[Mapbender-commits] r8762 - in trunk/mapbender: conf http/geoportal
svn_mapbender at osgeo.org
Mon Jan 27 23:09:12 PST 2014
Author: armin11
Date: 2014-01-27 23:09:12 -0800 (Mon, 27 Jan 2014)
New Revision: 8762
trunk/mapbender/conf/mapbender.conf-dist
trunk/mapbender/http/geoportal/mod_readCSWResults.php
Bugfix and new mapbender.conf for memcached configuration
Modified: trunk/mapbender/conf/mapbender.conf-dist
--- trunk/mapbender/conf/mapbender.conf-dist 2014-01-27 22:24:41 UTC (rev 8761)
+++ trunk/mapbender/conf/mapbender.conf-dist 2014-01-28 07:09:12 UTC (rev 8762)
@@ -252,6 +252,12 @@
#define("MAPBENDER_VARIABLE_CACHE", false);
#define("MAPBENDER_CACHE_TYPE", "apc");
+# define memcached server connections, if memcached ist used for session storing
+# lib/class_Mapbender_session.php
+#define("MEMCACHED_IP", "localhost");
+#define("MEMCACHED_PORT", "11211");
# HOSTNAME WHITELIST
# The whitelist is used for some modules who generate urls from a given hostName GET parameter. In such a case it is usefull to give a whitelist for security reasons! If no hostName is given, the parameter $_SERVER['HTTP_HOST'] is used for the urls!
Modified: trunk/mapbender/http/geoportal/mod_readCSWResults.php
--- trunk/mapbender/http/geoportal/mod_readCSWResults.php 2014-01-27 22:24:41 UTC (rev 8761)
+++ trunk/mapbender/http/geoportal/mod_readCSWResults.php 2014-01-28 07:09:12 UTC (rev 8762)
@@ -1,3 +1,4 @@
<?php
require_once(dirname(__FILE__)."/../../core/globalSettings.php");
@@ -6,6 +7,8 @@
//Script to read Results from CSW 2.0.2 Interfaces from mapbender geoportal
//example requests:
//GetRecords with textfilter
/*gp_csw
CREATE TABLE gp_csw (
@@ -24,8 +27,8 @@
select param_value from cat_op_conf where fk_cat_id=2 and param_type='getrecords';
select param_value from cat_op_conf where fk_cat_id=2 and param_type='getrecordsbyid';*/
-$resdir = TMPDIR;
-//$resdir = "/data/mapbender/http/tmp/";
+//$resdir = TMPDIR;
+$resdir = "/data/mapbender/http/tmp/";
$con = db_connect(DBSERVER,OWNER,PW);
db_select_db(DB,$con);
@@ -43,39 +46,36 @@
#if it came from cli, use output to tmp folder - > typo3 would find it and will show it in template, there should be an identifier from the gaz.php script which controls the different search moduls
#if it came as http request it should generate its own html window
#Maybe problematic: if requested from command-line, how would mapbender get the content? Should be tested.
