[Mapbender-commits] r8964 - in trunk/mapbender: http/plugins lib
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Jul 1 07:30:33 PDT 2014
Author: hwbllmnn
Date: 2014-07-01 07:30:33 -0700 (Tue, 01 Jul 2014)
New Revision: 8964
   trunk/mapbender/http/plugins/kmlTree.js
   trunk/mapbender/http/plugins/mb_digitize_widget.php
   trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
added select button for features, only partially disable digitizing when other icons are selected
Modified: trunk/mapbender/http/plugins/kmlTree.js
--- trunk/mapbender/http/plugins/kmlTree.js	2014-07-01 13:58:00 UTC (rev 8963)
+++ trunk/mapbender/http/plugins/kmlTree.js	2014-07-01 14:30:33 UTC (rev 8964)
@@ -73,6 +73,9 @@
     $kmlTree.append($KMLfolder);
     $addButton = $('<button class="add" name="addkml" value="addkml"></button>');
+    var selectButton = $('<button class="digitize-image digitize-cursor"></button>');
     $addButton.click(function(){
         var dlg = $('<div ></div>').dialog({
             "title": "KML hinzufügen",
@@ -183,8 +186,18 @@
             ifr.onload = onloadfun;
+    $KMLfolder.find('ul').before(selectButton);
     $KMLfolder.find("ul").before($addButton);
+    selectButton.bind('click', function() {
+        var kml = $('#mapframe1').data('kml');
+        if(kml.getQueriedLayer) {
+            kml.setQueriedLayer = false;
+        } else {
+            kml.setQueriedLayer(true);
     o.$target.bind('kml:loaded',function(e,obj){
         //console.log(obj);
         var checked = obj.display ? 'checked="checked"':'';
Modified: trunk/mapbender/http/plugins/mb_digitize_widget.php
--- trunk/mapbender/http/plugins/mb_digitize_widget.php	2014-07-01 13:58:00 UTC (rev 8963)
+++ trunk/mapbender/http/plugins/mb_digitize_widget.php	2014-07-01 14:30:33 UTC (rev 8964)
@@ -184,10 +184,7 @@
         go: $.noop,
         stop: function() {
-            digitizeDialog.dialog('close');
-            editDialog.dialog('close');
-            editStyleDialog.dialog('close');
-            attributesDialog.dialog('close');
+            that.deactivate();
@@ -515,6 +512,7 @@
     var editObject = function($link, menu) {
         return function(e) {
             editDialog.find('*').unbind();
             if($link.hasClass('kmltree-selected')) {
@@ -622,10 +620,6 @@
                 digitizingFor = $link.parent().attr('title');
                 that.activate();
-            digitizeDialog.find('.digitize-cursor').bind('click', function() {
-                var kml = $('#mapframe1').data('kml');
-                kml.setQueriedLayer($link.parent().attr('title'));
             digitizeDialog.find('.digitize-remove').bind('click', function() {
                 var url = $link.parent().attr('title');
Modified: trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
--- trunk/mapbender/lib/mb.ui.displayKmlFeatures.js	2014-07-01 13:58:00 UTC (rev 8963)
+++ trunk/mapbender/lib/mb.ui.displayKmlFeatures.js	2014-07-01 14:30:33 UTC (rev 8964)
@@ -66,24 +66,26 @@
             var matched = [];
             var matchedIds = [];
-            $.each(itm.data.features, function(k, v) {
-                if(v.geometry.type.match(/point/i)) {
-                    var pt = Proj4js.transform(self.wgs84, self.targetProj, {x: v.geometry.coordinates[0], y: v.geometry.coordinates[1]});
-                    var minx = pt.x - 20 * res;
-                    var miny = pt.y - 20 * res;
-                    var maxx = minx + 40 * res;
-                    var maxy = miny + 40 * res;
-                    if(minx < clickPoint.x && maxx > clickPoint.x && miny < clickPoint.y && maxy > clickPoint.y) {
-                        matched.push(v);
-                        matchedIds.push(k);
+            $.each(self._kmls, function(_, itm) {
+                $.each(itm.data.features, function(k, v) {
+                    if(v.geometry.type.match(/point/i)) {
+                        var pt = Proj4js.transform(self.wgs84, self.targetProj, {x: v.geometry.coordinates[0], y: v.geometry.coordinates[1]});
+                        var minx = pt.x - 20 * res;
+                        var miny = pt.y - 20 * res;
+                        var maxx = minx + 40 * res;
+                        var maxy = miny + 40 * res;
+                        if(minx < clickPoint.x && maxx > clickPoint.x && miny < clickPoint.y && maxy > clickPoint.y) {
+                            matched.push(v);
+                            matchedIds.push(k);
+                    } else {
+                        var box = self.getBbox(v);
+                        if(box[0] < wgspt.x && box[2] > wgspt.x && box[1] < wgspt.y && box[3] > wgspt.y) {
+                            matched.push(v);
-                } else {
-                    var box = self.getBbox(v);
-                    if(box[0] < wgspt.x && box[2] > wgspt.x && box[1] < wgspt.y && box[3] > wgspt.y) {
-                        matched.push(v);
             if(matchedIds.length > 0) {
More information about the Mapbender_commits mailing list
