[Mapbender-commits] r9036 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Aug 7 06:06:08 PDT 2014
Author: armin11
Date: 2014-08-07 06:06:08 -0700 (Thu, 07 Aug 2014)
New Revision: 9036
   trunk/mapbender/http/php/mod_inspireDownloadFeed.php
Enhancement for ATOM Feed generator: It is now possible to use a GML3 polygon to intersect the bboxes of the wms getmap and wfs getfeature requests. So no more empty tiles have to be provided ;-). It is testet with more than 8000 tiles and the performance is good.
Modified: trunk/mapbender/http/php/mod_inspireDownloadFeed.php
--- trunk/mapbender/http/php/mod_inspireDownloadFeed.php	2014-08-07 13:00:45 UTC (rev 9035)
+++ trunk/mapbender/http/php/mod_inspireDownloadFeed.php	2014-08-07 13:06:08 UTC (rev 9036)
@@ -568,38 +568,38 @@
 	switch ($generateFrom) {
 		case "dataurl":
 			$sql = <<<SQL
-select *, 'dataurl' as origin from (select * from (select * from (select * from (select mb_metadata.metadata_id, layer_relation.layer_name,layer_relation.inspire_download, layer_relation.fkey_wms_id, layer_relation.layer_id, mb_metadata.uuid as metadata_uuid, mb_metadata.format,mb_metadata.title as metadata_title, mb_metadata.abstract as metadata_abstract, box2d(mb_metadata.the_geom) as metadata_bbox, layer_relation.layer_title, layer_relation.layer_abstract, mb_metadata.ref_system as metadata_ref_system, mb_metadata.datasetid, mb_metadata.spatial_res_type, mb_metadata.spatial_res_value, mb_metadata.datasetid_codespace, mb_metadata.lastchanged as md_timestamp   from (select * from layer inner join ows_relation_metadata on layer.layer_id = ows_relation_metadata.fkey_layer_id) as layer_relation inner join mb_metadata on layer_relation.fkey_metadata_id = mb_metadata.metadata_id where mb_metadata.uuid = $1) as layer_metadata inner join ows_relation_data on ows_relation_data.fkey
 _layer_id = layer_metadata.layer_id) as layer_relation_data inner join datalink on layer_relation_data.fkey_datalink_id = datalink.datalink_id) as layer_data inner join wms on layer_data.fkey_wms_id = wms.wms_id)  as layer_wms, layer_epsg where layer_wms.layer_id = layer_epsg.fkey_layer_id and layer_epsg.epsg = 'EPSG:4326';
+select *, 'dataurl' as origin from (select * from (select * from (select * from (select mb_metadata.metadata_id, layer_relation.layer_name,layer_relation.inspire_download, layer_relation.fkey_wms_id, layer_relation.layer_id, mb_metadata.uuid as metadata_uuid, mb_metadata.format,mb_metadata.title as metadata_title, mb_metadata.abstract as metadata_abstract, box2d(mb_metadata.the_geom) as metadata_bbox, mb_metadata.bounding_geom as polygon, layer_relation.layer_title, layer_relation.layer_abstract, mb_metadata.ref_system as metadata_ref_system, mb_metadata.datasetid, mb_metadata.spatial_res_type, mb_metadata.spatial_res_value, mb_metadata.datasetid_codespace, mb_metadata.lastchanged as md_timestamp   from (select * from layer inner join ows_relation_metadata on layer.layer_id = ows_relation_metadata.fkey_layer_id) as layer_relation inner join mb_metadata on layer_relation.fkey_metadata_id = mb_metadata.metadata_id where mb_metadata.uuid = $1) as layer_metadata inner join ows_r
 elation_data on ows_relation_data.fkey_layer_id = layer_metadata.layer_id) as layer_relation_data inner join datalink on layer_relation_data.fkey_datalink_id = datalink.datalink_id) as layer_data inner join wms on layer_data.fkey_wms_id = wms.wms_id)  as layer_wms, layer_epsg where layer_wms.layer_id = layer_epsg.fkey_layer_id and layer_epsg.epsg = 'EPSG:4326';
