[Mapbender-commits] r8699 - in trunk/mapbender: conf http/php http/plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Sep 3 06:25:20 PDT 2013
Author: armin11
Date: 2013-09-03 06:25:18 -0700 (Tue, 03 Sep 2013)
New Revision: 8699
Added:
   trunk/mapbender/conf/mimetype.conf
   trunk/mapbender/http/php/mod_inspireDownloadFeed.php
   trunk/mapbender/http/plugins/mb_metadata_addon.php
New possibility to fully support INSPIRE Downloadservices with the OpenSearch interface (GetSpatialDataset/DescribeSpatialDataset operations).
Added: trunk/mapbender/conf/mimetype.conf
--- trunk/mapbender/conf/mimetype.conf	                        (rev 0)
+++ trunk/mapbender/conf/mimetype.conf	2013-09-03 13:25:18 UTC (rev 8699)
@@ -0,0 +1,26 @@
+<?php
+//Mapping hashtable mediatypes and file formats of corresponding metadata (iso19139) - in mb_metadata table
+//http://inspire.ec.europa.eu/media-types/
+$formatsMimetype = array(
+	"Esri Shape" => "application/x-shapefile",
+	"Esri File Geodatabase" => "application/x-filegdb",
+	"GeoTIFF" => "image/tiff" ,
+	"GML" => "application/gml+xml",
+	"Zipped GML" => "application/x-gmz",
+	"KML" => "application/vnd.google-earth.kml+xml",
+	"KMZ" => "application/vnd.google-earth.kmz",
+	"JPEG 2000" => "image/jp2",
+	"MapInfo Tab file" => "application/x-tab",
+	"MapInfo Tab raster file" => "application/x-tab-raster",
+	"CSV" => "text/csv",
+	"Database" => "text/sql"
+$formats = array(
+	"Database",
+	"Esri Shape",
+	"MapInfo Tab file",
+	"CSV",
+	"GML",
+	"GeoTIFF"
Modified: trunk/mapbender/http/php/mod_inspireDownloadFeed.php
--- trunk/mapbender/http/php/mod_inspireDownloadFeed.php	2013-08-29 14:57:08 UTC (rev 8698)
+++ trunk/mapbender/http/php/mod_inspireDownloadFeed.php	2013-09-03 13:25:18 UTC (rev 8699)
@@ -1,6 +1,6 @@
 <?php
 //2012-06-15-http://localhost/mapbender/php/mod_inspireDownloadFeed.php?id=70e0c3e5-707c-f8e1-8037-7b38702176d9&type=SERVICE&generatefrom=all
+//example: 2013-09-03 http://www.geoportal.rlp.de/mapbender/php/mod_inspireDownloadFeed.php?id=e9d22d13-e045-f0e0-25cc-1f146d681216&type=DATASET&generateFrom=wfs&wfsid=216&OPENSEARCH=true&spatial_dataset_identifier_code=e9d22d13-e045-f0e0-25cc-1f146d681216&spatial_dataset_identifier_namespace=http%3A%2F%2Fwww.geoportal.rlp.de&crs=EPSG:25832&language=de
 //20648
 // $Id: mod_inspireDownloadFeed.php 235
 // http://www.mapbender.org/index.php/
@@ -27,6 +27,8 @@
 require_once(dirname(__FILE__) . "/../classes/class_administration.php");
 require_once dirname(__FILE__) . "/../../core/epsg.php";
 require_once(dirname(__FILE__) . "/../classes/class_Uuid.php");
+require_once(dirname(__FILE__) . "/../../conf/mimetype.conf");
 //check_epsg_wms_13($tmp_epsg)
 //http://www.weichand.de/inspire/dls/verwaltungsgrenzen.xml
 $con = db_connect(DBSERVER,OWNER,PW);
@@ -42,6 +44,11 @@
 $maxFeatureCount = 100;
 $alterAxisOrder = false;
+$numberOfTiles = 0;
+$furtherLink = array();
 //pull the needed things from tables datalink, md_metadata, layer, wms
 //parse request parameter
@@ -150,6 +157,68 @@
 	$testMatch = NULL;
+//parse opensearch parameters - used if $openSearch=true
+//q, spatial_dataset_identifier_namespace, spatial_dataset_identifier_code, crs, language
+if (isset($_REQUEST['q']) & $_REQUEST['q'] != "") {
+	//validate type
+	$testMatch = $_REQUEST["q"];
+ 	/*if ($testMatch != 'wmslayer' && $testMatch != 'dataurl'  && $testMatch != 'wfs' && $testMatch != 'all'){
+		//echo 'GENERATEFROM: <b>'.$testMatch.'</b> is not valid.<br/>';
+		echo 'Parameter <b>GENERATEFROM</b> is not valid (wmslayer,dataurl,wfs,all).<br/>';
+		die();
+	$osQuery = $testMatch;
+	$testMatch = NULL;
+if (isset($_REQUEST['spatial_dataset_identifier_namespace']) & $_REQUEST['spatial_dataset_identifier_namespace'] != "") {
+	//validate type
+	$testMatch = $_REQUEST["spatial_dataset_identifier_namespace"];
