[Mapbender-commits] r8768 - in trunk/mapbender: conf cors_proxy/http resources/db
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Jan 31 04:05:11 PST 2014
Author: armin11
Date: 2014-01-31 04:05:10 -0800 (Fri, 31 Jan 2014)
New Revision: 8768
Added:
   trunk/mapbender/resources/db/Search_extended_DE_open_data.sql
   trunk/mapbender/conf/mapbender.conf-dist
   trunk/mapbender/cors_proxy/http/index.php
Some enhancements of cors_proxy and gui_erweiterte_suche aus geoportal.rlp
Modified: trunk/mapbender/conf/mapbender.conf-dist
--- trunk/mapbender/conf/mapbender.conf-dist	2014-01-31 11:25:54 UTC (rev 8767)
+++ trunk/mapbender/conf/mapbender.conf-dist	2014-01-31 12:05:10 UTC (rev 8768)
@@ -264,6 +264,12 @@
 define("HOSTNAME_WHITELIST", "");
+# CORS PROXY ORIGIN WHITELIST
+# The whitelist is used for CORS Proxy which is able to proxy GetMap REQUEST for OpenData classified WMS resources! The Origin part of the http header is read and the Access-Control-Allow-Origin for the GetMap results is set to this value! If more than one host is given please use space as separator
+define("CORS_WHITELIST", "http://localhost http://127.0.0.1");
 # Calculate bboxes for all supported SRS (Postgis needed)
 # This module will compute bboxes for all srs which will be found in the service capabilities and which are defined
Modified: trunk/mapbender/cors_proxy/http/index.php
--- trunk/mapbender/cors_proxy/http/index.php	2014-01-31 11:25:54 UTC (rev 8767)
+++ trunk/mapbender/cors_proxy/http/index.php	2014-01-31 12:05:10 UTC (rev 8768)
@@ -61,8 +61,8 @@
 		$originFromHeader = $value;
     	} else {
 		$originFromHeader = false;
-		//throwExceptionXml('','CORS Proxy don\'t find Origin header from client!');
-		$originFromHeader = "http://localhost";
+		throwExceptionXml('','CORS Proxy don\'t find Origin header from client!');
+		//$originFromHeader = "http://localhost";
 //check server against whitelist for cors header
Added: trunk/mapbender/resources/db/Search_extended_DE_open_data.sql
--- trunk/mapbender/resources/db/Search_extended_DE_open_data.sql	                        (rev 0)
+++ trunk/mapbender/resources/db/Search_extended_DE_open_data.sql	2014-01-31 12:05:10 UTC (rev 8768)
@@ -0,0 +1,267 @@
+INSERT INTO gui (gui_id, gui_name, gui_description, gui_public) VALUES ('Geoportal-RLP_erwSuche2','Geoportal-RLP_erwSuche2','client element collection',1);
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','i18n',1,1,'Internationalization module, collects data from all elements and sends them to the server in a single POST request. The strings are translated via gettext only.','Internationalization','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_i18n.js','','','','http://www.mapbender.org/Gettext');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','jq_upload',1,1,'','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../plugins/jq_upload.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','jq_datatables',1,1,'Includes the jQuery plugin datatables, use like this
+$(selector).datatables(options)','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_datatables.js','../extensions/dataTables-1.7.5/media/js/jquery.dataTables.min.js,../extensions/dataTables-1.7.5/extras/TableTools-2.0.0/media/js/TableTools.min.js','','','http://www.datatables.net/');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP_erwSuche2','jq_datatables','defaultCss','../extensions/dataTables-1.5/media/css/demo_table_jui.css','','file/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','jq_ui',1,1,'jQuery UI core','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.core.js','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP_erwSuche2','jq_ui','css','../extensions/jquery-ui-1.8.1.custom/css/custom-theme/jquery-ui-1.8.4.custom.css','','file/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','jq_ui_widget',1,1,'jQuery UI widget','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.widget.