 SQL;
 		$generateFromDataurl = true;
 		break;
 		case "wmslayer":
 			$sql = <<<SQL
-select *, 'wmslayer' as origin from (select * from (select mb_metadata.metadata_id, layer_relation.layer_name, layer_relation.fkey_wms_id, layer_relation.layer_id,layer_relation.inspire_download, mb_metadata.uuid as metadata_uuid, mb_metadata.format,mb_metadata.title as metadata_title, mb_metadata.abstract as metadata_abstract, box2d(mb_metadata.the_geom) as metadata_bbox, layer_relation.layer_title, layer_relation.layer_abstract, mb_metadata.ref_system as metadata_ref_system, mb_metadata.datasetid, mb_metadata.spatial_res_type, mb_metadata.spatial_res_value, mb_metadata.datasetid_codespace, mb_metadata.lastchanged as md_timestamp   from (select * from layer inner join ows_relation_metadata on layer.layer_id = ows_relation_metadata.fkey_layer_id) as layer_relation inner join mb_metadata on layer_relation.fkey_metadata_id = mb_metadata.metadata_id where mb_metadata.uuid = $1) layer_data inner join wms on layer_data.fkey_wms_id = wms.wms_id)  as layer_wms, layer_epsg where lay
 er_wms.layer_id = layer_epsg.fkey_layer_id and layer_epsg.epsg = 'EPSG:4326' and layer_wms.layer_id = $2;
+select *, 'wmslayer' as origin from (select * from (select mb_metadata.metadata_id, layer_relation.layer_name, layer_relation.fkey_wms_id, layer_relation.layer_id,layer_relation.inspire_download, mb_metadata.uuid as metadata_uuid, mb_metadata.format,mb_metadata.title as metadata_title, mb_metadata.abstract as metadata_abstract, box2d(mb_metadata.the_geom) as metadata_bbox, mb_metadata.bounding_geom as polygon, layer_relation.layer_title, layer_relation.layer_abstract, mb_metadata.ref_system as metadata_ref_system, mb_metadata.datasetid, mb_metadata.spatial_res_type, mb_metadata.spatial_res_value, mb_metadata.datasetid_codespace, mb_metadata.lastchanged as md_timestamp   from (select * from layer inner join ows_relation_metadata on layer.layer_id = ows_relation_metadata.fkey_layer_id) as layer_relation inner join mb_metadata on layer_relation.fkey_metadata_id = mb_metadata.metadata_id where mb_metadata.uuid = $1) layer_data inner join wms on layer_data.fkey_wms_id = wms.wms_i
 d)  as layer_wms, layer_epsg where layer_wms.layer_id = layer_epsg.fkey_layer_id and layer_epsg.epsg = 'EPSG:4326' and layer_wms.layer_id = $2;
 SQL;
 		break;
 		case "wfs":
 			$sql = <<<SQL
-select *, 'wfs' as origin from (select mb_metadata.metadata_id, featuretype_relation.featuretype_name, featuretype_relation.fkey_wfs_id, featuretype_relation.featuretype_id,featuretype_relation.inspire_download, mb_metadata.uuid as metadata_uuid, mb_metadata.format,mb_metadata.title as metadata_title, mb_metadata.abstract as metadata_abstract, box2d(mb_metadata.the_geom) as metadata_bbox, featuretype_relation.featuretype_title, featuretype_relation.featuretype_abstract, mb_metadata.ref_system as metadata_ref_system, mb_metadata.datasetid, mb_metadata.spatial_res_type, mb_metadata.spatial_res_value, mb_metadata.datasetid_codespace,  featuretype_relation.featuretype_latlon_bbox as latlonbbox, featuretype_relation.featuretype_srs, mb_metadata.lastchanged as md_timestamp from (select * from wfs_featuretype inner join ows_relation_metadata on wfs_featuretype.featuretype_id = ows_relation_metadata.fkey_featuretype_id) as featuretype_relation inner join mb_metadata on featuretype_r
