[Mapbender-commits] r8974 - in trunk/mapbender: http/plugins lib
svn_mapbender at osgeo.org
Wed Jul 2 07:00:01 PDT 2014
Author: hwbllmnn
Date: 2014-07-02 07:00:00 -0700 (Wed, 02 Jul 2014)
New Revision: 8974
trunk/mapbender/http/plugins/mb_digitize_widget.php
trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
added selection by box (still interferes with other map functions)
Modified: trunk/mapbender/http/plugins/mb_digitize_widget.php
--- trunk/mapbender/http/plugins/mb_digitize_widget.php 2014-07-02 11:54:49 UTC (rev 8973)
+++ trunk/mapbender/http/plugins/mb_digitize_widget.php 2014-07-02 14:00:00 UTC (rev 8974)
@@ -532,7 +532,6 @@
var editObject = function($link, menu) {
return function(e) {
editDialog.find('*').unbind();
if($link.hasClass('kmltree-selected')) {
editDialog.dialog('close');
@@ -782,6 +781,10 @@
+ this.closeEditDialog = function() {
+ editDialog.dialog('close');
create();
Modified: trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
--- trunk/mapbender/lib/mb.ui.displayKmlFeatures.js 2014-07-02 11:54:49 UTC (rev 8973)
+++ trunk/mapbender/lib/mb.ui.displayKmlFeatures.js 2014-07-02 14:00:00 UTC (rev 8974)
@@ -61,7 +61,55 @@
self.render();
+ // go: function () {
+ // if (!map) {
+ // new Mb_exception(options.id + ": " +
+ // options.target + " is not a map!");
+ // return;
+ // box = new Mapbender.Box({
+ // target: options.target
+ // $(map.getDomElement()).css(
+ // "cursor", "crosshair"
+ // ).mousedown(function (e) {
+ // box.start(e);
+ // return false;
+ // }).mouseup(function (e) {
+ // box.stop(e, function (extent) {
+ // if (typeof extent === "undefined") {
+ // return false;
+ // if (extent.constructor === Mapbender.Extent) {
+ // var xt = map.calculateExtent(extent);
+ // map.setMapRequest();
+ // else if (extent.constructor === Mapbender.Point) {
+ // map.setCenter(extent);
+ // return false;
+ // stop: function () {
+ // if (!map) {
+ // return;
+ // .css("cursor", "default")
+ // .unbind("mousedown")
+ // .unbind("mouseup")
+ // .unbind("mousemove");
+ // box = null;
this.element.bind('click', function(e) {
+ if(self.lastWasBox) {
+ self.lastWasBox = false;
+ return;
var map = self.element.mapbender();
var pos = map.getMousePosition(e);
var clickPoint = map.convertPixelToReal(new Point(pos.x,pos.y));
@@ -70,78 +118,41 @@
if(!self.queriedLayer) return;
- var matchedIds = [];
+ var matchedIds = self.findFeatures(pos);
- $.each(self._kmls, function(_, itm) {
- $.each(itm.data.features, function(k, v) {
- if(v.geometry.type.match(/point/i)) {
- var pt = Proj4js.transform(self.wgs84, self.targetProj, {x: v.geometry.coordinates[0], y: v.geometry.coordinates[1]});
- var minx = pt.x - 20 * res;
- var miny = pt.y - 20 * res;
- var maxx = minx + 40 * res;
- var maxy = miny + 40 * res;
- if(minx < clickPoint.x && maxx > clickPoint.x && miny < clickPoint.y && maxy > clickPoint.y) {
- matchedIds.push({url: itm.url, id: k});
- } else {
- var box = self.getBbox(v);
- if(box[0] < wgspt.x && box[2] > wgspt.x && box[1] < wgspt.y && box[3] > wgspt.y) {
- if(matchedIds.length == 1 && !e.ctrlKey && self.selectedFeatures.length == 0) {
