[Mapbender-commits] r8976 - trunk/mapbender/lib
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Jul 2 07:19:28 PDT 2014
Author: hwbllmnn
Date: 2014-07-02 07:19:28 -0700 (Wed, 02 Jul 2014)
New Revision: 8976
   trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
removed commented code
Modified: trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
--- trunk/mapbender/lib/mb.ui.displayKmlFeatures.js	2014-07-02 14:18:38 UTC (rev 8975)
+++ trunk/mapbender/lib/mb.ui.displayKmlFeatures.js	2014-07-02 14:19:28 UTC (rev 8976)
@@ -61,50 +61,6 @@
             self.render();
-		// go: function () {
-		// 	if (!map) {
-		// 		new Mb_exception(options.id + ": " +
-		// 			options.target + " is not a map!");
-		// 		return;
-		// 	box = new Mapbender.Box({
-		// 		target: options.target
-		// 	$(map.getDomElement()).css(
-		// 		"cursor", "crosshair"
-		// 	).mousedown(function (e) {
-		// 		box.start(e);
-		// 		return false;
-		// 	}).mouseup(function (e) {
-		// 		box.stop(e, function (extent) {
-		// 			if (typeof extent === "undefined") {
-		// 				return false;
-		// 			if (extent.constructor === Mapbender.Extent) {
-		// 				var xt = map.calculateExtent(extent);
-		// 				map.setMapRequest();
-		// 			else if (extent.constructor === Mapbender.Point) {
-		// 				map.setCenter(extent);
-		// 		return false;
-		// stop: function () {
-		// 	if (!map) {
-		// 		return;
-		// 		.css("cursor", "default")
-		// 		.unbind("mousedown")
-		// 		.unbind("mouseup")
-		// 		.unbind("mousemove");
-		// 	box = null;
         this.element.bind('click', function(e) {
             if(self.lastWasBox) {
                 self.lastWasBox = false;
More information about the Mapbender_commits mailing list
