[Mapbender-commits] r9217 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Jun 19 04:42:41 PDT 2015
Author: armin11
Date: 2015-06-19 04:42:40 -0700 (Fri, 19 Jun 2015)
New Revision: 9217
   trunk/mapbender/http/php/mod_callMetadata.php
   trunk/mapbender/http/php/mod_savewmc_server.php
store wmc to apc on demand
Modified: trunk/mapbender/http/php/mod_callMetadata.php
--- trunk/mapbender/http/php/mod_callMetadata.php	2015-06-19 11:42:20 UTC (rev 9216)
+++ trunk/mapbender/http/php/mod_callMetadata.php	2015-06-19 11:42:40 UTC (rev 9217)
@@ -48,8 +48,12 @@
 $preDefinedMaxResults = array(5,10,15,20,25,30);
 $searchEPSG = "EPSG:31466";
 $classJSON = new Mapbender_JSON;
-#$tempFolder = "/tmp";
-$tempFolder = TMPDIR;
+if (defined('ABSOLUTE_TMPDIR')){
+	$tempFolder = ABSOLUTE_TMPDIR;
+} else {
+	$tempFolder = TMPDIR;
 $orderBy = "rank"; //rank or title or id or date
 $hostName = $_SERVER['HTTP_HOST'];
 $headers = apache_request_headers();
@@ -894,7 +898,9 @@
 if ($resultTarget == 'file' or $resultTarget == 'webclient') {
 	$filename = $tempFolder."/".$searchId."_filter.json";
-	if (file_exists($filename)) {
+	$admin = new administration();
+	$admin->putToStorage($filename, $queryFilter, TMP_SEARCH_RESULT_STORAGE, TMP_SEARCH_RESULT_MAX_AGE);
+	/*if (file_exists($filename)) {
     		$e = new mb_notice("php/callMetdata.php: The file $filename exists - it will not be overwritten!");
 	} else {
@@ -905,7 +911,7 @@
 		} else {
 		$e = new mb_notice("php/callMetdata.php: cannot create filter_file!");
 //function to transpose a matrix - sometimes needed to do an array search
@@ -979,7 +985,7 @@
 //call class_metadata - in case of file for all requested resources, in case of web only for one resource - cause there are different result files
 if ($resultTarget == 'file') {
 	for($i=0; $i<count($searchResources);$i++){
-		$str = "nohup php5 /data/mapbender/http/php/mod_metadataWrite.php ";
+		/*$str = "nohup php5 /data/mapbender/http/php/mod_metadataWrite.php ";
 		$str .= "'".$userId."' ";
 		$str .= "'".$searchId."' ";
 		$str .= "'".$searchText."' ";
@@ -1008,7 +1014,8 @@
 		$str .= "'".$restrictToOpenData."' ";
 		$str .= " & ";
 		$e = new mb_notice($str);
-		exec($str);
+		exec($str);*/
+		$metadata = new searchMetadata($userId, $searchId, $searchText, $registratingDepartments, $isoCategories, $inspireThemes, $timeBegin, $timeEnd, $regTimeBegin, $regTimeEnd, $maxResults, $searchBbox, $searchTypeBbox, $accessRestrictions, $languageCode, $searchEPSG, $searchResources[$i], $searchPages[$i], $outputFormat, $resultTarget, $searchURL, $customCategories, $hostName, $orderBy, $resourceIds, $restrictToOpenData, $originFromHeader);
 if ($resultTarget == 'web' or $resultTarget == 'debug' or $resultTarget == 'webclient') {
Modified: trunk/mapbender/http/php/mod_savewmc_server.php
--- trunk/mapbender/http/php/mod_savewmc_server.php	2015-06-19 11:42:20 UTC (rev 9216)
+++ trunk/mapbender/http/php/mod_savewmc_server.php	2015-06-19 11:42:40 UTC (rev 9217)
@@ -12,57 +12,9 @@
 require_once(dirname(__FILE__)."/../classes/class_wmc.php");
 require_once(dirname(__FILE__)."/../classes/class_json.php");
 require_once(dirname(__FILE__)."/../classes/class_lzw_decompress.php");
-require_once(dirname(__FILE__)."/../classes/class_cache.php");
+//require_once(dirname(__FILE__)."/../classes/class_cache.php");
+$admin = new administration();
-function putWmcToStorage($filename, $xml) {
-	switch (TMP_WMC_SAVE_STORAGE) {
-		case "memcache":
-			$memcache_obj = new Memcache;
-			if (defined("MEMCACHED_IP") && MEMCACHED_IP != "" && defined("MEMCACHED_PORT") && MEMCACHED_PORT != "") {
-				$memcache_obj->connect(MEMCACHED_IP, MEMCACHED_PORT);
-			} else {
-				//use standard options
-				$memcache_obj->connect('localhost', 11211);
-			new mb_notice("wmc sessions stored via memcache");
-			$memcache_obj->set($filename, $xml, 0, TMP_WMC_MAX_AGE);
-			$memcache_obj->close();
-			return true;
-		break;
-		case "memcached":
-			$memcached_obj = new Memcached;
-				$memcached_obj->addServer(MEMCACHED_IP, MEMCACHED_PORT);
-			} else {
-				$memcached_obj->addServer('localhost', 11211);
-			new mb_notice("wmc stored via memcacheD");
-			return $memcached_obj->set($filename, $xml, TMP_WMC_MAX_AGE);
-			//$memcached_obj->quit();
-			return true;
-		break;
-		case "cache":
-			$cache = new Cache();
-			if ($cache->isActive) {
-				if ($cache->cachedVariableExists($filename)) {
-					$cache->cachedVariableDelete($filename);
-				return $cache->cachedVariableAdd($filename,$xml);
-				new mb_notice("wmc stored via cache");
-			} else {
-				return false;
-		break;
-		case "file":
-			file_put_contents($filename, $xml);
-		break;
-		default:
-		break;
 $ajaxResponse = new AjaxResponse($_POST);
 if($ajaxResponse->getMethod() != "saveWMC") {
 	$ajaxResponse->setSuccess(false);
@@ -116,7 +68,8 @@
 	$time_start = microtime();
-	putWmcToStorage($filename, $wmc->xml);
+	$wmcXml = $wmc->xml;
+	$admin->putToStorage($filename, $wmcXml, TMP_WMC_SAVE_STORAGE, TMP_WMC_MAX_AGE);
 	$time_end = microtime();
 	$timediff = $time_end - $time_start;
 	$e = new mb_notice('mod_savewmc_server.php: time to save wmc to storage: '.$timediff. '('.TMP_WMC_SAVE_STORAGE.')');
@@ -160,14 +113,14 @@
 		$wmc->wmc_srs	  = $map->epsg;
 	// make a keyword array here
-    $kwds = explode(",",$attributes->keywords);
-    $wmckwds = $wmc->keyword;
-    if(is_array($wmckwds)) {
-        foreach ($wmckwds as &$val) {
-            $val = trim($val);
-    $wmc->keyword = $wmckwds;
+    	$kwds = explode(",",$attributes->keywords);
+    	$wmckwds = $wmc->keyword;
+   	 if(is_array($wmckwds)) {
+       	 	foreach ($wmckwds as &$val) {
+            		$val = trim($val);
+    	$wmc->keyword = $wmckwds;
 	$wmc->wmc_keyword = $kwds;
 	$wmc->wmc_abstract = $attributes->abstract;
More information about the Mapbender_commits mailing list
