@
 		alert("No link to WMS Capabilities URL given.");
 		return;
-	else{
+	else {
 		if($("#compare_dialog").attr("checked")) {
 			if (typeof $compareDialog == 'object') {
-                $compareDialog.dialog("destroy");
+                		$compareDialog.dialog("destroy");
+			} else {
 			var params = {
 				command:"getWmsData",
-				"wmsUrl" : $("#myURL").val()
+				"wmsUrl" : $("#myURL").val(),
 			$.post("../php/mb_getWmsData.php", params, function (json, status) {
 				if (status == 'success') {
@@ -285,8 +346,19 @@
 function sel(){
 	var ind = document.form1.selWMS.selectedIndex;
 	var wmsData = document.form1.selWMS.options[ind].value.split("###");
+	//alert(wmsData[3]);
+ 	if (wmsData[3] != '') {
+ 		document.form1.capURL.style.backgroundColor = "#ff0000";
+ 		document.form1.capURL.style.color = "#ffffff";
+ 	} else {
+ 		document.form1.capURL.style.backgroundColor = "#ffffff";
+ 		document.form1.capURL.style.color = "#000000";
 	document.form1.capURL.value = wmsData[1];
 	document.form1.myWMS.value = wmsData[0];
+    	document.form1.imrOldAuthType.value = wmsData[3];
+ 	document.form1.imrOldAuthName.value = wmsData[4];
+ 	document.form1.imrOldAuthPassword.value = wmsData[5];
 	//new for showing metadata - 30.05.2008 AR
 	document.getElementById("metadatalink").href = "mod_layerMetadata.php?id="+wmsData[2];
 	document.getElementById("metadatatext").firstChild.nodeValue = "WMS-ID: "+wmsData[0];
@@ -311,8 +383,8 @@
 	$v = array();
 	$t = array();
 	$c = 1;
-	//$sql = "SELECT wms_id, wms_title, wms_getcapabilities, wms_upload_url  FROM wms ";
-	$sql = "SELECT wms.wms_id, wms.wms_title, wms.wms_getcapabilities, wms.wms_upload_url, layer.layer_id  FROM wms, layer ";
+	$sql = "SELECT wms.wms_id, wms.wms_title, wms.wms_getcapabilities, wms.wms_upload_url, wms.wms_auth_type, ";
+ 	$sql .= "wms.wms_username, wms.wms_password, layer.layer_id  FROM wms, layer ";
 	$sql .= "WHERE wms_id IN(";
 	for($i=0; $i<count($wms_id_own); $i++){
 		if($wms_id_own[$i] != ''){
@@ -331,8 +403,7 @@
 	$cnt = 0;
 	echo "<select name='selWMS' size='15' onchange='sel()'>";
 	while($row = db_fetch_array($res)){
-		//echo "<option value='".$row['wms_id']."###".$row['wms_upload_url']."'>".$row['wms_title']."</option>";
-		echo "<option value='".$row['wms_id']."###".$row['wms_upload_url']."###".$row['layer_id']."'>".$row['wms_title']."</option>";
+		echo "<option value='".$row['wms_id']."###".$row['wms_upload_url']."###".$row['layer_id']."###".$row['wms_auth_type']."###".$row['wms_username']."###".$row['wms_password']."'>".$row['wms_title']."</option>";
 		$cnt++;
 	echo "</select><br /><br />";
@@ -341,14 +412,29 @@
 	view wms metadata: <a id='metadatalink' href='' onclick="window.open(this.href,'Metadaten','width=500,height=600,left=100,top=200,scrollbars=yes ,dependent=yes'); return false" target="_blank"><span id="metadatatext">no WMS selected</span></a><br><br>
 <?php
-	echo "Link to the last uploaded Online Resource URL:<br><input type='text' size='120' name='capURL'><br />";
+	echo "Link to the last uploaded Online Resource URL:<br><input type='text' size='120' name='capURL' id='capURL'><br />";
 	echo "<input type='hidden' name='myWMS' id='myWMS' value=''><br>";
 	echo "Add the following REQUEST to the Online Resource URL to obtain the Capabilities document:<br>";
 	echo "<i>(Triple click to select and copy)</i><br>";
