[Mapbender-commits] r8785 - in trunk/mapbender: http/classes http/geoportal http/javascripts http/php lib resources/db/pgsql/UTF-8/update tools
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Feb 28 03:51:22 PST 2014
Author: armin11
Date: 2014-02-28 03:51:21 -0800 (Fri, 28 Feb 2014)
New Revision: 8785
   trunk/mapbender/http/classes/class_ows.php
   trunk/mapbender/http/classes/class_ows_factory.php
   trunk/mapbender/http/classes/class_universal_wfs_factory.php
   trunk/mapbender/http/classes/class_universal_wms_factory.php
   trunk/mapbender/http/classes/class_wfs.php
   trunk/mapbender/http/classes/class_wfsToDb.php
   trunk/mapbender/http/classes/class_wfs_1_0_factory.php
   trunk/mapbender/http/classes/class_wfs_1_1_factory.php
   trunk/mapbender/http/classes/class_wfs_2_0_factory.php
   trunk/mapbender/http/classes/class_wfs_factory.php
   trunk/mapbender/http/classes/class_wmc_factory.php
   trunk/mapbender/http/classes/class_wms.php
   trunk/mapbender/http/classes/class_wms_1_1_1_factory.php
   trunk/mapbender/http/geoportal/mod_pullInspireMonitoring.php
   trunk/mapbender/http/javascripts/initWmcObj.php
   trunk/mapbender/http/javascripts/mod_wfsGazetteerEditor_client.php
   trunk/mapbender/http/javascripts/mod_wfsGazetteerEditor_server.php
   trunk/mapbender/http/php/mod_loadWFSCapabilities.php
   trunk/mapbender/http/php/mod_loadwfs.php
   trunk/mapbender/http/php/mod_loadwms.php
   trunk/mapbender/http/php/mod_wfs_server.php
   trunk/mapbender/lib/class_GetApi.php
   trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql
   trunk/mapbender/tools/mod_runScheduler.php
New option to load wfs which is authenticated via http_auth (basic or digest), bugfixes
Modified: trunk/mapbender/http/classes/class_ows.php
--- trunk/mapbender/http/classes/class_ows.php	2014-02-20 07:23:30 UTC (rev 8784)
+++ trunk/mapbender/http/classes/class_ows.php	2014-02-28 11:51:21 UTC (rev 8785)
@@ -45,8 +45,8 @@
 	var $electronicMailAddress;
 	var $country;
 	var $termsofuse;
+	var $auth = false; //array 'auth_type', 'auth_username', 'auth_password', default false
 	 * Removes the namespace from a tag name.
@@ -107,8 +107,12 @@
 	final protected function get ($url) {
-		$connection = new connector($url);
-		$e = new mb_notice("OWS REQUEST: " . $url);
+		if (!$this->auth) {
+			$connection = new connector($url);
+		} else {
+			$connection = new connector($url, $this->auth);
+		//$e = new mb_notice("OWS REQUEST: " . $url);
 		$data = $connection->file;
 		if (!$data) {
 			$e = new mb_exception("OWS request returned no result: " . $url);
@@ -122,16 +126,19 @@
 		$connection->set("httpType", "post");
 		$connection->set("httpContentType", "xml");
 		$connection->set("httpPostData", $postData);
-		$e = new mb_notice("OWS REQUEST: " . $url . "\n\n" . $postData);
+		//$e = new mb_notice("OWS REQUEST: " . $url . "\n\n" . $postData);
 		$data = $connection->load($url);
+			$data = $connection->load($url);
+		} else {
+			$data = $connection->load($url, $this->auth);
 		if (!$data) {
 			$e = new mb_exception("OWS request returned no result: " . $url . "\n" . $postData);
 			return null;
 		return $data;
Modified: trunk/mapbender/http/classes/class_ows_factory.php
--- trunk/mapbender/http/classes/class_ows_factory.php	2014-02-20 07:23:30 UTC (rev 8784)
+++ trunk/mapbender/http/classes/class_ows_factory.php	2014-02-28 11:51:21 UTC (rev 8785)
@@ -31,7 +31,7 @@
 	 * @return Ows
 	 * @param $xml String
-	abstract public function createFromXml ($xml);
+	abstract public function createFromXml ($xml, $auth=false);
 	 * Creates an OWS from the Mapbender database.
@@ -100,8 +100,12 @@
 	 * @return String
 	 * @param $url String
-	final protected function get ($url) {
-		$x = new connector($url);
+	final protected function get ($url, $auth=false) {
+		if (!$auth) {
+			$x = new connector($url);
+		} else {
+			$x = new connector($url, $auth);
 		$xml = $x->file;
 		if(!$xml){
 			throw new Exception("Unable to open document: " . $url);
@@ -117,13 +121,16 @@
 	 * @return String
-	final protected function post ($url, $postData) {
+	final protected function post ($url, $postData, $auth=false) {
 		$x = new connector();
 		$x->set("httpType", "post");
 		$x->set("httpPostData", $postData);
 		$x->set("httpContentType", "XML");
-		$xml = $x->load($url);
+		if (!$auth) {
+			$xml = $x->load($url);
+		} else {
+			$xml = $x->load($url, $auth);
 		if(!$xml){
 			return null;
@@ -136,24 +143,41 @@
 	 * which is retrieved from a URL.
 	 * @return Ows
-	 * @param $url String
+	 * @param $url String, $auth authentication info hash
-	final public function createFromUrl ($url) {
-		try {
-			$xml = $this->get($url);
+	final public function createFromUrl ($url, $auth=false) {
+		if (!$auth) {
+			try {
+				$xml = $this->get($url);
-			$myOws = $this->createFromXml($xml);
-			if ($myOws != null) {
-				$myOws->uploadUrl = $url;
-				return $myOws;
+				$myOws = $this->createFromXml($xml);
+				if ($myOws != null) {
+					$myOws->uploadUrl = $url;
+					return $myOws;
+				return null;
+			catch (Exception $e) {
+				new mb_exception($e);
+				return null;
 			return null;
-		catch (Exception $e) {
-			new mb_exception($e);
+		} else {
+			try {
+				$xml = $this->get($url, $auth);
+				$myOws = $this->createFromXml($xml, $auth);
+					return $myOws;
+				return null;
+				return null;
 			return null;
-		return null;
\ No newline at end of file
Modified: trunk/mapbender/http/classes/class_universal_wfs_factory.php
--- trunk/mapbender/http/classes/class_universal_wfs_factory.php	2014-02-20 07:23:30 UTC (rev 8784)
+++ trunk/mapbender/http/classes/class_universal_wfs_factory.php	2014-02-28 11:51:21 UTC (rev 8785)
@@ -59,12 +59,11 @@
 	 * the capabilities document up-front.