+		die();
+	$osDatasetNamespace = $testMatch;
+if (isset($_REQUEST['spatial_dataset_identifier_code']) & $_REQUEST['spatial_dataset_identifier_code'] != "") {
+	//validate type
+	$testMatch = $_REQUEST["spatial_dataset_identifier_code"];
+		die();
+	$osDatasetIdentifier = $testMatch;
+if (isset($_REQUEST['crs']) & $_REQUEST['crs'] != "") {
+	//validate type TODO
+	$testMatch = $_REQUEST["crs"];
+		die();
+	$osCrs = $testMatch;
+if (isset($_REQUEST['language']) & $_REQUEST['language'] != "") {
+	$testMatch = $_REQUEST["language"];
+		die();
+	$osLanguage = $testMatch;
 if ($generateFrom == "wmslayer") {
 	//check if layerId is set too
 	if (isset($_REQUEST['LAYERID']) & $_REQUEST['LAYERID'] != "") {
@@ -192,8 +261,171 @@
 $feedDoc->preserveWhiteSpace = false;
 $feedDoc->formatOutput = true;
+/*function addToQuery($paramName,$queryString,$string,$queryList) {
+	//test if string was part of query before, if so, don't extent the query
+	//TODO: the strings come from json and so they are urlencoded! maybe we have to decode them to find the commata
+	$queryListComma = urldecode($queryList);
+	$queryListC = ",".$queryListComma.",";
+	$pattern = ','.$string.',';
+ 	if (!preg_match($pattern, $queryListC)){
+		//append the new element
+		$queryListNew = $queryListC.$string;
+		//echo "query string new: ".$queryListNew."<br>";
+		//delete the commatas
+		$queryListNew = ltrim($queryListNew,',');
+		//generate the new query string
+		$queryStringNew = str_replace($paramName.'='.$queryList,$paramName.'='.$queryListNew,$queryString);
+		return $queryStringNew;
+	} else {
+		return $queryString;
+// function to delete one GET parameter totally from a query url
+function delTotalFromQuery($paramName,$queryString) {
+	$queryString = "&".$queryString;
+	$queryStringNew = preg_replace('/\b'.$paramName.'\=[^&]+&?/',$str2exchange,$queryString);
+	$queryStringNew = ltrim($queryStringNew,'&');
+	$queryStringNew = rtrim($queryStringNew,'&');
+function answerOpenSearchRequest () {
+	global $admin, $type, $mapbenderMetadata, $indexMapbenderMetadata, $layerId, $wfsId, $mapbenderPath, $epsgId, $alterAxisOrder, $departmentMetadata, $userMetadata, $hasPermission, $m, $crs, $crsUpper, $countRessource, $furtherLink, $osDatasetIdentifier, $osQuery, $osDatasetNamespace, $osCrs, $osLanguage;
+	//service feed url
+	$serviceFeed = delTotalFromQuery("getopensearch",$mapbenderPath."..".$_SERVER['REQUEST_URI']);//delete GETOPENSEARCH
+	$serviceFeed = delTotalFromQuery("OPENSEARCH",$serviceFeed);
+	//echo $serviceFeed;
+	//die();
+	//datasetfeed url
+	$datasetFeed = str_replace("=SERVICE&","=DATASET&",$serviceFeed);
+	//echo $datasetFeed;
+	//die();
+	$returnFile = false;
+	switch ($generateFrom) {
+				case "dataurl":
+					$mimetype = $formatsMimetype[$mapbenderMetadata[$m]->format];
+				break;
+				case "wmslayer":
+					$mimetype = "image/tiff";
+				break;
+				case "wfs":
+					$mimetype = "application/gml+xml";
+				break;
+	//check correct headers
+	foreach (apache_request_headers() as $name => $value) {
+		if ($name == "Accept" && $value == $mimetype) {
+			$returnFile = true;
+	//TODO comment this line in productive environment - see inspire guidance for opensearch script
+	//check for identifier
+	/*$e = new mb_exception("mod_inspireDownloadFeed.php: osDatasetIdentifier: ".$osDatasetIdentifier);
+	$e = new mb_exception("mod_inspireDownloadFeed.php: osQuery: ".$osQuery);
+	$e = new mb_exception("mod_inspireDownloadFeed.php: osDatasetNamespace: ".$osDatasetNamespace);
+	$e = new mb_exception("mod_inspireDownloadFeed.php: numberOfTiles: ".$numberOfTiles);*/
+	if (!$osDatasetIdentifier) {
+		if (!$osQuery) {
+			//redirect to service feed
+			header("Location: ".$serviceFeed);
+			die();
+		//the query search for an identifier ?
