[Mapbender-commits] r9330 - in trunk/mapbender/http: classes php
svn_mapbender at osgeo.org
Thu Dec 3 08:35:54 PST 2015
Author: armin11
Date: 2015-12-03 08:35:54 -0800 (Thu, 03 Dec 2015)
New Revision: 9330
trunk/mapbender/http/classes/class_metadata_new.php
trunk/mapbender/http/php/mod_callMetadata.php
First draft of resolving data service metadata coupling otf while searching for datasets
Modified: trunk/mapbender/http/classes/class_metadata_new.php
--- trunk/mapbender/http/classes/class_metadata_new.php 2015-12-03 16:03:10 UTC (rev 9329)
+++ trunk/mapbender/http/classes/class_metadata_new.php 2015-12-03 16:35:54 UTC (rev 9330)
@@ -54,15 +54,16 @@
var $searchResources;
var $searchPages;
var $outputFormat;
- var $resultTarget;
+ var $resultTarget; //web,webclient,file,internal
var $tempFolder;
var $orderBy;
var $hostName;
var $resourceIds;
var $restrictToOpenData;
var $originFromHeader;
+ var $resolveCoupledResources;
- function __construct($userId, $searchId, $searchText, $registratingDepartments, $isoCategories, $inspireThemes, $timeBegin, $timeEnd, $regTimeBegin, $regTimeEnd, $maxResults, $searchBbox, $searchTypeBbox, $accessRestrictions, $languageCode, $searchEPSG, $searchResources, $searchPages, $outputFormat, $resultTarget, $searchURL, $customCategories, $hostName, $orderBy, $resourceIds, $restrictToOpenData, $originFromHeader){
+ function __construct($userId, $searchId, $searchText, $registratingDepartments, $isoCategories, $inspireThemes, $timeBegin, $timeEnd, $regTimeBegin, $regTimeEnd, $maxResults, $searchBbox, $searchTypeBbox, $accessRestrictions, $languageCode, $searchEPSG, $searchResources, $searchPages, $outputFormat, $resultTarget, $searchURL, $customCategories, $hostName, $orderBy, $resourceIds, $restrictToOpenData, $originFromHeader, $resolveCoupledResources = false){
$this->userId = (integer)$userId;
$this->searchId = $searchId;
$this->searchText = $searchText;
@@ -95,6 +96,8 @@
$this->restrictToOpenData = false;
$this->originFromHeader = $originFromHeader;
+ $this->internalResult = null; //will only be filled, if resultTarget = 'internal', includes json for wms or wfs
+ $this->resolveCoupledResources = $resolveCoupledResources;
//definitions for generating tagClouds
$this->maxObjects = 15;
$this->maxFontSize = 30;
@@ -164,7 +167,7 @@
$this->resourceClassifications[2]['relation_wms'] = 'layer_custom_category';
$this->resourceClassifications[2]['relation_wfs'] = 'featuretype_custom_category';
$this->resourceClassifications[2]['relation_wmc'] = 'wmc_custom_category';
- $this->resourceClassifications[1]['relation_dataset'] = 'mb_metadata_custom_category';
+ $this->resourceClassifications[2]['relation_dataset'] = 'mb_metadata_custom_category';
//TODO: define this in mapbender
//Defining of the different result categories
@@ -314,7 +317,7 @@
$this->generateWMCMetadata($this->wmcDoc);
if (isset($this->searchResources) & strtolower($this->searchResources) === "dataset") {
- $this->databaseIdColumnName = 'metadata_id';
+ $this->databaseIdColumnName = 'metadata_id'; //not metadata_id as in original table!