 	 * @return Wfs
-	 * @param $xml String
+	 * @param $xml String, $auth - optional array with authentication info, default false
-	public function createFromXml ($xml) {
+	public function createFromXml ($xml, $auth=false) {
 		try {
 			$version = $this->getVersionFromXml($xml);
 			switch ($version) {
 				case "1.0.0":
 					$factory = new Wfs_1_0_Factory();
@@ -79,7 +78,7 @@
 					throw new Exception("Unknown WFS version " . $version);
 					break;
-			return $factory->createFromXml($xml);
+			return $factory->createFromXml($xml, $auth);
Modified: trunk/mapbender/http/classes/class_universal_wms_factory.php
--- trunk/mapbender/http/classes/class_universal_wms_factory.php	2014-02-20 07:23:30 UTC (rev 8784)
+++ trunk/mapbender/http/classes/class_universal_wms_factory.php	2014-02-28 11:51:21 UTC (rev 8785)
@@ -51,7 +51,7 @@
 	 * @return Wms
 		try {
@@ -63,7 +63,7 @@
 					throw new Exception("Unknown WMS version " . $version);
 					break;
@@ -138,4 +138,4 @@
Modified: trunk/mapbender/http/classes/class_wfs.php
--- trunk/mapbender/http/classes/class_wfs.php	2014-02-20 07:23:30 UTC (rev 8784)
+++ trunk/mapbender/http/classes/class_wfs.php	2014-02-28 11:51:21 UTC (rev 8785)
@@ -102,7 +102,8 @@
 		if ($filter != null) {
 				$url .= "&filter=" . urlencode($filter);
-		return $this->get($url);
+                $e = new mb_notice("class_wfs.php: getFeatureGet: ".$url);
+		return $this->get($url); //from class_ows!
 	protected function getFeaturePost ($featureTypeName, $filter, $destSrs, $storedQueryId, $storedQueryParams, $maxFeatures) {
@@ -179,19 +180,20 @@
 		$postData .= "</wfs:GetFeature>";
+                $e = new mb_notice("class_wfs.php: getFeaturePost: ".$postData);
 	        if ($filter == null) {
 			if ($maxFeatures != null) {
-				$e = new mb_exception("maxfeatures: ".$maxFeatures);
+				$e = new mb_notice("maxfeatures: ".$maxFeatures);
 				return $this->getFeatureGet($featureTypeName, null, $maxFeatures);
 			} else {
 				return $this->getFeatureGet($featureTypeName, null, null);
 		} else {
 			if (is_int($maxFeatures)) {
-				return $this->post($this->getFeature."&MAXFEATURES=".$maxFeatures, $postData);
+				return $this->post($this->getFeature."&MAXFEATURES=".$maxFeatures, $postData); //from class_ows!
 			} else {
-				return $this->post($this->getFeature, $postData);
+				return $this->post($this->getFeature, $postData); //from class_ows!
@@ -264,7 +266,7 @@
 		$postData = $this->wrapTransaction($featureType, $requestData);
-		return $this->post($this->transaction, $postData);
+		return $this->post($this->transaction, $postData); //from class_ows!
 	protected function transactionInsert ($feature, $featureType, $authWfsConfElement, $gml, $geomColumnName) {
Modified: trunk/mapbender/http/classes/class_wfsToDb.php
--- trunk/mapbender/http/classes/class_wfsToDb.php	2014-02-20 07:23:30 UTC (rev 8784)
+++ trunk/mapbender/http/classes/class_wfsToDb.php	2014-02-28 11:51:21 UTC (rev 8785)
@@ -58,9 +58,13 @@
 		$sql .= "city , deliverypoint , administrativearea , ";
 		$sql .= "postalcode , voice , facsimile , ";
 		$sql .= "electronicmailaddress , country , ";
- 		$sql .= "wfs_owner, wfs_timestamp, wfs_timestamp_create, uuid) ";
-		$sql .= "VALUES ($1, $2, $3, $4, $5, $6, $7, $8, $9, $10, $11, $12, $13, $14 ,$15, $16, $17, $18, $19, $20, $21, $22, $23, $24, $25, $26, $27)";
+ 		$sql .= "wfs_owner, wfs_timestamp, wfs_timestamp_create, uuid, wfs_username, wfs_password, wfs_auth_type) ";
+		$sql .= "VALUES ($1, $2, $3, $4, $5, $6, $7, $8, $9, $10, $11, $12, $13, $14 ,$15, $16, $17, $18, $19, $20, $21, $22, $23, $24, $25, $26, $27, $28, $29, $30)";
+		if (!($aWfs->auth)) {
+			$aWfs->auth['username'] = "";
+			$aWfs->auth['password'] = "";
+			$aWfs->auth['auth_type'] = "";
 		$v = array(
 			$aWfs->getVersion(),
 			$aWfs->name,
@@ -88,10 +92,13 @@
 			Mapbender::session()->get("mb_user_id"),
 			strtotime("now"),
 			strtotime("now"),
-			$uuid
+			$uuid,
+			$aWfs->auth['username'],
+			$aWfs->auth['password'],
-		$t = array('s', 's', 's', 's', 's', 's', 's', 's', 's', 's', 's', 's', 's', 's', 's', 's', 's', 's', 's', 's', 's', 's', 's', 'i', 'i','i','s');
+		$t = array('s', 's', 's', 's', 's', 's', 's', 's', 's', 's', 's', 's', 's', 's', 's', 's', 's', 's', 's', 's', 's', 's', 's', 'i', 'i','i','s','s','s','s');
