[Mapbender-commits] r8983 - in trunk/mapbender/http: classes php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Jul 3 01:51:31 PDT 2014
Author: hwbllmnn
Date: 2014-07-03 01:51:31 -0700 (Thu, 03 Jul 2014)
New Revision: 8983
   trunk/mapbender/http/classes/class_wmc.php
   trunk/mapbender/http/php/mod_savewmc_server.php
fixed update of wmcs with local data
Modified: trunk/mapbender/http/classes/class_wmc.php
--- trunk/mapbender/http/classes/class_wmc.php	2014-07-03 07:33:55 UTC (rev 8982)
+++ trunk/mapbender/http/classes/class_wmc.php	2014-07-03 08:51:31 UTC (rev 8983)
@@ -227,7 +227,6 @@
 		// set title
 		$this->wmc_title = $generalTitle;
         if($mapObject[0]->kmls) {
             $this->has_local_data = true;
             $this->local_data_size = strlen(json_encode($mapObject[0]->kmls));
@@ -676,7 +675,6 @@
 				$tmpNode = $WMCDoc->importNode($NewKeywordList,true);
 				$general->appendChild($tmpNode);
 			$this->xml  = $WMCDoc->saveXML();
 			db_begin();
@@ -698,8 +696,8 @@
 				if($row = db_fetch_row($res)) {
 					$sql = "UPDATE mb_user_wmc SET wmc = $1, wmc_timestamp = $2, abstract = $3, srs = $4, minx = $5, miny = $6,".
-						" maxx = $7, maxy = $8, wmc_title = $9 WHERE fkey_user_id = $10 AND wmc_serial_id=$11 AND wmc_timestamp = $12 AND wmc_has_local_data = $13 ".
-                        "AND wmc_local_data_public = $14 AND wmc_local_data_size = $15;";
+						" maxx = $7, maxy = $8, wmc_title = $9, wmc_has_local_data = $13, ".
+                        "wmc_local_data_public = $14, wmc_local_data_size = $15 WHERE fkey_user_id = $10 AND wmc_serial_id=$11 AND wmc_timestamp = $12;";
 					$v = array($this->xml, time(), $this->wmc_abstract, $this->wmc_srs, $this->wmc_extent->minx, $this->wmc_extent->miny,
                     $this->wmc_extent->maxx, $this->wmc_extent->maxy ,administration::convertOutgoingString($this->wmc_title), $this->userId, $this->wmc_id,$row[2],
                     $this->has_local_data, $this->local_data_public, $this->local_data_size);
Modified: trunk/mapbender/http/php/mod_savewmc_server.php
--- trunk/mapbender/http/php/mod_savewmc_server.php	2014-07-03 07:33:55 UTC (rev 8982)
+++ trunk/mapbender/http/php/mod_savewmc_server.php	2014-07-03 08:51:31 UTC (rev 8983)
@@ -161,9 +161,13 @@
 	// make a keyword array here
     $kwds = explode(",",$attributes->keywords);
-	foreach ($wmc->keyword as &$val) {
-		$val = trim($val);
+    $wmckwds = $wmc->keyword;
+    if(is_array($wmckwds)) {
+        foreach ($wmckwds as &$val) {
+            $val = trim($val);
+    $wmc->keyword = $wmckwds;
 	$wmc->wmc_keyword = $kwds;
 	$wmc->wmc_abstract = $attributes->abstract;
More information about the Mapbender_commits mailing list