$this->databaseTableName = 'mb_metadata';
//$this->keywordRelation = 'layer_keyword';
//$this->searchView = 'wms_search_table';
@@ -581,6 +584,8 @@
#array_multisort($wfsMatrix['wfs_id'], SORT_ASC,$wfsMatrix['featuretype_id'], SORT_ASC,$wfsMatrix['wfs_conf_id'], SORT_ASC); //have some problems - the database version is more stable
#print_r($wfsMatrix);
$datasetMatrix = $this->flipDiagonally($datasetMatrix);
+ $allCoupledLayers = array();
+ $allCoupledFeaturetypes = array();
//read out first server entry - maybe this a little bit timeconsuming TODO
for($i=0; $i<count($datasetMatrix);$i++){
$this->datasetJSON->dataset->srv[$i]->id = $datasetMatrix[$i]['dataset_id'];
@@ -600,17 +605,50 @@
} else {
$spatialSource = $datasetMatrix[$i]['mb_group_stateorprovince'];
- $this->datasetJSON->dataset->srv[$i-$j]->iso3166 = $spatialSource;
+ $this->datasetJSON->dataset->srv[$i]->iso3166 = $spatialSource;
- $this->datasetJSON->dataset->srv[$i-$j]->bbox = array($datasetMatrix[$i]['bbox']); //TODO: read out bbox from wmc $datasetMatrix[$i][''];
- #$equalEPSG = $wmcMatrix[$i]['srs'];
- #$isEqual = true;
- //control if EPSG is supported by Client
- #if ($equalEPSG == $this->searchEPSG){
- # $isEqual = false;
+ $this->datasetJSON->dataset->srv[$i]->bbox = array($datasetMatrix[$i]['bbox']); //TODO: read out bbox from wmc $datasetMatrix[$i][''];
+ //search for coupled resources!!!!
+ if ($this->resolveCoupledResources == true) {
+ //maybe generate uuid first to find search!!
+ //http://localhost/mb_trunk/php/mod_callMetadata.php?searchId=test2&searchText=wald&outputFormat=json&resultTarget=web&searchResources=dataset&resolveCoupledResources=true
+ $coupledResources = json_decode($datasetMatrix[$i]['coupled_resources']);
+ foreach ($coupledResources->coupledResources->layerIds as $layer_id) {
+ $this->datasetJSON->dataset->srv[$i]->coupledResources->layer[] = $layer_id;
+ $allCoupledLayers[] = $layer_id;
+ foreach ($coupledResources->featuretypeIds as $featuretype_id) {
+ $this->datasetJSON->dataset->srv[$i]->coupledResources->featuretype[] = $featuretype_id;
+ $allCoupledFeaturetypes[] = $featuretype_id;
+ //$coupledLayers = new self($this->userId, 'dummysearch', '*', null, null, null, null, null, null, null, 10, null, null, null, $this->languageCode, null, 'wms', 1, 'json', 'internal', null, null, $this->hostName, 'rank', '13751,13752' ,false , null);
+ //$this->datasetJSON->dataset->srv[$i-$j]->coupledLayer = json_decode($coupledLayers->internalResult);
+ //$coupledFeaturetypes = new self($this->userId, 'dummysearch', '*', null, null, null, null, null, null, null, 10, null, null, null, $this->languageCode, null, 'wfs', 1, 'json', 'internal', null, null, $this->hostName, 'rank', '13751,13752' ,false , null);
+ //$this->datasetJSON->dataset->srv[$i-$j]->coupledFeaturetypes = json_decode($coupledFeaturetypes->internalResult);
+ //pull downloadoptions directly from layer downloadoptions cause they are the same !!!!
+ //search for coupled resources and push them into dataset json !