 		$res = db_prep_query($sql, $v, $t);
@@ -159,7 +166,11 @@
 		if (!isset($aWfs->wfs_network_access) || ($aWfs->wfs_network_access == '')) {
 			$aWfs->wfs_network_access = intval('0');
 		$admin = new administration();
 		db_begin();
@@ -172,7 +183,7 @@
 		$sql .= "city = $16, deliverypoint = $17, administrativearea = $18, ";
 		$sql .= "postalcode = $19, voice = $20, facsimile = $21, ";
 		$sql .= "electronicmailaddress = $22, country = $23, ";
-		$sql .= "wfs_timestamp = $24, wfs_network_access = $25, fkey_mb_group_id = $26, wfs_max_features = $28, inspire_annual_requests = $29 ";
+		$sql .= "wfs_timestamp = $24, wfs_network_access = $25, fkey_mb_group_id = $26, wfs_max_features = $28, inspire_annual_requests = $29, wfs_username = $30, wfs_password = $31, wfs_auth_type = $32";
 		$sql .= "WHERE wfs_id = $27";
 		$v = array(
@@ -204,10 +215,13 @@
 				$aWfs->fkey_mb_group_id,
 				$aWfs->id,
 				$aWfs->wfs_max_features,
-				$aWfs->inspire_annual_requests
+				$aWfs->inspire_annual_requests,
+				$aWfs->auth['auth_type'],
-		$t = array('s', 's', 's', 's', 's', 's', 's', 's' ,'s' ,'s' ,'s' ,'s','s' ,'s','s','s','s','s','s','s','s','s','s','i','i','i','i','i','i');
+		$t = array('s', 's', 's', 's', 's', 's', 's', 's' ,'s' ,'s' ,'s' ,'s','s' ,'s','s','s','s','s','s','s','s','s','s','i','i','i','i','i','i','s','s','s');
 		$e = new mb_notice("class_wfsToDb.php: UPDATING WFS " . $aWfs->id);
 		if (!$res) {
@@ -409,7 +423,7 @@
 	public static function delete ($aWfs) {
 		//first delete coupled metadata, cause there is no contraints in the database to do so
-		$e = new mb_exception("Deleting MetadataURLs for wfs with id :".$aWfs->id);
+		$e = new mb_notice("Deleting MetadataURLs for wfs with id :".$aWfs->id);
 		//WfsToDb::deleteFeatureTypeMetadataUrls($aWfs->id); //Not needed any more, cause the relations are deleted thru class_iso19139.php
 		//then delete wfs itself
 		$sql = "DELETE FROM wfs WHERE wfs_id = $1";
@@ -1075,7 +1089,7 @@
 		// insert feature type MetadataURL
-		$e = new mb_exception("Number of metadataurls for featuretype ".$aWfsFeatureType->id." : ".count($aWfsFeatureType->metadataUrlArray));
+		$e = new mb_notice("Number of metadataurls for featuretype ".$aWfsFeatureType->id." : ".count($aWfsFeatureType->metadataUrlArray));
 		for ($i = 0; $i < count($aWfsFeatureType->metadataUrlArray); $i++) {
 			$metadataUrl = $aWfsFeatureType->metadataUrlArray[$i];
 			if (!WfsToDb::insertFeatureTypeMetadataUrl($aWfsFeatureType->id, $metadataUrl)) {
Modified: trunk/mapbender/http/classes/class_wfs_1_0_factory.php
--- trunk/mapbender/http/classes/class_wfs_1_0_factory.php	2014-02-20 07:23:30 UTC (rev 8784)
+++ trunk/mapbender/http/classes/class_wfs_1_0_factory.php	2014-02-28 11:51:21 UTC (rev 8785)
@@ -36,12 +36,15 @@
 			$aWfs->getConjunctionCharacter($aWfs->describeFeatureType) .
 			"&SERVICE=WFS&VERSION=" . $aWfs->getVersion() .
 			"&REQUEST=DescribeFeatureType&TYPENAME=" . $featureTypeName;
+		if (isset($aWfs->auth)) {
+			$xml = $this->get($url, $aWfs->auth);
+		} else {
 		return $this->createFeatureTypeFromXml ($xml, $aWfs,$featureTypeName);
-	protected function createFeatureTypeFromXml ($xml, $myWfs,$featureTypeName) {
+	protected function createFeatureTypeFromXml ($xml, $myWfs, $featureTypeName) {
 		$newFeatureType = new WfsFeatureType($myWfs);
 		$doc = new DOMDocument();
@@ -121,16 +124,18 @@
 	 * @return Wfs_1_0
 		try {
 			$myWfs = new Wfs_1_0();
 			//new for parsing with simple xml:
 			$myWfs->getCapabilitiesDoc = $admin->char_encode($xml);
 			$myWfs->id = $this->createId();
+			//check for authentication
+			if (!$auth) {
+				$e = new mb_notice("class_wfs_1_0_factory.php - createFromXml - no athentication info given!");
+			$myWfs->auth = $auth; //always!
 			try {
 				$xml = str_replace('xlink:href', 'xlinkhref', $xml);
 				#http://forums.devshed.com/php-development-5/simplexml-namespace-attributes-problem-452278.html
Modified: trunk/mapbender/http/classes/class_wfs_1_1_factory.php
--- trunk/mapbender/http/classes/class_wfs_1_1_factory.php	2014-02-20 07:23:30 UTC (rev 8784)
+++ trunk/mapbender/http/classes/class_wfs_1_1_factory.php	2014-02-28 11:51:21 UTC (rev 8785)
@@ -71,8 +71,11 @@
 		$url = $aWfs->describeFeatureType .
