[Mapbender-commits] r9105 -	trunk/mapbender/resources/locale/de_DE/LC_MESSAGES
    svn_mapbender at osgeo.org
    Tue Oct 21 04:41:11 PDT 2014
Author: armin11
Date: 2014-10-21 04:41:11 -0700 (Tue, 21 Oct 2014)
New Revision: 9105
   trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po
Better translation
Modified: trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po
--- trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po	2014-10-21 09:04:42 UTC (rev 9104)
+++ trunk/mapbender/resources/locale/de_DE/LC_MESSAGES/Mapbender.po	2014-10-21 11:41:11 UTC (rev 9105)
@@ -1,3694 +1,3693 @@
-# SOME DESCRIPTIVE TITLE.
-# Copyright (C) YEAR THE PACKAGE'S COPYRIGHT HOLDER
-# This file is distributed under the same license as the PACKAGE package.
-# FIRST AUTHOR <EMAIL at ADDRESS>, YEAR.
-#, fuzzy
-msgid ""
-msgstr ""
-"Project-Id-Version: PACKAGE VERSION\n"
-"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2011-07-29 15:31+0200\n"
-"PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
-"Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
-"Language-Team: LANGUAGE <LL at li.org>\n"
-"MIME-Version: 1.0\n"
-"Content-Type: text/plain; charset=UTF-8\n"
-"Content-Transfer-Encoding: 8bit\n"
-#: printPDF.conf:13
-msgid "Download: Map as PDF..."
-msgstr "Download: Karte als PDF..."
-#: printPDF.conf:26
-msgid "print legend"
-msgstr "Legende drucken"
-#: printPDF.conf:30
-msgid "Legend"
-msgstr "Legende"
-#: printPDF.conf:31
-msgid "powered by Mapbender"
-msgstr "mit Unterstützung von Mapbender"
-#: printPDF.conf:60
-msgid "Print preview"
-msgstr "Druckansicht"
-#: printPDF.conf:63
-msgid "Scale 1:"
-msgstr "Maßstab 1:"
-#: printPDF.conf:64
-msgid "Date:"
-msgstr "Datum:"
-#: printPDF.conf:66
-msgid "Notes:"
-msgstr "Notizen:"
-#: printPDF.conf:73
-msgid ""
-"This copy has been generated automatically and is valid without signature."
-msgstr "Der Auszug wurde maschinell erzeugt. Er ist ohne Unterschrift gültig."
-#: printPDF.conf:74
-msgid ""
-"This copy is protected by law (Par. 3 Abs. 1 VermKatG NW). It can be "
-"duplicated, modified, published or be passed to third parties only in "
-"agreement with"
-msgstr ""
-"Dieser Auszug ist gesetzlich geschützt (§ 3 Abs. 1 VermKatG NW). "
-"Vervielfältigungen, Umarbeitungen, Veröffentlichungen oder die Weitergabe an "
-"Dritte nur mit Zustimmung des"
-#: printPDF.conf:75
-msgid ""
-"the publisher, except duplicates and modifications aimed at internal use of "
-"government agencies or private use."
-msgstr ""
-"Herausgebers, ausgenommen Vervielfältigungen und Umarbeitungen zur "
-"innerdienstlichen Verwendung bei Behörden oder zum eigenen Gebrauch."
-#: printPDF.conf:
-msgid "This copy is protected by law (Par. 3 Abs. 1 VermKatG NW)."
-msgstr "Dieser Auszug ist gesetzlich geschützt (Par. 3 Abs. 1 VermKatG NW)."
-#: printPDF.conf:
-msgid ""
-"It can be duplicated, modified, published or be passed to third parties only "
-"in"
-msgstr ""
-"Umarbeitungen, Veröffentlichungen oder die Weitergabe an Dritte nur mit"
-#: printPDF.conf:
-msgid "agreement with the publisher except duplicates and modifications"
-msgstr ""
-"Zustimmung des Herausgebers, ausgenommen Vervielfältigungen und Umarbeitungen"
-#: printPDF.conf:
-msgid "aimed at internal use of government agencies or private use."
-msgstr ""
-"zur innerdienstlichen Verwendung bei Behörden oder zum eigenen Gebrauch."
-#: printPDF.conf:94
-msgid "Format"
-msgstr "Format"
-#: printPDF.conf:101
-msgid "Orientation"
-msgstr "Ausrichtung"
-#: printPDF.conf:102
-msgid "portrait"
-msgstr "Hochformat"
-#: printPDF.conf:103
-msgid "landscape"
-msgstr "Querformat"
-#: printPDF.conf:104
-msgid "Quality"
-msgstr "Qualität"
-#: printPDF.conf:105 printPDF.conf:106
-#, php-format
-msgid "Quality: %d dpi"
-msgstr "Qualität: %d dpi"
-#: printPDF.conf:108
-msgid "Comment"
-msgstr "Kommentar"
-msgid "max."
-msgstr "max."
-#: printPDF.conf:111 ../http/plugins/mb_print.php:229
-msgid "print"
-msgstr "drucken"
-#: mod_printPDF.php:
-msgid "No format selected"
-msgstr "Bitte wählen Sie ein Format aus"
-#: mod_digitize_messages.php:18 ../http/php/mod_digitize_messages.php:18
-msgid "polygon"
-msgstr "Polygon"
-#: mod_digitize_messages.php:19 ../http/php/mod_digitize_messages.php:19
-msgid "line"
-msgstr "Linie"
-#: mod_digitize_messages.php:20 ../http/php/mod_digitize_messages.php:20
-msgid "point"
-msgstr "Punkt"
-#: mod_digitize_messages.php:21 ../http/php/mod_digitize_messages.php:21
-msgid "Not an integer value."
-msgstr "Kein Integer-Wert."
-#: mod_digitize_messages.php:22 ../http/php/mod_digitize_messages.php:22
-msgid "Not a double value."
-msgstr "Kein Double-Wert."
-#: mod_digitize_messages.php:23 ../http/php/mod_digitize_messages.php:23
-msgid "This field may not be empty."
-msgstr "Das Feld darf nicht leer sein."
-#: mod_digitize_messages.php:24 ../http/php/mod_digitize_messages.php:24
-msgid "Failure during form evaluation."
-msgstr "Fehler bei der Formularauswertung."
-#: mod_digitize_messages.php:25 ../http/php/mod_gazetteerMetadata.php:138
-#: ../http/php/mod_gazetteerMetadata.php:201
-#: ../http/php/mod_gazetteerMetadata.php:212
-#: ../http/php/mod_digitize_messages.php:25
-#: ../http/php/mod_gazetteerMetadata.php:133
-#: ../http/php/mod_gazetteerMetadata.php:196
-#: ../http/php/mod_gazetteerMetadata.php:207
-msgid "An error occured."
-msgstr "Ein Fehler ist aufgetreten."
-#: mod_digitize_messages.php:26 ../http/php/mod_digitize_messages.php:26
-msgid ""
-"At least two geometries must be available. Only polygons are allowed in the "
-"geometry list."
-msgstr ""
-"Es müssen mindestens zwei Geometrien ausgewählt sein. Es sind nur Polygone "
-"erlaubt in der Geometrieliste."
-#: mod_digitize_messages.php:27 ../http/php/mod_digitize_messages.php:27
-msgid ""
-"Exactly two geometries must be available. The first geometry shall be a "
-"polygon or a line, the second geometry shall be a line."
-msgstr ""
-"Es müssen genau zwei Geometrien ausgewählt sein. Die erste Geometrie sollte "
-"ein Polygon oder eine Linie, die zweite Geometrie eine Linie sein."
-#: mod_digitize_messages.php:28 ../http/php/mod_digitize_messages.php:28
-msgid "Exactly two polygons must be available."
-msgstr "Es müssen genau zwei Polygone ausgewählt sein."
-#: mod_digitize_messages.php:29 ../http/php/mod_digitize_messages.php:29
-msgid "Exactly two lines must be available."
-msgstr "Es müssen genau zwei Linien ausgewählt sein."
-#: mod_digitize_messages.php:30 ../http/php/mod_digitize_messages.php:30
-msgid "Success."
-msgstr "Aktion erfolgreich beendet."
-#: mod_digitize_messages.php:31 ../http/php/mod_digitize_messages.php:31
-msgid "Delete geometry from database?"
-msgstr "Geometrie in der Datenbank löschen?"
-#: mod_digitize_messages.php:32 ../http/php/mod_digitize_messages.php:32
-msgid "Clear list of geometries?"
-msgstr "Soll die Geometrieliste wirklich geleert werden?"
-#: mod_digitize_messages.php:33 ../http/php/mod_digitize_messages.php:33
-msgid "Please select an entry."
-msgstr "Bitte treffen Sie eine Auswahl."
-#: mod_digitize_messages.php:34 ../http/php/mod_digitize_messages.php:34
-msgid "Save"
-msgstr "Speichern"
-#: mod_digitize_messages.php:35 ../http/php/mod_digitize_messages.php:35
-msgid "Update"
-msgstr "Aktualisieren"
-#: mod_digitize_messages.php:36 ../http/php/mod_customTree.php:230
-#: ../http/php/mod_digitize_messages.php:36
-msgid "Delete"
-msgstr "Löschen"
-#: mod_digitize_messages.php:37 ../http/php/mod_digitize_messages.php:37
-msgid "Abort"
-msgstr "Abbrechen"
-#: mod_digitize_messages.php:38 ../http/php/mod_digitize_messages.php:38
-msgid "Fatal error: EPSG mismatch. "
-msgstr "Schwerwiegender Fehler: ungleiche EPSGs."
-#: mod_digitize_messages.php:39 ../http/php/mod_digitize_messages.php:39
-msgid "No geometry selected!"
-msgstr "Keine Geometrie ausgewählt!"
-#: mod_digitize_messages.php:40 ../http/php/mod_digitize_messages.php:40
-msgid ""
-"No valid line geometries for merging! Please check start and end points of "
-"your lines."
-msgstr ""
-"Keine gültigen Geometrien zum Verbinden! Bitte Start- und Endpunkte der "
-"Linien prüfen."
-#: mod_digitize_messages.php:41 ../http/php/mod_digitize_messages.php:41
-msgid "add point"
-msgstr "Punkt hinzufügen"
-#: mod_digitize_messages.php:42 ../http/php/mod_digitize_messages.php:42
-msgid "cancel editing"
-msgstr "Editieren abbrechen"
-#: mod_digitize_messages.php:43 ../http/php/mod_digitize_messages.php:43
-msgid "add line"
-msgstr "Linie hinzufügen"
-#: mod_digitize_messages.php:44 mod_digitize_messages.php:46
-#: ../http/php/mod_digitize_messages.php:44
-#: ../http/php/mod_digitize_messages.php:46
-msgid "finish line"
-msgstr "Linie abschliessen"
-#: mod_digitize_messages.php:45 ../http/php/mod_digitize_messages.php:45
-msgid "continue line"
-msgstr "Linie erweitern"
-#: mod_digitize_messages.php:47 ../http/php/mod_digitize_messages.php:47
-msgid "add polygon"
-msgstr "Polygon hinzufügen"
-#: mod_digitize_messages.php:48 ../http/php/mod_digitize_messages.php:48
-msgid "close polygon"
-msgstr "Polygon schliessen"
-#: mod_digitize_messages.php:49 mod_digitize_messages.php:50
-#: ../http/php/mod_digitize_messages.php:49
-#: ../http/php/mod_digitize_messages.php:50
-msgid "move basepoint"
-msgstr "Stützpunkt verschieben"
-#: mod_digitize_messages.php:51 mod_digitize_messages.php:52
-#: ../http/php/mod_digitize_messages.php:51
-#: ../http/php/mod_digitize_messages.php:52
-msgid "Insert basepoint"
-msgstr "Stützpunkt einfügen"
-#: mod_digitize_messages.php:53 mod_digitize_messages.php:54
-#: ../http/php/mod_digitize_messages.php:53
-#: ../http/php/mod_digitize_messages.php:54
-msgid "Delete basepoint"
-msgstr "Stützpunkt löschen"
-#: mod_digitize_messages.php:55 mod_digitize_messages.php:56
-#: ../http/php/mod_digitize_messages.php:55
-#: ../http/php/mod_digitize_messages.php:56
-msgid "clear list of geometries"
-msgstr "Geometrieliste leeren"
-#: mod_digitize_messages.php:57 mod_digitize_messages.php:58
-#: ../http/php/mod_digitize_messages.php:57
-#: ../http/php/mod_digitize_messages.php:58
-msgid ""
-"Merge two polygons into a single polygon (will be added to the geometry list)"
-msgstr ""
-"Zwei Polygone zu einem Polygon zusammenfügen (wird der Geometrieliste "
-"hinzugefügt)."
-#: mod_digitize_messages.php:59 mod_digitize_messages.php:60
-#: ../http/php/mod_digitize_messages.php:59
-#: ../http/php/mod_digitize_messages.php:60
-msgid ""
-"Split a polygon/line by a line (the new polygons/lines will be added to the "
-"geometry list)"
-msgstr ""
-"Polygon/Linie zerschneiden mit Hilfe einer Linie (neue Polygone/Linien "
-"werden zur Geometrienliste hinzugefügt)"
-#: mod_digitize_messages.php:61 ../http/php/mod_digitize_messages.php:61
-msgid ""
-"Combine two polygons (to create en- and exclave or to compute the difference)"
-msgstr ""
-"Verbinde zwei Polygone (zum Erstellen von En- oder Exklaven oder zum "
-"Berechnen der Differenz)"
-#: mod_digitize_messages.php:62 ../http/php/mod_digitize_messages.php:62
-msgid "Split geometries"
-msgstr "Geometrien zerschneiden"
-#: mod_digitize_messages.php:63 mod_digitize_messages.php:64
-#: ../http/php/mod_digitize_messages.php:63
-#: ../http/php/mod_digitize_messages.php:64
-msgid "Merge two lines into a single line"
-msgstr "Zwei Linien zu einer Linie zusammenfügen."
-#: mod_digitize_messages.php:65 ../http/php/mod_digitize_messages.php:65
-msgid "save / update / delete"
-msgstr "speichern / aktualisieren / löschen"
-#: mod_digitize_messages.php:66 ../http/php/mod_digitize_messages.php:66
-msgid "remove from workspace"
-msgstr "aus der Liste entfernen"
-#: mod_digitize_messages.php:67 ../http/php/mod_digitize_messages.php:67
-msgid "remove from database"
-msgstr "aus der Datenbank löschen"
-#: mod_digitize_messages.php:68 ../http/php/mod_digitize_messages.php:68
-msgid "clone this geometry"
-msgstr "dupliziere diese Geometrie"
-#: mod_digitize_messages.php:69 ../http/php/mod_digitize_messages.php:69
-msgid "click the first basepoint to close the polygon"
-msgstr "Auf den ersten Stützpunkt klicken, um das Polygon zu schliessen"
-#: mod_digitize_messages.php:70 ../http/php/mod_digitize_messages.php:70
-msgid "Current: "
-msgstr "Letztes Segment: "
-#: mod_digitize_messages.php:71 ../http/php/mod_digitize_messages.php:71
-msgid "Total: "
-msgstr "Gesamtlänge: "
-#: mod_digitize_messages.php:72 ../http/php/mod_createCategory.php:118
-#: ../http/php/mod_digitize_messages.php:72
-msgid "new"
-msgstr "neu"
-#: mod_wfsSpatialRequest_messages.php:33
-#: ../http/php/mod_wfsSpatialRequest_messages.php:30
-msgid "select by rectangle"
-msgstr "Auswahl über Rechteck"
-#: mod_wfsSpatialRequest_messages.php:34
-#: ../http/php/mod_wfsSpatialRequest_messages.php:31
-msgid "select by polygon"
-msgstr "Auswahl über Polygon"
-#: mod_wfsSpatialRequest_messages.php:35
-#: ../http/php/mod_wfsSpatialRequest_messages.php:32
-msgid "select by point"
-msgstr "Auswahl über Punkt test"
-#: mod_wfsSpatialRequest_messages.php:36
-#: ../http/php/mod_wfsSpatialRequest_messages.php:33
-msgid "select by extent"
-msgstr "Auswahl über Extent"
-#: mod_wfsSpatialRequest_messages.php:37
-#: ../http/php/mod_wfsSpatialRequest_messages.php:34
-msgid "open dialogue form"
-msgstr "Auswahlfenster öffnen"
-#: mod_wfsSpatialRequest_messages.php:38
-#: ../http/php/mod_wfsSpatialRequest_messages.php:35
-msgid "Invalid box!"
-msgstr "Ausschnitt ungültig!"
-#: /html/mod_treefolder2.php:56 http/html/mod_treefolderPlain.php:34
-#: ../http/html/mod_treefolderPlain.php:33
-#: ../http/html/mod_treefolderPlain.php:32
-msgid "Toggles the visibility of this service"
-msgstr "Sichtbarkeit des Layers an/aus"
-#: /html/mod_treefolder2.php:57 http/html/mod_treefolderPlain.php:35
-#: ../http/html/mod_treefolderPlain.php:34
-msgid "Toggles the queryability of this service"
-msgstr "Infoabfrage an/aus"
-#: /html/mod_treefolder2.php:58 http/html/mod_treefolderPlain.php:36
-#: ../http/html/mod_treefolderPlain.php:35
-msgid "Opens the layer context menu"
-msgstr "Öffnet das Layer Kontextmenü"
-#: /html/mod_treefolder2.php:59 http/html/mod_treefolderPlain.php:37
-#: ../http/html/mod_treefolderPlain.php:36
-msgid "Opens the WMS context menu"
-msgstr "Öffnet das WMS Kontextmenü"
-#: /html/mod_treefolder2.php:60 http/html/mod_treefolderPlain.php:38
-#: ../http/html/mod_treefolderPlain.php:37
-msgid "Removes the selected WMS"
-msgstr "Entfernt den gewählten Dienst"
-#: /html/mod_treefolder2.php:61 http/html/mod_treefolderPlain.php:39
-#: ../http/html/mod_treefolderPlain.php:38
-msgid "Moves the selection up"
-msgstr "selektierten Dienst nach oben verschieben"
-#: /html/mod_treefolder2.php:62 http/html/mod_treefolderPlain.php:40
-#: ../http/html/mod_treefolderPlain.php:39
-msgid "Moves the selection down"
-msgstr "selektierten Dienst nach unten verschieben"
-#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:327
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:450
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:487
-msgid "WMS name"
-msgstr "WMS Name"
-#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:328
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:451
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:488
-msgid "WMS abstract"
-msgstr "WMS Beschreibung"
-#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:329
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:452
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:489
-msgid "Please select a WMS"
-msgstr "Bitte wählen Sie einen WMS aus"
-#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:330
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:453
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:490
-msgid "Please select an application"
-msgstr "Bitte wählen Sie eine Applikation aus"
-#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:331
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:454
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:491
-msgid "Please select a group"
-msgstr "Bitte wählen Sie eine Gruppe aus"
-#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:332
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:455
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:492
-msgid "group abstract"
-msgstr "Beschreibung der Gruppe"
-#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:333
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:456
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:493
-msgid "group name"
-msgstr "Name der Gruppe"
-#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:334
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:457
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:494
-msgid "application abstract"
-msgstr "Beschreibung der Applikation"
-#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:335
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:458
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:495
-msgid "application name"
-msgstr "Name der Anwendung"
-#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:336
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:459
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:496
-msgid "no result"
-msgstr "kein Ergebnis"
-#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:342
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:465
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:475
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:502
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:512
-msgid "Add WMS"
-msgstr "WMS hinzufügen"
-#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:343
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:466
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:503
-msgid "Enter a Capabilities-URL of a WMS or select one or more WMS from list."
-msgstr ""
-"Geben Sie eine Capabilities-URL ein oder wählen Sie einen der aufgelisteten "
-"Dienste."
-#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:344
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:467
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:504
-msgid ""
-"Notice: Be aware of the scale hints. Possibly you need to zoom in to display "
-"the added service."
-msgstr ""
-"Hinweis: Beachten Sie die logischen Zoomstufen. Möglicherweise müssen Sie "
-"den Maßstab wechseln, um die Ebenen des geladenen Dienstes zu sehen."
-#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:350
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:473
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:510
-msgid "Capabilities-URL"
-msgstr "Capabilities-URL"
-#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:362
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:529
-msgid "List all WMS"
-msgstr "Liste aller WMS"
-#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:363
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:530
-msgid "List WMS by Group"
-msgstr "WMS nach Gruppen sortiert"
-#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:364
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:531
-msgid "List WMS by Application"
-msgstr "WMS nach Anwendungen sortiert"
-#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:374
-msgid "Loading WMS"
-msgstr "Der WMS wird geladen"
-#: http/php/mod_createJSObjFromXML.php:33
-#: ../http/php/mod_createJSLayerObjFromXML.php:34
-#: ../http/php/mod_createJSObjFromXML.php:40
-msgid ""
-"Error: The Capabilities Document could not be accessed. Please check whether "
-"the server is responding and accessible to Mapbender."
-msgstr ""
-"Fehler: Das Capabilities-Dokument ist nicht verfügbar. Bitte prüfen Sie, ob "
-"der Server antwortet und für Mapbender erreichbar ist."
-#: http/html/mod_treefolderPlain.php:33
-#: ../http/html/mod_treefolderPlain.php:31
-msgid "(De)activate this service"
-msgstr "Dienst (de)aktivieren"
-#: http/html/mod_treefolderPlain.php:144
-#: ../http/html/mod_treefolderPlain.php:143
-#: ../http/html/mod_treefolderPlain.php:199
-msgid "Move up"
-msgstr "rauf"
-#: http/html/mod_treefolderPlain.php:145
-#: ../http/html/mod_treefolderPlain.php:144
-#: ../http/html/mod_treefolderPlain.php:200
-msgid "Move down"
-msgstr "runter"
-#: http/html/mod_treefolderPlain.php:146
-#: ../http/html/mod_treefolderPlain.php:145
-#: ../http/html/mod_treefolderPlain.php:201
-msgid "Remove"
-msgstr "entfernen"
-#: http/html/mod_treefolderPlain.php:147
-#: ../http/html/mod_treefolderPlain.php:146
-#: ../http/html/mod_treefolderPlain.php:202
-msgid "Opacity up"
-msgstr "Transparenz verringern"
-#: http/html/mod_treefolderPlain.php:148
-#: ../http/html/mod_treefolderPlain.php:147
-#: ../http/html/mod_treefolderPlain.php:203
-msgid "Opacity down"
-msgstr "Transparenz erhöhen"
-#: http/html/mod_treefolderPlain.php:149
-#: ../http/html/mod_treefolderPlain.php:148
-#: ../http/html/mod_treefolderPlain.php:204
-#: ../http/javascripts/mod_featureInfo.php:98
-#: ../http/javascripts/mod_featureInfoTunnel.php:131
-#: ../http/javascripts/mod_featureInfoTunnel.php:160
-#: ../http/javascripts/mod_tooltip.php:78
-#: ../http/javascripts/mod_featureInfo.php:107
-#: ../http/javascripts/mod_featureInfo.php:111
-#: ../http/javascripts/mod_featureInfoTunnel.php:139
-#: ../http/javascripts/mod_featureInfoTunnel.php:168
-msgid "Information"
-msgstr "Information"
-#: http/html/mod_treefolderPlain.php:150 http/html/mod_treefolderPlain.php:152
-#: ../http/html/mod_treefolderPlain.php:149
-#: ../http/html/mod_treefolderPlain.php:151
-#: ../http/html/mod_treefolderPlain.php:205
-#: ../http/html/mod_treefolderPlain.php:208
-msgid "Zoom"
-msgstr "auf Ebene zoomen"
-#: http/html/mod_treefolderPlain.php:151
-#: ../http/html/mod_treefolderPlain.php:150
-#: ../http/html/mod_treefolderPlain.php:206
-msgid "Hide menu"
-msgstr "schließen"
-#: conf/wfs_additional_spatial_search.conf:17
-msgid "Spatial filter is set."
-msgstr "räumlicher Filter gesetzt"
-#: conf/wfs_additional_spatial_search.conf:31
-msgid "Search results"
-msgstr "Suchergebnisse"
-#: conf/wfs_additional_spatial_search.conf:37
-msgid "Details"
-msgstr "Details"
-#: http/php/mb_listGUIs.php:59 ../http/php/mb_listGUIs.php:59
-msgid "available applications"
-msgstr "Liste der verfügbaren Anwendungen"
-#: http/php/mb_listGUIs.php:82 ../http/php/mb_listGUIs.php:99
-#: ../http/php/mb_listGUIs.php:82
-msgid "Others"
-msgstr "Sonstige"
-#: ../http/html/mod_treefolderPlain.php:420
-#: ../http/html/mod_treefolderPlain.php:522
-msgid "You have to select the WMS you want to move up!"
-msgstr "Sie müssen den Dienst, den Sie nach oben schieben wollen, selektieren."
-#: ../http/html/mod_treefolderPlain.php:425
-#: ../http/html/mod_treefolderPlain.php:457
-#: ../http/html/mod_treefolderPlain.php:527
-#: ../http/html/mod_treefolderPlain.php:559
-msgid "Illegal move operation"
-msgstr "Ungültige Operation"
-#: ../http/html/mod_treefolderPlain.php:452
-#: ../http/html/mod_treefolderPlain.php:554
-msgid "You have to select the WMS you want to move down!"
-msgstr ""
-"Sie müssen den Dienst, den Sie nach unten schieben wollen, selektieren."
-#: ../http/html/mod_treefolderPlain.php:484
-#: ../http/html/mod_treefolderPlain.php:586
-msgid "You have to select the WMS you want to delete!"
-msgstr "Sie müssen den Dienst, den Sie entfernen wollen, selektieren."
-#: ../http/html/mod_treefolderPlain.php:488
-#: ../http/html/mod_treefolderPlain.php:590
-msgid "It is not possible to delete a single layer, please select a WMS!"
-msgstr ""
-"Es ist nicht möglich einen einzelnen Layer zu entfernen. Bitte selektieren "
-"Sie einen WMS!"
-#: ../http/html/mod_treefolderPlain.php:496
-#: ../http/html/mod_treefolderPlain.php:598
-msgid "Last WMS can not be removed."
-msgstr "Der letzte WMS kann nicht entfernt werden."
-#: ../http/html/mod_treefolderPlain.php:499
-#: ../http/html/mod_treefolderPlain.php:601
-msgid "Are you sure you want to remove"
-msgstr "Sind Sie sicher, dass Sie diesen Dienst entfernen wollen "
-#: http/javascripts/mod_measure.php:298
-#: ../http/javascripts/mod_measure.php:288
-msgid "Close polygon"
-#: http/javascripts/mod_measure.php:314
-#: ../http/javascripts/mod_measure.php:305
-msgid "Rubber"
-msgstr "Skizze löschen"
-#: http/javascripts/mod_measure.php:329
-#: ../http/javascripts/mod_measure.php:320
-msgid "Get area"
-msgstr "Fläche berechnen"
-#: ../http/javascripts/mod_wfs_gazetteer_client.php:411
-#: ../http/javascripts/mod_wfs_gazetteer_client.php:667
-msgid "show metadata"
-msgstr "Metadaten anzeigen"
-#: ../http/javascripts/mod_wfs_gazetteer_client.php:420
-#: ../http/javascripts/mod_wfs_gazetteer_client.php:676
-msgid "remove WFS Conf"
-msgstr "WFS Konfiguration entfernen"
-#: ../http/javascripts/mod_wfs_gazetteer_client.php:455
-#: ../http/javascripts/mod_wfs_gazetteer_client.php:711
-msgid "Point"
-msgstr "Punkt"
-#: ../http/javascripts/mod_wfs_gazetteer_client.php:459
-#: ../http/javascripts/mod_wfs_gazetteer_client.php:715
-msgid "Line"
-msgstr "Linie"
-#: ../http/javascripts/mod_wfs_gazetteer_client.php:463
-#: ../http/javascripts/mod_wfs_gazetteer_client.php:719
-msgid "Polygon"
-msgstr "Polygon"
-#: ../http/javascripts/mod_wfs_gazetteer_client.php:621
-#: ../http/javascripts/mod_wfs_gazetteer_client.php:891
-msgid "Different EPSG of map and wfs featuretype, no spatial request possible!"
-msgstr ""
-"Unterschiedliche EPSG von Karte und WFS FeatureType. Es ist keine räumliche "
-"möglich."
-msgid "Show metadata"
-#: ../http/html/mod_treefolderPlain.php:207
-msgid "Change style"
-msgstr "Stil ändern"
-#: ../http/html/mod_treefolderPlain.php:471
-msgid "Change layer style"
-msgstr "Layer Stil ändern"
-msgid "Please select a style"
-msgstr "Bitte wählen Sie einen Stil aus"
-#: ../http/html/mod_treefolderPlain.php:477
-msgid "Close"
-msgstr "schließen"
-msgid "close"
-msgstr "schließen"
-#: ../http/html/mod_treefolderPlain.php:490
-msgid "There is no different style available for this layer."
-msgstr "Es liegen keine weiteren Stile für diesen Layer vor."
-msgid ""
-"Hint: Possibly you need to zoom in for showing layers from external map "
-"service. The operator of the external service is responsible for the display "
-"ranges. PortalU does not have a stake in this behaviour."
-msgstr ""
-"Hinweis: Möglicherweise müssen Sie in die Karte zoomen, um Layer von "
-"externen Diensten zu sehen.Der Administrator des externen Dienstes ist für "
-"die Anzeige verantwortlich."
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:479
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:516
-msgid "activate layers"
-msgstr "Ebenen des Kartendienstes aktivieren"
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:483
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:520
-msgid "zoom to extent"
-msgstr "auf Ausdehnung des Kartendiensten zoomen"
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:501
-#: ../http/javascripts/mod_searchCSW_ajax.php:507
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:538
-#: ../http/javascripts/mod_searchCSW_ajax.php:409
-msgid "Loading"
-msgstr "Kartendienst wird geladen"
-#: ../http/php/mod_meetingPoint.php:42 ../http/php/mod_meetingPoint.php:45
-#: ../http/php/mod_meetingPoint.php:46
-msgid "Your meeting point. Follow the link!"
-msgstr "Ihr Treffpunkt. Folgen Sie dem Link!"
-#: ../http/php/mod_meetingPoint.php:98 ../http/php/mod_meetingPoint.php:108
-#: ../http/php/mod_meetingPoint.php:109
-msgid "Please click for the meeting point position!"
-msgstr "Bitte klicken Sie in die Karte, um einen Treffpunkt zu erzeugen."
-#: ../http/php/mod_meetingPoint.php:210 ../http/php/mod_meetingPoint.php:227
-#: ../http/php/mod_meetingPoint.php:228
-msgid "Max characters"
-msgstr "Max. Eingabe"
-#: ../http/php/mod_meetingPoint.php:229 ../http/php/mod_meetingPoint.php:151
-#: ../http/php/mod_meetingPoint.php:246 ../http/php/mod_meetingPoint.php:152
-#: ../http/php/mod_meetingPoint.php:247
-msgid "Please define a text!"
-msgstr "Bitte geben Sie einen Text ein."
-#: ../http/php/mod_meetingPoint.php:323 ../http/php/mod_meetingPoint.php:352
-#: ../http/php/mod_meetingPoint.php:353
-msgid "cancel"
-msgstr "Abbrechen"
-#: ../http/php/mod_gazetteerMetadata.php:150
-#: ../http/php/mod_gazetteerMetadata.php:145
-msgid "The added Service has more than"
-msgstr "Der hinzugefügte Dienst hat mehr als"
-#: ../http/php/mod_gazetteerMetadata.php:208
-#: ../http/php/mod_gazetteerMetadata.php:203
-msgid "The following Service has been added"
-msgstr "Der folgende Dienst wurde hinzugefügt"
-#: ../http/php/mod_gazetteerMetadata.php:234
-msgid "SelectKeyword"
-msgstr "Suchbegriff auswählen"
-#: ../http/php/mod_gazetteerMetadata.php:249
-#: ../http/plugins/mb_metadata_wmc_edit.php:31
-#: ../http/plugins/mb_metadata_wmc_server.php:57
-#: ../http/php/mod_gazetteerMetadata.php:246
-#: ../http/php/mod_subscribersServiceList.php:167
-#: ../http/plugins/mb_metadata_wmc_server.php:54
-msgid "Metadata"
-msgstr "Metadaten"
-#: ../http/php/mod_gazetteerMetadata.php:267
-#: ../http/php/mod_gazetteerMetadata.php:264
-msgid "Searching"
-msgstr "Suche läuft"
-#: ../http/php/mod_gazetteerMetadata.php:317
-#: ../http/php/mod_gazetteerMetadata.php:314
-msgid "Load"
-msgstr "Laden"
-#: ../http/php/mod_gazetteerMetadata.php:342
-#: ../http/php/mod_gazetteerMetadata.php:339
-msgid "Add WMS and zoom to extent"
-msgstr "Kartendienst hinzuladen und auf Ausdehnung zoomen"
-#: ../http/php/mod_gazetteerMetadata.php:440
-#: ../http/php/mod_gazetteerMetadata.php:437
-msgid "keywords"
-msgstr "Suchbegriffe"
-msgid "layer. The layer of the MapService will NOT be activated."
-msgstr "Ebenen. Die Ebenen des Kartendienstes werden NICHT aktiviert."
-#: ../http/php/mod_SelectKeyword.php:24
-#: ../http/php/mod_gazetteerMetadata.php:230
-msgid "Select a keyword"
-msgstr "Wählen Sie einen Suchbegriff aus"
-#: ../http/php/mod_SelectKeyword.php:48
-msgid "Please double click to select a keyword."
-msgstr "Suchbegriff per Doppelklick auswählen."
-#: ../http/php/mod_gazetteerMetadata.php:262
-#: ../http/php/mod_gazetteerMetadata.php:259
-msgid "Please insert a keyword!"
-msgstr "Bitte geben Sie einen Suchbegriff an."