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','zoomOut1',1,1,'zoomOut button','Aus der Karte herauszoomen','img','../img/button_blue_red/zoomOut2_off.png','',300,196,24,24,20,'','','','mod_zoomOut1.js','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','zoomIn1',1,1,'zoomIn button','In die Karte hineinzoomen','img','../img/button_blue_red/zoomIn2_off.png','',300,171,24,24,20,'','','','mod_zoomIn1.js','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','zoomFull',1,1,'zoom to full extent button','Auf gesamte Karte zoomen','img','../img/button_blue_red/zoomFull_off.png','',300,246,24,24,20,'','','img','mod_zoomFull.js','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','selArea1',1,1,'zoombox','Ausschnitt mit Box aufziehen','img','../img/button_blue_red/selArea_off.png','',300,221,24,24,20,'','','','mod_selArea.js','mod_box1.js','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','pan1',1,1,'pan','Ausschnitt verschieben','img','../img/button_blue_red/pan_off.png','',300,271,24,24,20,'','','','mod_pan.js','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','forward',1,1,'History.forward()','Nach vorne','img','../img/button_blue_red/forward_off_disabled.png','',300,296,24,24,20,'','','','mod_forward.php','','mapframe1,overview0','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','body',1,1,'body (obligatory)','','body','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../geoportal/mod_revertGuiSessionSettings.php','','','','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP_erwSuche2','body','css_class_bg','body{ background-color: #f3f3f3; }','to define the color of the body','text/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP_erwSuche2','body','css_file_body','../css/mapbender.css','file/css','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP_erwSuche2','body','favicon','../img/favicon.png','favicon','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP_erwSuche2','body','includeWhileLoading','','show splash screen while the application is loading','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP_erwSuche2','body','popupcss','../css/popup.css','file css','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP_erwSuche2','body','tablesortercss','../css/tablesorter.css','file css','file/css');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP_erwSuche2','body','use_load_message','false','show splash screen while the application is loading','php_var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP_erwSuche2','body','jq_ui_theme','../extensions/jquery-ui-1.8.1.custom/css/custom-theme_geoportal_rlp/jquery-ui-1.8.4.custom.css','UI Theme from Themeroller','file/css');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','mapframe1',1,1,'Frame for a map','','div','','',10,180,280,154,20,'overflow:hidden;background-color:#ffffff','','div','../plugins/mb_map.js','../../lib/history.js,map_obj.js,map.js,wms.js,wfs_obj.js,initWmcObj.php','','','http://www.mapbender.org/index.php/Mapframe');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP_erwSuche2','mapframe1','skipWmsIfSrsNotSupported','0','if set to 1, it skips the WMS request if the current SRS is not supported by the WMS; if set to 0, the WMS is always queried. Default is 0, because of backwards compatibility','var');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP_erwSuche2','mapframe1','slippy','1','1 = Activates an animated, pseudo slippy map','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','mb_helpDialog',1,1,'Mapbender wrapper for helptexts in jq dialogs','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','','mb_helpDialog.js','','jq_ui, jq_metadata','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','jq_metadata',1,1,'jQuery Metadata plugin - selects elements by tag names out of html?','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','','../extensions/jquery.metadata.2.1/jquery.metadata.min.js','','','http://plugins.jquery.com/project/metadata');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','renderGML',2,0,'renders a gml contained in $_SESSION[''GML'']','','div','','',NULL ,NULL,NULL ,NULL,1,'','','div','../javascripts/mod_renderGML.php','mod_highlight.php','overview,mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','wholeBackground',2,1,'background for spatial filter mapbender mapframe - cause this cannot be positioned relativly','','div','','',0,0,750,600,NULL ,'color: #008000;background-color:#e3e3e3;position:absolute','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','spatialBackground',2,0,'background for spatial filter mapbender mapframe - cause this cannot be positioned relativly','','div','','',0,160,704,200,1,'color: #008000;background-color:#e3e3e3;position:absolute','','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','navFrame',2,1,'navigation mapborder','','div','','',0,0,NULL ,NULL,20,'font-size:1px','','div','mod_navFrame.