[Mapbender-commits] r9115 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Oct 28 07:00:54 PDT 2014
Author: armin11
Date: 2014-10-28 07:00:54 -0700 (Tue, 28 Oct 2014)
New Revision: 9115
Removed:
   trunk/mapbender/http/javascripts/mb_downloadFeedClient.js
Exchanged with php version of file
Deleted: trunk/mapbender/http/javascripts/mb_downloadFeedClient.js
--- trunk/mapbender/http/javascripts/mb_downloadFeedClient.js	2014-10-28 14:00:02 UTC (rev 9114)
+++ trunk/mapbender/http/javascripts/mb_downloadFeedClient.js	2014-10-28 14:00:54 UTC (rev 9115)
@@ -1,347 +0,0 @@
-var mapframe_dataset_list, mapframe_file_list, datasetSelect, file_list, bboxDataset, bboxFiles, formats, sf;
-function updateFormats() {
-            var in_options = {
-                'internalProjection': mapframe_dataset_list.baseLayer.projection,
-                'externalProjection': new OpenLayers.Projection("EPSG:4326")
-            var out_options = {
-                'externalProjection': new OpenLayers.Projection("EPSG:900913")
-            var gmlOptions = {
-                featureType: "feature",
-                featureNS: "http://example.com/feature"
-            var gmlOptionsIn = OpenLayers.Util.extend(
-                OpenLayers.Util.extend({}, gmlOptions),
-                in_options
-            var gmlOptionsOut = OpenLayers.Util.extend(
-                out_options
-            var kmlOptionsIn = OpenLayers.Util.extend(
-                {extractStyles: true}, in_options);
-            formats = {
-              'in': {
-                wkt: new OpenLayers.Format.WKT(in_options),
-                geojson: new OpenLayers.Format.GeoJSON(in_options),
-                georss: new OpenLayers.Format.GeoRSS(in_options),
-                gml2: new OpenLayers.Format.GML.v2(gmlOptionsIn),
-                gml3: new OpenLayers.Format.GML.v3(gmlOptionsIn),
-                kml: new OpenLayers.Format.KML(kmlOptionsIn),
-                atom: new OpenLayers.Format.Atom(in_options),
-                gpx: new OpenLayers.Format.GPX(in_options)
-              'out': {
-                wkt: new OpenLayers.Format.WKT(out_options),
-                geojson: new OpenLayers.Format.GeoJSON(out_options),
-                georss: new OpenLayers.Format.GeoRSS(out_options),
-                gml2: new OpenLayers.Format.GML.v2(gmlOptionsOut),
-                gml3: new OpenLayers.Format.GML.v3(gmlOptionsOut),
-                kml: new OpenLayers.Format.KML(out_options),
-                atom: new OpenLayers.Format.Atom(out_options),
-                gpx: new OpenLayers.Format.GPX(out_options)
-function init(){
-	//generate 2 Mapframes
-	mapframe_dataset_list = new OpenLayers.Map('mapframe_dataset_list');
-	mapframe_file_list = new OpenLayers.Map('mapframe_file_list');
-	var wms1 = new OpenLayers.Layer.WMS( "Open Layers WMS",
-                "http://www.gdi-rp-dienste2.rlp.de/cgi-bin/mapserv?map=/data/umn/geoportal/karte_rp/rheinland-pfalz-gesamt2.map&", {layers: 'ATKIS-Praes',transparent: "true",format: "image/png"}, {singleTile: true, isBaseLayer: false});
-	var wms11 = new OpenLayers.Layer.WMS( "OpenLayers WMS",
-                "http://www2.demis.nl/wms/wms.ashx?wms=WorldMap&", {layers: 'Bathymetry,Countries,Topography,Hillshading,Coastlines,Waterbodies,Rivers,Streams,Railroads,Highways,Roads,Borders,Cities,Settlements,Airports'}, {singleTile: true});
-	//var wms_osm = new OpenLayers.Layer.WMS( "OpenLayers WMS",
-        //        "http://osm.omniscale.net/proxy/service?", {layers: 'osm'}, {singleTile: true});
-	var wms2 = new OpenLayers.Layer.WMS( "OpenLayers WMS",
-	var wms22 = new OpenLayers.Layer.WMS( "DEMIS World",
-	//Vector layer for the georss polygons of the service feed - maybe more than one
-	bboxDataset = new OpenLayers.Layer.Vector("Dataset bounding boxes");
