[Mapbender-commits] r8629 - in trunk/mapbender/http: classes plugins
svn_mapbender at osgeo.org
Sun May 26 05:18:54 PDT 2013
Author: armin11
Date: 2013-05-26 05:18:54 -0700 (Sun, 26 May 2013)
New Revision: 8629
trunk/mapbender/http/classes/class_iso19139.php
trunk/mapbender/http/plugins/mb_metadata_server.php
Some further enhancements for service content metadata editor and code cleaning.
Modified: trunk/mapbender/http/classes/class_iso19139.php
--- trunk/mapbender/http/classes/class_iso19139.php 2013-05-26 08:43:56 UTC (rev 8628)
+++ trunk/mapbender/http/classes/class_iso19139.php 2013-05-26 12:18:54 UTC (rev 8629)
@@ -627,8 +627,119 @@
- public function createFromDB($fileIdentifier){
- return $this;
+ public function createFromDBInternalId($metadataId){
+ $sql = "SELECT * from mb_metadata WHERE metadata_id = $1";
+ $v = array($metadataId);
+ $t = array('i');
+ $res = db_prep_query($sql,$v,$t);
+ if ($res) {
+ $row = db_fetch_assoc($res);
+ //fill object with information from mb_metadata table
+ //initialize empty iso19139 object
+ $this->fileIdentifier = $row['uuid'];
+ $this->title = $row['title'];
+ $this->abstract = $row['abstract'];
+ $this->createDate = $row['createdate'];//"1900-01-01";
+ $this->changeDate = $row['changedate'];//"1900-01-01";
+ $this->metadata = $row['data'];
+ //some possibilities:
+ $this->datasetId = $row['datasetid'];
+ $this->datasetIdCodeSpace = $row['datasetid_codespace'];
+ //fill keywords and categories later cause they are stored in relations!
+ /*$this->keywords = array();
+ $this->keywordsThesaurusName = array();
+ $this->isoCategoryKeys = array();
+ //following information is specific to mapbender information model - they are identified by id!
+ $this->isoCategories = array();
+ $this->inspireCategories = array();
+ $this->customCategories = array();
+ $this->hierachyLevel = $row['type'];
+ $this->tmpExtentBegin = $row['tmp_reference_1'];//"1900-01-01";
+ $this->tmpExtentEnd = $row['tmp_reference_2'];//"1900-01-01";
+ $this->randomId = $row['randomid'];
+ $this->owner = $row['fkey_mb_user_id']; //dummy entry for metadata owner - in case of metadataURL entries the owner of the corresponding service
+ $this->href = $row['link'];// "";
+ $this->format = $row['md_format'];//"";
+ $this->type = $row['linktype'];//"";
+ $this->origin = $row['origin'];//"";
+ $this->refSystem = $row['ref_system'];//"";
+ $this->harvestResult = $row['harvestresult'];//;0;
+ $this->harvestException = $row['harvestexception'];//"";
+ $this->lineage = $row['lineage'];//"";
+ $this->inspireTopConsistence = $row['inspire_top_consistance'];//"f";
+ $this->spatialResType = $row['spatial_res_type'];//"";
+ $this->spatialResValue = $row['spatial_res_value'];//"";
+ $this->export2Csw = $row['export2csw'];//"t";
+ $this->updateFrequency = $row['update_frequency'];//"";
+ $this->dataFormat = $row['format'];//"";
+ $this->inspireCharset = $row['inspire_charset'];//"";
+ //$this->linkAlreadyInDB = false;
+ //$this->fileIdentifierAlreadyInDB = false;
+ //get relations from other tables:
+ //get categories and keywords
+ //get isoCategories
+ $sql = <<<SQL
+SELECT md_topic_category_id, md_topic_category_code_en FROM mb_metadata_md_topic_category INNER JOIN md_topic_category ON mb_metadata_md_topic_category.fkey_md_topic_category_id = md_topic_category.md_topic_category_id WHERE mb_metadata_md_topic_category.fkey_metadata_id = $1