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','sandclock',2,1,'displays a sand clock while waiting for requests','','div','','',80,0,0,0,0,'','','div','mod_sandclock.js','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','mapbender',2,1,'Mapbender-Logo','','div','','onclick="javascript:window.open(''http://www.mapbender.org'','''','''');"',81,-19,1,1,30,'font-size : 10px;font-weight : bold;font-family: Arial, Helvetica, sans-serif;color:white;cursor:help;','<span>Ma</span><span style="color: blue;">P</span><span style="color: red;">b</span><span>ender</span><script type="text/javascript"> mb_registerSubFunctions("mod_mapbender()"); function mod_mapbender(){ document.getElementById("mapbender").style.left = parseInt(document.getElementById("mapframe1").style.left) + parseInt(document.getElementById("mapframe1").style.width) - 90; document.getElementById("mapbender").style.top = parseInt(document.getElementById("mapframe
 1").style.top) + parseInt(document.getElementById("mapframe1").style.height) -1; } </script>','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','loadData',2,0,'IFRAME, um Daten zu laden','','iframe','../html/mod_blank.html','frameborder = "0" ',0,0,1,1,NULL ,'visibility:visible','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','imprint',2,0,'Information about the owner of the gui','','iframe','../x_geoportal/imprint_geoportal.html','frameborder = "0" ',1,1,1,1,5,'visibility:hidden;','','iframe','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','dependentDiv',2,0,'displays infos in a sticky div-tag','','div','','',81,-19,1,1,NULL ,'visibility:visible;position:absolute;font-size: 11px;font-family: "Arial", sans-serif;','','div','mod_dependentDiv.php','','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','mb_div_collection1',2,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','mapframe1, zoomIn1,zoomFull,zoomOut1,selArea1,pan1,forward,back,navFrame','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','spatialFilter',2,1,'Div which shows the spatial filter options for the metadata search','','div','','class=''spatialFilter''',NULL ,NULL,NULL ,NULL,20,'','	<fieldset>
+		<img class="help-dialog" id="helpSpatialFilter" title="Help" help="{text:''Help SpatialFilter''}"  src="../img/questionmark.png" align="right"></img>
+		<p>
+			<input type=''checkbox'' name=''searchBbox'' id=''searchBbox''>
+			<label  id="labelSpatialFilter" name="labelSpatialFilter">Activate Spatial Filter</label>
+			<legend id="labelSpatialFilterType" name="labelSpatialFilterType">how?</legend>
+			<input type=''radio'' name=''searchTypeBbox'' value=''intersects'' id=''searchTypeBbox''>
+			<label id="labelIntersects" name="labelIntersects" for="bbox">intersects</label>
+			<input type=''radio'' name=''searchTypeBbox'' value=''outside'' id=''searchTypeBbox''>
+			<label id="labelOutside" name="labelOutside">outside</label>
+			<input type=''radio'' name=''searchTypeBbox'' value=''inside'' id=''searchTypeBbox''>
+			<label id="labelInside" name="labelInside">fully inside</label>
+		</p>
+	</fieldset>','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','back',2,1,'History.back()','Zurück','img','../img/button_blue_red/back_off_disabled.png','',300,321,24,24,20,'','','','mod_back.php','','mapframe1,overview0','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','mapcheck',2,0,'alert if a map-image fails to load','','div','','',0,0,NULL ,NULL,NULL ,'','','div','','mod_mapcheck.php','mapframe1','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','jq_ui_mouse',2,1,'jQuery UI mouse','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.mouse.js','','jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','jq_ui_position',2,1,'jQuery UI position','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.position.js','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','classifications',3,1,'Put category divs into one div collection','Themen','div','','',NULL ,NULL,NULL ,NULL,20,'','<fieldset>
