[Mapbender-commits] r8865 - in trunk/mapbender: http/css http/plugins lib
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu May 15 04:10:13 PDT 2014
Author: hwbllmnn
Date: 2014-05-15 04:10:13 -0700 (Thu, 15 May 2014)
New Revision: 8865
   trunk/mapbender/http/css/digitize_new.css
   trunk/mapbender/http/plugins/mb_digitize_widget.php
   trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
added preview of style, cleaned up
Modified: trunk/mapbender/http/css/digitize_new.css
--- trunk/mapbender/http/css/digitize_new.css	2014-05-15 07:57:54 UTC (rev 8864)
+++ trunk/mapbender/http/css/digitize_new.css	2014-05-15 11:10:13 UTC (rev 8865)
@@ -151,3 +151,8 @@
 .digitize-hidden {
     display: none;
+.digitize-preview {
+    width: 40px;
+    height: 40px;
Modified: trunk/mapbender/http/plugins/mb_digitize_widget.php
--- trunk/mapbender/http/plugins/mb_digitize_widget.php	2014-05-15 07:57:54 UTC (rev 8864)
+++ trunk/mapbender/http/plugins/mb_digitize_widget.php	2014-05-15 11:10:13 UTC (rev 8865)
@@ -81,7 +81,7 @@
         '</fieldset></div>';
     var editHtml = '<div title="Edit feature">' +
-        '<div class="digitize-image digitize-polygon"></div>' +
+        '<div class="digitize-preview"></div>' +
         '<span>my polygon</span><br></br>' +
         '<div class="digitize-image digitize-style"></div>' +
         '<div class="digitize-image digitize-attributes"></div>' +
@@ -268,23 +268,6 @@
-    var renderStylePreview = function(feature, target) {
-        var canvas = Raphael(target, 32, 32);
-        switch(feature.geometry.type.toLowerCase()) {
-            case 'point':
-            canvas.image(markerSymbol, 0, 0, 32, 32);
-            break;
-            case 'linestring':
-            var line = 'M 10 20 L 20 10';
-            canvas.path(line).attr(feature.properties);
-            break;
-            case 'polygon':
-            var poly = 'M 10 10 L 10 20 20 20 20 10 Z';
-            canvas.path(poly).attr(feature.properties);
-            break;
     var editObject = function($link, menu) {
         return function() {
             $link.addClass('kmltree-selected').siblings().removeClass('kmltree-selected');
@@ -320,6 +303,8 @@
             editDialog.find('.digitize-delete-vertex').bind('click', function() {
                 o.$target.mb_digitize('deleteVertexMode');
+            var preview = editDialog.find('.digitize-preview').html('').get(0);
+            kml.renderPreview(feature, preview);
             menu.menu('destroy').remove();
Modified: trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
--- trunk/mapbender/lib/mb.ui.displayKmlFeatures.js	2014-05-15 07:57:54 UTC (rev 8864)
+++ trunk/mapbender/lib/mb.ui.displayKmlFeatures.js	2014-05-15 11:10:13 UTC (rev 8865)
@@ -76,138 +76,9 @@
                 $('li[title="' + self.queriedLayer + '"] li[idx="' + matchedIds[0] + '"]').click();
-/*        this.element.bind('click', function(e){
-            var map = self.element.mapbender();
-            var pos = map.getMousePosition(e);
-            var clickPoint =  map.convertPixelToReal(new Point(pos.x,pos.y));
-            var feed = null;
-            var requestGeometries = [];
-            // This uses two methods to determine wether a clickposition is on a geometry
-            // - Points are represented as icons, so we check if the click is on an icon
-            // - Polygons don't have a dom Element when not using Rapheljs, so we go ask postgis
-            // after that's finished the results are merged and displayed in a box
-            var pointGeometries = {};
-            var g,h,nodes = null;
-            $("*",self._popup).remove();
-            var $tabs = $("<ul></ul>");
-            for (var i in self.kmlOrder){
-                feed = self._kmls[self.kmlOrder[i]] ;
-                if(!feed.display){ continue; }
-                requestGeometries = [];