-#: ../http/javascripts/mod_searchCSW_ajax.php:89
-#: ../http/javascripts/mod_searchCSW_ajax.php:489
-#: ../http/javascripts/mod_searchCSW_ajax.php:391
-msgid "+ Advanced"
-msgstr "+ Erweitert"
-#: ../http/javascripts/mod_searchCSW_ajax.php:107
-#: ../http/javascripts/mod_searchCSW_form.php:66
-msgid "Title "
-msgstr "Titel"
-#: ../http/javascripts/mod_searchCSW_ajax.php:109
-#: ../http/javascripts/mod_searchCSW_form.php:68
-msgid "Abstract"
-msgstr "Beschreibung"
-#: ../http/javascripts/mod_searchCSW_ajax.php:111
-#: ../http/javascripts/mod_searchCSW_form.php:70
-msgid "Keywords"
-msgstr "Stichworte"
-#: ../http/javascripts/mod_searchCSW_ajax.php:121
-#: ../http/javascripts/mod_searchCSW_form.php:75
-msgid "Lat-Min"
-msgstr "min. Lat"
-#: ../http/javascripts/mod_searchCSW_ajax.php:128
-#: ../http/javascripts/mod_searchCSW_form.php:79
-msgid "Lon-Min"
-msgstr "min. Lon"
-#: ../http/javascripts/mod_searchCSW_ajax.php:133
-msgid "Lat-Max"
-msgstr "max. Lat"
-#: ../http/javascripts/mod_searchCSW_ajax.php:140
-#: ../http/javascripts/mod_searchCSW_form.php:81
-msgid "Lon-Max"
-msgstr "max. Lon"
-#: ../http/javascripts/mod_searchCSW_ajax.php:161
-msgid "Getrecords Medium"
-msgstr "noch übersetzen Getrecords Medium"
-#: ../http/javascripts/mod_searchCSW_ajax.php:169
-msgid "Query Language"
-msgstr "noch Übersetzen: Query Language"
-#: ../http/javascripts/mod_searchCSW_ajax.php:184
-#: ../http/javascripts/mod_searchCSW_ajax.php:495
-#: ../http/javascripts/mod_searchCSW_ajax.php:397
-msgid "+ Options"
-msgstr "+ Optionen"
-#: ../http/javascripts/mod_searchCSW_ajax.php:459
-#: ../http/javascripts/mod_searchCSW_ajax.php:360
-msgid "Record Title"
-msgstr "Titel"
-#: ../http/javascripts/mod_searchCSW_ajax.php:460
-#: ../http/javascripts/mod_searchCSW_ajax.php:361
-msgid "Record Abstract"
-#: ../http/javascripts/mod_searchCSW_ajax.php:461
-#: ../http/javascripts/mod_searchCSW_ajax.php:362
-msgid "Returned Results..."
-msgstr "Erhaltene Treffer..."
-#: ../http/javascripts/mod_searchCSW_ajax.php:472
-#: ../http/javascripts/mod_searchCSW_ajax.php:373
-msgid ""
-"Do a Basic or Advanced Search of Catalogs in the system. Please visit the "
-"Catalog Admin to add a Catalog"
-msgstr ""
-"Führen Sie eine einfache oder erweiterte Suche durch. Über die "
-"Administration können Sie auch einen Katalogdienst laden."
-#: ../http/javascripts/mod_searchCSW_ajax.php:480
-#: ../http/javascripts/mod_searchCSW_ajax.php:382
-#: ../http/javascripts/mod_searchCSW_form.php:55
-msgid "Search for "
-msgstr "Suche nach"
-#: ../http/javascripts/mod_searchCSW_ajax.php:500
-#: ../http/javascripts/mod_searchCSW_ajax.php:402
-#: ../http/javascripts/mod_searchCSW_form.php:48
-#: ../http/javascripts/mod_searchCSW_form.php:58
-#: ../http/javascripts/mod_searchCSW_form.php:85
-msgid "Search CSW"
-msgstr "Katalogsuche"
-#: ../http/javascripts/mod_searchCSW_ajax.php:102
-msgid "- Advanced"
-msgstr "- Erweitert"
-#: ../http/javascripts/mod_searchCSW_ajax.php:105
-msgid "Advanced Search"
-msgstr "Erweiterte Suche"
-#: ../http/javascripts/mod_searchCSW_ajax.php:154
-msgid "- Options"
-msgstr "- Optionen"
-#: ../http/javascripts/mod_searchCSW_ajax.php:159
-msgid "Number of Hits"
-msgstr "Anzahl der Treffer"
-#: ../http/javascripts/mod_searchCSW_ajax.php:171
-#: ../http/javascripts/mod_searchCSW_ajax.php:172
-msgid "CQL"
-msgstr "CQL"
-msgid "Filter"
-msgstr "Filter"
-#: ../http/javascripts/mod_searchCSW_ajax.php:478
-#: ../http/javascripts/mod_searchCSW_ajax.php:380
-msgid "Capabilities"
-msgstr "noch übersetzen: Capabilities"
-#: ../http/javascripts/mod_searchCSW_ajax.php:470
-#: ../http/javascripts/mod_searchCSW_ajax.php:371
-msgid "Catalog Search"
-#: ../http/javascripts/mod_searchCSW_ajax.php:31
-msgid "Search Catalog"
-msgstr "Suche starten"
-msgid "Name:"
-msgstr "Name:"
-msgid "Firstname:"
-msgstr "Vorname:"
-msgid "Lastname:"
-msgstr "Nachname:"
-msgid "Usertype:"
-msgstr "Typ des Nutzers:"
-msgid "Germany"
-msgstr "Deutschland"
-msgid "my lines"
-msgstr "meine Linien"
-msgid "Save configuration"
-msgstr "Konfiguration speichern"
-#: ../http/javascripts/mod_loadwmc.js:68
-msgid "List"
-msgstr "Liste"
-#: ../http/javascripts/mod_loadwmc.js:69
-msgid "Upload"
-msgstr "Laden"
-#: ../http/javascripts/mod_loadwmc.js:80
-msgid "WMC name"
-msgstr "WMS Name"
-#: ../http/javascripts/mod_loadwmc.js:81
-msgid "last update"
-msgstr "letzte Änderung"
-#: ../http/javascripts/mod_loadwmc.js:82
-msgid "created"
-msgstr "erstellt"
-#: ../http/javascripts/mod_loadwmc.js:83
-msgid "load"
-msgstr "laden"
-#: ../http/javascripts/mod_loadwmc.js:84
-msgid "merge"
-msgstr "mergen"
-#: ../http/javascripts/mod_loadwmc.js:85
-msgid "append"
-msgstr "hinzufügen"
-#: ../http/javascripts/mod_loadwmc.js:86
-msgid "public"
-msgstr "öffentlich"
-#: ../http/javascripts/mod_loadwmc.js:87
-msgid "show/save"
-msgstr "anzeigen/speichern"
-#: ../http/javascripts/mod_loadwmc.js:88
-#: ../http/javascripts/mod_loadwmc.js:294
-msgid "OpenLayers"
-msgstr "OpenLayers"
-#: ../http/javascripts/mod_loadwmc.js:89
-msgid "delete"
-msgstr "löschen"
-#: ../http/javascripts/mod_loadwmc.js:173
-msgid "load this WMC"
-msgstr "lade dieses WMC"
-#: ../http/javascripts/mod_loadwmc.js:175
-#: ../http/javascripts/mod_loadwmc.js:358
-msgid "WMC has been loaded successfully."
-msgstr "Das WMC wurde erfolgreich geladen."
-#: ../http/javascripts/mod_loadwmc.js:196
-msgid "merge WMC"
-msgstr "WMC zusammenfügen"
-#: ../http/javascripts/mod_loadwmc.js:198
-msgid "WMC has been merged successfully."
-msgstr "WMC wurde erfolgreich zusammengeführt."
-#: ../http/javascripts/mod_loadwmc.js:222
-msgid "append WMC"
-msgstr "WMC hinzufügen"
-#: ../http/javascripts/mod_loadwmc.js:224
-msgid "WMC has been appended successfully."
-msgstr "WMC wurde erfolgreich hinzugefügt"
-#: ../http/javascripts/mod_loadwmc.js:229
-msgid "currentState"
-msgstr "aktueller Stand"
-#: ../http/javascripts/mod_loadwmc.js:262
-msgid "display WMC XML"
-msgstr "WMC XML anzeigen"
-#: ../http/javascripts/mod_loadwmc.js:267
-msgid "WMC Document"
-msgstr "WMC Dokument"
-#: ../http/javascripts/mod_loadwmc.js:289
-msgid "export to OpenLayers"
-msgstr "nach OpenLayers exportieren"
-#: ../http/javascripts/mod_loadwmc.js:322
-msgid "delete this WMC"
-msgstr "WMC löschen"
-#: ../http/javascripts/mod_loadwmc.js:325
-msgid "Do you really want to delete WMC"
-msgstr "Wollen Sie dieses WMC wirklich löschen?"
-#: ../http/javascripts/mod_loadwmc.js:404
-msgid "load Service anyway?"
-msgstr "Dienst trotzdem laden?"
-#: ../http/plugins/wfsConfTree.js:7
-msgid "No geometry modules are available. You can load those from the Search."
-msgstr ""
-"Keine Geometriemodule verfügbar. Sie können Module über die Suche hinzuladen."
-#: ../http/javascripts/mod_zoomCoords.php:36
-msgid "Please type a number."
-msgstr "Bitte geben Sie die Koordinaten als Zahlen ein."
-#: ../http/javascripts/mod_zoomCoords.php:88
-msgid "ok"
-msgstr "ok"
-#: ../http/javascripts/mod_zoomCoords.php:91
-msgid "Longitude"
-msgstr "Rechtswert"
-#: ../http/javascripts/mod_zoomCoords.php:92
-msgid "Latitude"
-msgstr "Hochwert"
-#: workspace/test27/http/plugins/mb_metadata_edit.php:10
-#: workspace/test27/http/plugins/mb_metadata_layer.php:34
-#: ../http/plugins/mb_metadata_edit.php:10
-#: ../http/plugins/mb_metadata_featuretype.php:34
-#: ../http/plugins/mb_metadata_layer.php:34
-#: ../http/plugins/mb_metadata_wfs_edit.php:10
-#: ../http/plugins/mb_metadata_edit.php:11
-#: ../http/plugins/mb_metadata_wfs_edit.php:11
-msgid "Show original Service Metadata from last update"
-msgstr "Originale Dienstmetadaten von letzter Aktualisierung anzeigen"
-#: workspace/test27/http/plugins/jq_upload_images.php:29
-#: workspace/test27/http/plugins/jq_upload.php:29
-#: ../http/plugins/jq_upload.php:29 ../http/plugins/jq_upload.php:28
-#, php-format
-msgid "Files with this extension are not allowed. Must be %s."
-msgstr ""
-"Dateien in diesem Format werden nicht unterstützt, wählen Sie eines der "
-"folgenden Bildformate: %s."
-#: workspace/test27/http/plugins/jq_upload_images.php:49
-#: workspace/test27/http/plugins/jq_upload.php:50
-#: ../http/plugins/jq_upload.php:50 ../http/plugins/jq_upload.php:49
-#, php-format
-msgid "Files with extension %s are not allowed. Must be %s."
-msgstr ""
-"Dateien in dem Format %s werden nicht unterstützt, wählen Sie eines der "
-#: workspace/test27/http/plugins/jq_upload_images.php:61
-#: workspace/test27/http/plugins/jq_upload.php:63
-#: ../http/plugins/jq_upload.php:63 ../http/plugins/jq_upload.php:62
-#, php-format
-msgid "File size limit (%s KB) exceeded."
-msgstr "Datei zu groß (maximal %s KB)."
-#: workspace/test27/http/plugins/jq_upload_images.php:75
-#: workspace/test27/http/plugins/jq_upload.php:78
-#: ../http/plugins/jq_upload.php:77
-msgid "File could not be stored on server. Please contact the administrator."
-msgstr ""
-"Die Datei konnte nicht hochgeladen werden. Bitte wenden Sie sich an den "
-"Administrator."
-#: workspace/test27/http/plugins/jq_upload_images.php:80
-#: workspace/test27/http/plugins/jq_upload.php:83
-#: ../http/plugins/jq_upload.php:82
-msgid "File has been uploaded."
-msgstr "Die Datei wurde erfolgreich hochgeladen."
-#: workspace/test27/http/plugins/mb_i18n_server.php:48
-#: workspace/test27/http/plugins/mb_metadata_server.php:388
-#: workspace/test27/http/plugins/mb_original_metadata_server.php:172
-#: workspace/test27/http/plugins/mb_twitter.php:126
-#: ../http/plugins/mb_i18n_server.php:48
-#: ../http/plugins/mb_metadata_server.php:424
-#: ../http/plugins/mb_metadata_wfs_server.php:388
-#: ../http/plugins/mb_metadata_wmc_server.php:217
-#: ../http/plugins/mb_original_metadata_server.php:205
-#: ../http/plugins/mb_original_metadata_wfs_server.php:206
-#: ../http/plugins/mb_original_metadata_wmc_server.php:75
-#: ../http/plugins/mb_sql_server.php:36
-#: ../http/php/mod_changeEPSG_server.php:116
-#: ../http/php/mod_changeEPSG_server.php:125
-#: ../http/php/mod_coordsLookup_server.php:126
-#: ../http/php/mod_coordsLookup_server.php:136
-#: ../http/php/mod_treefolder2_l10n.php:51
-#: ../http/php/mod_wfs_gazetteer_l10n.php:55
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:135
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:187
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:198
-#: ../http/plugins/mb_metadata_server.php:1071
-#: ../http/plugins/mb_metadata_wfs_server.php:453
-#: ../http/plugins/mb_metadata_wmc_server.php:214
-msgid "An unknown error occured."
-msgstr "Ein unkekannter Fehler ist aufgetreten."
-#: workspace/test27/http/plugins/mb_metadata_edit.php:8
-#: ../http/plugins/mb_metadata_edit.php:8
-#: ../http/plugins/mb_metadata_wfs_edit.php:8
-#: ../http/plugins/mb_metadata_wmc_edit.php:23
-#: ../http/plugins/mb_metadata_edit.php:9
-#: ../http/plugins/mb_metadata_wfs_edit.php:9
-msgid "Service Level Metadata"
-msgstr "Service Metadaten"
-#: workspace/test27/http/plugins/mb_metadata_edit.php:12
-#: workspace/test27/http/plugins/mb_metadata_edit.php:57
-#: workspace/test27/http/plugins/mb_metadata_layer.php:32
-#: workspace/test27/http/plugins/mb_metadata_layer.php:36
-#: workspace/test27/http/plugins/mb_metadata_layer.php:62
-#: ../http/plugins/mb_metadata_edit.php:12
-#: ../http/plugins/mb_metadata_edit.php:57
-#: ../http/plugins/mb_metadata_featuretype.php:32
-#: ../http/plugins/mb_metadata_featuretype.php:36
-#: ../http/plugins/mb_metadata_featuretype.php:62
-#: ../http/plugins/mb_metadata_layer.php:32
-#: ../http/plugins/mb_metadata_layer.php:36
-#: ../http/plugins/mb_metadata_layer.php:62
-#: ../http/plugins/mb_metadata_wfs_edit.php:12
-#: ../http/plugins/mb_metadata_wfs_edit.php:57
-#: ../http/plugins/mb_metadata_addon.php:9
-#: ../http/plugins/mb_metadata_addon.php:10
-#: ../http/plugins/mb_metadata_addon.php:11
-#: ../http/plugins/mb_metadata_addon.php:34
-#: ../http/plugins/mb_metadata_addon.php:38
-#: ../http/plugins/mb_metadata_addon.php:42
-#: ../http/plugins/mb_metadata_addon.php:46
-#: ../http/plugins/mb_metadata_addon.php:48
-#: ../http/plugins/mb_metadata_addon.php:55
-#: ../http/plugins/mb_metadata_addon.php:75
-#: ../http/plugins/mb_metadata_addon.php:86
-#: ../http/plugins/mb_metadata_addon.php:91
-#: ../http/plugins/mb_metadata_addon.php:107
-#: ../http/plugins/mb_metadata_addon.php:117
-#: ../http/plugins/mb_metadata_addon.php:124
-#: ../http/plugins/mb_metadata_edit.php:13
-#: ../http/plugins/mb_metadata_edit.php:59
-#: ../http/plugins/mb_metadata_edit.php:126
-#: ../http/plugins/mb_metadata_edit.php:151
-#: ../http/plugins/mb_metadata_layer.php:63
-#: ../http/plugins/mb_metadata_wfs_edit.php:13
-#: ../http/plugins/mb_metadata_wfs_edit.php:58
-#: ../http/plugins/mb_metadata_wfs_edit.php:125
-#: ../http/plugins/mb_metadata_wfs_edit.php:150
-msgid "Help"
-msgstr "Hilfe"
-msgid ""
-"Possibility to adapt and add informations in the separate WMS-Layer "
-"Metadata. The modified Metadata is stored in the database of the GeoPortal."
-"rlp, outwardly these metadata overwrite the original Service-Metadata."
-msgstr ""
-"Möglichkeit der Überarbeitung und Ergänzung der WMS Metadaten. Die "
-"bearbeiteten Metadaten werden in der Datenbank des GeoPortal.rlp abgelegt "
-"und überschreiben nach Außen hin die originären Metadaten des WMS-Dienstes."
-msgid ""
-"The original WMS-Metadata from the last update could be recovered or "
-"updated, so that the original Service-Metadata will be shown outward again."
-msgstr ""
-"Anzeige der originären WMS Metadaten (Stand: letzte Aktualisierung) "
-"Hilfetext: Die originären Metadaten des WMS vom Stand der letzten "
-"Aktualisierung können wiederhergestellt bzw. aktualisiert und werden damit "
-"nach Außen sichtbar."
-#: workspace/test27/http/plugins/mb_metadata_edit.php:15
-#: ../http/plugins/mb_metadata_edit.php:16
-msgid "WMS Title (OWS)"
-msgstr "WMS-Titel (OWS)"
-#: workspace/test27/http/plugins/mb_metadata_edit.php:17
-#: workspace/test27/http/plugins/mb_metadata_edit.php:22
-#: workspace/test27/http/plugins/mb_metadata_edit.php:27
-#: workspace/test27/http/plugins/mb_metadata_edit.php:32
-#: workspace/test27/http/plugins/mb_metadata_edit.php:37
-#: workspace/test27/http/plugins/mb_metadata_edit.php:81
-#: workspace/test27/http/plugins/mb_metadata_edit.php:106
-#: workspace/test27/http/plugins/mb_metadata_edit.php:111
-#: workspace/test27/http/plugins/mb_metadata_edit.php:116
-#: workspace/test27/http/plugins/mb_metadata_layer.php:45
-#: workspace/test27/http/plugins/mb_metadata_layer.php:50
-#: workspace/test27/http/plugins/mb_metadata_layer.php:97
-#: workspace/test27/http/plugins/mb_metadata_layer.php:107
-#: ../http/plugins/mb_metadata_edit.php:17
-#: ../http/plugins/mb_metadata_edit.php:22
-#: ../http/plugins/mb_metadata_edit.php:27
-#: ../http/plugins/mb_metadata_edit.php:32
-#: ../http/plugins/mb_metadata_edit.php:37
-#: ../http/plugins/mb_metadata_edit.php:81
-#: ../http/plugins/mb_metadata_edit.php:106
-#: ../http/plugins/mb_metadata_edit.php:111
-#: ../http/plugins/mb_metadata_edit.php:116
-#: ../http/plugins/mb_metadata_featuretype.php:45
-#: ../http/plugins/mb_metadata_featuretype.php:50
-#: ../http/plugins/mb_metadata_featuretype.php:90
-#: ../http/plugins/mb_metadata_featuretype.php:101
-#: ../http/plugins/mb_metadata_layer.php:45
-#: ../http/plugins/mb_metadata_layer.php:50
-#: ../http/plugins/mb_metadata_layer.php:97
-#: ../http/plugins/mb_metadata_layer.php:108
-#: ../http/plugins/mb_metadata_wfs_edit.php:17
-#: ../http/plugins/mb_metadata_wfs_edit.php:22
-#: ../http/plugins/mb_metadata_wfs_edit.php:27
-#: ../http/plugins/mb_metadata_wfs_edit.php:32
-#: ../http/plugins/mb_metadata_wfs_edit.php:37
-#: ../http/plugins/mb_metadata_wfs_edit.php:81
-#: ../http/plugins/mb_metadata_wfs_edit.php:106
-#: ../http/plugins/mb_metadata_wfs_edit.php:111
-#: ../http/plugins/mb_metadata_wfs_edit.php:116
-#: ../http/plugins/mb_metadata_wmc_edit.php:36
-#: ../http/plugins/mb_metadata_wmc_edit.php:41
-#: ../http/plugins/mb_metadata_wmc_edit.php:46
-#: ../http/plugins/mb_metadata_wmc_edit.php:70
-#: ../http/plugins/mb_metadata_wmc_edit.php:81
-#: ../http/plugins/mb_metadata_layer.php:88
-#: ../http/plugins/mb_metadata_layer.php:99
-msgid "Inspire"
-msgstr "Inspire"
-#: workspace/test27/http/plugins/mb_metadata_edit.php:20
-#: ../http/plugins/mb_metadata_edit.php:20
-#: ../http/plugins/mb_metadata_edit.php:21
-msgid "WMS Abstract (OWS)"
-msgstr "WMS-Beschreibung (OWS)"
-#: workspace/test27/http/plugins/mb_metadata_edit.php:25
-#: ../http/plugins/mb_metadata_edit.php:25
-msgid "WMS Keywords (OWS)"
-msgstr "WMS Schlüsselwörter (OWS)"
-#: workspace/test27/http/plugins/mb_metadata_edit.php:30
-#: ../http/plugins/mb_metadata_edit.php:30
-msgid "WMS Fees (OWS)"
-msgstr "WMS Kosten/Gebühren (OWS)"
-#: workspace/test27/http/plugins/mb_metadata_edit.php:35
-#: ../http/plugins/mb_metadata_edit.php:35
-msgid "WMS AccessConstraints (OWS)"
-msgstr "WMS Zugriffsbeschränkung (OWS)"
-#: workspace/test27/http/plugins/mb_metadata_edit.php:48
-#: ../http/plugins/mb_metadata_edit.php:48
-#: ../http/plugins/mb_metadata_edit.php:50
-msgid "WMS Predefined Licence (Registry)"
-msgstr "WMS vordefiniere Lizenzbedingungen (Registry)"
-msgid ""
-"Auswahl von vordefinierten Lizenzen hinsichtlich Gebühren und "
-"Zugriffsbeschränkungen."
-msgstr ""
-#: workspace/test27/http/plugins/mb_metadata_edit.php:61
-#: ../http/plugins/mb_metadata_edit.php:61
-#: ../http/plugins/mb_metadata_edit.php:67
-msgid "WMS Provider Section (OWS)"
-msgstr "Bereitstellende Organisation (OWS)"
-#: workspace/test27/http/plugins/mb_metadata_edit.php:63
-#: ../http/plugins/mb_metadata_edit.php:63
-#: ../http/plugins/mb_metadata_wfs_edit.php:63
-#: ../http/plugins/mb_metadata_edit.php:69
-#: ../http/plugins/mb_metadata_wfs_edit.php:68
-msgid "Contact Individual Name (OWS)"
-msgstr "Ansprechpartner (OWS)"
-#: workspace/test27/http/plugins/mb_metadata_edit.php:67
-#: ../http/plugins/mb_metadata_wfs_edit.php:67
-#: ../http/plugins/mb_metadata_edit.php:73
-#: ../http/plugins/mb_metadata_wfs_edit.php:72
-msgid "Contact Position Name (OWS)"
-msgstr "Position des Ansprechpartners (OWS)"
-#: workspace/test27/http/plugins/mb_metadata_edit.php:71
-#: ../http/plugins/mb_metadata_edit.php:71
-#: ../http/plugins/mb_metadata_wfs_edit.php:71
-#: ../http/plugins/mb_metadata_edit.php:77
-#: ../http/plugins/mb_metadata_wfs_edit.php:76
-msgid "Contact Phone Voice (OWS)"
-msgstr "Telefonnummer (OWS)"
-#: workspace/test27/http/plugins/mb_metadata_edit.php:79
-#: ../http/plugins/mb_metadata_edit.php:79
-#: ../http/plugins/mb_metadata_edit.php:85
-msgid "Contact Organisation (WMS)"
-msgstr "Organisation (WMS)"
-#: workspace/test27/http/plugins/mb_metadata_edit.php:84
-#: ../http/plugins/mb_metadata_edit.php:84
-#: ../http/plugins/mb_metadata_edit.php:90
-msgid "Contact Address (WMS)"
-msgstr "Adresse (WMS)"
-#: workspace/test27/http/plugins/mb_metadata_edit.php:88
-#: ../http/plugins/mb_metadata_edit.php:88
-#: ../http/plugins/mb_metadata_edit.php:94
-msgid "Contact City (WMS)"
-msgstr "Ort/Stadt (WMS)"
-#: workspace/test27/http/plugins/mb_metadata_edit.php:92
-#: ../http/plugins/mb_metadata_edit.php:92
-#: ../http/plugins/mb_metadata_edit.php:98
-msgid "Contact State or Province (WMS) - ISO 3166-II"
-msgstr "Bundesland (WMS)"
-#: workspace/test27/http/plugins/mb_metadata_edit.php:96
-#: ../http/plugins/mb_metadata_edit.php:96
-#: ../http/plugins/mb_metadata_edit.php:102
-msgid "Contact Post Code (WMS)"
-msgstr "PLZ (WMS)"
-#: workspace/test27/http/plugins/mb_metadata_edit.php:100
-#: ../http/plugins/mb_metadata_edit.php:100
-msgid "Contact Post Country (WMS) - ISO 3166"
-msgstr "Land (WMS)"
-#: workspace/test27/http/plugins/mb_metadata_edit.php:104
-#: ../http/plugins/mb_metadata_edit.php:104
-#: ../http/plugins/mb_metadata_edit.php:110
-msgid "Contact Electronic Mail Address (WMS)"
-msgstr "e-mail (WMS)"
-#: workspace/test27/http/plugins/mb_metadata_edit.php:109
-#: ../http/plugins/mb_metadata_edit.php:109
-#: ../http/plugins/mb_metadata_wfs_edit.php:109
-#: ../http/plugins/mb_metadata_edit.php:115
-#: ../http/plugins/mb_metadata_wfs_edit.php:114
-msgid "Date of first registration (Registry)"
-msgstr "Datum der ersten Registrierung des WMS-Dienstes (Registry)"
-#: workspace/test27/http/plugins/mb_metadata_edit.php:114
-#: ../http/plugins/mb_metadata_edit.php:114
-#: ../http/plugins/mb_metadata_edit.php:120
-#: ../http/plugins/mb_metadata_wfs_edit.php:119
-msgid "Date of last revision (Registry)"
-msgstr "Datum des letzten Updates des WMS-Dienstes (Registry)"
-msgid ""
-"Metadata. The modified Metadata will be stored in the database of the "
-"GeoPortal.rlp, outwardly these metadata overwrite the original Service-"
-"Metadata."
-msgstr ""
-"Möglichkeit der Überarbeitung und Ergänzung der in den einzelnen WMS-Layern "
-"enthaltenen Metadaten. Die bearbeiteten Metadaten werden in der Datenbank "
-"des GeoPortal.rlp abgelegt und überschreiben nach Außen hin die originären "
-"Metadaten des WMS-Dienstes."
-#: workspace/test27/http/plugins/mb_metadata_layer.php:39
-#: ../http/plugins/mb_metadata_layer.php:39
-msgid "Number of Layer (Registry)"
-msgstr "Identifikationsnummer des Layers (Registry)"
-#: workspace/test27/http/plugins/mb_metadata_layer.php:44
-#: ../http/plugins/mb_metadata_layer.php:44
-msgid "Layer Title (WMS)"
-msgstr "Layertitel (WMS)"
-#: workspace/test27/http/plugins/mb_metadata_layer.php:49
-#: ../http/plugins/mb_metadata_layer.php:49
-msgid "Layer Abstract (WMS)"
-msgstr "Beschreibung (WMS)"
-#: workspace/test27/http/plugins/mb_metadata_layer.php:54
-#: ../http/plugins/mb_metadata_layer.php:54
-msgid "Layer Keywords (WMS)"
-msgstr "Schlüsselwörter (WMS)"
-#: workspace/test27/http/plugins/mb_metadata_layer.php:61
-#: ../http/plugins/mb_metadata_featuretype.php:61
-#: ../http/plugins/mb_metadata_layer.php:61
-msgid "Add Information about the underlying data"
-msgstr "Weitere standardisierte Informationen zum Layer (Datensatz-Metadaten)"
-msgid ""
-"Linking the WMS layer with metadata set (coupled resource), which describes "
-"the underlying informations of the representation in more detail (eg "
-"Actuality / quality). It occurs via a link to an already existing metadta "
-"set in a catalog or a simple metadata set will be generatetd using a "
-"Mapbender Layer Addon-Editor."
-msgstr ""
-"Verknüpfen des WMS-Layers mit einem Metadatensatzes (gekoppelte Ressource), "
-"der die der Darstellung zugrundeliegenden Informationen näher beschreibt (z."
-"B.: Aktualität/Qualität). Verknüpfung erfolgt entweder über Link zu einem "
-"schon in einem Katalog vorhandenen Metadatensatz oder über die Generierung "
-"des eines einfachen Metadatensatzes mittels Mapbender Layer-AddonEditor."
-#: ../http/plugins/mb_metadata_featuretype.php:65
-#: ../http/plugins/mb_metadata_layer.php:65
-msgid "Add new Metadata Record"
-msgstr "Metadatensatz erzeugen"
-#: ../http/plugins/mb_metadata_featuretype.php:68
-#: ../http/plugins/mb_metadata_layer.php:68
-msgid "Edit Metadata Linkage"
-msgstr "Metadatensatz editieren"
-#: ../http/plugins/mb_metadata_featuretype.php:71
-#: ../http/plugins/mb_metadata_layer.php:71
-msgid "Delete Metadata Linkage"
-msgstr "Metadatensatz löschen"
-#: workspace/test27/http/plugins/mb_metadata_layer.php:86
-#: ../http/plugins/mb_metadata_layer.php:86
-#: ../http/plugins/mb_metadata_wmc_edit.php:57
-#: ../http/plugins/mb_metadata_layer.php:77
-msgid "Preview"
-msgstr "Vorschau"
-#: workspace/test27/http/plugins/mb_metadata_layer.php:94
-#: ../http/plugins/mb_metadata_featuretype.php:87
-#: ../http/plugins/mb_metadata_layer.php:94
-#: ../http/plugins/mb_metadata_wmc_edit.php:66
-#: ../http/plugins/mb_metadata_layer.php:85
-msgid "Classification"
-msgstr "Klassifizierung"
-#: workspace/test27/http/plugins/mb_metadata_layer.php:96
-#: ../http/plugins/mb_metadata_featuretype.php:89
-#: ../http/plugins/mb_metadata_layer.php:96
-#: ../http/plugins/mb_metadata_wmc_edit.php:68
-#: ../http/plugins/mb_metadata_layer.php:87
-msgid "ISO Topic Category"
-msgstr "ISO-Kategorie"
-#: workspace/test27/http/plugins/mb_metadata_layer.php:106
-#: ../http/plugins/mb_metadata_featuretype.php:100
-#: ../http/plugins/mb_metadata_layer.php:107
-#: ../http/plugins/mb_metadata_wmc_edit.php:80
-#: ../http/plugins/mb_metadata_layer.php:98
-msgid "INSPIRE Category"
-msgstr "INSPIRE Kategorie"
-#: workspace/test27/http/plugins/mb_metadata_layer.php:116
-#: ../http/plugins/mb_metadata_featuretype.php:111
-#: ../http/plugins/mb_metadata_layer.php:118
-#: ../http/plugins/mb_metadata_wmc_edit.php:91
-#: ../http/plugins/mb_metadata_layer.php:109
-msgid "Custom Category"
-msgstr "Frei definierte Kategorie"
-#: workspace/test27/http/plugins/mb_metadata_server.php:20
-#: workspace/test27/http/plugins/mb_metadata_server.php:32
-#: ../http/plugins/mb_metadata_server.php:20
-#: ../http/plugins/mb_metadata_server.php:32
-#: ../http/plugins/mb_metadata_wfs_server.php:21
-#: ../http/plugins/mb_metadata_wfs_server.php:33
-#: ../http/plugins/mb_metadata_wmc_server.php:23
-#: ../http/plugins/mb_metadata_server.php:31
-#: ../http/plugins/mb_metadata_wfs_server.php:31
-msgid "No metadata sets available."
-msgstr "Keine Metadaten verfügbar."
-#: workspace/test27/http/plugins/mb_metadata_server.php:23
-#: ../http/plugins/mb_metadata_server.php:23
-#: ../http/plugins/mb_metadata_server.php:22
-msgid "You are not allowed to access this WMS."
-msgstr "Es ist Ihnen nicht gestattet auf diesen WMS zuzugreifen."
-#: workspace/test27/http/plugins/mb_metadata_server.php:36
-#: ../http/plugins/mb_metadata_server.php:36
-#: ../http/plugins/mb_metadata_server.php:35
-msgid "You are not allowed to access WMS "
-msgstr "Der Zugriff auf WMS-Dienste ist Ihnen nicht erlaubt."
-#: workspace/test27/http/plugins/mb_metadata_server.php:300
-#: ../http/plugins/mb_metadata_server.php:319
-#: ../http/plugins/mb_metadata_server.php:400
-msgid "Invalid WMS ID."
-msgstr "Ungültige WMS ID."
-#: workspace/test27/http/plugins/mb_twitter.php:22
-msgid ""
-"Element vars consumerKey and consumerSecret are not set. If you don't have "
-"them, get them from Twitter."
-msgstr ""
-"Die Elemente vars consumerKey und consumerSecret sind nicht definiert. Falls "
-"diese nicht vorliegen, können diese über Twitter ermittelt werden."
-#: workspace/test27/http/plugins/mb_twitter.php:64
-msgid "Signed in."
-msgstr "Angemeldet."
-#: workspace/test27/http/plugins/mb_twitter.php:69
-#: workspace/test27/http/plugins/mb_twitter.php:99
-msgid "Not signed in."
-msgstr "Nicht angemeldet."
-#: workspace/test27/http/plugins/mb_twitter.php:79
-#: workspace/test27/http/plugins/mb_twitter.php:116
-msgid "Could not connect to Twitter."
-msgstr "Verbindung zu Twitter fehlgeschlagen."
-#: workspace/test27/http/plugins/mb_twitter.php:92
-msgid "Signed out."
-msgstr "Abgemeldet."
-#: workspace/test27/http/plugins/mb_metadata_edit.php:75
-#: ../http/plugins/mb_metadata_edit.php:75
-#: ../http/plugins/mb_metadata_wfs_edit.php:75
-#: ../http/plugins/mb_metadata_wfs_edit.php:80
-msgid "Contact Phone Fax (OWS)"
-msgstr "Kontakt Telefonnummer (OWS)"
-msgid ""
-"Possibility to adapt and add informations in the separate WFS-Featuretype "
-"Metadata."