-	//Vector layer for the georss polygons of one single data feed entry - maybe more than one if the dataset is tiled into different sections
-	bboxFiles = new OpenLayers.Layer.Vector("File bounding boxes");
-	mapframe_dataset_list.addLayers([wms11,wms1,bboxDataset]);
-	mapframe_dataset_list.addControl(new OpenLayers.Control.MousePosition());
-	mapframe_file_list.addLayers([wms22,wms2,bboxFiles]);
-	mapframe_file_list.addControl(new OpenLayers.Control.MousePosition());
-	updateFormats();
-	//initialize mapframes
-	mapframe_dataset_list.setCenter(new OpenLayers.LonLat(7, 50), 7);
-	mapframe_file_list.setCenter(new OpenLayers.LonLat(7, 50), 7);
-	resetForm();
-	//start parsing when no empty string was found in input for url
-	if ($('#download_feed_url').val() != "") {
-		method =  "getServiceFeedObjectFromUrl";
-        	data = $("#download_feed_url").val();
-		//call server by ajax function
-		callServer(data,method);
-	//initialize button for load service feed - the first feed will be parsed.
-	$(document).ready(function(e) {
-    		$('#download_feed_button').click(function() {
-			resetForm();
-	//don't show elements of dataset feed
-//central function to call server by ajax, result is a featureCollection which is generated by mapbenders server component
-function callServer(data,method,id) {
-	if (id === undefined) id = 0;
-	//alert("ajax call begin");
-	$.ajax({
-  		url: '../plugins/mb_downloadFeedServer.php',
-  		type: "post",
-		async: false, //cause reading the first feed may take longer than the second
-		data: {url: data, method: method , id: id},
-       		dataType: "json",
-  		success: function(result) {
-			if (method == "getServiceFeedObjectFromUrl") {
-				//draw georss polygons from service feed
-				drawMetadataPolygons(result);
-				//show datasets in a dropdown list
-				showDatasetList(result);
-			if (method == "getDatasetFeedObjectFromUrl") {
-				//function to draw bboxes of single link to data tile and the corresponding list of tiles
-				//alert("ajax datasetfeed read!");
-				showDatasetEntryList(result, id);
-	return false;
-function resetForm() {
-	//reset form
-	$("#representation_select").css("display","none");
-	$("#representation_info").css("display","none");
-	//change size of outer fieldset
-	$("#client").css("height","450px");
-function showDatasetList(featureCollection,id) {
-	resetForm();
-	if (featureCollection == null) {
-		alert("No parseable content found");
-		return false;
-	//remove old dataset select option
-	$('#dataset_select').remove();
-	//delete identifier anchor
-	$('#dataset_identifier_link').remove();
-	//delete capabilities anchor
-	$('#capabilities_link').remove();
-	//delete old entries
-	var datasetSelect =  $(document.createElement('select')).appendTo('#dataset_list');
-	datasetSelect.attr({'id':'dataset_select'});
-	var selectOptions = "";
-	//iterate over all single features which can be identified with the entries of the inspire service feed
-	for(var i=0; i<featureCollection.features.length; ++i) {
-		//fill in first title, rights and abstract in fields
-		if (i == id) {
-			$('#dataset_title').val(featureCollection.features[i].properties.title);
-			$('#dataset_rights').val(featureCollection.features[i].properties.rights);
-			$('#dataset_abstract').val(featureCollection.features[i].properties.summary);
-			//add capabilities anchor
-			identifierAnchor =  $(document.createElement('a')).appendTo('#capabilities_hybrid');
-			identifierAnchor.attr({'id':'capabilities_link'});
-			identifierAnchor.attr({'href':featureCollection.features[i].properties.capabilitiesLink});
-			identifierAnchor.text(featureCollection.features[i].properties.capabilitiesLink);
-			//$('#capabilities_link').val(featureCollection.features[i].properties.capabilitiesLink);
-			//add identifier anchor
-			identifierAnchor =  $(document.createElement('a')).appendTo('#dataset_identifier');
-			identifierAnchor.attr({'id':'dataset_identifier_link'});
