[Mapbender-commits] r9226 - in trunk/mapbender/http: php plugins
svn_mapbender at osgeo.org
Wed Jun 24 04:40:17 PDT 2015
Author: syed
Date: 2015-06-24 04:40:17 -0700 (Wed, 24 Jun 2015)
New Revision: 9226
Added:
trunk/mapbender/http/php/transformPoint.php
trunk/mapbender/http/plugins/mb_digitize_widget.php
replace proj4js with a serverside script
Added: trunk/mapbender/http/php/transformPoint.php
--- trunk/mapbender/http/php/transformPoint.php (rev 0)
+++ trunk/mapbender/http/php/transformPoint.php 2015-06-24 11:40:17 UTC (rev 9226)
@@ -0,0 +1,61 @@
+<?php
+# http://www.mapbender.org/index.php/Administration
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+header("Content-Type: application/json");
+$point_pos = $_POST["point_pos"];
+$targetProj = json_decode($_POST["targetProj"], true);
+$currentProj = json_decode($_POST["currentProj"], true);
+// Return the multipoints and use it on the client-side
+try {
+ $multipoint = "";
+ $points_obj = json_decode($point_pos, true);
+ $last_item = end($points_obj);
+ foreach ($points_obj as $key => $value) {
+ $multipoint .= '(';
+ $multipoint .= $value["pos"]["x"];
+ $multipoint .= ' ';
+ $multipoint .= $value["pos"]["y"];
+ $multipoint .= '),';
+ $multipoint = 'MULTIPOINT (' . rtrim($multipoint, ',') . ')';
+ // var_dump($point_pos);die;
+ // die('<pre>' . print_r($multipoint, 1) . '</pre>');
+ $targetProjSricCode = intval($targetProj["srsProjNumber"]);
+ $currentProjSricCode = intval($currentProj["srsProjNumber"]);
+ $sql = "SELECT ST_AsGeoJson(ST_Transform(ST_GeomFromText($1,$2),$3)) As target_geom";
+ $v = array($multipoint, intval($targetProjSricCode), intval($currentProjSricCode));
+ $t = array('s', 'i', 'i');
+ $res = db_prep_query($sql, $v, $t);
+ db_fetch_row($res);
+ $geom = db_result($res, 0, 'target_geom');
+ // @TODO: Test the sql
+ // die('<pre>' . print_r($geom, 1) . '</pre>');
+ echo($geom);
+ // $geom = json_decode(db_result($res, 0, 'geom'));
+ // $feat->geometry = $geom;
+ // transform point json to wkt MULTIPOINT
+} catch (Exception $e) {
+ echo($e);
+ die;
Modified: trunk/mapbender/http/plugins/mb_digitize_widget.php
--- trunk/mapbender/http/plugins/mb_digitize_widget.php 2015-06-22 20:09:25 UTC (rev 9225)
+++ trunk/mapbender/http/plugins/mb_digitize_widget.php 2015-06-24 11:40:17 UTC (rev 9226)
@@ -68,22 +68,22 @@
* http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
-var $digitize = $(this);
+ var $digitize = $(this);
-var DigitizeApi = function (o) {
+ var DigitizeApi = function (o) {
var digitizeHtml = '<div title="<?php echo _mb("Sketch");?>">' +
- '<div title="<?php echo _mb("Digitize new point");?>"class="digitize-image digitize-point"></div>' +
- '<div title="<?php echo _mb("Digitize new line");?>"class="digitize-image digitize-line"></div>' +
- '<div title="<?php echo _mb("Digitize new polygon");?>"class="digitize-image digitize-polygon"></div>' +
- '<div title="<?php echo _mb("Attributes of collection");?>"class="digitize-image digitize-attributes editFeatureCollection"></div>' +
- '</div>';
+ '<div title="<?php echo _mb("Digitize new point");?>"class="digitize-image digitize-point"></div>' +
+ '<div title="<?php echo _mb("Digitize new line");?>"class="digitize-image digitize-line"></div>' +
+ '<div title="<?php echo _mb("Digitize new polygon");?>"class="digitize-image digitize-polygon"></div>' +
+ '<div title="<?php echo _mb("Attributes of collection");?>"class="digitize-image digitize-attributes editFeatureCollection"></div>' +
+ '</div>';
var editHtml = '<div title="<?php echo _mb("Edit feature");?>">' +
- '<div class="digitize-preview"></div>' +
- '<span>my polygon</span><br></br>' +
- '<div title="<?php echo _mb("Edit style");?>" class="digitize-image digitize-style"></div>' +