+	<legend  id="classificationsLegend" name="classificationsLegend">Classifications</legend>
+		<div class="inspire">
+			<fieldset>
+			<legend id="legendInspireThemes" name="legendInspireThemes">Inspire Themes</legend>
+			<img class="help-dialog" id="helpInspireThemes" title="Help" help="{text:''Help Inspire Categories''}"  src="../img/questionmark.png" align="right"></img>
+<img id="imageInspireThemes" title="Inspire" src="../img/inspire_tr_36.png" align="right"></img>
+				<p>
+					<select class=''selectCat'' size=''5'' name=''inspireThemes'' id=''inspireThemes'' multiple ></select>
+					<br><a  id="deleteSelection2" name="deleteSelection" href="#"  onclick=''removeListSelections("inspireThemes");''>Drop current selection</a>
+				</p>
+			</fieldset>
+		</div>
+		<div class="iso">
+			<fieldset>
+			<legend  id="legendIsoCategories" name="legendIsoCategories">ISO19115 Themes</legend>
+			<img class="help-dialog" id="helpIsoCategories" title="Help" help="{text:''Help ISO Categories''}"  src="../img/questionmark.png" align="right"></img>
+				<p>
+					<select class=''selectCat'' size=''5'' name=''isoCategories'' id=''isoCategories'' width="200px"  multiple></select>
+					<br><a id="deleteSelection3" name="deleteSelection" href="#"  onclick=''removeListSelections("isoCategories");''>Drop current selection</a>
+				</p>
+			</fieldset>
+		</div>
+		<div class="custom">
+			<fieldset>
+				<legend  id="legendCustomCategories" name="legendCustomCategories">Other Themes</legend>
+				<img class="help-dialog" id="helpCustomCategories" title="Help" help="{text:''Help Custom Categories''}"  src="../img/questionmark.png" align="right"></img>
+				<p>
+					<select class=''selectCat'' size=''5'' name=''customCategories'' id=''customCategories'' multiple></select>
+					<br><a id="deleteSelection4" name="deleteSelection" href="#" onclick=''removeListSelections("customCategories");''>Drop current selection</a>
+				</p>
+			</fieldset>
+		</div>
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','actuality',3,1,'Div which shows the date field for temporal filters for metadata search','Wann?','div','','class=''actuality''',NULL ,NULL,NULL ,NULL,20,'','<fieldset>
+<legend  id="legendActuality" name="legendActuality">Actuality</legend>
+	<fieldset>
+		<legend id="legendDateOfPublication" name="legendDateOfPublication">Date of Publication</legend>
+		<img class="help-dialog" id="helpDateOfPublication" title="Help" help="{text:''Help DateOfPublication''}"  src="../img/questionmark.png" align="right"></img>
+		<table>
+			<p>
+			<tr>
+			<td><label id="labelDateOfPublicationStart" name="labelDateOfPublicationStart"  for="regTimeBegin">Date from</label></td>
+			<td><input class=''hasdatepicker'' type=''text'' size=15 name=''regTimeBegin'' id=''regTimeBegin'' > </td>
+			</tr>
+			<tr>
+			<td><label id="labelDateOfPublicationEnd" name="labelDateOfPublicationEnd"  for="regTimeEnd">Date to</label></td>
+			<td><input class=''hasdatepicker'' type=''text'' size=15 name=''regTimeEnd'' id=''regTimeEnd'' > </td>
+			</tr>
+			</p>
+		</table>
+	</fieldset>
+	<fieldset>
+		<legend id="legendDateOfLastRevision" name="legendDateOfLastRevision">Data actuality</legend>
+		<img class="help-dialog" id="helpDateOfLastRevision" title="Help" help="{text:''Help DateOfLastRevision''}"  src="../img/questionmark.png" align="right"></img>
+			<table>
+			<p>
+			<tr>
+				<td><label id="labelDateOfLastRevisionStart" name="labelDateOfLastRevisionStart"  for="timeBegin" >Date from</label></td>
+				<td><input disabled="disabled" type=''text'' size=15 name=''timeBegin'' id=''timeBegin'' > </td>
+			</tr>
+			<tr>
+				<td><label id="labelDateOfLastRevisionEnd" name="labelDateOfLastRevisionEnd"   for="timeEnd">Date to</label></td>
+<td><input disabled="disabled" type=''text'' size=15 name=''timeEnd'' id=''timeEnd'' > </td>
+			</tr>
+			</p>
+			</table>
+	</fieldset>
+</fieldset>
+','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','button',3,1,'Div for the button to submit extended search module','','div','','class=''button''',500,25,60,40,20,'','<button id="search" name="search" type="button" value="Start Search" onclick="validate();">Start Search</button>