 elation.fkey_metadata_id = mb_metadata.metadata_id where mb_metadata.uuid = $1) as featuretype_data inner join wfs on featuretype_data.fkey_wfs_id = wfs.wfs_id where wfs.wfs_id = $2;
+select *, 'wfs' as origin from (select mb_metadata.metadata_id, featuretype_relation.featuretype_name, featuretype_relation.fkey_wfs_id, featuretype_relation.featuretype_id,featuretype_relation.inspire_download, mb_metadata.uuid as metadata_uuid, mb_metadata.format,mb_metadata.title as metadata_title, mb_metadata.abstract as metadata_abstract, box2d(mb_metadata.the_geom) as metadata_bbox, mb_metadata.bounding_geom as polygon, featuretype_relation.featuretype_title, featuretype_relation.featuretype_abstract, mb_metadata.ref_system as metadata_ref_system, mb_metadata.datasetid, mb_metadata.spatial_res_type, mb_metadata.spatial_res_value, mb_metadata.datasetid_codespace,  featuretype_relation.featuretype_latlon_bbox as latlonbbox, featuretype_relation.featuretype_srs, mb_metadata.lastchanged as md_timestamp from (select * from wfs_featuretype inner join ows_relation_metadata on wfs_featuretype.featuretype_id = ows_relation_metadata.fkey_featuretype_id) as featuretype_relation i
 nner join mb_metadata on featuretype_relation.fkey_metadata_id = mb_metadata.metadata_id where mb_metadata.uuid = $1) as featuretype_data inner join wfs on featuretype_data.fkey_wfs_id = wfs.wfs_id where wfs.wfs_id = $2;
 SQL;
 		break;
 		case "metadata":
 			$sql = <<<SQL
-select 'metadata' as origin,mb_metadata.metadata_id, mb_metadata.uuid as metadata_uuid, mb_metadata.format,mb_metadata.title as metadata_title, mb_metadata.abstract as metadata_abstract, box2d(mb_metadata.the_geom) as metadata_bbox, mb_metadata.ref_system as metadata_ref_system, mb_metadata.datasetid, mb_metadata.spatial_res_type, mb_metadata.spatial_res_value, mb_metadata.datasetid_codespace, mb_metadata.fkey_mb_user_id,  mb_metadata.lastchanged as md_timestamp, box2d(the_geom) as bbox2d, datalinks FROM mb_metadata where uuid = $1 and inspire_download = 1;
+select 'metadata' as origin,mb_metadata.metadata_id, mb_metadata.uuid as metadata_uuid, mb_metadata.format,mb_metadata.title as metadata_title, mb_metadata.abstract as metadata_abstract, box2d(mb_metadata.the_geom) as metadata_bbox, mb_metadata.bounding_geom as polygon,  mb_metadata.ref_system as metadata_ref_system, mb_metadata.datasetid, mb_metadata.spatial_res_type, mb_metadata.spatial_res_value, mb_metadata.datasetid_codespace, mb_metadata.fkey_mb_user_id,  mb_metadata.lastchanged as md_timestamp, box2d(the_geom) as bbox2d, datalinks FROM mb_metadata where uuid = $1 and inspire_download = 1;
 SQL;
 		break;
 		case "all":
 			$sql = array();
 			$sql[0] = <<<SQL
-select *, 'dataurl' as origin from (select * from (select * from (select * from (select mb_metadata.metadata_id, layer_relation.layer_name, layer_relation.fkey_wms_id, layer_relation.layer_id,layer_relation.inspire_download, mb_metadata.uuid as metadata_uuid, mb_metadata.format,mb_metadata.title as metadata_title, mb_metadata.abstract as metadata_abstract, box2d(mb_metadata.the_geom) as metadata_bbox, layer_relation.layer_title, layer_relation.layer_abstract, mb_metadata.ref_system as metadata_ref_system, mb_metadata.datasetid, mb_metadata.spatial_res_type, mb_metadata.spatial_res_value, mb_metadata.datasetid_codespace, mb_metadata.lastchanged as md_timestamp   from (select * from layer inner join ows_relation_metadata on layer.layer_id = ows_relation_metadata.fkey_layer_id) as layer_relation inner join mb_metadata on layer_relation.fkey_metadata_id = mb_metadata.metadata_id where mb_metadata.uuid = $1) as layer_metadata inner join ows_relation_data on ows_relation_data.fkey
