[Mapbender-commits] r9249 - trunk/mapbender/http/plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Jul 13 05:44:12 PDT 2015
Author: armin11
Date: 2015-07-13 05:44:12 -0700 (Mon, 13 Jul 2015)
New Revision: 9249
Removed:
   trunk/mapbender/http/plugins/kmlTree.js
Handle new visualization - drop kmlTree.js
Deleted: trunk/mapbender/http/plugins/kmlTree.js
--- trunk/mapbender/http/plugins/kmlTree.js	2015-07-13 12:43:56 UTC (rev 9248)
+++ trunk/mapbender/http/plugins/kmlTree.js	2015-07-13 12:44:12 UTC (rev 9249)
@@ -1,890 +0,0 @@
- * Package: kmlTree
- * Description:
- * Module to load KML temporary in a tree
- * Files:
- *  - mapbender/http/plugins/kmlTree.js
- *  - mapebnder/lib/mb.ui.displayKmlFeatures.js
- *  - mapbender/http/css/kmltree.css
- * SQL:
- * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,
- * > e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content,
- * > e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('<app_id>',
- * > 'kmlTree',2,1,'Displays KML on the map','KML','ul','','',1,1,200,200,NULL ,
- * > 'visibility:visible','','ul','../plugins/kmlTree.js','../../lib/mb.ui.displayKmlFeatures.js',
- * > 'mapframe1','jq_ui_widget','http://www.mapbender.org/Loadkml');
- * > INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type) VALUES('gui', 'kmlTree',
- * > 'buffer', '100', '' ,'var');
- * > VALUES('gui', 'kmlTree', 'styles', '../css/kmltree.css', '' ,'file/css');
- * Help:
- * http://www.mapbender.org/Loadkml
- * Maintainer:
- * http://www.mapbender.org/User:Armin_Retterath
- * License:
- * Copyright (c) 2009, Open Source Geospatial Foundation
- * This program is dual licensed under the GNU General Public License
- * and Simplified BSD license.
- * http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
-if (typeof window.DOMParser === "undefined") {
-	window.DOMParser = function() {};
-	window.DOMParser.prototype.parseFromString = function(str, contentType) {
-		if (typeof ActiveXObject !== 'undefined') {
-			var xmldata = new ActiveXObject('MSXML.DomDocument');
-			xmldata.async = false;
-			xmldata.loadXML(str);
-			return xmldata;
-		} else if (typeof XMLHttpRequest !== 'undefined') {
-			var xmldata = new XMLHttpRequest;
-			if (!contentType) {
-				contentType = 'application/xml';
-			xmldata.open('GET', 'data:' + contentType + ';charset=utf-8,' + encodeURIComponent(str), false);
-			if (xmldata.overrideMimeType) {
-				xmldata.overrideMimeType(contentType);
-			xmldata.send(null);
-			return xmldata.responseXML;
-var $kmlTree = $(this);
-var KmlTree = function(o) {
-	$kmlTree.children().remove();
-	$kmlTree.addClass('kmlTree');
-	var $KMLfolder = $('<li class="open kml"><ul></ul></li>');
-	$kmlTree.append($KMLfolder);
-	$addButton = $('<button class="add" name="addkml" value="addkml"></button>');
-	var selectButton = $('<img id="toggle-select-features" src="../img/osgeo_graphics/geosilk/cursor.png"></img>');
-	$addButton.click(function() {
-		if ($('#mySpatialData').dialog('isOpen') === true) {
-			return;
-		} else {
-			var dlg = $('<div id="mySpatialData"></div>').dialog({
-				"title": "My spatial data",
-				width: 720,
-				height: 420,
-				close: function() {
-					$('#kml-load-tabs').tabs('destroy');
-					$(this).html('').dialog('destroy');
-					// $('#mySpatialData').dialog('destroy');
-					$('#mySpatialData').remove();