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','form1',3,1,'Form for the extended mapbender metadata search','','form','','method=''post'' name=''form1''',0,0,400,NULL ,NULL,'','','form','../plugins/mb_div_collection.js','../plugins/mb_extendedSearch.js','searchField,button,orderBy,mb_tabs_horizontal','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','orderBy',3,1,'Div which shows orderby options for the metadata search','Order','div','','class=''orderBy''',0,80,480,NULL ,20,'','<fieldset>
+<legend id="legendOrderBy" name="legendOrderBy">Sort by:</legend>
+		<img class="help-dialog" id="helpOrderBy" title="Help" help="{text:''Help OrderBy''}"  src="../img/questionmark.png" align="right"></img>
+		<p>
+			<input type=''radio'' name=''orderBy'' value=''rank'' id=''orderBy'' checked >
+			<label id="labelOrderByRank" name="labelOrderByRank">relevance</label>
+			<input type=''radio'' name=''orderBy'' value=''title'' id=''orderBy''>
+			<label id="labelOrderByTitle" name="labelOrderByTitle">title</label>
+			<input type=''radio'' name=''orderBy'' value=''id'' id=''orderBy''>
+			<label id="labelOrderById" name="labelOrderById">identification</label>
+			<input type=''radio'' name=''orderBy'' value=''date'' id=''orderBy''>
+			<label id="labelOrderByDate" name="labelOrderByDate">date</label>
+		</p>
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','searchField',3,1,'Div which shows the search field for the metadata search','','div','','class=''searchField''',0,0,480,NULL ,20,'','		<fieldset>
+		<legend id="legendSearchTextTitle" name="legendSearchTextTitle">Searchterm(s):</legend>
+		<img class="help-dialog" id="helpSearchText" title="Help" help="{text:''Help SearchText''}"  src="../img/questionmark.png" align="right"></img>
+			<p>
+				<input type=''text'' size=30 name=''searchText'' id=''searchText''><input id="restrictToOpenData" type="checkbox" name="restrictToOpenData">
+<label id="labelOpenData" name="labelOpenData">nur freie Daten</label>
+			</p>
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','form2',3,1,'Form for the extended mapbender metadata search - this form submits the values as hidden to the search script','','form','','method=''get'' name=''form2'' action=''/portal/nc/servicebereich/erweiterte-suche.html'' target=''_top''',0,250,NULL ,NULL,NULL ,'','	<input type="hidden" value='''' name=''searchText''>
+<input type="hidden" value='''' name=restrictToOpenData>
+	<input type="hidden" value='''' name=''registratingDepartments''>
+	<input type="hidden" value='''' name=''isoCategories''>
+	<input type="hidden" value='''' name=''inspireThemes''>
+	<input type="hidden" value='''' name=''customCategories''>
+	<input type="hidden" value='''' name=''regTimeBegin''>
+	<input type="hidden" value='''' name=''regTimeEnd''>
+	<input type="hidden" value='''' name=''timeBegin''>
+	<input type="hidden" value='''' name=''timeEnd''>
+	<input type="hidden" value='''' name=''searchBbox''>
+	<input type="hidden" value='''' name=''searchTypeBbox''>
+	<input type="hidden" value='''' name=''searchResources''>
+	<input type="hidden" value='''' name=''orderBy''>	','form','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','classSearchResources',3,1,'Div which shows the different bsearchable resources for metadata search','Was?','div','','',NULL ,NULL,NULL ,NULL,20,'','<fieldset><legend id="legendSearchResources" name="legendSearchResources">Types of Resources</legend>
+		<img class="help-dialog" id="helpSearchResources" title="Help" help="{text:''Help SearchResources''}"  src="../img/questionmark.png" align="right"></img>
+		<div id=''searchResources'' name=''searchResources''>
+			<input name=''checkResourcesWms'' id=''checkResourcesWms'' type=''checkbox'' value=''wms''>
+			<label id="labelCheckResourcesWms" name="labelCheckResourcesWms">Viewing Services</label>
+			<input name=''checkResourcesWfs'' id=''checkResourcesWfs'' type=''checkbox'' value=''wfs''>
+			<label id="labelCheckResourcesWfs" name="labelCheckResourcesWfs">Search/Download/Digitize Modules</label>