 			implode("&", $paramArray);
-		$e = new mb_exception($url);
+			$e = new mb_notice("class_wfs_1_1_factory.php - createFeatureTypeFromUrlGet: authentication for wfs not given");
 		//parse result to see if it is a real featuretype description
 		return $this->createFeatureTypeFromXml ($xml, $aWfs, $featureTypeName);
@@ -86,10 +89,9 @@
-		//$e = new mb_exception($xml);
 		$doc->loadXML($xml);
-		$e = new mb_exception("class_wfs_1_1_factory.php: Got following FeatureType XML: ".$xml);
+		$e = new mb_notice("class_wfs_1_1_factory.php: Got following FeatureType XML: ".$xml);
 		$xpath =  new DOMXpath($doc);
 		$xpath->registerNamespace("xs","http://www.w3.org/2001/XMLSchema");
@@ -164,17 +166,18 @@
 	 * @return Wfs_1_1
 		try {
 			$myWfs = new Wfs_1_1();
+			if (!$auth) {
+				$e = new mb_notice("class_wfs_1_1_factory.php - createFromXml - no authentication info given!");
 			$featuretype_crsArray = array();//new for wfs 1.1.0
 			try {
@@ -259,7 +262,7 @@
 				$myWfs->getCapabilities = $wfs11Cap->xpath('/wfs:WFS_Capabilities/ows:OperationsMetadata/ows:Operation[@name="GetCapabilities"]/ows:DCP/ows:HTTP/ows:Get/@xlinkhref');
 				$myWfs->getCapabilities = html_entity_decode($myWfs->getCapabilities[0]);
-				$e = new mb_exception($myWfs->getCapabilities);#get
+				$e = new mb_notice($myWfs->getCapabilities);#get
 				$myWfs->describeFeatureType = $wfs11Cap->xpath('/wfs:WFS_Capabilities/ows:OperationsMetadata/ows:Operation[@name="DescribeFeatureType"]/ows:DCP/ows:HTTP/ows:Get/@xlinkhref');
 				$myWfs->describeFeatureType = html_entity_decode($myWfs->describeFeatureType[0]);#get
Modified: trunk/mapbender/http/classes/class_wfs_2_0_factory.php
--- trunk/mapbender/http/classes/class_wfs_2_0_factory.php	2014-02-20 07:23:30 UTC (rev 8784)
+++ trunk/mapbender/http/classes/class_wfs_2_0_factory.php	2014-02-28 11:51:21 UTC (rev 8785)
@@ -48,8 +48,11 @@
 		$postData .= "><TypeName>" . $featureTypeName . "</TypeName>" .
 				"</DescribeFeatureType>";
-		$xml = $this->post($aWfs->describeFeatureType, $postData);
+			$xml = $this->post($aWfs->describeFeatureType, $postData, $aWfs->auth);
+		} else {
+			$xml = $this->post($aWfs->describeFeatureType, $postData);
@@ -73,7 +76,7 @@
@@ -90,7 +93,7 @@
 			$aWfs->getConjunctionCharacter($listStoredQueries) .
 		#$e = new mb_notice("class_wfs_2_0_factory.php: Got following StoredQuery XML: ".$xml);
@@ -284,17 +287,17 @@
 	 * @return Wfs_2_0
 		try {
 			$myWfs = new Wfs_2_0();
+			if (!$auth) {
+				$e = new mb_notice("class_wfs_2_0_factory.php - createFromXml - no athentication info given!");
 			try {
Modified: trunk/mapbender/http/classes/class_wfs_factory.php
--- trunk/mapbender/http/classes/class_wfs_factory.php	2014-02-20 07:23:30 UTC (rev 8784)
+++ trunk/mapbender/http/classes/class_wfs_factory.php	2014-02-28 11:51:21 UTC (rev 8785)
@@ -113,6 +113,14 @@
 			$aWfs->inspire_annual_requests = db_result($res, $cnt, "inspire_annual_requests");
 			$aWfs->fkey_mb_group_id = db_result($res, $cnt, "fkey_mb_group_id");
 			$aWfs->uuid = db_result($res, $cnt, "uuid");
+			if(db_result($res, $cnt, "wfs_username") != '' && db_result($res, $cnt, "wfs_auth_type") !='' && db_result($res, $cnt, "wfs_password") !=''){
+				$e = new mb_notice("class_wfs_factory.php - createFromDb: wfs has all 3 auth strings not empty!");
+				$aWfs->auth['username'] = db_result($res, $cnt, "wfs_username");
+				$aWfs->auth['password'] = db_result($res, $cnt, "wfs_password");
+				$aWfs->auth['auth_type'] = db_result($res, $cnt, "wfs_auth_type");
+			} else {
+				$aWfs->auth = false;
 			// Featuretypes
 			$sql_fe = "SELECT * FROM wfs_featuretype WHERE fkey_wfs_id = $1 ORDER BY featuretype_id";
 			$v = array($aWfs->id);
Modified: trunk/mapbender/http/classes/class_wmc_factory.php
--- trunk/mapbender/http/classes/class_wmc_factory.php	2014-02-20 07:23:30 UTC (rev 8784)
+++ trunk/mapbender/http/classes/class_wmc_factory.php	2014-02-28 11:51:21 UTC (rev 8785)
@@ -24,10 +24,10 @@
 	 * @return wmc
 		try {
 			$wmc = new wmc();
-			$wmc->createFromXml($xml);
+			$wmc->createFromXml($xml, $auth);
 			throw new Exception("Could not create WMC from XML.");
Modified: trunk/mapbender/http/classes/class_wms.php
--- trunk/mapbender/http/classes/class_wms.php	2014-02-20 07:23:30 UTC (rev 8784)
+++ trunk/mapbender/http/classes/class_wms.php	2014-02-28 11:51:21 UTC (rev 8785)
@@ -527,7 +527,6 @@
 		$res = db_query($sql);
 		while ($row = db_fetch_array($res)){
 			$inspireCatHash[$row['inspire_category_code_en']] = (integer)$row['inspire_category_id'];
-			//$e = new mb_exception("inspireCatHash: ".$row['inspire_category_code_en'] ." : ". $row['inspire_category_id'] );
 		//custom
 		//keywords - as text i custom category - special keywords of geoportal instance defined as keys!