-#check if requested as cli
-if(isset($_REQUEST["type"]) && $_REQUEST["type"]=="rss") {
- $outputRss = true;
-} else {
- $outputRss = false;
+#check if requested as cli
if (isset($argv[0])&isset($argv[1])){
- if (!$outputRss) echo "\nthe script was invoked from commandline\n";
+ echo "\nthe script was invoked from commandline\n";
$from_cli=true;
#do something with the searchstring if needed
#from cli no pagenumber will be given. Therefor everytime page number 1 will be requested
$request_p = 1;
$_REQUEST["q"] = $argv[2];//.$argv[3];//$searchPortaluFilter = $argv[3];
$cli_id = $argv[1];
- if (!$outputRss) echo "\nID: ".$argv[1]."\n";
- if (!$outputRss) echo "\nSearchstring: ".$argv[2]."\n";
-} else {
- if (!$outputRss) echo "<html><body>";
- if (!$outputRss) echo "\n<br>no commandline args set!\n<br>";
+ echo "\nID: ".$argv[1]."\n";
+ echo "\nSearchstring: ".$argv[2]."\n";
+ else
+ echo "<html><body>";
+ echo "\n<br>no commandline args set!\n<br>";
$from_cli=false;
#When script was not invoked from cli it should have been invoked per http - check the params
if (!$from_cli){
#***Validation of GET Parameters
#handle errors
//make html frame
if(!isset($_REQUEST["q"]) ) {
- if (!$outputRss) echo "No search string found! Please send a query!<br>";
+ echo "No search string found! Please send a query!<br>";
die();
if(!isset($_REQUEST["p"]) ) {
$request_p = 1;
@@ -85,21 +85,16 @@
if(!isset($_REQUEST["request_id"]) or $_REQUEST["request_id"]=='') {
- if (!$outputRss) echo "<br> request_id is not set <br>";
+ echo "<br> request_id is not set <br>";
$requeststring="&request_id=from_http";
$cli_id="from_http";
else
- if (!$outputRss) echo "<br>request_id is set<br>";
+ echo "<br>request_id is set<br>";
$cli_id=$_REQUEST["request_id"];
- if (!$outputRss) echo "<br>Search string: <b>".$_REQUEST["q"]."</b> will be send<br>";
+ echo "<br>Search string: <b>".$_REQUEST["q"]."</b> will be send<br>";
//convert the the opensearch filter to ogc filter encoding
@@ -215,7 +210,7 @@
while($row_csw = db_fetch_array($res_csw)){
$csw_list[$cnt_csw]['id'] = $row_csw["csw_id"];
$csw_list[$cnt_csw]['name'] = $row_csw["csw_name"];
- if (!$outputRss) echo "csw_name=".$row_csw["csw_name"];
+ echo "csw_name=".$row_csw["csw_name"];
$csw_list[$cnt_csw]['hierachylevel'] = $row_csw["hierachylevel"];
$csw_list[$cnt_csw]['fkey_cat_id'] = $row_csw["fkey_cat_id"];
//echo "<br>CAT ID from DB: ".$row_csw["fkey_cat_id"]."<br>";
@@ -269,7 +264,7 @@
//debug output
if (!$from_cli) {
- if (!$outputRss) echo "<br>Count of registrated OpenSearch Interfaces: ".count($csw_list)."<br>";
+ echo "<br>Count of registrated OpenSearch Interfaces: ".count($csw_list)."<br>";
#get command_line args
@@ -298,8 +293,8 @@
#if ($from_cli) {
#write out xml 'is really no xml!' with opensearch-catalogs
if ($from_cli) {
-if (!$outputRss) echo "\nFolder to write to: ".$resdir."\n";
-if (!$outputRss) echo "\nFile to open: ".$resdir."/".$cli_id."_os.xml\n";
+echo "\nFolder to write to: ".$resdir."\n";
+echo "\nFile to open: ".$resdir."/".$cli_id."_os.xml\n";
if($os_catalogs_file_handle = fopen($resdir."/".$cli_id."_os.xml","w")){
fwrite($os_catalogs_file_handle,"<interfaces>\n");
@@ -315,7 +310,7 @@
else
if ($from_cli) {
- if (!$outputRss) echo "\nCouldn't open file!\n";
+ echo "\nCouldn't open file!\n";
@@ -324,19 +319,12 @@
#***loop for things to do for each registrated search interface - only if the search should be done in all interfaces!