+		$osDatasetIdentifier = $osQuery;
+	//check namespace
+	if (!$osDatasetNamespace) {
+			echo "No namespace given!";
+			die();
+	//check crs and language
+	if ($osCrs && $osCrs != $crs) {
+		echo "Dataset not available in requested crs!";
+		die();
+	if (!$osLanguage || $osLanguage == "*") {
+		$osLanguage = "de";
+	if ($osLanguage != "de") {
+		echo "Dataset not available in requested language!";
+		die();
+	//check count of links
+	//redirect to downloadlink
+	//parse dataset atom feed and count links - maybe one or multiple!!!!
+	$links = getDatasetFeedLinks($datasetFeed);
+	$numberOfTiles = count($links);
+	//$e = new mb_exception("mod_inspireDownloadFeed.php: numberOfTiles: ".$numberOfTiles);
+	if ($numberOfTiles > 1) {
+		//redirect to dataset atom feed
+		header("Location: ".$datasetFeed);
+	} else {
+		if ($returnFile) {
+			//echo "links[0]:". $links[0];
+			//die();
+			header("Location: ".$links[0]);
+		} else {
+			//redirect to datasetfeed
+	die();
+function getDatasetFeedLinks($datasetFeedUrl) {
+	//$links = array();
+	//get feed from remote server
+	$feedConnector = new connector($datasetFeedUrl);
+	$feedConnector->set("timeOut", "10");
+	$feedFile = $feedConnector->file;
+	libxml_use_internal_errors(true);
+	try {
+		$feedXML = simplexml_load_string($feedFile);
+		if ($feedXML === false) {
+			foreach(libxml_get_errors() as $error) {
+        			$err = new mb_exception("mod_inspireDownloadFeed.php:".$error->message);
+			throw new Exception("mod_inspireDownloadFeed.php:".'Cannot parse Feed!');
+			return false;
+	catch (Exception $e) {
+    		$err = new mb_exception("mod_inspireDownloadFeed.php:".$e->getMessage());
+		return false;
+	if ($feedXML != false) {
+		$feedXML->registerXPathNamespace("georss", "http://www.georss.org/georss");
+		$feedXML->registerXPathNamespace("inspire_dls", "http://inspire.ec.europa.eu/schemas/inspire_dls/1.0");
+		$feedXML->registerXPathNamespace("defaultns", "http://www.w3.org/2005/Atom");
+		$title = $feedXML->xpath('/defaultns:feed/defaultns:entry/defaultns:title');
+		//TODO: This is only possible, if one entry is available as it is now. Maybe altered later.