-                for(var j = 0; j < feed.geomArray.count(); j++){
-                    g = feed.geomArray.get(j);
-                    h = feed.highlightArray[j];
-                    nodes = h.getNodes();
-                    if(g.geomType == geomType.point){
-                        // we only add one point per highlight so we can assume there's only one node
-                        if(!nodes[0]){ continue;}
-                        var rect = nodes[0].getBoundingClientRect();
-                        if(e.clientX >= rect.left && e.clientX <= rect.right &&
-                           e.clientY >= rect.top  && e.clientY <= rect.bottom){
-                            // we just need the keys to exist
-                            // theywill be merged with the ones coming from the
-                            // server
-                            pointGeometries[j] = true;
-                    }else{
-                        requestGeometries.push(g.toText());
-                var req = new Mapbender.Ajax.Request({
-                    url: "../php/intersection.php",
-                    method: "intersect",
-                    parameters: {
-                        clickPoint:	clickPoint.toText(),
-                        geometries: requestGeometries
-                    callback: (function(geomArray,pointGeometries){ return function(result, success, message){
-        if(!success){
-        return;
-        // this is basically an onclick handler, !intersects means
-        // the click didn't happen on the polygon
-        $.extend(result.geometries,pointGeometries);
-        if(!result.geometries || result.geometries.length <1){
-        return;
-        // this iterates over an object where the keys are _not_ the incremential
-        // basically a sparse array. therefore It cannot be used to count the entries in the object
-        // this is why j is used
-        for(i in result.geometries){
-        var g = geomArray.get(i);
-        title = g.e.getElementValueByName("title");
-        name  = g.e.getElementValueByName("name");
-        if(typeof(name) == "string"){
-        title = name != "false" ? name : title;
-        if (icon == "false"){
-        g.e.setElement("Mapbender:icon","../img/marker/red.png");
-        }else{
-        //sane browsers go here
-        title = name != false ? name : title;
-        if (icon === false){
-        description = g.e.getElementValueByName("description");
-        $tabs.append('<li><a href="#rsspopup_'+ i +'">'+ title + '</a></li>');
-        self._popup.append('<div id="rsspopup_'+ i +'"><h1>'+ title +'</h1><p>'+ description +'</p></h1>');
-        if($tabs.children().size() > 1){
-        self._popup.dialog('open');
-        var $tabcontainer = $("<div><div>");
-        $tabcontainer.append($tabs);
-        $tabcontainer.append($('div',self._popup));
-        $tabs.css("display","none");
-        self._popup.append($tabcontainer);
-        $tabcontainer.tabs();
-        // -1 because we need it zero based later
-        var tabcount = $tabcontainer.find(".ui-tabs-panel").size() -1;
-        $tabcontainer.find(".ui-tabs-panel").each(function(i){
-        var  $navbar = $("<div></div>");
-        $(this).append($navbar);
-        // add to first panel
-        if(i == 0 ){
-        var next = i+1;
-        $navbar.append('<a style="float:right;" href="#" class="next-tab" rel="'+next+'">mehr</a>');
-        // add to all except the first panel
-        if(i > 0 ){
-        var prev = i-1;
-        $navbar.append('<a href="#" class="prev-tab" rel="'+prev+'">zurück</a>');
-        // add to all except first and last panel
-        if( tabcount  > i && i > 0  ){
-        var next = i+1;
-        $navbar.append('<a style="float:right;" href="#" class="next-tab" rel="'+next+'">vor</a>');
-        $tabcontainer.find(".next-tab, .prev-tab").click(function(){