+ //$e = new mb_exception("count of all layers:".count(array_unique($allCoupledLayers)));
+ //$e = new mb_exception("cs of all layers:".implode(',',array_unique($allCoupledLayers)));
+ //$e = new mb_exception("count layers: ".time());
+ //$csLayerIds = implode(',',array_unique($allCoupledLayers));
+ //$countLayerIds = (integer)count(array_unique($allCoupledLayers));
+ if (count($allCoupledLayers) >= 1) {
+ //$e = new mb_exception("invoke search");
+ //$coupledLayers = new self($this->userId, 'dummysearch', '*', null, null, null, null, null, null, null, count(array_unique($allCoupledLayers)), null, null, null, $this->languageCode, null, 'wms', 1, 'json', 'internal', null, null, $this->hostName, 'rank', implode(',',array_unique($allCoupledLayers))$csLayerIds ,false , null);
+ $coupledLayers = new self($this->userId, 'dummysearch', '*', null, null, null, null, null, null, null, count(array_unique($allCoupledLayers)), null, null, null, $this->languageCode, null, 'wms', 1, 'json', 'internal', null, null, $this->hostName, 'rank',implode(',',array_unique($allCoupledLayers)) ,false , null);
+ //$test = json_decode($coupledLayers->internalResult);
+ //$e = new mb_exception($coupledLayers->internalResult);
+ //$e = new mb_exception("count featuretypes: ".time());
+ if (count($allCoupledFeaturetypes) >= 1) {
+ $coupledFeaturetypes = new self($this->userId, 'dummysearch', '*', null, null, null, null, null, null, null, count(array_unique($allCoupledFeaturetypes)), null, null, null, $this->languageCode, null, 'wfs', 1, 'json', 'internal', null, null, $this->hostName, 'rank', implode(',',array_unique($allCoupledFeaturetypes)) ,false , null);
+ //$e = new mb_exception("end counting: ".time());
@@ -840,6 +878,9 @@
if ($this->resultTarget == 'web' or $this->resultTarget == 'debug') {
echo $this->wmsJSON;
+ if ($this->resultTarget == 'internal') {
+ $this->internalResult = $this->wmsJSON;
if ($this->resultTarget == 'webclient') {
$this->allJSON = new stdClass;
$this->allJSON->categories = $this->json->decode($this->keyJSON);
@@ -900,6 +941,9 @@
if ($this->resultTarget == 'web'or $this->resultTarget == 'debug') {
echo $this->wfsJSON;
+ $this->internalResult = $this->wfsJSON;
$e = new mb_notice("Time to generate WFS-Metadata: ".$usedTime);
@@ -1237,7 +1281,10 @@
//filename to search for:
$filename = $this->tempFolder."/".$this->searchId."_".$this->searchResources."_cat.json";
$keyFilename = $this->tempFolder."/".$this->searchId."_".$this->searchResources."_keywords.json";
- if (!file_exists($filename) or $this->resultTarget == 'debug') { //TODO at the moment the cat file will be overwritten - change this in production system
+ //check filename exists in storage
+ $admin = new administration();
+ $fileExists = $admin->getFromStorage($filename,TMP_SEARCH_RESULT_STORAGE);
+ if ($fileExists == false or $this->resultTarget == 'debug') { //TODO at the moment the cat file will be overwritten - change this in production system
//open category file for results
$this->catJSON = new stdClass;
$this->catJSON->searchMD = (object) array(
Modified: trunk/mapbender/http/php/mod_callMetadata.php
--- trunk/mapbender/http/php/mod_callMetadata.php 2015-12-03 16:03:10 UTC (rev 9329)
+++ trunk/mapbender/http/php/mod_callMetadata.php 2015-12-03 16:35:54 UTC (rev 9330)
@@ -47,6 +47,7 @@
$resultTarget = "web";
$preDefinedMaxResults = array(5,10,15,20,25,30);
$searchEPSG = "EPSG:31466";
+$resolveCoupledResources = false;
$classJSON = new Mapbender_JSON;
if (defined('ABSOLUTE_TMPDIR')){
@@ -296,6 +297,24 @@
$testMatch = NULL;
+if (isset($_REQUEST["resolveCoupledResources"]) & $_REQUEST["resolveCoupledResources"] != "") {
+ $testMatch = $_REQUEST["resolveCoupledResources"];
+ if (!($testMatch == 'true' or $testMatch == 'false')){
