[Mapbender-commits] r9112 - trunk/mapbender/resources/db/pgsql/UTF-8/update
svn_mapbender at osgeo.org
Tue Oct 28 04:16:38 PDT 2014
Author: armin11
Date: 2014-10-28 04:16:38 -0700 (Tue, 28 Oct 2014)
New Revision: 9112
trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql
Add new iso19139 field to database model
Modified: trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql
--- trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql 2014-10-28 08:17:09 UTC (rev 9111)
+++ trunk/mapbender/resources/db/pgsql/UTF-8/update/update_2.7.4_to_2.8_pgsql_UTF-8.sql 2014-10-28 11:16:38 UTC (rev 9112)
@@ -589,5 +589,10 @@
INSERT INTO translations (locale, msgid, msgstr) values ('de','Export current mapimage','Export des aktuellen Kartenbilds');
insert into translations (locale,msgid,msgstr) values ('en','Export des aktuellen Kartenbilds','Export current mapimage');
+-- Column: transfer_size
+-- ALTER TABLE mb_metadata DROP COLUMN transfer_size;
+ALTER TABLE mb_metadata ADD COLUMN transfer_size real;
More information about the Mapbender_commits