@@ -535,8 +534,7 @@
 		$sql = "SELECT custom_category_id, custom_category_key FROM custom_category";
-			$customCatHash[$row['custom_category_key']] = (integer)$row['custom_category_id'];
-			//$e = new mb_exception("customCatHash: ".$row['custom_category_key'] ." : ". $row['custom_category_id'] );
+			$customCatHash[$row['custom_category_key']] = (integer)$row['custom_category_id'];
 		$data = $x->file;
 		if ($data=='401') {
@@ -1086,10 +1084,10 @@
 			$returnObject['message'] = _mb("WMS has double layer names and could therefor not be loaded!");
 			return $returnObject;
 		if(!$this->wms_title || $this->wms_title == "" || !$this->wms_getmap || $this->wms_getmap == ""){
 			$this->wms_status = false;
-			$this->optimizeWMS();
+			//$this->optimizeWMS();
 			$e = new mb_exception("class_wms: createObjFromXML: WMS " . $url . " could not be loaded.");
 			$returnObject['success'] = false;
 			$returnObject['message'] = _mb("WMS could not be loaded!");
@@ -1163,8 +1161,9 @@
 		#some default
 		$this->gui_wms_visible = 1;
 		$this->gui_wms_opacity = 100;
-		/*if the rootlayer has no epsg...*/
-		if($this->objLayer[0]->layer_epsg[0]["epsg"] == ""){
+		/*if the rootlayer has no epsg...read them from following layer TODO what if this layer have also no SRS?*/
+		$testVar = $this->objLayer[0]->layer_epsg[0]["epsg"];
+		if($this->objLayer[0]->layer_epsg[0]["epsg"] == "" || empty($testVar)){
 			$this->objLayer[0]->layer_epsg = $this->objLayer[1]->layer_epsg;
 			for($i=0;$i<count($this->objLayer[0]->layer_epsg);$i++){
 				for($j=1; $j<count($this->objLayer); $j++){
@@ -2651,7 +2650,6 @@
 			$this->wms_network_access = $row["wms_network_access"];
 			$this->wms_max_imagesize = $row["wms_max_imagesize"];
 			$this->inspire_annual_requests = $row["inspire_annual_requests"];
-			//$e = new mb_exception("class_wms.php: wms_network_access from database: ".$this->wms_network_access);
 		//if network access is either stored in database nor given thru object, set it too a default value 0
 		if (!isset($this->wms_network_access) || ($this->wms_network_access == '')) {
@@ -2848,7 +2846,6 @@
 			if($i>0){$sql .= ',';}
 			$sql .= "$".$c;
 			array_push($v,$this->objLayer[$i]->layer_name);
-			#$e = new mb_exception("class_wms: old layer name added for read: ".$this->objLayer[$i]->layer_name);
 			array_push($t,'s');
 			$c++;
@@ -2896,7 +2893,6 @@
 			$sql .= "$".$c;
-			#$e = new mb_exception("class_wms: old layer name added for delete: ".$this->objLayer[$i]->layer_name);
 			array_push($t,'s');
 			$c++;
@@ -3406,7 +3402,6 @@
 				else{
 					if($row2["legendurl"]!=''){
 						$this->objLayer[$layer_cnt]->layer_style[$count_layer_style]["legendurl"]=$row2["legendurl"];
-						#$e = new mb_exception("legendurl = ".$this->objLayer[$layer_cnt]->layer_style[$count_layer_style]["legendurl"]);
 				$this->objLayer[$layer_cnt]->layer_style[$count_layer_style]["legendurlformat"]=$row2["legendurlformat"];
@@ -3485,7 +3480,6 @@
 			//the following things are not given without a special gui!!!!!
 			$this->gui_wms_epsg=$row["gui_wms_epsg"];
-			//$e = new mb_exception("gui_wms_epsg: ".$this->gui_wms_epsg); --this is not there if update of metadata is made! Problem when updateing metadata with metadata editor
 			$this->gui_wms_sldurl = $row["gui_wms_sldurl"];
 			if($this->wms_version == "1.0.0"){
Modified: trunk/mapbender/http/classes/class_wms_1_1_1_factory.php
--- trunk/mapbender/http/classes/class_wms_1_1_1_factory.php	2014-02-20 07:23:30 UTC (rev 8784)
+++ trunk/mapbender/http/classes/class_wms_1_1_1_factory.php	2014-02-28 11:51:21 UTC (rev 8785)
@@ -24,7 +24,7 @@
 	 * @return Wms
 	public function createFromDb ($id) {
Modified: trunk/mapbender/http/geoportal/mod_pullInspireMonitoring.php
--- trunk/mapbender/http/geoportal/mod_pullInspireMonitoring.php	2014-02-20 07:23:30 UTC (rev 8784)
+++ trunk/mapbender/http/geoportal/mod_pullInspireMonitoring.php	2014-02-28 11:51:21 UTC (rev 8785)
@@ -247,13 +247,15 @@
 select metadata_layer.title, metadata_layer.uuid, resource_id, resource_uuid, resource_type, inspire_actual_coverage, inspire_whole_area, service_id, inspire_download, wms_owner as service_owner, fkey_mb_group_id as service_group, wms_title as service_title, f_collect_inspire_cat_layer(resource_id) as inspire_cat from (select title,uuid ,resource_uuid, layer_id as resource_id, 'layer' as resource_type, fkey_wms_id as service_id, inspire_download, inspire_actual_coverage, inspire_whole_area from (select layer.layer_id, layer.fkey_wms_id, layer.uuid as resource_uuid, layer.inspire_download, layer_custom_category.fkey_custom_category_id from layer inner join layer_custom_category on layer.layer_id = layer_custom_category.fkey_layer_id where layer_custom_category.fkey_custom_category_id = $inspireCatId AND layer_searchable = 1 ORDER BY layer_id) as layer_inspire inner join (select metadata_id, uuid, title, inspire_actual_coverage, inspire_whole_area, fkey_layer_id from mb_metada
 ta inner join ows_relation_metadata on ows_relation_metadata.fkey_metadata_id = mb_metadata.metadata_id) as metadata_relation on metadata_relation.fkey_layer_id = layer_inspire.layer_id) as metadata_layer INNER JOIN wms ON metadata_layer.service_id = wms_id
+SQL;
 union
 select metadata_featuretype.title, metadata_featuretype.uuid, resource_id, resource_uuid, resource_type,inspire_actual_coverage, inspire_whole_area, service_id, inspire_download, wfs_owner as service_owner, fkey_mb_group_id as service_group, wfs_title as service_title, f_collect_inspire_cat_wfs_featuretype(resource_id) as inspire_cat from (select title, uuid, resource_uuid, featuretype_id as resource_id, 'wfs_featuretype' as resource_type, fkey_wfs_id as service_id, inspire_download, inspire_actual_coverage, inspire_whole_area from (select wfs_featuretype.featuretype_id ,wfs_featuretype.fkey_wfs_id,  wfs_featuretype.inspire_download, wfs_featuretype.uuid as resource_uuid from wfs_featuretype) as featuretype_inspire inner join (select metadata_id, uuid, title, fkey_featuretype_id, inspire_actual_coverage, inspire_whole_area from mb_metadata inner join ows_relation_metadata on ows_relation_metadata.fkey_metadata_id = mb_metadata.metadata_id) as metadata_relation on metadata_re