-        $tabcontainer.tabs("select",$(this).attr("rel"));
-        return false;
-        };})(feed.geomArray, pointGeometries)
-                req.send();
-                pointGeometries = {};
         self.element.bind('kml:loaded',function(event,obj){
             if(o.autoOpen){
                 self.render();
-                //self._display(obj);
         self.element.bind('kml:error',function(event,message){
@@ -221,7 +92,6 @@
             this._kmls = kmls;
             for(var k in kmls) {
                 kmls[k].loadedOnStartup = true;
-                self._convertFromJson(kmls[k]);
                 self.element.trigger('kml:loaded',kmls[k]);
@@ -325,7 +195,6 @@
         h.add(geom);
         itm.data.features.push(JSON.parse(multi.toString()));
-        this._convertFromJson(itm);
         this.element.trigger('kml:loaded',{type:"geojson",data:itm.data,url:itm.url,display: itm.display, refreshing: true});
         $map.setMapRequest();
@@ -333,7 +202,6 @@
     refresh: function(url) {
         var $map = $(this.element).mapbender();
         var itm = this._kmls[url];
@@ -425,7 +293,6 @@
             list.push(itm.data.features[v]);
         itm.data.features = list;
@@ -459,97 +326,6 @@
-    _convertFromJson: function(mapitem) {
-        // var geojson = mapitem.data;
-        // var self = this;
-        // var $map = $(self.element).mapbender();
-        // var markers = [];
-        // var title = "";
-        // we always transform _from_ 4326 KML use this as their default
-        // var projSrc = new Proj4js.Proj('EPSG:4326');
-        // var projDest = new Proj4js.Proj($map.epsg);
-        // var markeroptions = {width: "19px", height: "34px"};
-        // var g = null;
-        // for(var i in mapitem.highlightArray){
-        //     var h = mapitem.highlightArray[i].hide;
-        //     if(h) h();
-        // mapitem.geomArray = new GeometryArray();
-        // mapitem.highlightArray = [];
-        // mapitem.geomArray.importGeoJSON(geojson);
-        //get bbox for array
-        // var bbox = mapitem.geomArray.getBBox();
-        // var bufferFloat = parseFloat(0.1);
-        // var buffer = new Point(bufferFloat,bufferFloat);
-        // bbox[0] = bbox[0].minus(buffer);
-        // bbox[1] = bbox[1].plus(buffer);
-        // for(i =0; i < mapitem.geomArray.count(); i++){
-        //     var elemid = "mapframe1_" + parseInt(Math.random()*100000, 10);
-        //     var h = new Highlight([self.element.attr('id')], elemid,{
-        //         "position":"absolute",
-        //         "top": "0px",
-        //         "left": "0px",
-        //         "z-index": "80" },1);
-        //     $('#mapframe1').children('*[id*="' + elemid + '"]').attr('data-idx', i)
-        //         .attr('data-url', mapitem.url);
-        //     g = mapitem.geomArray.get(i);
-        //     icon = g.e.getElementValueByName("Mapbender:icon");
-        //     //title = g.e.getElementValueByName("title");
-        //     name = g.e.getElementValueByName("name");
-        //     if(name != "false" && name !== false){
-        //         title = name; // use for tooltip
-        //     if(icon == "false" || icon === false){
-        //         g.e.setElement("Mapbender:iconOffsetX", -10);
-        //         g.e.setElement("Mapbender:iconOffsetY", -34);
-        //         g.e.setElement("Mapbender:icon","../img/marker/red.png");
-        //     h.add(g);
-        //     mapitem.highlightArray.push(h);
-        //     title = "";
-        //     name = "";
-        // if(mapitem.display){
-        //     for(var j in mapitem.highlightArray){
-        //         if(mapitem.data.features[j].display !== false) {
-        //             mapitem.highlightArray[j].paint();
-        // }else{
-        //         mapitem.highlightArray[j].hide();
-        // self.element.mapbender().events.afterMapRequest.register(function () {
