[Mapbender-commits] r8908 - trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org
Mon May 26 05:37:49 PDT 2014
Author: armin11
Date: 2014-05-26 05:37:48 -0700 (Mon, 26 May 2014)
New Revision: 8908
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql
Update mb_user_wmc to allow management of metadata for integrated geoJSON objects
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql 2014-05-26 12:32:42 UTC (rev 8907)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql 2014-05-26 12:37:48 UTC (rev 8908)
@@ -441,4 +441,28 @@
ALTER TABLE search_wms_view
OWNER TO postgres;
+-- Column: wmc_local_data_public
+-- ALTER TABLE mb_user_wmc DROP COLUMN wmc_local_data_public;
+ALTER TABLE mb_user_wmc ADD COLUMN wmc_local_data_public integer;
+UPDATE mb_user_wmc SET wmc_local_data_public = 0 WHERE wmc_local_data_public IS NULL;
+ALTER TABLE mb_user_wmc ALTER COLUMN wmc_local_data_public SET DEFAULT 0;
+-- Column: wmc_local_data_size
+-- ALTER TABLE mb_user_wmc DROP COLUMN wmc_local_data_size;
+ALTER TABLE mb_user_wmc ADD COLUMN wmc_local_data_size varchar(50);
+UPDATE mb_user_wmc SET wmc_local_data_size = '0' WHERE wmc_local_data_size IS NULL;
+ALTER TABLE mb_user_wmc ALTER COLUMN wmc_local_data_size SET DEFAULT '0';
+-- Column: wmc_has_local_data
+-- ALTER TABLE mb_user_wmc DROP COLUMN wmc_has_local_data;
+ALTER TABLE mb_user_wmc ADD COLUMN wmc_has_local_data integer;
+UPDATE mb_user_wmc SET wmc_has_local_data = 0 WHERE wmc_has_local_data IS NULL;
+ALTER TABLE mb_user_wmc ALTER COLUMN wmc_has_local_data SET DEFAULT 0;
More information about the Mapbender_commits