 lation.fkey_featuretype_id = featuretype_inspire.featuretype_id) as metadata_featuretype INNER JOIN wfs ON metadata_featuretype.service_id = wfs_id
 order by uuid
-SQL;
 } else {
@@ -265,15 +267,17 @@
 select metadata_featuretype.title, wfs.uuid as service_uuid, wfs_title || ':' || featuretype_title as inspire_service_title, metadata_featuretype.uuid, metadata_featuretype.datasetid, metadata_featuretype.datasetid_codespace, resource_id, resource_uuid, resource_type, service_id, inspire_download, wfs_owner as service_owner, fkey_mb_group_id as service_group, wfs_title as service_title, f_collect_inspire_cat_wfs_featuretype(resource_id) as inspire_cat from (select title, uuid, datasetid, datasetid_codespace, featuretype_id as resource_id, 'wfs_featuretype' as resource_type, resource_uuid, fkey_wfs_id as service_id, inspire_download, featuretype_title from (select wfs_featuretype.featuretype_id , wfs_featuretype.featuretype_title, wfs_featuretype.fkey_wfs_id,  wfs_featuretype.inspire_download, wfs_featuretype.uuid as resource_uuid from wfs_featuretype inner join wfs_featuretype_custom_category on wfs_featuretype.featuretype_id = wfs_featuretype_custom_category.fkey_featuretyp
 e_id where wfs_featuretype_custom_category.fkey_custom_category_id = $inspireCatId AND featuretype_searchable = 1 ORDER BY featuretype_id) as featuretype_inspire inner join (select metadata_id, datasetid, datasetid_codespace, uuid, title, fkey_featuretype_id from mb_metadata inner join ows_relation_metadata on ows_relation_metadata.fkey_metadata_id = mb_metadata.metadata_id) as metadata_relation on metadata_relation.fkey_featuretype_id = featuretype_inspire.featuretype_id) as metadata_featuretype INNER JOIN wfs ON metadata_featuretype.service_id = wfs_id
-union
-select title, null as service_uuid, null as inspire_service_title, uuid, datasetid, datasetid_codespace, metadata_id as resource_id, null as resource_uuid, null as resource_type, null as service_id, null as inspire_download, fkey_mb_user_id as service_owner, null as service_group, null as service_title, f_collect_inspire_cat_dataset(metadata_id) as inspire_cat from mb_metadata inner join mb_metadata_custom_category on mb_metadata.metadata_id = mb_metadata_custom_category.fkey_metadata_id where mb_metadata_custom_category.fkey_custom_category_id = $inspireCatId
 ) as foo $sWhere $sOrder $sLimit
 SQL;
+union
+select title, null as service_uuid, null as inspire_service_title, uuid, datasetid, datasetid_codespace, metadata_id as resource_id, null as resource_uuid, null as resource_type, null as service_id, null as inspire_download, fkey_mb_user_id as service_owner, null as service_group, null as service_title, f_collect_inspire_cat_dataset(metadata_id) as inspire_cat from mb_metadata inner join mb_metadata_custom_category on mb_metadata.metadata_id = mb_metadata_custom_category.fkey_metadata_id where mb_metadata_custom_category.fkey_custom_category_id = $inspireCatId
 $startTime = microtime();
 //get all service / owner / fkey_group information for the list of services
Modified: trunk/mapbender/http/javascripts/initWmcObj.php
--- trunk/mapbender/http/javascripts/initWmcObj.php	2014-02-20 07:23:30 UTC (rev 8784)
+++ trunk/mapbender/http/javascripts/initWmcObj.php	2014-02-28 11:51:21 UTC (rev 8785)
@@ -335,10 +335,8 @@
 //KML
 $inputKmlArray = $getApi->getKml();
-$e = new mb_exception("initWmcObj.php: check KML API");
 if($inputKmlArray){
 	$wmc->generalExtensionArray['KML'] = $inputKmlArray;
-	$e = new mb_exception("initWmcObj.php: found KML");
 //TODO test following
 //workaround to have a fully merged WMC for loading
Modified: trunk/mapbender/http/javascripts/mod_wfsGazetteerEditor_client.php
--- trunk/mapbender/http/javascripts/mod_wfsGazetteerEditor_client.php	2014-02-20 07:23:30 UTC (rev 8784)
+++ trunk/mapbender/http/javascripts/mod_wfsGazetteerEditor_client.php	2014-02-28 11:51:21 UTC (rev 8785)
@@ -634,11 +634,22 @@
 	var submit_attr = document.getElementById("attrPanel_Submit");
 	var epsgCode = parent.mb_mapObj[ind].getSRS().toUpperCase();
-	var epsgCodeSplit = epsgCode.split(":");
+	var epsgString = parent.mb_mapObj[ind].getSRS();
+	//check for "http://www.opengis.net/gml/srs/epsg.xml#4326"
+	if (epsgString.search("http://www.opengis.net/gml/srs/epsg.xml") !== -1) {
+		var epsgCodeSplit = epsgCode.split("#");
+	} else {
+		var epsgCodeSplit = epsgCode.split(":");
 	var epsgString = epsgCodeSplit[1];
-	var ftSrs = global_wfsConfObj[global_selectedWfsConfId].featuretype_srs;
-	var ftSrsSplit = ftSrs.split(":");
+	var ftSrs = global_wfsConfObj[global_selectedWfsConfId].featuretype_srs;
+	if (ftSrs.search("http://www.opengis.net/gml/srs/epsg.xml") !== -1) {
+		var ftSrsSplit = ftSrs.split("#");
+	} else {
+		var ftSrsSplit = ftSrs.split(":");
 	if(ftSrsSplit.length > 2) {
 		if(ftSrsSplit.length == 6) {
Modified: trunk/mapbender/http/javascripts/mod_wfsGazetteerEditor_server.php
--- trunk/mapbender/http/javascripts/mod_wfsGazetteerEditor_server.php	2014-02-20 07:23:30 UTC (rev 8784)
+++ trunk/mapbender/http/javascripts/mod_wfsGazetteerEditor_server.php	2014-02-28 11:51:21 UTC (rev 8785)
@@ -169,9 +169,9 @@
 	$myWfsFactory = new UniversalWfsFactory();
 	$myWfs = $myWfsFactory->createFromDb($wfsId);
 	$data = $myWfs->getFeature($typename, $filter,$destSrs, $storedQueryId, $storedQueryParams, null);
+	//$e = new mb_exception($filter);
+	$e = new mb_exception($data);
-	#new mb_exception($data);
 	if ($data === null) die('{}');
 	if (defined("WFS_RESPONSE_SIZE_LIMIT") && WFS_RESPONSE_SIZE_LIMIT < strlen($data)) {
@@ -214,13 +214,14 @@
 	$data = $myWfs->getFeature($wfsFeatureTypeName, null, $destSrs, null, null, 20);
 		die("Too many results, please restrict your search.");
 	$gmlFactory = new UniversalGmlFactory();
-	//TODO: The follwoning code is not nice but more stable - exchange it later with the code below!