-        //     self.render();
-        //     // if(mapitem.display){
-        //     //     for(var i in mapitem.highlightArray){
-        //     //         if(mapitem.data.features[i].display !== false) {
-        //     //             mapitem.highlightArray[i].paint();
-        //     // }else{
-        //     //         mapitem.highlightArray[i].hide();
-        // set new bbox for mapframe
-        // if(!mapitem.loadedOnStartup) {
-        //     $map.calculateExtent(
-        //         new Mapbender.Extent(bbox[0], bbox[1])
     getLayerBbox: function(url) {
         var self = this;
@@ -568,7 +344,7 @@
             case 'point':
             var map = $(this.element).mapbender();
-            var res = map.getScale() / mb_resolution / 100;
+            var res = 10;
             var minx = feature.geometry.coordinates[0] - 20 * res;
             var miny = feature.geometry.coordinates[1] - 20 * res;
             return [minx, miny, minx + 40 * res, miny + 40 * res];
@@ -609,6 +385,9 @@
                   y: feature.geometry.coordinates[1]};
         if(isNaN(pt.x) || isNaN(pt.y)) return;
         pt = $('#mapframe1').mapbender().convertRealToPixel(pt);
+        if(feature.preview) {
+            pt = {x: feature.geometry.coordinates[0], y: feature.geometry.coordinates[1]};
         if(feature.properties['Mapbender:icon']) {
             var img = canvas.image(feature.properties['Mapbender:icon'], pt.x, pt.y, 32, 32).node;
             if(img.setAttributeNS) {
@@ -625,6 +404,9 @@
         var path;
         $.each(feature.geometry.coordinates, function(_, v) {
             var pt = map.convertRealToPixel({x: v[0], y: v[1]});
+                pt = {x: v[0], y: v[1]};
             if(!path) {
                 path = 'M' + pt.x + ' ' + pt.y;
@@ -642,6 +424,9 @@
         var path;
         $.each(feature.geometry.coordinates[0], function(_, v) {
             if(!path) {
@@ -663,7 +448,6 @@
                 self.renderPoint(canvas, feature);
                 break;
                 case 'linestring':
-                var line = 'M';
                 self.renderLine(canvas, feature);
                 break;
                 case 'polygon':
@@ -673,6 +457,32 @@
+    renderPreview: function(feature, target) {
+        var canvas = Raphael(target, 40, 40);
+        var feat = {
+            geometry: {
+                type: feature.geometry.type
+            properties: feature.properties,
+            preview: true
+        switch(feature.geometry.type.toLowerCase()) {
+            case 'point':
+            feat.geometry.coordinates = [0, 0];
+            break;
+            case 'linestring':
+            feat.geometry.coordinates = [[5, 35], [35, 5]];
+            break;
+            case 'polygon':
+            feat.geometry.coordinates = [[[5, 5], [5, 35], [35, 35], [35, 5]]];
+            break;
+        this.renderFeature(canvas)(null, feat);
     render: function() {
         var target = $('#kml-rendering-pane');
         var map = $('#mapframe1').mapbender();
@@ -688,15 +498,6 @@
                 $.each(item.data.features, $.proxy(self, self.renderFeature(canvas)));
-    _display : function(mapitem){
-        var self = this, o = this.options;
-        // getting the mapitem from the events bre
-        mapitem = self._kmls[mapitem.url];
-        if(typeof(Mapbender) != "undefined"){
-            this._convertFromJson(mapitem);
@@ -706,19 +507,4 @@
     _eventNamespace : "kml"
 $.widget('ui.kml',displayKML);
-var displayGeoJSON = $.extend({},displayFeatures,{
-    _endpointURL: "",
-    _load: function(){
-        $.ajax({ url: o.url,
-                 type: "GET",
-                 dataType: "json",
-                 success : function(data,textStatus,xhr){
-                     self._display(data);
 $.widget('ui.geojson',displayKML);
More information about the Mapbender_commits mailing list