+select *, 'dataurl' as origin from (select * from (select * from (select * from (select mb_metadata.metadata_id, layer_relation.layer_name, layer_relation.fkey_wms_id, layer_relation.layer_id,layer_relation.inspire_download, mb_metadata.uuid as metadata_uuid, mb_metadata.format,mb_metadata.title as metadata_title, mb_metadata.abstract as metadata_abstract, box2d(mb_metadata.the_geom) as metadata_bbox, mb_metadata.bounding_geom as polygon, layer_relation.layer_title, layer_relation.layer_abstract, mb_metadata.ref_system as metadata_ref_system, mb_metadata.datasetid, mb_metadata.spatial_res_type, mb_metadata.spatial_res_value, mb_metadata.datasetid_codespace, mb_metadata.lastchanged as md_timestamp   from (select * from layer inner join ows_relation_metadata on layer.layer_id = ows_relation_metadata.fkey_layer_id) as layer_relation inner join mb_metadata on layer_relation.fkey_metadata_id = mb_metadata.metadata_id where mb_metadata.uuid = $1) as layer_metadata inner join ows_r
 SQL;
 			$sql[1] =  <<<SQL
-select *, 'wmslayer' as origin from (select * from (select mb_metadata.metadata_id, layer_relation.layer_name,layer_relation.inspire_download, layer_relation.fkey_wms_id, layer_relation.layer_id, mb_metadata.uuid as metadata_uuid, mb_metadata.format,mb_metadata.title as metadata_title, mb_metadata.abstract as metadata_abstract, box2d(mb_metadata.the_geom) as metadata_bbox, layer_relation.layer_title, layer_relation.layer_abstract, mb_metadata.ref_system as metadata_ref_system, mb_metadata.datasetid, mb_metadata.spatial_res_type, mb_metadata.spatial_res_value, mb_metadata.datasetid_codespace, mb_metadata.lastchanged as md_timestamp   from (select * from layer inner join ows_relation_metadata on layer.layer_id = ows_relation_metadata.fkey_layer_id) as layer_relation inner join mb_metadata on layer_relation.fkey_metadata_id = mb_metadata.metadata_id where mb_metadata.uuid = $1) layer_data inner join wms on layer_data.fkey_wms_id = wms.wms_id)  as layer_wms, layer_epsg where lay
+select *, 'wmslayer' as origin from (select * from (select mb_metadata.metadata_id, layer_relation.layer_name,layer_relation.inspire_download, layer_relation.fkey_wms_id, layer_relation.layer_id, mb_metadata.uuid as metadata_uuid, mb_metadata.format,mb_metadata.title as metadata_title, mb_metadata.abstract as metadata_abstract, box2d(mb_metadata.the_geom) as metadata_bbox, mb_metadata.bounding_geom as polygon, layer_relation.layer_title, layer_relation.layer_abstract, mb_metadata.ref_system as metadata_ref_system, mb_metadata.datasetid, mb_metadata.spatial_res_type, mb_metadata.spatial_res_value, mb_metadata.datasetid_codespace, mb_metadata.lastchanged as md_timestamp   from (select * from layer inner join ows_relation_metadata on layer.layer_id = ows_relation_metadata.fkey_layer_id) as layer_relation inner join mb_metadata on layer_relation.fkey_metadata_id = mb_metadata.metadata_id where mb_metadata.uuid = $1) layer_data inner join wms on layer_data.fkey_wms_id = wms.wms_i