-			var dlgcontent = '<div id="kml-load-tabs">' + '<ul><li><a class="icon icon-wmc" href="#kml-from-wmc">Stored data</a></li>' + '<li><a class="icon icon-local" href="#kml-from-upload">Upload</a></li>' + '<li><a class="icon icon-remote" href="#kml-from-url">External source</a></li>' + '<li><a class="icon icon-new" href="#kml-new">New</a></li></ul>' + '<div id="kml-from-wmc">wmc</div>' + '<div id="kml-from-upload">' + '<iframe name="kml-upload-target" style="width: 0; height: 0; border: 0px;"></iframe>' + '<form action="../php/uploadKml.php" method="post" enctype="multipart/form-data" target="kml-upload-target">' + '<input type="file" name="kml"></input>' + '<input type="submit" class="upload" value="Upload"></input><br>' + 'You can upload local KML, GPX and geoJSON files here. The filename should' + ' have the typical file extension (.kml, .gpx or .geojson) and the size' + ' is limited to 250kb of data.' + '</div>' + '</form>' + '<div id="kml-from-url">URL: <input class="kmlurl" /><b
 utton class="add" name="add" value="add"></button><br>' + 'You can give an url to a datafile which is located somewhere in the www. ' + 'Only KML, geoJSON and GPX files are supported. The files will be validated before they' + ' are loaded into the mapviewer.' + '</div>' + '<div id="kml-new">' + '<label>Title: <input type="text" name="kml-new-title"></input></label>' + '<button class="add-kml"></button>' + '</div>' + '</div>';
-			$('#kml-load-tabs').remove();
-			$(dlg).append(dlgcontent);
-			$.ajax({
-				type: 'get',
-				url: '../php/mb_list_wmc_local_data.php',
-				success: function(data) {
-					var origData = $.extend(true, {}, data);
-					$.each(data, function(_, v) {
-						v[2] = new Date(v[2] * 1000);
-						if (v[3]) {
-							v[3] = '<img src="' + v[3] + '"></img>';
-						if (v[4]) {
-							v[4] = '<img class="publishIcon" src="../img/osgeo_graphics/check.png"></img><img class="exportImage" src="../img/osgeo_graphics/geosilk/link22.png"></img>';
-						} else {
-							v[4] = '<img class="publishIcon" src="../img/button_digitize/geomRemove.png"></img>';
-						v[5] = Math.round(v[5] / 1024) + 'kb';
-					// add dialog for ópen links
-					$('#kml-from-wmc').html('<table class="display"></table>').find('table').dataTable({
-							aaData: data,
-							aoColumns: [{
-								sTitle: 'ID'
-								sTitle: 'Title'
-								sTitle: 'last change'
-								sTitle: 'License'
-								sTitle: 'public'
-								sTitle: 'size'
-								sTitle: 'owner'
-						.find('tr').bind('dblclick', function() {
-							var id = $($(this).find('td')[0]).text();
-							$.ajax({
-								type: 'post',
-								url: '../php/mb_load_local_data.php',
-								data: {
-									id: id
-									var kml = $('#mapframe1').data('kml');
-									$.each(data, function(url, json) {
-										kml.addLayer(url, json.data);
-									$(dlg).dialog('destroy');
-						}).end()
-						.find('.exportImage').bind('click', function(event) { // add click event to the link image
-							// stop event propagation beacause the following bind has to catch the click events on the 'tr'
-							event.stopPropagation();
-							if ($('#dataExportDialog').dialog('isOpen') === true) {
-								$('#dataExportDialog').dialog('close');
-								$('#dataExportDialog').remove();
-								$(this).trigger('click');
-							} else {
-								var title = $(this).parent().siblings().eq(1).html();
-								var wmc_serial_id = $(this).parent().siblings().eq(0).html();
-								var outputFormat;
-								var dataExportDlg = $('<div id="dataExportDialog"></div>').dialog({
-									title: "Export my data " + title,
-									width: 250,
-									height: 212,
-									position: {
-										my: "center",
-										at: "top",
-										of: window
-										$('#dataExportDialog').dialog('destroy');
-								// var exportHtmlsdfdsf = '<div id="exportHtml">' + '<form>' + '<label class="export-format-kml">KML<input type="radio" name="export-format" value="kml" checked="checked"></input></label>' + '<label class="export-format-kml">KML<input type="radio" name="export-format" value="kml" checked="checked"></input></label>' + '<label class="export-format-kml">KML<input type="radio" name="export-format" value="kml" checked="checked"></input></label><br><br>' +
