[Mapbender-commits] r8938 - in trunk/mapbender/http: classes	javascripts
    svn_mapbender at osgeo.org
    Thu Jun 26 02:48:31 PDT 2014
Author: hwbllmnn
Date: 2014-06-26 02:48:31 -0700 (Thu, 26 Jun 2014)
New Revision: 8938
   trunk/mapbender/http/classes/class_wmc.php
   trunk/mapbender/http/javascripts/map.php
   trunk/mapbender/http/javascripts/mod_savewmc.js
added option to limit local data size in wmcs
Modified: trunk/mapbender/http/classes/class_wmc.php
--- trunk/mapbender/http/classes/class_wmc.php	2014-06-26 09:22:57 UTC (rev 8937)
+++ trunk/mapbender/http/classes/class_wmc.php	2014-06-26 09:48:31 UTC (rev 8938)
@@ -228,6 +228,19 @@
 		// set title
 		$this->wmc_title = $generalTitle;
+        if($mapObject[0]->kmls) {
+            $this->has_local_data = true;
+            $this->local_data_size = strlen(json_encode($mapObject[0]->kmls));
+            if(defined('MAX_WMC_LOCAL_DATA_SIZE')) {
+                if($this->local_data_size > MAX_WMC_LOCAL_DATA_SIZE) {
+                    $this->has_local_data = false;
+                    $this->local_data_size = '0';
+                    unset($mapObject[0]->kmls);
+                    unset($mapObject[0]->kmlOrder);
 		// create the map objects
 		for ($i = 0; $i < count($mapObject); $i++) {
 			$currentMap = new Map();
@@ -241,11 +254,6 @@
-        if($mapObject[0]->kmls) {
-            $this->has_local_data = true;
-            $this->local_data_size = strlen(json_encode($mapObject[0]->kmls));
 		// create XML
 		$this->createXml();
Modified: trunk/mapbender/http/javascripts/map.php
--- trunk/mapbender/http/javascripts/map.php	2014-06-26 09:22:57 UTC (rev 8937)
+++ trunk/mapbender/http/javascripts/map.php	2014-06-26 09:48:31 UTC (rev 8938)
@@ -23,7 +23,7 @@
 $json = new Mapbender_JSON();
 // see http://trac.osgeo.org/mapbender/ticket/79
-ini_set('session.bug_compat_42',0);
+ini_set('session.bug_compat_42',0);
 ini_set('session.bug_compat_warn',0);
 Mapbender::session()->set("mb_user_gui", $gui_id);
@@ -33,6 +33,9 @@
 // Define global variables (TODO: move to mapbender object later on)
+if(defined('MAX_WMC_LOCAL_DATA_SIZE')) {
+    echo "Mapbender.options = {MAX_WMC_LOCAL_DATA_SIZE: " . MAX_WMC_LOCAL_DATA_SIZE . "};\n";
 echo "Mapbender.sessionId = '".session_id()."';\n";
 echo "var mb_nr = Mapbender.sessionId;\n";
 echo "Mapbender.sessionName = '".session_name()."';\n";
@@ -95,8 +98,8 @@
 $libPath = dirname(__FILE__) . "/../../lib/";
 $libFileArray = array(
-	"exception.js",
-	"ajax.js",
+	"exception.js",
+	"ajax.js",
 	"basic.js",
 	"div.js",
 	"list.js",
@@ -178,8 +181,8 @@
 $linkJsPluginsArray = array();
 //get language code
 $langCode = Mapbender::session()->get("mb_lang");
-$mb_sql = "SELECT DISTINCT e_js_file, e_id, e_src, e_target, e_pos, e_url, " .
-	"e_left, e_top, e_title, gettext($2, e_title) AS e_current_title, " .
+$mb_sql = "SELECT DISTINCT e_js_file, e_id, e_src, e_target, e_pos, e_url, " .
+	"e_left, e_top, e_title, gettext($2, e_title) AS e_current_title, " .
 	"e_width, e_height, e_requires FROM gui_element WHERE e_public = 1 AND " .
 	"fkey_gui_id = $1 ORDER BY e_pos";
 $mb_v = array($gui_id, $langCode);
@@ -190,7 +193,7 @@
 	// Create element properties
-	$e_id = isset($row_js["e_id"]) ?
+	$e_id = isset($row_js["e_id"]) ?
 	str_replace(" ", "", $row_js["e_id"]) : "";
 	$e_src = $row_js["e_src"];
 	$e_require = $row_js["e_requires"];
@@ -203,17 +206,17 @@
 	$e_left = intval($row_js["e_left"]);
 	$e_url = $row_js["e_url"];
-	$elementAttributes = "{" .
