[Mapbender-commits] r8777 - in trunk/mapbender/http: geoportal javascripts php
svn_mapbender at osgeo.org
Fri Feb 14 03:04:41 PST 2014
Author: armin11
Date: 2014-02-14 03:04:41 -0800 (Fri, 14 Feb 2014)
New Revision: 8777
trunk/mapbender/http/geoportal/mod_pullInspireMonitoring.php
trunk/mapbender/http/javascripts/mod_featureInfo.php
trunk/mapbender/http/php/mod_inspireAtomFeedISOMetadata.php
trunk/mapbender/http/php/mod_inspireDownloadFeed.php
Some bugfixes for monitoring table
Modified: trunk/mapbender/http/geoportal/mod_pullInspireMonitoring.php
--- trunk/mapbender/http/geoportal/mod_pullInspireMonitoring.php 2014-02-12 10:13:14 UTC (rev 8776)
+++ trunk/mapbender/http/geoportal/mod_pullInspireMonitoring.php 2014-02-14 11:04:41 UTC (rev 8777)
@@ -368,9 +368,8 @@
$serviceIndex = 0;
$orgaIndex = 0;
$alreadyBuildDls = array();
- $alreadBuildVs = array();
$alreadyReadOrgas = array();
+ $alreadyBuildVs = array();
$currentUuid = "";
$inspireMonitoring = array(
"datasets" => array(),
@@ -499,11 +498,11 @@
//How to generate UUIDs for INSPIRE Download Service Metadata records (not really needed for INSPIRE!!! See DB Metadaten)
//12-4-4-4-8
//dataurl
- //WMS uuid (12-4), Type (4) - 0001, MD uuid (4-8)
+ //LAYER uuid (12-4), Type (4) - 0001, MD uuid (4-8)
//wfs
//WFS uuid (12-4), MD uuid (4-4-8)
//wmsgetmap
- //WMS uuid (12-4), Type (4) - 0002, MD uuid (4-8)
+ //LAYER uuid (12-4), Type (4) - 0002, MD uuid (4-8)
if (isset($sqlTable['service_uuid'][$i]) && $sqlTable['service_uuid'][$i] != '' ) { //TODO - don't use service uuids from table but from options!
//TODO - what to do if metadata id is no uuid?????
@@ -521,6 +520,7 @@
$servicePart = explode('-',$option->serviceUuid);
//$mdPart = explode('-',$mdUuid);
switch ($option->type) {
case "wmslayergetmap":
$dlsFileIdentifier = $servicePart[0]."-".$servicePart[1]."-"."0002"."-".$mdPart[3]."-".$mdPart[4];
@@ -534,10 +534,20 @@
$dlsFileIdentifier = $servicePart[0]."-".$servicePart[1]."-".$mdPart[2]."-".$mdPart[3]."-".$mdPart[4];
$capUrl = $mapbenderUrl."/php/mod_inspireDownloadFeed.php?id=".$sqlTable['uuid'][$i]."&type=SERVICE&generateFrom=wfs&wfsid=".$option->serviceId;
break;
+ case "downloadlink":
+ $linkPart = md5($option->link);
+ $dlsFileIdentifier = $mdPart[0]."-".$mdPart[1]."-".$mdPart[2]."-".substr($linkPart, -12, 4)."-".substr($linkPart, -8, 8);
+ $capUrl = $mapbenderUrl."/php/mod_inspireDownloadFeed.php?id=".$sqlTable['uuid'][$i]."&type=SERVICE&generateFrom=metadata&id=".$mdUuid;
+ break;
} else {
- $dlsFileIdentifier = "no id found - please check if services have uuids or generate new ones!";
+ //generate dummy uuid - is not good!