-msgstr ""
-msgid ""
-"The original WFS-Metadata from the last update could be recovered or "
-msgstr ""
-#: ../http/plugins/mb_metadata_featuretype.php:39
-msgid "Number of Featuretype (Registry)"
-msgstr "Nummer des Featuretype (Registry)"
-#: ../http/plugins/mb_metadata_featuretype.php:44
-msgid "Featuretype Title (WFS)"
-msgstr "Featuretype Titel (WFS)"
-#: ../http/plugins/mb_metadata_featuretype.php:49
-msgid "Featuretype Abstract (WFS)"
-msgstr ""
-#: ../http/plugins/mb_metadata_featuretype.php:54
-msgid "Featuretype Keywords (WFS)"
-msgstr ""
-msgid ""
-"Linking the WFS layer with metadata set (coupled resource), which describes "
-"set in a catalog or a simple metadata set will be generated using a "
-msgstr ""
-#: ../http/plugins/mb_metadata_featuretype.php:97
-#: ../http/plugins/mb_metadata_featuretype.php:108
-#: ../http/plugins/mb_metadata_featuretype.php:119
-#: ../http/plugins/mb_metadata_layer.php:104
-#: ../http/plugins/mb_metadata_layer.php:115
-#: ../http/plugins/mb_metadata_layer.php:126
-#: ../http/plugins/mb_metadata_wmc_edit.php:77
-#: ../http/plugins/mb_metadata_wmc_edit.php:88
-#: ../http/plugins/mb_metadata_wmc_edit.php:99
-#: ../http/plugins/mb_metadata_layer.php:95
-#: ../http/plugins/mb_metadata_layer.php:106
-#: ../http/plugins/mb_metadata_layer.php:117
-msgid "Reset selection"
-msgstr "Auswahl löschen"
-msgid ""
-msgstr ""
-#: ../http/plugins/mb_metadata_wfs_edit.php:16
-msgid "WFS Title (OWS)"
-msgstr ""
-#: ../http/plugins/mb_metadata_wfs_edit.php:20
-#: ../http/plugins/mb_metadata_wfs_edit.php:21
-msgid "WFS Abstract (OWS)"
-msgstr ""
-#: ../http/plugins/mb_metadata_wfs_edit.php:25
-#: ../http/plugins/mb_metadata_wfs_edit.php:26
-msgid "WFS Keywords (OWS)"
-msgstr ""
-#: ../http/plugins/mb_metadata_wfs_edit.php:30
-#: ../http/plugins/mb_metadata_wfs_edit.php:31
-msgid "WFS Fees (OWS)"
-msgstr ""
-#: ../http/plugins/mb_metadata_wfs_edit.php:35
-#: ../http/plugins/mb_metadata_wfs_edit.php:36
-msgid "WFS AccessConstraints (OWS)"
-msgstr ""
-#: ../http/plugins/mb_metadata_wfs_edit.php:48
-#: ../http/plugins/mb_metadata_wfs_edit.php:49
-msgid "WFS Predefined Licence (Registry)"
-msgstr ""
-#: ../http/plugins/mb_metadata_wfs_edit.php:61
-#: ../http/plugins/mb_metadata_wfs_edit.php:66
-msgid "WFS Provider Section (OWS)"
-msgstr ""
-#: ../http/plugins/mb_metadata_wfs_edit.php:79
-#: ../http/plugins/mb_metadata_wfs_edit.php:84
-msgid "Contact Organisation (WFS)"
-msgstr ""
-#: ../http/plugins/mb_metadata_wfs_edit.php:89
-msgid "Contact Address (WFS)"
-msgstr ""
-#: ../http/plugins/mb_metadata_wfs_edit.php:88
-#: ../http/plugins/mb_metadata_wfs_edit.php:93
-msgid "Contact City (WFS)"
-msgstr ""
-#: ../http/plugins/mb_metadata_wfs_edit.php:92
-#: ../http/plugins/mb_metadata_wfs_edit.php:97
-msgid "Contact State or Province (WFS) - ISO 3166-II"
-msgstr ""
-#: ../http/plugins/mb_metadata_wfs_edit.php:96
-#: ../http/plugins/mb_metadata_wfs_edit.php:101
-msgid "Contact Post Code (WFS)"
-msgstr ""
-#: ../http/plugins/mb_metadata_wfs_edit.php:100
-#: ../http/plugins/mb_metadata_wfs_edit.php:105
-msgid "Contact Post Country (WFS) - ISO 3166"
-msgstr ""
-#: ../http/plugins/mb_metadata_wfs_edit.php:104
-msgid "Contact Electronic Mail Address (WFS)"
-msgstr ""
-#: ../http/plugins/mb_metadata_wfs_server.php:24
-#: ../http/plugins/mb_metadata_wfs_server.php:22
-msgid "You are not allowed to access this WFS."
-msgstr ""
-#: ../http/plugins/mb_metadata_wfs_server.php:37
-#: ../http/plugins/mb_metadata_wfs_server.php:35
-msgid "You are not allowed to access this WFS "
-msgstr ""
-#: ../http/plugins/mb_metadata_wfs_server.php:286
-#: ../http/plugins/mb_metadata_wfs_server.php:295
-#: ../http/plugins/mb_metadata_wfs_server.php:342
-#: ../http/plugins/mb_metadata_wfs_server.php:351
-msgid "Invalid WFS ID."
-msgstr "Invalide WFS Identifikationsnummer"
-msgid ""
-"Possibility to adapt and add informations in the separate WMC-Featuretype "
-msgstr ""
-#: ../http/plugins/mb_metadata_wmc_edit.php:34
-msgid "WMC Title (OWS)"
-msgstr ""
-#: ../http/plugins/mb_metadata_wmc_edit.php:39
-msgid "WMC Abstract (OWS)"
-msgstr ""
-#: ../http/plugins/mb_metadata_wmc_edit.php:44
-msgid "WMC Keywords (OWS)"
-msgstr ""
-#: ../http/plugins/mb_metadata_wmc_edit.php:49
-msgid "WMC is public"
-msgstr "Kartenzusammenstellung ist öffentlich"
-#: ../http/plugins/mb_metadata_wmc_server.php:26
-msgid "You are not allowed to access this WMC."
-msgstr "Sie sind nicht autorisiert diese Kartenzusammenstellung zu nutzen."
-#: ../http/plugins/mb_metadata_wmc_server.php:147
-#: ../http/plugins/mb_metadata_wmc_server.php:155
-#: ../http/plugins/mb_metadata_wmc_server.php:144
-#: ../http/plugins/mb_metadata_wmc_server.php:152
-msgid "Invalid WMC ID."
-msgstr "Invalide WMC Identifizierungsnummer"
-#: ../http/plugins/mb_sql_server.php:31
-msgid "You are not allowed to access this application."
-msgstr "Sie sind nicht autorisiert diese Anwendung zu verwenden!"
-#: ../http/plugins/mb_measure_widget.php:47
-#: ../http/plugins/mb_measure_widget.php:80
-msgid "Click in the map to start measuring."
-msgstr "Klicken Sie in die Karte, um die Messung zu starten."
-#: ../http/plugins/mb_measure_widget.php:51
-#: ../http/plugins/mb_measure_widget.php:84
-msgid "Last point: "
-msgstr "letzter Stützpunkt: "
-#: ../http/plugins/mb_measure_widget.php:54
-#: ../http/plugins/mb_measure_widget.php:87
-msgid "Current point: "
-msgstr "aktueller Stützpunkt: "
-#: ../http/plugins/mb_measure_widget.php:57
-#: ../http/plugins/mb_measure_widget.php:90
-msgid "Distance (to last point): "
-msgstr "Entfernung zum letzten Punkt: "
-#: ../http/plugins/mb_measure_widget.php:60
-#: ../http/plugins/mb_measure_widget.php:93
-msgid "Distance (total): "
-msgstr "Länge (gesamt): "
-#: ../http/plugins/mb_measure_widget.php:63
-#: ../http/javascripts/mod_coordsLookup.php:100
-#: ../http/plugins/mb_measure_widget.php:96
-#: ../http/javascripts/mod_coordsLookup.php:125
-msgid "Perimeter: "
-msgstr "Umring: "
-#: ../http/javascripts/mod_coordsLookup.php:90
-#: ../http/javascripts/mod_coordsLookup.php:115
-msgid "Spatial Reference System"
-msgstr "Räumliches Bezugssystem"
-#: ../http/javascripts/mod_coordsLookup.php:81
-#: ../http/javascripts/mod_coordsLookup.php:105
-msgid "zoom to coordinates"
-msgstr "Auf Koordinaten zoomen"
-#: ../http/javascripts/mod_coordsLookup.php:71
-#: ../http/javascripts/mod_coordsLookup.php:95
-msgid "coordinates"
-msgstr "Koordinaten"
-#: ../http/javascripts/mod_coordsLookup.php:128
-#: ../http/javascripts/mod_coordsLookup.php:153
-msgid "Invalid X coordinate! Must be a float or a DMS value!"
-msgstr ""
-"Ungültige X Koordinate! Erlaubt sind lediglich Fließkomma oder GMS Werte!"
-#: ../http/javascripts/mod_coordsLookup.php:139
-#: ../http/javascripts/mod_coordsLookup.php:165
-msgid "Invalid Y coordinate! Must be a float or a DMS value!"
-msgstr ""
-"Ungültige Y Koordinate! Erlaubt sind lediglich Fließkomma oder GMS Werte!"
-#: ../http/javascripts/mod_coordsLookup.php:147
-#: ../http/javascripts/mod_coordsLookup.php:174
-msgid "Invalid SRS!"
-msgstr "Ungültiges KBS!"
-#: ../http/plugins/mb_measure_widget.php:66
-#: ../http/plugins/mb_measure_widget.php:99
-msgid "Area: "
-msgstr "Fläche: "
-#: ../http/plugins/mb_print.php:461
-msgid "print document"
-msgstr "Drucke Dokument"
-#: ../http/plugins/mb_print.php:560 ../http/plugins/mb_print.php:602
-msgid "use print box"
-msgstr "Nutze Druckrahmen"
-#: ../http/php/mod_abo_show.php:40
-msgid "Mapbender Service Provider"
-msgstr ""
-#: ../http/php/mod_abo_show.php:41
-msgid "Confirmation of subscribers notification"
-msgstr "Bestätigung der Abonnentenbenachrichtigung"
-#: ../http/php/mod_abo_show.php:43
-msgid "Mapbender monitoring subscriber"
-msgstr "Monitoring abonnieren"
-#: ../http/php/mod_abo_show.php:44
-msgid "Mapbender subscribers notification"
-msgstr "Abonnentenbenachrichtigung"
-#: ../http/php/mod_abo_show.php:45
-msgid "The following services are affected"
-msgstr "Folgende Dienste sind betroffen "
-#: ../http/php/mod_abo_show.php:46
-msgid "e-mail form for notifications to the subscribers of the following WMS"
-msgstr "EMail Formular für die Benachrichtigung der Abonnenten folgender WMS "
-#: ../http/php/mod_abo_show.php:47
-msgid "Subscriber notification for Mapbender service providers"
-msgstr "Abo Benachrichtigung für die Anbieter von OWS"
-#: ../http/php/mod_abo_show.php:48
-msgid ""
-"Notifications have been sent. You will receive a confirmation mail shortly."
-msgstr ""
-"Benachrichtung wurde gesendet. Sie werden in Kürze eine Bestätigungsmail "
-"erhalten."
-#: ../http/php/mod_abo_show.php:49
-msgid "Create mail form"
-msgstr "Erzeuge Mail Formular"
-#: ../http/php/mod_abo_show.php:50
-msgid "The subscribers to these WMS have been notified"
-msgstr "Die Abonnenten folgender WMS wurden benachrichtigt"
-#: ../http/php/mod_abo_show.php:51
-msgid "For further inquiries contact"
-msgstr "Für weitere Fragen kontaktieren sie bitte "
-#: ../http/php/mod_abo_show.php:52
-msgid "Subscriber notification"
-msgstr "Abonnenten Benachrichtigung"
-#: ../http/php/mod_abo_show.php:53
-msgid "# subscribers"
-msgstr "# Abonnenten"
-#: ../http/php/mod_abo_show.php:54
-msgid "Notify"
-msgstr "Benachrichtigung"
-#: ../http/php/mod_abo_show.php:55
-msgid "Send mail"
-msgstr "Sende EMail"
-#: ../http/php/mod_acceptedTou_server.php:39
-#: ../http/php/mod_loadwmc_server.php:269
-#: ../http/php/mod_sessionWmc_server.php:56
-#: ../http/php/mod_loadwmc_server.php:271
-msgid "No method specified."
-msgstr "Keine Methode definiert."
-#: ../http/php/mod_changeEPSG_server.php:30
-#: ../http/php/mod_coordsLookup_server.php:67
-msgid "PostGIS is not available. Please contact the administrator."
-msgstr ""
-"PostGIS ist nicht verfügbar. Bitte benachrichtigen sie den Administrator."
-#: ../http/php/mod_changeEPSG_server.php:71
-msgid "The coordinates could not be projected."
-msgstr "Die Koordinaten konnten nicht transformiert werden."
-#: ../http/php/mod_createCategory.php:71
-msgid "Please enter a category name!"
-msgstr "Geben sie bitte einen Namen für die Kategorie an! "
-#: ../http/php/mod_createCategory.php:76
-msgid "Please enter a category description!"
-msgstr "Bitte geben sie eine Beschreibung für die Kategorie an!"
-#: ../http/php/mod_createCategory.php:104
-msgid "existing Categories"
-msgstr "vorhandene Kategorien"
-#: ../http/php/mod_createCategory.php:116
-msgid "Category Name"
-msgstr "Kategorie Namen"
-#: ../http/php/mod_createCategory.php:117 ../lib/editGroup.php:219
-#: ../lib/editUser.php:408
-msgid "Description"
-#: ../http/php/mod_createCategory.php:125
-msgid "The Category has been created successfully."
-msgstr "Die Kategorie wurde erfolgreich erstellt."
-#: ../http/php/mod_customTree.php:61
-msgid "You have changed the tree. All changes will be lost. Save changes?"
-msgstr ""
-#: ../http/php/mod_customTree.php:160
-msgid "You are about to delete your customized folder structure. Proceed?"
-msgstr ""
-#: ../http/php/mod_customTree.php:220
-msgid "Configure tree"
-msgstr "Konfiguriere Layerbaum"
-#: ../http/php/mod_customTree.php:221
-msgid "Please select a gui which its tree should be configured."
-msgstr ""
-#: ../http/php/mod_customTree.php:229 ../http/php/mod_customTree.php:236
-msgid "Add"
-msgstr "Hinzufügen"
-#: ../http/php/mod_customTree.php:231
-msgid "Edit"
-msgstr "Editieren"
-#: ../http/php/mod_editElements.php:563
-msgid ""
-"Please make sure you have made a backup of your application before using "
-"this feature! Continue?"
-msgstr ""
-#: ../http/php/mod_layerMetadata.php:277 ../http/php/mod_showMetadata.php:710
-#: ../http/php/mod_showMetadata.php:786
-msgid "Monitoring Abo löschen"
-msgstr ""
-#: ../http/php/mod_layerMetadata.php:283 ../http/php/mod_showMetadata.php:715
-msgid "Subscribe Monitoring"
-#: ../http/php/mod_loadwmc_server.php:32 ../http/php/mod_loadwmc_server.php:34
-msgid "The WMC document could not be found."
-msgstr "Das Dokument konnte nicht gefunden werden."
-#: ../http/php/mod_loadwmc_server.php:46 ../http/php/mod_loadwmc_server.php:48
-msgid "WMC has been deleted from the database."
-msgstr "Das Dokument wurde aus der Datenbank entfernt."
-#: ../http/php/mod_loadwmc_server.php:50 ../http/php/mod_loadwmc_server.php:52
-msgid "WMC could not be deleted."
-msgstr "WMC konnte nicht gelöscht werden."
-#: ../http/php/mod_loadwmc_server.php:78 ../http/php/mod_loadwmc_server.php:87
-#: ../http/php/mod_loadwmc_server.php:101
-#: ../http/php/mod_loadwmc_server.php:80 ../http/php/mod_loadwmc_server.php:89
-#: ../http/php/mod_loadwmc_server.php:103
-msgid "WMC could not be loaded."
-msgstr "WMC konnte nicht geladen werden"
-#: ../http/php/mod_loadwmc_server.php:132
-#: ../http/php/mod_loadwmc_server.php:134
-msgid "WMC could not be merged."
-msgstr ""
-#: ../http/php/mod_loadwmc_server.php:163
-#: ../http/php/mod_loadwmc_server.php:165
-msgid "WMC could not be appended."
-msgstr "WMC konnte nicht angefügt werden."
-#: ../http/php/mod_loadwmc_server.php:174
-#: ../http/php/mod_loadwmc_server.php:176
-msgid "Updated public flag"
-msgstr "Öffentlichkeitsflag wurde aktualisiert"
-#: ../http/php/mod_loadwmc_server.php:177
-#: ../http/php/mod_loadwmc_server.php:179
-msgid "could not update public flag"
-msgstr "Kann Öffentlichkeitsflag nicht aktualisieren."
-msgid "Save configuration as WebMapContext document"
-msgstr "Speichere Konfiguration als WebMapContext Dokument"
-#: ../http/php/mod_map_messages.php:30
-msgid "The following WMS do not support the current SRS"
-msgstr ""
-"Folgende WMS unterstützen das verwendete Koordinatenbezugssystem nicht "
-#: ../http/php/mod_meetingPoint.php:222 ../http/php/mod_meetingPoint.php:223
-msgid "Input too long. Maximum of allowed characters is"
-msgstr "Eingabe zu lang. Maximale Stellenzahl "
-#: ../http/php/mod_savewmc_server.php:75
-#: ../http/php/mod_savewmc_server.php:102
-msgid "saved wmc document to session"
-msgstr "Speichere Dokument zwischen"
-#: ../http/php/mod_savewmc_server.php:84 ../http/php/mod_savewmc_server.php:91
-#: ../http/php/mod_savewmc_server.php:111
-#: ../http/php/mod_savewmc_server.php:118
-msgid "WMC document must have a title."
-msgstr "WebMapContext Dokument braucht einen Titel"
-#: ../http/php/mod_savewmc_server.php:117
-#: ../http/php/mod_savewmc_server.php:145
-msgid "WMC"
-msgstr "WMC"
-msgid "has been saved."
-msgstr "wurde gespeichert."
-#: ../http/javascripts/mod_savewmc.js
-msgid "New / overwrite"
-msgstr "Neu / überschreiben"
-msgid "Categories"
-msgstr "Kategorien"
-#: ../http/php/mod_sessionWmc_server.php:27
-msgid "WMC in session reset."
-msgstr "Zwischenspeicherung wurde verworfen."
-#: ../http/php/mod_sessionWmc_server.php:30
-msgid "No WMC in session found."
-msgstr "Kein Dokument in der Session vorhanden."
-#: ../http/php/mod_sessionWmc_server.php:40
-msgid "No WMC in session."
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:144
-msgid ""
-"The map service contains too many layers. The layers of this service will "
-"not be activated"
-msgstr ""
-"Der Dienst beinhaltet zu viele Ebenen. Die Ebenen werden daher automatisch "
-"deaktiviert."
-#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:194
-msgid "The following Service has been added to the application"
-msgstr "Folgender Dienst wurde in die Anwendung eingebunden."
-#: ../http/javascripts/mod_featureInfoTunnel.php:158
-#: ../http/javascripts/mod_featureInfoTunnel.php:166
-#: ../http/javascripts/mod_wfsGazetteerEditor_client.php:950
-#: ../http/javascripts/mod_wfsGazetteerEditor_client.php:1079
-msgid "No result"
-msgstr "Kein Ergebnis"
-#: ../http/javascripts/mod_georss.php:67
-msgid "mapframe: "
-msgstr "Kartenrahmen: "
-#: ../http/javascripts/mod_georss.php:76
-#: ../http/javascripts/mod_georss.php:121
-msgid "No GeoRSS feed information found. Please check your URL."
-msgstr "Keine GeoRSS gefunden. Bitte checken sie die URL."
-#: ../http/javascripts/mod_help.php:27
-msgid "click highlighted elements for help"
-msgstr ""
-#: ../http/javascripts/mod_poi.php:95
-msgid "Invalid search term"
-msgstr "Invalider Suchbegriff"
-#: ../http/javascripts/mod_poi.php:111
-msgid "Invalid language"
-msgstr "Unzulässige Sprache"
-#: ../http/javascripts/mod_poi.php:125
-msgid "Invalid configuration file"
-msgstr ""
-#: ../http/javascripts/mod_searchCSW_ajax.php:363
-msgid "Record ID"
-msgstr "Datensatz Identifikator"
-#: ../http/javascripts/mod_searchCSW_form.php:49
-msgid "Search catalog metadata"
-msgstr ""
-#: ../http/javascripts/mod_searchCSW_form.php:77
-msgid "Lat-Maz"
-msgstr ""
-#: ../lib/ajax.php:134
-msgid "Fatal error: Could not detect ID of AJAX request."
-msgstr ""
-#: ../lib/ajax.php:144
-msgid "The session has expired. Please log in again."
-msgstr "Die Sitzung ist abgelaufen, bitte melden sie sich erneut an."
-#: ../lib/editGroup.php:189
-msgid "Name"
-msgstr "Name"
-#: ../lib/editGroup.php:198 ../http/plugins/mb_metadata_edit.php:156
-#: ../http/plugins/mb_metadata_wfs_edit.php:155
-msgid "Title"
-msgstr "Titel"
-#: ../lib/editGroup.php:208 ../lib/editUser.php:524
-msgid "Owner"
-msgstr "Eigentümer"
-#: ../lib/editGroup.php:228 ../http/plugins/mb_metadata_edit.php:161
-#: ../http/plugins/mb_metadata_wfs_edit.php:160
-msgid "Address"
-msgstr "Adresse"
-#: ../lib/editGroup.php:237 ../http/plugins/mb_metadata_edit.php:165
-#: ../http/plugins/mb_metadata_wfs_edit.php:164
-msgid "Postcode"
-msgstr "Postleitzahl"
-#: ../lib/editGroup.php:246 ../lib/editUser.php:478
-#: ../http/plugins/mb_metadata_edit.php:169
-#: ../http/plugins/mb_metadata_wfs_edit.php:168
-msgid "City"
-msgstr "Stadt"
-#: ../lib/editGroup.php:255
-msgid "Province"
-msgstr "(Bundes) Land"
-#: ../lib/editGroup.php:264 ../lib/editUser.php:510
-msgid "Country"
-msgstr "Staat"
-#: ../lib/editGroup.php:273
-msgid "Voicetelephone"
-msgstr "Telefonnummer"
-#: ../lib/editGroup.php:282
-msgid "Facsimiletelephone"
-msgstr "Faxnummer"
-#: ../lib/editUser.php:155 ../lib/editUser.php:196
-msgid "Username must be unique!"
-msgstr "Der Nutzername muß eindeutig sein!"
-#: ../lib/editUser.php:273
-msgid "User"
-msgstr "Nutzer"
-#: ../lib/editUser.php:278
-msgid "NEW"
-msgstr "NEU"
-#: ../lib/editUser.php:344
-msgid "Username"
-msgstr "Nutzername"
-#: ../lib/editUser.php:351
-msgid "Firstname"
-msgstr "Vorname"
-#: ../lib/editUser.php:359
-msgid "Lastname"
-msgstr "Nachname"
-#: ../lib/editUser.php:366
-msgid "Academic title"
-msgstr "Akademischer Titel"
-#: ../lib/editUser.php:380
-msgid "Password"
-msgstr "Passwort"
-#: ../lib/editUser.php:393
-msgid "Confirm password"
-msgstr "Passwort bestätigen"
-#: ../lib/editUser.php:416 ../http/plugins/mb_metadata_edit.php:177
-#: ../http/plugins/mb_metadata_wfs_edit.php:176
-msgid "Email"
-msgstr "EMail"
-#: ../lib/editUser.php:424
-msgid "Phone"
-msgstr "Telefon"
-#: ../lib/editUser.php:432
-msgid "Facsimile"
-msgstr "Fax"
-#: ../lib/editUser.php:446
-msgid "Street"
-msgstr "Straße"
-#: ../lib/editUser.php:454
-msgid "Housenumber"
-msgstr "Hausnummer"
-#: ../lib/editUser.php:462
-msgid "Delivery Point"
-msgstr ""
-#: ../lib/editUser.php:470
-msgid "Postal Code"
-#: ../lib/editUser.php:486
-msgid "Organization"
-msgstr "Organisation"
-#: ../lib/editUser.php:494
-msgid "Department"
-msgstr "Behörde"
-#: ../lib/editUser.php:502
-msgid "Position"
-msgstr "Position"
-#: ../lib/editUser.php:543
-msgid "Login_count"
-msgstr "Anzahl der fehlerhaften Einwahlversuche"
-#: ../http/php/mod_showMetadata.php:790
-msgid "Monitoring abonnieren"
-msgstr ""
-#: ../http/javascripts/mod_coordsLookup.php:106
-msgid "Geographic Coordinates"
-msgstr "Geographische Koordinaten"
-msgid "Gauss-Krueger 2"
-msgstr "Gauß-Krüger 2 (DHDN)"
-msgid "Gauss-Krueger 3"
-msgstr "Gauß-Krüger 3 (DHDN)"
-msgid "Gauss-Krueger 4"
-msgstr "Gauß-Krüger 4 (DHDN)"
-msgid "Gauss-Krueger 5"
-msgstr "Gauß-Krüger 5 (DHDN)"
-msgid "UTM 32 North"
-msgstr "UTM 32 Nord (ETRS98)"
-#: ../http/javascripts/mod_wfsGazetteerEditor_client.php:250
-msgid "Informations"
-msgstr "Informationen"
-#: ../http/javascripts/mod_wfsGazetteerEditor_client.php:280
-msgid "Moduletype: Search"
-msgstr "Modulart: Suche"
-#: ../http/javascripts/mod_wfsGazetteerEditor_client.php:284
-msgid "Moduletype: Download"
-msgstr "Modulart: Download"
-#: ../http/javascripts/mod_wfsGazetteerEditor_client.php:301
-msgid "Geometrytype: point"
-msgstr "Geometrietyp: Punkt"
-#: ../http/javascripts/mod_wfsGazetteerEditor_client.php:306
-msgid "Geometrytype: line"
-msgstr "Geometrietyp: Linie"
-#: ../http/javascripts/mod_wfsGazetteerEditor_client.php:311
-msgid "Geometrytype: area"
-msgstr "Geometrietyp: Fläche"
-#: ../http/javascripts/mod_wfsGazetteerEditor_client.php:609
-msgid ""
-"The coordinate reference system (crs) of the objects differ from the crs of "
-"the viewer. A query will not be possible. Please change the crs of the "
-"viewer first."
-msgstr ""
-"Das Koordinatenreferenzsystem (CRS) der Objekte unterscheidet sich vom CRS "
-"des Viewers. Eine Suche ist nicht möglich. Bitte wechseln sie das "
-"Koordinatenreferenzsystem des Viewers."
-#: ../http/javascripts/mod_wfsGazetteerEditor_client.php:961
-msgid "An error occured when start download."
-msgstr "Es ist ein Fehler beim Download aufgetreten."
-#: ../http/javascripts/mod_wfsGazetteerEditor_client.php:1124
-msgid "No information available."
-msgstr "Keine Information verfügbar."
-#: ../http/javascripts/mod_wfsGazetteerEditor_client.php:1206
-msgid "Show information"
-msgstr "Zeige Informationen"
-#: ../http/javascripts/mod_wfsGazetteerEditor_client.php:1210
-msgid "Set spatial filter"
-msgstr "Definiere räumliche Auswahl"
-#: ../http/javascripts/mod_wfsGazetteerEditor_client.php:1214
-msgid "Set attribute filter"
-msgstr "Definiere attributive Auswahl"
-#: ../http/javascripts/mod_wfsGazetteerEditor_client.php:1256
-msgid "Export data"
-msgstr "Exportiere Daten"
-#: ../http/javascripts/mod_wfsGazetteerEditor_client.php:1252
-msgid "Reset filter"
-msgstr "Filter zurücksetzen"
-#: ../http/javascripts/mod_wfsGazetteerEditor_client.php:1249
-msgid "Start query"
-msgstr "Anfrage starten"
-#: ../http/javascripts/mod_wfsGazetteerEditor_client.php:1217
-msgid "Examples (first 20 entries):"
-msgstr "Beispielinhalte (erste 20 Datensätze):"
-#: ../http/javascripts/initWmcObj.php ../http/javascripts/initWmcObj.php:29
-msgid "You as User"
-msgstr "Sie als Nutzer"
-#: ../http/javascripts/initWmcObj.php:31
-msgid "have no authorization to access following layers."
-msgstr "haben keine Berechtigung auf folgende Layer zuzugreifen."
-#: ../http/javascripts/initWmcObj.php:35
-msgid ""
-"Following layers come from an unkown origin. There is no information about "
-"the links. They may be broken and the underlaying services may not exist "
-"anymore!"
-msgstr ""
-"Folgende Layer stammen aus einer der Registry unbekannten Quelle. Es kann "
-"daher nicht überprüft werden, ob die Links verwaist sind oder ob die Dienste "
-"überhaupt Daten liefern."
-#: ../http/javascripts/initWmcObj.php:39
-msgid ""
-"The last monitoring had problems with the following layers. Maybe the "
-"underlying services will not be able to answer the requests for sometime."
-msgstr ""
-"Bei folgenden Diensten kam es während des letzten Monitorings zu Problemen. "
-"Es ist möglich, dass diese Dienste derzeit keine Informationen zur Verfügung "
-"stellen können."
-#: ../http/javascripts/initWmcObj.php:43
-msgid ""
-"Following layers have been removed from the registry. They may be broken and "
-"the underlaying services may not exist anymore!"
-msgstr ""
-"Folgende Dienste/Layer sind aus der Registrierungsstelle gelöscht worden. Es "
-"kann daher nicht überprüft werden, ob die Links verwaist sind oder ob die "
-"Dienste überhaupt Daten liefern."
-#: ../http/javascripts/initWmcObj.php:409
-msgid "MapService"
-msgstr "Kartendienst"
-#: ../http/javascripts/initWmcObj.php:442
-msgid ""
-"The configuration, which should be loaded, consists of different services "
-"which have the following terms of use:"
-msgstr ""
-"Die zu ladende Konfiguration enthält verschiedene Dienste mit folgenden "
-"Nutzungsbedigungen:"
-msgid "Should this services be loaded regardless?"
-msgstr "Sollen die Dienste trotzdem hinzugeladen werden?"
-msgid "Confirmation"
-msgstr "Hinweis"
-#: ../http/php/mod_subscribersServiceList.php:144
-msgid "WebMapService"
-#: ../http/php/mod_subscribersServiceList.php:145
-msgid "Availability of Capabilities"
-msgstr "Verfügbarkeit Dienstebeschreibung"
-#: ../http/php/mod_subscribersServiceList.php:146
-msgid "Average Response Time for GetCapabilities"
-msgstr "Durchschnittliche Antwortzeit Beschreibung"
-#: ../http/php/mod_subscribersServiceList.php:147
-msgid "Availability of GetMap"
-msgstr "Verfügbarkeit Kartenbild"
-#: ../http/php/mod_subscribersServiceList.php:148
-msgid "Availability (2 month)"
-msgstr "Verfügbarkeit (2 Monate)"
-#: ../http/php/mod_subscribersServiceList.php:168
-msgid "Request GetCapabilities"
-msgstr "Aufruf des Capabilities Dokument"
-#: ../http/php/mod_subscribersServiceList.php:186
-msgid "Tested GetMap Request"
-msgstr "Getesteter GetMap Aufruf"
-msgid "Service ID"
-msgstr "Dienst ID"
-msgid "cycles"
-msgstr "Zyklen"
-#: ../http/php/mod_monitorCapabilities_read_single.php
-#: ../http/php/mod_monitorCapabilities_read_single.php:77
-msgid "Monitoring results"
-msgstr "Monitoring Ergebnisse"
-#: ../http/php/mod_monitorCapabilities_read_single.php:80
-msgid "Status"
-msgstr "Status"
-msgid "Response time"
-msgstr "Antwortzeit"
-#: ../http/javascripts/mod_addWMSgeneralFunctions.js
-msgid ""
-"The selected service is already activated in your application and will not "
-"be included again:"
-msgstr ""
-"Der folgende Dienst befindet sich bereits unter 'Aktive Dienste', und wird "
-"nicht erneut hinzugefügt:"
-#: ../ ../http/plugins/mb_metadata_wmcPreview.php:49
-msgid "Preview saved"
-msgstr "Vorschau gespeichert"
-msgid "Preview saved - but following service urls are not included !"
-msgstr "Vorschau gespeichert - aber folgende Dienste fehlen! "
-#: ../http/plugins/mb_metadata_wmcPreview.php:43
-msgid "Preview could not be created"
-msgstr "Vorschau konnte nicht gespeichert werden"
-msgid "Loading application: "
-msgstr "Lade Anwendung: "
-msgid "please wait ... "
-msgstr "Bitte warten ... "
-#: ../tools/mod_mailAbo.php
-msgid ""
-"Mapbender was unable to access the services listed above. These service may "
-"be unreachable on short notice. Please contact the service provider listed "
-"in the service metadata. You will find the metadata by following the link "
-"mentioned above. Note: This e-mail has been sent automatically because you "
-"subscribed to this service. You can unsubscribe by logging in and clicking "
-"the unsubscribe button in the Mapbender metadata dialogue."
-msgstr ""
-"Das GeoPortal hat Probleme beim Zugriff auf die oben in dieser E-Mail "
-"genannten Dienste. Es ist möglich, dass diese kurzfristig nicht verfügbar "
-"sind. Weitere Informationen erhalten Sie auf Anfrage beim "
-"Dienstebereitsteller, der in den Metadaten des Dienstes angegeben ist. "
-"Folgen Sie dazu dem oben in dieser E-Mail aufgeführten Link. Hinweis: Diese "
-"E-Mail wurde automatisiert erzeugt und der Versand von Ihnen beantragt. "
-"Diese E-Mail-Benachrichtigung können Sie jederzeit abbestellen, indem Sie "
-"das Abonnement über die Metadatenanzeige im GeoPortal deaktivieren."
-msgid "Choose kind of coupled metadata"
-msgstr "Art der Metadatenkopplung"
-msgid "Add URL to existing Metadataset"
-msgstr "Link zu einem existierenden Metadatensatz"
-msgid ""
-"Here someone can add a url to an existing metadata record, which is "
-"available over www. The record can either be harvested and pushed to the own "
-"catalogue service or it is only used as a link. This links are pushed into "
-"the service metadata record and the new capabilities document."
-msgstr ""
-"An dieser Stelle kann ein Link zu einem existierenden Metadatensatz "
-"angereichert werden. Der Datensatz kann entweder geharvested und über den "
-"eigenen Katalog veröffentlicht werden oder einfach als Link hinzugefügt "
-"werden. Die Links werden sowohl in die Service Metadaten, als auch in die "
-"INSPIRE Capabilities eingetragen."
-msgid ""
-"Add a simple metadata record which is mostly generated from given layer "
-"information"
-msgstr "Erzeugung eines einfachen Metadatensatz aus Layer Informationen"
-msgid ""
-"With this option someone can generate a very simple metadata record for the "
-"data which is distributed thru the wms layer. The record fulfills only the "
-"INSPIRE Metadata Regulation! Most of the needed data is pulled from the "
-"service, layer and group information of the owner of the service. The "
-"metadate will be created on the fly. It is not stored in the database!"
-msgstr ""
-"Mit dieser Option kann ein sehr einfacher Metadatensatz für die über den WMS "
-"zur Verfügung gestellten Daten generiert werden. Der Datensatz erfüllt dabei "
-"nur die Mindestanforderungen der EU-INSPIRE Richtlinie! Der Großteil der "
-"Daten wird dabei den Service- und Layer-Metadaten, sowie der "
-"Benutzerverwaltung der Registry übernommen. (Informationen über Eigentümer "
-"des Dienstes) Der Datensatz wird weiterhin nicht abgespeichert, sondern "
-"dynamisch -on the fly- erzeugt."
-msgid "Add a simple metadata record from a local file"
-msgstr "Hochladen eines lokalen Metadatensatzes"
-msgid ""
-"With this option someone can upload an existing metadata record and couple "
-"it to the layer. The uploaded data is pushed to the catalogue and will be "
-"available for searching. The uploaded data is not fully controlled and "
-"validated. It cannot be edited but must be replaced with a new record if "
-"needed!"
