[Mapbender-commits] r8934 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Wed Jun 25 06:57:31 PDT 2014
Author: hwbllmnn
Date: 2014-06-25 06:57:31 -0700 (Wed, 25 Jun 2014)
New Revision: 8934
trunk/mapbender/http/classes/class_wmc.php
properly store whether a wmc has local data and its size
Modified: trunk/mapbender/http/classes/class_wmc.php
--- trunk/mapbender/http/classes/class_wmc.php 2014-06-25 11:49:54 UTC (rev 8933)
+++ trunk/mapbender/http/classes/class_wmc.php 2014-06-25 13:57:31 UTC (rev 8934)
@@ -94,6 +94,9 @@
var $userId;
var $timestamp;
var $public;
+ var $local_data_public = 0;
+ var $has_local_data = 0;
+ var $local_data_size = '0';
// set during parsing
var $wmc_version;
@@ -157,7 +160,7 @@
return false;
$this->createObjFromWMC_xml($doc);
- $sql = "SELECT wmc_timestamp, wmc_title, wmc_public, srs, minx, miny, maxx, maxy " .
+ $sql = "SELECT wmc_timestamp, wmc_title, wmc_public, srs, minx, miny, maxx, maxy, wmc_has_local_data, wmc_local_data_size, wmc_local_data_public " .
"FROM mb_user_wmc WHERE wmc_serial_id = $1 AND (fkey_user_id = $2 OR wmc_public = 1)";
$v = array($wmcId, Mapbender::session()->get("mb_user_id"));
$t = array("i", "i");
@@ -174,6 +177,9 @@
$this->wmc_extent->miny = $row[5];
$this->wmc_extent->maxx = $row[6];
$this->wmc_extent->maxy = $row[7];
+ $this->local_data_public = $row[10];
+ $this->local_data_size = $row[9];
+ $this->has_local_data = $row[8];
return true;
return false;
@@ -235,6 +241,10 @@
+ if($mapObject[0]->kmls) {
+ $this->has_local_data = true;
+ $this->local_data_size = strlen(json_encode($mapObject[0]->kmls));
// create XML
$this->createXml();
@@ -680,10 +690,12 @@
if($row = db_fetch_row($res)) {
$sql = "UPDATE mb_user_wmc SET wmc = $1, wmc_timestamp = $2, abstract = $3, srs = $4, minx = $5, miny = $6,".
- " maxx = $7, maxy = $8, wmc_title = $9 WHERE fkey_user_id = $10 AND wmc_serial_id=$11 AND wmc_timestamp = $12;";
+ " maxx = $7, maxy = $8, wmc_title = $9 WHERE fkey_user_id = $10 AND wmc_serial_id=$11 AND wmc_timestamp = $12 AND wmc_has_local_data = $13 ".
+ "AND wmc_local_data_public = $14 AND wmc_local_data_size = $15;";
$v = array($this->xml, time(), $this->wmc_abstract, $this->wmc_srs, $this->wmc_extent->minx, $this->wmc_extent->miny,
- $this->wmc_extent->maxx, $this->wmc_extent->maxy ,administration::convertOutgoingString($this->wmc_title), $this->userId, $this->wmc_id,$row[2]);
- $t = array("s", "s","s","s","i","i","i","i", "s", "i", "i","s");
+ $this->wmc_extent->maxx, $this->wmc_extent->maxy ,administration::convertOutgoingString($this->wmc_title), $this->userId, $this->wmc_id,$row[2],
+ $this->has_local_data, $this->local_data_public, $this->local_data_size);
+ $t = array("s", "s","s","s","i","i","i","i", "s", "i", "i","s", "i", "i", "s");
$res = db_prep_query($sql, $v, $t);
// need the database Id
$wmc_DB_ID = $row[3];
@@ -715,11 +727,12 @@
$sql = "INSERT INTO mb_user_wmc (" .
"wmc_id, fkey_user_id, wmc, wmc_title, wmc_public, wmc_timestamp, wmc_timestamp_create, " .
- "abstract, srs, minx, miny, maxx, maxy, wmc_serial_id".
- ") VALUES ($1, $2, $3, $4, $5, $6, $7, $8, $9, $10, $11, $12, $13, $14);";
+ "abstract, srs, minx, miny, maxx, maxy, wmc_serial_id, wmc_has_local_data, wmc_local_data_public, wmc_local_data_size".
+ ") VALUES ($1, $2, $3, $4, $5, $6, $7, $8, $9, $10, $11, $12, $13, $14, $15, $16, $17);";
$v = array(time(), $this->userId, $this->xml, administration::convertOutgoingString($this->wmc_title), $this->isPublic()?1:0,time(),time(),
- $this->wmc_abstract, $this->wmc_srs, $this->wmc_extent->minx, $this->wmc_extent->miny, $this->wmc_extent->maxx, $this->wmc_extent->maxy, $wmc_DB_ID_new);
- $t = array("s", "i", "s", "s", "i", "s","s", "s","s","i","i","i", "i", "i");
+ $this->wmc_abstract, $this->wmc_srs, $this->wmc_extent->minx, $this->wmc_extent->miny, $this->wmc_extent->maxx, $this->wmc_extent->maxy, $wmc_DB_ID_new,
+ $t = array("s", "i", "s", "s", "i", "s","s", "s","s","i","i","i", "i", "i", "i", "i", "s");
//$sql = "SELECT max(wmc_serial_id) AS i FROM mb_user_wmc";
@@ -737,12 +750,13 @@
//$e = new mb_exception($sql);
$v = array(time(), $this->userId, $this->xml, administration::convertOutgoingString($this->wmc_title), $this->isPublic()?1:0, time(),time(),
@@ -1032,7 +1046,33 @@
return $noIdArray;
+ public function hasLocalData() {
+ return $this->has_local_data;
+ public function isLocalDataPublic() {
+ return $this->local_data_public;
+ public function getLocalDataSize() {
+ return $this->local_data_size;
+ public function setHasLocalData($has_local_data) {
+ $this->has_local_data = $has_local_data;
+ return $this;
+ public function setLocalDataPublic($local_data_public) {
+ $this->local_data_public = $local_data_public;
+ return $this;
+ public function setLocalDataSize($local_data_size) {
+ $this->local_data_size = $local_data_size;
+ return $this;
// OUTPUT FUNCTIONS
More information about the Mapbender_commits
