[Mapbender-commits] r8711 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org
Fri Oct 4 03:20:37 PDT 2013
Author: armin11
Date: 2013-10-04 03:20:37 -0700 (Fri, 04 Oct 2013)
New Revision: 8711
Added:
trunk/mapbender/http/plugins/mb_metadata_gml_import.js
First draft to upload a simple gml polygon to mb_metadata table
Added: trunk/mapbender/http/plugins/mb_metadata_gml_import.js
--- trunk/mapbender/http/plugins/mb_metadata_gml_import.js (rev 0)
+++ trunk/mapbender/http/plugins/mb_metadata_gml_import.js 2013-10-04 10:20:37 UTC (rev 8711)
@@ -0,0 +1,88 @@
+var $gmlImport = $(this);
+var importGmlMetadataId;
+var GmlImportApi = function () {
+ var that = this;
+ var type;
+ this.events = {
+ "uploadComplete" : new Mapbender.Event()
+ this.events.uploadComplete.register(function () {
+ $gmlImport.dialog("close");
+ var importUploadedFile = function(filename, metadataId, callback){
+ var req = new Mapbender.Ajax.Request({
+ url: "../plugins/mb_metadata_server.php",
+ method: "importGmlAddon",
+ parameters: {
+ filename: filename,
+ "metadataId": metadataId
+ callback: function (obj, result, message, errorCode) {
+ if (!result) {
+ switch (errorCode) {
+ case -1002:
+ alert("file: "+filename+"has problems: "+message);
+ break;
+ default:
+ alert(message);
+ return;
+ alert(message);
+ //invoke external script from mb_metadata_showMetadataAddon.js
+ //that.fillLayerForm(layerId);
+ //Mapbender.modules.mb_md_showMetadataAddon.fillLayerForm(layerId);
+ if ($.isFunction(callback)) {
+ callback(obj.id);
+ req.send();
+ $gmlImport.upload({
+ size: 10,
+ timeout: 20000,
+ url: "../plugins/jq_upload.php",
+ callback: function(result,stat,msg){
+ if(!result){
+ alert(msg);
+ return;
+ var uploadResultName = result.filename;
+ var uploadResultOrigName = result.origFilename;
+ importUploadedFile(result.filename, that.importGmlMetadataId, function (id) {
+ that.events.uploadComplete.trigger({
+ "type": type,
+ "id": id
+ }).dialog({
+ title: 'GML Import',
+ autoOpen: false,
+ modal: false,
+ width: 580
+ this.init = function (obj) {
+ type = obj.type;
+ $gmlImport.dialog("open");
+ initGmlImport = function (metadataId) {
+ that.importGmlMetadataId = metadataId;
+ return true;
+$gmlImport.mapbender(new GmlImportApi());
More information about the Mapbender_commits
