[Mapbender-commits] r9185 - trunk/mapbender/http/php
svn_mapbender at osgeo.org
Mon Apr 27 02:53:49 PDT 2015
Author: syed
Date: 2015-04-27 02:53:49 -0700 (Mon, 27 Apr 2015)
New Revision: 9185
trunk/mapbender/http/php/mb_delete_local_data.php
fix delete_local_data php-script
Modified: trunk/mapbender/http/php/mb_delete_local_data.php
--- trunk/mapbender/http/php/mb_delete_local_data.php 2015-04-17 11:37:47 UTC (rev 9184)
+++ trunk/mapbender/http/php/mb_delete_local_data.php 2015-04-27 09:53:49 UTC (rev 9185)
@@ -19,53 +19,41 @@
require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
require_once(dirname(__FILE__) . "/../classes/class_wmc.php");
+// user id in session
$user_id = Mapbender::session()->get("mb_user_id");
+// create wmc object
$wmc = new wmc();
+// get post parameter
+$serial_id;
$wmc_id = $_POST["id"];
-$form_target = $self;
-$sql = 'Select wmc from mb_user_wmc where wmc_id = $1 and wmc_has_local_data = 1 and fkey_user_id = $2;';
+// sql statement to get the wmc object and the serial_id
+$sql = 'Select wmc,wmc_serial_id from mb_user_wmc where wmc_id = $1 and wmc_has_local_data = 1 and fkey_user_id = $2;';
$v = array($wmc_id, $user_id);
-$t = array("i", "i");
+$t = array("c", "i");
$res = db_prep_query($sql, $v, $t);
-// if($row = db_fetch_array($res)){
-// $wmc->createFromXml($row['wmc']);
-// $wmc->generalExtensionArray['KMLS'] = null;
-// $wmc->wmc_id = $wmc_id;
-// $wmc->has_local_data = 0;
-// $wmc->local_data_public = 0;
-// $wmc->local_data_size = '0';
-// $res = $wmc->insert(true);
-// echo(json_encode($res));
-// } else {
-// echo('{"success":false}');
-if($row = db_fetch_array($res)){
- //FIXME: Diesnt work!!
+// fetch result
+if ($row = db_fetch_array($res)) {
+ $wmc->generalExtensionArray['KMLORDER'] = null;
$newWmcXml = $wmc->toXml();
- // var_dump($wmc->wmc_id);die;
+ // set the serial_id
+ $serial_id = $row['wmc_serial_id'];
if (is_int(intval($wmc->wmc_id))) {
- $wmc->update_existing($newWmcXml, $wmc->wmc_id);
+ $wmc->update_existing($newWmcXml, $serial_id);
+ // send sql to update the local-data flag
+ $sql = 'UPDATE mb_user_wmc mb SET wmc_has_local_data = 0 WHERE wmc_id = $1';
+ $v = array($wmc_id);
+ $t = array("s");
+ $res = db_prep_query($sql, $v, $t);
echo('{"success":true}');
+} else {
+ echo('{"success":false}');
-else {
-echo('{"success":false}');
More information about the Mapbender_commits