 SQL;
 			$sql[2] =  <<<SQL
-select *, 'wfs' as origin from (select mb_metadata.metadata_id, featuretype_relation.featuretype_name, featuretype_relation.fkey_wfs_id, featuretype_relation.inspire_download, featuretype_relation.featuretype_id, mb_metadata.uuid as metadata_uuid, mb_metadata.format,mb_metadata.title as metadata_title, mb_metadata.abstract as metadata_abstract, box2d(mb_metadata.the_geom) as metadata_bbox, featuretype_relation.featuretype_title, featuretype_relation.featuretype_abstract, mb_metadata.ref_system as metadata_ref_system, mb_metadata.datasetid, mb_metadata.spatial_res_type, mb_metadata.spatial_res_value, mb_metadata.datasetid_codespace, featuretype_relation.featuretype_latlon_bbox as latlonbbox, featuretype_relation.featuretype_srs, mb_metadata.lastchanged as md_timestamp from (select * from wfs_featuretype inner join ows_relation_metadata on wfs_featuretype.featuretype_id = ows_relation_metadata.fkey_featuretype_id) as featuretype_relation inner join mb_metadata on featuretype_r
 elation.fkey_metadata_id = mb_metadata.metadata_id where mb_metadata.uuid = $1) as featuretype_data inner join wfs on featuretype_data.fkey_wfs_id = wfs.wfs_id;
+select *, 'wfs' as origin from (select mb_metadata.metadata_id, featuretype_relation.featuretype_name, featuretype_relation.fkey_wfs_id, featuretype_relation.inspire_download, featuretype_relation.featuretype_id, mb_metadata.uuid as metadata_uuid, mb_metadata.format,mb_metadata.title as metadata_title, mb_metadata.abstract as metadata_abstract, box2d(mb_metadata.the_geom) as metadata_bbox, mb_metadata.bounding_geom as polygon, featuretype_relation.featuretype_title, featuretype_relation.featuretype_abstract, mb_metadata.ref_system as metadata_ref_system, mb_metadata.datasetid, mb_metadata.spatial_res_type, mb_metadata.spatial_res_value, mb_metadata.datasetid_codespace, featuretype_relation.featuretype_latlon_bbox as latlonbbox, featuretype_relation.featuretype_srs, mb_metadata.lastchanged as md_timestamp from (select * from wfs_featuretype inner join ows_relation_metadata on wfs_featuretype.featuretype_id = ows_relation_metadata.fkey_featuretype_id) as featuretype_relation i
 nner join mb_metadata on featuretype_relation.fkey_metadata_id = mb_metadata.metadata_id where mb_metadata.uuid = $1) as featuretype_data inner join wfs on featuretype_data.fkey_wfs_id = wfs.wfs_id;
 SQL;
 		break;
@@ -1022,7 +1022,15 @@
 	$feedAuthor->appendChild($feedAuthorName);
 	$feedAuthor->appendChild($feedAuthorEmail);
 	$feed->appendChild($feedAuthor);
+	//check for given polygonal extent:
+	if (is_null($mapbenderMetadata[$m]->metadata_polygon)) {
+		$e = new mb_notice("php/mod_inspireDownloadFeed.php polygonalFilter is not set");
+		$polygonalFilter = false;
+	} else {
+		$e = new mb_notice("php/mod_inspireDownloadFeed.php polygonalFilter was found and will be applied!");
+		$polygonalFilter = true;
+	$e = new mb_notice("php/mod_inspireDownloadFeed.php metadata_uuid: ".$mapbenderMetadata[$m]->metadata_uuid);
 	//<!-- pre-defined dataset - a entry for each pre-defined dataset - in the case of dataURL only one entry is used! -->
 	//if dataurl not given and a raster wms is defined - calculate the number of entries
 	if ($type == 'DATASET' && $generateFrom == "wmslayer") {
@@ -1044,24 +1052,12 @@
 				//TODO: check if epsg, and bbox are filled correctly!
