[Mapbender-commits] r8757 - in trunk/mapbender/http: classes geoportal php plugins
svn_mapbender at osgeo.org
Wed Jan 8 07:34:04 PST 2014
Author: armin11
Date: 2014-01-08 07:34:04 -0800 (Wed, 08 Jan 2014)
New Revision: 8757
trunk/mapbender/http/classes/class_iso19139.php
trunk/mapbender/http/geoportal/mod_pullInspireMonitoring.php
trunk/mapbender/http/php/mod_inspireDownloadFeed.php
trunk/mapbender/http/plugins/mb_downloadFeedClient.php
Some bugfixes for external CSW metadata based INSPIRE dls
Modified: trunk/mapbender/http/classes/class_iso19139.php
--- trunk/mapbender/http/classes/class_iso19139.php 2014-01-03 12:46:10 UTC (rev 8756)
+++ trunk/mapbender/http/classes/class_iso19139.php 2014-01-08 15:34:04 UTC (rev 8757)
@@ -215,6 +215,8 @@
foreach ($this->keywords as $keyword) {
$thesaurusName = $iso19139Xml->xpath('//gmd:MD_Metadata/gmd:identificationInfo/gmd:MD_DataIdentification/gmd:descriptiveKeywords[gmd:MD_Keywords/gmd:keyword/gco:CharacterString="'.$keyword.'"]/gmd:MD_Keywords/gmd:thesaurusName/gmd:CI_Citation/gmd:title/gco:CharacterString');
$this->keywordsThesaurusName[$iKeyword] = $thesaurusName[0];
+ //$e = new mb_exception("Keyword: ".$keyword);
+ //$e = new mb_exception("Thesaurus: ".$thesaurusName[0]);
//check if keyword is inspire thematic key and add it into mapbenders inspire category
if (is_int($inspireCatHash[trim($keyword)])) {
$this->inspireCategories[] = $inspireCatHash[trim($keyword)];
@@ -224,6 +226,25 @@
//$e = new mb_exception("class_iso19139.php: found entry ".$customCatHash[trim($keyword)]." for custom keyword: ".trim($keyword));
$this->customCategories[] = $customCatHash[trim($keyword)];
+ //extract special keywords for mapbenders proxy and inspire monitoring
+ switch ($this->keywordsThesaurusName[$iKeyword]) {
+ case "mapbender.2.inspireDownload":
+ if ($keyword == "1") {
+ $this->inspireDownload = 1;
+ } else {
+ $this->inspireDownload = 0;
+ //$e = new mb_exception("inspireDownload: ".$this->inspireDownload);
+ break;
+ case "mapbender.2.inspireWholeArea":
+ $this->inspireWholeArea = $keyword;
+ //$e = new mb_exception("inspireWholeArea: ".$this->inspireWholeArea);
+ break;
+ case "mapbender.2.inspireActualCoverage":
+ $this->inspireActualCoverage = $keyword;
+ //$e = new mb_exception("inspireActualCoverage: ".$this->inspireActualCoverage);
+ break;
unset($thesaurusName);
$iKeyword++;
@@ -251,6 +272,10 @@
$e = new mb_exception("class_iso19139.php: customcat: ".$category);
$this->downloadLinks = $iso19139Xml->xpath('//gmd:MD_Metadata/gmd:distributionInfo/gmd:MD_Distribution/gmd:transferOptions/gmd:MD_DigitalTransferOptions/gmd:onLine/gmd:CI_OnlineResource[gmd:function/gmd:CI_OnLineFunctionCode/@codeListValue="download"]/gmd:linkage/gmd:URL');
+ //$this->downloadLinks = array_values($this->downloadLinks);
+ //$dump = var_export($this->downloadLinks, true);
+ //$e = new mb_exception("type of this->downloadLinks: ".gettype($this->downloadLinks)." - count: ".count($this->downloadLinks)."- obj: - ".$dump);
+ $this->downloadLinks = (array)$this->downloadLinks[0];
/*<gmd:extent><gmd:EX_Extent><gmd:geographicElement><gmd:EX_GeographicBoundingBox><gmd:westBoundLongitude><gco:Decimal>5</gco:Decimal></gmd:westBoundLongitude><gmd:eastBoundLongitude><gco:Decimal>10</gco:Decimal></gmd:eastBoundLongitude><gmd:southBoundLatitude><gco:Decimal>48</gco:Decimal></gmd:southBoundLatitude><gmd:northBoundLatitude><gco:Decimal>52</gco:Decimal></gmd:northBoundLatitude></gmd:EX_GeographicBoundingBox></gmd:geographicElement></gmd:EX_Extent></gmd:extent>*/