+SQL;
+ $t = array('i');
+ while ($row = db_fetch_assoc($res)) {
+ $this->isoCategories[] = (string)$row['md_topic_category_id'];
+ $this->isoCategoriesKeys[] = $row['md_topic_category_code_en'];
+ //get custom categories
+ $sql = <<<SQL
+SELECT custom_category_id FROM mb_metadata_custom_category INNER JOIN custom_category ON mb_metadata_custom_category.fkey_custom_category_id = custom_category.custom_category_id WHERE mb_metadata_custom_category.fkey_metadata_id = $1
+SQL;
+ $t = array('i');
+ $this->customCategories[] = (string)$row['custom_category_id'];
+ //generate one keyword entry with special thesaurus
+ $this->keywords[] = $row['fkey_custom_category_id'];
+ if (defined("METADATA_DEFAULT_CODESPACE") && METADATA_DEFAULT_CODESPACE != '') {
+ $this->keywordsThesaurusName[] = METADATA_DEFAULT_CODESPACE;
+ } else {
+ $this->keywordsThesaurusName[] = "http://www.mapbender.org";
+ //get inspire categories
+ $sql = <<<SQL
+SELECT inspire_category_id, inspire_category_key FROM mb_metadata_inspire_category INNER JOIN inspire_category ON mb_metadata_inspire_category.fkey_inspire_category_id = inspire_category.inspire_category_id WHERE mb_metadata_inspire_category.fkey_metadata_id = $1
+SQL;
+ $t = array('i');
+ $this->inspireCategories[] = (string)$row['inspire_category_id'];
+ $this->keywords[] = $row['inspire_category_key'];
+ $this->keywordsThesaurusName[] = "GEMET - INSPIRE themes, version 1.0";
+ //get other keywords from keyword table - only fill in, if not already in keywords!
+ $sql = <<<SQL
+SELECT keyword FROM mb_metadata_keyword INNER JOIN keyword ON mb_metadata_keyword.fkey_keyword_id = keyword.keyword_id WHERE mb_metadata_keyword.fkey_metadata_id = $1
+SQL;
+ $t = array('i');
+ if (!in_array($row['keyword'],$this->keywords)) {
+ $this->keywords[] = $row['keyword'];
+ $this->keywordsThesaurusName[] = "";
+ } else {
+ $e = new mb_exception("Could not get metadata with id ".$metadataId." from DB!");
+ return false;
+ return true;
//the following functions are only for the simple metadata editor
@@ -893,6 +1004,7 @@
$countExistingKeywords = 0;
$existingKeywords[$countExistingKeywords]['keyword'] = $row['keyword'];
+ $e = new mb_exception("existing keyword: ".$row['keyword']);
$existingKeywords[$countExistingKeywords]['id'] = $row['keyword_id'];
$existingKeywordsArray[$countExistingKeywords] = $row['keyword'];
$countExistingKeywords++;
@@ -912,10 +1024,12 @@
$sqlInsert = rtrim($sqlInsert,",");
$sql = "INSERT INTO mb_metadata_keyword (fkey_metadata_id, fkey_keyword_id) VALUES ".$sqlInsert;
- $e = new mb_notice("class_Iso19139.php: sql for keywords: ".$sql);
+ $e = new mb_exception("class_Iso19139.php: sql for keywords: ".$sql);
$res = db_query($sql);
if (!$res) {
$e = new mb_exception("class_Iso19139:"._mb("Cannot insert keyword relations for this metadata!"));
+ } else {
+ $e = new mb_exception("class_Iso19139:"._mb("Inserted keyword relations for existing keywords!"));
//insert those keywords, that are not already in the keyword table
@@ -929,9 +1043,20 @@
$sqlInsert = "";
- $otherKeywords = array_diff($this->keywords,$existingKeywordsArray);
+ //test if $existingKeywordsArray is array!