+ $uuid = new Uuid();
+ $dlsFileIdentifier = $uuid;
+ $dlsFileIdentifier = "00000000-0000-0000-000000000000";
if (!in_array($dlsFileIdentifier,$alreadyBuildDls)) {
//generate the rest of the service element
Modified: trunk/mapbender/http/javascripts/mod_featureInfo.php
--- trunk/mapbender/http/javascripts/mod_featureInfo.php 2014-02-12 10:13:14 UTC (rev 8776)
+++ trunk/mapbender/http/javascripts/mod_featureInfo.php 2014-02-14 11:04:41 UTC (rev 8777)
@@ -36,6 +36,9 @@
var featureInfoLayerPreselect = false;
if(typeof(featureInfoDrawClick)==='undefined')
var featureInfoDrawClick = false;
+if(typeof(featureInfoCircleColor)==='undefined')
+ var featureInfoCircleColor = '#ff0000';
var mod_featureInfo_elName = "<?php echo $e_id;?>";
var mod_featureInfo_frameName = "";
var mod_featureInfo_target = "<?php echo $e_target[0]; ?>";
@@ -46,10 +49,10 @@
var mod_featureInfo_img_over = new Image(); mod_featureInfo_img_over.src = "<?php echo preg_replace("/_off/","_over",$e_src); ?>";
if (featureInfoDrawClick) {
- var standingHighlight = null;
+ var standingHighlightFeatureInfo = null;
Mapbender.events.afterMapRequest.register( function(){
- if(standingHighlight){
- standingHighlight.paint();
+ if(standingHighlightFeatureInfo){
+ standingHighlightFeatureInfo.paint();
@@ -125,12 +128,12 @@
var point = mod_featureInfo_mapObj.getMousePosition(e);
var map = Mapbender.modules[options.target];
- if(standingHighlight !== null){
- standingHighlight.clean();
+ if(standingHighlightFeatureInfo !== null){
+ standingHighlightFeatureInfo.clean();
}else{
- standingHighlight = new Highlight(
+ standingHighlightFeatureInfo = new Highlight(
[options.target],
- "standingHighlight",
+ "standingHighlightFeatureInfo",
{"position":"absolute", "top":"0px", "left":"0px", "z-index":100},
2);
@@ -143,8 +146,8 @@
coordinates:[realWorldPoint.x,realWorldPoint.y,null]
},Mapbender.modules[options.target].getSRS())
var m = ga.get(-1,-1);
- standingHighlight.add(m, "#ff0000");
+ standingHighlightFeatureInfo.add(m, featureInfoCircleColor);
map.setMapRequest();
eventBeforeFeatureInfo.trigger({"fName":mod_featureInfo_target});
@@ -172,9 +175,9 @@
for(var i=0;i<urls.length;i++){
if (urls[i].inBbox) {
if (urls[i].legendurl !== "empty" ) {
- featureInfoList += "<tr><td><a style='text-decoration: underline' href='"+urls[i].request+"' target='_blank'>"+urls[i].title+"</a></td><td><img src='"+urls[i].legendurl+"' alt='<?php echo _mb("No legend available");?>!'/></td></tr>";
+ featureInfoList += "<tr><td valign='top'><a style='text-decoration: underline' href='"+urls[i].request+"' target='_blank'>"+urls[i].title+"</a></td><td><img src='"+urls[i].legendurl+"' alt='<?php echo _mb("No legend available");?>!'/></td></tr>";
} else {
- featureInfoList += "<tr><td><a style='text-decoration: underline' href='"+urls[i].request+"' target='_blank'>"+urls[i].title+"</a></td><td><img src='' alt='<?php echo _mb("No legend available");?>!'/></td></tr>";
+ featureInfoList += "<tr><td valign='top'><a style='text-decoration: underline' href='"+urls[i].request+"' target='_blank'>"+urls[i].title+"</a></td><td><img src='' alt='<?php echo _mb("No legend available");?>!'/></td></tr>";
@@ -182,9 +185,9 @@
for(var i=urls.length-1; i>=0; i--){
} else {
@@ -193,15 +196,15 @@
$("<div id='featureInfo_preselect'></div>").dialog({
bgiframe: true,
autoOpen: true,
- modal: true,
+ modal: false,
title: '<?php echo _mb("Please choose a requestable Layer");?>',
width:parseInt(featureInfoPopupWidth, 10),
height:parseInt(featureInfoPopupHeight, 10),
position:dialogPosition,
buttons: {
"Close": function(){
$(this).dialog('close').remove();
Modified: trunk/mapbender/http/php/mod_inspireAtomFeedISOMetadata.php
--- trunk/mapbender/http/php/mod_inspireAtomFeedISOMetadata.php 2014-02-12 10:13:14 UTC (rev 8776)
+++ trunk/mapbender/http/php/mod_inspireAtomFeedISOMetadata.php 2014-02-14 11:04:41 UTC (rev 8777)
@@ -170,12 +170,13 @@
$mapbenderMetadata['mdOrigin'] = $mbMetadata['origin'];
//read information for layer/layer_epsg/wms/layer classification - 'inspireidentifiziert'?
