[Mapbender-commits] r9222 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Mon Jun 22 11:45:45 PDT 2015
Author: armin11
Date: 2015-06-22 11:45:45 -0700 (Mon, 22 Jun 2015)
New Revision: 9222
trunk/mapbender/http/classes/class_administration.php
Bugfix cache management
Modified: trunk/mapbender/http/classes/class_administration.php
--- trunk/mapbender/http/classes/class_administration.php 2015-06-22 15:51:37 UTC (rev 9221)
+++ trunk/mapbender/http/classes/class_administration.php 2015-06-22 18:45:45 UTC (rev 9222)
@@ -848,7 +848,7 @@
return $layer_id_array;
- function getAllLayerByWms($wms_id){
+ function getAllLayerByWms($wms_id){
$sql = "SELECT layer_id from layer WHERE fkey_wms_id = $1 GROUP BY layer_id, layer_title ORDER BY layer_title";
$v = array($wms_id);
$t = array('i');
@@ -1565,6 +1565,118 @@
+ function putToStorage($filename, $content, $cacheType, $maxAge) {
+ switch ($cacheType) {
+ case "memcache":
+ $filename = md5($filename);
+ $memcache_obj = new Memcache;
+ if (defined("MEMCACHED_IP") && MEMCACHED_IP != "" && defined("MEMCACHED_PORT") && MEMCACHED_PORT != "") {
+ $memcache_obj->connect(MEMCACHED_IP, MEMCACHED_PORT);
+ } else {
+ //use standard options
+ $memcache_obj->connect('localhost', 11211);
+ //check for existence
+ $objectExists = $memcache_obj->get($filename);
+ if ($objectExists == false) {
+ $memcache_obj->add($filename, $content, false, $maxAge);
+ new mb_notice("add object");
+ } else {
+ $memcache_obj->replace($filename, $content, false, $maxAge);
+ new mb_notice("replace object");
+ $memcache_obj->close();
+ return true;
+ break;
+ case "memcached":
+ $memcached_obj = new Memcached;
+ $memcached_obj->addServer(MEMCACHED_IP, MEMCACHED_PORT);
+ } else {
+ $memcached_obj->addServer('localhost', 11211);
+ new mb_notice("file stored via memcacheD");
+ $memcached_obj->set($filename, $content, $maxAge);
+ //$memcached_obj->quit();
+ return true;
+ break;
+ case "cache":
+ $cache = new Cache();
+ if ($cache->isActive) {
+ if ($cache->cachedVariableExists($filename)) {
+ $cache->cachedVariableDelete($filename);
+ return $cache->cachedVariableAdd($filename, $content ,$maxAge);
+ } else {
+ return false;
+ break;
+ case "file":
+ file_put_contents($filename, $content);
+ break;
+ default:
+ break;
+ function getFromStorage($filename, $cacheType) {
+ case "memcache":
+ } else {
+ $content = $memcache_obj->get($filename);
+ return $content;
+ break;
+ case "memcached":
+ } else {
+ new mb_notice("content via memcacheD");
+ $content = $memcached_obj->get($filename);
+ return $content;
+ break;
+ case "cache":
+ if ($cache->isActive && $cache->cachedVariableExists($filename)) {
+ $content = $cache->cachedVariableFetch($filename);
+ return $content;
+ } else {
+ return false;
+ break;
+ case "file":
+ $content = file_get_contents($filename);
+ return $content;
+ break;
+ default:
+ return $content;
+ break;
function is_utf8_string($string) {
if (is_array($string))
@@ -1692,117 +1804,6 @@
- function putToStorage($filename, $content, $cacheType, $maxAge) {
- switch ($cacheType) {
- case "memcache":
- $filename = md5($filename);
- $memcache_obj = new Memcache;
- if (defined("MEMCACHED_IP") && MEMCACHED_IP != "" && defined("MEMCACHED_PORT") && MEMCACHED_PORT != "") {
- $memcache_obj->connect(MEMCACHED_IP, MEMCACHED_PORT);
- } else {
- //use standard options
- $memcache_obj->connect('localhost', 11211);
- //check for existence
- $objectExists = $memcache_obj->get($filename);
- if ($objectExists == false) {
- $memcache_obj->add($filename, $content, false, $maxAge);
- new mb_notice("add object");
- } else {
- $memcache_obj->replace($filename, $content, false, $maxAge);
- new mb_notice("replace object");
- $memcache_obj->close();
- return true;
- break;
- case "memcached":
- $memcached_obj = new Memcached;
- $memcached_obj->addServer(MEMCACHED_IP, MEMCACHED_PORT);
- } else {
- $memcached_obj->addServer('localhost', 11211);
- new mb_notice("file stored via memcacheD");
- $memcached_obj->set($filename, $content, $maxAge);
- //$memcached_obj->quit();
- return true;
- break;
- case "cache":
- $cache = new Cache();
- if ($cache->isActive) {
- if ($cache->cachedVariableExists($filename)) {
- $cache->cachedVariableDelete($filename);
- return $cache->cachedVariableAdd($filename, $content ,$maxAge);
- } else {
- return false;
- break;
- case "file":
- file_put_contents($filename, $content);
- break;
- default:
- break;
- function getFromStorage($filename, $cacheType) {
- case "memcache":
- } else {
- $content = $memcache_obj->get($filename);
- return $content;
- break;
- case "memcached":
- } else {
- new mb_notice("content via memcacheD");
- $content = $memcached_obj->get($filename);
- return $content;
- break;
- case "cache":
- if ($cache->isActive && $cache->cachedVariableExists($filename)) {
- $content = $cache->cachedVariableFetch($filename);
- return $content;
- } else {
- return false;
- break;
- case "file":
- $content = file_get_contents($filename);
- return $content;
- break;
- default:
- return $content;
- break;
More information about the Mapbender_commits