//esri
/*<gmd:extent><gmd:EX_Extent><gmd:geographicElement><gmd:EX_GeographicBoundingBox><gmd:westBoundLongitude><gco:Decimal>11.1414</gco:Decimal></gmd:westBoundLongitude><gmd:eastBoundLongitude><gco:Decimal>11.7284</gco:Decimal></gmd:eastBoundLongitude><gmd:southBoundLatitude><gco:Decimal>58.8838</gco:Decimal></gmd:southBoundLatitude><gmd:northBoundLatitude><gco:Decimal>59.2562</gco:Decimal></gmd:northBoundLatitude></gmd:EX_GeographicBoundingBox></gmd:geographicElement><gmd:temporalElement><gmd:EX_TemporalExtent><gmd:extent><gml:TimePeriod gml:id="idNummer1"><gml:beginPosition>1999-05-05</gml:beginPosition><gml:endPosition>2012-04-04</gml:endPosition></gml:TimePeriod></gmd:extent></gmd:EX_TemporalExtent></gmd:temporalElement></gmd:EX_Extent></gmd:extent>*/
Modified: trunk/mapbender/http/geoportal/mod_pullInspireMonitoring.php
--- trunk/mapbender/http/geoportal/mod_pullInspireMonitoring.php 2014-01-03 12:46:10 UTC (rev 8756)
+++ trunk/mapbender/http/geoportal/mod_pullInspireMonitoring.php 2014-01-08 15:34:04 UTC (rev 8757)
@@ -217,30 +217,24 @@
$inspireCategories['key'][$row['inspire_category_id']] = $row['inspire_category_key'];
$inspireCategories['title'][$row['inspire_category_id']] = $row['inspire_category_code_'.$lang];
+if ($outputFormat == 'monitoring' || $outputFormat == 'table') {
+} else {
//define sql to do a count of inspire relevant data (metadata)
$sqlCount = <<<SQL
-select count(metadata_id) as count from (select metadata_id, title from mb_metadata where metadata_id in (select distinct (metadata_id) from (select fkey_metadata_id as metadata_id from ows_relation_metadata inner join (select fkey_layer_id from layer_custom_category where fkey_custom_category_id = $inspireCatId ) as foo on foo.fkey_layer_id = ows_relation_metadata.fkey_layer_id
-union
-select fkey_metadata_id as metadata_id from ows_relation_metadata inner join (select fkey_featuretype_id from wfs_featuretype_custom_category where fkey_custom_category_id = $inspireCatId ) as foo on foo.fkey_featuretype_id = ows_relation_metadata.fkey_featuretype_id
-union
-select fkey_metadata_id as metadata_id from mb_metadata_custom_category where fkey_custom_category_id = $inspireCatId) as foo ) as foo2) as foo3
-SQL;
-$sqlCount2 = <<<SQL
-select count(metadata_id) from (select metadata_id, title, uuid from mb_metadata where metadata_id in (select distinct (metadata_id) from (select fkey_metadata_id as metadata_id from ows_relation_metadata inner join (select fkey_layer_id from layer_custom_category where fkey_custom_category_id = $inspireCatId ) as foo on foo.fkey_layer_id = ows_relation_metadata.fkey_layer_id
+select count(metadata_id) from (select distinct (uuid), metadata_id, title, uuid from mb_metadata where metadata_id in (select distinct (metadata_id) from (select fkey_metadata_id as metadata_id from ows_relation_metadata inner join (select fkey_layer_id from layer_custom_category where fkey_custom_category_id = $inspireCatId ) as foo on foo.fkey_layer_id = ows_relation_metadata.fkey_layer_id
union
union
select fkey_metadata_id as metadata_id from mb_metadata_custom_category where fkey_custom_category_id = $inspireCatId ) as foo )) as foo2 $sWhere
SQL;
-$resultCount = db_query($sqlCount2);
+$resultCount = db_query($sqlCount);
$rowCount = db_fetch_array($resultCount);
$resultCount = $rowCount['count'];
$iTotal = $resultCount;
//$e = new mb_exception($rowCount['count']);
//all inspire relevant data
@@ -248,7 +242,22 @@
//Define sql to select relevant information out of the registry.