$sql = <<<SQL
- select * from (select layer.layer_id, layer.layer_minscale, layer.layer_maxscale, wms.wms_timestamp, wms.wms_owner, wms.fkey_mb_group_id, wms.contactorganization, wms.uuid, wms.contactelectronicmailaddress, wms.wms_timestamp_create, wms.fees, wms.accessconstraints from layer inner join wms on layer.fkey_wms_id = wms.wms_id where layer.layer_id = $1) as wms_layer, layer_epsg where wms_layer.layer_id = layer_epsg.fkey_layer_id and layer_epsg.epsg = 'EPSG:4326';
+ select * from (select layer.layer_id, layer.layer_minscale, layer.layer_maxscale, wms.wms_timestamp, wms.wms_owner, wms.fkey_mb_group_id, wms.contactorganization, layer.uuid, wms.contactelectronicmailaddress, wms.wms_timestamp_create, wms.fees, wms.accessconstraints from layer inner join wms on layer.fkey_wms_id = wms.wms_id where layer.layer_id = $1) as wms_layer, layer_epsg where wms_layer.layer_id = layer_epsg.fkey_layer_id and layer_epsg.epsg = 'EPSG:4326';
SQL;
$v = array((integer)$mapbenderMetadata['resourceId']);
$t = array('i');
$res = db_prep_query($sql,$v,$t);
$mbMetadata = db_fetch_array($res);
+ //use layer.uuid because dataurl is defined at layer_level
$mapbenderMetadata['serviceUuid'] = $mbMetadata['uuid'];
$mapbenderMetadata['serviceTimestamp'] = $mbMetadata['wms_timestamp'];
$mapbenderMetadata['serviceTimestampCreate'] = $mbMetadata['wms_timestamp_create'];
@@ -308,7 +309,7 @@
$sql = <<<SQL
SQL;
$t = array('i');
@@ -480,7 +481,7 @@
//How to generate UUIDs for INSPIRE Download Service Metadata records (not really needed for INSPIRE!!! See DB Metadata)
//12-4-4-4-8
//dataurl
//wfs
//wmsgetmap
@@ -490,6 +491,7 @@
if (isset($mapbenderMetadata['serviceUuid']) && $mapbenderMetadata['serviceUuid'] != '' ) {
$servicePart = explode('-',$mapbenderMetadata['serviceUuid']);
+ //in case of wmslayer and dataurl use layer_uuid - cause the same metadata record may be coupled with more than one layer of a service
$mdPart = explode('-',$recordId);
switch ($generateFrom) {
case "wmslayer":
Modified: trunk/mapbender/http/php/mod_inspireDownloadFeed.php
--- trunk/mapbender/http/php/mod_inspireDownloadFeed.php 2014-02-12 10:13:14 UTC (rev 8776)
+++ trunk/mapbender/http/php/mod_inspireDownloadFeed.php 2014-02-14 11:04:41 UTC (rev 8777)
@@ -327,6 +327,9 @@
case "wfs":
$mimetype = "application/gml+xml";
break;
+ case "metadata":
+ $mimetype = $formatsMimetype[$mapbenderMetadata[$m]->format];
+ break;
//check correct headers
foreach (apache_request_headers() as $name => $value) {
More information about the Mapbender_commits