+	//TODO: The following code is not nice but more stable - exchange it later with the code below!
 	$parser = xml_parser_create();
 	xml_parser_set_option($parser,XML_OPTION_CASE_FOLDING,0);
         xml_parser_set_option($parser,XML_OPTION_SKIP_WHITE,1);
Modified: trunk/mapbender/http/php/mod_loadWFSCapabilities.php
--- trunk/mapbender/http/php/mod_loadWFSCapabilities.php	2014-02-20 07:23:30 UTC (rev 8784)
+++ trunk/mapbender/http/php/mod_loadWFSCapabilities.php	2014-02-28 11:51:21 UTC (rev 8785)
@@ -164,8 +164,19 @@
 if (isset($xml_file)){
 	echo"<input type='text' name='xml_file' size='50' value='".$xml_file."'>";
 }else{
-	echo"<input type='text' name='xml_file' size='50' value='http://'>";
+	echo"<input type='text' name='xml_file' size='50' value='http://'><br>";
+//show fields for authentication - only possible if curl is used as connector!
+if (CONNECTION == 'curl') {
+	echo"HTTP Authentication:<br>";
+	echo"<input type='radio' name='auth_type' checked='checked' value='none'>None<br>";
+	echo"<input type='radio' name='auth_type' value='digest'>Digest<br>";
+    	echo"<input type='radio' name='auth_type' value='basic'>Basic<br>";
+	echo"Username<br>";
+	echo"<input type='text' name='username' size='50' value=''><br>";
+	echo"Password:<br>";
+	echo"<input type='text' name='password' size='50' value=''><br>";
 echo"<input type='button' name='loadCap' value='Load' onClick='validate(\"guiList\")'>";
 echo "</form>";
Modified: trunk/mapbender/http/php/mod_loadwfs.php
--- trunk/mapbender/http/php/mod_loadwfs.php	2014-02-20 07:23:30 UTC (rev 8784)
+++ trunk/mapbender/http/php/mod_loadwfs.php	2014-02-28 11:51:21 UTC (rev 8785)
@@ -24,25 +24,56 @@
 echo "file: ".$_REQUEST["xml_file"];
 echo "<br>-------------------------------<br>";
 $guiList = mb_validateInput($_REQUEST["guiList"]);
 $url = mb_validateInput($_REQUEST["xml_file"]);
-$myWfs = $myWfsFactory->createFromUrl($url);
-if (is_null($myWfs)) {
-	echo "WFS could not be uploaded.";
-	die;
+if ($_REQUEST["auth_type"] == 'basic' || $_REQUEST["auth_type"] == 'digest') {
+	$auth = array();
+    	$auth['username'] = $_REQUEST["username"];
+    	$auth['password'] = $_REQUEST["password"];
+    	$auth['auth_type'] = $_REQUEST["auth_type"];
+if (isset($auth)) {
+	echo "auth set";
+	echo $auth['username']."<br>";
+	echo $auth['password']."<br>";
+	echo $auth['auth_type']."<br>";
+	$myWfs = $myWfsFactory->createFromUrl($url, $auth);
+	//store the authentication information in the object
+	if (isset($myWfs->auth)) {
+		$e = new mb_exception("ows auth set");
+	//TODO
+	//$myWfs = $myWfsFactory->createFromUrl($url,$auth);
+	/*$result = $mywms->createObjFromXML($xml, $auth);
+	if ($result['success']) {
+		$mywms->writeObjInDB($gui_id, $auth);
+	} else {
+		echo $result['message'];
+		die();
+} else {
+	$myWfs = $myWfsFactory->createFromUrl($url);
+	if (is_null($myWfs)) {
+		echo "WFS could not be uploaded.";
+		die;
+	/*$result = $mywms->createObjFromXML($xml);
+		$mywms->writeObjInDB($gui_id);
+	} else {
+		die();
+$e = new mb_exception($myWfs->auth['username']);
 $myWfs->insertOrUpdate();
 // link WFS to GUIs in $guiList
 $guiArray = explode(",", $guiList);
 foreach ($guiArray as $appName) {
 	$currentApp = new gui($appName);
 	$currentApp->addWfs($myWfs);
 echo $myWfs;
Modified: trunk/mapbender/http/php/mod_loadwms.php
--- trunk/mapbender/http/php/mod_loadwms.php	2014-02-20 07:23:30 UTC (rev 8784)
+++ trunk/mapbender/http/php/mod_loadwms.php	2014-02-28 11:51:21 UTC (rev 8785)
@@ -21,19 +21,16 @@
 require_once(dirname(__FILE__) . "/../classes/class_wms.php");
 if(isset($_REQUEST["wms_id"]) == false) {
-    echo "file: ".$_REQUEST["xml_file"];
-    $gui_id = $_REQUEST["guiList"];
-    $xml = $_REQUEST["xml_file"];
-    if ($_REQUEST["auth_type"] == 'basic'
-		|| $_REQUEST["auth_type"] == 'digest') {
+	echo "file: ".$_REQUEST["xml_file"];
+    	$gui_id = $_REQUEST["guiList"];
+    	$xml = $_REQUEST["xml_file"];
+    	if ($_REQUEST["auth_type"] == 'basic' || $_REQUEST["auth_type"] == 'digest') {
 		$auth = array();
-    	$auth['username'] = $_REQUEST["username"];
-    	$auth['password'] = $_REQUEST["password"];
-    	$auth['auth_type'] = $_REQUEST["auth_type"];
-    $mywms = new wms();
+    	$mywms = new wms();
     	if(empty($_POST['twitter_news'])) {
 		$mywms->twitterNews = false;
@@ -48,8 +45,7 @@
 			die();