//The direction is from the classified service layer/featuretype information to the coupled metadata.
//The classifications of the layers are used to decide if the resource is in the outgoing table.
$sql = <<<SQL
+select metadata_layer.title, metadata_layer.uuid, resource_id, resource_type, service_id, inspire_download, wms_owner as service_owner, fkey_mb_group_id as service_group, wms_title as service_title, f_collect_inspire_cat_layer(resource_id) as inspire_cat from (select title,uuid, layer_id as resource_id, 'layer' as resource_type, fkey_wms_id as service_id, inspire_download from (select layer.layer_id, layer.fkey_wms_id, layer.inspire_download, layer_custom_category.fkey_custom_category_id from layer inner join layer_custom_category on layer.layer_id = layer_custom_category.fkey_layer_id where layer_custom_category.fkey_custom_category_id = $inspireCatId AND layer_searchable = 1 ORDER BY layer_id) as layer_inspire inner join (select metadata_id, uuid, title, fkey_layer_id from mb_metadata inner join ows_relation_metadata on ows_relation_metadata.fkey_metadata_id = mb_metadata.metadata_id) as metadata_relation on metadata_relation.fkey_layer_id = layer_inspire.layer_id) as meta
data_layer INNER JOIN wms ON metadata_layer.service_id = wms_id
+union
+select metadata_featuretype.title, metadata_featuretype.uuid, resource_id, resource_type, service_id, inspire_download, wfs_owner as service_owner, fkey_mb_group_id as service_group, wfs_title as service_title, f_collect_inspire_cat_wfs_featuretype(resource_id) as inspire_cat from (select title, uuid, featuretype_id as resource_id, 'wfs_featuretype' as resource_type, fkey_wfs_id as service_id, inspire_download from (select wfs_featuretype.featuretype_id ,wfs_featuretype.fkey_wfs_id, wfs_featuretype.inspire_download from wfs_featuretype) as featuretype_inspire inner join (select metadata_id, uuid, title, fkey_featuretype_id from mb_metadata inner join ows_relation_metadata on ows_relation_metadata.fkey_metadata_id = mb_metadata.metadata_id) as metadata_relation on metadata_relation.fkey_featuretype_id = featuretype_inspire.featuretype_id) as metadata_featuretype INNER JOIN wfs ON metadata_featuretype.service_id = wfs_id
+order by uuid
+SQL;
+} else {
+$sql = <<<SQL
select distinct (uuid), * from (
select metadata_layer.title, wms.uuid as service_uuid, wms_title || ':' || layer_title as inspire_service_title, metadata_layer.uuid, metadata_layer.datasetid, metadata_layer.datasetid_codespace, resource_id, resource_uuid, resource_type, service_id, inspire_download, wms_owner as service_owner, fkey_mb_group_id as service_group, wms_title as service_title, f_collect_inspire_cat_layer(resource_id) as inspire_cat from (select title, uuid, datasetid, datasetid_codespace, layer_id as resource_id, 'layer' as resource_type, fkey_wms_id as service_id, inspire_download, layer_title, resource_uuid from (select layer.layer_id, layer.layer_title, layer.fkey_wms_id, layer.uuid as resource_uuid, layer.inspire_download, layer_custom_category.fkey_custom_category_id from layer inner join layer_custom_category on layer.layer_id = layer_custom_category.fkey_layer_id where layer_custom_category.fkey_custom_category_id = $inspireCatId AND layer_searchable = 1 ORDER BY layer_id) as layer_inspi
