[Mapbender-commits] r8857 - in trunk/mapbender/http: plugins widgets
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue May 13 07:45:18 PDT 2014
Author: hwbllmnn
Date: 2014-05-13 07:45:18 -0700 (Tue, 13 May 2014)
New Revision: 8857
   trunk/mapbender/http/plugins/mb_digitize_widget.php
   trunk/mapbender/http/widgets/w_digitize.js
added moving of geometries
Modified: trunk/mapbender/http/plugins/mb_digitize_widget.php
--- trunk/mapbender/http/plugins/mb_digitize_widget.php	2014-05-13 14:07:03 UTC (rev 8856)
+++ trunk/mapbender/http/plugins/mb_digitize_widget.php	2014-05-13 14:45:18 UTC (rev 8857)
@@ -282,11 +282,28 @@
                 $(this).next().toggleClass('digitize-hidden');
-            status = 'edit-point';
+            status = 'edit-' + feature.geometry.type.toLowerCase();
+            if(status === 'edit-linestring') {
+                // TODO consolidate this
+                status = 'edit-line';
             digitizingFor = url;
             editedFeature = feature;
             that.activate();
+            editDialog.find('.digitize-move').bind('click', function() {
+                o.$target.mb_digitize('moveMode');
+            editDialog.find('.digitize-add-vertex').bind('click', function() {
+                o.$target.mb_digitize('addVertexMode');
+            editDialog.find('.digitize-move-vertex').bind('click', function() {
+                o.$target.mb_digitize('moveVertexMode');
+            editDialog.find('.digitize-delete-vertex').bind('click', function() {
+                o.$target.mb_digitize('deleteVertexMode');
             menu.menu('destroy').remove();
@@ -385,6 +402,21 @@
         that.activate();
+    var featureMoved = function() {
+        var kml = $('#mapframe1').data('kml');
+        var digit = o.$target.data('mb_digitize');
+        var pts = digit._digitizePoints;
+        if(status === 'edit-point') {
+            editedFeature.geometry.coordinates = [pts[0].pos.x, pts[0].pos.y];
+        } else {
+            editedFeature.geometry.coordinates = [];
+            $.each(pts, function(_, v) {
+                editedFeature.geometry.coordinates.push([v.pos.x, v.pos.y]);
+        kml.refresh(digitizingFor);
     this.activate = function () {
         var mode = status.match(/(new|edit)-.+/)[1];
@@ -401,7 +433,8 @@
                 o.type = status.match(/edit-(.+)/)[1];
                 o.editedFeature = editedFeature;
                 o.$target
-                .mb_digitize(o);
+                .mb_digitize(o)
+                .bind('mb_digitizefeaturemoved', featureMoved);
         if (!inProgress) {
Modified: trunk/mapbender/http/widgets/w_digitize.js
--- trunk/mapbender/http/widgets/w_digitize.js	2014-05-13 14:07:03 UTC (rev 8856)
+++ trunk/mapbender/http/widgets/w_digitize.js	2014-05-13 14:45:18 UTC (rev 8857)
@@ -405,6 +405,65 @@
+    pointFromEvent: function(e) {
+        var mousePos = this._map.getMousePosition(e);
+        return {
+            mousePos: mousePos,
+            pos: this._map.convertPixelToReal(mousePos)
+    startMoving: function(e) {
+        this.moving = true;
+        this.moveStartPoint = this.pointFromEvent(e);
+        this.originalDigitizePoints = this._digitizePoints;
+    move: function(e) {
+        if(this.moving) {
+            var self = this;
+            var pt = this.pointFromEvent(e);
+            var diff = {
+                mousePos: {
+                    x: this.moveStartPoint.mousePos.x - pt.mousePos.x,
+                    y: this.moveStartPoint.mousePos.y - pt.mousePos.y
+                pos: {
+                    x: this.moveStartPoint.pos.x - pt.pos.x,
+                    y: this.moveStartPoint.pos.y - pt.pos.y
+            this._digitizePoints = [];
+            $.each(this.originalDigitizePoints, function(_, v) {
+                self._digitizePoints.push({
+                    mousePos: {
+                        x: v.mousePos.x - diff.mousePos.x,
+                        y: v.mousePos.y - diff.mousePos.y
+                    pos: {
+                        x: v.pos.x - diff.pos.x,
+                        y: v.pos.y - diff.pos.y
+            this._redraw();
+    stopMoving: function(e) {
+        this.moving = false;
+        this._trigger("featuremoved", e);
+    moveMode: function() {
+        this.element
+            .bind("mousedown", $.proxy(this, 'startMoving'))
+            .bind("mousemove", $.proxy(this, 'move'))
+            .bind('mouseup', $.proxy(this, 'stopMoving'))
+            .css("cursor", "crosshair");
     coordinatesToDigitizePoints: function(coords) {
         var map = $('#mapframe1').mapbender();
         if($.isArray(coords[0])) {
More information about the Mapbender_commits mailing list