+ if (is_array($existingKeywordsArray)) {
+ $otherKeywords = array_values(array_diff($this->keywords,$existingKeywordsArray));
+ } else {
+ $otherKeywords = $this->keywords;
+ //debug
+ foreach ($otherKeywords as $test) {
+ $e = new mb_exception("otherKeywords: ".$test);
+ $e = new mb_exception("otherKeywords: ".$otherKeywords);
if (count($otherKeywords) > 0) {
if (count($otherKeywords) == 1) {
+ $e = new mb_exception("Only one new keyword found: ".$otherKeywords[0]);
//keyword table
$sqlInsert .= "('".$otherKeywords[0]."')";
} else {
@@ -941,7 +1066,7 @@
$sql = "INSERT INTO keyword (keyword) VALUES ".$sqlInsert." RETURNING keyword_id" ;
if (!$res) {
$e = new mb_exception("class_Iso19139:"._mb("Cannot insert new keywords into keyword table!"));
@@ -954,7 +1079,7 @@
if (count($insertedKeywordIds) == 1) {
//keyword relation table
- $sqlInsert .= "(".$insertedKeywordIds[0].")";
+ $sqlInsert .= "(".(integer)$metadataId.",".$insertedKeywordIds[0].")";
} else {
foreach ($insertedKeywordIds as $insertedKeywordId) {
$sqlInsert .= "(".(integer)$metadataId.",".(integer)$insertedKeywordId."),";
@@ -1053,7 +1178,7 @@
- private function updateMetadataById($metadataId) {
+ public function updateMetadataById($metadataId) {
//check if the timestamp of an existing metadata element is not newer than the timestamp of the current metadata object!!!!
//TODO
//problem: <<<SQL have a limited number of chars!
Modified: trunk/mapbender/http/plugins/mb_metadata_server.php
--- trunk/mapbender/http/plugins/mb_metadata_server.php 2013-05-26 08:43:56 UTC (rev 8628)
+++ trunk/mapbender/http/plugins/mb_metadata_server.php 2013-05-26 12:18:54 UTC (rev 8629)
@@ -656,13 +656,10 @@
$ajaxResponse->setSuccess(false);
break;
case "getWmsIdByLayerId" :
$layerId = $ajaxResponse->getParameter("layerId");
$sql = <<<SQL
SELECT fkey_wms_id from layer where layer_id = $1
SQL;
$v = array($layerId);
$t = array('i');
@@ -676,37 +673,29 @@
$ajaxResponse->setSuccess(true);
break;
case "getLayerMetadataAddon" :
- $layerId = $ajaxResponse->getParameter("layerId");
+ //$layerId = $ajaxResponse->getParameter("layerId");
$metadataId = $ajaxResponse->getParameter("metadataId");
- $sql = <<<SQL
-SELECT * from mb_metadata where metadata_id = $1
-SQL;
- $v = array($metadataId);
- $t = array('i');
- $res = db_prep_query($sql,$v,$t);
- $row = array();
- if ($res) {
- $row = db_fetch_assoc($res);
- $resultObj["metadata_id"]= $row['metadata_id']; //serial
- $resultObj["uuid"] = $row["uuid"]; //char
- $resultObj["origin"] = $row["origin"]; //char
- $resultObj["link"] = $row["link"]; //char
- $resultObj["linktype"] = $row["linktype"]; //char
- $resultObj["title"] = $row["title"]; //char -- prefill from layer
- $resultObj["abstract"] = $row["abstract"]; //char - prefill from layer
- $resultObj["format"] = $row["format"]; //char
- $resultObj["ref_system"] = $row["ref_system"]; //char
- $resultObj["spatial_res_type"] = $row["spatial_res_type"]; //integer
- $resultObj["spatial_res_value"] = $row["spatial_res_value"]; //char
- $resultObj["inspire_charset"] = $row["inspire_charset"]; //char
- $resultObj["lineage"] = $row["lineage"]; //text
- $resultObj["tmp_reference_1"] = $row["tmp_reference_1"]; //text
- $resultObj["tmp_reference_2"] = $row["tmp_reference_2"]; //text
- $export2csw = $row["export2csw"]; //boolean
- $resultObj["update_frequency"] = $row["update_frequency"]; //text
+ $mbMetadata = new Iso19139();
+ $result = $mbMetadata->createFromDBInternalId($metadataId);
+ if ($result) {
+ //map metadata object to json return object
+ $resultObj["metadata_id"]= $metadataId; //is not part of the object TODO!