#use only one catalogue if a further page is requested
$start_cat=0;
$end_cat=count($csw_list);
-$e = new mb_exception($end_cat);
-$cat = $_REQUEST["cat"];
-$e = new mb_exception($cat);
+$cat=$_REQUEST["cat"];
if (isset($cat)){
- $start_cat=(int)$cat;
- $end_cat=(int)$cat+1;
+$start_cat=(int)$cat;
+$end_cat=(int)$cat+1;
for ($i_si = $start_cat; $i_si < $end_cat ; $i_si++) {
//$i_si = 0;
//echo "<br>".$csw_list[$i_si]['getrecordsurl']."<br>";
@@ -445,9 +433,9 @@
$getRecords .= ' </csw:Query>';
$getRecords .= '</csw:GetRecords>';
- //echo "<br>REQUEST for results<br>".htmlentities($getRecords)."<br>";
- $e = new mb_notice($getRecords);
- //for CSW define POST REQUEST for getrecords
+//echo "<br>REQUEST for results<br>".htmlentities($getRecords)."<br>";
+$e = new mb_notice($getRecords);
+//for CSW define POST REQUEST for getrecords
$cswInterfaceObject = new connector();
$cswInterfaceObject->set('httpType','POST');
$postData = $getRecords;
@@ -459,7 +447,8 @@
$cswInterfaceObject->set('httpContentType','text/xml');
//extent url when needed
$openSearchUrlSearch[$i_si] = $openSearchUrl[$i_si];
- if (!$outputRss) echo "<br><br>".$openSearchUrlSearch[$i_si]."<br>";
+ echo "<br><br>".$openSearchUrlSearch[$i_si]."<br>";
//echo $openSearchUrl[$i_si]."<br>";
$cswInterfaceObject->load($openSearchUrl[$i_si]);
#echo "<br>Results: ".htmlentities($cswInterfaceObject->file)."<br><br>";
@@ -470,7 +459,7 @@
//$url=$openSearchUrlSearch[$i_si]."q=".$queryText.$csw_list[$i_si] ['standardfilter']."&h=".$csw_list[$i_si] ['h']."&p=".$request_p;
$url = $openSearchUrl[$i_si];
if (!$from_cli) {
- if (!$outputRss) echo "<br> url: ".$url."<br>";
+ echo "<br> url: ".$url."<br>";
else
@@ -483,7 +472,7 @@
// $e = new mb_exception('external xml : '.$openSearchResult);
- $e = new mb_exception('external xml : '.$openSearchResult);
+ $e = new mb_notice('external xml : '.$openSearchResult);
#parse result to simplexml
$openSearchXml = new SimpleXMLElement($openSearchResult);
//$openSearchXml = ($openSearchResult);
@@ -512,19 +501,19 @@
#do a html output for showing results of the different opensearch catalogues
//if (!$from_cli) {
- if (!$outputRss) echo "<b>".$n_results."</b> Ergebnisse in Katalog <b>".$csw_list[$i_si] ['name']."</b><br><br>";
+ echo "<b>".$n_results."</b> Ergebnisse in Katalog <b>".$csw_list[$i_si] ['name']."</b><br><br>";
#show Pagenumbers
if ((int)$request_p>1) {
- if (!$outputRss) echo "<a href=\"mod_readCSWResults.php?q=".$_REQUEST['q']."&p=".(string)((int)$request_p-1)."&cat=".$i_si.$requeststring."\"> Vorige Seite </a> ";
+ echo "<a href=\"mod_readCSWResults.php?q=".$_REQUEST['q']."&p=".(string)((int)$request_p-1)."&cat=".$i_si.$requeststring."\"> Vorige Seite </a> ";
- if (!$outputRss) echo "Seite: <b>".$request_p."</b> von <b>".$number_of_pages."</b>";
+ echo "Seite: <b>".$request_p."</b> von <b>".$number_of_pages."</b>";
if ((int)$request_p < (int)$number_of_pages) {
- if (!$outputRss) echo " <a href=\"mod_readCSWResults.php?q=".$_REQUEST['q']."&p=".(string)((int)$request_p+1)."&cat=".$i_si.$requeststring."\"> Nächste Seite </a>";
+ echo " <a href=\"mod_readCSWResults.php?q=".$_REQUEST['q']."&p=".(string)((int)$request_p+1)."&cat=".$i_si.$requeststring."\"> Nächste Seite </a>";
- if (!$outputRss) echo "<br><br>";
+ echo "<br><br>";
//else
@@ -532,70 +521,6 @@
$from_cli=true; //- do this everytime
-if ($_REQUEST['type'] == "rss") {
- //initialize new rss document
- $rssDoc = new DOMDocument('1.0');