-msgstr ""
-"Über diese Option kann ein lokal vorliegender existierender Metadatensatz in "
-"die Registry übernommen werden. Der Datensatz wird in der Mapbender "
-"Datenbank abgelegt und über die Katalogschnittstelle nach Außen abgegeben. "
-"Er wird nicht vollständig validiert. Bitte nutzen sie hierzu den INSPIRE "
-"Validator Service. Der Datensatz kann nicht editiert werden, sondern muss "
-"bei Bedarf gelöscht bzw. ausgetauscht werden."
-#: ../http/plugins/mb_metadata_addon.php:17
-msgid "Link Editor"
-msgstr "Link Editor"
-#: ../http/plugins/mb_metadata_addon.php:20
-msgid "Harvest link target and export to CSW"
-msgstr "Link Ziel verfolgen und über CSW veröffentlichen."
-#: ../http/plugins/mb_metadata_addon.php:27
-msgid "Metadata upload"
-msgstr "Metadaten hochladen"
-#: ../http/plugins/mb_metadata_addon.php:32
-msgid "Simple metadata editor"
-msgstr "Einfacher Metadateneditor"
-msgid "Resource title"
-msgstr "Ressourcenbezeichnung"
-msgid ""
-"This a characteristic, and often unique, name by which the resource is known."
-msgstr ""
-"Charakteristische und häufig eindeutige Bezeichnung, unter der die Ressource "
-"bekannt ist. Der Wertebereich dieses Metadatenelements ist Freitext."
-msgid "Resource abstract"
-msgstr "Ressourcenüberblick"
-msgid "This is a brief narrative summary of the content of the resource."
-msgstr ""
-"Kurze beschreibende Zusammenfassung des Ressourceninhalts. Der Wertebereich "
-"dieses Metadatenelements ist Freitext."
-msgid "Lineage"
-msgstr "Herkunft"
-msgid ""
-"This is a statement on process history and/or overall quality of the spatial "
-"data set. Where appropriate it may include a statement whether the data set "
-"has been validated or quality assured, whether it is the official version "
-"(if multiple versions exist), and whether it has legal validity. The value "
-"domain of this metadata element is free text."
-msgstr ""
-"Angaben zum Ablauf der Datenerstellung und/oder zur Gesamtqualität des "
-"Geodatensatzes. Gegebenenfalls kann hierzu auch eine Angabe gehören, ob der "
-"Datensatz validiert oder einer Qualitätssicherung unterzogen worden ist, ob "
-"es sich (im Fall mehrerer Versionen) um die amtliche Version handelt und ob "
-"er Rechtsgültigkeit besitzt. Der Wertebereich dieses Metadatenelements ist "
-"Freitext."
-msgid "TEMPORAL REFERENCE"
-msgstr "ZEITBEZUG"
-msgid ""
-"This metadata element addresses the requirement to have information on the "
-"temporal dimension of the data as referred to in Article 8(2)(d) of "
-"Directive 2007/2/EC. At least one of the metadata elements referred to in "
-"points 5.1 to 5.4 shall be provided. The value domain of the metadata "
-"elements referred to in points 5.1 to 5.4 is a set of dates. Each date shall "
-"refer to a temporal reference system and shall be expressed in a form "
-"compatible with that system. The default reference system shall be the "
-"Gregorian calendar, with dates expressed in accordance with ISO 8601."
-msgstr ""
-"Mit diesem Metadatenelement werden die nach Artikel 8 Absatz 2 Buchstabe d "
-"der Richtlinie 2007/2/EG erforderlichen Informationen zur zeitlichen "
-"Datendimension bereitgestellt. Mindestens eines der in den Unterabsätzen 5.1 "
-"bis 5.4 aufgeführten Metadatenelemente ist anzugeben. Der Wertebereich der "
-"in den Unterabsätzen 5.1 bis 5.4 aufgeführten Metadatenelemente ist eine "
-"Menge von Datumsangaben. Jedes Datum ist einem zeitlichen Bezugssystem "
-"zugeordnet und in einer zu diesem System kompatiblen Form auszudrücken. Die "
-"Voreinstellung für dieses Bezugssystem ist der Gregorianische Kalender mit "
-"Datumsangaben, die ISO 8601 entsprechen."
-msgid "Temporal extent"
-msgstr "Zeitliche Ausdehnung"
-msgid ""
-"The temporal extent defines the time period covered by the content of the "
-"resource. This time period may be expressed as any of the following: - an "
-"individual date, - an interval of dates expressed through the starting date "
-"and end date of the interval, - a mix of individual dates and intervals of "
-"dates."
-msgstr ""
-"Die zeitliche Ausdehnung beschreibt den Zeitraum, der vom Inhalt der "
-"Ressource erfasst wird. Dieser Zeitraum kann in einer der folgenden Weisen "
-"ausgedrückt werden: - als Einzeldatum, - als Datumsintervall unter Angabe "
-"von Anfangs- und Enddatum des Intervalls oder - als Kombination von "
-"Einzeldaten und Datumsintervallen."
-msgid "Spatial resolution"
-msgstr "Räumliche Auflösung"
-msgid ""
-"Spatial resolution refers to the level of detail of the data set. It shall "
-"be expressed as a set of zero to many resolution distances (typically for "
-"gridded data and imagery-derived products) or equivalent scales (typically "
-"for maps or map-derived products). An equivalent scale is generally "
-"expressed as an integer value expressing the scale denominator. A resolution "
-"distance shall be expressed as a numerical value associated with a unit of "
-"length."
-msgstr ""
-"Die räumliche Auflösung bezieht sich auf den Detaillierungsgrad des "
-"Datensatzes und ist als Menge von null bis vielen Auflösungsabständen (in "
-"der Regel für Gitterdaten und aus Bildern abgeleitete Produkte) oder als "
-"äquivalente Maßstäbe (in der Regel für Karten und daraus abgeleitete "
-"Produkte) anzugeben."
-#: ../http/plugins/mb_metadata_addon.php:78
-msgid "Ground distance in [m]"
-msgstr "Bodenauflösung in [m]"
-#: ../http/plugins/mb_metadata_addon.php:82
-msgid "Scale denominator [1:X]"
-msgstr "Nenner eines äquivalenten Maßstabs [1:X]"
-msgid "Value of resolution"
-msgstr "Wert der räumlichen Auflösung"
-msgid "Value of spatial resolution in [m] or scale denominator"
-msgstr "Wert der räumlichen Auflösung in [m] oder Nenner des Maßstabes"
-msgid "Coordinate Reference System"
-msgstr "Koordinatenreferenzsystem"
-msgid "Description of the coordinate reference system(s) used in the data set."
-msgstr ""
-"Beschreibung des Koordinatenreferenzsystems bzw. der "
-"Koordinatenreferenzsysteme, die im Datensatz verwendet werden."
-msgid "Encoding"
-msgstr "Datenablageformat"
-msgid ""
-"Description of the computer language construct(s) specifying the "
-"representation of data objects in a record, file, message, storage device or "
-"transmission channel."
-msgstr ""
-"Beschreibung des Programmiersprachenkonstrukts, das die Darstellung eines "
-"Datenobjekts in einem Datensatz, in einer Datei, einer Nachricht, einem "
-"Speichermedium oder einem Übertragungskanal bestimmt."
-msgid "Character Encoding"
-msgstr "Zeichenkodierung"
-msgid ""
-"The character encoding used in the data set. This element is mandatory only "
-"if an encoding is used that is not based on UTF-8."
-msgstr ""
-"die im Datensatz verwendete Zeichenkodierung. Dieses Element ist nur dann "
-"erforderlich, wenn eine nicht auf UTF-8 basierende Kodierung verwendet wird."
-msgid "Topological Consistency"
-msgstr "Topologische Konsistenz"
-msgid ""
-"Correctness of the explicitly encoded topological characteristics of the "
-"data set as described by the scope. This element is mandatory only if the "
-"data set includes types from the Generic Network Model and does not assure "
-"centreline topology (connectivity of centrelines) for the network."
-msgstr ""
-"Stichhaltigkeit/Genauigkeit der explizit kodierten topologischen Merkmale "
-"des im Geltungsbereich beschriebenen Datensatzes. Dieses Element ist nur "
-"dann erforderlich, wenn der Datensatz Typen des Generischen Netzwerkmodells "
-"(Generic Network Model) enthält und keine Mittellinientopologie "
-"(Konnektivität von Mittellinien) für das Netzwerk gewährleistet."
-#: ../http/plugins/mb_metadata_addon.php:49
-msgid "from"
-msgstr "von"
-#: ../http/plugins/mb_metadata_addon.php:51
-msgid "to"
-msgstr "bis"
-msgid "Maintenance and update frequency"
-msgstr "Pflege-/ Aktualisierungszyklus"
-msgid ""
-"Frequency with which changes and additions are made to the resource after "
-"the initial resource is completed. Notice: This value may change the value "
-"of the end date of temporal extent. The end date will be computed "
-"automatically from the current timestamp if a cyclic update is defined!"
-msgstr ""
-"Intervall in dem Änderungen und Anpassungen an der Ressource erfolgen nach "
-"dem diese erstmalig erstellt wurde. Hinweis: Eine Auswahl eines regelmäßigen "
-"Aktualisierungsintervalls ändert den Endzeitpunkt der zeitlichen Ausdehnung. "
-"Der Endzeitpunkt wird dann immer anhand des aktuellen Datums berechnet. Da "
-"die Metadaten dynamisch erzeugt werden, muss man sie nicht mehr händisch "
-"anpassen."
-#: ../http/plugins/mb_metadata_addon.php:57
-msgid "continual"
-msgstr "kontinuierlich"
-#: ../http/plugins/mb_metadata_addon.php:58
-msgid "daily"
-msgstr "täglich"
-#: ../http/plugins/mb_metadata_addon.php:59
-msgid "weekly"
-msgstr "wöchentlich"
-#: ../http/plugins/mb_metadata_addon.php:60
-msgid "fortnightly"
-msgstr "zweiwöchentlich"
-#: ../http/plugins/mb_metadata_addon.php:61
-msgid "monthly"
-msgstr "monatlich"
-#: ../http/plugins/mb_metadata_addon.php:62
-msgid "quarterly"
-msgstr "vierteljährlich"
-#: ../http/plugins/mb_metadata_addon.php:63
-msgid "biannually"
-msgstr "halbjährlich"
-#: ../http/plugins/mb_metadata_addon.php:64
-msgid "annually"
-msgstr "jährlich"
-#: ../http/plugins/mb_metadata_addon.php:65
-msgid "as needed"
-msgstr "nach Bedarf"
-#: ../http/plugins/mb_metadata_addon.php:66
-msgid "irregular"
-msgstr "unregelmäßig"
-#: ../http/plugins/mb_metadata_addon.php:68
-msgid "not planned"
-msgstr "nicht geplant"
-#: ../http/plugins/mb_metadata_addon.php:70
-msgid "unknown"
-msgstr "unbekannt"
-#: ../http/geoportal/mod_allow_publishing_metadata.php
-msgid "Registrating institutions"
-msgstr "Registrierende Stellen"
-msgid "My (metadata-)provider"
-msgstr "Meine (Metadaten-)Provider"
-msgid "There are too many primary groups defined for the user with ID: "
-msgstr ""
-"Fehler: Es wurden zu viele primäre Gruppen für den Nutzer mit folgender ID "
-"definiert: "
-msgid ""
-"You have not yet an primary group. Please contact the central system admin "
-"to define a primary group for user with ID: "
-msgstr ""
-"Sie sind noch keiner primären Gruppe zugewiesen. Bitte kontaktieren sie den "
-"Zentraladministrator um Nutzer mit folgender ID eine primäre Gruppe "
-"zuzuweisen: "
-msgid "You have no rights to use this module!"
-msgstr "Sie haben keine Berechtigung dieses Modul zu nutzen!"
-#: ../http/geoportal/mod_readOpenSearchResultsDetail.php
-msgid "Contact"
-msgstr "Kontakt"
-msgid "Metadata identifier"
-msgstr "Metadatenidentifikator"
-msgid "Resource type"
-msgstr "Art der Ressource"
-msgid "Resource locator"
-msgstr "Adresse zur Ressource"
-msgid "Unique resource identifier id"
-msgstr "ID des eindeutigen Identifikators"
-msgid "Unique resource identifier namespace"
-msgstr "Namensraum des eindeutigen Identifikators"
-msgid "Language"
-msgstr "Sprache"
-msgid "Coupled resource"
-msgstr "Verknüpfte Ressource"
-msgid "Topic category"
-msgstr "ISO Themengebiet"
-msgid "Spatial data service type"
-msgstr "Art des Geodatendienstes"
-msgid "Keyword value"
-msgstr "Suchbegriff"
-msgid "Geographic bounding box"
-msgstr "Geographische Ausdehnung"
-msgid "Date of publication"
-msgstr "Datum der Veröffentlichung"
-msgid "Date of creation"
-msgstr "Datum der Erstellung"
-msgid "Date of last revision"
-msgstr "Datum der letzten Überarbeitung"
-msgid "Equivalent scale"
-msgstr "Vergleichsmaßstab"
-msgid "Ground Distance Value"
-msgstr "Bodenauflösung"
-msgid "Specification title"
-msgstr "Titel der Spezifikation"
-msgid "Specification reference date"
-msgstr "Datum der Spezifikation"
-msgid "Degree of conformance"
-msgstr "Grad der Konformität"
-msgid "Conditions applying to access and use"
-msgstr "Nutzungsbedingungen"
-msgid "Access constraints code"
-msgstr "Code für Zugangsbeschränkungen"
-msgid "Other constraints"
-msgstr "Andere Zugangsbeschränkungen"
-msgid "Responsible party name"
-msgstr "Name der veantwortlichen Stelle"
-msgid "Responsible party email"
-msgstr "E-Mail Adresse der verantwortlichen Stelle"
-msgid "Responsible party role"
-msgstr "Rolle der verantwortlichen Stelle"
-msgid "Overview"
-msgstr "Übersicht"
-msgid "Properties"
-msgstr "Eigenschaften"
-msgid "Terms of use"
-msgid "Common"
-msgstr "Allgemein"
-msgid "Geographic extent"
-msgid "Service information"
-msgstr "Informationen zum Dienst"
-msgid "Data/Service provider"
-msgstr "Daten-/Dienstanbieter"
-msgid "Metadata provider"
-msgstr "Anbieter der Metadaten"
-msgid "Conditions"
-msgstr "Bedingungen"
-msgid "Access constraints"
-msgstr "Zugangsbeschränkungen"
-msgid "Validity"
-msgstr "Gültigkeit"
-msgid "Resolution"
-msgstr "Auflösung"
-msgid "Metadata point of contact email"
-msgstr "Metadatenkontakt E-Mail"
-msgid "Metadata point of contact name"
-msgstr "Name der Kontaktstelle für Metadaten"
-msgid "Metadata date"
-msgstr "Datum der Metadaten"
-msgid "Metadata language"
-msgstr "Sprache der Metadaten"
-msgid "Coordinate reference system"
-msgid "Character encoding"
-msgstr "Zeichensatz"
-msgid "Interfaces"
-msgstr "Schnittstellen"
-msgid "Konfigure tree"
-msgstr ""
-#: ../http/php/mod_wmc2ol.php:624 ../http/php/mod_wmc2ol.php:693
-msgid ""
-"Some georss entries does not have numeric values for CRS or coordinates! For "
-"security reasons the script will die!"
-msgstr ""
-#: ../http/plugins/mb_metadata_addon.php:84
-msgid "Please set the resolution type!"
-msgstr ""
-#: ../http/plugins/mb_metadata_addon.php:97
-msgid "EPSG:"
-msgstr ""
-#: ../http/plugins/mb_metadata_addon.php:109
-msgid "Database"
-msgstr ""
-#: ../http/plugins/mb_metadata_addon.php:110
-msgid "Esri Shape"
-msgstr ""
-#: ../http/plugins/mb_metadata_addon.php:111
-msgid "MapInfo Tab file"
-msgstr ""
-#: ../http/plugins/mb_metadata_addon.php:112
-msgid "CSV"
-msgstr ""
-#: ../http/plugins/mb_metadata_addon.php:113
-msgid "GML"
-msgstr ""
-#: ../http/plugins/mb_metadata_addon.php:119
-msgid "utf8"
-msgstr ""
-#: ../http/plugins/mb_metadata_addon.php:120
-msgid "latin1"
-msgstr ""
-#: ../http/plugins/mb_metadata_edit.php:18
-#: ../http/plugins/mb_metadata_wfs_edit.php:18
-msgid "INSPIRE 1.1: resource title"
-msgstr ""
-#: ../http/plugins/mb_metadata_edit.php:23
-#: ../http/plugins/mb_metadata_wfs_edit.php:23
-msgid "INSPIRE 1.2: resource abstract"
-msgstr ""
-#: ../http/plugins/mb_metadata_edit.php:24
-msgid "Help for INSPIRE Abstract"
-msgstr ""
-msgid ""
-"INSPIRE demands some information about the spatial resolution in the "
-"abstract tag of the capabilities document. Please insert some words about it."
-msgstr ""
-#: ../http/plugins/mb_metadata_edit.php:29
-#: ../http/plugins/mb_metadata_wfs_edit.php:28
-msgid "INSPIRE 3: keyword"
-msgstr ""
-#: ../http/plugins/mb_metadata_edit.php:34
-#: ../http/plugins/mb_metadata_wfs_edit.php:33
-msgid "INSPIRE 8.1: conditions applying to access and use"
-msgstr ""
-#: ../http/plugins/mb_metadata_edit.php:39
-#: ../http/plugins/mb_metadata_wfs_edit.php:38
-msgid "INSPIRE 8.2: limitations on public access"
-msgstr ""
-#: ../http/plugins/mb_metadata_edit.php:62
-msgid "Restricted Network Access (Registry)"
-msgstr ""
-#: ../http/plugins/mb_metadata_edit.php:87
-#: ../http/plugins/mb_metadata_wfs_edit.php:86
-msgid "INSPIRE 9.1: responsible party name"
-msgstr ""
-#: ../http/plugins/mb_metadata_edit.php:112
-msgid "INSPIRE 9.1: responsible party email"
-msgstr ""
-#: ../http/plugins/mb_metadata_edit.php:117
-msgid "INSPIRE 5.2: date of publication"
-msgstr ""
-#: ../http/plugins/mb_metadata_edit.php:122
-#: ../http/plugins/mb_metadata_wfs_edit.php:121
-msgid "INSPIRE 10.2: metadata date"
-msgstr ""
-msgid "Metadata Point of contact (registry)"
-msgstr ""
-msgid ""
-"Information about the organization which is responsible for contributing the "
-"metadata. The information will be automaticcaly generated from the mapbender "
-"database mb_group object. The information came from the primary group of the "
-"service owner or from a group which has authorized the owner to publish "
-"metadata in their name."
-msgstr ""
-#: ../http/plugins/mb_metadata_edit.php:142
-#: ../http/plugins/mb_metadata_wfs_edit.php:141
-msgid "Organization responsible for metadata"
-msgstr ""
-#: ../http/plugins/mb_metadata_edit.php:151
-#: ../http/plugins/mb_metadata_wfs_edit.php:150
-msgid ""
-"Selection of different organizations which authorized you to publish "
-msgstr ""
-#: ../http/plugins/mb_metadata_edit.php:158
-#: ../http/plugins/mb_metadata_wfs_edit.php:157
-msgid "INSPIRE 10.1: metadata point of contact name"
-msgstr ""
-#: ../http/plugins/mb_metadata_edit.php:173
-#: ../http/plugins/mb_metadata_wfs_edit.php:172
-msgid "Telephone"
-msgstr ""
-#: ../http/plugins/mb_metadata_edit.php:179
-#: ../http/plugins/mb_metadata_wfs_edit.php:178
-msgid "INSPIRE 10.1: metadata point of contact email"
-msgstr ""
-#: ../http/plugins/mb_metadata_edit.php:182
-#: ../http/plugins/mb_metadata_wfs_edit.php:181
-msgid "Logo url"
-msgstr ""
-#: ../http/plugins/mb_metadata_layer.php:63
-msgid ""
-"Linking the WMS layer with a metadata set (coupled resource), which "
-"describes the underlying information of the representation in more detail "
-"(eg actuality / quality). It can be done by linking to an already existing "
-"metadata set (e.g. in a catalogue) or by generating a simple metadata file "
-"using mapbender."
-msgstr ""
-#: ../http/plugins/mb_metadata_layer.php:66
-msgid "Table of coupled Metadata"
-msgstr ""
-#: ../http/plugins/mb_metadata_server.php:56
-msgid "WMS ID"
-msgstr ""
-#: ../http/plugins/mb_metadata_server.php:57
-msgid "title"
-msgstr ""
-#: ../http/plugins/mb_metadata_server.php:58
-msgid "last change"
-msgstr ""
-#: ../http/plugins/mb_metadata_server.php:59
-msgid "creation"
-msgstr ""
-#: ../http/plugins/mb_metadata_server.php:60
-msgid "version"
-msgstr ""
-#: ../http/plugins/mb_metadata_server.php:61
-msgid "status"
-msgstr ""
-#: ../http/plugins/mb_metadata_server.php:62
-msgid "wms id"
-msgstr ""
-#: ../http/plugins/mb_metadata_server.php:461
-msgid "Could not read layer ID "
-msgstr ""
-#: ../http/plugins/mb_metadata_server.php:472
-msgid "Could not get layer with ID "
-msgstr ""
-#: ../http/plugins/mb_metadata_server.php:640
-msgid "Could not update metadata object in database!"
-msgstr ""
-#: ../http/plugins/mb_metadata_server.php:751
-msgid "Could not load metadata from source url!"
-msgstr ""
-#: ../http/plugins/mb_metadata_server.php:767
-msgid "Temporary file could not be parsed!"
-msgstr ""
-#: ../http/plugins/mb_metadata_server.php:836
-#: ../http/plugins/mb_metadata_server.php:1028
-msgid "Insert of harvested metadata into database failed!"
-msgstr ""
-#: ../http/plugins/mb_metadata_server.php:840
-msgid ""
-"Problem with parsing the XML structure with SimpleXML! Record was not "
-"inserted into database! Ask your administrator."
-msgstr ""
-#: ../http/plugins/mb_metadata_server.php:856
-msgid "Insert of link into database failed!"
-msgstr ""
-#: ../http/plugins/mb_metadata_server.php:873
-#: ../http/plugins/mb_metadata_server.php:1044
-msgid "Cannot get metadata record with following uuid from database: "
-msgstr ""
-#: ../http/plugins/mb_metadata_server.php:890
-#: ../http/plugins/mb_metadata_server.php:1061
-msgid "Cannot write relation between ows and metadata to database!"
-msgstr ""
-#: ../http/plugins/mb_metadata_server.php:911
-msgid "Could not delete metadata from database!"
-msgstr ""
-#: ../http/plugins/mb_metadata_server.php:962
-msgid "Reading file "
-msgstr ""
-#: ../http/plugins/mb_metadata_server.php:969
-msgid "Parsing ISO19139 XML failed!"
-msgstr ""
-#: ../http/plugins/mb_metadata_wfs_edit.php:58
-msgid "Selection of predefined licences."
-msgstr ""
-#: ../http/plugins/mb_metadata_wmcPreview.php:53
-msgid ""
-"Preview saved - but following service urls are not included cause the "
-"firewall prevent this!"
-msgstr ""
-#: ../http/plugins/mb_metadata_wmcPreview.php:62
-msgid "invalid method"
-msgstr ""
-#: ../http/javascripts/mod_wfsLayerObj_conf.js:13
-msgid "none"
-msgstr ""
-#: ../http/javascripts/mod_wfsLayerObj_conf.js:30
-msgid "Set WFS for layer"
-msgstr ""
-#: ../http/javascripts/mod_wfsLayerObj_conf.js:36
-msgid "Cancel"
-msgstr ""
-msgid "Kind of resource"
-msgid "Map Service"
-msgid "Data Service"
-msgid "Map Layer"
-msgstr "Kartenebene"
-msgid "Featuretype"
-msgstr "Objektart"
-msgid "Type of geometry"
-msgstr "Geometrietyp"
-msgid "Resourceidentifier"
-msgstr "Ressourcenidentifikator"
-msgid "Name of the resource"
-msgstr "Name der Ressource"
-msgid "Information about the service"
-msgid "Extent"
-msgstr "Ausdehnung"
-msgid "Responsible party for content"
-msgstr "Inhaltlich verantwortliche Stelle"
-msgid "Responsible party for service"
-msgstr "Technisch verantwortliche Stelle"
-msgid "Contact person"
-msgstr "Ansprechpartner"
-msgid "Logo"
-msgstr "Logo"
-msgid "Availability"
-msgstr "Verfügbarkeit"
-msgid "Problem with last monitoring!"
-msgstr "Probleme beim letzten Monitoring!"
-msgid "Last Monitoring: OK"
-msgstr "Letztes Monitoring OK"
-msgid "Servicedescription changed!"
-msgstr "Dienstebeschreibung hat sich geändert!"
-msgid "Layer not queryable"
-msgstr "Ebene nicht abfragbar"
-msgid "Layer queryable"
-msgstr "Ebene abfragbar"
-msgid "Query"
-msgstr "Abfragbarkeit"
-msgid "Visibility"
-msgstr "Sichtbarkeit"
-msgid "Minimum scale"
-msgstr "Minimaler Maßstab"
-msgid "Maximum scale"
-msgstr "Maximaler Maßstab"
-msgid "Used Coordinate Reference System"
-msgstr "Eingestelltes Koordinatenreferenzsystem"
-msgid "Spatial Extent"
-msgstr "Räumliche Ausdehnung"
-msgid "Corner in geographic Coordinates"
-msgstr "Eckpunkte in geogr. Koordinaten"
-msgid "Geoportal Capabilities"
-msgstr "Geoportal Capabilities"
-msgid "Original Capabilities"
-msgstr "Original Capabilities"
-msgid "Dataschema"
-msgstr "Link zum Datenschema"
-msgid "KML"
-msgstr "KML"
-msgid "INSPIRE Service Metadata"
-msgstr "INSPIRE Service Metadaten"
-msgid "Metadatarecord"
-msgstr "Metadatendatei"
-msgid "Secured Capabilities URL"
-msgstr "Abgesicherte Capabilities URL"
-msgid "INSPIRE Capabilities URL"
-msgstr "INSPIRE Capabilities URL"
-msgid "Link to Capabilities document"
-msgstr "Link zum Capabilities Dokument"
-msgid "Validation against INSPIRE Geoportal"
-msgstr "Validierung gegen INSPIRE Geoportal"
-msgid "Start validation"
-msgstr "Validierung starten"
-msgid "stable"
-msgstr "Stabil"
-msgid "Description changed - update necessary"
-msgstr "Beschreibung hat sich geändert - Aktualisierung nötig"
-msgid "Problem at last control"
-msgstr "Problem bei letzter Kontrolle"
-msgid "Web Map Context document"
-msgstr "Web Map Context Dokument"
-msgid "Graphical Overview not active"
-msgstr "Graphische Übersicht nicht aktiviert"
-msgid "Information about Quality is only available if the service monitoring is activated!"
-msgstr "Informationen über die Qualität sind nur verfügbar, wenn das Service Monitoring aktiv ist!"
-msgid "In case of Web Map Context Documents the Quality part is not applicable!"
-msgstr "Für Web Map Context Dokumente entfällt die Angabe zur Qualität!"
-msgid "No informations about terms of use are available!"
-msgstr "Es sind keine Informationen über Nutzungsbedingungen verfügbar!"
-msgid "Link to start application with WMC"
-msgstr "Link um Anwendung mit WMC zu starten"
-msgid "validate"
-msgstr "Validierung"
-msgid "uploaded metadata"
-msgstr "Hochgeladene Metadaten"
-msgid "linked metadata"
-msgstr "Verlinkte Metadaten"
-msgid "metadata from capabilities"
-msgstr "Metadaten von Service Capabilities"
-msgid "added from registry"
-msgstr "Metadaten über Registry angereichert"
-msgid "Coupled Metadata"
-msgstr "Verknüpfte Metadaten"
-msgid "Show map in own viewer"
-msgstr "Karte im eigenen Viewer anzeigen"
-msgid "Show map"
-msgstr "Karte anzeigen"
-msgid "Search for addresses"
-msgstr "Suche nach Adressen"
-msgid "Last WMS cannot be removed"
-msgstr "Der letzte WMS kann nicht entfernt werden"
-msgid "FeatureInfoFormat"
-msgstr "Sachdatenformat"
-msgid "ExceptionFormat"
-msgstr "Fehlermeldungen"
-msgid "Transparency"
-msgstr "Transparenz"
-msgid "MapFormat"
-msgstr "Bildformat"
-msgid "Help for address search"
-msgstr "Hilfe zur Adresssuche"
-#: ../plugins/mod_downloadFeedClient.php
-msgid "INSPIRE ATOM Feed Client"
-msgstr "INSPIRE ATOM Feed Client"
-msgid "ATOM Feed url"
-msgstr "URL zum ATOM Feed"
-msgid "Dataset title"
-msgstr "Bezeichnung"
-msgid "Dataset abstract"
-msgstr "Beschreibung"
-msgid "Rights"
-msgstr "Rechtliche Angaben"
-msgid "Available representations"
-msgstr "Verfügbare Varianten"
-msgid "Select to download dataset"
-msgstr "Auswahl zum Download"
-#: ../php/mb_getWmsData.php
-msgid "Old layer name: "
-msgstr "Alter Layername: "
-msgid " - changed to: "
-msgstr " - geändert zu: "
-msgid "has been updated"
-msgstr "wurde aktualisiert"
-msgid "You may want to check the changes as you are an owner or subscriber of this WMS. If you have integrated the service into a gis client, you have to reconfigure the client!"
-msgstr "Als Abonnent oder Eigentümer einer Anwendung, in der der WMS eingebunden ist, sollten Sie die Änderungen kontrollieren. Wenn Sie den Dienst in einem GIS Client eingebunden haben, müssen Sie dessen Konfiguration aktualisieren!"
-msgid "Note: This e-mail has been sent automatically because you subscribed to this service. You can unsubscribe by logging in and clicking the unsubscribe button in the Mapbender metadata dialogue by following the given link."
-msgstr "Zu beachten: Diese Mail wurde automatisch versendet, weil Sie entweder den betroffenen Dienst abonniert haben oder der Dienst in einer Ihrer Mapbender Anwendungen integriert ist. Sie können diese Benachrichtigung deaktivieren, wenn Sie sich am Portal anmelden und dann das Abo über die Metadatenanzeige ausschalten."
-msgid "Attention - following layers have been renamed"
-msgstr "Achtung - folgende Layer wurden bei der Aktualisierung vom Anbieter umbenannt"
-msgid "Update of an observed WMS"
-msgstr "Aktualisierung eines beobachteten WMS"
-msgid "Other owners of this WMS have been informed about the changes!"
-msgstr "Andere Nutzer und die Abonnenten dieses WMS wurden per Mail über die Änderungen informiert!"
-msgid "When notifying the owners of this WMS about your changes, an error occured"
-msgstr "Bei der Benachrichtigung der Nutzer und Abonnenten über die Änderungen am WMS trat ein Fehler auf"
-msgid "Note on protection of privacy"
-msgstr "Datenschutzhinweis"
-msgid "Constraints on public access"
-msgstr "Beschränkungen des öffentlichen Zugangs"
-msgid "Information about costs/fees/licences"
-msgstr "Angaben zu Kosten/Gebühren/Lizenzen"
-msgid "Licence"
-msgstr "Lizenz"
-msgid "This Service is <b>not available via www</b> but only in special networks. Possibly you get further information about the network availability in the following paragraph.<br>"
-msgstr "Der Dienst ist <b>nicht im Internet</b> sondern nur in ausgewählten  Netzwerken (z.B. Intranets) verfügbar. Genauere Angaben erhalten Sie ggf. im folgenden Abschnitt.<br>"
-msgid "The access on this service is logged <b>user-related</b> by the provider. The logging is done to support automated settlement based on a contract "
-msgstr "Die Zugriffe auf den Dienst werden vom Anbieter <b>nutzerbezogen</b> aufgezeichnet. Dies erfolgt entweder zur Abrechnung vertraglicher Vereinbarungen "
-msgid "or to fulfill legal standards.<br><b>If you do not agree on this - please don't use this service!</b><br>"
-msgstr "oder aufgrund gesetzlicher Vorgaben.<br><b>Wenn Sie hiermit nicht einverstanden sein sollten, nutzen Sie diesen Dienst nicht!</b><br>"
-msgid "If you have further questions, please contact the provider under "
-msgstr "Falls Sie weitere Fragen haben, kontaktieren Sie bitte den Anbieter unter "
-msgid "The provider have defined a charge of <b>"
-msgstr "Der Anbieter dieses Dienstes hat ein allgemeines Nutzungsentgelt von <b>"
-msgid " (euro)cent per megapixel</b> "
-msgstr " Cent pro Megapixel</b> "
-msgid " for retrieved picture data. The retrieving of a typical map with a standardized resolution of 600x400 px will cost <b>"
-msgstr " für abgerufene Bildinformationen angegeben. Das Abrufen eines Kartenbildes in einer Standardauflösung von 600x400 Pixeln kostet dementsprechend <b>"
-msgid " euro</b>. For information about possible discounts please contact "
-msgstr " Euro</b>. Angaben zu eventuell möglichen Rabatten erhalten Sie über "
-msgid "The coordinate reference system (crs) of the objects differ from the crs of the viewer"
-msgstr "Das Koordinatensystem (CRS) der abgefragten Objekte unterscheidet sich vom Koordinatensystem des Viewers"
-msgid "A query will not be possible."
-msgstr "Eine Abfrage ist nicht möglich."
-msgid "Please switch viewer crs to"
-msgstr "Bitte wechseln sie das Koordinatensystem auf"
-msgid "CRS Error"
-msgstr "Fehler bei den Koordinatensystemen"
-msgid "Please choose a requestable Layer"
-msgstr "Wählen Sie bitte die abfragbare Ebene aus"
-msgid "Please enable some layer to be requestable"
-msgstr "Aktivieren Sie bitte die Abfragbarkeit einer Ebene"
-msgid "No legend available"
-msgstr "Keine Legende verfügbar"
-msgid "Download options for dataset(s)"
-msgstr "Downloadmöglichkeiten für Datensatz(-sätze)"
-msgid "Download raster data from INSPIRE Download Service"
-msgstr "Download von Rasterdaten über INSPIRE Downloaddienst"
-msgid "Download linked data from INSPIRE Download Service"
-msgstr "Download von verlinkten Daten über INSPIRE-EU Downloaddienst"
-msgid "Used dataset(s)"
-msgstr "Verwendeter Datensatz bzw. -sätze"
-msgid "Download GML data from INSPIRE Download Service"
-msgstr "Download von GML Daten über INSPIRE Downloaddienst"
-msgid "spatial dataset"
-msgstr "Geodatensatz"
-msgid "The document includes data resources from different organizations. The following parapgraph shows the different terms of use for the includes resources:"
-msgstr "Das vorliegende Dokument enthält Datenquellen von unterschiedlichen Stellen. Diese unterliegen den im folgenden aufgeführten Nutzungsbedingungen:"
-msgid "Web Map Service"
-msgid "Web Feature Service"
-msgstr "Datendienst"
+# SOME DESCRIPTIVE TITLE.