+ $resultObj["uuid"] = $mbMetadata->fileIdentifier; //char
+ $resultObj["origin"] = $mbMetadata->origin; //char
+ $resultObj["link"] = $mbMetadata->href; //char
+ $resultObj["linktype"] = $mbMetadata->type; //char
+ $resultObj["title"] = $mbMetadata->title; //char -- prefill from layer
+ $resultObj["abstract"] = $mbMetadata->abstract; //char - prefill from layer
+ $resultObj["format"] = $mbMetadata->dataFormat; //char
+ $resultObj["ref_system"] = $mbMetadata->refSystem; //char
+ $resultObj["spatial_res_type"] = $mbMetadata->spatialResType; //integer
+ $resultObj["spatial_res_value"] = $mbMetadata->spatialResValue; //char
+ $resultObj["inspire_charset"] = $mbMetadata->inspireCharset; //char
+ $resultObj["lineage"] = $mbMetadata->lineage; //text
+ $resultObj["tmp_reference_1"] = $mbMetadata->tmpExtentBegin; //text
+ $resultObj["tmp_reference_2"] = $mbMetadata->tmpExtentEnd; //text
+ $export2csw = $mbMetadata->export2Csw; //boolean
+ $resultObj["update_frequency"] = $mbMetadata->updateFrequency; //text
switch ($export2csw) {
case "t" :
$resultObj["export2csw"] = true;
@@ -717,7 +706,7 @@
default:
break;
- $inspire_top_consistence = $row["inspire_top_consistence"]; //boolean
+ $inspire_top_consistence = $mbMetadata->inspireTopConsistence; //boolean
switch ($inspire_top_consistence) {
case "t" :
$resultObj["inspire_top_consistence"] = true;
@@ -727,50 +716,33 @@
break;
default:
break;
+ //categories and keywords
+ $resultObj["md_md_topic_category_id"] = $mbMetadata->isoCategories;
+ $resultObj["md_custom_category_id"] = $mbMetadata->customCategories;
+ $resultObj["md_inspire_category_id"] = $mbMetadata->inspireCategories;
+ //only pull keywords without a thesaurus name!!