re inner join (select metadata_id, datasetid, datasetid_codespace, uuid, title, fkey_layer_id from mb_metadata inner join ows_relation_metadata on ows_relation_metadata.fkey_metadata_id = mb_metadata.metadata_id) as metadata_relation on metadata_relation.fkey_layer_id = layer_inspire.layer_id) as metadata_layer INNER JOIN wms ON metadata_layer.service_id = wms_id
@@ -264,6 +273,8 @@
) as foo $sWhere $sOrder $sLimit
SQL;
$startTime = microtime();
//get all service / owner / fkey_group information for the list of services
$result = db_query($sql);
Modified: trunk/mapbender/http/php/mod_inspireDownloadFeed.php
--- trunk/mapbender/http/php/mod_inspireDownloadFeed.php 2014-01-03 12:46:10 UTC (rev 8756)
+++ trunk/mapbender/http/php/mod_inspireDownloadFeed.php 2014-01-08 15:34:04 UTC (rev 8757)
@@ -1424,8 +1424,8 @@
case "metadata":
$downloadLinks = json_decode($mapbenderMetadata[$i]->datalinks);
$furtherLink = urldecode($downloadLinks->downloadLinks[0]);
- $furtherLinkType = $formatsMimetype[$mapbenderMetadata[$m]->format];
- $furtherLinkTitle = $ressourceTitle." im CRS ".$mapbenderMetadata[$i]->metadata_ref_system."(".$mapbenderMetadata[$m]->format.")";
+ $furtherLinkType = $formatsMimetype[$mapbenderMetadata[$i]->format];
+ $furtherLinkTitle = $ressourceTitle." im CRS ".$mapbenderMetadata[$i]->metadata_ref_system."(".$mapbenderMetadata[$i]->format.")";
//generate content link
$feedEntryLink = $feedDoc->createElement("link");
$feedEntryLink->setAttribute("rel", "section");
@@ -1708,7 +1708,7 @@
$mapbenderMetadata[$indexMapbenderMetadata]->datasetid_codespace = $row['datasetid_codespace'];
$mapbenderMetadata[$indexMapbenderMetadata]->metadata_uuid = $row['metadata_uuid'];
$mapbenderMetadata[$indexMapbenderMetadata]->metadata_title = $row['metadata_title'];
- $e = new mb_exception("title: ".$row['metadata_title']);
+ //$e = new mb_exception("title: ".$row['metadata_title']);
$mapbenderMetadata[$indexMapbenderMetadata]->metadata_abstract = $row['metadata_abstract'];
$mapbenderMetadata[$indexMapbenderMetadata]->accessconstraints = $row['accessconstraints'];//TODO: Let metadata get this from service when created
Modified: trunk/mapbender/http/plugins/mb_downloadFeedClient.php
--- trunk/mapbender/http/plugins/mb_downloadFeedClient.php 2014-01-03 12:46:10 UTC (rev 8756)
+++ trunk/mapbender/http/plugins/mb_downloadFeedClient.php 2014-01-08 15:34:04 UTC (rev 8757)
@@ -28,6 +28,8 @@
<meta http-equiv="content-style-type" content="text/css" />
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<link rel="stylesheet" href="../extensions/OpenLayers-2.9.1/theme/default/style.css" type="text/css">
+ <link rel="stylesheet" href="../extensions/OpenLayers-2.9.1/theme/default/style.css" type="text/css">
+ <link type="text/css" href="../extensions/jquery-ui-1.8.16.custom/css/ui-lightness/jquery-ui-1.8.16.custom.css" rel="Stylesheet" />
<style type="text/css">
select, textarea {
font: 0.9em Verdana, Arial, sans-serif;
@@ -175,6 +177,8 @@
<!--<select id="section_file_list" multiple='multiple'>-->
<!--<input type="button" title="Download selected files" value="Download selection"/>-->
<!--</fieldset> -->
+ <div id="dialog-modal" title="Download Link">
+</div>
</div>
</fieldset>
More information about the Mapbender_commits
