[Mapbender-commits] r9148 - in trunk/mapbender/http: classes plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Jan 22 01:17:06 PST 2015
Author: verenadiewald
Date: 2015-01-22 01:17:06 -0800 (Thu, 22 Jan 2015)
New Revision: 9148
   trunk/mapbender/http/classes/class_wms_owsproxy_log.php
   trunk/mapbender/http/plugins/mb_owsproxy_log_csv.js
bugfix in owsproxy_log: confirm message when deleting all log entries for all wms of selected user
Modified: trunk/mapbender/http/classes/class_wms_owsproxy_log.php
--- trunk/mapbender/http/classes/class_wms_owsproxy_log.php	2015-01-21 15:27:33 UTC (rev 9147)
+++ trunk/mapbender/http/classes/class_wms_owsproxy_log.php	2015-01-22 09:17:06 UTC (rev 9148)
@@ -271,15 +271,23 @@
 //            $t = array('i', "t", "t");
 //            $sql = "DELETE FROM mb_proxy_log WHERE fkey_wms_id = $1"
 //                    ." AND proxy_log_timestamp >= $2 AND proxy_log_timestamp <= $3";
-            $v = array($this->wmsId, $this->timeFrom, $this->timeTo, $this->mb_user_id);
-            $t = array('i', "t", "t", "i");
+            $v = array($this->timeFrom, $this->timeTo, $this->mb_user_id);
+            $t = array("t", "t", "i");
             $sql = "DELETE FROM mb_proxy_log"
                     ." WHERE log_id in("
                         ." SELECT m.log_id"
                         ." FROM mb_proxy_log AS m INNER JOIN wms AS w ON"
-                        ." (m.fkey_wms_id = w.wms_id AND w.wms_owner=$4"
-                        ." AND m.fkey_wms_id = $1 AND  m.proxy_log_timestamp >= $2"
-                        ." AND m.proxy_log_timestamp <= $3)"
+                        ." (m.fkey_wms_id = w.wms_id AND w.wms_owner=$3";
+            $inOffset = 4;
+    		foreach(explode(",",$this->wmsId) as $wms) {
+    			$v[] = trim($wms);
+    			$t[] = "i";
+    			$inParams[] = "$".$inOffset;
+    			$inOffset++;
+    		$sql .= " AND m.fkey_wms_id IN (" .implode(",",$inParams) .")";
+    		$sql .= " AND  m.proxy_log_timestamp >= $1"
+                   ." AND m.proxy_log_timestamp <= $2)"
             $result = db_prep_query($sql,$v,$t);
             $resnum = pg_affected_rows($result);
@@ -302,9 +310,17 @@
             $whereWms = "";
             if($this->wmsId !== null && $this->wmsId != "") {
-                $whereWms = " AND m.fkey_wms_id = $5";
-                $v[] = $this->wmsId;
-                $t[] = 'i';
+                $whereWms = " AND m.fkey_wms_id IN (";
+                $inOffset = 5;
+    				$t[] = "i";
+    				$inOffset++;
+                $whereWms .= implode(",",$inParams);
+                $whereWms .= ")";
Modified: trunk/mapbender/http/plugins/mb_owsproxy_log_csv.js
--- trunk/mapbender/http/plugins/mb_owsproxy_log_csv.js	2015-01-21 15:27:33 UTC (rev 9147)
+++ trunk/mapbender/http/plugins/mb_owsproxy_log_csv.js	2015-01-22 09:17:06 UTC (rev 9148)
@@ -58,13 +58,27 @@
     this.deleteData = function(e){
+    	if(lastRequestData.wmsId == -1) {
+    		var delMsg = "Die Logeinträge ALLER vorhandenen Dienste aus der Liste werden gelöscht. Soll diese Aktion ausgeführt werden?";
+    	else {
     	var delMsg = "Die Logeinträge werden gelöscht. Soll diese Aktion ausgeführt werden?";
     	var delConfirm = confirm(delMsg);
         if(delConfirm == true){
         var a = 0;
         if (lastRequestData != null){
             var parameter = lastRequestData;
             parameter['function'] = "deleteServiceLogs";
+        			var allServices = new Array();
+        			$('#wmsId option').each(function(){
+        				if(this.value != "" && this.value != -1) {
+        					allServices.push(this.value);
+        			parameter['wmsId'] = allServices.join(',');
             that.loadJson(parameter);
@@ -427,4 +441,4 @@
\ No newline at end of file
More information about the Mapbender_commits mailing list