+ for ($i = 0; $i < count($mbMetadata->keywords); $i++) {
+ if ($mbMetadata->keywordsThesaurusName[$i] == "" or $mbMetadata->keywordsThesaurusName[$i] == "none") {
+ $resultObj["keywords"][] = $mbMetadata->keywords[$i];
+ $resultObj["keywords"] = implode(",",$resultObj["keywords"]);
+ //give back result:
+ $ajaxResponse->setResult($resultObj);
+ $ajaxResponse->setSuccess(true);
+ break;
+ } else {
+ //could not read metadata from db
+ $ajaxResponse->setMessage(_mb("Could not get metadata object from database!"));
+ $ajaxResponse->setSuccess(false);
+ break;
- //get categories and keywords
- //get isoCategories
- $sql = <<<SQL
-SELECT fkey_md_topic_category_id FROM mb_metadata_md_topic_category where fkey_metadata_id = $1
-SQL;
- $t = array('i');
- while ($row = db_fetch_assoc($res)) {
- $resultObj["md_md_topic_category_id"][]= $row["fkey_md_topic_category_id"];
- //get custom categories
- $sql = <<<SQL
-SELECT fkey_custom_category_id FROM mb_metadata_custom_category where fkey_metadata_id = $1
-SQL;
- $t = array('i');
- $resultObj["md_custom_category_id"][]= $row["fkey_custom_category_id"];
- //get inspire categories
- $sql = <<<SQL
-SELECT fkey_inspire_category_id FROM mb_metadata_inspire_category where fkey_metadata_id = $1
-SQL;
- $t = array('i');
- $resultObj["md_inspire_category_id"][]= $row["fkey_inspire_category_id"];
- $ajaxResponse->setResult($resultObj);
- $ajaxResponse->setSuccess(true);
- break;
case "getInitialLayerMetadata" :
$sql = <<<SQL
SELECT layer_title, layer_abstract from layer where layer_id = $1
SQL;
$t = array('i');
@@ -785,92 +757,73 @@
break;
case "updateLayerMetadataAddon" :
+ //get json data from ajax call
$data = $ajaxResponse->getParameter("data");
- if ($data->export2csw) {
- $data->export2csw = 't';
- } else {
- $data->export2csw = 'f';
- if ($data->inspire_top_consistence) {
- $data->inspire_top_consistence = 't';
- } else {
- $data->inspire_top_consistence = 'f';
- //new for keywords and classifications:
- /*if (isset($data->keywords) && $data->keywords != "") {
- $mbMetadata->keywords = explode(',',$data->keywords);
- //for all those keywords don't set a special thesaurus name
- foreach ($mbMetadata->keywords as $keyword) {
- $mbMetadata->keywordsThesaurusName[] = "none";
+ //initialize actual metadata object from db!
+ if ($result) {
+ if ($data->export2csw) {
+ $mbMetadata->export2Csw = 't';
+ } else {
+ $mbMetadata->export2Csw = 'f';
- if (isset($data->md_md_topic_category_id)) {
- $mbMetadata->isoCategories = $data->md_md_topic_category_id;
- if (isset($data->md_inspire_category_id)) {
- $inspireCategories = $data->md_inspire_category_id;
- $e = new mb_exception($inspireCategories);
- if (count($inspireCategories) > 1 ) {
- //for all those keywords set a special thesaurus name
- foreach ($inspireCategories as $keyword) {
- $mbMetadata->keywords[] = $keyword;
- $mbMetadata->keywordsThesaurusName[] = "GEMET - INSPIRE themes, version 1.0";
+ if ($data->inspire_top_consistence) {
+ $mbMetadata->inspireTopConsistence = 't';
} else {
- $mbMetadata->keywords[] = $inspireCategories;
+ $mbMetadata->inspireTopConsistence = 'f';
- if (isset($data->md_custom_category_id)) {
- $customCategories = $data->md_custom_category_id;
- if (count($customCategories) > 1 ) {
+ //$mbMetadata->fileIdentifier = $metadataId;
+ $mbMetadata->href = $data->link;
+ $mbMetadata->title = $data->title;
+ $mbMetadata->abstract = $data->abstract;
+ $mbMetadata->dataFormat = $data->format;
+ $mbMetadata->refSystem = $data->ref_system;
+ $mbMetadata->tmpExtentBegin = $data->tmp_reference_1;
+ $mbMetadata->tmpExtentEnd = $data->tmp_reference_2;
+ $mbMetadata->lineage = $data->lineage;
+ $mbMetadata->spatialResType = $data->spatial_res_type;
+ $mbMetadata->spatialResValue = $data->spatial_res_value;
+ $mbMetadata->inspireCharset = $data->inspire_charset;
+ $mbMetadata->updateFrequency = $data->update_frequency;
+ //categories ...