-								//     '<img src="../img/osgeo_graphics/geosilk/link22.png"/>' + '<label class="export-format-gpx">GPX</label>' + '<label class="export-format-geojson">geoJSON</label><br></br>' +
-								//     '<a download="myfeatures.kml" href="#" class="digitize-image digitize-export" style="float: left;"></a>' + '</form>' + '</div>';
-								var exportHtml = '<div id="exportHtml"><table><tbody>' +
-									'<tr><td>KML:</td><td><label class="export-format-kml exportDatasetIcon" style="padding-top:11px;"></label></td><td class="exportDataLink kml" wmcId="' + wmc_serial_id + '"outputFormat="kml"><img src="../img/osgeo_graphics/geosilk/link22.png"/></td></tr>' +
-									'<tr><td>GPX:</td><td><label class="export-format-gpx exportDatasetIcon" style="padding-top:11px;"></label></td><td class="exportDataLink gpx" wmcId="' + wmc_serial_id + '"outputFormat="gpx"><img src="../img/osgeo_graphics/geosilk/link22.png"/></td></tr>' +
-									'<tr><td>GeoJson:</td><td><label class="export-format-geojson exportDatasetIcon" style="padding-top:11px;"></label></td><td class="exportDataLink geojson" wmcId="' + wmc_serial_id + '"outputFormat="geojson"><img src="../img/osgeo_graphics/geosilk/link22.png"/></td></tr>' +
-									'</tbody></table></div><iframe id="export-DataCollection" style="border:0;height:0; width:0;"></iframe>';
-								// append the context
-								$(dataExportDlg).append(exportHtml);
-								//export the data
-								$('.exportDatasetIcon').bind('click', function(event) {
-									var exportClass = $(this).attr('class').toString().split(' ')[0];
-									//getting the outputformat
-									switch (exportClass) {
-										case 'export-format-kml':
-											outputFormat = 'kml';
-											break;
-										case 'export-format-gpx':
-											outputFormat = 'gpx';
-											break;
-										case 'export-format-geojson':
-											outputFormat = 'geojson';
-											break;
-									$('#export-DataCollection').attr("src", "../php/mod_GetPublishedData.php?wmc_id=" + wmc_serial_id + "&outputFormat=" + outputFormat);
-								$('.exportDataLink').bind('click', function(event) {
-									var format = $(this).attr('outputFormat');
-									var exportDataLinkDlg = $('<div id="exportDataLinkDlg"></div>').dialog({
-										"title": "Link to your Dataset",
-										width: 350,
-										height: 80,
-											$('#exportDataLinkDlg').dialog('destroy');
-											$('#exportDataLinkDlg').remove();
-									var exportDataLinkContent = '<div><label for="exportLinkInput">Link: </label><input id="exportLinkInput" size="35" type="text" value="http://' + window.location.hostname + '/mapbender/php/mod_GetPublishedData.php?wmc_id=' + wmc_serial_id + '&outputFormat=' + format + '"></div>';
-									$(exportDataLinkDlg).append(exportDataLinkContent);
-						.end()
-						.find('.publishIcon').bind('click', function() {
-							// var id = $($(this).find('td')[0]).text();
-							var id = $(this).parent().parent().children(':first').html();
-							var d;
-							$.each(origData, function(_, val) {
-								if (val[0] == id) {
-									d = val;
-							var dlg = '<div title="Options ' + d[1] + '">' +
-								'<ul class="kmltree-metadata-list">' + '<li class="kmltree-metadata-delete"><img style="vertical-align: middle;" src="../img/button_digitize/geomRemove.png"></img>Delete datacollection</li>';
-							if (d[4]) {
-								dlg += '<li class="kmltree-metadata-unpublish"><img style="vertical-align: middle;" src="../img/gnome/emblem-unreadable.png"></img>Withdraw publication</li>';
-							} else {
-								dlg += '<li class="kmltree-metadata-publish"><img style="vertical-align: middle;" src="../img/gnome/share.png"></img>Publish datacollection</li>';
-							dlg += '</ul></div>';
-							dlg = $(dlg).appendTo('body');
-							$(dlg).dialog({
-								create: function() {
