[Mapbender-commits] r8759 - trunk/mapbender/http/php
svn_mapbender at osgeo.org
Wed Jan 22 08:52:18 PST 2014
Author: armin11
Date: 2014-01-22 08:52:18 -0800 (Wed, 22 Jan 2014)
New Revision: 8759
trunk/mapbender/http/php/wms.php
Bugfix for AuthorityURL see INSPIRE Validator 2: http://inspire-geoportal.ec.europa.eu/validator2/changes.xml
Modified: trunk/mapbender/http/php/wms.php
--- trunk/mapbender/http/php/wms.php 2014-01-10 12:03:31 UTC (rev 8758)
+++ trunk/mapbender/http/php/wms.php 2014-01-22 16:52:18 UTC (rev 8759)
@@ -960,7 +960,7 @@
//call function for sublayer element
-function createLayerElement ($doc, $wmsId, $layerRow, $wmsRow) {
+function createLayerElement ($doc, $wmsId, $layerRow, $wmsRow, $AuthorityName) {
#Creating single layer node
$layer = $doc->createElement("Layer");
if($layerRow['layer_queryable'] <> "" AND $layerRow['layer_queryable'] <> NULL) {
@@ -1098,8 +1098,9 @@
//create Identifier tags
$Identifier = $doc->createElement("Identifier");
+ $Identifier->setAttribute('authority', $AuthorityName);
+ //$Identifier->setAttribute('mist', $AuthorityName);
$Identifier = $layer->appendChild($Identifier);
- $Identifier->setAttribute('authority', $AuthorityName);
$IdentifierText = $doc->createTextNode($datasetId);
$IdentifierText = $Identifier->appendChild($IdentifierText);
//$e = new mb_exception("i: ".$i);
@@ -1286,7 +1287,7 @@
//$e = new mb_exception($sub_layer_sql);
$res_sub_layer_sql = db_prep_query($sub_layer_sql, $v, $t);
while ($sub_layer_row = db_fetch_array($res_sub_layer_sql)) {
- $subLayer = createLayerElement($doc, $wmsId, $sub_layer_row, $wms_row);
+ $subLayer = createLayerElement($doc, $wmsId, $sub_layer_row, $wms_row, $AuthorityName);
//recursive creation
createLayerTree($sub_layer_row['layer_pos'], $withChilds, $layerId, $subLayer, $wmsId, $doc, $wms_row);
$layer->appendChild($subLayer);
@@ -1303,12 +1304,12 @@
//TODO: root layer is always there but the following pulls only the sublayer and not the requested layer by its own!! - todo: don't use the root layer every time!!! pull the requested layer instead but pull all srs and things which are inherited from the root layer or the parents from this layer - it is not always easy if the hirarchy is nested much - pull all parents - maybe a thing for class_administration!
if ($withChilds) {
//create layer itself first!
- $subLayer = createLayerElement($doc, $wmsId, $row, $wms_row);
+ $subLayer = createLayerElement($doc, $wmsId, $row, $wms_row, $AuthorityName);
createLayerTree($layerPos, $withChilds, $layerId, $subLayer, $wms_row['wms_id'], $doc, $wms_row);
} else {
//only create one layer
header("Content-type: application/xhtml+xml; charset=UTF-8");
More information about the Mapbender_commits
