[Mapbender-commits] r8831 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org
Thu May 8 07:31:32 PDT 2014
Author: hwbllmnn
Date: 2014-05-08 07:31:32 -0700 (Thu, 08 May 2014)
New Revision: 8831
trunk/mapbender/http/plugins/kmlTree.js
trunk/mapbender/http/plugins/mb_digitize_widget.php
implemented digitized features zoomto
Modified: trunk/mapbender/http/plugins/kmlTree.js
--- trunk/mapbender/http/plugins/kmlTree.js 2014-05-08 14:13:01 UTC (rev 8830)
+++ trunk/mapbender/http/plugins/kmlTree.js 2014-05-08 14:31:32 UTC (rev 8831)
@@ -61,7 +61,6 @@
//console.log(obj);
var checked = obj.display ? 'checked="checked"':'';
title = obj.url;
if(obj.refreshing) {
$KMLfolder.find('ul li[title="' + title + '"]').remove();
@@ -80,7 +79,6 @@
bbox[0] = bbox[0].minus(buffer);
bbox[1] = bbox[1].plus(buffer);
map.calculateExtent(
new Mapbender.Extent(bbox[0], bbox[1])
Modified: trunk/mapbender/http/plugins/mb_digitize_widget.php
--- trunk/mapbender/http/plugins/mb_digitize_widget.php 2014-05-08 14:13:01 UTC (rev 8830)
+++ trunk/mapbender/http/plugins/mb_digitize_widget.php 2014-05-08 14:31:32 UTC (rev 8831)
@@ -170,23 +170,33 @@
$('#mapframe1').bind('kml:loaded', function(evt, item) {
var url = item.url;
$('li[title="' + url + '"] > a').live('contextmenu', function() {
+ var $link = $(this);
var menu = $(folderMenu);
$(document.body).append(menu);
- var pos = $(this).offset();
+ var pos = $link.offset();
menu.css({position: 'absolute', top: pos.top, left: pos.left}).menu()
.children().addClass('ui-menu-item')
.hover(function() {$(this).addClass('ui-state-hover'); },
function() {$(this).removeClass('ui-state-hover'); });
+ menu.children('li:has(.digitize-zoomto)').bind('click', function() {
+ $link.click();
+ menu.menu('destroy').remove();
return false;
$('li[title="' + url + '"] > ul > li').live('contextmenu', function() {
var menu = $(geomMenu);
+ $link.click();
return false;
More information about the Mapbender_commits
