[Mapbender-commits] r8855 - in trunk/mapbender/http: plugins widgets
svn_mapbender at osgeo.org
Tue May 13 06:32:35 PDT 2014
Author: hwbllmnn
Date: 2014-05-13 06:32:35 -0700 (Tue, 13 May 2014)
New Revision: 8855
trunk/mapbender/http/plugins/mb_digitize_widget.php
trunk/mapbender/http/widgets/w_digitize.js
highlight vertices of edited features
Modified: trunk/mapbender/http/plugins/mb_digitize_widget.php
--- trunk/mapbender/http/plugins/mb_digitize_widget.php 2014-05-13 12:10:33 UTC (rev 8854)
+++ trunk/mapbender/http/plugins/mb_digitize_widget.php 2014-05-13 13:32:35 UTC (rev 8855)
@@ -140,6 +140,7 @@
inProgress = false,
title = o.title,
digitizingFor = '',
+ editedFeature = null,
status = 'none';
var create = function() {
@@ -218,47 +219,7 @@
kml.zoomToFeature(url, $link.attr('idx'));
menu.menu('destroy').remove();
- menu.children('li:has(.digitize-pencil)').bind('click', function() {
- $link.addClass('kmltree-selected').siblings().removeClass('kmltree-selected');
- var idx = $link.attr('idx');
- var kml = $('#mapframe1').data('kml');
- var url = $link.parent().parent().attr('title');
- var feature = kml._kmls[url].data.features[idx];
- editDialog.find('span').text(feature.properties.title);
- editDialog.dialog('open');
- editDialog.find('.digitize-attributes').bind('click', function() {
- attributesDialog.dialog('open');
- var rows = '';
- $.each(feature.properties, function(k, v) {
- if(k.match(/Mapbender:/)) return;
- rows += '<tr><td>' + k + '</td><td><input type="text" name="' + k + '" value="' + v + '"></input></td></tr>';
- attributesDialog.find('table').html(rows);
- attributesDialog.find('.digitize-add').bind('click', function() {
- var newRow = $('<tr><td><input type="text"></input></td><td><input type="text"></input></td></tr>');
- attributesDialog.find('table').append(newRow);
- newRow.find('input').first().bind('change', function() {
- newRow.find('input').last().attr('name', $(this).val());
- attributesDialog.find('.digitize-save').bind('click', function() {
- attributesDialog.find('table input').each(function() {
- var k = $(this).attr('name');
- var v = $(this).val();
- if(k) {
- feature.properties[k] = v;
- attributesDialog.dialog('close');
- editDialog.dialog('close');
- kml.refresh(url);
- editDialog.find('.digitize-pencil').bind('click', function() {
- $(this).next().toggleClass('digitize-hidden');
- menu.menu('destroy').remove();
+ menu.children('li:has(.digitize-pencil)').bind('click', editObject($link, menu));
menu.children('li:has(.digitize-remove)').bind('click', function() {
@@ -276,6 +237,60 @@
return false;
+ var editAttributes = function(feature, kml, url) {
+ return function() {
+ attributesDialog.dialog('open');
+ var rows = '';
+ $.each(feature.properties, function(k, v) {
+ if(k.match(/Mapbender:/)) return;
+ rows += '<tr><td>' + k + '</td><td><input type="text" name="' + k + '" value="' + v + '"></input></td></tr>';
+ attributesDialog.find('table').html(rows);
+ attributesDialog.find('.digitize-add').bind('click', function() {
+ var newRow = $('<tr><td><input type="text"></input></td><td><input type="text"></input></td></tr>');
+ attributesDialog.find('table').append(newRow);
+ newRow.find('input').first().bind('change', function() {
+ newRow.find('input').last().attr('name', $(this).val());
+ attributesDialog.find('.digitize-save').bind('click', function() {
+ attributesDialog.find('table input').each(function() {
+ var k = $(this).attr('name');
+ var v = $(this).val();
+ if(k) {
+ feature.properties[k] = v;
+ attributesDialog.dialog('close');
+ editDialog.dialog('close');
+ kml.refresh(url);
+ var editObject = function($link, menu) {
+ $link.addClass('kmltree-selected').siblings().removeClass('kmltree-selected');
+ var idx = $link.attr('idx');
+ var kml = $('#mapframe1').data('kml');
+ var url = $link.parent().parent().attr('title');
+ var feature = kml._kmls[url].data.features[idx];
+ editDialog.find('span').text(feature.properties.title);
+ editDialog.dialog('open');
+ editDialog.find('.digitize-attributes').bind('click', editAttributes(feature, kml, url));
+ editDialog.find('.digitize-pencil').bind('click', function() {
+ $(this).next().toggleClass('digitize-hidden');
+ status = 'edit-point';
+ digitizingFor = url;
+ editedFeature = feature;
+ that.activate();
+ menu.menu('destroy').remove();
var contextmenuLayer = function() {
var $link = $(this);
var menu = $(folderMenu);
@@ -371,13 +386,23 @@
this.activate = function () {
- if (o.$target.size() > 0) {
- o.type = status.match(/new-(.+)/)[1];
- o.$target
- .mb_digitize(o)
-// .bind("mb_digitizepointadded", newPoint)
- .bind("mb_digitizelastpointadded", finishDigitize)
- .bind("mb_digitizereinitialize", reinitializeDigitize);
+ var mode = status.match(/(new|edit)-.+/)[1];
+ if(mode === 'new') {
+ if (o.$target.size() > 0) {
+ o.type = status.match(/new-(.+)/)[1];
+ o.$target
+ .mb_digitize(o)
+ .bind("mb_digitizelastpointadded", finishDigitize)
+ .bind("mb_digitizereinitialize", reinitializeDigitize);
+ } else {
+ if(o.$target.size() > 0) {
+ o.type = status.match(/edit-(.+)/)[1];
+ o.editedFeature = editedFeature;
+ o.$target
+ .mb_digitize(o);
if (!inProgress) {
inProgress = true;
Modified: trunk/mapbender/http/widgets/w_digitize.js
--- trunk/mapbender/http/widgets/w_digitize.js 2014-05-13 12:10:33 UTC (rev 8854)
+++ trunk/mapbender/http/widgets/w_digitize.js 2014-05-13 13:32:35 UTC (rev 8855)
@@ -15,7 +15,8 @@
pointStrokeDefault: "#FC3",
pointStrokeSnapped: "#F30",
pointStrokeWidthDefault: 2,
- type: null
+ type: null,
+ editedFeature: null
_digitizePoints: [],
_map: undefined,
@@ -393,18 +394,34 @@
this._digitizePoints = [];
this._canvas.clear();
- // if(this.options.type === 'point') {
- // this.element
- // .bind("click", $.proxy(this, "_addPoint"))
- // .css("cursor", "crosshair");
- // } else {
+ if(this.options.editedFeature) {
+ this._digitizePoints = this.coordinatesToDigitizePoints(this.options.editedFeature.geometry.coordinates);
+ this._redraw();
+ } else {
this.element
.bind("mousemove", $.proxy(this, "_digitize"))
+ coordinatesToDigitizePoints: function(coords) {
+ var map = $('#mapframe1').mapbender();
+ if($.isArray(coords[0])) {
+ var pts = [];
+ $.each(coords, function(_, v) {
+ var pos = {x: v[0], y: v[1]};
+ var mousePos = map.convertRealToPixel(pos);
+ pts.push({pos: pos, mousePos: mousePos});
+ return pts;
+ } else {
+ var pos = {x: coords[0], y: coords[1]};
+ return [{pos: pos, mousePos: mousePos}];
_create: function () {
More information about the Mapbender_commits
