[Mapbender-commits] r8949 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Jun 30 04:08:02 PDT 2014
Author: hwbllmnn
Date: 2014-06-30 04:08:02 -0700 (Mon, 30 Jun 2014)
New Revision: 8949
   trunk/mapbender/http/javascripts/initWmcObj.php
fixed php warning
Modified: trunk/mapbender/http/javascripts/initWmcObj.php
--- trunk/mapbender/http/javascripts/initWmcObj.php	2014-06-30 10:02:12 UTC (rev 8948)
+++ trunk/mapbender/http/javascripts/initWmcObj.php	2014-06-30 11:08:02 UTC (rev 8949)
@@ -1,7 +1,7 @@
 <?php
 // Load WMS via WMC
 require_once dirname(__FILE__)."/../php/mb_validateSession.php";
 require_once dirname(__FILE__)."/../classes/class_wmc.php";
 require_once dirname(__FILE__)."/../classes/class_wmc_factory.php";
@@ -32,7 +32,7 @@
 					#exit;
 				fclose($h);
 function getWmcFromStorage($filename) {
@@ -67,16 +67,16 @@
 			$cache = new Cache();
 			if ($cache->isActive && $cache->cachedVariableExists($filename)) {
 				$wmc = $cache->cachedVariableFetch($filename);
-				return $wmc;
+				return $wmc;
 			} else {
 				return false;
 		break;
-		case "file":
+		case "file":
 			$wmc = file_get_contents($filename);
 			return $wmc;
 		break;
-		default:
+		default:
 			return $wmc;
 		break;
@@ -182,7 +182,7 @@
 	// just make it work for a single Wmc
 		try {
 			$wmcGetApi = WmcFactory::createFromDb($input["id"]);
-			//update urls from wmc with urls from database if id is given
+			//update urls from wmc with urls from database if id is given
 			$updatedWMC = $wmcGetApi->updateUrlsFromDb();
 	        	$wmcGetApi->createFromXml($updatedWMC);
 			//increment load count
@@ -383,14 +383,14 @@
 $inputGeoRSSArray = $getApi->getGeoRSSFeeds();
 $e = new mb_notice("initWmcObj.php: check GEORSS API");
 if($inputGeoRSSArray){
-	$wmc->generalExtensionArray['GEORSS'] = $inputGeoRSSArray;
+	$wmc->generalExtensionArray['GEORSS'] = $inputGeoRSSArray;
 //KML
 $inputKmlArray = $getApi->getKml();
 if($inputKmlArray){
-	$wmc->generalExtensionArray['KML'] = $inputKmlArray;
+	$wmc->generalExtensionArray['KML'] = $inputKmlArray;
 //TODO test following
 //workaround to have a fully merged WMC for loading
@@ -493,13 +493,13 @@
 		$constraints->type = "wms";
 		$constraints->returnDirect = false;
 		$touForWMS = $constraints->getDisclaimer();
-		//add only those who have no special tou defined -
+		//add only those who have no special tou defined -
 		if ($touForWMS != 'free'){
 			$tou .= $touHeader.$touForWMS;
 		//set the tou to be accepted - TODO maybe do this after the button which deletes the message window - from a ajax request.
 		$classTou->set('wms',$WMS['id']);
 if ($tou != "") {
 	$tou = _mb("The configuration, which should be loaded, consists of different services which have the following terms of use:")."<br>".$tou;
@@ -541,7 +541,9 @@
 //overwrite extent of wmc with information from GetApi if given
 $e = new mb_notice("initWmcObj.php: check ZOOM API");
 $zoom = $getApi->getZoom();
-$e = new mb_notice("initWmcObj.php: check ZOOM API: ".implode(',',$zoom));
+if(is_array($zoom)) {
+    $e = new mb_notice("initWmcObj.php: check ZOOM API: ".implode(',',$zoom));
 if (count($zoom) == 4 || count($zoom) == 5) {
 	$e = new mb_notice("initWmcObject.php: found EXTENT");
 	if (count($zoom) == 5){
@@ -549,7 +551,7 @@
 			$zoom[0],
 			$zoom[1],
 			$zoom[2],
-			$zoom[3],
+			$zoom[3],
 			$epsg = $zoom[4]);
 	} else {
 		//get current epsg from wmc bounding box
@@ -559,7 +561,7 @@
 			$zoom[0],
 			$zoom[1],
 			$zoom[2],
-			$zoom[3],
+			$zoom[3],
 			$epsg = $wmcGetApi->mainMap->getEpsg());
 	$wmcGetApi->mainMap->setExtent($bbox);
More information about the Mapbender_commits mailing list