+ echo 'Parameter <b>resolveCoupledResources</b> is not valid (true,false (default to false)).<br/>';
+ die();
+ switch ($testMatch) {
+ case "true":
+ $resolveCoupledResources = "true";
+ break;
+ case "false":
+ $resolveCoupledResources = "false";
+ break;
+ $testMatch = NULL;
if (isset($_REQUEST["hostName"]) & $_REQUEST["hostName"] != "") {
//validate to some hosts
$testMatch = $_REQUEST["hostName"];
@@ -370,9 +389,9 @@
if (isset($_REQUEST["resultTarget"]) & $_REQUEST["resultTarget"] != "") {
//validate to web,debug,file
$testMatch = $_REQUEST["resultTarget"];
- if (!($testMatch == 'web' or $testMatch == 'debug' or $testMatch == 'file' or $testMatch == 'webclient')){
+ if (!($testMatch == 'web' or $testMatch == 'debug' or $testMatch == 'file' or $testMatch == 'webclient' or $testMatch == 'internal')){
//echo 'resultTarget: <b>'.$testMatch.'</b> is not valid.<br/>';
- echo 'Parameter <b>resultTarget</b> is not valid (file,web,debug,webclient).<br/>';
+ echo 'Parameter <b>resultTarget</b> is not valid (file,web,debug,webclient,internal).<br/>';
die();
$resultTarget = $testMatch;
@@ -402,14 +421,11 @@
#$searchResources = array('wms','wfs','wmc','georss');
#$searchPages = array(1,1,1,1);
//TODO: if class is called directly
if ($resultTarget == 'debug') {
echo "<br>DEBUG: searchURL: ".$searchURL."<br>";
#echo "<br>DEBUG: languageCode: ".$languageCode."<br>";
@@ -1012,16 +1028,17 @@
$str .= "'".$orderBy."' ";
$str .= "'".$resourceIds."' ";
$str .= "'".$restrictToOpenData."' ";
+ $str .= "'".$resolveCoupledResources."' ";
$str .= " & ";
$e = new mb_notice($str);
exec($str);*/
- $metadata = new searchMetadata($userId, $searchId, $searchText, $registratingDepartments, $isoCategories, $inspireThemes, $timeBegin, $timeEnd, $regTimeBegin, $regTimeEnd, $maxResults, $searchBbox, $searchTypeBbox, $accessRestrictions, $languageCode, $searchEPSG, $searchResources[$i], $searchPages[$i], $outputFormat, $resultTarget, $searchURL, $customCategories, $hostName, $orderBy, $resourceIds, $restrictToOpenData, $originFromHeader);
+ $metadata = new searchMetadata($userId, $searchId, $searchText, $registratingDepartments, $isoCategories, $inspireThemes, $timeBegin, $timeEnd, $regTimeBegin, $regTimeEnd, $maxResults, $searchBbox, $searchTypeBbox, $accessRestrictions, $languageCode, $searchEPSG, $searchResources[$i], $searchPages[$i], $outputFormat, $resultTarget, $searchURL, $customCategories, $hostName, $orderBy, $resourceIds, $restrictToOpenData, $originFromHeader, $resolveCoupledResources);
if ($resultTarget == 'web' or $resultTarget == 'debug' or $resultTarget == 'webclient') {
if (count($searchResources) == 1) {
//$e = new mb_exception("originFromHeader: ".$originFromHeader);
- $metadata = new searchMetadata($userId, $searchId, $searchText, $registratingDepartments, $isoCategories, $inspireThemes, $timeBegin, $timeEnd, $regTimeBegin, $regTimeEnd, $maxResults, $searchBbox, $searchTypeBbox, $accessRestrictions, $languageCode, $searchEPSG, $searchResources[0], $searchPages[0], $outputFormat, $resultTarget, $searchURL, $customCategories, $hostName, $orderBy, $resourceIds, $restrictToOpenData, $originFromHeader);
+ $metadata = new searchMetadata($userId, $searchId, $searchText, $registratingDepartments, $isoCategories, $inspireThemes, $timeBegin, $timeEnd, $regTimeBegin, $regTimeEnd, $maxResults, $searchBbox, $searchTypeBbox, $accessRestrictions, $languageCode, $searchEPSG, $searchResources[0], $searchPages[0], $outputFormat, $resultTarget, $searchURL, $customCategories, $hostName, $orderBy, $resourceIds, $restrictToOpenData, $originFromHeader, $resolveCoupledResources);
#if ($outputFormat == 'xml') {
# header("Content-type: application/xhtml+xml; charset=UTF-8");
More information about the Mapbender_commits
