[Mapbender-commits] r8994 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Wed Jul 9 04:09:02 PDT 2014
Author: armin11
Date: 2014-07-09 04:09:02 -0700 (Wed, 09 Jul 2014)
New Revision: 8994
trunk/mapbender/http/classes/class_point.php
Solve problem of transforming coordinates that cannot be transformed via postgis/proj, cause the points are not in the area of the projection that is demanded.
Modified: trunk/mapbender/http/classes/class_point.php
--- trunk/mapbender/http/classes/class_point.php 2014-07-09 11:08:40 UTC (rev 8993)
+++ trunk/mapbender/http/classes/class_point.php 2014-07-09 11:09:02 UTC (rev 8994)
@@ -163,6 +163,38 @@
if(SYS_DBTYPE=='pgsql'){
$currentEpsg = preg_replace("/EPSG:/", "", $this->epsg);
$targetEpsg = preg_replace("/EPSG:/", "", $toEpsg);
+ //get EPSG:4326 extents for which $this->epsg are defined
+ $geometryUnchanged = true;
+ if (defined("SRS_ARRAY") && SRS_ARRAY !== "" ) {
+ //check if this->epsg is 4326
+ $posTargetEpsgBbox = array_search($targetEpsg,explode(",",SRS_ARRAY));
+ if ($posTargetEpsgBbox !== false) {
+ //check if bboxes are defined for special epsg SRS_ARRAY_MAX_EXTENTS
+ if (defined("SRS_ARRAY_MAX_EXTENTS") && SRS_ARRAY_MAX_EXTENTS !== "" ) {
+ $bboxArray = explode("|",SRS_ARRAY_MAX_EXTENTS);
+ $wgs84BboxTargetEpsg = explode(",",$bboxArray[$posTargetEpsgBbox]);
+ //compare point values with bboxes and adopt them if needed
+ //$e = new mb_exception("class_point: bbox compare started before transforming!!!");
+ //$e = new mb_exception("class_point: minx:".$wgs84BboxTargetEpsg[0]." - miny:".$wgs84BboxTargetEpsg[1]." - maxx:".$wgs84BboxTargetEpsg[2]." - maxy:".$wgs84BboxTargetEpsg[3]);
+ if ($this->x < $wgs84BboxTargetEpsg[0]) {
+ $this->x = $wgs84BboxTargetEpsg[0];
+ $geometryUnchanged = false;
+ if ($this->x > $wgs84BboxTargetEpsg[2]) {
+ $this->x = $wgs84BboxTargetEpsg[2];
+ if ($this->y < $wgs84BboxTargetEpsg[1]) {
+ $this->y = $wgs84BboxTargetEpsg[1];
+ if ($this->y > $wgs84BboxTargetEpsg[3]) {
+ $this->y = $wgs84BboxTargetEpsg[3];
db_begin();
$sql = "SELECT X(transform(GeometryFromText('POINT(".$this->x." ".$this->y.")',".$currentEpsg."),".$targetEpsg.")) as x, ";
$sql .= "Y(transform(GeometryFromText('POINT(".$this->x." ".$this->y.")',".$currentEpsg."),".$targetEpsg.")) as y";
More information about the Mapbender_commits