- $('li[title="' + matchedIds[0].url + '"] li[idx="' + matchedIds[0].id + '"]').click();
- } else {
- if(!e.ctrlKey) {
- self.selectedFeatures = [];
- $.each(matchedIds, function(_, v) {
- var contained = false;
- $.each(self.selectedFeatures, function(_, sel) {
- if(v.url == sel.url && v.id == sel.id) contained = true;
- if(!contained) {
- self.selectedFeatures.push(v);
+ self.updateSelectedFeatures(matchedIds, e.ctrlKey);
- $('.kmltree-selected').removeClass('kmltree-selected');
- $.each(self.selectedFeatures, function(_, v) {
- $('li[title="' + v.url + '"] li[idx="' + v.id + '"]').addClass('kmltree-selected');
+ var boxfun;
- if(self.selectedFeatures.length > 1) {
- $('#selection-dialog').dialog('destroy').remove();
- var dlg = $(self.selectionDialog);
- var list = dlg.find('#selected-features-list')
- .html('');
- var feat = self._kmls[v.url].data.features[v.id];
- var title = feat.properties.name;
- list.append('<li><div style="width: 20px; height: 20px; display: inline;" class="style-preview"></div><span>' + title + '</span></li>');
- var node = list.find('li div.style-preview').last()[0];
- self.renderPreview(feat, node);
- dlg.dialog({
- close: function() {
- $(this).dialog('destroy').remove();
- dlg.find('.digitize-export').bind('click', function() {
- var data = {type: 'FeatureCollection', features: []};
- data.features.push(feat);
- self.exportItem(data);
- dlg.dialog('close');
+ this.element.bind('mousedown', boxfun = function(e) {
+ if(!self.queriedLayer) return;
+ var box = new Mapbender.Box({
+ target: 'mapframe1'
+ box.start(e);
+ $('#mapframe1').css("cursor", "crosshair")
+ .mouseup(function (e) {
+ box.stop(e, function (extent) {
+ if (typeof extent === "undefined") {
+ return;
+ var matchedIds = self.findFeatures(extent);
+ self.lastWasBox = true;
+ $('#mapframe1')
+ .css("cursor", "default")
+ .unbind("mousedown")
+ .unbind("mouseup")
+ .unbind("mousemove")
+ .bind('mousedown', boxfun);
+ return false;
self.element.bind('kml:loaded',function(event,obj){
if(o.autoOpen){
self.render();
@@ -176,6 +187,154 @@
+ findFeatures: function(posOrBox) {
+ var matchedIds = [];
+ var self = this;
+ var map = self.element.mapbender();
+ var ispoint;
+ var clickPoint, wgspt, clickBox, min, max;
+ if(posOrBox.x) {
+ clickPoint = map.convertPixelToReal(new Point(posOrBox.x,posOrBox.y));
+ wgspt = Proj4js.transform(self.targetProj, self.wgs84, {x: clickPoint.x, y: clickPoint.y});
+ ispoint = true;
+ } else {
+ clickBox = posOrBox;
+ min = Proj4js.transform(self.targetProj, self.wgs84, {x: clickBox.minx, y: clickBox.miny});
+ max = Proj4js.transform(self.targetProj, self.wgs84, {x: clickBox.maxx, y: clickBox.maxy});
+ ispoint = false;
+ var res = map.getScale() / mb_resolution / 100;
+ $.each(self._kmls, function(_, itm) {
+ $.each(itm.data.features, function(k, v) {
+ if(ispoint) {
+ self.matchFeatureToPoint(v, clickPoint, matchedIds, res, itm, wgspt, k);
+ } else {
+ self.matchFeatureToBox(v, {min: min, max: max}, matchedIds, itm, k);
+ return matchedIds;
+ inBox: function(minx, miny, maxx, maxy, x, y) {
+ return minx < x && maxx > x && miny < y && maxy > y;