-									$(dlg).find('li.kmltree-metadata-delete').bind('click', function() {
-										if (confirm('Really delete spatial data set?')) {
-											$.ajax({
-												type: 'post',
-												url: '../php/mb_delete_local_data.php',
-												data: {
-													id: id
-													if (arguments[1] == 'success') {
-														alert('Deleting local data was succesfull');
-														$('#mySpatialData').dialog('destroy');
-														$($addButton).trigger('click');
-													} else {
-														alert('Problem when deleting local data');
-									$(dlg).find('li.kmltree-metadata-unpublish').bind('click', function() {
-										if (confirm('Really unpublish spatial data set?')) {
-											$.ajax({
-												url: '../php/mb_unpublish_wmc.php',
-												type: 'POST',
-												data: {
-													wmc_serial_id: id
-									$(dlg).find('li.kmltree-metadata-publish').bind('click', function() {
-										// check if the user is public(guest-user) or not
-										var isPublic;
-										$.ajax({
-											url: '../php/mb_checkGuest.php',
-											type: 'POST',
-												isPublic = data;
-												if (isPublic == 1){
-													alert('To publicate a WMC is not allowed for the Guest-User!'+
-														  'If you want to use this function, please create an account.');
-													return false;
-												var publishDialog;
-												if ($('#wmcPublishConfirm').dialog('isOpen') === true) {
-													return;
-												} else {
-													publishDialog = $('<div id="wmcPublishConfirm"></div>').dialog({
-														title: "Publish datacollection " + d[1],
-														width: 373,
-														height: 'auto',
-														position: {
-															my: "center",
-															at: "top",
-															of: window
-															// $('#kml-load-tabs').tabs('destroy');
-															// $(this).html('').dialog('destroy');
-															$('#wmcPublishConfirm').dialog('destroy');
-															$('#wmcPublishConfirm').remove();
-													var publishDlgContent = "<div style='font-size:16px;text-align:justify'>If you want to publish a datacolletcion, you first have to choose a license" +
-														" under which you want to distribute your data. Actually only OpenData compatible" +
-														" licences are supported in this application. Please read the licenses carefully before" +
-														" you activate this option. All of your data will be available for each person in the web" +
-														" in different formats and may be redistributed freely without any copyright. </div>" +
-														"<table style='margin-top:7px' ><tr><th id = 'publishDenied'><img src='../img/button_digitize/geomRemove.png'></img>  No, I dont't want to publish</th>" +
-														"<th style='width:16%;visibility:hidden'>empty</th>" +
-														"<th id = 'publishConfirmed'><img src='../img/osgeo_graphics/check.png'></img>  Yes, I know what I am doing </th></tr></table>";
-													$(publishDialog).append(publishDlgContent);
-												$(publishDialog).find('#publishConfirmed').bind('click', function() {
-													$(publishDialog).dialog('close');
-													var chooseLicenseDialog = $('<div id="chooseLicenseDialog"></div>').dialog({
-														title: "Choose OpenData license for datacollection " + d[1],
-														width: 720,
-														height: 150,
-														position: {
-															my: "center",
-															at: "top",
-															of: window
-															$('#chooseLicenseDialog').dialog('destroy');
-															$('#chooseLicenseDialog').remove();
-													var chooseLicenseDlgCont = "<div><table id='licenseTbl'style='border-collapse: collapse'>" +
-														"<tr><th>Lizenz</th>" +
-														"<th>Logo</th><th>Beschreibung</th><th>Opendata</th></tr>" +