-			identifierAnchor.attr({'uuid':featureCollection.features[i].properties.code});
-			identifierAnchor.attr({'href':'../php/mod_iso19139ToHtml.php?url='+encodeURIComponent(featureCollection.features[i].properties.metadataLink)});
-			identifierAnchor.text(featureCollection.features[i].properties.namespace+"#"+featureCollection.features[i].properties.code);
-		selectOptions = selectOptions+"<option value='"+featureCollection.features[i].properties.datasetFeedLink+"' url='"+featureCollection.features[i].properties.datasetFeedLink+"' optionid='"+i+"'>"+featureCollection.features[i].properties.title+"</option>";
-	datasetSelect.append(selectOptions);
-	//preselect option
-	$("#dataset_select option[optionid='" + id + "']").attr("selected","selected");
-	$('#dataset_select').bind('change', function() {
-		var $this = $(this);
-		optionSelected = $(this).find('option:selected').attr('optionid');
-		//alert(optionSelected);
-		showDatasetList(featureCollection,optionSelected);
-		method =  "getDatasetFeedObjectFromUrl";
-        	data = $this.val();
-		resetForm();
-	//call second feed with first entry for default
-        data = featureCollection.features[0].properties.datasetFeedLink;
-	datasetFeedObject = callServer(data,method);
-function showDatasetEntryList(featureCollection, id) {
-		return false;
-	//alert("test");
-	//remove select element for the different possible representations (formats, crs, ...)
-	$('#dataset_representation_select').remove();
-	//generate new select element
-	var datasetEntrySelect =  $(document.createElement('select')).appendTo('#dataset_representation_list');
-	datasetEntrySelect.attr({'id':'dataset_representation_select'});
-	//initialize options
-	var selectROptions = "";
-	//iterate over all possible representations, which are modeled as entries in the dataset feed (here features of the featureCollection)
-		selectROptions = selectROptions+"<option value='"+i+"' url='"+featureCollection.features[i].properties.datasetFeedLink+"'>"+featureCollection.features[i].properties.title+"</option>";
-	datasetEntrySelect.append(selectROptions);
-	fillSectionList(featureCollection, id);
-	$('#dataset_representation_select').bind('change', function() {
-		fillSectionList(featureCollection,$this.val());
-function fillSectionList(featureCollection, k) {
-		bboxFiles.removeAllFeatures();
-		$('#section_option').remove();
-		//initialize option string
-		var selectFOptions = "";
-		//count number of links in representation
-		var numberOfLinks = featureCollection.features[k].properties.link.length;
-		if (numberOfLinks >= 1 || numberOfLinks === undefined) {
-			//show list
-			$("#representation_select").css("display","block");
-			//deactivate mapframe2 by default
-			$("#mapframe_file_list").css("display","none");
-			//$("#multi_select").css("display","none");
-			$("#representation_info").css("display","block");
-			//extent size of outer fieldset
-			$("#client").css("height","730px");
-		} else {
-			alert("No links to datasets or parts of them found in feed!");
-                for (var i = 0; i < numberOfLinks; i++) {
-			if (featureCollection.features[k].properties.link[i]['@attributes'].bbox == '' || featureCollection.features[k].properties.link[i]['@attributes'].bbox === undefined) {
-				selectFOptions = selectFOptions+"<option value='"+i+"' url='"+featureCollection.features[k].properties.link[i]['@attributes'].href+"' title='"+featureCollection.features[k].properties.link[i]['@attributes'].title+"'  onclick='window.open(\""+featureCollection.features[k].properties.link[i]['@attributes'].href+"\");'>"+featureCollection.features[k].properties.link[i]['@attributes'].title+"</option>";
-			} else {
-                		ext = featureCollection.features[k].properties.link[i]['@attributes'].bbox;
-				extArrayNew = new Array();
-				extArray = ext.split(" ");
-				//sort array to lat lon
