[Mapbender-commits] r9126 - trunk/mapbender/conf
svn_mapbender at osgeo.org
Wed Nov 19 06:07:57 PST 2014
Author: armin11
Date: 2014-11-19 06:07:57 -0800 (Wed, 19 Nov 2014)
New Revision: 9126
trunk/mapbender/conf/atomFeedClient.conf-dist
Extract atomfeedclient extent to con file
Modified: trunk/mapbender/conf/atomFeedClient.conf-dist
--- trunk/mapbender/conf/atomFeedClient.conf-dist 2014-11-19 14:07:46 UTC (rev 9125)
+++ trunk/mapbender/conf/atomFeedClient.conf-dist 2014-11-19 14:07:57 UTC (rev 9126)
@@ -19,4 +19,7 @@
//metadata layer
$metadataPolygonLayer = "var wms222 = new OpenLayers.Layer.WMS( \"Exterior polygon from metadata\",
\"http://".$_SERVER['HTTP_HOST']."/cgi-bin/mapserv?map=/data/mapbender/tools/wms_extent/extents.map&metadata_uuid=\"+$('#dataset_identifier_link').attr('uuid'), {layers: 'metadata_polygon',transparent: \"true\",format: \"image/png\"}, {singleTile: true, isBaseLayer: false});";
+$olCentreLon = "7";
+$olCentreLat = "50";
+$olScale = "7";
More information about the Mapbender_commits