-	else {
+	} else {
@@ -58,11 +54,9 @@
 			die();
    	$mywms->displayWMS();
 	$wms_id = $mywms->wms_id;
-else {
+} else {
 	$wms_id = $_REQUEST["wms_id"];
 require_once(dirname(__FILE__)."/../php/mod_editWMS_Metadata.php");
Modified: trunk/mapbender/http/php/mod_wfs_server.php
--- trunk/mapbender/http/php/mod_wfs_server.php	2014-02-20 07:23:30 UTC (rev 8784)
+++ trunk/mapbender/http/php/mod_wfs_server.php	2014-02-28 11:51:21 UTC (rev 8785)
@@ -236,6 +236,7 @@
 	$url = $obj->url;
 	$wfsFactory = new UniversalWfsFactory();
 	$myWfs = $wfsFactory->createFromUrl($url);
+        //TODO Problem: How to handle authenticated wfs - the old object should be pulled to get the auth information
 	if (!MD_OVERWRITE) {
 		$myWfs->overwrite = false;
Modified: trunk/mapbender/lib/class_GetApi.php
--- trunk/mapbender/lib/class_GetApi.php	2014-02-20 07:23:30 UTC (rev 8784)
+++ trunk/mapbender/lib/class_GetApi.php	2014-02-28 11:51:21 UTC (rev 8785)
@@ -291,7 +291,6 @@
 		return is_array($input) ? $input : array($input);
 	private function normalizeKmlInput($input){
-		$e = new mb_exception("normalizeKmlInput");
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql	2014-02-20 07:23:30 UTC (rev 8784)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql	2014-02-28 11:51:21 UTC (rev 8785)
@@ -254,5 +254,28 @@
 ALTER TABLE search_wfs_view
   OWNER TO postgres;
+-- Column: wfs_username
+-- ALTER TABLE wfs DROP COLUMN wfs_username;
+ALTER TABLE wfs ADD COLUMN wfs_username character varying(255);
+ALTER TABLE wfs ALTER COLUMN wfs_username SET DEFAULT ''::character varying;
+-- Column: wfs_password
+-- ALTER TABLE wfs DROP COLUMN wfs_password;
+ALTER TABLE wfs ADD COLUMN wfs_password character varying(255);
+ALTER TABLE wfs ALTER COLUMN wfs_password SET DEFAULT ''::character varying;
+-- Column: wfs_auth_type
+-- ALTER TABLE wfs DROP COLUMN wfs_auth_type;
+ALTER TABLE wfs ADD COLUMN wfs_auth_type character varying(255);
+ALTER TABLE wfs ALTER COLUMN wfs_auth_type SET DEFAULT ''::character varying;
+UPDATE wfs SET wfs_username = '' WHERE wfs_username IS NULL;
+UPDATE wfs SET wfs_password = '' WHERE wfs_password IS NULL;
+UPDATE wfs SET wfs_auth_type = '' WHERE wfs_auth_type IS NULL;
Modified: trunk/mapbender/tools/mod_runScheduler.php
--- trunk/mapbender/tools/mod_runScheduler.php	2014-02-20 07:23:30 UTC (rev 8784)
+++ trunk/mapbender/tools/mod_runScheduler.php	2014-02-28 11:51:21 UTC (rev 8785)
@@ -70,15 +70,30 @@
 for ($i=0; $i<count($wmsToUpdate); $i++) {
     	//create new wms object
     	$updateWms = new wms();
-    	$createObjFromXml = $updateWms->createObjFromXML($wmsToUpdate[$i]['wms_upload_url']);
+	try {
+    		$createObjFromXml = $updateWms->createObjFromXML($wmsToUpdate[$i]['wms_upload_url']);
+	catch(Exception $e) {
+  		throw $e;
+		$errorMsg = "Error when creatingObjFromXML from wms_upload_url";
+		continue;
 	$updateWms->owner = $wmsToUpdate[$i]['wms_owner'];
     	if(!$createObjFromXml['success']) {
         	//$errorMsg = "Error while creating object from GetCapabilities XML";
-		$errorMsg =$createObjFromXml['message'];
+		$errorMsg = $createObjFromXml['message'];
+		echo "Error while creating object from GetCapabilities XML";
+		continue;
     	//check scheduler_searchable attribute for layer searchable in class_wms.php
-    	$updateWms->optimizeWMS($wmsToUpdate[$i]['scheduler_searchable']);
+	try {
+    		$updateWms->optimizeWMS($wmsToUpdate[$i]['scheduler_searchable']);
+  		throw $e;
+		$errorMsg = "Error when optimizeWMS";
+		continue;
     	//check overwrite attribute
     	if (!$wmsToUpdate[$i]['scheduler_overwrite']) {
 		echo "overwrite md = false\n";
@@ -104,10 +119,18 @@
 		echo "publish = false\n";
 	echo "Start update of ".$wmsToUpdate[$i]['wms_id']."\n";
-   	$updateObjInDb = $updateWms->updateObjInDB($wmsToUpdate[$i]['wms_id']);
+	try {
+   		$updateObjInDb = $updateWms->updateObjInDB($wmsToUpdate[$i]['wms_id']);
+  		throw $e;
+		$errorMsg = "Error when updateObjInDB(".$wmsToUpdate[$i]['wms_id'].")";
+		continue;
     	if(!$updateObjInDb) {
-    	    $errorMsg = "Error while updating wms object in database";
+    	    	$errorMsg = "Error while updating wms object in database";
+		echo "Error while updating wms object in database";
+	    	continue;
 	if($wmsToUpdate[$i]['scheduler_mail']) {
More information about the Mapbender_commits mailing list