+ matchFeatureToPoint: function(feat, clickPoint, matchedIds, res, itm, wgspt, idx) {
+ if(feat.geometry.type.match(/point/i)) {
+ var pt = Proj4js.transform(this.wgs84, this.targetProj, {x: feat.geometry.coordinates[0], y: feat.geometry.coordinates[1]});
+ var minx = pt.x - 20 * res;
+ var miny = pt.y - 20 * res;
+ var maxx = minx + 40 * res;
+ var maxy = miny + 40 * res;
+ if(minx < clickPoint.x && maxx > clickPoint.x && miny < clickPoint.y && maxy > clickPoint.y) {
+ matchedIds.push({url: itm.url, id: idx});
+ } else {
+ var box = this.getBbox(feat);
+ if(this.inBox(box[0], box[1], box[2], box[3], wgspt.x, wgspt.y)) {
+ matchFeatureToBox: function(feat, wgsbox, matchedIds, itm, idx) {
+ if(this.inBox(wgsbox.min.x, wgsbox.min.y, wgsbox.max.x, wgsbox.max.y, feat.geometry.coordinates[0], feat.geometry.coordinates[1])) {
+ } else {
+ if(this.inBox(box[0], box[1], box[2], box[3], wgsbox.min.x, wgsbox.min.y)
+ || this.inBox(box[0], box[1], box[2], box[3], wgsbox.min.x, wgsbox.max.y)
+ || this.inBox(box[0], box[1], box[2], box[3], wgsbox.max.x, wgsbox.max.y)
+ || this.inBox(box[0], box[1], box[2], box[3], wgsbox.max.x, wgsbox.min.y)) {
+ return;
+ if(wgsbox.min.x > box[0] && wgsbox.max.x < box[2]) {
+ if(wgsbox.min.y > box[1] && wgsbox.max.y < box[3]) {
+ return;
+ if(wgsbox.min.y < box[1] && wgsbox.max.y > box[3]) {
+ return;
+ if(wgsbox.min.x < box[0] && wgsbox.max.x > box[2] && wgsbox.min.y > box[1] && wgsbox.max.y < box[3]) {
+ return;
+ updateSelectedFeatures: function(ids, append) {
+ var self = this;
+ if(ids.length == 1 && !append && self.selectedFeatures.length == 0) {
+ $('li[title="' + ids[0].url + '"] li[idx="' + ids[0].id + '"]').click();
+ } else {
+ if(!append) {
+ self.selectedFeatures = [];
+ $.each(ids, function(_, v) {
+ var contained = false;
+ $.each(self.selectedFeatures, function(_, sel) {
+ if(v.url == sel.url && v.id == sel.id) contained = true;
+ if(!contained) {
+ self.selectedFeatures.push(v);
+ $('.kmltree-selected').removeClass('kmltree-selected');
+ $.each(self.selectedFeatures, function(_, v) {
+ $('li[title="' + v.url + '"] li[idx="' + v.id + '"]').addClass('kmltree-selected');
+ $('#selection-dialog').dialog('destroy').remove();
+ if(self.selectedFeatures.length == 0) {
+ Mapbender.modules.digitize_widget.closeEditDialog();
+ if(self.selectedFeatures.length > 1) {
+ var dlg = $(self.selectionDialog);
+ var list = dlg.find('#selected-features-list')
+ .html('');
+ var feat = self._kmls[v.url].data.features[v.id];
+ var title = feat.properties.name;
+ list.append('<li><div style="width: 20px; height: 20px; display: inline;" class="style-preview"></div><span>' + title + '</span></li>');
+ var node = list.find('li div.style-preview').last()[0];
+ self.renderPreview(feat, node);
+ dlg.dialog({
+ close: function() {
+ $(this).dialog('destroy').remove();
+ dlg.find('.digitize-export').bind('click', function() {
+ var data = {type: 'FeatureCollection', features: []};
+ data.features.push(feat);
+ self.exportItem(data);
+ dlg.dialog('close');
zoomToFeature: function(url, idx) {
var map = $('#mapframe1').mapbender();
var item = this._kmls[url];
More information about the Mapbender_commits
