[Mapbender-commits] r8940 - in trunk/mapbender/http: extensions plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Jun 26 06:45:40 PDT 2014
Author: hwbllmnn
Date: 2014-06-26 06:45:40 -0700 (Thu, 26 Jun 2014)
New Revision: 8940
Added:
   trunk/mapbender/http/extensions/tokml.js
   trunk/mapbender/http/plugins/mb_digitize_widget.php
added actual exporting to kml
Added: trunk/mapbender/http/extensions/tokml.js
--- trunk/mapbender/http/extensions/tokml.js	                        (rev 0)
+++ trunk/mapbender/http/extensions/tokml.js	2014-06-26 13:45:40 UTC (rev 8940)
@@ -0,0 +1,241 @@
+!function(e){if("object"==typeof exports)module.exports=e();else if("function"==typeof define&&define.amd)define(e);else{var f;"undefined"!=typeof window?f=window:"undefined"!=typeof global?f=global:"undefined"!=typeof self&&(f=self),f.tokml=e()}}(function(){var define,module,exports;return (function e(t,n,r){function s(o,u){if(!n[o]){if(!t[o]){var a=typeof require=="function"&&require;if(!u&&a)return a(o,!0);if(i)return i(o,!0);throw new Error("Cannot find module '"+o+"'")}var f=n[o]={exports:{}};t[o][0].call(f.exports,function(e){var n=t[o][1][e];return s(n?n:e)},f,f.exports,e,t,n,r)}return n[o].exports}var i=typeof require=="function"&&require;for(var o=0;o<r.length;o++)s(r[o]);return s})({1:[function(require,module,exports){
+var strxml = require('strxml'),
+    tag = strxml.tag,
+    encode = strxml.encode;
+module.exports = function tokml(geojson, options) {
+    options = options || {
+        documentName: undefined,
+        documentDescription: undefined,
+        name: 'name',
+        description: 'description',
+        simplestyle: false
+    return '<?xml version="1.0" encoding="UTF-8"?>' +
+        tag('kml',
+            tag('Document',
+                documentName(options) +
+                documentDescription(options) +
+                root(geojson, options)
+               ), [['xmlns', 'http://www.opengis.net/kml/2.2']]);
+function feature(options) {
+    return function(_) {
+        var styleDefinition = '',
+            styleReference = '';
+        if (options.simplestyle && hasStyle(_.properties)) {
+            styleDefinition = iconstyle(_.properties);
+            styleReference = tag('styleUrl', '#' + iconHash(_.properties));
+        if (!_.properties || !geometry.valid(_.geometry)) return '';
+        var geometryString = geometry.any(_.geometry);
+        if (!geometryString) return '';
+        return styleDefinition + tag('Placemark',
+            name(_.properties, options) +
+            description(_.properties, options) +
+            geometryString +
+            extendeddata(_.properties) +
+            styleReference);
+function root(_, options) {
+    if (!_.type) return '';
+    switch (_.type) {
+        case 'FeatureCollection':
+            if (!_.features) return '';
+            return _.features.map(feature(options)).join('');
+        case 'Feature':
+            return feature(options)(_);
+        default:
+            return feature(options)({
+                type: 'Feature',
+                geometry: _,
+                properties: {}
+    return '';
+function documentName(options) {
+    return (options.documentName !== undefined) ? tag('name', options.documentName) : '';
+function documentDescription(options) {
+    return (options.documentDescription !== undefined) ? tag('description', options.documentDescription) : '';
+function name(_, options) {
+    return _[options.name] ? tag('name', encode(_[options.name])) : '';
+function description(_, options) {
+    return _[options.description] ? tag('description', encode(_[options.description])) : '';
+// ## Geometry Types
+// https://developers.google.com/kml/documentation/kmlreference#geometry
+var geometry = {
+    Point: function(_) {
+        return tag('Point', tag('coordinates', _.coordinates.join(',')));
+    LineString: function(_) {
+        return tag('LineString', tag('coordinates', linearring(_.coordinates)));
+    Polygon: function(_) {
+        if (!_.coordinates.length) return '';
+        var outer = _.coordinates[0],
+            inner = _.coordinates.slice(1),
+            outerRing = tag('outerBoundaryIs',
+                tag('LinearRing', tag('coordinates', linearring(outer)))),
+            innerRings = inner.map(function(i) {
+                return tag('innerBoundaryIs',
+                    tag('LinearRing', tag('coordinates', linearring(i))));
+            }).join('');
+        return tag('Polygon', outerRing + innerRings);