-		"id:'$e_id'," .
+	$elementAttributes = "{" .
+		"id:'$e_id'," .
 		"target:" . ($e_target[0] != "" ? $json->encode($e_target) : "[]") . "," .
 		"url:'$e_url'," .
-		"top:$e_top," .
-		"left:$e_left," .
-		"width:$e_width," .
-		"height:$e_height," .
-		"src:'$e_src'," .
-		"title:'$e_title'," .
-		"currentTitle:'$e_currentTitle'" .
+		"top:$e_top," .
+		"left:$e_left," .
+		"width:$e_width," .
+		"height:$e_height," .
+		"src:'$e_src'," .
+		"title:'$e_title'," .
+		"currentTitle:'$e_currentTitle'" .
 	echo "Mapbender.modules." . $e_id . " = " . $elementAttributes . ";\n";
@@ -221,7 +224,7 @@
 	echo "var sel = [];for (var k in t) {t[k] = $.trim(t[k]);if($('#' + t[k]).size() > 0) {sel.push($('#' + t[k]).get(0))}}\n";
 	echo "Mapbender.modules." . $e_id . ".\$target = sel.length > 0 ? \$(sel) : $([]);\n";
 	echo "$('#" . $e_id . "').data('api', Mapbender.modules." . $e_id . ");";
 	// Include JavaScript files
@@ -238,17 +241,17 @@
 			ob_start();
 			echo "var options = Mapbender.modules." . $e_id . ";\n";
-			// extend the options variable by JS element vars
+			// extend the options variable by JS element vars
 			echo $elementVars;
-			echo "\n$.fn.$e_id = function (options) {\n" .
+			echo "\n$.fn.$e_id = function (options) {\n" .
 				"\treturn this.each(function () {\n\n";
 			$jsArray = explode(",", $jsFileString);
 			for ($i = 0; $i < count($jsArray); $i++) {
 				$currentFile = trim($jsArray[$i]);
 				if (!file_exists($currentFile)) {
 					$e = new mb_exception("Javascript not found: " . $currentFile);
 					echo "var e = new Mb_exception('Javascript not found: " . $currentFile . "');";
@@ -260,21 +263,21 @@
 				 * folder?
 				require(secure($currentFile));
 			echo "\n\t});\n};\n\n";
 			echo "$('#$e_id').$e_id(options);\n";
 			$executeJsPluginsArray[] = ob_get_contents();
 			ob_end_clean();
-			$linkJsPluginsArray[] = "var options = {'id':'" . $e_id .
+			$linkJsPluginsArray[] = "var options = {'id':'" . $e_id .
 				"'};" . $elementVars . ";linkPlugins(options);";
 		else {
@@ -334,13 +337,13 @@
 	Mapbender.events.hideSplashScreen.trigger();
 	$jsText
 	$linkJsPluginsText
 	$("img").bind("mousedown", function (e) {
@@ -350,7 +353,7 @@
 	}).bind("mousemove", function (e) {
 		e.preventDefault();
 	// creates the map objects (mapframe1, overview...)
 	Mapbender.events.initMaps.trigger();
Modified: trunk/mapbender/http/javascripts/mod_savewmc.js
--- trunk/mapbender/http/javascripts/mod_savewmc.js	2014-06-26 09:22:57 UTC (rev 8937)
+++ trunk/mapbender/http/javascripts/mod_savewmc.js	2014-06-26 09:48:31 UTC (rev 8938)
@@ -170,6 +170,12 @@
             if(kml) {
                 mb_mapObj[0].kmls = kml._kmls;
                 mb_mapObj[0].kmlOrder = kml.kmlOrder;
+                var json = JSON.stringify(kml._kmls);
+                if(Mapbender.options && Mapbender.options.MAX_WMC_LOCAL_DATA_SIZE && json.length > Mapbender.options.MAX_WMC_LOCAL_DATA_SIZE) {
+                    alert('The maximum local data size is ' + Math.round(Mapbender.options.MAX_WMC_LOCAL_DATA_SIZE / 1024) + 'kb, your data is ' + Math.round(json.length / 1024) + 'kb, data will NOT be saved.');
+                    mb_mapObj[0].kmls = null;
+                    mb_mapObj[0].kmlOrder = null;
 	    	var mapObjectToSend = $.toJSON(mb_mapObj);
More information about the Mapbender_commits