-				$sqlMinx = "SELECT X(transform(GeometryFromText('POINT(".$mapbenderMetadata[$m]->minx." ".$mapbenderMetadata[$m]->miny.")',4326),".$epsgId.")) as minx";
-				$e = new mb_exception($sqlMinx);
-				$resMinx = db_query($sqlMinx);
-				$minx = floatval(db_result($resMinx,0,"minx"));
-				$sqlMiny = "SELECT Y(transform(GeometryFromText('POINT(".$mapbenderMetadata[$m]->minx." ".$mapbenderMetadata[$m]->miny.")',4326),".$epsgId.")) as miny";
-				$resMiny = db_query($sqlMiny);
-				$miny = floatval(db_result($resMiny,0,"miny"));
-				$sqlMaxx = "SELECT X(transform(GeometryFromText('POINT(".$mapbenderMetadata[$m]->maxx." ".$mapbenderMetadata[$m]->maxy.")',4326),".$epsgId.")) as maxx";
-				$resMaxx = db_query($sqlMaxx);
-				$maxx = floatval(db_result($resMaxx,0,"maxx"));
-				$sqlMaxy = "SELECT Y(transform(GeometryFromText('POINT(".$mapbenderMetadata[$m]->maxx." ".$mapbenderMetadata[$m]->maxy.")',4326),".$epsgId.")) as maxy";
-				$resMaxy = db_query($sqlMaxy);
-				$maxy = floatval(db_result($resMaxy,0,"maxy"));
+				$sqlExtent = "SELECT X(transform(GeometryFromText('POINT(".$mapbenderMetadata[$m]->minx." ".$mapbenderMetadata[$m]->miny.")',4326),".$epsgId.")) as minx, Y(transform(GeometryFromText('POINT(".$mapbenderMetadata[$m]->minx." ".$mapbenderMetadata[$m]->miny.")',4326),".$epsgId.")) as miny, X(transform(GeometryFromText('POINT(".$mapbenderMetadata[$m]->maxx." ".$mapbenderMetadata[$m]->maxy.")',4326),".$epsgId.")) as maxx, Y(transform(GeometryFromText('POINT(".$mapbenderMetadata[$m]->maxx." ".$mapbenderMetadata[$m]->maxy.")',4326),".$epsgId.")) as maxy";
+				$resExtent =  db_query($sqlExtent);
+				$minx = floatval(db_result($resExtent,0,"minx"));
+				$miny = floatval(db_result($resExtent,0,"miny"));
+				$maxx = floatval(db_result($resExtent,0,"maxx"));
+				$maxy = floatval(db_result($resExtent,0,"maxy"));
 				$diffX = $maxx - $minx; //in m
 				$diffY = $maxy - $miny;	//in m
@@ -1106,7 +1102,15 @@
 						$maxyWms = $miny + ($j+1) * $incY;
 						//echo "maxyWms: ". $maxyWms .",";
 						$bboxWms[] = $minxWms.",".$minyWms.",".$maxxWms.",".$maxyWms;
-						$bboxWmsWGS84[] = transformBbox($minxWms.",".$minyWms.",".$maxxWms.",".$maxyWms,intval($epsgId),4326);
+						//new: use filter of polygon is given ;-)
+						$lonLatBboxWms = transformBbox($minxWms.",".$minyWms.",".$maxxWms.",".$maxyWms,intval($epsgId),4326,$mapbenderMetadata[$m]->metadata_uuid,$polygonalFilter);
+						//only add entry, if not false
+						if ($lonLatBboxWms != false) {
+							$bboxWmsWGS84[] = $lonLatBboxWms;
+						} else {
+							//delete last entry from $bboxWms, cause it is outside the polygon!
+							array_pop($bboxWms);
@@ -1133,7 +1137,7 @@
 				//use featuretype ref system?
 				$crs = $mapbenderMetadata[$i]->featuretype_srs;
 				//log ref system of metadata - is this a good idea?