+# Copyright (C) YEAR THE PACKAGE'S COPYRIGHT HOLDER
+# This file is distributed under the same license as the PACKAGE package.
+# FIRST AUTHOR <EMAIL at ADDRESS>, YEAR.
+#, fuzzy
+msgid ""
+msgstr ""
+"Project-Id-Version: PACKAGE VERSION\n"
+"Report-Msgid-Bugs-To: \n"
+"POT-Creation-Date: 2011-07-29 15:31+0200\n"
+"PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
+"Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
+"Language-Team: LANGUAGE <LL at li.org>\n"
+"MIME-Version: 1.0\n"
+"Content-Type: text/plain; charset=UTF-8\n"
+"Content-Transfer-Encoding: 8bit\n"
+#: printPDF.conf:13
+msgid "Download: Map as PDF..."
+msgstr "Download: Karte als PDF..."
+#: printPDF.conf:26
+msgid "print legend"
+msgstr "Legende drucken"
+#: printPDF.conf:30
+msgid "Legend"
+msgstr "Legende"
+#: printPDF.conf:31
+msgid "powered by Mapbender"
+msgstr "mit Unterstützung von Mapbender"
+#: printPDF.conf:60
+msgid "Print preview"
+msgstr "Druckansicht"
+#: printPDF.conf:63
+msgid "Scale 1:"
+msgstr "Maßstab 1:"
+#: printPDF.conf:64
+msgid "Date:"
+msgstr "Datum:"
+#: printPDF.conf:66
+msgid "Notes:"
+msgstr "Notizen:"
+#: printPDF.conf:73
+msgid ""
+"This copy has been generated automatically and is valid without signature."
+msgstr "Der Auszug wurde maschinell erzeugt. Er ist ohne Unterschrift gültig."
+#: printPDF.conf:74
+msgid ""
+"This copy is protected by law (Par. 3 Abs. 1 VermKatG NW). It can be "
+"duplicated, modified, published or be passed to third parties only in "
+"agreement with"
+msgstr ""
+"Dieser Auszug ist gesetzlich geschützt (§ 3 Abs. 1 VermKatG NW). "
+"Vervielfältigungen, Umarbeitungen, Veröffentlichungen oder die Weitergabe an "
+"Dritte nur mit Zustimmung des"
+#: printPDF.conf:75
+msgid ""
+"the publisher, except duplicates and modifications aimed at internal use of "
+"government agencies or private use."
+msgstr ""
+"Herausgebers, ausgenommen Vervielfältigungen und Umarbeitungen zur "
+"innerdienstlichen Verwendung bei Behörden oder zum eigenen Gebrauch."
+#: printPDF.conf:
+msgid "This copy is protected by law (Par. 3 Abs. 1 VermKatG NW)."
+msgstr "Dieser Auszug ist gesetzlich geschützt (Par. 3 Abs. 1 VermKatG NW)."
+#: printPDF.conf:
+msgid ""
+"It can be duplicated, modified, published or be passed to third parties only "
+"in"
+msgstr ""
+"Umarbeitungen, Veröffentlichungen oder die Weitergabe an Dritte nur mit"
+#: printPDF.conf:
+msgid "agreement with the publisher except duplicates and modifications"
+msgstr ""
+"Zustimmung des Herausgebers, ausgenommen Vervielfältigungen und Umarbeitungen"
+#: printPDF.conf:
+msgid "aimed at internal use of government agencies or private use."
+msgstr ""
+"zur innerdienstlichen Verwendung bei Behörden oder zum eigenen Gebrauch."
+#: printPDF.conf:94
+msgid "Format"
+msgstr "Format"
+#: printPDF.conf:101
+msgid "Orientation"
+msgstr "Ausrichtung"
+#: printPDF.conf:102
+msgid "portrait"
+msgstr "Hochformat"
+#: printPDF.conf:103
+msgid "landscape"
+msgstr "Querformat"
+#: printPDF.conf:104
+msgid "Quality"
+msgstr "Qualität"
+#: printPDF.conf:105 printPDF.conf:106
+#, php-format
+msgid "Quality: %d dpi"
+msgstr "Qualität: %d dpi"
+#: printPDF.conf:108
+msgid "Comment"
+msgstr "Kommentar"
+msgid "max."
+msgstr "max."
+#: printPDF.conf:111 ../http/plugins/mb_print.php:229
+msgid "print"
+msgstr "drucken"
+#: mod_printPDF.php:
+msgid "No format selected"
+msgstr "Bitte wählen Sie ein Format aus"
+#: mod_digitize_messages.php:18 ../http/php/mod_digitize_messages.php:18
+msgid "polygon"
+msgstr "Polygon"
+#: mod_digitize_messages.php:19 ../http/php/mod_digitize_messages.php:19
+msgid "line"
+msgstr "Linie"
+#: mod_digitize_messages.php:20 ../http/php/mod_digitize_messages.php:20
+msgid "point"
+msgstr "Punkt"
+#: mod_digitize_messages.php:21 ../http/php/mod_digitize_messages.php:21
+msgid "Not an integer value."
+msgstr "Kein Integer-Wert."
+#: mod_digitize_messages.php:22 ../http/php/mod_digitize_messages.php:22
+msgid "Not a double value."
+msgstr "Kein Double-Wert."
+#: mod_digitize_messages.php:23 ../http/php/mod_digitize_messages.php:23
+msgid "This field may not be empty."
+msgstr "Das Feld darf nicht leer sein."
+#: mod_digitize_messages.php:24 ../http/php/mod_digitize_messages.php:24
+msgid "Failure during form evaluation."
+msgstr "Fehler bei der Formularauswertung."
+#: mod_digitize_messages.php:25 ../http/php/mod_gazetteerMetadata.php:138
+#: ../http/php/mod_gazetteerMetadata.php:201
+#: ../http/php/mod_gazetteerMetadata.php:212
+#: ../http/php/mod_digitize_messages.php:25
+#: ../http/php/mod_gazetteerMetadata.php:133
+#: ../http/php/mod_gazetteerMetadata.php:196
+#: ../http/php/mod_gazetteerMetadata.php:207
+msgid "An error occured."
+msgstr "Ein Fehler ist aufgetreten."
+#: mod_digitize_messages.php:26 ../http/php/mod_digitize_messages.php:26
+msgid ""
+"At least two geometries must be available. Only polygons are allowed in the "
+"geometry list."
+msgstr ""
+"Es müssen mindestens zwei Geometrien ausgewählt sein. Es sind nur Polygone "
+"erlaubt in der Geometrieliste."
+#: mod_digitize_messages.php:27 ../http/php/mod_digitize_messages.php:27
+msgid ""
+"Exactly two geometries must be available. The first geometry shall be a "
+"polygon or a line, the second geometry shall be a line."
+msgstr ""
+"Es müssen genau zwei Geometrien ausgewählt sein. Die erste Geometrie sollte "
+"ein Polygon oder eine Linie, die zweite Geometrie eine Linie sein."
+#: mod_digitize_messages.php:28 ../http/php/mod_digitize_messages.php:28
+msgid "Exactly two polygons must be available."
+msgstr "Es müssen genau zwei Polygone ausgewählt sein."
+#: mod_digitize_messages.php:29 ../http/php/mod_digitize_messages.php:29
+msgid "Exactly two lines must be available."
+msgstr "Es müssen genau zwei Linien ausgewählt sein."
+#: mod_digitize_messages.php:30 ../http/php/mod_digitize_messages.php:30
+msgid "Success."
+msgstr "Aktion erfolgreich beendet."
+#: mod_digitize_messages.php:31 ../http/php/mod_digitize_messages.php:31
+msgid "Delete geometry from database?"
+msgstr "Geometrie in der Datenbank löschen?"
+#: mod_digitize_messages.php:32 ../http/php/mod_digitize_messages.php:32
+msgid "Clear list of geometries?"
+msgstr "Soll die Geometrieliste wirklich geleert werden?"
+#: mod_digitize_messages.php:33 ../http/php/mod_digitize_messages.php:33
+msgid "Please select an entry."
+msgstr "Bitte treffen Sie eine Auswahl."
+#: mod_digitize_messages.php:34 ../http/php/mod_digitize_messages.php:34
+msgid "Save"
+msgstr "Speichern"
+#: mod_digitize_messages.php:35 ../http/php/mod_digitize_messages.php:35
+msgid "Update"
+msgstr "Aktualisieren"
+#: mod_digitize_messages.php:36 ../http/php/mod_customTree.php:230
+#: ../http/php/mod_digitize_messages.php:36
+msgid "Delete"
+msgstr "Löschen"
+#: mod_digitize_messages.php:37 ../http/php/mod_digitize_messages.php:37
+msgid "Abort"
+msgstr "Abbrechen"
+#: mod_digitize_messages.php:38 ../http/php/mod_digitize_messages.php:38
+msgid "Fatal error: EPSG mismatch. "
+msgstr "Schwerwiegender Fehler: ungleiche EPSGs."
+#: mod_digitize_messages.php:39 ../http/php/mod_digitize_messages.php:39
+msgid "No geometry selected!"
+msgstr "Keine Geometrie ausgewählt!"
+#: mod_digitize_messages.php:40 ../http/php/mod_digitize_messages.php:40
+msgid ""
+"No valid line geometries for merging! Please check start and end points of "
+"your lines."
+msgstr ""
+"Keine gültigen Geometrien zum Verbinden! Bitte Start- und Endpunkte der "
+"Linien prüfen."
+#: mod_digitize_messages.php:41 ../http/php/mod_digitize_messages.php:41
+msgid "add point"
+msgstr "Punkt hinzufügen"
+#: mod_digitize_messages.php:42 ../http/php/mod_digitize_messages.php:42
+msgid "cancel editing"
+msgstr "Editieren abbrechen"
+#: mod_digitize_messages.php:43 ../http/php/mod_digitize_messages.php:43
+msgid "add line"
+msgstr "Linie hinzufügen"
+#: mod_digitize_messages.php:44 mod_digitize_messages.php:46
+#: ../http/php/mod_digitize_messages.php:44
+#: ../http/php/mod_digitize_messages.php:46
+msgid "finish line"
+msgstr "Linie abschliessen"
+#: mod_digitize_messages.php:45 ../http/php/mod_digitize_messages.php:45
+msgid "continue line"
+msgstr "Linie erweitern"
+#: mod_digitize_messages.php:47 ../http/php/mod_digitize_messages.php:47
+msgid "add polygon"
+msgstr "Polygon hinzufügen"
+#: mod_digitize_messages.php:48 ../http/php/mod_digitize_messages.php:48
+msgid "close polygon"
+msgstr "Polygon schliessen"
+#: mod_digitize_messages.php:49 mod_digitize_messages.php:50
+#: ../http/php/mod_digitize_messages.php:49
+#: ../http/php/mod_digitize_messages.php:50
+msgid "move basepoint"
+msgstr "Stützpunkt verschieben"
+#: mod_digitize_messages.php:51 mod_digitize_messages.php:52
+#: ../http/php/mod_digitize_messages.php:51
+#: ../http/php/mod_digitize_messages.php:52
+msgid "Insert basepoint"
+msgstr "Stützpunkt einfügen"
+#: mod_digitize_messages.php:53 mod_digitize_messages.php:54
+#: ../http/php/mod_digitize_messages.php:53
+#: ../http/php/mod_digitize_messages.php:54
+msgid "Delete basepoint"
+msgstr "Stützpunkt löschen"
+#: mod_digitize_messages.php:55 mod_digitize_messages.php:56
+#: ../http/php/mod_digitize_messages.php:55
+#: ../http/php/mod_digitize_messages.php:56
+msgid "clear list of geometries"
+msgstr "Geometrieliste leeren"
+#: mod_digitize_messages.php:57 mod_digitize_messages.php:58
+#: ../http/php/mod_digitize_messages.php:57
+#: ../http/php/mod_digitize_messages.php:58
+msgid ""
+"Merge two polygons into a single polygon (will be added to the geometry list)"
+msgstr ""
+"Zwei Polygone zu einem Polygon zusammenfügen (wird der Geometrieliste "
+"hinzugefügt)."
+#: mod_digitize_messages.php:59 mod_digitize_messages.php:60
+#: ../http/php/mod_digitize_messages.php:59
+#: ../http/php/mod_digitize_messages.php:60
+msgid ""
+"Split a polygon/line by a line (the new polygons/lines will be added to the "
+"geometry list)"
+msgstr ""
+"Polygon/Linie zerschneiden mit Hilfe einer Linie (neue Polygone/Linien "
+"werden zur Geometrienliste hinzugefügt)"
+#: mod_digitize_messages.php:61 ../http/php/mod_digitize_messages.php:61
+msgid ""
+"Combine two polygons (to create en- and exclave or to compute the difference)"
+msgstr ""
+"Verbinde zwei Polygone (zum Erstellen von En- oder Exklaven oder zum "
+"Berechnen der Differenz)"
+#: mod_digitize_messages.php:62 ../http/php/mod_digitize_messages.php:62
+msgid "Split geometries"
+msgstr "Geometrien zerschneiden"
+#: mod_digitize_messages.php:63 mod_digitize_messages.php:64
+#: ../http/php/mod_digitize_messages.php:63
+#: ../http/php/mod_digitize_messages.php:64
+msgid "Merge two lines into a single line"
+msgstr "Zwei Linien zu einer Linie zusammenfügen."
+#: mod_digitize_messages.php:65 ../http/php/mod_digitize_messages.php:65
+msgid "save / update / delete"
+msgstr "speichern / aktualisieren / löschen"
+#: mod_digitize_messages.php:66 ../http/php/mod_digitize_messages.php:66
+msgid "remove from workspace"
+msgstr "aus der Liste entfernen"
+#: mod_digitize_messages.php:67 ../http/php/mod_digitize_messages.php:67
+msgid "remove from database"
+msgstr "aus der Datenbank löschen"
+#: mod_digitize_messages.php:68 ../http/php/mod_digitize_messages.php:68
+msgid "clone this geometry"
+msgstr "dupliziere diese Geometrie"
+#: mod_digitize_messages.php:69 ../http/php/mod_digitize_messages.php:69
+msgid "click the first basepoint to close the polygon"
+msgstr "Auf den ersten Stützpunkt klicken, um das Polygon zu schliessen"
+#: mod_digitize_messages.php:70 ../http/php/mod_digitize_messages.php:70
+msgid "Current: "
+msgstr "Letztes Segment: "
+#: mod_digitize_messages.php:71 ../http/php/mod_digitize_messages.php:71
+msgid "Total: "
+msgstr "Gesamtlänge: "
+#: mod_digitize_messages.php:72 ../http/php/mod_createCategory.php:118
+#: ../http/php/mod_digitize_messages.php:72
+msgid "new"
+msgstr "neu"
+#: mod_wfsSpatialRequest_messages.php:33
+#: ../http/php/mod_wfsSpatialRequest_messages.php:30
+msgid "select by rectangle"
+msgstr "Auswahl über Rechteck"
+#: mod_wfsSpatialRequest_messages.php:34
+#: ../http/php/mod_wfsSpatialRequest_messages.php:31
+msgid "select by polygon"
+msgstr "Auswahl über Polygon"
+#: mod_wfsSpatialRequest_messages.php:35
+#: ../http/php/mod_wfsSpatialRequest_messages.php:32
+msgid "select by point"
+msgstr "Auswahl über Punkt test"
+#: mod_wfsSpatialRequest_messages.php:36
+#: ../http/php/mod_wfsSpatialRequest_messages.php:33
+msgid "select by extent"
+msgstr "Auswahl über Extent"
+#: mod_wfsSpatialRequest_messages.php:37
+#: ../http/php/mod_wfsSpatialRequest_messages.php:34
+msgid "open dialogue form"
+msgstr "Auswahlfenster öffnen"
+#: mod_wfsSpatialRequest_messages.php:38
+#: ../http/php/mod_wfsSpatialRequest_messages.php:35
+msgid "Invalid box!"
+msgstr "Ausschnitt ungültig!"
+#: /html/mod_treefolder2.php:56 http/html/mod_treefolderPlain.php:34
+#: ../http/html/mod_treefolderPlain.php:33
+#: ../http/html/mod_treefolderPlain.php:32
+msgid "Toggles the visibility of this service"
+msgstr "Sichtbarkeit des Layers an/aus"
+#: /html/mod_treefolder2.php:57 http/html/mod_treefolderPlain.php:35
+#: ../http/html/mod_treefolderPlain.php:34
+msgid "Toggles the queryability of this service"
+msgstr "Infoabfrage an/aus"
+#: /html/mod_treefolder2.php:58 http/html/mod_treefolderPlain.php:36
+#: ../http/html/mod_treefolderPlain.php:35
+msgid "Opens the layer context menu"
+msgstr "Öffnet das Layer Kontextmenü"
+#: /html/mod_treefolder2.php:59 http/html/mod_treefolderPlain.php:37
+#: ../http/html/mod_treefolderPlain.php:36
+msgid "Opens the WMS context menu"
+msgstr "Öffnet das WMS Kontextmenü"
+#: /html/mod_treefolder2.php:60 http/html/mod_treefolderPlain.php:38
+#: ../http/html/mod_treefolderPlain.php:37
+msgid "Removes the selected WMS"
+msgstr "Entfernt den gewählten Dienst"
+#: /html/mod_treefolder2.php:61 http/html/mod_treefolderPlain.php:39
+#: ../http/html/mod_treefolderPlain.php:38
+msgid "Moves the selection up"
+msgstr "selektierten Dienst nach oben verschieben"
+#: /html/mod_treefolder2.php:62 http/html/mod_treefolderPlain.php:40
+#: ../http/html/mod_treefolderPlain.php:39
+msgid "Moves the selection down"
+msgstr "selektierten Dienst nach unten verschieben"
+#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:327
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:450
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:487
+msgid "WMS name"
+msgstr "WMS Name"
+#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:328
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:451
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:488
+msgid "WMS abstract"
+msgstr "WMS Beschreibung"
+#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:329
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:452
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:489
+msgid "Please select a WMS"
+msgstr "Bitte wählen Sie einen WMS aus"
+#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:330
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:453
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:490
+msgid "Please select an application"
+msgstr "Bitte wählen Sie eine Applikation aus"
+#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:331
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:454
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:491
+msgid "Please select a group"
+msgstr "Bitte wählen Sie eine Gruppe aus"
+#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:332
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:455
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:492
+msgid "group abstract"
+msgstr "Beschreibung der Gruppe"
+#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:333
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:456
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:493
+msgid "group name"
+msgstr "Name der Gruppe"
+#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:334
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:457
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:494
+msgid "application abstract"
+msgstr "Beschreibung der Applikation"
+#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:335
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:458
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:495
+msgid "application name"
+msgstr "Name der Anwendung"
+#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:336
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:459
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:496
+msgid "no result"
+msgstr "kein Ergebnis"
+#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:342
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:465
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:475
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:502
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:512
+msgid "Add WMS"
+msgstr "WMS hinzufügen"
+#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:343
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:466
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:503
+msgid "Enter a Capabilities-URL of a WMS or select one or more WMS from list."
+msgstr ""
+"Geben Sie eine Capabilities-URL ein oder wählen Sie einen der aufgelisteten "
+"Dienste."
+#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:344
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:467
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:504
+msgid ""
+"Notice: Be aware of the scale hints. Possibly you need to zoom in to display "
+"the added service."
+msgstr ""
+"Hinweis: Beachten Sie die logischen Zoomstufen. Möglicherweise müssen Sie "
+"den Maßstab wechseln, um die Ebenen des geladenen Dienstes zu sehen."
+#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:350
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:473
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:510
+msgid "Capabilities-URL"
+msgstr "Capabilities-URL"
+#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:362
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:529
+msgid "List all WMS"
+msgstr "Liste aller WMS"
+#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:363
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:530
+msgid "List WMS by Group"
+msgstr "WMS nach Gruppen sortiert"
+#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:364
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:531
+msgid "List WMS by Application"
+msgstr "WMS nach Anwendungen sortiert"
+#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:374
+msgid "Loading WMS"
+msgstr "Der WMS wird geladen"
+#: http/php/mod_createJSObjFromXML.php:33
+#: ../http/php/mod_createJSLayerObjFromXML.php:34
+#: ../http/php/mod_createJSObjFromXML.php:40
+msgid ""
+"Error: The Capabilities Document could not be accessed. Please check whether "
+"the server is responding and accessible to Mapbender."
+msgstr ""
+"Fehler: Das Capabilities-Dokument ist nicht verfügbar. Bitte prüfen Sie, ob "
+"der Server antwortet und für Mapbender erreichbar ist."
+#: http/html/mod_treefolderPlain.php:33
+#: ../http/html/mod_treefolderPlain.php:31
+msgid "(De)activate this service"
+msgstr "Dienst (de)aktivieren"
+#: http/html/mod_treefolderPlain.php:144
+#: ../http/html/mod_treefolderPlain.php:143
+#: ../http/html/mod_treefolderPlain.php:199
+msgid "Move up"
+msgstr "rauf"
+#: http/html/mod_treefolderPlain.php:145
+#: ../http/html/mod_treefolderPlain.php:144
+#: ../http/html/mod_treefolderPlain.php:200
+msgid "Move down"
+msgstr "runter"
+#: http/html/mod_treefolderPlain.php:146
+#: ../http/html/mod_treefolderPlain.php:145
+#: ../http/html/mod_treefolderPlain.php:201
+msgid "Remove"
+msgstr "entfernen"
+#: http/html/mod_treefolderPlain.php:147
+#: ../http/html/mod_treefolderPlain.php:146
+#: ../http/html/mod_treefolderPlain.php:202
+msgid "Opacity up"
+msgstr "Transparenz verringern"
+#: http/html/mod_treefolderPlain.php:148
+#: ../http/html/mod_treefolderPlain.php:147
+#: ../http/html/mod_treefolderPlain.php:203
+msgid "Opacity down"
+msgstr "Transparenz erhöhen"
+#: http/html/mod_treefolderPlain.php:149
+#: ../http/html/mod_treefolderPlain.php:148
+#: ../http/html/mod_treefolderPlain.php:204
+#: ../http/javascripts/mod_featureInfo.php:98
+#: ../http/javascripts/mod_featureInfoTunnel.php:131
+#: ../http/javascripts/mod_featureInfoTunnel.php:160
+#: ../http/javascripts/mod_tooltip.php:78
+#: ../http/javascripts/mod_featureInfo.php:107
+#: ../http/javascripts/mod_featureInfo.php:111
+#: ../http/javascripts/mod_featureInfoTunnel.php:139
+#: ../http/javascripts/mod_featureInfoTunnel.php:168
+msgid "Information"
+msgstr "Information"
+#: http/html/mod_treefolderPlain.php:150 http/html/mod_treefolderPlain.php:152
+#: ../http/html/mod_treefolderPlain.php:149
+#: ../http/html/mod_treefolderPlain.php:151
+#: ../http/html/mod_treefolderPlain.php:205
+#: ../http/html/mod_treefolderPlain.php:208
+msgid "Zoom"
+msgstr "auf Ebene zoomen"
+#: http/html/mod_treefolderPlain.php:151
+#: ../http/html/mod_treefolderPlain.php:150
+#: ../http/html/mod_treefolderPlain.php:206
+msgid "Hide menu"
+msgstr "schließen"
+#: conf/wfs_additional_spatial_search.conf:17
+msgid "Spatial filter is set."
+msgstr "räumlicher Filter gesetzt"
+#: conf/wfs_additional_spatial_search.conf:31
+msgid "Search results"
+msgstr "Suchergebnisse"
+#: conf/wfs_additional_spatial_search.conf:37
+msgid "Details"
+msgstr "Details"
+#: http/php/mb_listGUIs.php:59 ../http/php/mb_listGUIs.php:59
+msgid "available applications"
+msgstr "Liste der verfügbaren Anwendungen"
+#: http/php/mb_listGUIs.php:82 ../http/php/mb_listGUIs.php:99
+#: ../http/php/mb_listGUIs.php:82
+msgid "Others"
+msgstr "Sonstige"
+#: ../http/html/mod_treefolderPlain.php:420
+#: ../http/html/mod_treefolderPlain.php:522
+msgid "You have to select the WMS you want to move up!"
+msgstr "Sie müssen den Dienst, den Sie nach oben schieben wollen, selektieren."
+#: ../http/html/mod_treefolderPlain.php:425
+#: ../http/html/mod_treefolderPlain.php:457
+#: ../http/html/mod_treefolderPlain.php:527
+#: ../http/html/mod_treefolderPlain.php:559
+msgid "Illegal move operation"
+msgstr "Ungültige Operation"
+#: ../http/html/mod_treefolderPlain.php:452
+#: ../http/html/mod_treefolderPlain.php:554
+msgid "You have to select the WMS you want to move down!"
+msgstr ""
+"Sie müssen den Dienst, den Sie nach unten schieben wollen, selektieren."
+#: ../http/html/mod_treefolderPlain.php:484
+#: ../http/html/mod_treefolderPlain.php:586
+msgid "You have to select the WMS you want to delete!"
+msgstr "Sie müssen den Dienst, den Sie entfernen wollen, selektieren."
+#: ../http/html/mod_treefolderPlain.php:488
+#: ../http/html/mod_treefolderPlain.php:590
+msgid "It is not possible to delete a single layer, please select a WMS!"
+msgstr ""
+"Es ist nicht möglich einen einzelnen Layer zu entfernen. Bitte selektieren "
+"Sie einen WMS!"
+#: ../http/html/mod_treefolderPlain.php:496
+#: ../http/html/mod_treefolderPlain.php:598
+msgid "Last WMS can not be removed."
+msgstr "Der letzte WMS kann nicht entfernt werden."
+#: ../http/html/mod_treefolderPlain.php:499
+#: ../http/html/mod_treefolderPlain.php:601
+msgid "Are you sure you want to remove"
+msgstr "Sind Sie sicher, dass Sie diesen Dienst entfernen wollen "
+#: http/javascripts/mod_measure.php:298
+#: ../http/javascripts/mod_measure.php:288
+msgid "Close polygon"
+#: http/javascripts/mod_measure.php:314
+#: ../http/javascripts/mod_measure.php:305
+msgid "Rubber"
+msgstr "Skizze löschen"
+#: http/javascripts/mod_measure.php:329
+#: ../http/javascripts/mod_measure.php:320
+msgid "Get area"
+msgstr "Fläche berechnen"
+#: ../http/javascripts/mod_wfs_gazetteer_client.php:411
+#: ../http/javascripts/mod_wfs_gazetteer_client.php:667
+msgid "show metadata"
+msgstr "Metadaten anzeigen"
+#: ../http/javascripts/mod_wfs_gazetteer_client.php:420
+#: ../http/javascripts/mod_wfs_gazetteer_client.php:676
+msgid "remove WFS Conf"
+msgstr "WFS Konfiguration entfernen"
+#: ../http/javascripts/mod_wfs_gazetteer_client.php:455
+#: ../http/javascripts/mod_wfs_gazetteer_client.php:711
+msgid "Point"
+msgstr "Punkt"
+#: ../http/javascripts/mod_wfs_gazetteer_client.php:459
+#: ../http/javascripts/mod_wfs_gazetteer_client.php:715
+msgid "Line"
+msgstr "Linie"
+#: ../http/javascripts/mod_wfs_gazetteer_client.php:463
+#: ../http/javascripts/mod_wfs_gazetteer_client.php:719
+msgid "Polygon"
+msgstr "Polygon"
+#: ../http/javascripts/mod_wfs_gazetteer_client.php:621
+#: ../http/javascripts/mod_wfs_gazetteer_client.php:891
+msgid "Different EPSG of map and wfs featuretype, no spatial request possible!"
+msgstr ""
+"Unterschiedliche EPSG von Karte und WFS FeatureType. Es ist keine räumliche "
+"möglich."
+msgid "Show metadata"
+#: ../http/html/mod_treefolderPlain.php:207
+msgid "Change style"
+msgstr "Stil ändern"
+#: ../http/html/mod_treefolderPlain.php:471
+msgid "Change layer style"
+msgstr "Layer Stil ändern"
+msgid "Please select a style"
+msgstr "Bitte wählen Sie einen Stil aus"
+#: ../http/html/mod_treefolderPlain.php:477
+msgid "Close"
+msgstr "schließen"
+msgid "close"
+msgstr "schließen"
+#: ../http/html/mod_treefolderPlain.php:490
+msgid "There is no different style available for this layer."
+msgstr "Es liegen keine weiteren Stile für diesen Layer vor."
+msgid ""
+"Hint: Possibly you need to zoom in for showing layers from external map "
+"service. The operator of the external service is responsible for the display "
+"ranges. PortalU does not have a stake in this behaviour."
+msgstr ""
+"Hinweis: Möglicherweise müssen Sie in die Karte zoomen, um Layer von "
+"externen Diensten zu sehen.Der Administrator des externen Dienstes ist für "
+"die Anzeige verantwortlich."
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:479
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:516
+msgid "activate layers"
+msgstr "Ebenen des Kartendienstes aktivieren"
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:483
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:520
+msgid "zoom to extent"
+msgstr "auf Ausdehnung des Kartendiensten zoomen"
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:501
+#: ../http/javascripts/mod_searchCSW_ajax.php:507
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:538
+#: ../http/javascripts/mod_searchCSW_ajax.php:409
+msgid "Loading"
+msgstr "Kartendienst wird geladen"
+#: ../http/php/mod_meetingPoint.php:42 ../http/php/mod_meetingPoint.php:45
+#: ../http/php/mod_meetingPoint.php:46
+msgid "Your meeting point. Follow the link!"
+msgstr "Ihr Treffpunkt. Folgen Sie dem Link!"
+#: ../http/php/mod_meetingPoint.php:98 ../http/php/mod_meetingPoint.php:108
+#: ../http/php/mod_meetingPoint.php:109
+msgid "Please click for the meeting point position!"
+msgstr "Bitte klicken Sie in die Karte, um einen Treffpunkt zu erzeugen."
+#: ../http/php/mod_meetingPoint.php:210 ../http/php/mod_meetingPoint.php:227
+#: ../http/php/mod_meetingPoint.php:228
+msgid "Max characters"
+msgstr "Max. Eingabe"
+#: ../http/php/mod_meetingPoint.php:229 ../http/php/mod_meetingPoint.php:151
+#: ../http/php/mod_meetingPoint.php:246 ../http/php/mod_meetingPoint.php:152
+#: ../http/php/mod_meetingPoint.php:247
+msgid "Please define a text!"
+msgstr "Bitte geben Sie einen Text ein."
+#: ../http/php/mod_meetingPoint.php:323 ../http/php/mod_meetingPoint.php:352
+#: ../http/php/mod_meetingPoint.php:353
+msgid "cancel"
+msgstr "Abbrechen"
+#: ../http/php/mod_gazetteerMetadata.php:150
+#: ../http/php/mod_gazetteerMetadata.php:145
+msgid "The added Service has more than"
+msgstr "Der hinzugefügte Dienst hat mehr als"
+#: ../http/php/mod_gazetteerMetadata.php:208
+#: ../http/php/mod_gazetteerMetadata.php:203
+msgid "The following Service has been added"
+msgstr "Der folgende Dienst wurde hinzugefügt"
+#: ../http/php/mod_gazetteerMetadata.php:234
+msgid "SelectKeyword"
+msgstr "Suchbegriff auswählen"
+#: ../http/php/mod_gazetteerMetadata.php:249
+#: ../http/plugins/mb_metadata_wmc_edit.php:31
+#: ../http/plugins/mb_metadata_wmc_server.php:57
+#: ../http/php/mod_gazetteerMetadata.php:246
+#: ../http/php/mod_subscribersServiceList.php:167
+#: ../http/plugins/mb_metadata_wmc_server.php:54
+msgid "Metadata"
+msgstr "Metadaten"
+#: ../http/php/mod_gazetteerMetadata.php:267
+#: ../http/php/mod_gazetteerMetadata.php:264
+msgid "Searching"
+msgstr "Suche läuft"
+#: ../http/php/mod_gazetteerMetadata.php:317
+#: ../http/php/mod_gazetteerMetadata.php:314
+msgid "Load"
+msgstr "Laden"
+#: ../http/php/mod_gazetteerMetadata.php:342
+#: ../http/php/mod_gazetteerMetadata.php:339
+msgid "Add WMS and zoom to extent"
+msgstr "Kartendienst hinzuladen und auf Ausdehnung zoomen"
+#: ../http/php/mod_gazetteerMetadata.php:440
+#: ../http/php/mod_gazetteerMetadata.php:437
+msgid "keywords"
+msgstr "Suchbegriffe"
+msgid "layer. The layer of the MapService will NOT be activated."
+msgstr "Ebenen. Die Ebenen des Kartendienstes werden NICHT aktiviert."
+#: ../http/php/mod_SelectKeyword.php:24
+#: ../http/php/mod_gazetteerMetadata.php:230
+msgid "Select a keyword"
+msgstr "Wählen Sie einen Suchbegriff aus"
+#: ../http/php/mod_SelectKeyword.php:48
+msgid "Please double click to select a keyword."
+msgstr "Suchbegriff per Doppelklick auswählen."
+#: ../http/php/mod_gazetteerMetadata.php:262
+#: ../http/php/mod_gazetteerMetadata.php:259
+msgid "Please insert a keyword!"
+msgstr "Bitte geben Sie einen Suchbegriff an."
+#: ../http/javascripts/mod_searchCSW_ajax.php:89
+#: ../http/javascripts/mod_searchCSW_ajax.php:489
+#: ../http/javascripts/mod_searchCSW_ajax.php:391
+msgid "+ Advanced"
+msgstr "+ Erweitert"
+#: ../http/javascripts/mod_searchCSW_ajax.php:107
+#: ../http/javascripts/mod_searchCSW_form.php:66
+msgid "Title "
+msgstr "Titel"
+#: ../http/javascripts/mod_searchCSW_ajax.php:109
+#: ../http/javascripts/mod_searchCSW_form.php:68
+msgid "Abstract"
+msgstr "Beschreibung"
+#: ../http/javascripts/mod_searchCSW_ajax.php:111
+#: ../http/javascripts/mod_searchCSW_form.php:70
+msgid "Keywords"
+msgstr "Stichworte"
+#: ../http/javascripts/mod_searchCSW_ajax.php:121
+#: ../http/javascripts/mod_searchCSW_form.php:75
+msgid "Lat-Min"
+msgstr "min. Lat"
+#: ../http/javascripts/mod_searchCSW_ajax.php:128
+#: ../http/javascripts/mod_searchCSW_form.php:79
+msgid "Lon-Min"
+msgstr "min. Lon"
+#: ../http/javascripts/mod_searchCSW_ajax.php:133
+msgid "Lat-Max"
+msgstr "max. Lat"
+#: ../http/javascripts/mod_searchCSW_ajax.php:140
+#: ../http/javascripts/mod_searchCSW_form.php:81
+msgid "Lon-Max"
+msgstr "max. Lon"
+#: ../http/javascripts/mod_searchCSW_ajax.php:161
+msgid "Getrecords Medium"
+msgstr "noch übersetzen Getrecords Medium"
+#: ../http/javascripts/mod_searchCSW_ajax.php:169
+msgid "Query Language"
+msgstr "noch Übersetzen: Query Language"
+#: ../http/javascripts/mod_searchCSW_ajax.php:184
+#: ../http/javascripts/mod_searchCSW_ajax.php:495
+#: ../http/javascripts/mod_searchCSW_ajax.php:397
+msgid "+ Options"
+msgstr "+ Optionen"
+#: ../http/javascripts/mod_searchCSW_ajax.php:459
+#: ../http/javascripts/mod_searchCSW_ajax.php:360
+msgid "Record Title"
+msgstr "Titel"
+#: ../http/javascripts/mod_searchCSW_ajax.php:460
+#: ../http/javascripts/mod_searchCSW_ajax.php:361
+msgid "Record Abstract"
+#: ../http/javascripts/mod_searchCSW_ajax.php:461
+#: ../http/javascripts/mod_searchCSW_ajax.php:362
+msgid "Returned Results..."