+		$title = $title[0];
+		//for ($i=0; $i<=(count($title)-1); $i++) {
+			$links = $feedXML->xpath('/defaultns:feed/defaultns:entry[1]/defaultns:link/@href');
+	return $links;
 function generateOpenSearchDescription($feedDoc, $recordId, $generateFrom) {
-	global $admin, $type, $mapbenderMetadata, $indexMapbenderMetadata, $layerId, $wfsId, $mapbenderPath, $epsgId, $alterAxisOrder, $departmentMetadata, $userMetadata, $hasPermission, $m, $crs, $crsUpper, $countRessource;
+	global $admin, $type, $mapbenderMetadata, $indexMapbenderMetadata, $layerId, $wfsId, $mapbenderPath, $epsgId, $alterAxisOrder, $departmentMetadata, $userMetadata, $hasPermission, $m, $crs, $crsUpper, $countRessource, $numberOfTiles;
+				case "dataurl":
+				break;
+				case "wmslayer":
+				break;
+				case "wfs":
+				break;
 	//part which generates the feed
 	$feed =  $feedDoc->createElementNS('http://a9.com/-/spec/opensearch/1.1/', 'OpenSearchDescription');
 	$feed = $feedDoc->appendChild($feed);
@@ -215,26 +447,34 @@
 	$urlSelf = $feedDoc->createElement("Url");
 	$urlSelf->setAttribute("type", "application/opensearchdescription+xml");
 	$urlSelf->setAttribute("rel", "self");
-	$urlSelf->setAttribute("template", $mapbenderPath."..".$_SERVER['SCRIPT_NAME']."?getopensearch=true");
+	$urlSelf->setAttribute("template", $mapbenderPath."..".$_SERVER['REQUEST_URI']);
 	$feed->appendChild($urlSelf);
 	//Url - results Atom
 	$urlSelf->setAttribute("type", "application/atom+xml");
 	$urlSelf->setAttribute("rel", "results");
-	$urlSelf->setAttribute("template", $mapbenderPath."..".$_SERVER['SCRIPT_NAME']."?q={searchTerms}");
+	$urlSelf->setAttribute("template", str_replace("=SERVICE&","=DATASET&",$mapbenderPath."..".$_SERVER['REQUEST_URI']).str_replace("&","&","&OPENSEARCH=true&q={searchTerms}"));
 	//Url - describedby
 	$urlDescribedby = $feedDoc->createElement("Url");
 	$urlDescribedby->setAttribute("type", "application/atom+xml");
 	$urlDescribedby->setAttribute("rel", "describedby");
-	$urlDescribedby->setAttribute("template", $mapbenderPath."..".$_SERVER['SCRIPT_NAME']."?spatial_dataset_identifier_code={inspire_dls:spatial_dataset_identifier_code?}&spatial_dataset_identifier_namespace={inspire_dls:spatial_dataset_identifier_namespace?}&crs={inspire_dls:crs?}&language={language?}&q={searchTerms?}");
+	//see documentation
+	$urlDescribedby->setAttribute("template", str_replace("=SERVICE&","=DATASET&",$mapbenderPath."..".$_SERVER['REQUEST_URI']).str_replace("&","&","&OPENSEARCH=true&spatial_dataset_identifier_code={inspire_dls:spatial_dataset_identifier_code?}&spatial_dataset_identifier_namespace={inspire_dls:spatial_dataset_identifier_namespace?}&crs={inspire_dls:crs?}&language={language?}&q={searchTerms?}"));
 	$feed->appendChild($urlDescribedby);
 	//Url - results single part (e.g. zipfile)
 	$urlResults = $feedDoc->createElement("Url");
-	$urlResults->setAttribute("type", "application/zip");
+	$urlResults->setAttribute("type", $mimetype);//TODO give reasonable format!! - mimetypes??? geotiff/gml/other - see format of metadata
 	$urlResults->setAttribute("rel", "results");
-	$urlResults->setAttribute("template", $mapbenderPath."..".$_SERVER['SCRIPT_NAME']."?spatial_dataset_identifier_code={inspire_dls:spatial_dataset_identifier_code?}&spatial_dataset_identifier_namespace={inspire_dls:spatial_dataset_identifier_namespace?}&crs={inspire_dls:crs?}&language={language?}&q={searchTerms?}");
+	$urlResults->setAttribute("template", str_replace("=SERVICE&","=DATASET&",$mapbenderPath."..".$_SERVER['REQUEST_URI']).str_replace("&","&","&OPENSEARCH=true&spatial_dataset_identifier_code={inspire_dls:spatial_dataset_identifier_code?}&spatial_dataset_identifier_namespace={inspire_dls:spatial_dataset_identifier_namespace?}&crs={inspire_dls:crs?}&language={language?}&q={searchTerms?}"));
 	$feed->appendChild($urlResults);
+	//for firefox?