-														"<tr><td><select id='licenseChooser name='license'>" +
-														"</select></td>" +
-														"<td id='licenseImg'></td>" +
-														"<td id='licenseDescription'></td>" +
-														"<td id='licenseOpen' nowrap></td></tr>" +
-														"<tr id='submitLicense' ><td style='border:none;cursor:pointer; nowrap'><img src='../img/osgeo_graphics/check.png' style='margin-top:10px'/> <span>Publish data</span></td></tr>" +
-														"</table></div>";
-													//  add options for the select box
-													$(chooseLicenseDialog).append(chooseLicenseDlgCont);
-													$.ajax({
-														url: '../php/mb_publish_wmc.php',
-														type: 'POST',
-														data: {
-															wmc_serial_id: id,
-															mode: 'getAllLicencesMode',
-															license: 'empty',
-															openData_only: options.openData_only,
-															for (var i = 0; i < data.length; i++) {
-																$('#licenseTbl select').append("<option>" + data[i].name + "</option>");
-													$.ajax({
-														type: 'POST',
-														data: {
-															mode: 'getLicenseMode',
-															license: 'cc-by'
-															$('#licenseImg').html('<img src="' + data.symbollink + '" />');
-															$('#licenseDescription').html('<a href="' + data.description + '" />' + data.description + '</a>');
-															if (data.isopen == 1) {
-																$('#licenseOpen').html('<img src="../img/od_80x15_blue.png" />');
-															} else {
-																$('#licenseOpen').html('<span>No OpenData</span>');
-													$('#licenseTbl select').bind('change', function(event) {
-														$('#licenseImg').html('');
-														$('#licenseDescription').html('');
-														$.ajax({
-															type: 'POST',
-															data: {
-																license: $('#licenseTbl select').val()
-																} else {
-													$('#submitLicense').bind('click', function(event) {
-														//save the license from the choosed wmc
-														$.ajax({
-															type: 'POST',
-															data: {
-																mode: 'saveLicenseMode',
-												$(publishDialog).find('#publishDenied').bind('click', function() {
-					// .bind('dblclick', function() {
-					//     $.ajax({
-					//         type: 'post',
-					//         url: '../php/mb_load_local_data.php',
-					//         data: {
-					//             id: id
-					//         success: function(data) {
-					//             var kml = $('#mapframe1').data('kml');
-					//             $.each(data, function(url, json) {
-					//                 kml.addLayer(url, json.data);
-					//             $(dlg).dialog('destroy');
-					var allRows = $('#kml-from-wmc').find('tr');
-					$.each(allRows, function(index, val) {
-						if ( parseInt($(val).find('td:last').html()) ===  parseInt(Mapbender.userId)) {
-							$(val).css('background-color','rgb(146, 232, 183)');
-			$('#kml-load-tabs').tabs();
-			$('#kml-load-tabs').find('button.add').bind('click', function() {
-				$('#mapframe1').kml({ //TODO: what is happening?
-					url: $('#kml-load-tabs').find('.kmlurl').val()
-			$('#kml-load-tabs').find('button.add-kml').bind('click', function() {
-				var title = $('#kml-load-tabs input[name="kml-new-title"]').val();
-				var version = 'v1'
-				if (title == '') {
-					return;
-				kml.addLayer(title, {
-					uuid: UUID.genV4().toString(),
-					created: new Date().toISOString(),
-					title: title,
-					updated: new Date().toISOString(),
-					version: version,
-					type: 'FeatureCollection',
-					features: []
-			var ifr = $('iframe[name="kml-upload-target"]')[0];
-			var onloadfun = function() {
-				ifr.onload = null;
-				var txt = $(this).contents().find('pre').text(); // result von uploadKML.php
-				var data;