+msgstr "Erhaltene Treffer..."
+#: ../http/javascripts/mod_searchCSW_ajax.php:472
+#: ../http/javascripts/mod_searchCSW_ajax.php:373
+msgid ""
+"Do a Basic or Advanced Search of Catalogs in the system. Please visit the "
+"Catalog Admin to add a Catalog"
+msgstr ""
+"Führen Sie eine einfache oder erweiterte Suche durch. Über die "
+"Administration können Sie auch einen Katalogdienst laden."
+#: ../http/javascripts/mod_searchCSW_ajax.php:480
+#: ../http/javascripts/mod_searchCSW_ajax.php:382
+#: ../http/javascripts/mod_searchCSW_form.php:55
+msgid "Search for "
+msgstr "Suche nach"
+#: ../http/javascripts/mod_searchCSW_ajax.php:500
+#: ../http/javascripts/mod_searchCSW_ajax.php:402
+#: ../http/javascripts/mod_searchCSW_form.php:48
+#: ../http/javascripts/mod_searchCSW_form.php:58
+#: ../http/javascripts/mod_searchCSW_form.php:85
+msgid "Search CSW"
+msgstr "Katalogsuche"
+#: ../http/javascripts/mod_searchCSW_ajax.php:102
+msgid "- Advanced"
+msgstr "- Erweitert"
+#: ../http/javascripts/mod_searchCSW_ajax.php:105
+msgid "Advanced Search"
+msgstr "Erweiterte Suche"
+#: ../http/javascripts/mod_searchCSW_ajax.php:154
+msgid "- Options"
+msgstr "- Optionen"
+#: ../http/javascripts/mod_searchCSW_ajax.php:159
+msgid "Number of Hits"
+msgstr "Anzahl der Treffer"
+#: ../http/javascripts/mod_searchCSW_ajax.php:171
+#: ../http/javascripts/mod_searchCSW_ajax.php:172
+msgid "CQL"
+msgstr "CQL"
+msgid "Filter"
+msgstr "Filter"
+#: ../http/javascripts/mod_searchCSW_ajax.php:478
+#: ../http/javascripts/mod_searchCSW_ajax.php:380
+msgid "Capabilities"
+msgstr "noch übersetzen: Capabilities"
+#: ../http/javascripts/mod_searchCSW_ajax.php:470
+#: ../http/javascripts/mod_searchCSW_ajax.php:371
+msgid "Catalog Search"
+#: ../http/javascripts/mod_searchCSW_ajax.php:31
+msgid "Search Catalog"
+msgstr "Suche starten"
+msgid "Name:"
+msgstr "Name:"
+msgid "Firstname:"
+msgstr "Vorname:"
+msgid "Lastname:"
+msgstr "Nachname:"
+msgid "Usertype:"
+msgstr "Typ des Nutzers:"
+msgid "Germany"
+msgstr "Deutschland"
+msgid "my lines"
+msgstr "meine Linien"
+msgid "Save configuration"
+msgstr "Konfiguration speichern"
+#: ../http/javascripts/mod_loadwmc.js:68
+msgid "List"
+msgstr "Liste"
+#: ../http/javascripts/mod_loadwmc.js:69
+msgid "Upload"
+msgstr "Laden"
+#: ../http/javascripts/mod_loadwmc.js:80
+msgid "WMC name"
+msgstr "WMS Name"
+#: ../http/javascripts/mod_loadwmc.js:81
+msgid "last update"
+msgstr "letzte Änderung"
+#: ../http/javascripts/mod_loadwmc.js:82
+msgid "created"
+msgstr "erstellt"
+#: ../http/javascripts/mod_loadwmc.js:83
+msgid "load"
+msgstr "laden"
+#: ../http/javascripts/mod_loadwmc.js:84
+msgid "merge"
+msgstr "mergen"
+#: ../http/javascripts/mod_loadwmc.js:85
+msgid "append"
+msgstr "hinzufügen"
+#: ../http/javascripts/mod_loadwmc.js:86
+msgid "public"
+msgstr "öffentlich"
+#: ../http/javascripts/mod_loadwmc.js:87
+msgid "show/save"
+msgstr "anzeigen/speichern"
+#: ../http/javascripts/mod_loadwmc.js:88
+#: ../http/javascripts/mod_loadwmc.js:294
+msgid "OpenLayers"
+msgstr "OpenLayers"
+#: ../http/javascripts/mod_loadwmc.js:89
+msgid "delete"
+msgstr "löschen"
+#: ../http/javascripts/mod_loadwmc.js:173
+msgid "load this WMC"
+msgstr "lade dieses WMC"
+#: ../http/javascripts/mod_loadwmc.js:175
+#: ../http/javascripts/mod_loadwmc.js:358
+msgid "WMC has been loaded successfully."
+msgstr "Das WMC wurde erfolgreich geladen."
+#: ../http/javascripts/mod_loadwmc.js:196
+msgid "merge WMC"
+msgstr "WMC zusammenfügen"
+#: ../http/javascripts/mod_loadwmc.js:198
+msgid "WMC has been merged successfully."
+msgstr "WMC wurde erfolgreich zusammengeführt."
+#: ../http/javascripts/mod_loadwmc.js:222
+msgid "append WMC"
+msgstr "WMC hinzufügen"
+#: ../http/javascripts/mod_loadwmc.js:224
+msgid "WMC has been appended successfully."
+msgstr "WMC wurde erfolgreich hinzugefügt"
+#: ../http/javascripts/mod_loadwmc.js:229
+msgid "currentState"
+msgstr "aktueller Stand"
+#: ../http/javascripts/mod_loadwmc.js:262
+msgid "display WMC XML"
+msgstr "WMC XML anzeigen"
+#: ../http/javascripts/mod_loadwmc.js:267
+msgid "WMC Document"
+msgstr "WMC Dokument"
+#: ../http/javascripts/mod_loadwmc.js:289
+msgid "export to OpenLayers"
+msgstr "nach OpenLayers exportieren"
+#: ../http/javascripts/mod_loadwmc.js:322
+msgid "delete this WMC"
+msgstr "WMC löschen"
+#: ../http/javascripts/mod_loadwmc.js:325
+msgid "Do you really want to delete WMC"
+msgstr "Wollen Sie dieses WMC wirklich löschen?"
+#: ../http/javascripts/mod_loadwmc.js:404
+msgid "load Service anyway?"
+msgstr "Dienst trotzdem laden?"
+#: ../http/plugins/wfsConfTree.js:7
+msgid "No geometry modules are available. You can load those from the Search."
+msgstr ""
+"Keine Geometriemodule verfügbar. Sie können Module über die Suche hinzuladen."
+#: ../http/javascripts/mod_zoomCoords.php:36
+msgid "Please type a number."
+msgstr "Bitte geben Sie die Koordinaten als Zahlen ein."
+#: ../http/javascripts/mod_zoomCoords.php:88
+msgid "ok"
+msgstr "ok"
+#: ../http/javascripts/mod_zoomCoords.php:91
+msgid "Longitude"
+msgstr "Rechtswert"
+#: ../http/javascripts/mod_zoomCoords.php:92
+msgid "Latitude"
+msgstr "Hochwert"
+#: workspace/test27/http/plugins/mb_metadata_edit.php:10
+#: workspace/test27/http/plugins/mb_metadata_layer.php:34
+#: ../http/plugins/mb_metadata_edit.php:10
+#: ../http/plugins/mb_metadata_featuretype.php:34
+#: ../http/plugins/mb_metadata_layer.php:34
+#: ../http/plugins/mb_metadata_wfs_edit.php:10
+#: ../http/plugins/mb_metadata_edit.php:11
+#: ../http/plugins/mb_metadata_wfs_edit.php:11
+msgid "Show original Service Metadata from last update"
+msgstr "Originale Dienstmetadaten von letzter Aktualisierung anzeigen"
+#: workspace/test27/http/plugins/jq_upload_images.php:29
+#: workspace/test27/http/plugins/jq_upload.php:29
+#: ../http/plugins/jq_upload.php:29 ../http/plugins/jq_upload.php:28
+#, php-format
+msgid "Files with this extension are not allowed. Must be %s."
+msgstr ""
+"Dateien in diesem Format werden nicht unterstützt, wählen Sie eines der "
+"folgenden Bildformate: %s."
+#: workspace/test27/http/plugins/jq_upload_images.php:49
+#: workspace/test27/http/plugins/jq_upload.php:50
+#: ../http/plugins/jq_upload.php:50 ../http/plugins/jq_upload.php:49
+#, php-format
+msgid "Files with extension %s are not allowed. Must be %s."
+msgstr ""
+"Dateien in dem Format %s werden nicht unterstützt, wählen Sie eines der "
+#: workspace/test27/http/plugins/jq_upload_images.php:61
+#: workspace/test27/http/plugins/jq_upload.php:63
+#: ../http/plugins/jq_upload.php:63 ../http/plugins/jq_upload.php:62
+#, php-format
+msgid "File size limit (%s KB) exceeded."
+msgstr "Datei zu groß (maximal %s KB)."
+#: workspace/test27/http/plugins/jq_upload_images.php:75
+#: workspace/test27/http/plugins/jq_upload.php:78
+#: ../http/plugins/jq_upload.php:77
+msgid "File could not be stored on server. Please contact the administrator."
+msgstr ""
+"Die Datei konnte nicht hochgeladen werden. Bitte wenden Sie sich an den "
+"Administrator."
+#: workspace/test27/http/plugins/jq_upload_images.php:80
+#: workspace/test27/http/plugins/jq_upload.php:83
+#: ../http/plugins/jq_upload.php:82
+msgid "File has been uploaded."
+msgstr "Die Datei wurde erfolgreich hochgeladen."
+#: workspace/test27/http/plugins/mb_i18n_server.php:48
+#: workspace/test27/http/plugins/mb_metadata_server.php:388
+#: workspace/test27/http/plugins/mb_original_metadata_server.php:172
+#: workspace/test27/http/plugins/mb_twitter.php:126
+#: ../http/plugins/mb_i18n_server.php:48
+#: ../http/plugins/mb_metadata_server.php:424
+#: ../http/plugins/mb_metadata_wfs_server.php:388
+#: ../http/plugins/mb_metadata_wmc_server.php:217
+#: ../http/plugins/mb_original_metadata_server.php:205
+#: ../http/plugins/mb_original_metadata_wfs_server.php:206
+#: ../http/plugins/mb_original_metadata_wmc_server.php:75
+#: ../http/plugins/mb_sql_server.php:36
+#: ../http/php/mod_changeEPSG_server.php:116
+#: ../http/php/mod_changeEPSG_server.php:125
+#: ../http/php/mod_coordsLookup_server.php:126
+#: ../http/php/mod_coordsLookup_server.php:136
+#: ../http/php/mod_treefolder2_l10n.php:51
+#: ../http/php/mod_wfs_gazetteer_l10n.php:55
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:135
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:187
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:198
+#: ../http/plugins/mb_metadata_server.php:1071
+#: ../http/plugins/mb_metadata_wfs_server.php:453
+#: ../http/plugins/mb_metadata_wmc_server.php:214
+msgid "An unknown error occured."
+msgstr "Ein unkekannter Fehler ist aufgetreten."
+#: workspace/test27/http/plugins/mb_metadata_edit.php:8
+#: ../http/plugins/mb_metadata_edit.php:8
+#: ../http/plugins/mb_metadata_wfs_edit.php:8
+#: ../http/plugins/mb_metadata_wmc_edit.php:23
+#: ../http/plugins/mb_metadata_edit.php:9
+#: ../http/plugins/mb_metadata_wfs_edit.php:9
+msgid "Service Level Metadata"
+msgstr "Service Metadaten"
+#: workspace/test27/http/plugins/mb_metadata_edit.php:12
+#: workspace/test27/http/plugins/mb_metadata_edit.php:57
+#: workspace/test27/http/plugins/mb_metadata_layer.php:32
+#: workspace/test27/http/plugins/mb_metadata_layer.php:36
+#: workspace/test27/http/plugins/mb_metadata_layer.php:62
+#: ../http/plugins/mb_metadata_edit.php:12
+#: ../http/plugins/mb_metadata_edit.php:57
+#: ../http/plugins/mb_metadata_featuretype.php:32
+#: ../http/plugins/mb_metadata_featuretype.php:36
+#: ../http/plugins/mb_metadata_featuretype.php:62
+#: ../http/plugins/mb_metadata_layer.php:32
+#: ../http/plugins/mb_metadata_layer.php:36
+#: ../http/plugins/mb_metadata_layer.php:62
+#: ../http/plugins/mb_metadata_wfs_edit.php:12
+#: ../http/plugins/mb_metadata_wfs_edit.php:57
+#: ../http/plugins/mb_metadata_addon.php:9
+#: ../http/plugins/mb_metadata_addon.php:10
+#: ../http/plugins/mb_metadata_addon.php:11
+#: ../http/plugins/mb_metadata_addon.php:34
+#: ../http/plugins/mb_metadata_addon.php:38
+#: ../http/plugins/mb_metadata_addon.php:42
+#: ../http/plugins/mb_metadata_addon.php:46
+#: ../http/plugins/mb_metadata_addon.php:48
+#: ../http/plugins/mb_metadata_addon.php:55
+#: ../http/plugins/mb_metadata_addon.php:75
+#: ../http/plugins/mb_metadata_addon.php:86
+#: ../http/plugins/mb_metadata_addon.php:91
+#: ../http/plugins/mb_metadata_addon.php:107
+#: ../http/plugins/mb_metadata_addon.php:117
+#: ../http/plugins/mb_metadata_addon.php:124
+#: ../http/plugins/mb_metadata_edit.php:13
+#: ../http/plugins/mb_metadata_edit.php:59
+#: ../http/plugins/mb_metadata_edit.php:126
+#: ../http/plugins/mb_metadata_edit.php:151
+#: ../http/plugins/mb_metadata_layer.php:63
+#: ../http/plugins/mb_metadata_wfs_edit.php:13
+#: ../http/plugins/mb_metadata_wfs_edit.php:58
+#: ../http/plugins/mb_metadata_wfs_edit.php:125
+#: ../http/plugins/mb_metadata_wfs_edit.php:150
+msgid "Help"
+msgstr "Hilfe"
+msgid ""
+"Possibility to adapt and add informations in the separate WMS-Layer "
+"Metadata. The modified Metadata is stored in the database of the GeoPortal."
+"rlp, outwardly these metadata overwrite the original Service-Metadata."
+msgstr ""
+"Möglichkeit der Überarbeitung und Ergänzung der WMS Metadaten. Die "
+"bearbeiteten Metadaten werden in der Datenbank des GeoPortal.rlp abgelegt "
+"und überschreiben nach Außen hin die originären Metadaten des WMS-Dienstes."
+msgid ""
+"The original WMS-Metadata from the last update could be recovered or "
+"updated, so that the original Service-Metadata will be shown outward again."
+msgstr ""
+"Anzeige der originären WMS Metadaten (Stand: letzte Aktualisierung) "
+"Hilfetext: Die originären Metadaten des WMS vom Stand der letzten "
+"Aktualisierung können wiederhergestellt bzw. aktualisiert und werden damit "
+"nach Außen sichtbar."
+#: workspace/test27/http/plugins/mb_metadata_edit.php:15
+#: ../http/plugins/mb_metadata_edit.php:16
+msgid "WMS Title (OWS)"
+msgstr "WMS-Titel (OWS)"
+#: workspace/test27/http/plugins/mb_metadata_edit.php:17
+#: workspace/test27/http/plugins/mb_metadata_edit.php:22
+#: workspace/test27/http/plugins/mb_metadata_edit.php:27
+#: workspace/test27/http/plugins/mb_metadata_edit.php:32
+#: workspace/test27/http/plugins/mb_metadata_edit.php:37
+#: workspace/test27/http/plugins/mb_metadata_edit.php:81
+#: workspace/test27/http/plugins/mb_metadata_edit.php:106
+#: workspace/test27/http/plugins/mb_metadata_edit.php:111
+#: workspace/test27/http/plugins/mb_metadata_edit.php:116
+#: workspace/test27/http/plugins/mb_metadata_layer.php:45
+#: workspace/test27/http/plugins/mb_metadata_layer.php:50
+#: workspace/test27/http/plugins/mb_metadata_layer.php:97
+#: workspace/test27/http/plugins/mb_metadata_layer.php:107
+#: ../http/plugins/mb_metadata_edit.php:17
+#: ../http/plugins/mb_metadata_edit.php:22
+#: ../http/plugins/mb_metadata_edit.php:27
+#: ../http/plugins/mb_metadata_edit.php:32
+#: ../http/plugins/mb_metadata_edit.php:37
+#: ../http/plugins/mb_metadata_edit.php:81
+#: ../http/plugins/mb_metadata_edit.php:106
+#: ../http/plugins/mb_metadata_edit.php:111
+#: ../http/plugins/mb_metadata_edit.php:116
+#: ../http/plugins/mb_metadata_featuretype.php:45
+#: ../http/plugins/mb_metadata_featuretype.php:50
+#: ../http/plugins/mb_metadata_featuretype.php:90
+#: ../http/plugins/mb_metadata_featuretype.php:101
+#: ../http/plugins/mb_metadata_layer.php:45
+#: ../http/plugins/mb_metadata_layer.php:50
+#: ../http/plugins/mb_metadata_layer.php:97
+#: ../http/plugins/mb_metadata_layer.php:108
+#: ../http/plugins/mb_metadata_wfs_edit.php:17
+#: ../http/plugins/mb_metadata_wfs_edit.php:22
+#: ../http/plugins/mb_metadata_wfs_edit.php:27
+#: ../http/plugins/mb_metadata_wfs_edit.php:32
+#: ../http/plugins/mb_metadata_wfs_edit.php:37
+#: ../http/plugins/mb_metadata_wfs_edit.php:81
+#: ../http/plugins/mb_metadata_wfs_edit.php:106
+#: ../http/plugins/mb_metadata_wfs_edit.php:111
+#: ../http/plugins/mb_metadata_wfs_edit.php:116
+#: ../http/plugins/mb_metadata_wmc_edit.php:36
+#: ../http/plugins/mb_metadata_wmc_edit.php:41
+#: ../http/plugins/mb_metadata_wmc_edit.php:46
+#: ../http/plugins/mb_metadata_wmc_edit.php:70
+#: ../http/plugins/mb_metadata_wmc_edit.php:81
+#: ../http/plugins/mb_metadata_layer.php:88
+#: ../http/plugins/mb_metadata_layer.php:99
+msgid "Inspire"
+msgstr "Inspire"
+#: workspace/test27/http/plugins/mb_metadata_edit.php:20
+#: ../http/plugins/mb_metadata_edit.php:20
+#: ../http/plugins/mb_metadata_edit.php:21
+msgid "WMS Abstract (OWS)"
+msgstr "WMS-Beschreibung (OWS)"
+#: workspace/test27/http/plugins/mb_metadata_edit.php:25
+#: ../http/plugins/mb_metadata_edit.php:25
+msgid "WMS Keywords (OWS)"
+msgstr "WMS Schlüsselwörter (OWS)"
+#: workspace/test27/http/plugins/mb_metadata_edit.php:30
+#: ../http/plugins/mb_metadata_edit.php:30
+msgid "WMS Fees (OWS)"
+msgstr "WMS Kosten/Gebühren (OWS)"
+#: workspace/test27/http/plugins/mb_metadata_edit.php:35
+#: ../http/plugins/mb_metadata_edit.php:35
+msgid "WMS AccessConstraints (OWS)"
+msgstr "WMS Zugriffsbeschränkung (OWS)"
+#: workspace/test27/http/plugins/mb_metadata_edit.php:48
+#: ../http/plugins/mb_metadata_edit.php:48
+#: ../http/plugins/mb_metadata_edit.php:50
+msgid "WMS Predefined Licence (Registry)"
+msgstr "WMS vordefiniere Lizenzbedingungen (Registry)"
+msgid ""
+"Auswahl von vordefinierten Lizenzen hinsichtlich Gebühren und "
+"Zugriffsbeschränkungen."
+msgstr ""
+#: workspace/test27/http/plugins/mb_metadata_edit.php:61
+#: ../http/plugins/mb_metadata_edit.php:61
+#: ../http/plugins/mb_metadata_edit.php:67
+msgid "WMS Provider Section (OWS)"
+msgstr "Bereitstellende Organisation (OWS)"
+#: workspace/test27/http/plugins/mb_metadata_edit.php:63
+#: ../http/plugins/mb_metadata_edit.php:63
+#: ../http/plugins/mb_metadata_wfs_edit.php:63
+#: ../http/plugins/mb_metadata_edit.php:69
+#: ../http/plugins/mb_metadata_wfs_edit.php:68
+msgid "Contact Individual Name (OWS)"
+msgstr "Ansprechpartner (OWS)"
+#: workspace/test27/http/plugins/mb_metadata_edit.php:67
+#: ../http/plugins/mb_metadata_wfs_edit.php:67
+#: ../http/plugins/mb_metadata_edit.php:73
+#: ../http/plugins/mb_metadata_wfs_edit.php:72
+msgid "Contact Position Name (OWS)"
+msgstr "Position des Ansprechpartners (OWS)"
+#: workspace/test27/http/plugins/mb_metadata_edit.php:71
+#: ../http/plugins/mb_metadata_edit.php:71
+#: ../http/plugins/mb_metadata_wfs_edit.php:71
+#: ../http/plugins/mb_metadata_edit.php:77
+#: ../http/plugins/mb_metadata_wfs_edit.php:76
+msgid "Contact Phone Voice (OWS)"
+msgstr "Telefonnummer (OWS)"
+#: workspace/test27/http/plugins/mb_metadata_edit.php:79
+#: ../http/plugins/mb_metadata_edit.php:79
+#: ../http/plugins/mb_metadata_edit.php:85
+msgid "Contact Organisation (WMS)"
+msgstr "Organisation (WMS)"
+#: workspace/test27/http/plugins/mb_metadata_edit.php:84
+#: ../http/plugins/mb_metadata_edit.php:84
+#: ../http/plugins/mb_metadata_edit.php:90
+msgid "Contact Address (WMS)"
+msgstr "Adresse (WMS)"
+#: workspace/test27/http/plugins/mb_metadata_edit.php:88
+#: ../http/plugins/mb_metadata_edit.php:88
+#: ../http/plugins/mb_metadata_edit.php:94
+msgid "Contact City (WMS)"
+msgstr "Ort/Stadt (WMS)"
+#: workspace/test27/http/plugins/mb_metadata_edit.php:92
+#: ../http/plugins/mb_metadata_edit.php:92
+#: ../http/plugins/mb_metadata_edit.php:98
+msgid "Contact State or Province (WMS) - ISO 3166-II"
+msgstr "Bundesland (WMS)"
+#: workspace/test27/http/plugins/mb_metadata_edit.php:96
+#: ../http/plugins/mb_metadata_edit.php:96
+#: ../http/plugins/mb_metadata_edit.php:102
+msgid "Contact Post Code (WMS)"
+msgstr "PLZ (WMS)"
+#: workspace/test27/http/plugins/mb_metadata_edit.php:100
+#: ../http/plugins/mb_metadata_edit.php:100
+msgid "Contact Post Country (WMS) - ISO 3166"
+msgstr "Land (WMS)"
+#: workspace/test27/http/plugins/mb_metadata_edit.php:104
+#: ../http/plugins/mb_metadata_edit.php:104
+#: ../http/plugins/mb_metadata_edit.php:110
+msgid "Contact Electronic Mail Address (WMS)"
+msgstr "e-mail (WMS)"
+#: workspace/test27/http/plugins/mb_metadata_edit.php:109
+#: ../http/plugins/mb_metadata_edit.php:109
+#: ../http/plugins/mb_metadata_wfs_edit.php:109
+#: ../http/plugins/mb_metadata_edit.php:115
+#: ../http/plugins/mb_metadata_wfs_edit.php:114
+msgid "Date of first registration (Registry)"
+msgstr "Datum der ersten Registrierung des WMS-Dienstes (Registry)"
+#: workspace/test27/http/plugins/mb_metadata_edit.php:114
+#: ../http/plugins/mb_metadata_edit.php:114
+#: ../http/plugins/mb_metadata_edit.php:120
+#: ../http/plugins/mb_metadata_wfs_edit.php:119
+msgid "Date of last revision (Registry)"
+msgstr "Datum des letzten Updates des WMS-Dienstes (Registry)"
+msgid ""
+"Metadata. The modified Metadata will be stored in the database of the "
+"GeoPortal.rlp, outwardly these metadata overwrite the original Service-"
+"Metadata."
+msgstr ""
+"Möglichkeit der Überarbeitung und Ergänzung der in den einzelnen WMS-Layern "
+"enthaltenen Metadaten. Die bearbeiteten Metadaten werden in der Datenbank "
+"des GeoPortal.rlp abgelegt und überschreiben nach Außen hin die originären "
+"Metadaten des WMS-Dienstes."
+#: workspace/test27/http/plugins/mb_metadata_layer.php:39
+#: ../http/plugins/mb_metadata_layer.php:39
+msgid "Number of Layer (Registry)"
+msgstr "Identifikationsnummer des Layers (Registry)"
+#: workspace/test27/http/plugins/mb_metadata_layer.php:44
+#: ../http/plugins/mb_metadata_layer.php:44
+msgid "Layer Title (WMS)"
+msgstr "Layertitel (WMS)"
+#: workspace/test27/http/plugins/mb_metadata_layer.php:49
+#: ../http/plugins/mb_metadata_layer.php:49
+msgid "Layer Abstract (WMS)"
+msgstr "Beschreibung (WMS)"
+#: workspace/test27/http/plugins/mb_metadata_layer.php:54
+#: ../http/plugins/mb_metadata_layer.php:54
+msgid "Layer Keywords (WMS)"
+msgstr "Schlüsselwörter (WMS)"
+#: workspace/test27/http/plugins/mb_metadata_layer.php:61
+#: ../http/plugins/mb_metadata_featuretype.php:61
+#: ../http/plugins/mb_metadata_layer.php:61
+msgid "Add Information about the underlying data"
+msgstr "Weitere standardisierte Informationen zum Layer (Datensatz-Metadaten)"
+msgid ""
+"Linking the WMS layer with metadata set (coupled resource), which describes "
+"the underlying informations of the representation in more detail (eg "
+"Actuality / quality). It occurs via a link to an already existing metadta "
+"set in a catalog or a simple metadata set will be generatetd using a "
+"Mapbender Layer Addon-Editor."
+msgstr ""
+"Verknüpfen des WMS-Layers mit einem Metadatensatzes (gekoppelte Ressource), "
+"der die der Darstellung zugrundeliegenden Informationen näher beschreibt (z."
+"B.: Aktualität/Qualität). Verknüpfung erfolgt entweder über Link zu einem "
+"schon in einem Katalog vorhandenen Metadatensatz oder über die Generierung "
+"des eines einfachen Metadatensatzes mittels Mapbender Layer-AddonEditor."
+#: ../http/plugins/mb_metadata_featuretype.php:65
+#: ../http/plugins/mb_metadata_layer.php:65
+msgid "Add new Metadata Record"
+msgstr "Metadatensatz erzeugen"
+#: ../http/plugins/mb_metadata_featuretype.php:68
+#: ../http/plugins/mb_metadata_layer.php:68
+msgid "Edit Metadata Linkage"
+msgstr "Metadatensatz editieren"
+#: ../http/plugins/mb_metadata_featuretype.php:71
+#: ../http/plugins/mb_metadata_layer.php:71
+msgid "Delete Metadata Linkage"
+msgstr "Metadatensatz löschen"
+#: workspace/test27/http/plugins/mb_metadata_layer.php:86
+#: ../http/plugins/mb_metadata_layer.php:86
+#: ../http/plugins/mb_metadata_wmc_edit.php:57
+#: ../http/plugins/mb_metadata_layer.php:77
+msgid "Preview"
+msgstr "Vorschau"
+#: workspace/test27/http/plugins/mb_metadata_layer.php:94
+#: ../http/plugins/mb_metadata_featuretype.php:87
+#: ../http/plugins/mb_metadata_layer.php:94
+#: ../http/plugins/mb_metadata_wmc_edit.php:66
+#: ../http/plugins/mb_metadata_layer.php:85
+msgid "Classification"
+msgstr "Klassifizierung"
+#: workspace/test27/http/plugins/mb_metadata_layer.php:96
+#: ../http/plugins/mb_metadata_featuretype.php:89
+#: ../http/plugins/mb_metadata_layer.php:96
+#: ../http/plugins/mb_metadata_wmc_edit.php:68
+#: ../http/plugins/mb_metadata_layer.php:87
+msgid "ISO Topic Category"
+msgstr "ISO-Kategorie"
+#: workspace/test27/http/plugins/mb_metadata_layer.php:106
+#: ../http/plugins/mb_metadata_featuretype.php:100
+#: ../http/plugins/mb_metadata_layer.php:107
+#: ../http/plugins/mb_metadata_wmc_edit.php:80
+#: ../http/plugins/mb_metadata_layer.php:98
+msgid "INSPIRE Category"
+msgstr "INSPIRE Kategorie"
+#: workspace/test27/http/plugins/mb_metadata_layer.php:116
+#: ../http/plugins/mb_metadata_featuretype.php:111
+#: ../http/plugins/mb_metadata_layer.php:118
+#: ../http/plugins/mb_metadata_wmc_edit.php:91
+#: ../http/plugins/mb_metadata_layer.php:109
+msgid "Custom Category"
+msgstr "Frei definierte Kategorie"
+#: workspace/test27/http/plugins/mb_metadata_server.php:20
+#: workspace/test27/http/plugins/mb_metadata_server.php:32
+#: ../http/plugins/mb_metadata_server.php:20
+#: ../http/plugins/mb_metadata_server.php:32
+#: ../http/plugins/mb_metadata_wfs_server.php:21
+#: ../http/plugins/mb_metadata_wfs_server.php:33
+#: ../http/plugins/mb_metadata_wmc_server.php:23
+#: ../http/plugins/mb_metadata_server.php:31
+#: ../http/plugins/mb_metadata_wfs_server.php:31
+msgid "No metadata sets available."
+msgstr "Keine Metadaten verfügbar."
+#: workspace/test27/http/plugins/mb_metadata_server.php:23
+#: ../http/plugins/mb_metadata_server.php:23
+#: ../http/plugins/mb_metadata_server.php:22
+msgid "You are not allowed to access this WMS."
+msgstr "Es ist Ihnen nicht gestattet auf diesen WMS zuzugreifen."
+#: workspace/test27/http/plugins/mb_metadata_server.php:36
+#: ../http/plugins/mb_metadata_server.php:36
+#: ../http/plugins/mb_metadata_server.php:35
+msgid "You are not allowed to access WMS "
+msgstr "Der Zugriff auf WMS-Dienste ist Ihnen nicht erlaubt."
+#: workspace/test27/http/plugins/mb_metadata_server.php:300
+#: ../http/plugins/mb_metadata_server.php:319
+#: ../http/plugins/mb_metadata_server.php:400
+msgid "Invalid WMS ID."
+msgstr "Ungültige WMS ID."
+#: workspace/test27/http/plugins/mb_twitter.php:22
+msgid ""
+"Element vars consumerKey and consumerSecret are not set. If you don't have "
+"them, get them from Twitter."
+msgstr ""
+"Die Elemente vars consumerKey und consumerSecret sind nicht definiert. Falls "
+"diese nicht vorliegen, können diese über Twitter ermittelt werden."
+#: workspace/test27/http/plugins/mb_twitter.php:64
+msgid "Signed in."
+msgstr "Angemeldet."
+#: workspace/test27/http/plugins/mb_twitter.php:69
+#: workspace/test27/http/plugins/mb_twitter.php:99
+msgid "Not signed in."
+msgstr "Nicht angemeldet."
+#: workspace/test27/http/plugins/mb_twitter.php:79
+#: workspace/test27/http/plugins/mb_twitter.php:116
+msgid "Could not connect to Twitter."
+msgstr "Verbindung zu Twitter fehlgeschlagen."
+#: workspace/test27/http/plugins/mb_twitter.php:92
+msgid "Signed out."
+msgstr "Abgemeldet."
+#: workspace/test27/http/plugins/mb_metadata_edit.php:75
+#: ../http/plugins/mb_metadata_edit.php:75
+#: ../http/plugins/mb_metadata_wfs_edit.php:75
+#: ../http/plugins/mb_metadata_wfs_edit.php:80
+msgid "Contact Phone Fax (OWS)"
+msgstr "Kontakt Telefonnummer (OWS)"
+msgid ""
+"Possibility to adapt and add informations in the separate WFS-Featuretype "
+"Metadata."
