[Mapbender-commits] r9324 - in trunk/mapbender/http: classes php
svn_mapbender at osgeo.org
Tue Dec 1 04:05:54 PST 2015
Author: armin11
Date: 2015-12-01 04:05:54 -0800 (Tue, 01 Dec 2015)
New Revision: 9324
trunk/mapbender/http/classes/class_iso19139.php
trunk/mapbender/http/php/mod_inspireDownloadFeed.php
Bugfix for calculating bboxes
Modified: trunk/mapbender/http/classes/class_iso19139.php
--- trunk/mapbender/http/classes/class_iso19139.php 2015-12-01 10:47:12 UTC (rev 9323)
+++ trunk/mapbender/http/classes/class_iso19139.php 2015-12-01 12:05:54 UTC (rev 9324)
@@ -1785,7 +1785,7 @@
$this->fees,
$this->licenseSourceNote
- $e = new mb_exception("class_iso19139: ".$this->createWktBboxFromArray($this->wgs84Bbox));
+ //$e = new mb_exception("class_iso19139: ".$this->createWktBboxFromArray($this->wgs84Bbox));
$t = array('s','s','s','s','s','s','s','s','s','s','s','s','s','b','s','s','s','s','i','i','s','s','b','s','s','s','s','s','s','POLYGON','s','s','s','i','POLYGON','d','s','s');
$res = db_prep_query($sql,$v,$t);
return $res;
Modified: trunk/mapbender/http/php/mod_inspireDownloadFeed.php
--- trunk/mapbender/http/php/mod_inspireDownloadFeed.php 2015-12-01 10:47:12 UTC (rev 9323)
+++ trunk/mapbender/http/php/mod_inspireDownloadFeed.php 2015-12-01 12:05:54 UTC (rev 9324)
@@ -1308,6 +1308,7 @@
$bboxFilter = '<Filter xmlns:gml="http://www.opengis.net/gml"><BBOX>';
//$bboxFilter .= '<gml:Box srsName="EPSG:'.$epsgId[1].'"';
$bboxFilter .= '<ogc:PropertyName>the_geom</ogc:PropertyName>';//TODO parse DescribeFeatureType for geom property
$bboxFilter .= '<gml:Box>';
$bboxFilter .= '<gml:coordinates>';
$currentBbox = explode(',',$bboxWfs[$mapbenderMetadata[$i]->featuretype_name][$l]);
@@ -1685,8 +1686,7 @@
function parseBox2d($box2d) {
//"BOX(6.9213399887085 50.1331939697266,6.93241024017334 50.138801574707)"
//delete BOX( and ), replace , with blank
- //new 20151201 - use xmin not bbox2d from postgis!!!
- //$bbox = str_replace(","," ",str_replace(")","",str_replace("BOX(", "", $box2d)));
+ $bbox = str_replace(","," ",str_replace(")","",str_replace("BOX(", "", $box2d)));
//explode with blank
$bbox = explode(" ",$bbox);
return $bbox;
@@ -1734,11 +1734,8 @@
//to generate an atom feed from mb_metadata there must be some information avaiable, that is normally used from service metadata
//owner, group, bbox, ... - the mb_metadata table have to be filled with the geometry from the layer/featuretype - of which it has been coupled with
$mapbenderMetadata[$indexMapbenderMetadata]->origin = $row['origin'];
- $e = new mb_exception($row['origin']);
if (isset($row['bbox2d']) && $row['bbox2d'] != '') {
$bbox = $row['bbox2d'];
- //$bbox = str_replace(' ',',',str_replace(')','',str_replace('BOX(','',$row['bbox2d'])));
- //$e = new mb_exception("class_iso19139.php: got bbox for metadata: ".$bbox);
$mapbenderMetadata[$indexMapbenderMetadata]->latlonbbox = explode(',',$bbox);
$mapbenderMetadata[$indexMapbenderMetadata]->minx = $mapbenderMetadata[$indexMapbenderMetadata]->latlonbbox[0];
$mapbenderMetadata[$indexMapbenderMetadata]->miny = $mapbenderMetadata[$indexMapbenderMetadata]->latlonbbox[1];
@@ -1846,7 +1843,7 @@
//overwrite mapbenderMetadata->minx ... which came from layer/featuretype metadata with bbox of metadata itself, if given
if (isset($mapbenderMetadata[$indexMapbenderMetadata]->metadata_bbox) && $mapbenderMetadata[$indexMapbenderMetadata]->metadata_bbox !== "") {
- $bbox = parseBox2d($mapbenderMetadata[$indexMapbenderMetadata]->metadata_bbox);
+ $bbox = explode(",", $mapbenderMetadata[$indexMapbenderMetadata]->metadata_bbox);
$mapbenderMetadata[$indexMapbenderMetadata]->minx = $bbox[0];
$mapbenderMetadata[$indexMapbenderMetadata]->miny = $bbox[1];
$mapbenderMetadata[$indexMapbenderMetadata]->maxx = $bbox[2];
More information about the Mapbender_commits