-				extArrayNew[0] = extArray[1];
-				extArrayNew[1] = extArray[0];
-				extArrayNew[2] = extArray[3];
-				extArrayNew[3] = extArray[2];
-                		bound = OpenLayers.Bounds.fromArray(extArrayNew);
-				attributes = {id: i, url:featureCollection.features[k].properties.link[i]['@attributes'].href};
-                		box = new OpenLayers.Feature.Vector(bound.toGeometry(),attributes);
-                		bboxFiles.addFeatures(box);
-				selectFOptions = selectFOptions+"<option value='"+i+"' url='"+featureCollection.features[k].properties.link[i]['@attributes'].href+"' title='"+featureCollection.features[k].properties.link[i]['@attributes'].title+"' onclick='highlightFeatureIndexById("+i+",true);' onmouseover='highlightFeatureIndexById("+i+",false);'>"+featureCollection.features[k].properties.link[i]['@attributes'].title+"</option>";
-		//count features of bboxFiles
-		//bboxFiles if not available show error message
-		selectFObject = $(document.createElement('select')).appendTo('#section_list');
-		selectFObject.attr({'id':'section_option'});
-		selectFObject.attr({'multiple':'multiple'});
-		//add options
-		selectFOptionsObject = $('#section_option').append(selectFOptions);
-		selectFOptionsObject.attr({'width': 300});
-		//alert(bboxFiles.features.length);
-		if (bboxFiles.features.length >= 1) {//TODO
-			//show mapframe
-			$("#mapframe_file_list").css("display","block");
-			$("#client").css("height","900px");
-			bound = bboxFiles.getDataExtent();
-			//Add wms layer from mb_metadata table (bounding_geom column)
-	 		var wms222 = new OpenLayers.Layer.WMS( "Exterior polygon from metadata",
-                "http://localhost/cgi-bin/mapserv?map=/home/armin/GDI-RP/Geoportal/devel/mapbender_trunk/tools/wms_extent/extents.map&metadata_uuid="+$('#dataset_identifier_link').attr('uuid'), {layers: 'metadata_polygon',transparent: "true",format: "image/png"}, {singleTile: true, isBaseLayer: false});
-			mapframe_file_list.addLayers([wms222]);
-			//Add polygon layer from mb_metadata tables bounding_geom column
-			mapframe_file_list.zoomToExtent(bound);
-			bboxFiles.events.on({
-   				featureselected: function(event) {
-        				var feature = event.feature;
-        				var id = feature.attributes.id;
-					var url = feature.attributes.url;
-					$('#section_option option').removeAttr('selected')
-					$("#section_option option[value='"+id+"']").attr('selected',true);
-					//window.open(url,'download_window');
-					/*if ($('#multi_select').is(':checked')) {
-						alert("checked");
-					} else {
-						alert("un-checked");
-					alert(url);*/
-                	sf = new OpenLayers.Control.SelectFeature(bboxFiles);
-                	mapframe_file_list.addControl(sf);
-                	sf.activate();
-function drawMetadataPolygons(featureCollection) {
-	 var type = "geojson";
-         var features = formats['in'][type].read(featureCollection);
-         var bounds;
-         if(features) {
-             if(features.constructor != Array) {
-                 features = [features];
-             for(var i=0; i<features.length; ++i) {
-                 if (!bounds) {
-                     bounds = features[i].geometry.getBounds();
-                 } else {
-                     bounds.extend(features[i].geometry.getBounds());
-	     //delete old features:
-	     bboxDataset.removeAllFeatures();
-             bboxDataset.addFeatures(features);
-             mapframe_dataset_list.zoomToExtent(bounds);
-function highlightFeatureIndexById(id, open) {
-	features = bboxFiles.features;
-		if(features[i].attributes.id == id) {
-			index = i;
-			break;
-	//unselect all if one is selected
-	sf.unselectAll();
-	sf.select(bboxFiles.features[index]);
-	if (open) {
-		window.open(bboxFiles.features[index].attributes.url,'download_window');
More information about the Mapbender_commits mailing list