-				try {
-					data = JSON.parse(txt);
-				} catch (e) {
-					var xml = new DOMParser().parseFromString(txt, 'application/xml');
-					data = toGeoJSON.gpx(xml);
-				var name;
-				// check the features for properties
-				data = setFeatureAttr(data);
-				if (data.hasOwnProperty('title')) {
-					name = data['title'];
-					kml.addLayer(name, data);
-				} else {
-					name = $('#kml-from-upload input[type="file"]').val();
-					// test.replace(/\\/g,"/").split("/")
-					if (name.replace(/\\/g, "/").split("/")) {
-						// name = name.match(/[\\]([^\\]+)/g);
-						name = name.replace(/\\/g, "/").split("/");
-					name = name[name.length - 1];
-			$('#kml-from-upload form').bind('submit', function() {
-				if ( $( "#kml-from-upload > form > input[type='file'] " ).val() === "") {
-					return;
-				ifr.onload = onloadfun;
-	$KMLfolder.find('ul').before(selectButton);
-	$KMLfolder.find("ul").before($addButton);
-	var btn = new Mapbender.Button({
-		domElement: selectButton[0],
-		over: '../img/osgeo_graphics/geosilk/cursor_selected.png',
-		on: '../img/osgeo_graphics/geosilk/cursor_selected.png',
-		off: '../img/osgeo_graphics/geosilk/cursor.png',
-		name: 'toggle-select-features',
-		go: function() {
-			kml.setQueriedLayer(true);
-		stop: function() {
-			kml.setQueriedLayer(false);
-	o.$target.bind('kml:loaded', function(e, obj) {
-		var checked = obj.display ? 'checked="checked"' : '';
-		title = obj.url;
-		if (obj.refreshing) {
-			$KMLfolder.find('ul li[title="' + title + '"]').remove();
-		abbrevTitle = title.length < 20 ? title : title.substr(0, 17) + "...";
-		$kmlEntry = $('<li title="' + title + '" class="open"><button class="digitize-menu-arrow"></button><button class="toggle" name="toggle" value="toggle" ></button> <input type="checkbox"' + checked + '/><a href="#">' + abbrevTitle + '</a></li>');
-		$KMLfolder.children("ul").append($kmlEntry);
-		$kmlEntry.find("a").bind("click", (function(url) {
-			return function() {
-				$('#mapframe1').data('kml').zoomToLayer(url);
-		})(obj.url));
-		//@TODO: add default icon for points,polygons and linestrings on import
-		$featureList = $("<ul />");
-		$kmlEntry.append($featureList);
-		var pointCount = 1;
-		var polygonCount = 1;
-		var linestringCount = 1;
-		for (var i = obj.data.features.length - 1; i >= 0; --i) { //FIXME: for feature without the "type: FeatureCollection ",change functionallity: if (obj.data.type == "Feature") ...
-			var multi = obj.data.features[i].geometry.type.match(/^Multi/i);
-			var toggle = '';
-			if (multi) {
-				toggle = '<button class="toggle" name="toggle" value="toggle"></button>';
-			if (obj.data.features[i].properties.name) {
-				title = obj.data.features[i].properties.name;
-			} else if (obj.data.features[i].properties.title) {
-				title = obj.data.features[i].properties.title;
-			} else {
-				switch (obj.data.features[i].geometry.type){
-					case 'Point':
-						title = 'point_'+pointCount;
-						pointCount += 1;
-						break;
-					case 'Polygon':
-						title = 'polygon_'+polygonCount;
-						polygonCount += 1;
-						break;
-					case 'LineString':
-						title = 'linestring_'+linestringCount;
-						linestringCount += 1;
-						break;
-				// title = 'Title undefined';
-			// title = obj.data.features[i].properties.name;
-			var displ = obj.data.features[i].display === true || obj.data.features[i].display === undefined;
-			$feature = $('<li idx="' + i + '" title="' + title + '"><button class="digitize-menu-arrow"></button>' + toggle + '<input type="checkbox" ' + (displ ? 'checked="checked"' : '') + '/><div class="style-preview" style="width: 20px; height: 20px; display: inline;"></div><a href="#" >' + abbrevTitle + '</a></li>');
-			$featureList.append($feature);
-			var preview = $feature.find('.style-preview').get(0);