+    MultiPoint: function(_) {
+        return tag('MultiGeometry', _.coordinates.map(function(c) {
+            return geometry.Point({ coordinates: c });
+        }).join(''));
+    MultiPolygon: function(_) {
+            return geometry.Polygon({ coordinates: c });
+        }).join(''));
+    MultiLineString: function(_) {
+            return geometry.LineString({ coordinates: c });
+        }).join(''));
+    GeometryCollection: function(_) {
+            _.geometries.map(geometry.any).join(''));
+    valid: function(_) {
+        return _ && _.type && (_.coordinates ||
+            _.type === 'GeometryCollection' && _.geometries.every(geometry.valid));
+    any: function(_) {
+        if (geometry[_.type]) {
+            return geometry[_.type](_);
+        } else {
+            return '';
+function linearring(_) {
+    return _.map(function(cds) { return cds.join(','); }).join(' ');
+// ## Data
+function extendeddata(_) {
+    return tag('ExtendedData', pairs(_).map(data).join(''));
+function data(_) {
+    return tag('Data', tag('value', encode(_[1])), [['name', encode(_[0])]]);
+// ## Icons
+function iconstyle(_) {
+    return tag('Style',
+        tag('IconStyle',
+            tag('Icon',
+                tag('href', iconUrl(_)))) +
+        iconSize(_), [['id', iconHash(_)]]);
+function iconUrl(_) {
+    var size = _['marker-size'] || 'medium',
+        symbol = _['marker-symbol'] ? '-' + _['marker-symbol'] : '',
+        color = (_['marker-color'] || '7e7e7e').replace('#', '');
+    return 'https://api.tiles.mapbox.com/v3/marker/' + 'pin-' + size.charAt(0) +
+        symbol + '+' + color + '.png';
+function iconSize(_) {
+    return tag('hotSpot', '', [
+        ['xunits', 'fraction'],
+        ['yunits', 'fraction'],
+        ['x', 0.5],
+        ['y', 0.5]
+function hasStyle(_) {
+    return !!(_['marker-size'] || _['marker-symbol'] || _['marker-color']);
+function iconHash(_) {
+    return (_['marker-symbol'] || '') +
+        (_['marker-color'] || '').replace('#', '') +
+        (_['marker-size'] || '');
+// ## Helpers
+function pairs(_) {
+    var o = [];
+    for (var i in _) o.push([i, _[i]]);
+    return o;
+},{"strxml":2}],2:[function(require,module,exports){
+module.exports.attr = attr;
+module.exports.tagClose = tagClose;
+module.exports.tag = tag;
+module.exports.encode = encode;
+ * @param {array} _ an array of attributes
+ * @returns {string}
+function attr(_) {
+    return (_ && _.length) ? (' ' + _.map(function(a) {
+        return a[0] + '="' + a[1] + '"';
+    }).join(' ')) : '';
+ * @param {string} el element name
+ * @param {array} attributes array of pairs
+function tagClose(el, attributes) {
+    return '<' + el + attr(attributes) + '/>';
+ * @param {string} contents innerXML
+function tag(el, contents, attributes) {
+    return '<' + el + attr(attributes) + '>' + contents + '</' + el + '>';
+ * @param {string} _ a string of attribute
+function encode(_) {
+    return (_ === null ? '' : _.toString()).replace(/&/g, '&')
+        .replace(/</g, '<')
+        .replace(/>/g, '>')
+        .replace(/"/g, '"');
+},{}]},{},[1])
+(1)
\ No newline at end of file
Modified: trunk/mapbender/http/plugins/mb_digitize_widget.php
--- trunk/mapbender/http/plugins/mb_digitize_widget.php	2014-06-26 09:49:25 UTC (rev 8939)
+++ trunk/mapbender/http/plugins/mb_digitize_widget.php	2014-06-26 13:45:40 UTC (rev 8940)
@@ -397,6 +397,15 @@
             menu.menu('destroy').remove();
         menu.children('li:has(.digitize-pencil)').bind('click', editObject($link, menu));
+        menu.children('li:has(.digitize-export)').bind('click', function() {
+            var kml = $('#mapframe1').data('kml');
+            var url = $link.parent().parent().attr('title');
+            var idx = $link.attr('idx');
+            var data = kml._kmls[url];
+            kml = tokml(data.data.features[idx]);
+            window.open('data:application/xml,' + encodeURIComponent(kml));
+            menu.menu('destroy').remove();
         menu.children('li:has(.digitize-remove)').bind('click', function() {
@@ -535,6 +544,14 @@
             $link.parent().remove();
+            var url = $link.parent().attr('title');
+            kml = tokml(data.data);
         menu.children('li:has(.digitize-add,.digitize-pencil)').bind('click', function() {
             digitizeDialog.dialog('open');
             digitizeDialog.find('.digitize-add,.digitize-pencil').bind('click', function() {
More information about the Mapbender_commits mailing list