+msgstr ""
+msgid ""
+"The original WFS-Metadata from the last update could be recovered or "
+msgstr ""
+#: ../http/plugins/mb_metadata_featuretype.php:39
+msgid "Number of Featuretype (Registry)"
+msgstr "Nummer des Featuretype (Registry)"
+#: ../http/plugins/mb_metadata_featuretype.php:44
+msgid "Featuretype Title (WFS)"
+msgstr "Featuretype Titel (WFS)"
+#: ../http/plugins/mb_metadata_featuretype.php:49
+msgid "Featuretype Abstract (WFS)"
+msgstr ""
+#: ../http/plugins/mb_metadata_featuretype.php:54
+msgid "Featuretype Keywords (WFS)"
+msgstr ""
+msgid ""
+"Linking the WFS layer with metadata set (coupled resource), which describes "
+"set in a catalog or a simple metadata set will be generated using a "
+msgstr ""
+#: ../http/plugins/mb_metadata_featuretype.php:97
+#: ../http/plugins/mb_metadata_featuretype.php:108
+#: ../http/plugins/mb_metadata_featuretype.php:119
+#: ../http/plugins/mb_metadata_layer.php:104
+#: ../http/plugins/mb_metadata_layer.php:115
+#: ../http/plugins/mb_metadata_layer.php:126
+#: ../http/plugins/mb_metadata_wmc_edit.php:77
+#: ../http/plugins/mb_metadata_wmc_edit.php:88
+#: ../http/plugins/mb_metadata_wmc_edit.php:99
+#: ../http/plugins/mb_metadata_layer.php:95
+#: ../http/plugins/mb_metadata_layer.php:106
+#: ../http/plugins/mb_metadata_layer.php:117
+msgid "Reset selection"
+msgstr "Auswahl löschen"
+msgid ""
+msgstr ""
+#: ../http/plugins/mb_metadata_wfs_edit.php:16
+msgid "WFS Title (OWS)"
+msgstr ""
+#: ../http/plugins/mb_metadata_wfs_edit.php:20
+#: ../http/plugins/mb_metadata_wfs_edit.php:21
+msgid "WFS Abstract (OWS)"
+msgstr ""
+#: ../http/plugins/mb_metadata_wfs_edit.php:25
+#: ../http/plugins/mb_metadata_wfs_edit.php:26
+msgid "WFS Keywords (OWS)"
+msgstr ""
+#: ../http/plugins/mb_metadata_wfs_edit.php:30
+#: ../http/plugins/mb_metadata_wfs_edit.php:31
+msgid "WFS Fees (OWS)"
+msgstr ""
+#: ../http/plugins/mb_metadata_wfs_edit.php:35
+#: ../http/plugins/mb_metadata_wfs_edit.php:36
+msgid "WFS AccessConstraints (OWS)"
+msgstr ""
+#: ../http/plugins/mb_metadata_wfs_edit.php:48
+#: ../http/plugins/mb_metadata_wfs_edit.php:49
+msgid "WFS Predefined Licence (Registry)"
+msgstr ""
+#: ../http/plugins/mb_metadata_wfs_edit.php:61
+#: ../http/plugins/mb_metadata_wfs_edit.php:66
+msgid "WFS Provider Section (OWS)"
+msgstr ""
+#: ../http/plugins/mb_metadata_wfs_edit.php:79
+#: ../http/plugins/mb_metadata_wfs_edit.php:84
+msgid "Contact Organisation (WFS)"
+msgstr ""
+#: ../http/plugins/mb_metadata_wfs_edit.php:89
+msgid "Contact Address (WFS)"
+msgstr ""
+#: ../http/plugins/mb_metadata_wfs_edit.php:88
+#: ../http/plugins/mb_metadata_wfs_edit.php:93
+msgid "Contact City (WFS)"
+msgstr ""
+#: ../http/plugins/mb_metadata_wfs_edit.php:92
+#: ../http/plugins/mb_metadata_wfs_edit.php:97
+msgid "Contact State or Province (WFS) - ISO 3166-II"
+msgstr ""
+#: ../http/plugins/mb_metadata_wfs_edit.php:96
+#: ../http/plugins/mb_metadata_wfs_edit.php:101
+msgid "Contact Post Code (WFS)"
+msgstr ""
+#: ../http/plugins/mb_metadata_wfs_edit.php:100
+#: ../http/plugins/mb_metadata_wfs_edit.php:105
+msgid "Contact Post Country (WFS) - ISO 3166"
+msgstr ""
+#: ../http/plugins/mb_metadata_wfs_edit.php:104
+msgid "Contact Electronic Mail Address (WFS)"
+msgstr ""
+#: ../http/plugins/mb_metadata_wfs_server.php:24
+#: ../http/plugins/mb_metadata_wfs_server.php:22
+msgid "You are not allowed to access this WFS."
+msgstr ""
+#: ../http/plugins/mb_metadata_wfs_server.php:37
+#: ../http/plugins/mb_metadata_wfs_server.php:35
+msgid "You are not allowed to access this WFS "
+msgstr ""
+#: ../http/plugins/mb_metadata_wfs_server.php:286
+#: ../http/plugins/mb_metadata_wfs_server.php:295
+#: ../http/plugins/mb_metadata_wfs_server.php:342
+#: ../http/plugins/mb_metadata_wfs_server.php:351
+msgid "Invalid WFS ID."
+msgstr "Invalide WFS Identifikationsnummer"
+msgid ""
+"Possibility to adapt and add informations in the separate WMC-Featuretype "
+msgstr ""
+#: ../http/plugins/mb_metadata_wmc_edit.php:34
+msgid "WMC Title (OWS)"
+msgstr ""
+#: ../http/plugins/mb_metadata_wmc_edit.php:39
+msgid "WMC Abstract (OWS)"
+msgstr ""
+#: ../http/plugins/mb_metadata_wmc_edit.php:44
+msgid "WMC Keywords (OWS)"
+msgstr ""
+#: ../http/plugins/mb_metadata_wmc_edit.php:49
+msgid "WMC is public"
+msgstr "Kartenzusammenstellung ist öffentlich"
+#: ../http/plugins/mb_metadata_wmc_server.php:26
+msgid "You are not allowed to access this WMC."
+msgstr "Sie sind nicht autorisiert diese Kartenzusammenstellung zu nutzen."
+#: ../http/plugins/mb_metadata_wmc_server.php:147
+#: ../http/plugins/mb_metadata_wmc_server.php:155
+#: ../http/plugins/mb_metadata_wmc_server.php:144
+#: ../http/plugins/mb_metadata_wmc_server.php:152
+msgid "Invalid WMC ID."
+msgstr "Invalide WMC Identifizierungsnummer"
+#: ../http/plugins/mb_sql_server.php:31
+msgid "You are not allowed to access this application."
+msgstr "Sie sind nicht autorisiert diese Anwendung zu verwenden!"
+#: ../http/plugins/mb_measure_widget.php:47
+#: ../http/plugins/mb_measure_widget.php:80
+msgid "Click in the map to start measuring."
+msgstr "Klicken Sie in die Karte, um die Messung zu starten."
+#: ../http/plugins/mb_measure_widget.php:51
+#: ../http/plugins/mb_measure_widget.php:84
+msgid "Last point: "
+msgstr "letzter Stützpunkt: "
+#: ../http/plugins/mb_measure_widget.php:54
+#: ../http/plugins/mb_measure_widget.php:87
+msgid "Current point: "
+msgstr "aktueller Stützpunkt: "
+#: ../http/plugins/mb_measure_widget.php:57
+#: ../http/plugins/mb_measure_widget.php:90
+msgid "Distance (to last point): "
+msgstr "Entfernung zum letzten Punkt: "
+#: ../http/plugins/mb_measure_widget.php:60
+#: ../http/plugins/mb_measure_widget.php:93
+msgid "Distance (total): "
+msgstr "Länge (gesamt): "
+#: ../http/plugins/mb_measure_widget.php:63
+#: ../http/javascripts/mod_coordsLookup.php:100
+#: ../http/plugins/mb_measure_widget.php:96
+#: ../http/javascripts/mod_coordsLookup.php:125
+msgid "Perimeter: "
+msgstr "Umring: "
+#: ../http/javascripts/mod_coordsLookup.php:90
+#: ../http/javascripts/mod_coordsLookup.php:115
+msgid "Spatial Reference System"
+msgstr "Räumliches Bezugssystem"
+#: ../http/javascripts/mod_coordsLookup.php:81
+#: ../http/javascripts/mod_coordsLookup.php:105
+msgid "zoom to coordinates"
+msgstr "Auf Koordinaten zoomen"
+#: ../http/javascripts/mod_coordsLookup.php:71
+#: ../http/javascripts/mod_coordsLookup.php:95
+msgid "coordinates"
+msgstr "Koordinaten"
+#: ../http/javascripts/mod_coordsLookup.php:128
+#: ../http/javascripts/mod_coordsLookup.php:153
+msgid "Invalid X coordinate! Must be a float or a DMS value!"
+msgstr ""
+"Ungültige X Koordinate! Erlaubt sind lediglich Fließkomma oder GMS Werte!"
+#: ../http/javascripts/mod_coordsLookup.php:139
+#: ../http/javascripts/mod_coordsLookup.php:165
+msgid "Invalid Y coordinate! Must be a float or a DMS value!"
+msgstr ""
+"Ungültige Y Koordinate! Erlaubt sind lediglich Fließkomma oder GMS Werte!"
+#: ../http/javascripts/mod_coordsLookup.php:147
+#: ../http/javascripts/mod_coordsLookup.php:174
+msgid "Invalid SRS!"
+msgstr "Ungültiges KBS!"
+#: ../http/plugins/mb_measure_widget.php:66
+#: ../http/plugins/mb_measure_widget.php:99
+msgid "Area: "
+msgstr "Fläche: "
+#: ../http/plugins/mb_print.php:461
+msgid "print document"
+msgstr "Drucke Dokument"
+#: ../http/plugins/mb_print.php:560 ../http/plugins/mb_print.php:602
+msgid "use print box"
+msgstr "Nutze Druckrahmen"
+#: ../http/php/mod_abo_show.php:40
+msgid "Mapbender Service Provider"
+msgstr ""
+#: ../http/php/mod_abo_show.php:41
+msgid "Confirmation of subscribers notification"
+msgstr "Bestätigung der Abonnentenbenachrichtigung"
+#: ../http/php/mod_abo_show.php:43
+msgid "Mapbender monitoring subscriber"
+msgstr "Monitoring abonnieren"
+#: ../http/php/mod_abo_show.php:44
+msgid "Mapbender subscribers notification"
+msgstr "Abonnentenbenachrichtigung"
+#: ../http/php/mod_abo_show.php:45
+msgid "The following services are affected"
+msgstr "Folgende Dienste sind betroffen "
+#: ../http/php/mod_abo_show.php:46
+msgid "e-mail form for notifications to the subscribers of the following WMS"
+msgstr "EMail Formular für die Benachrichtigung der Abonnenten folgender WMS "
+#: ../http/php/mod_abo_show.php:47
+msgid "Subscriber notification for Mapbender service providers"
+msgstr "Abo Benachrichtigung für die Anbieter von OWS"
+#: ../http/php/mod_abo_show.php:48
+msgid ""
+"Notifications have been sent. You will receive a confirmation mail shortly."
+msgstr ""
+"Benachrichtung wurde gesendet. Sie werden in Kürze eine Bestätigungsmail "
+"erhalten."
+#: ../http/php/mod_abo_show.php:49
+msgid "Create mail form"
+msgstr "Erzeuge Mail Formular"
+#: ../http/php/mod_abo_show.php:50
+msgid "The subscribers to these WMS have been notified"
+msgstr "Die Abonnenten folgender WMS wurden benachrichtigt"
+#: ../http/php/mod_abo_show.php:51
+msgid "For further inquiries contact"
+msgstr "Für weitere Fragen kontaktieren sie bitte "
+#: ../http/php/mod_abo_show.php:52
+msgid "Subscriber notification"
+msgstr "Abonnenten Benachrichtigung"
+#: ../http/php/mod_abo_show.php:53
+msgid "# subscribers"
+msgstr "# Abonnenten"
+#: ../http/php/mod_abo_show.php:54
+msgid "Notify"
+msgstr "Benachrichtigung"
+#: ../http/php/mod_abo_show.php:55
+msgid "Send mail"
+msgstr "Sende EMail"
+#: ../http/php/mod_acceptedTou_server.php:39
+#: ../http/php/mod_loadwmc_server.php:269
+#: ../http/php/mod_sessionWmc_server.php:56
+#: ../http/php/mod_loadwmc_server.php:271
+msgid "No method specified."
+msgstr "Keine Methode definiert."
+#: ../http/php/mod_changeEPSG_server.php:30
+#: ../http/php/mod_coordsLookup_server.php:67
+msgid "PostGIS is not available. Please contact the administrator."
+msgstr ""
+"PostGIS ist nicht verfügbar. Bitte benachrichtigen sie den Administrator."
+#: ../http/php/mod_changeEPSG_server.php:71
+msgid "The coordinates could not be projected."
+msgstr "Die Koordinaten konnten nicht transformiert werden."
+#: ../http/php/mod_createCategory.php:71
+msgid "Please enter a category name!"
+msgstr "Geben sie bitte einen Namen für die Kategorie an! "
+#: ../http/php/mod_createCategory.php:76
+msgid "Please enter a category description!"
+msgstr "Bitte geben sie eine Beschreibung für die Kategorie an!"
+#: ../http/php/mod_createCategory.php:104
+msgid "existing Categories"
+msgstr "vorhandene Kategorien"
+#: ../http/php/mod_createCategory.php:116
+msgid "Category Name"
+msgstr "Kategorie Namen"
+#: ../http/php/mod_createCategory.php:117 ../lib/editGroup.php:219
+#: ../lib/editUser.php:408
+msgid "Description"
+#: ../http/php/mod_createCategory.php:125
+msgid "The Category has been created successfully."
+msgstr "Die Kategorie wurde erfolgreich erstellt."
+#: ../http/php/mod_customTree.php:61
+msgid "You have changed the tree. All changes will be lost. Save changes?"
+msgstr ""
+#: ../http/php/mod_customTree.php:160
+msgid "You are about to delete your customized folder structure. Proceed?"
+msgstr ""
+#: ../http/php/mod_customTree.php:220
+msgid "Configure tree"
+msgstr "Konfiguriere Layerbaum"
+#: ../http/php/mod_customTree.php:221
+msgid "Please select a gui which its tree should be configured."
+msgstr ""
+#: ../http/php/mod_customTree.php:229 ../http/php/mod_customTree.php:236
+msgid "Add"
+msgstr "Hinzufügen"
+#: ../http/php/mod_customTree.php:231
+msgid "Edit"
+msgstr "Editieren"
+#: ../http/php/mod_editElements.php:563
+msgid ""
+"Please make sure you have made a backup of your application before using "
+"this feature! Continue?"
+msgstr ""
+#: ../http/php/mod_layerMetadata.php:277 ../http/php/mod_showMetadata.php:710
+#: ../http/php/mod_showMetadata.php:786
+msgid "Monitoring Abo löschen"
+msgstr ""
+#: ../http/php/mod_layerMetadata.php:283 ../http/php/mod_showMetadata.php:715
+msgid "Subscribe Monitoring"
+#: ../http/php/mod_loadwmc_server.php:32 ../http/php/mod_loadwmc_server.php:34
+msgid "The WMC document could not be found."
+msgstr "Das Dokument konnte nicht gefunden werden."
+#: ../http/php/mod_loadwmc_server.php:46 ../http/php/mod_loadwmc_server.php:48
+msgid "WMC has been deleted from the database."
+msgstr "Das Dokument wurde aus der Datenbank entfernt."
+#: ../http/php/mod_loadwmc_server.php:50 ../http/php/mod_loadwmc_server.php:52
+msgid "WMC could not be deleted."
+msgstr "WMC konnte nicht gelöscht werden."
+#: ../http/php/mod_loadwmc_server.php:78 ../http/php/mod_loadwmc_server.php:87
+#: ../http/php/mod_loadwmc_server.php:101
+#: ../http/php/mod_loadwmc_server.php:80 ../http/php/mod_loadwmc_server.php:89
+#: ../http/php/mod_loadwmc_server.php:103
+msgid "WMC could not be loaded."
+msgstr "WMC konnte nicht geladen werden"
+#: ../http/php/mod_loadwmc_server.php:132
+#: ../http/php/mod_loadwmc_server.php:134
+msgid "WMC could not be merged."
+msgstr ""
+#: ../http/php/mod_loadwmc_server.php:163
+#: ../http/php/mod_loadwmc_server.php:165
+msgid "WMC could not be appended."
+msgstr "WMC konnte nicht angefügt werden."
+#: ../http/php/mod_loadwmc_server.php:174
+#: ../http/php/mod_loadwmc_server.php:176
+msgid "Updated public flag"
+msgstr "Öffentlichkeitsflag wurde aktualisiert"
+#: ../http/php/mod_loadwmc_server.php:177
+#: ../http/php/mod_loadwmc_server.php:179
+msgid "could not update public flag"
+msgstr "Kann Öffentlichkeitsflag nicht aktualisieren."
+msgid "Save configuration as WebMapContext document"
+msgstr "Speichere Konfiguration als WebMapContext Dokument"
+#: ../http/php/mod_map_messages.php:30
+msgid "The following WMS do not support the current SRS"
+msgstr ""
+"Folgende WMS unterstützen das verwendete Koordinatenbezugssystem nicht "
+#: ../http/php/mod_meetingPoint.php:222 ../http/php/mod_meetingPoint.php:223
+msgid "Input too long. Maximum of allowed characters is"
+msgstr "Eingabe zu lang. Maximale Stellenzahl "
+#: ../http/php/mod_savewmc_server.php:75
+#: ../http/php/mod_savewmc_server.php:102
+msgid "saved wmc document to session"
+msgstr "Speichere Dokument zwischen"
+#: ../http/php/mod_savewmc_server.php:84 ../http/php/mod_savewmc_server.php:91
+#: ../http/php/mod_savewmc_server.php:111
+#: ../http/php/mod_savewmc_server.php:118
+msgid "WMC document must have a title."
+msgstr "WebMapContext Dokument braucht einen Titel"
+#: ../http/php/mod_savewmc_server.php:117
+#: ../http/php/mod_savewmc_server.php:145
+msgid "WMC"
+msgstr "WMC"
+msgid "has been saved."
+msgstr "wurde gespeichert."
+#: ../http/javascripts/mod_savewmc.js
+msgid "New / overwrite"
+msgstr "Neu / überschreiben"
+msgid "Categories"
+msgstr "Kategorien"
+#: ../http/php/mod_sessionWmc_server.php:27
+msgid "WMC in session reset."
+msgstr "Zwischenspeicherung wurde verworfen."
+#: ../http/php/mod_sessionWmc_server.php:30
+msgid "No WMC in session found."
+msgstr "Kein Dokument in der Session vorhanden."
+#: ../http/php/mod_sessionWmc_server.php:40
+msgid "No WMC in session."
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:144
+msgid ""
+"The map service contains too many layers. The layers of this service will "
+"not be activated"
+msgstr ""
+"Der Dienst beinhaltet zu viele Ebenen. Die Ebenen werden daher automatisch "
+"deaktiviert."
+#: ../http/javascripts/mod_addWMSfromfilteredList_ajax.php:194
+msgid "The following Service has been added to the application"
+msgstr "Folgender Dienst wurde in die Anwendung eingebunden."
+#: ../http/javascripts/mod_featureInfoTunnel.php:158
+#: ../http/javascripts/mod_featureInfoTunnel.php:166
+#: ../http/javascripts/mod_wfsGazetteerEditor_client.php:950
+#: ../http/javascripts/mod_wfsGazetteerEditor_client.php:1079
+msgid "No result"
+msgstr "Kein Ergebnis"
+#: ../http/javascripts/mod_georss.php:67
+msgid "mapframe: "
+msgstr "Kartenrahmen: "
+#: ../http/javascripts/mod_georss.php:76
+#: ../http/javascripts/mod_georss.php:121
+msgid "No GeoRSS feed information found. Please check your URL."
+msgstr "Keine GeoRSS gefunden. Bitte checken sie die URL."
+#: ../http/javascripts/mod_help.php:27
+msgid "click highlighted elements for help"
+msgstr ""
+#: ../http/javascripts/mod_poi.php:95
+msgid "Invalid search term"
+msgstr "Invalider Suchbegriff"
+#: ../http/javascripts/mod_poi.php:111
+msgid "Invalid language"
+msgstr "Unzulässige Sprache"
+#: ../http/javascripts/mod_poi.php:125
+msgid "Invalid configuration file"
+msgstr ""
+#: ../http/javascripts/mod_searchCSW_ajax.php:363
+msgid "Record ID"
+msgstr "Datensatz Identifikator"
+#: ../http/javascripts/mod_searchCSW_form.php:49
+msgid "Search catalog metadata"
+msgstr ""
+#: ../http/javascripts/mod_searchCSW_form.php:77
+msgid "Lat-Maz"
+msgstr ""
+#: ../lib/ajax.php:134
+msgid "Fatal error: Could not detect ID of AJAX request."
+msgstr ""
+#: ../lib/ajax.php:144
+msgid "The session has expired. Please log in again."
+msgstr "Die Sitzung ist abgelaufen, bitte melden sie sich erneut an."
+#: ../lib/editGroup.php:189
+msgid "Name"
+msgstr "Name"
+#: ../lib/editGroup.php:198 ../http/plugins/mb_metadata_edit.php:156
+#: ../http/plugins/mb_metadata_wfs_edit.php:155
+msgid "Title"
+msgstr "Titel"
+#: ../lib/editGroup.php:208 ../lib/editUser.php:524
+msgid "Owner"
+msgstr "Eigentümer"
+#: ../lib/editGroup.php:228 ../http/plugins/mb_metadata_edit.php:161
+#: ../http/plugins/mb_metadata_wfs_edit.php:160
+msgid "Address"
+msgstr "Adresse"
+#: ../lib/editGroup.php:237 ../http/plugins/mb_metadata_edit.php:165
+#: ../http/plugins/mb_metadata_wfs_edit.php:164
+msgid "Postcode"
+msgstr "Postleitzahl"
+#: ../lib/editGroup.php:246 ../lib/editUser.php:478
+#: ../http/plugins/mb_metadata_edit.php:169
+#: ../http/plugins/mb_metadata_wfs_edit.php:168
+msgid "City"
+msgstr "Stadt"
+#: ../lib/editGroup.php:255
+msgid "Province"
+msgstr "(Bundes) Land"
+#: ../lib/editGroup.php:264 ../lib/editUser.php:510
+msgid "Country"
+msgstr "Staat"
+#: ../lib/editGroup.php:273
+msgid "Voicetelephone"
+msgstr "Telefonnummer"
+#: ../lib/editGroup.php:282
+msgid "Facsimiletelephone"
+msgstr "Faxnummer"
+#: ../lib/editUser.php:155 ../lib/editUser.php:196
+msgid "Username must be unique!"
+msgstr "Der Nutzername muß eindeutig sein!"
+#: ../lib/editUser.php:273
+msgid "User"
+msgstr "Nutzer"
+#: ../lib/editUser.php:278
+msgid "NEW"
+msgstr "NEU"
+#: ../lib/editUser.php:344
+msgid "Username"
+msgstr "Nutzername"
+#: ../lib/editUser.php:351
+msgid "Firstname"
+msgstr "Vorname"
+#: ../lib/editUser.php:359
+msgid "Lastname"
+msgstr "Nachname"
+#: ../lib/editUser.php:366
+msgid "Academic title"
+msgstr "Akademischer Titel"
+#: ../lib/editUser.php:380
+msgid "Password"
+msgstr "Passwort"
+#: ../lib/editUser.php:393
+msgid "Confirm password"
+msgstr "Passwort bestätigen"
+#: ../lib/editUser.php:416 ../http/plugins/mb_metadata_edit.php:177
+#: ../http/plugins/mb_metadata_wfs_edit.php:176
+msgid "Email"
+msgstr "EMail"
+#: ../lib/editUser.php:424
+msgid "Phone"
+msgstr "Telefon"
+#: ../lib/editUser.php:432
+msgid "Facsimile"
+msgstr "Fax"
+#: ../lib/editUser.php:446
+msgid "Street"
+msgstr "Straße"
+#: ../lib/editUser.php:454
+msgid "Housenumber"
+msgstr "Hausnummer"
+#: ../lib/editUser.php:462
+msgid "Delivery Point"
+msgstr ""
+#: ../lib/editUser.php:470
+msgid "Postal Code"
+#: ../lib/editUser.php:486
+msgid "Organization"
+msgstr "Organisation"
+#: ../lib/editUser.php:494
+msgid "Department"
+msgstr "Behörde"
+#: ../lib/editUser.php:502
+msgid "Position"
+msgstr "Position"
+#: ../lib/editUser.php:543
+msgid "Login_count"
+msgstr "Anzahl der fehlerhaften Einwahlversuche"
+#: ../http/php/mod_showMetadata.php:790
+msgid "Monitoring abonnieren"
+msgstr ""
+#: ../http/javascripts/mod_coordsLookup.php:106
+msgid "Geographic Coordinates"
+msgstr "Geographische Koordinaten"
+msgid "Gauss-Krueger 2"
+msgstr "Gauß-Krüger 2 (DHDN)"
+msgid "Gauss-Krueger 3"
+msgstr "Gauß-Krüger 3 (DHDN)"
+msgid "Gauss-Krueger 4"
+msgstr "Gauß-Krüger 4 (DHDN)"
+msgid "Gauss-Krueger 5"
+msgstr "Gauß-Krüger 5 (DHDN)"
+msgid "UTM 32 North"
+msgstr "UTM 32 Nord (ETRS98)"
+#: ../http/javascripts/mod_wfsGazetteerEditor_client.php:250
+msgid "Informations"
+msgstr "Informationen"
+#: ../http/javascripts/mod_wfsGazetteerEditor_client.php:280
+msgid "Moduletype: Search"
+msgstr "Modulart: Suche"
+#: ../http/javascripts/mod_wfsGazetteerEditor_client.php:284
+msgid "Moduletype: Download"
+msgstr "Modulart: Download"
+#: ../http/javascripts/mod_wfsGazetteerEditor_client.php:301
+msgid "Geometrytype: point"
+msgstr "Geometrietyp: Punkt"
+#: ../http/javascripts/mod_wfsGazetteerEditor_client.php:306
+msgid "Geometrytype: line"
+msgstr "Geometrietyp: Linie"
+#: ../http/javascripts/mod_wfsGazetteerEditor_client.php:311
+msgid "Geometrytype: area"
+msgstr "Geometrietyp: Fläche"
+#: ../http/javascripts/mod_wfsGazetteerEditor_client.php:609
+msgid ""
+"The coordinate reference system (crs) of the objects differ from the crs of "
+"the viewer. A query will not be possible. Please change the crs of the "
+"viewer first."
+msgstr ""
+"Das Koordinatenreferenzsystem (CRS) der Objekte unterscheidet sich vom CRS "
+"des Viewers. Eine Suche ist nicht möglich. Bitte wechseln sie das "
+"Koordinatenreferenzsystem des Viewers."
+#: ../http/javascripts/mod_wfsGazetteerEditor_client.php:961
+msgid "An error occured when start download."
+msgstr "Es ist ein Fehler beim Download aufgetreten."
+#: ../http/javascripts/mod_wfsGazetteerEditor_client.php:1124
+msgid "No information available."
+msgstr "Keine Information verfügbar."
+#: ../http/javascripts/mod_wfsGazetteerEditor_client.php:1206
+msgid "Show information"
+msgstr "Zeige Informationen"
+#: ../http/javascripts/mod_wfsGazetteerEditor_client.php:1210
+msgid "Set spatial filter"
+msgstr "Definiere räumliche Auswahl"
+#: ../http/javascripts/mod_wfsGazetteerEditor_client.php:1214
+msgid "Set attribute filter"
+msgstr "Definiere attributive Auswahl"
+#: ../http/javascripts/mod_wfsGazetteerEditor_client.php:1256
+msgid "Export data"
+msgstr "Exportiere Daten"
+#: ../http/javascripts/mod_wfsGazetteerEditor_client.php:1252
+msgid "Reset filter"
+msgstr "Filter zurücksetzen"
+#: ../http/javascripts/mod_wfsGazetteerEditor_client.php:1249
+msgid "Start query"
+msgstr "Anfrage starten"
+#: ../http/javascripts/mod_wfsGazetteerEditor_client.php:1217
+msgid "Examples (first 20 entries):"
+msgstr "Beispielinhalte (erste 20 Datensätze):"
+#: ../http/javascripts/initWmcObj.php ../http/javascripts/initWmcObj.php:29
+msgid "You as User"
+msgstr "Sie als Nutzer"
+#: ../http/javascripts/initWmcObj.php:31
+msgid "have no authorization to access following layers."
+msgstr "haben keine Berechtigung auf folgende Layer zuzugreifen."
+#: ../http/javascripts/initWmcObj.php:35
+msgid ""
+"Following layers come from an unkown origin. There is no information about "
+"the links. They may be broken and the underlaying services may not exist "
+"anymore!"
+msgstr ""
+"Folgende Layer stammen aus einer der Registry unbekannten Quelle. Es kann "
+"daher nicht überprüft werden, ob die Links verwaist sind oder ob die Dienste "
+"überhaupt Daten liefern."
+#: ../http/javascripts/initWmcObj.php:39
+msgid ""
+"The last monitoring had problems with the following layers. Maybe the "
+"underlying services will not be able to answer the requests for sometime."
+msgstr ""
+"Bei folgenden Diensten kam es während des letzten Monitorings zu Problemen. "
+"Es ist möglich, dass diese Dienste derzeit keine Informationen zur Verfügung "
+"stellen können."
+#: ../http/javascripts/initWmcObj.php:43
+msgid ""
+"Following layers have been removed from the registry. They may be broken and "
+"the underlaying services may not exist anymore!"
+msgstr ""
+"Folgende Dienste/Layer sind aus der Registrierungsstelle gelöscht worden. Es "
+"kann daher nicht überprüft werden, ob die Links verwaist sind oder ob die "
+"Dienste überhaupt Daten liefern."
+#: ../http/javascripts/initWmcObj.php:409
+msgid "MapService"
+msgstr "Kartendienst"
+#: ../http/javascripts/initWmcObj.php:442
+msgid ""
+"The configuration, which should be loaded, consists of different services "
+"which have the following terms of use:"
+msgstr ""
+"Die zu ladende Konfiguration enthält verschiedene Dienste mit folgenden "
+"Nutzungsbedigungen:"
+msgid "Should this services be loaded regardless?"
+msgstr "Sollen die Dienste trotzdem hinzugeladen werden?"
+msgid "Confirmation"
+msgstr "Hinweis"
+#: ../http/php/mod_subscribersServiceList.php:144
+msgid "WebMapService"
+#: ../http/php/mod_subscribersServiceList.php:145
+msgid "Availability of Capabilities"
+msgstr "Verfügbarkeit Dienstebeschreibung"
+#: ../http/php/mod_subscribersServiceList.php:146
+msgid "Average Response Time for GetCapabilities"
+msgstr "Durchschnittliche Antwortzeit Beschreibung"
+#: ../http/php/mod_subscribersServiceList.php:147
+msgid "Availability of GetMap"
+msgstr "Verfügbarkeit Kartenbild"
+#: ../http/php/mod_subscribersServiceList.php:148
+msgid "Availability (2 month)"
+msgstr "Verfügbarkeit (2 Monate)"
+#: ../http/php/mod_subscribersServiceList.php:168
+msgid "Request GetCapabilities"
+msgstr "Aufruf des Capabilities Dokument"
+#: ../http/php/mod_subscribersServiceList.php:186
+msgid "Tested GetMap Request"
+msgstr "Getesteter GetMap Aufruf"
+msgid "Service ID"
+msgstr "Dienst ID"
+msgid "cycles"
+msgstr "Zyklen"
+#: ../http/php/mod_monitorCapabilities_read_single.php
+#: ../http/php/mod_monitorCapabilities_read_single.php:77
+msgid "Monitoring results"
+msgstr "Monitoring Ergebnisse"
+#: ../http/php/mod_monitorCapabilities_read_single.php:80
+msgid "Status"
+msgstr "Status"
+msgid "Response time"
+msgstr "Antwortzeit"
+#: ../http/javascripts/mod_addWMSgeneralFunctions.js
+msgid ""
+"The selected service is already activated in your application and will not "
+"be included again:"
+msgstr ""
+"Der folgende Dienst befindet sich bereits unter 'Aktive Dienste', und wird "
+"nicht erneut hinzugefügt:"
+#: ../ ../http/plugins/mb_metadata_wmcPreview.php:49
+msgid "Preview saved"
+msgstr "Vorschau gespeichert"
+msgid "Preview saved - but following service urls are not included !"
+msgstr "Vorschau gespeichert - aber folgende Dienste fehlen! "
+#: ../http/plugins/mb_metadata_wmcPreview.php:43
+msgid "Preview could not be created"
+msgstr "Vorschau konnte nicht gespeichert werden"
+msgid "Loading application: "
+msgstr "Lade Anwendung: "
+msgid "please wait ... "
+msgstr "Bitte warten ... "
+#: ../tools/mod_mailAbo.php
+msgid ""
+"Mapbender was unable to access the services listed above. These service may "
+"be unreachable on short notice. Please contact the service provider listed "
+"in the service metadata. You will find the metadata by following the link "
+"mentioned above. Note: This e-mail has been sent automatically because you "
+"subscribed to this service. You can unsubscribe by logging in and clicking "
+"the unsubscribe button in the Mapbender metadata dialogue."
+msgstr ""
+"Das GeoPortal hat Probleme beim Zugriff auf die oben in dieser E-Mail "
+"genannten Dienste. Es ist möglich, dass diese kurzfristig nicht verfügbar "
+"sind. Weitere Informationen erhalten Sie auf Anfrage beim "
+"Dienstebereitsteller, der in den Metadaten des Dienstes angegeben ist. "
+"Folgen Sie dazu dem oben in dieser E-Mail aufgeführten Link. Hinweis: Diese "
+"E-Mail wurde automatisiert erzeugt und der Versand von Ihnen beantragt. "
+"Diese E-Mail-Benachrichtigung können Sie jederzeit abbestellen, indem Sie "
+"das Abonnement über die Metadatenanzeige im GeoPortal deaktivieren."
+msgid "Choose kind of coupled metadata"
+msgstr "Art der Metadatenkopplung"
+msgid "Add URL to existing Metadataset"
+msgstr "Link zu einem existierenden Metadatensatz"
+msgid ""
+"Here someone can add a url to an existing metadata record, which is "
+"available over www. The record can either be harvested and pushed to the own "
+"catalogue service or it is only used as a link. This links are pushed into "
+"the service metadata record and the new capabilities document."
+msgstr ""
+"An dieser Stelle kann ein Link zu einem existierenden Metadatensatz "
+"angereichert werden. Der Datensatz kann entweder geharvested und über den "
+"eigenen Katalog veröffentlicht werden oder einfach als Link hinzugefügt "
+"werden. Die Links werden sowohl in die Service Metadaten, als auch in die "
+"INSPIRE Capabilities eingetragen."
+msgid ""
+"Add a simple metadata record which is mostly generated from given layer "
+"information"
+msgstr "Erzeugung eines einfachen Metadatensatz aus Layer Informationen"
+msgid ""
+"With this option someone can generate a very simple metadata record for the "
+"data which is distributed thru the wms layer. The record fulfills only the "
+"INSPIRE Metadata Regulation! Most of the needed data is pulled from the "
+"service, layer and group information of the owner of the service. The "
+"metadate will be created on the fly. It is not stored in the database!"
+msgstr ""
+"Mit dieser Option kann ein sehr einfacher Metadatensatz für die über den WMS "
+"zur Verfügung gestellten Daten generiert werden. Der Datensatz erfüllt dabei "
+"nur die Mindestanforderungen der EU-INSPIRE Richtlinie! Der Großteil der "
+"Daten wird dabei den Service- und Layer-Metadaten, sowie der "
+"Benutzerverwaltung der Registry übernommen. (Informationen über Eigentümer "
+"des Dienstes) Der Datensatz wird weiterhin nicht abgespeichert, sondern "
+"dynamisch -on the fly- erzeugt."
+msgid "Add a simple metadata record from a local file"
+msgstr "Hochladen eines lokalen Metadatensatzes"
+msgid ""
+"With this option someone can upload an existing metadata record and couple "
+"it to the layer. The uploaded data is pushed to the catalogue and will be "
+"available for searching. The uploaded data is not fully controlled and "
+"validated. It cannot be edited but must be replaced with a new record if "
+"needed!"
