[Mapbender-commits] r8896 - in trunk/mapbender/http: plugins widgets
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed May 21 08:03:09 PDT 2014
Author: hwbllmnn
Date: 2014-05-21 08:03:09 -0700 (Wed, 21 May 2014)
New Revision: 8896
   trunk/mapbender/http/plugins/mb_digitize_widget.php
   trunk/mapbender/http/widgets/w_digitize.js
cleaned up event handling when modifying geometries' vertices
Modified: trunk/mapbender/http/plugins/mb_digitize_widget.php
--- trunk/mapbender/http/plugins/mb_digitize_widget.php	2014-05-21 14:10:59 UTC (rev 8895)
+++ trunk/mapbender/http/plugins/mb_digitize_widget.php	2014-05-21 15:03:09 UTC (rev 8896)
@@ -500,8 +500,12 @@
         //digit.modeOff();
         var pts = $.extend(true, {}, digit._digitizePoints);
         $.each(pts, function(_, v) {
+            if(!$.isPlainObject(v.pos)) {
+                v.pos = {x: v.pos.x, y: v.pos.y};
             Proj4js.transform(kml.targetProj, kml.wgs84, v.pos);
         if(status === 'edit-point') {
             editedFeature.geometry.coordinates = [pts[0].pos.x, pts[0].pos.y];
         } else if(status === 'edit-line') {
@@ -527,6 +531,8 @@
                 o.editedFeature = null;
                 o.$target
                     .mb_digitize(o)
+                    .mb_digitize('modeOff')
+                    .mb_digitize('startDigitizing')
                     .unbind('mb_digitizelastpointadded')
                     .unbind('mb_digitizereinitialize')
                     .bind("mb_digitizelastpointadded", finishDigitize)
@@ -538,6 +544,7 @@
                 o.editedFeature = editedFeature;
                 o.$target
                 .mb_digitize(o)
                 .unbind('mb_digitizefeaturemodified')
                 .bind('mb_digitizefeaturemodified', featureModified);
Modified: trunk/mapbender/http/widgets/w_digitize.js
--- trunk/mapbender/http/widgets/w_digitize.js	2014-05-21 14:10:59 UTC (rev 8895)
+++ trunk/mapbender/http/widgets/w_digitize.js	2014-05-21 15:03:09 UTC (rev 8896)
@@ -416,19 +416,26 @@
             this._digitizePoints = this.coordinatesToDigitizePoints(this.options.editedFeature.geometry.coordinates);
             this._redraw();
         } else {
-            this.element
-                .bind("click", $.proxy(this, "_addPoint"))
-                .bind("mousemove", $.proxy(this, "_digitize"))
-                .css("cursor", "crosshair");
+            this.startDigitizing();
+    startDigitizing: function() {
+        this.element
+            .bind("click", $.proxy(this, "_addPoint"))
+            .bind("mousemove", $.proxy(this, "_digitize"))
+            .css("cursor", "crosshair");
     pointFromEvent: function(e) {
         var mousePos = this._map.getMousePosition(e);
+        var kml = $('#mapframe1').data('kml');
+        var pos = this._map.convertPixelToReal(mousePos);
         return {
             mousePos: mousePos,
-            pos: this._map.convertPixelToReal(mousePos)
+            pos: pos
@@ -531,9 +538,9 @@
     addVertexMode: function() {
+        this.modeOff();
         this.addingVertex = true;
         this.element
-            .unbind('mousedown').unbind('mousemove').unbind('mouseup')
             .bind('mousedown', $.proxy(this, 'addVertex'))
             .bind('mousemove', $.proxy(this, 'vertexMove'))
             .bind('mouseup', $.proxy(this, 'stopVertexMoving'))
@@ -555,15 +562,15 @@
     deleteVertexMode: function() {
+        this.modeOff();
         this.element
             .bind('mousedown', $.proxy(this, 'deleteVertex'))
             .css('cursor', 'crosshair');
     moveMode: function() {
+        this.modeOff();
         this.element
             .bind("mousedown", $.proxy(this, 'startMoving'))
             .bind("mousemove", $.proxy(this, 'move'))
             .bind('mouseup', $.proxy(this, 'stopMoving'))
@@ -572,7 +579,9 @@
     modeOff: function() {
         this.element
-            .unbind('mousedown').unbind('mousemove').unbind('mouseup');
+            .unbind('mousedown').unbind('mousemove').unbind('mouseup').unbind('click');
+        this.addingVertex = false;
+        this._redraw();
     coordinatesToDigitizePoints: function(coords) {
More information about the Mapbender_commits mailing list