-			$('#mapframe1').data('kml').renderPreview(obj.data.features[i], preview, 20);
-			$feature.bind('mouseout', (function(jsonFeature) {
-					var map = o.$target.mapbender();
-					var g = new GeometryArray();
-					g.importGeoJSON(jsonFeature, false);
-					var feature = g.get(0);
-					if (feature.geomType != "point") {
-						var me = $kmlTree.mapbender();
-						me.resultHighlight.clean();
-						me.resultHighlight.paint();
-			})(obj.data.features[i]));
-			$feature.bind('mouseover', (function(jsonFeature) {
-						feature = feature.getBBox4();
-						me.resultHighlight = new Highlight(
-							[o.target],
-							"KmlTreeHighlight", {
-								"position": "absolute",
-								"top": "0px",
-								"left": "0px",
-								"z-index": 100
-							2);
-						me.resultHighlight.add(feature, "#00ff00");
-					} else if (feature.geomType == "point") {
-		$('button.digitize-layer', $kmlEntry).bind('click', function() {
-			var active = $(this).toggleClass('active').hasClass('active');
-			if (active) {
-				$(this).parent().siblings().find('button.digitize-layer').removeClass('active');
-		$('#kmlTree > li > ul').sortable({
-			update: function() {
-				var urls = [];
-				$(this).children('li[title]').each(function(k, v) {
-					urls.push($(this).attr('title'));
-				kml.setOrder(urls);
-		$('#kmlTree > li > ul > li > ul').sortable({
-			update: function(evt, data) {
-				var url = $(this).parent().attr('title');
-				var ids = [];
-				var i = $(this).children().length;;
-				$.each($(this).children(), function(k, v) {
-					ids.push($(v).attr('idx'));
-					$(v).attr('idx', --i);
-				kml.reorderFeatures(url, ids.reverse());
-		$('input[type="checkbox"]', $kmlEntry).bind('click', function() {
-			var idx = $(this).parent().attr('idx');
-			if (idx === undefined) {
-				if ($(this).attr('checked')) {
-					o.$target.kml('show', obj.url);
-				} else {
-					o.$target.kml('hide', obj.url);
-			} else {
-					kml.showFeature(obj.url, idx);
-				} else {
-					kml.hideFeature(obj.url, idx);
-		$("button.toggle", $kmlEntry).bind('click', function() {
-			if ($(this).parent().hasClass("open")) {
-				$(this).parent().removeClass("open");
-				$(this).parent().addClass("closed");
-			} else {
-				$(this).parent().removeClass("closed");
-				$(this).parent().addClass("open");
-			// IE8 workaround to make style previews visible...
-			$(this).parent().find('ul.ui-sortable li .rvml').removeClass('rvml').addClass('rvml');
-		$('#tabs_kmlTree').bind('click', function() {
-			window.setTimeout(function() {
-				$('#kmlTree').find('ul.ui-sortable li .rvml').removeClass('rvml').addClass('rvml');
-			}, 1000);
-	var setFeatureAttr = function(data) {
-		var simpleStyleDefaults = {
-			"title": "",
-			"description": "",
-			"marker-size": "medium",
-			"marker-symbol": "",
-			"marker-color": "7e7e7e",
-			"stroke": "#555555",
-			"stroke-opacity": 1.0,
-			"stroke-width": 2,
-			"fill": "#555555",
-			"fill-opacity": 0.5
-		if (data.type == 'Feature') {
-			if (Object.getOwnPropertyNames(data.properties).length === 0 || data.properties === null) {
-				data.properties = simplyStyleDefaults;
-			} else {
-				$.each(simpleStyleDefaults, function(index, val) {
-					if (!data.properties.hasOwnProperty(index)) {
-						data.properties[index] = value;
-		} else if (data.type == 'FeatureCollection') {
-			// get all features in the featureCollection and set the default properties if they are not set
-			$.each(data.features, function(index, val) {
-				$.each(simpleStyleDefaults, function(prop, propVal) {
-					if (!val.properties.hasOwnProperty(prop)) {
-						//TODO: get index in this scope
-						data.features[index].properties[prop] = propVal;
-		return data;
-Mapbender.events.init.register(function() {
-	$kmlTree.mapbender(new KmlTree(options));
More information about the Mapbender_commits mailing list