+ //new for keywords and classifications:
+ if (isset($data->keywords) && $data->keywords != "") {
+ $mbMetadata->keywords = array_map('trim',explode(',',$data->keywords));
- foreach ($customCategories as $keyword) {
- if (defined("METADATA_DEFAULT_CODESPACE") && METADATA_DEFAULT_CODESPACE != '') {
- $mbMetadata->keywordsThesaurusName[] = METADATA_DEFAULT_CODESPACE;
- } else {
- $mbMetadata->keywordsThesaurusName[] = "http://www.mapbender.org";
+ foreach ($mbMetadata->keywords as $keyword) {
+ $mbMetadata->keywordsThesaurusName[] = "none";
+ if (isset($data->md_md_topic_category_id)) {
+ $mbMetadata->isoCategories = $data->md_md_topic_category_id;
+ if (isset($data->md_inspire_category_id)) {
+ $mbMetadata->inspireCategories = $data->md_inspire_category_id;
+ if (isset($data->md_custom_category_id)) {
+ $mbMetadata->customCategories = $data->md_custom_category_id;
+ //try to update metadata object (only mb_metadata)
+ $res = $mbMetadata->updateMetadataById($metadataId);
+ if (!$res) {
+ //could not update metadata in db
+ $ajaxResponse->setMessage(_mb("Could not update metadata object in database!"));
} else {
- $mbMetadata->keywords[] = $customCategories;
- } else {
+ //update relations for keywords and categories
+ $mbMetadata->insertKeywordsAndCategoriesIntoDB($metadataId);
+ $ajaxResponse->setMessage(_mb("Edited metadata was updated in the mapbender database!"));
- }*/ //no mbMetadata instantiated till now
- $sql = <<<SQL
-UPDATE mb_metadata SET link = $2, title = $3, abstract = $4, format = $5, ref_system = $6, export2csw = $7, inspire_top_consistence = $8, tmp_reference_1 = $9, tmp_reference_2 = $10, lineage = $11, spatial_res_type = $12, spatial_res_value = $13, inspire_charset = $14, changedate = now(), update_frequency = $15 WHERE metadata_id = $1
-SQL;
- $v = array($metadataId, $data->link, $data->title, $data->abstract, $data->format, $data->ref_system, $data->export2csw, $data->inspire_top_consistence, $data->tmp_reference_1, $data->tmp_reference_2, $data->lineage, $data->spatial_res_type, $data->spatial_res_value, $data->inspire_charset, $data->update_frequency);
- $t = array('i','s','s','s','s','s','b','b','s','s','s','s','s','s','s');
- try {
- catch (Exception $e){
+ } else {
- $ajaxResponse->setMessage(_mb("Could not update metadata object in database!"));
- $ajaxResponse->send();
- die;
- //delete all categories
- //TODO!!!
- //newly create them
- $ajaxResponse->setMessage("Metadata updated!");
break;
case "getOwnedMetadata" :
@@ -1023,7 +976,6 @@
//Check if origin is external and export2csw is activated!
if ($origin == 'external' ) {
//harvest link from location, parse the content for datasetid and push xml into data column
@@ -1033,9 +985,7 @@
$mbMetadata->type = "ISO19115:2003";
$mbMetadata->origin = "external";
$mbMetadata->owner = $mdOwner;
$result = $mbMetadata->insertToDB("layer",$layerId);
if ($result['value'] == false){
$e = new mb_exception("Problem while storing metadata to mb_metadata table!");
$e = new mb_exception($result['message']);
@@ -1089,7 +1039,6 @@
//$ajaxResponse->send();
//die();
break;
case "importLayerXmlAddon" :
//this case is similar to insert the metadata from external link, but came from internal file from tmp folder which has been uploaded before
@@ -1112,9 +1061,7 @@
$mbMetadata->origin = "upload";
$e = new mb_exception("Problem while storing uploaded metadata xml to mb_metadata table!");
@@ -1126,12 +1073,10 @@
break;
default:
$ajaxResponse->setMessage(_mb("An unknown error occured."));
break;
More information about the Mapbender_commits
