[Mapbender-commits] r8928 - trunk/mapbender/http/geoportal
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Jun 25 00:31:49 PDT 2014
Author: armin11
Date: 2014-06-25 00:31:49 -0700 (Wed, 25 Jun 2014)
New Revision: 8928
   trunk/mapbender/http/geoportal/mod_readCSWResultsDetail.php
Fix XSS vulnerability by using whitelists for request params
Modified: trunk/mapbender/http/geoportal/mod_readCSWResultsDetail.php
--- trunk/mapbender/http/geoportal/mod_readCSWResultsDetail.php	2014-06-25 06:58:36 UTC (rev 8927)
+++ trunk/mapbender/http/geoportal/mod_readCSWResultsDetail.php	2014-06-25 07:31:49 UTC (rev 8928)
@@ -7,6 +7,7 @@
 require_once(dirname(__FILE__)."/../php/mod_validateInspire.php");
 require_once(dirname(__FILE__) . "/../../tools/wms_extent/extent_service.conf");
 require_once(dirname(__FILE__) . "/../classes/class_iso19139.php");
+require_once(dirname(__FILE__) . "/../classes/class_Uuid.php");
 //INSPIRE Mapping
 require_once(dirname(__FILE__)."/../../conf/isoMetadata.conf");
 $languageCode = "de";
@@ -24,12 +25,55 @@
 	//validate to csv integer list
 	$testMatch = $_REQUEST["languageCode"];
 	if (!($testMatch == 'de' or $testMatch == 'fr' or $testMatch == 'en')){
-		echo 'languageCode: <b>'.$testMatch.'</b> is not valid.<br/>';
+		echo 'languageCode is not valid - it should be de, fr, or en.<br/>';
 		die();
 	$languageCode = $testMatch;
 	$testMatch = NULL;
+//validate following parameter to prohibit xss - see result pentest 03/2014
+//cat_id
+if (isset($_REQUEST["cat_id"]) & $_REQUEST["cat_id"] != "") {
+	//validate to integer
+        $testMatch = $_REQUEST["cat_id"];
+        //give max 99 entries - more will be to slow
+        $pattern = '/^[0-9]*$/';
+        if (!preg_match($pattern,$testMatch)){
+                echo 'Parameter <b>cat_id</b> is not valid (integer).<br/>';
+                die();
+        $testMatch = NULL;
+//validate
+if (isset($_REQUEST["validate"]) & $_REQUEST["validate"] != "") {
+	$testMatch = $_REQUEST["validate"];
+ 	if (!($testMatch == 'true' or $testMatch == 'false')){
+		echo 'Parameter <b>validate</b> is not valid (true,false).<br/>';
+		die();
+//uuid
+if (isset($_REQUEST['uuid']) & $_REQUEST['uuid'] != "") {
+	//validate cs list of uuids or other identifiers - which?
+	$testMatch = $_REQUEST["uuid"];
+	$uuid = new Uuid($testMatch);
+	$isUuid = $uuid->isValid();
+	if (!$isUuid) {
+		echo 'Parameter <b>uuid</b> is not a valid uuid (12-4-4-4-8) or a list of uuids!<br/>';
+		die();
+//mdtype
+if (isset($_REQUEST["mdtype"]) & $_REQUEST["mdtype"] != "") {
+	$testMatch = $_REQUEST["mdtype"];
+ 	if (!($testMatch == 'html' or $testMatch == 'iso19139' or $testMatch == 'debug' or $testMatch == 'inspire')){
+		echo 'Parameter <b>mdtype</b> is not valid (iso19139, html, debug, inspire).<br/>';
+		die();
 if(!isset($_REQUEST["cat_id"])) {
 	echo "no opensearch id set";
More information about the Mapbender_commits mailing list