-				$e = new mb_exception("Ref system of featuretype ".$mapbenderMetadata[$i]->featuretype_name." : ".$crs);
+				$e = new mb_notice("Ref system of featuretype ".$mapbenderMetadata[$i]->featuretype_name." : ".$crs);
 				//handle other definitions of epsg ids
 				//urn:ogc:def:crs:EPSG::31467
@@ -1147,7 +1151,7 @@
 				$epsgId = end($epsgId);
 				//check if order have to be altered
 				if (strpos($crsUpper,'urn') !== false) {
-					$e = new mb_exception("urn - found");
+					$e = new mb_notice("urn - found");
 					//check if axis order should be changed
 					if (check_epsg_wms_13($epsgId)) {
 						//alter order of axis for 4326
@@ -1228,21 +1232,12 @@
 							$mapbenderMetadata[$i]->maxy = $maxyI;
 							$mapbenderMetadata[$i]->maxx = $maxxI;
-						$sqlMinx = "SELECT X(transform(GeometryFromText('POINT(".$mapbenderMetadata[$i]->minx." ".$mapbenderMetadata[$i]->miny.")',4326),".$epsgId.")) as minx";
-						$sqlMiny = "SELECT Y(transform(GeometryFromText('POINT(".$mapbenderMetadata[$i]->minx." ".$mapbenderMetadata[$i]->miny.")',4326),".$epsgId.")) as miny";
-						$sqlMaxx = "SELECT X(transform(GeometryFromText('POINT(".$mapbenderMetadata[$i]->maxx." ".$mapbenderMetadata[$i]->maxy.")',4326),".$epsgId.")) as maxx";
-						$sqlMaxy = "SELECT Y(transform(GeometryFromText('POINT(".$mapbenderMetadata[$i]->maxx." ".$mapbenderMetadata[$i]->maxy.")',4326),".$epsgId.")) as maxy";
+						$sqlExtent = "SELECT X(transform(GeometryFromText('POINT(".$mapbenderMetadata[$i]->minx." ".$mapbenderMetadata[$i]->miny.")',4326),".$epsgId.")) as minx, Y(transform(GeometryFromText('POINT(".$mapbenderMetadata[$i]->minx." ".$mapbenderMetadata[$i]->miny.")',4326),".$epsgId.")) as miny, X(transform(GeometryFromText('POINT(".$mapbenderMetadata[$i]->maxx." ".$mapbenderMetadata[$i]->maxy.")',4326),".$epsgId.")) as maxx, Y(transform(GeometryFromText('POINT(".$mapbenderMetadata[$i]->maxx." ".$mapbenderMetadata[$i]->maxy.")',4326),".$epsgId.")) as maxy";
 				//only calculate new boxes if countTiles > 1
@@ -1266,13 +1261,16 @@
 							$maxyWfs = $miny + ($j+1) * $width;
 							$bboxWfs[$mapbenderMetadata[$i]->featuretype_name][$countBbox] = $minxWfs.",".$minyWfs.",".$maxxWfs.",".$maxyWfs;
-							//transform bbox back to geographic coordinates
-							$lonLatBbox = transformBbox($minxWfs.",".$minyWfs.",".$maxxWfs.",".$maxyWfs,intval($epsgId),4326);
-							$lonLatBbox = explode(',',$lonLatBbox);
-							//georss needs latitude longitude
-							$featureTypeBboxWGS84[] = $lonLatBbox[1].",".$lonLatBbox[0].",".$lonLatBbox[3].",".$lonLatBbox[2];
-							//switch bbox to lat/lon cause inspire demands ist
-							$countBbox++;
+							//transform bbox back to geographic coordinates and filter them if a spatial_extent as polygon is given (give only those which intersects)!!