- $rssDoc->encoding = 'UTF-8';
- $rssDoc->preserveWhiteSpace = false;
- $rssDoc->formatOutput = true;
- /*<rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:opensearch="http://a9.com/-/spec/opensearch/1.1/">
- <channel>
- <title>WMS servers</title>
- <link>http://www.geopole.org/wms/search?search=wald&type=rss</link>
- <description>Geopole WMS search results for "wald"</description>
- <opensearch:totalResults>25</opensearch:totalResults>
- <opensearch:Query role="request" searchTerms="wald" />
- </channel>*/
- $rssElement = $rssDoc->createElement("rss");
- $rssElement->setAttribute("version", "2.0");
- $rssElement->setAttribute("xmlns:dc", "http://purl.org/dc/elements/1.1/");
- $rssElement->setAttribute("xmlns:opensearch", "http://a9.com/-/spec/opensearch/1.1/");
- $channel = $rssDoc->createElement("channel");
- $title = $rssDoc->createElement("title");
- $titleText = $rssDoc->createTextNode("Service Search in CSW Catalogue: ".$csw_list[$i_si] ['name']);
- $title->appendChild($titleText);
- $channel->appendChild($title);
- $link = $rssDoc->createElement("link");
- $linkText = $rssDoc->createTextNode("http://www.geoportal.rlp.de");
- $link->appendChild($linkText);
- $channel->appendChild($link);
- $description = $rssDoc->createElement("description");
- $descriptionText = $rssDoc->createTextNode("Extract service metadata from CSW. Show only first ".$csw_list[$i_si] ['h']." from total ".$n_results." results! Please refine your search.");
- $description->appendChild($descriptionText);
- $channel->appendChild($description);
- $openSearchTotalResults = $rssDoc->createElement("opensearch:totalResults");
- $openSearchTotalResultsText = $rssDoc->createTextNode($n_results);
- $openSearchTotalResults->appendChild($openSearchTotalResultsText);
- $channel->appendChild($openSearchTotalResults);
- /*$openSearchQuery = $rssDoc->createElement("opensearch:Query");
- $openSearchQueryText = $rssDoc->createTextNode($query);
- $openSearchQuery->appendChild($openSearchQueryText);
- $channel->appendChild($openSearchQuery);*/
- $openSearchQuery = $rssDoc->createElement("opensearch:Query");
- $openSearchQuery->setAttribute("role", "request");
- $openSearchQuery->setAttribute("searchTerms", $q);
- $rssElement->appendChild($channel);
- //header("Content-type: text/xml; charset=UTF-8");
- //$xml = $rssDoc->saveXML();
- //$xml = trim($xml,"\n");
- //remove newline from xml
- //echo $xml;
- //die();
if ($from_cli) { #do these things if the request was done from the commandline - it is done by the central search function
#generate the output for each page! Like: xyz_os1_1_10.xml = this means: searchid_os#catalogid_#page_#totalpages.xml
#open the specific file for writing
@@ -665,7 +590,7 @@
$abstract = $openSearchXml->xpath('/csw:GetRecordsResponse/csw:SearchResults/gmd:MD_Metadata['.$index.']/gmd:identificationInfo/*/gmd:abstract/gco:CharacterString');
$accessUrl = $openSearchXml->xpath('/csw:GetRecordsResponse/csw:SearchResults/gmd:MD_Metadata['.$index.']/gmd:distributionInfo/gmd:MD_Distribution/gmd:transferOptions/gmd:MD_DigitalTransferOptions/gmd:onLine/gmd:CI_OnlineResource/gmd:linkage/gmd:URL');
- if (!$outputRss) echo "<br>General first accessUrl: ".$accessUrl[0]."<br>";
+ echo "<br>General first accessUrl: ".$accessUrl[0]."<br>";
@@ -739,9 +664,9 @@
$isViewService = false;
$accessUrl = $accessUrl[0];
$typeOfServiceUpper = strtoupper($typeOfService);
- if (!$outputRss) echo "<br>accessUrl: ".$accessUrl."<br>";