 	echo "REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.1<br>";
 	echo "REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.1.0<br>";
 	echo "REQUEST=capabilities&WMTVER=1.0.0<br><br>";
-	echo "Link to new WMS Capabilities URL:<br><input size='120' type='text' name='myURL' id='myURL'><br>";
+	echo "HTTP Authentication:<br>";
+ 	echo "<input type='radio' name='imrHttpAuth' value='none' onclick='toggleAuthDivVis();' checked='checked' /> None<br>";
+ 	echo "<input type='radio' name='imrHttpAuth' value='digest' onclick='toggleAuthDivVis();' /> Digest<br>";
+ 	echo "<input type='radio' name='imrHttpAuth' value='basic' onclick='toggleAuthDivVis();' /> Basic<br>";
+ 	echo "<input type='radio' name='imrHttpAuth' value='keep' onclick='toggleAuthDivVis();' /> Keep old values<br>";
+ 	echo "<input type='hidden' name='imrOldAuthType' id='imrOldAuthType' />";
+ 	echo "<input type='hidden' name='imrOldAuthName' id = 'imrOldAuthName' />";
+ 	echo "<input type='hidden' name='imrOldAuthPassword' id = 'imrOldAuthPassword'/>";
+	echo "<input type='hidden' name='imrAuthType' id = 'imrAuthType'/>";
+ 	echo "<br>";
+ 	echo "<div id='imrAuthDiv' style='display: none;'>";
+ 	echo "Username : <input type='text' name='imrAuthName' id='imrAuthName' /><br>";
+ 	echo "Password : <input type='text' name='imrAuthPassword' id='imrAuthPassword'/><br><br>";
+ 	echo "</div>";
+ 	echo "Link to new WMS Capabilities URL:<br><input size='120' type='text' name='myURL' id='myURL'><br>";
 	if (defined("TWITTER_NEWS") && TWITTER_NEWS == true) {
 		echo"<input type='checkbox' name='twitter_news' id='twitter_news' checked='checked'>Publish via Twitter<br>";
@@ -357,18 +443,34 @@
 	echo"<input type='checkbox' name='compare_dialog' id='compare_dialog'><label for='compare_dialog'>Use compare dialog</label><br>";
 	echo "<input type='button' value='Preview Capabilities' onclick='window.open(this.form.myURL.value,\"\",\"\")'> ";
-	echo "<input type='button' value='Upload Capabilities' onclick='validate()'><br>";
+	echo "<input type='button' value='Upload Capabilities' onclick='validate()'> ";
+ 	echo "<input type='button' value='Reupload old service' onclick='reupload()'><br>";
 if(isset($myURL) && $myURL != ''){
-	$mywms = new wms();
-	$xml = $mywms->createObjFromXML($myURL);
+    	$mywms = new wms();
+ 	if (in_array($imrHttpAuth, array('basic','digest'))) {
+ 		$auth = array();
+ 		$auth['username'] = $imrAuthName;
+ 		$auth['password'] = $imrAuthPassword;
+ 		$auth['auth_type'] = $imrHttpAuth;
+ 		$mywms->createObjFromXML($myURL, $auth);
+ 	} elseif ($imrHttpAuth == 'keep') {
+ 		$auth = array();
+ 		$auth['username'] = $imrOldAuthName;
+ 		$auth['password'] = $imrOldAuthPasswword;
+ 		$auth['auth_type'] = $imrOldAuthType;
+ 	} else {
+ 		$mywms->createObjFromXML($myURL);
-	if($xml == "") {
+	/*if($xml == "") {
 	    echo "<br>WMS could not be loaded, no valid XML. Please check WMS GetCapabilities";
 	    die();
 	echo "<br />";
@@ -381,9 +483,15 @@
-	$updateObj = $mywms->updateObjInDB($myWMS);
+	//set values for default variables -> 4 parameters for authenticated services 3 for services without authentication - no metadataUpdate = false, changedLayers = null
+	if ($imrHttpAuth != 'none') {
+ 		$mywms->updateObjInDB($myWMS,false,null,$auth);
+ 	} else {
+ 		$mywms->updateObjInDB($myWMS);
 	echo "<div id='updateResult'>";
     	echo "</div>";
More information about the Mapbender_commits mailing list