+			<input name=''checkResourcesWmc'' id=''checkResourcesWmc'' type=''checkbox'' value=''wmc''>
+			<label id="labelCheckResourcesWmc" name="labelCheckResourcesWmc">Map Collections</label>
+			<input disabled="disabled" name=''checkResourcesGeorss'' id=''checkResourcesGeorss'' type=''checkbox'' value=''georss''>
+			<label disabled="disabled" id="labelCheckResourcesGeorss" name="labelCheckResourcesGeorss">GeoRSS Feeds</label>
+		</div>
+</fieldset>','div','','','','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','mb_div_collection2',3,1,'Put existing divs in new div object. List the elements comma-separated under target, and make sure they have a title.','Wo?','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','../plugins/mb_div_collection.js','','spatialFilter,mb_div_collection1,spatialBackground','','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','provider',3,1,'Div which shows a list of providers for the metadata search','Anbieter','div','','',NULL ,NULL,NULL ,NULL,20,'','<fieldset>
+<legend  id="legendDepartment" name="legendDepartment">Provider</legend>
+<img class="help-dialog" id="helpProvider" title="Help" help="{text:''Help Provider''}"  src="../img/questionmark.png" align="right"></img>
+		<p>
+			<select class=''selectCat'' size=''5'' name=''registratingDepartments'' id=''registratingDepartments'' multiple ></select>
+			<br><a id="deleteSelection1" name="deleteSelection" href="#" c onclick=''removeListSelections("registratingDepartments");''>Drop current selection</a>
+		</p>
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','mb_tabs_horizontal',4,1,'Puts existing elements into horizontal tabs, using jQuery UI tabs. List the elements comma-separated under target, and make sure they have a title.','','div','','',0,200,700,NULL ,NULL,'','<ul></ul><div class=''ui-layout-content''></div>','div','../plugins/mb_tabs_horizontal.js','','mb_div_collection2,actuality,classifications,provider,classSearchResources','jq_ui_tabs','');
+INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES ('Geoportal-RLP_erwSuche2','mb_tabs_horizontal','inputs','[
+        "type": "id",
+        "method": "select",
+        "title": "Select a tab",
+        "linkedTo": [
+                "id": "mb_md_select",
+                "event": "selected",
+                "value": "mb_md_edit"
+] ','','var');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','jq_ui_button',4,1,'jQuery UI button','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.button.js','','jq_ui,jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','jq_ui_droppable',4,1,'jQuery UI droppable','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.droppable.js','','jq_ui,jq_ui_widget,jq_ui_mouse,jq_ui_draggable','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','jq_ui_resizable',5,1,'Resizable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','../plugins/jq_ui_resizable.js','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.resizable.js','','jq_ui,jq_ui_mouse,jq_ui_widget','http://jqueryui.com/demos/resizable/');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','jq_ui_draggable',5,1,'Draggable from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.draggable.js','','jq_ui,jq_ui_mouse,jq_ui_widget','http://jqueryui.com/demos/draggable/');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','jq_ui_tabs',5,1,'horizontal tabs from the jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.tabs.js','','jq_ui,jq_ui_widget','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','jq_ui_datepicker',5,1,'Datepicker from jQuery UI framework','','div','','',NULL ,NULL,NULL ,NULL,NULL ,'','','div','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.datepicker.js','','jq_ui','');
+INSERT INTO gui_element (fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content, e_closetag, e_js_file, e_mb_mod, e_target, e_requires,e_url) VALUES ('Geoportal-RLP_erwSuche2','jq_ui_dialog',5,1,'Dialog from jQuery UI framework','','','','',NULL ,NULL,NULL ,NULL,NULL ,'','','','','../extensions/jquery-ui-1.8.16.custom/development-bundle/ui/jquery.ui.dialog.js','','jq_ui,jq_ui_widget,jq_ui_button,jq_ui_draggable,jq_ui_mouse,jq_ui_position,jq_ui_resizable','');
More information about the Mapbender_commits mailing list