- if (!$outputRss) echo "<br>typeOfService:*".$typeOfServiceUpper."*<br>";
- if (!$outputRss) echo "<br>typeOfRecord:*".$typeOfRecord."*<br>";
+ echo "<br>accessUrl: ".$accessUrl."<br>";
+ echo "<br>typeOfService:*".$typeOfServiceUpper."*<br>";
+ echo "<br>typeOfRecord:*".$typeOfRecord."*<br>";
$title = $title[0];
$graphicURL = $graphicURL[0];
@@ -755,7 +680,7 @@
//check for view service type
if ($typeOfServiceUpper == 'WMS' || $typeOfServiceUpper == 'VIEW' || strpos($typeOfServiceUpper,'WMS') !== false) {
$isViewService = true;
- if (!$outputRss) echo "view service identified<br>";
+ echo "view service identified<br>";
//check if service is view or wms and correct it for wms 1.1.1 caabilities request
if ($typeOfRecord == 'service' && $isViewService) {
@@ -765,7 +690,7 @@
$accessUrl = '';
} else {
- if (!$outputRss) echo "<b>no</b> view service identified<br>";
+ echo "<b>no</b> view service identified<br>";
//give dummy if orgaName not given
@@ -780,46 +705,24 @@
$abstractShort = substr($abstract,0,250)."...";
//echo "<br>Resultlist:<br>";
- if (!$outputRss) echo "<br><span>";
+ echo "<br><span>";
if (isset($graphicURL) && $graphicURL != '') {
- if (!$outputRss) echo "<img src='".$graphicURL."' width='100' height='100'/>";
+ echo "<img src='".$graphicURL."' width='100' height='100'/>";
- if (!$outputRss) echo "<a href = '".$openSearchWrapperDetail."?cat_id=".$csw_list[$i_si] ['id']."&uuid=".$uuid."&mdtype=html'>".$title."</a><br>";
- if (!$outputRss) echo $dateStamp." - ".$orgaName."<br>";
+ echo "<a href = '".$openSearchWrapperDetail."?cat_id=".$csw_list[$i_si] ['id']."&uuid=".$uuid."&mdtype=html'>".$title."</a><br>";
+ echo $dateStamp." - ".$orgaName."<br>";
if (isset($bbox) && $bbox != '') {
- if (!$outputRss) echo $bbox."<br>";
+ echo $bbox."<br>";
- if (!$outputRss) echo $abstractShort."</span>";
+ echo $abstractShort."</span>";
//check for isViewService to allow integration into Viewer by link TODO
if (isset($accessUrl) && $accessUrl != '') {
if ($isViewService) {
- if (!$outputRss) echo "<br><span><a href ='".$accessUrl."'>Capabilities</a><br><br></span>";
+ echo "<br><span><a href ='".$accessUrl."'>Capabilities</a><br><br></span>";
} else {
- if (!$outputRss) echo "<br><span><a href ='".$accessUrl."'>Link</a><br><br></span>";
+ echo "<br><span><a href ='".$accessUrl."'>Link</a><br><br></span>";
- //write xml tags for rss feed
- if ($outputRss) {
- $e = new mb_exception("fill item: ".$title);
- $item = $rssDoc->createElement("item");
- $titleItem = $rssDoc->createElement("title");
- $titleItemText = $rssDoc->createTextNode($title);
- $titleItem->appendChild($titleItemText);
- $item->appendChild($titleItem);
- $linkText = $rssDoc->createTextNode($accessUrl);
- $item->appendChild($link);
- $descriptionText = $rssDoc->createTextNode($abstract);
- $item->appendChild($description);
- $rssElement->appendChild($item);
//output to file in tmp folder:
if (isset($uuid) && $uuid != ''){
#Do result XML output to file
@@ -891,17 +794,10 @@
fwrite($os_catalogs_file_handle,"</resultlist>\n");
fclose($os_catalogs_file_handle);
- if($outputRss) {
- $rssDoc->appendChild($rssElement);
- header("Content-type: text/xml; charset=UTF-8");
- $xml = $rssDoc->saveXML();
- echo $xml;
- die();
- if (!$outputRss) echo "</body></html>";
+ echo "</body></html>";
function correctWmsUrl($wms_url) {
//check if last sign is ? or & or none of them
More information about the Mapbender_commits