+	$urlResults = $feedDoc->createElement("Url");
+	$urlResults->setAttribute("type", "text/html");//TODO give reasonable format!! - mimetypes??? geotiff/gml/other - see format of metadata - see https://developer.mozilla.org/de/docs/OpenSearch_Plugin_f%C3%BCr_Firefox_erstellen
+	$urlResults->setAttribute("rel", "results");
+	$feed->appendChild($urlResults);
 	//Url -results multi part
@@ -494,7 +734,7 @@
 function generateFeed($feedDoc, $recordId, $generateFrom) {
-	global $admin, $type, $imageResolution, $maxImageSize, $maxFeatureCount, $mapbenderMetadata, $indexMapbenderMetadata, $layerId, $wfsId, $mapbenderPath, $epsgId, $alterAxisOrder, $departmentMetadata, $userMetadata, $hasPermission, $m, $crs, $crsUpper,$countRessource;
+	global $admin, $type, $imageResolution, $maxImageSize, $maxFeatureCount, $mapbenderMetadata, $indexMapbenderMetadata, $layerId, $wfsId, $mapbenderPath, $epsgId, $alterAxisOrder, $departmentMetadata, $userMetadata, $hasPermission, $m, $crs, $crsUpper,$countRessource, $numberOfTiles, $furtherLink;
 	$feed =  $feedDoc->createElementNS('http://www.w3.org/2005/Atom', 'feed');
@@ -1258,9 +1498,10 @@
 	return $feedDoc->saveXML();
 //function to give away the xml data
 function pushOpenSearch($feedDoc, $recordId, $generateFrom) {
-	header("Content-type: application/xhtml+xml; charset=UTF-8");
+	header("Content-type: application/opensearchdescription+xml; charset=UTF-8");
 	$xml = generateOpenSearchDescription($feedDoc, $recordId, $generateFrom);
 	echo $xml;
 	die();
@@ -1372,15 +1613,21 @@
-if ($getOpenSearch) {
+if ($openSearch) {
 	readInfoFromDatabase($recordId, $generateFrom);
-	pushOpenSearch($feedDoc, $recordId, $generateFrom);
+	//generate rss to get number of tiles!
+	//generateFeed($feedDoc, $recordId, $generateFrom);//TODO: maybe call feed from cache first - we have to parse the feed - it is mor simple than generate it !!!!
+	answerOpenSearchRequest($feedDoc, $recordId, $generateFrom);
 } else {
-	readInfoFromDatabase($recordId, $generateFrom);
-	pushFeed($feedDoc, $recordId, $generateFrom); //throw it out to world!
+	if ($getOpenSearch) {
+		readInfoFromDatabase($recordId, $generateFrom);
+		pushOpenSearch($feedDoc, $recordId, $generateFrom);
+	} else {
+		pushFeed($feedDoc, $recordId, $generateFrom); //throw it out to world!
Modified: trunk/mapbender/http/plugins/mb_metadata_addon.php
--- trunk/mapbender/http/plugins/mb_metadata_addon.php	2013-08-29 14:57:08 UTC (rev 8698)
+++ trunk/mapbender/http/plugins/mb_metadata_addon.php	2013-09-03 13:25:18 UTC (rev 8699)
@@ -1,6 +1,6 @@
 <?php
 	require_once dirname(__FILE__) . "/../../core/globalSettings.php";
+	require_once(dirname(__FILE__) . "/../../conf/mimetype.conf");
 	function displayCategories ($sql) {
 		if (Mapbender::session()->get("mb_lang") === "de") {
@@ -84,12 +84,14 @@
 		<fieldset id="data_format">
 		<legend><?php echo _mb("Encoding");?><img class="help-dialog" title="<?php echo _mb("Help");?>" help="{text:'<?php echo _mb("Description of the computer language construct(s) specifying the representation of data objects in a record, file, message, storage device or transmission channel.");?>'}" src="../img/questionmark.png" alt="" /></legend>
 		<select class="required format_selectbox" id='format' name='format'>
-			<option value="database"><?php echo _mb("Database");?></option>
-			<option value="shapefile"><?php echo _mb("Esri Shape");?></option>
-			<option value="tab"><?php echo _mb("MapInfo Tab file");?></option>
-			<option value="csv"><?php echo _mb("CSV");?></option>
-			<option value="gml"><?php echo _mb("GML");?></option>
-			<option value="geotiff"><?php echo _mb("GeoTIFF");?></option>
+			<!--Format List from conf file -->
+			<?php 	$str ="";
+				foreach ($formats as $format) {
+					$str .= "<option value='" . $format . "'>"._mb($format)."</option>";
+				echo $str;
 		</select>
 		</fieldset>
 		<fieldset id="charset">
More information about the Mapbender_commits mailing list
