[Mapbender-commits] r8834 - trunk/mapbender/cors_proxy/http
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu May 8 07:52:35 PDT 2014
Author: armin11
Date: 2014-05-08 07:52:35 -0700 (Thu, 08 May 2014)
New Revision: 8834
   trunk/mapbender/cors_proxy/http/index.php
Modified: trunk/mapbender/cors_proxy/http/index.php
--- trunk/mapbender/cors_proxy/http/index.php	2014-05-08 14:46:34 UTC (rev 8833)
+++ trunk/mapbender/cors_proxy/http/index.php	2014-05-08 14:52:35 UTC (rev 8834)
@@ -27,6 +27,7 @@
 $width = 400;
 $height = 400;
 $tmpSession = false;
+$corsAllowedFor = false;
 //parse url
 $query = new QueryHandler();
 $reqParams = $query->getRequestParams();
@@ -71,6 +72,8 @@
 	$CORS_WHITELIST_array = explode(" ",CORS_WHITELIST);
 	if (!in_array($originFromHeader,$CORS_WHITELIST_array)) {
 		throwExceptionXml('','Server not found in whitelist of cors_proxy, please check your configuration!');
+	} else {
+		$corsAllowedFor = $originFromHeader;
 } else {
 	throwExceptionXml('','Mapbenders cors_proxy has no whitelist defined, check your configuration!');
@@ -185,10 +188,14 @@
  * @param string the original url of the image to send
 function getImage($or){
-	global $reqParams;
+	global $reqParams, $corsAllowedFor;
 	header("Content-Type: ".$reqParams['format']);
 	//set cors header
-	header('Access-Control-Allow-Origin: '.CORS_WHITELIST);
+	if ($corsAllowedFor != false) {
+		header('Access-Control-Allow-Origin: '.$corsAllowedFor);
+	} else {
+		header('Access-Control-Allow-Origin: '."");
 	//log the image_requests to database
 	//log the following to table mb_proxy_log
 	//timestamp,user_id,getmaprequest,amount pixel,price - but do this only for wms to log - therefor first get log tag out of wms!
@@ -246,10 +253,15 @@
 function responseImage($im){
 	$format = $reqParams['format'];
 	$format="image/gif";
+	} else {
 	if($format == 'image/png'){header("Content-Type: image/png");}
 	if($format == 'image/jpeg' || $format == 'image/jpg'){header("Content-Type: image/jpeg");}
 	if($format == 'image/gif'){header("Content-Type: image/gif");}
More information about the Mapbender_commits mailing list