+msgstr ""
+"Über diese Option kann ein lokal vorliegender existierender Metadatensatz in "
+"die Registry übernommen werden. Der Datensatz wird in der Mapbender "
+"Datenbank abgelegt und über die Katalogschnittstelle nach Außen abgegeben. "
+"Er wird nicht vollständig validiert. Bitte nutzen sie hierzu den INSPIRE "
+"Validator Service. Der Datensatz kann nicht editiert werden, sondern muss "
+"bei Bedarf gelöscht bzw. ausgetauscht werden."
+#: ../http/plugins/mb_metadata_addon.php:17
+msgid "Link Editor"
+msgstr "Link Editor"
+#: ../http/plugins/mb_metadata_addon.php:20
+msgid "Harvest link target and export to CSW"
+msgstr "Link Ziel verfolgen und über CSW veröffentlichen."
+#: ../http/plugins/mb_metadata_addon.php:27
+msgid "Metadata upload"
+msgstr "Metadaten hochladen"
+#: ../http/plugins/mb_metadata_addon.php:32
+msgid "Simple metadata editor"
+msgstr "Einfacher Metadateneditor"
+msgid "Resource title"
+msgstr "Ressourcenbezeichnung"
+msgid ""
+"This a characteristic, and often unique, name by which the resource is known."
+msgstr ""
+"Charakteristische und häufig eindeutige Bezeichnung, unter der die Ressource "
+"bekannt ist. Der Wertebereich dieses Metadatenelements ist Freitext."
+msgid "Resource abstract"
+msgstr "Ressourcenüberblick"
+msgid "This is a brief narrative summary of the content of the resource."
+msgstr ""
+"Kurze beschreibende Zusammenfassung des Ressourceninhalts. Der Wertebereich "
+"dieses Metadatenelements ist Freitext."
+msgid "Lineage"
+msgstr "Herkunft"
+msgid ""
+"This is a statement on process history and/or overall quality of the spatial "
+"data set. Where appropriate it may include a statement whether the data set "
+"has been validated or quality assured, whether it is the official version "
+"(if multiple versions exist), and whether it has legal validity. The value "
+"domain of this metadata element is free text."
+msgstr ""
+"Angaben zum Ablauf der Datenerstellung und/oder zur Gesamtqualität des "
+"Geodatensatzes. Gegebenenfalls kann hierzu auch eine Angabe gehören, ob der "
+"Datensatz validiert oder einer Qualitätssicherung unterzogen worden ist, ob "
+"es sich (im Fall mehrerer Versionen) um die amtliche Version handelt und ob "
+"er Rechtsgültigkeit besitzt. Der Wertebereich dieses Metadatenelements ist "
+"Freitext."
+msgid "TEMPORAL REFERENCE"
+msgstr "ZEITBEZUG"
+msgid ""
+"This metadata element addresses the requirement to have information on the "
+"temporal dimension of the data as referred to in Article 8(2)(d) of "
+"Directive 2007/2/EC. At least one of the metadata elements referred to in "
+"points 5.1 to 5.4 shall be provided. The value domain of the metadata "
+"elements referred to in points 5.1 to 5.4 is a set of dates. Each date shall "
+"refer to a temporal reference system and shall be expressed in a form "
+"compatible with that system. The default reference system shall be the "
+"Gregorian calendar, with dates expressed in accordance with ISO 8601."
+msgstr ""
+"Mit diesem Metadatenelement werden die nach Artikel 8 Absatz 2 Buchstabe d "
+"der Richtlinie 2007/2/EG erforderlichen Informationen zur zeitlichen "
+"Datendimension bereitgestellt. Mindestens eines der in den Unterabsätzen 5.1 "
+"bis 5.4 aufgeführten Metadatenelemente ist anzugeben. Der Wertebereich der "
+"in den Unterabsätzen 5.1 bis 5.4 aufgeführten Metadatenelemente ist eine "
+"Menge von Datumsangaben. Jedes Datum ist einem zeitlichen Bezugssystem "
+"zugeordnet und in einer zu diesem System kompatiblen Form auszudrücken. Die "
+"Voreinstellung für dieses Bezugssystem ist der Gregorianische Kalender mit "
+"Datumsangaben, die ISO 8601 entsprechen."
+msgid "Temporal extent"
+msgstr "Zeitliche Ausdehnung"
+msgid ""
+"The temporal extent defines the time period covered by the content of the "
+"resource. This time period may be expressed as any of the following: - an "
+"individual date, - an interval of dates expressed through the starting date "
+"and end date of the interval, - a mix of individual dates and intervals of "
+"dates."
+msgstr ""
+"Die zeitliche Ausdehnung beschreibt den Zeitraum, der vom Inhalt der "
+"Ressource erfasst wird. Dieser Zeitraum kann in einer der folgenden Weisen "
+"ausgedrückt werden: - als Einzeldatum, - als Datumsintervall unter Angabe "
+"von Anfangs- und Enddatum des Intervalls oder - als Kombination von "
+"Einzeldaten und Datumsintervallen."
+msgid "Spatial resolution"
+msgstr "Räumliche Auflösung"
+msgid ""
+"Spatial resolution refers to the level of detail of the data set. It shall "
+"be expressed as a set of zero to many resolution distances (typically for "
+"gridded data and imagery-derived products) or equivalent scales (typically "
+"for maps or map-derived products). An equivalent scale is generally "
+"expressed as an integer value expressing the scale denominator. A resolution "
+"distance shall be expressed as a numerical value associated with a unit of "
+"length."
+msgstr ""
+"Die räumliche Auflösung bezieht sich auf den Detaillierungsgrad des "
+"Datensatzes und ist als Menge von null bis vielen Auflösungsabständen (in "
+"der Regel für Gitterdaten und aus Bildern abgeleitete Produkte) oder als "
+"äquivalente Maßstäbe (in der Regel für Karten und daraus abgeleitete "
+"Produkte) anzugeben."
+#: ../http/plugins/mb_metadata_addon.php:78
+msgid "Ground distance in [m]"
+msgstr "Bodenauflösung in [m]"
+#: ../http/plugins/mb_metadata_addon.php:82
+msgid "Scale denominator [1:X]"
+msgstr "Nenner eines äquivalenten Maßstabs [1:X]"
+msgid "Value of resolution"
+msgstr "Wert der räumlichen Auflösung"
+msgid "Value of spatial resolution in [m] or scale denominator"
+msgstr "Wert der räumlichen Auflösung in [m] oder Nenner des Maßstabes"
+msgid "Coordinate Reference System"
+msgstr "Koordinatenreferenzsystem"
+msgid "Description of the coordinate reference system(s) used in the data set."
+msgstr ""
+"Beschreibung des Koordinatenreferenzsystems bzw. der "
+"Koordinatenreferenzsysteme, die im Datensatz verwendet werden."
+msgid "Encoding"
+msgstr "Datenablageformat"
+msgid ""
+"Description of the computer language construct(s) specifying the "
+"representation of data objects in a record, file, message, storage device or "
+"transmission channel."
+msgstr ""
+"Beschreibung des Programmiersprachenkonstrukts, das die Darstellung eines "
+"Datenobjekts in einem Datensatz, in einer Datei, einer Nachricht, einem "
+"Speichermedium oder einem Übertragungskanal bestimmt."
+msgid "Character Encoding"
+msgstr "Zeichenkodierung"
+msgid ""
+"The character encoding used in the data set. This element is mandatory only "
+"if an encoding is used that is not based on UTF-8."
+msgstr ""
+"die im Datensatz verwendete Zeichenkodierung. Dieses Element ist nur dann "
+"erforderlich, wenn eine nicht auf UTF-8 basierende Kodierung verwendet wird."
+msgid "Topological Consistency"
+msgstr "Topologische Konsistenz"
+msgid ""
+"Correctness of the explicitly encoded topological characteristics of the "
+"data set as described by the scope. This element is mandatory only if the "
+"data set includes types from the Generic Network Model and does not assure "
+"centreline topology (connectivity of centrelines) for the network."
+msgstr ""
+"Stichhaltigkeit/Genauigkeit der explizit kodierten topologischen Merkmale "
+"des im Geltungsbereich beschriebenen Datensatzes. Dieses Element ist nur "
+"dann erforderlich, wenn der Datensatz Typen des Generischen Netzwerkmodells "
+"(Generic Network Model) enthält und keine Mittellinientopologie "
+"(Konnektivität von Mittellinien) für das Netzwerk gewährleistet."
+#: ../http/plugins/mb_metadata_addon.php:49
+msgid "from"
+msgstr "von"
+#: ../http/plugins/mb_metadata_addon.php:51
+msgid "to"
+msgstr "bis"
+msgid "Maintenance and update frequency"
+msgstr "Pflege-/ Aktualisierungszyklus"
+msgid ""
+"Frequency with which changes and additions are made to the resource after "
+"the initial resource is completed. Notice: This value may change the value "
+"of the end date of temporal extent. The end date will be computed "
+"automatically from the current timestamp if a cyclic update is defined!"
+msgstr ""
+"Intervall in dem Änderungen und Anpassungen an der Ressource erfolgen nach "
+"dem diese erstmalig erstellt wurde. Hinweis: Eine Auswahl eines regelmäßigen "
+"Aktualisierungsintervalls ändert den Endzeitpunkt der zeitlichen Ausdehnung. "
+"Der Endzeitpunkt wird dann immer anhand des aktuellen Datums berechnet. Da "
+"die Metadaten dynamisch erzeugt werden, muss man sie nicht mehr händisch "
+"anpassen."
+#: ../http/plugins/mb_metadata_addon.php:57
+msgid "continual"
+msgstr "kontinuierlich"
+#: ../http/plugins/mb_metadata_addon.php:58
+msgid "daily"
+msgstr "täglich"
+#: ../http/plugins/mb_metadata_addon.php:59
+msgid "weekly"
+msgstr "wöchentlich"
+#: ../http/plugins/mb_metadata_addon.php:60
+msgid "fortnightly"
+msgstr "zweiwöchentlich"
+#: ../http/plugins/mb_metadata_addon.php:61
+msgid "monthly"
+msgstr "monatlich"
+#: ../http/plugins/mb_metadata_addon.php:62
+msgid "quarterly"
+msgstr "vierteljährlich"
+#: ../http/plugins/mb_metadata_addon.php:63
+msgid "biannually"
+msgstr "halbjährlich"
+#: ../http/plugins/mb_metadata_addon.php:64
+msgid "annually"
+msgstr "jährlich"
+#: ../http/plugins/mb_metadata_addon.php:65
+msgid "as needed"
+msgstr "nach Bedarf"
+#: ../http/plugins/mb_metadata_addon.php:66
+msgid "irregular"
+msgstr "unregelmäßig"
+#: ../http/plugins/mb_metadata_addon.php:68
+msgid "not planned"
+msgstr "nicht geplant"
+#: ../http/plugins/mb_metadata_addon.php:70
+msgid "unknown"
+msgstr "unbekannt"
+#: ../http/geoportal/mod_allow_publishing_metadata.php
+msgid "Registrating institutions"
+msgstr "Registrierende Stellen"
+msgid "My (metadata-)provider"
+msgstr "Meine (Metadaten-)Provider"
+msgid "There are too many primary groups defined for the user with ID: "
+msgstr ""
+"Fehler: Es wurden zu viele primäre Gruppen für den Nutzer mit folgender ID "
+"definiert: "
+msgid ""
+"You have not yet an primary group. Please contact the central system admin "
+"to define a primary group for user with ID: "
+msgstr ""
+"Sie sind noch keiner primären Gruppe zugewiesen. Bitte kontaktieren sie den "
+"Zentraladministrator um Nutzer mit folgender ID eine primäre Gruppe "
+"zuzuweisen: "
+msgid "You have no rights to use this module!"
+msgstr "Sie haben keine Berechtigung dieses Modul zu nutzen!"
+#: ../http/geoportal/mod_readOpenSearchResultsDetail.php
+msgid "Contact"
+msgstr "Kontakt"
+msgid "Metadata identifier"
+msgstr "Metadatenidentifikator"
+msgid "Resource type"
+msgstr "Art der Ressource"
+msgid "Resource locator"
+msgstr "Adresse zur Ressource"
+msgid "Unique resource identifier id"
+msgstr "ID des eindeutigen Identifikators"
+msgid "Unique resource identifier namespace"
+msgstr "Namensraum des eindeutigen Identifikators"
+msgid "Language"
+msgstr "Sprache"
+msgid "Coupled resource"
+msgstr "Verknüpfte Ressource"
+msgid "Topic category"
+msgstr "ISO Themengebiet"
+msgid "Spatial data service type"
+msgstr "Art des Geodatendienstes"
+msgid "Keyword value"
+msgstr "Suchbegriff"
+msgid "Geographic bounding box"
+msgstr "Geographische Ausdehnung"
+msgid "Date of publication"
+msgstr "Datum der Veröffentlichung"
+msgid "Date of creation"
+msgstr "Datum der Erstellung"
+msgid "Date of last revision"
+msgstr "Datum der letzten Überarbeitung"
+msgid "Equivalent scale"
+msgstr "Vergleichsmaßstab"
+msgid "Ground Distance Value"
+msgstr "Bodenauflösung"
+msgid "Specification title"
+msgstr "Titel der Spezifikation"
+msgid "Specification reference date"
+msgstr "Datum der Spezifikation"
+msgid "Degree of conformance"
+msgstr "Grad der Konformität"
+msgid "Conditions applying to access and use"
+msgstr "Nutzungsbedingungen"
+msgid "Access constraints code"
+msgstr "Code für Zugangsbeschränkungen"
+msgid "Other constraints"
+msgstr "Andere Zugangsbeschränkungen"
+msgid "Responsible party name"
+msgstr "Name der veantwortlichen Stelle"
+msgid "Responsible party email"
+msgstr "E-Mail Adresse der verantwortlichen Stelle"
+msgid "Responsible party role"
+msgstr "Rolle der verantwortlichen Stelle"
+msgid "Overview"
+msgstr "Übersicht"
+msgid "Properties"
+msgstr "Eigenschaften"
+msgid "Terms of use"
+msgid "Common"
+msgstr "Allgemein"
+msgid "Geographic extent"
+msgid "Service information"
+msgstr "Informationen zum Dienst"
+msgid "Data/Service provider"
+msgstr "Daten-/Dienstanbieter"
+msgid "Metadata provider"
+msgstr "Anbieter der Metadaten"
+msgid "Conditions"
+msgstr "Bedingungen"
+msgid "Access constraints"
+msgstr "Zugangsbeschränkungen"
+msgid "Validity"
+msgstr "Gültigkeit"
+msgid "Resolution"
+msgstr "Auflösung"
+msgid "Metadata point of contact email"
+msgstr "Metadatenkontakt E-Mail"
+msgid "Metadata point of contact name"
+msgstr "Name der Kontaktstelle für Metadaten"
+msgid "Metadata date"
+msgstr "Datum der Metadaten"
+msgid "Metadata language"
+msgstr "Sprache der Metadaten"
+msgid "Coordinate reference system"
+msgid "Character encoding"
+msgstr "Zeichensatz"
+msgid "Interfaces"
+msgstr "Schnittstellen"
+msgid "Konfigure tree"
+msgstr ""
+#: ../http/php/mod_wmc2ol.php:624 ../http/php/mod_wmc2ol.php:693
+msgid ""
+"Some georss entries does not have numeric values for CRS or coordinates! For "
+"security reasons the script will die!"
+msgstr ""
+#: ../http/plugins/mb_metadata_addon.php:84
+msgid "Please set the resolution type!"
+msgstr ""
+#: ../http/plugins/mb_metadata_addon.php:97
+msgid "EPSG:"
+msgstr ""
+#: ../http/plugins/mb_metadata_addon.php:109
+msgid "Database"
+msgstr ""
+#: ../http/plugins/mb_metadata_addon.php:110
+msgid "Esri Shape"
+msgstr ""
+#: ../http/plugins/mb_metadata_addon.php:111
+msgid "MapInfo Tab file"
+msgstr ""
+#: ../http/plugins/mb_metadata_addon.php:112
+msgid "CSV"
+msgstr ""
+#: ../http/plugins/mb_metadata_addon.php:113
+msgid "GML"
+msgstr ""
+#: ../http/plugins/mb_metadata_addon.php:119
+msgid "utf8"
+msgstr ""
+#: ../http/plugins/mb_metadata_addon.php:120
+msgid "latin1"
+msgstr ""
+#: ../http/plugins/mb_metadata_edit.php:18
+#: ../http/plugins/mb_metadata_wfs_edit.php:18
+msgid "INSPIRE 1.1: resource title"
+msgstr ""
+#: ../http/plugins/mb_metadata_edit.php:23
+#: ../http/plugins/mb_metadata_wfs_edit.php:23
+msgid "INSPIRE 1.2: resource abstract"
+msgstr ""
+#: ../http/plugins/mb_metadata_edit.php:24
+msgid "Help for INSPIRE Abstract"
+msgstr ""
+msgid ""
+"INSPIRE demands some information about the spatial resolution in the "
+"abstract tag of the capabilities document. Please insert some words about it."
+msgstr ""
+#: ../http/plugins/mb_metadata_edit.php:29
+#: ../http/plugins/mb_metadata_wfs_edit.php:28
+msgid "INSPIRE 3: keyword"
+msgstr ""
+#: ../http/plugins/mb_metadata_edit.php:34
+#: ../http/plugins/mb_metadata_wfs_edit.php:33
+msgid "INSPIRE 8.1: conditions applying to access and use"
+msgstr ""
+#: ../http/plugins/mb_metadata_edit.php:39
+#: ../http/plugins/mb_metadata_wfs_edit.php:38
+msgid "INSPIRE 8.2: limitations on public access"
+msgstr ""
+#: ../http/plugins/mb_metadata_edit.php:62
+msgid "Restricted Network Access (Registry)"
+msgstr ""
+#: ../http/plugins/mb_metadata_edit.php:87
+#: ../http/plugins/mb_metadata_wfs_edit.php:86
+msgid "INSPIRE 9.1: responsible party name"
+msgstr ""
+#: ../http/plugins/mb_metadata_edit.php:112
+msgid "INSPIRE 9.1: responsible party email"
+msgstr ""
+#: ../http/plugins/mb_metadata_edit.php:117
+msgid "INSPIRE 5.2: date of publication"
+msgstr ""
+#: ../http/plugins/mb_metadata_edit.php:122
+#: ../http/plugins/mb_metadata_wfs_edit.php:121
+msgid "INSPIRE 10.2: metadata date"
+msgstr ""
+msgid "Metadata Point of contact (registry)"
+msgstr ""
+msgid ""
+"Information about the organization which is responsible for contributing the "
+"metadata. The information will be automaticcaly generated from the mapbender "
+"database mb_group object. The information came from the primary group of the "
+"service owner or from a group which has authorized the owner to publish "
+"metadata in their name."
+msgstr ""
+#: ../http/plugins/mb_metadata_edit.php:142
+#: ../http/plugins/mb_metadata_wfs_edit.php:141
+msgid "Organization responsible for metadata"
+msgstr ""
+#: ../http/plugins/mb_metadata_edit.php:151
+#: ../http/plugins/mb_metadata_wfs_edit.php:150
+msgid ""
+"Selection of different organizations which authorized you to publish "
+msgstr ""
+#: ../http/plugins/mb_metadata_edit.php:158
+#: ../http/plugins/mb_metadata_wfs_edit.php:157
+msgid "INSPIRE 10.1: metadata point of contact name"
+msgstr ""
+#: ../http/plugins/mb_metadata_edit.php:173
+#: ../http/plugins/mb_metadata_wfs_edit.php:172
+msgid "Telephone"
+msgstr ""
+#: ../http/plugins/mb_metadata_edit.php:179
+#: ../http/plugins/mb_metadata_wfs_edit.php:178
+msgid "INSPIRE 10.1: metadata point of contact email"
+msgstr ""
+#: ../http/plugins/mb_metadata_edit.php:182
+#: ../http/plugins/mb_metadata_wfs_edit.php:181
+msgid "Logo url"
+msgstr ""
+#: ../http/plugins/mb_metadata_layer.php:63
+msgid ""
+"Linking the WMS layer with a metadata set (coupled resource), which "
+"describes the underlying information of the representation in more detail "
+"(eg actuality / quality). It can be done by linking to an already existing "
+"metadata set (e.g. in a catalogue) or by generating a simple metadata file "
+"using mapbender."
+msgstr ""
+#: ../http/plugins/mb_metadata_layer.php:66
+msgid "Table of coupled Metadata"
+msgstr ""
+#: ../http/plugins/mb_metadata_server.php:56
+msgid "WMS ID"
+msgstr ""
+#: ../http/plugins/mb_metadata_server.php:57
+msgid "title"
+msgstr ""
+#: ../http/plugins/mb_metadata_server.php:58
+msgid "last change"
+msgstr ""
+#: ../http/plugins/mb_metadata_server.php:59
+msgid "creation"
+msgstr ""
+#: ../http/plugins/mb_metadata_server.php:60
+msgid "version"
+msgstr ""
+#: ../http/plugins/mb_metadata_server.php:61
+msgid "status"
+msgstr ""
+#: ../http/plugins/mb_metadata_server.php:62
+msgid "wms id"
+msgstr ""
+#: ../http/plugins/mb_metadata_server.php:461
+msgid "Could not read layer ID "
+msgstr ""
+#: ../http/plugins/mb_metadata_server.php:472
+msgid "Could not get layer with ID "
+msgstr ""
+#: ../http/plugins/mb_metadata_server.php:640
+msgid "Could not update metadata object in database!"
+msgstr ""
+#: ../http/plugins/mb_metadata_server.php:751
+msgid "Could not load metadata from source url!"
+msgstr ""
+#: ../http/plugins/mb_metadata_server.php:767
+msgid "Temporary file could not be parsed!"
+msgstr ""
+#: ../http/plugins/mb_metadata_server.php:836
+#: ../http/plugins/mb_metadata_server.php:1028
+msgid "Insert of harvested metadata into database failed!"
+msgstr ""
+#: ../http/plugins/mb_metadata_server.php:840
+msgid ""
+"Problem with parsing the XML structure with SimpleXML! Record was not "
+"inserted into database! Ask your administrator."
+msgstr ""
+#: ../http/plugins/mb_metadata_server.php:856
+msgid "Insert of link into database failed!"
+msgstr ""
+#: ../http/plugins/mb_metadata_server.php:873
+#: ../http/plugins/mb_metadata_server.php:1044
+msgid "Cannot get metadata record with following uuid from database: "
+msgstr ""
+#: ../http/plugins/mb_metadata_server.php:890
+#: ../http/plugins/mb_metadata_server.php:1061
+msgid "Cannot write relation between ows and metadata to database!"
+msgstr ""
+#: ../http/plugins/mb_metadata_server.php:911
+msgid "Could not delete metadata from database!"
+msgstr ""
+#: ../http/plugins/mb_metadata_server.php:962
+msgid "Reading file "
+msgstr ""
+#: ../http/plugins/mb_metadata_server.php:969
+msgid "Parsing ISO19139 XML failed!"
+msgstr ""
+#: ../http/plugins/mb_metadata_wfs_edit.php:58
+msgid "Selection of predefined licences."
+msgstr ""
+#: ../http/plugins/mb_metadata_wmcPreview.php:53
+msgid ""
+"Preview saved - but following service urls are not included cause the "
+"firewall prevent this!"
+msgstr ""
+#: ../http/plugins/mb_metadata_wmcPreview.php:62
+msgid "invalid method"
+msgstr ""
+#: ../http/javascripts/mod_wfsLayerObj_conf.js:13
+msgid "none"
+msgstr ""
+#: ../http/javascripts/mod_wfsLayerObj_conf.js:30
+msgid "Set WFS for layer"
+msgstr ""
+#: ../http/javascripts/mod_wfsLayerObj_conf.js:36
+msgid "Cancel"
+msgstr ""
+msgid "Kind of resource"
+msgid "Map Service"
+msgid "Data Service"
+msgid "Map Layer"
+msgstr "Kartenebene"
+msgid "Featuretype"
+msgstr "Objektart"
+msgid "Type of geometry"
+msgstr "Geometrietyp"
+msgid "Resourceidentifier"
+msgstr "Ressourcenidentifikator"
+msgid "Name of the resource"
+msgstr "Name der Ressource"
+msgid "Information about the service"
+msgid "Extent"
+msgstr "Ausdehnung"
+msgid "Responsible party for content"
+msgstr "Inhaltlich verantwortliche Stelle"
+msgid "Responsible party for service"
+msgstr "Technisch verantwortliche Stelle"
+msgid "Contact person"
+msgstr "Ansprechpartner"
+msgid "Logo"
+msgstr "Logo"
+msgid "Availability"
+msgstr "Verfügbarkeit"
+msgid "Problem with last monitoring!"
+msgstr "Probleme beim letzten Monitoring!"
+msgid "Last Monitoring: OK"
+msgstr "Letztes Monitoring OK"
+msgid "Servicedescription changed!"
+msgstr "Dienstebeschreibung hat sich geändert!"
+msgid "Layer not queryable"
+msgstr "Ebene nicht abfragbar"
+msgid "Layer queryable"
+msgstr "Ebene abfragbar"
+msgid "Query"
+msgstr "Abfragbarkeit"
+msgid "Visibility"
+msgstr "Sichtbarkeit"
+msgid "Minimum scale"
+msgstr "Minimaler Maßstab"
+msgid "Maximum scale"
+msgstr "Maximaler Maßstab"
+msgid "Used Coordinate Reference System"
+msgstr "Eingestelltes Koordinatenreferenzsystem"
+msgid "Spatial Extent"
+msgstr "Räumliche Ausdehnung"
+msgid "Corner in geographic Coordinates"
+msgstr "Eckpunkte in geogr. Koordinaten"
+msgid "Geoportal Capabilities"
+msgstr "Geoportal Capabilities"
+msgid "Original Capabilities"
+msgstr "Original Capabilities"
+msgid "Dataschema"
+msgstr "Link zum Datenschema"
+msgid "KML"
+msgstr "KML"
+msgid "INSPIRE Service Metadata"
+msgstr "INSPIRE Service Metadaten"
+msgid "Metadatarecord"
+msgstr "Metadatendatei"
+msgid "Secured Capabilities URL"
+msgstr "Abgesicherte Capabilities URL"
+msgid "INSPIRE Capabilities URL"
+msgstr "INSPIRE Capabilities URL"
+msgid "Link to Capabilities document"
+msgstr "Link zum Capabilities Dokument"
+msgid "Validation against INSPIRE Geoportal"
+msgstr "Validierung gegen INSPIRE Geoportal"
+msgid "Start validation"
+msgstr "Validierung starten"
+msgid "stable"
+msgstr "Stabil"
+msgid "Description changed - update necessary"
+msgstr "Beschreibung hat sich geändert - Aktualisierung nötig"
+msgid "Problem at last control"
+msgstr "Problem bei letzter Kontrolle"
+msgid "Web Map Context document"
+msgstr "Web Map Context Dokument"
+msgid "Graphical Overview not active"
+msgstr "Graphische Übersicht nicht aktiviert"
+msgid "Information about Quality is only available if the service monitoring is activated!"
+msgstr "Informationen über die Qualität sind nur verfügbar, wenn das Service Monitoring aktiv ist!"
+msgid "In case of Web Map Context Documents the Quality part is not applicable!"
+msgstr "Für Web Map Context Dokumente entfällt die Angabe zur Qualität!"
+msgid "No informations about terms of use are available!"
+msgstr "Es sind keine Informationen über Nutzungsbedingungen verfügbar!"
+msgid "Link to start application with WMC"
+msgstr "Link um Anwendung mit WMC zu starten"
+msgid "validate"
+msgstr "Validierung"
+msgid "uploaded metadata"
+msgstr "Hochgeladene Metadaten"
+msgid "linked metadata"
+msgstr "Verlinkte Metadaten"
+msgid "metadata from capabilities"
+msgstr "Metadaten von Service Capabilities"
+msgid "added from registry"
+msgstr "Metadaten über Registry angereichert"
+msgid "Coupled Metadata"
+msgstr "Verknüpfte Metadaten"
+msgid "Show map in own viewer"
+msgstr "Karte im eigenen Viewer anzeigen"
+msgid "Show map"
+msgstr "Karte anzeigen"
+msgid "Search for addresses"
+msgstr "Suche nach Adressen"
+msgid "Last WMS cannot be removed"
+msgstr "Der letzte WMS kann nicht entfernt werden"
+msgid "FeatureInfoFormat"
+msgstr "Sachdatenformat"
+msgid "ExceptionFormat"
+msgstr "Fehlermeldungen"
+msgid "Transparency"
+msgstr "Transparenz"
+msgid "MapFormat"
+msgstr "Bildformat"
+msgid "Help for address search"
+msgstr "Hilfe zur Adresssuche"
+#: ../plugins/mod_downloadFeedClient.php
+msgid "INSPIRE ATOM Feed Client"
+msgstr "INSPIRE ATOM Feed Client"
+msgid "ATOM Service Feed url"
+msgstr "URL des ATOM Service Feeds"
+msgid "Dataset title"
+msgstr "Bezeichnung"
+msgid "Dataset abstract"
+msgstr "Beschreibung"
+msgid "Rights"
+msgstr "Rechtliche Angaben"
+msgid "Available representations"
+msgstr "Verfügbare Varianten"
+msgid "Select to download dataset"
+msgstr "Auswahl zum Download"
+#: ../php/mb_getWmsData.php
+msgid "Old layer name: "
+msgstr "Alter Layername: "
+msgid " - changed to: "
+msgstr " - geändert zu: "
+msgid "has been updated"
+msgstr "wurde aktualisiert"
+msgid "You may want to check the changes as you are an owner or subscriber of this WMS. If you have integrated the service into a gis client, you have to reconfigure the client!"
+msgstr "Als Abonnent oder Eigentümer einer Anwendung, in der der WMS eingebunden ist, sollten Sie die Änderungen kontrollieren. Wenn Sie den Dienst in einem GIS Client eingebunden haben, müssen Sie dessen Konfiguration aktualisieren!"
+msgid "Note: This e-mail has been sent automatically because you subscribed to this service. You can unsubscribe by logging in and clicking the unsubscribe button in the Mapbender metadata dialogue by following the given link."
+msgstr "Zu beachten: Diese Mail wurde automatisch versendet, weil Sie entweder den betroffenen Dienst abonniert haben oder der Dienst in einer Ihrer Mapbender Anwendungen integriert ist. Sie können diese Benachrichtigung deaktivieren, wenn Sie sich am Portal anmelden und dann das Abo über die Metadatenanzeige ausschalten."
+msgid "Attention - following layers have been renamed"
+msgstr "Achtung - folgende Layer wurden bei der Aktualisierung vom Anbieter umbenannt"
+msgid "Update of an observed WMS"
+msgstr "Aktualisierung eines beobachteten WMS"
+msgid "Other owners of this WMS have been informed about the changes!"
+msgstr "Andere Nutzer und die Abonnenten dieses WMS wurden per Mail über die Änderungen informiert!"
+msgid "When notifying the owners of this WMS about your changes, an error occured"
+msgstr "Bei der Benachrichtigung der Nutzer und Abonnenten über die Änderungen am WMS trat ein Fehler auf"
+msgid "Note on protection of privacy"
+msgstr "Datenschutzhinweis"
+msgid "Constraints on public access"
+msgstr "Beschränkungen des öffentlichen Zugangs"
+msgid "Information about costs/fees/licences"
+msgstr "Angaben zu Kosten/Gebühren/Lizenzen"
+msgid "Licence"
+msgstr "Lizenz"
+msgid "This Service is <b>not available via www</b> but only in special networks. Possibly you get further information about the network availability in the following paragraph.<br>"
+msgstr "Der Dienst ist <b>nicht im Internet</b> sondern nur in ausgewählten  Netzwerken (z.B. Intranets) verfügbar. Genauere Angaben erhalten Sie ggf. im folgenden Abschnitt.<br>"
+msgid "The access on this service is logged <b>user-related</b> by the provider. The logging is done to support automated settlement based on a contract "
+msgstr "Die Zugriffe auf den Dienst werden vom Anbieter <b>nutzerbezogen</b> aufgezeichnet. Dies erfolgt entweder zur Abrechnung vertraglicher Vereinbarungen "
+msgid "or to fulfill legal standards.<br><b>If you do not agree on this - please don't use this service!</b><br>"
+msgstr "oder aufgrund gesetzlicher Vorgaben.<br><b>Wenn Sie hiermit nicht einverstanden sein sollten, nutzen Sie diesen Dienst nicht!</b><br>"
+msgid "If you have further questions, please contact the provider under "
+msgstr "Falls Sie weitere Fragen haben, kontaktieren Sie bitte den Anbieter unter "
+msgid "The provider have defined a charge of <b>"
+msgstr "Der Anbieter dieses Dienstes hat ein allgemeines Nutzungsentgelt von <b>"
+msgid " (euro)cent per megapixel</b> "
+msgstr " Cent pro Megapixel</b> "
+msgid " for retrieved picture data. The retrieving of a typical map with a standardized resolution of 600x400 px will cost <b>"
+msgstr " für abgerufene Bildinformationen angegeben. Das Abrufen eines Kartenbildes in einer Standardauflösung von 600x400 Pixeln kostet dementsprechend <b>"
+msgid " euro</b>. For information about possible discounts please contact "
+msgstr " Euro</b>. Angaben zu eventuell möglichen Rabatten erhalten Sie über "
+msgid "The coordinate reference system (crs) of the objects differ from the crs of the viewer"
+msgstr "Das Koordinatensystem (CRS) der abgefragten Objekte unterscheidet sich vom Koordinatensystem des Viewers"
+msgid "A query will not be possible."
+msgstr "Eine Abfrage ist nicht möglich."
+msgid "Please switch viewer crs to"
+msgstr "Bitte wechseln sie das Koordinatensystem auf"
+msgid "CRS Error"
+msgstr "Fehler bei den Koordinatensystemen"
+msgid "Please choose a requestable Layer"
+msgstr "Wählen Sie bitte die abfragbare Ebene aus"
+msgid "Please enable some layer to be requestable"
+msgstr "Aktivieren Sie bitte die Abfragbarkeit einer Ebene"
+msgid "No legend available"
+msgstr "Keine Legende verfügbar"
+msgid "Download options for dataset(s)"
+msgstr "Downloadmöglichkeiten für Datensatz(-sätze)"
+msgid "Download raster data from INSPIRE Download Service"
+msgstr "Download von Rasterdaten über INSPIRE Downloaddienst"
+msgid "Download linked data from INSPIRE Download Service"
+msgstr "Download von verlinkten Daten über INSPIRE-EU Downloaddienst"
+msgid "Used dataset(s)"
+msgstr "Verwendeter Datensatz bzw. -sätze"
+msgid "Download GML data from INSPIRE Download Service"
+msgstr "Download von GML Daten über INSPIRE Downloaddienst"
+msgid "spatial dataset"
+msgstr "Geodatensatz"
+msgid "The document includes data resources from different organizations. The following parapgraph shows the different terms of use for the includes resources:"
+msgstr "Das vorliegende Dokument enthält Datenquellen von unterschiedlichen Stellen. Diese unterliegen den im folgenden aufgeführten Nutzungsbedingungen:"
+msgid "Web Map Service"
+msgid "Web Feature Service"
+msgstr "Datendienst"
More information about the Mapbender_commits