+							$lonLatBbox = transformBbox($minxWfs.",".$minyWfs.",".$maxxWfs.",".$maxyWfs,intval($epsgId),4326, $mapbenderMetadata[$i]->metadata_uuid, $mapbenderMetadata[$i]->polygonFilter);
+							if ($lonLatBbox != false) {
+								$lonLatBbox = explode(',',$lonLatBbox);
+								//georss needs latitude longitude
+								$featureTypeBboxWGS84[] = $lonLatBbox[1].",".$lonLatBbox[0].",".$lonLatBbox[3].",".$lonLatBbox[2];
+								//switch bbox to lat/lon cause inspire demands ist
+								$countBbox++;
 				} else {
@@ -1679,28 +1677,36 @@
 	return $bbox;
-function transformBbox($oldBbox, $fromCRS, $toCRS) {
+function transformBbox($oldBbox, $fromCRS, $toCRS, $metadataUuid = false ,$polygonFilter = false) {
 	//Transform the given BBOX to $toCRS
 	$arrayBbox = explode(',',$oldBbox);
-	//$e = new mb_exception($oldBbox);
-	//$e = new mb_exception(count($arrayBbox));
-	//$e = new mb_exception($arrayBbox[0]);
-	$sql = "select asewkt(transform(GeometryFromText ( 'LINESTRING ( ".$arrayBbox[0]." ".$arrayBbox[1].",".$arrayBbox[2]." ".$arrayBbox[3]." )', $fromCRS ),".intval($toCRS)."))";
-	//$e = new mb_exception("inspireDownload sql transform: ".$sql);
-	//$sql = "select asewkt(transform(GeometryFromText ( 'LINESTRING ( $1 $2, $3 $4 )', $5 ),$6))";
-	//$v = array($arrayBbox[0],$arrayBbox[1],$arrayBbox[2],$arrayBbox[3],$fromCRS,$toCRS);
-	//$t = array('s','s','s','s','i','i');
-	$res = db_query($sql,$v,$t);
-	//read out result
-	$textBbox = db_fetch_row($res);
-	//$e = new mb_exception("inspireDownload sql result: ".$textBbox[0]);
-	$pattern = '~LINESTRING\((.*)\)~i';
-	preg_match($pattern, $textBbox[0], $subpattern);
-	//exchange blancs
-	$newBbox = str_replace(" ", ",", $subpattern[1]);
-	//set new BBOX
-	//$arrayBboxNew = explode(',',$newBbox);
-	return $newBbox;
+	if ($metadataUuid != false && $polygonFilter != false) {
+		$sql = "select asewkt(transform(GeometryFromText ( 'LINESTRING ( ".$arrayBbox[0]." ".$arrayBbox[1].",".$arrayBbox[2]." ".$arrayBbox[3]." )', $fromCRS ),".intval($toCRS).")) as bbox,
+CASE
+WHEN st_intersects((select bounding_geom from mb_metadata where uuid = '".$metadataUuid."'), transform(GeometryFromText ( 'LINESTRING ( ".$arrayBbox[0]." ".$arrayBbox[1].",".$arrayBbox[2]." ".$arrayBbox[3]." )', $fromCRS ),".intval($toCRS)." )) = true THEN true
+ELSE false
+END as inside;";
+		$res = db_query($sql,$v,$t);
+		$row = db_fetch_assoc($res);
+		$textBbox = $row['bbox'];
+		$inside = $row['inside'];
+		if ($inside == "f") {
+			return false;
+		} else {
+			$pattern = '~LINESTRING\((.*)\)~i';
+			preg_match($pattern, $textBbox, $subpattern);
+			$newBbox = str_replace(" ", ",", $subpattern[1]);
+			return $newBbox;
+	} else {
+		$sql = "select asewkt(transform(GeometryFromText ( 'LINESTRING ( ".$arrayBbox[0]." ".$arrayBbox[1].",".$arrayBbox[2]." ".$arrayBbox[3]." )', $fromCRS ),".intval($toCRS)."))";
+		$textBbox = db_fetch_row($res);
+		preg_match($pattern, $textBbox[0], $subpattern);
+		return $newBbox;
@@ -1775,6 +1781,7 @@
 				$mapbenderMetadata[$indexMapbenderMetadata]->layer_title = $row['layer_title'];
 				$mapbenderMetadata[$indexMapbenderMetadata]->metadata_abstract = $row['metadata_abstract'];
 				$mapbenderMetadata[$indexMapbenderMetadata]->metadata_bbox = $row['metadata_bbox'];
+				$mapbenderMetadata[$indexMapbenderMetadata]->metadata_polygon = $row['polygon'];
 				$mapbenderMetadata[$indexMapbenderMetadata]->layer_abstract = $row['layer_abstract'];
 				$mapbenderMetadata[$indexMapbenderMetadata]->accessconstraints = $row['accessconstraints'];
 				$mapbenderMetadata[$indexMapbenderMetadata]->metadata_uuid = $row['metadata_uuid'];
More information about the Mapbender_commits mailing list