- '<div title="<?php echo _mb("Edit attributes");?>" class="digitize-image digitize-attributes"></div>' +
+ '<div class="digitize-preview"></div>' +
+ '<span>my polygon</span><br></br>' +
+ '<div title="<?php echo _mb("Edit style");?>" class="digitize-image digitize-style"></div>' +
+ '<div title="<?php echo _mb("Edit attributes");?>" class="digitize-image digitize-attributes"></div>' +
// '<div class="digitize-image digitize-add"></div>' +
'<div title="<?php echo _mb("Delete feature");?>" class="digitize-image digitize-remove"></div>' +
'<div title="<?php echo _mb("Edit geometry");?>" class="digitize-image digitize-pencil"></div>' +
@@ -95,7 +95,7 @@
'<div title="<?php echo _mb("Export geometry");?>" class="digitize-image digitize-export digitize-export-edit-dialog"></div>' +
'</div>';
- var editAttributesHtml = '<div title="<?php echo _mb("Feature attributes");?>">' +
+ var editAttributesHtml = '<div title="<?php echo _mb("Feature attributes");?>">' +
'<div class="digitize-image digitize-style"></div>' +
'<div class="digitize-preview"></div><br></br>' +
// '<div class="attrAccordion">' +
@@ -106,7 +106,7 @@
'<div title="<?php echo _mb("Save object");?>" class="digitize-image digitize-save"></div>' +
'</div>';
- var tableEditAttributesHtml = '<div title="<?php echo _mb("Feature attributes");?>">' +
+ var tableEditAttributesHtml = '<div title="<?php echo _mb("Feature attributes");?>">' +
@@ -115,7 +115,7 @@
'</div>';
- var editStyleHtml = '<div title="<?php echo _mb("Edit style");?>">' +
+ var editStyleHtml = '<div title="<?php echo _mb("Edit style");?>">' +
'<form id="digitize-marker-form"><label><input type="radio" name="marker-type" checked="checked" value="predefined"><?php echo _mb("Predefined");?></input></label>' +
'<label><input type="radio" name="marker-type" value="custom"><?php echo _mb("Custom");?></input></label></form>' +
@@ -139,7 +139,7 @@
'<button name="digitize-reset-style"><?php echo _mb("Reset");?></button>' +
'</div>';
- var folderMenu = '<ul class="digitize-contextmenu">' +
+ var folderMenu = '<ul class="digitize-contextmenu">' +
'<li><div class="digitize-image digitize-pencil"></div><?php echo _mb("Edit");?></li>' +
'<li><div class="digitize-image digitize-zoomto"></div><?php echo _mb("Zoom to");?></li>' +
'<li><div class="digitize-image digitize-add"></div><?php echo _mb("New");?></li>' +
@@ -148,7 +148,7 @@
'<li><div class="digitize-image digitize-close"></div><?php echo _mb("Close");?></li>' +
'</ul>';
- var geomMenu = '<ul class="digitize-contextmenu">' +
+ var geomMenu = '<ul class="digitize-contextmenu">' +
// '<li><div class="digitize-image digitize-add"></div><?php echo _mb("New");?></li>' +
@@ -158,7 +158,7 @@
'</ul>';
- var geomPartMenu = '<ul class="digitize-contextmenu">' +
+ var geomPartMenu = '<ul class="digitize-contextmenu">' +
'<li><div class="digitize-image digitize-export"></div><?php echo _mb("Export");?></li>' +
@@ -166,16 +166,16 @@
'</ul>';
- var exportHtml = '<div id="export-dialog" title="<?php echo _mb("Export my features");?>">'
- + '<form>'
- + '<label class="export-format-kml">KML<input type="radio" name="export-format" value="kml" checked="checked"></input></label>'
- + '<label class="export-format-gpx">GPX<input type="radio" name="export-format" value="gpx"></input></label>'
- + '<label class="export-format-geojson">geoJSON<input type="radio" name="export-format" value="geojson"></input></label><br></br>'
- + '<a download="myfeatures.kml" href="#" class="digitize-image digitize-export" style="float: left;"></a>'
- + '</form>'
- + '</div>';
+ var exportHtml = '<div id="export-dialog" title="<?php echo _mb("Export my features");?>">'
+ + '<form>'
+ + '<label class="export-format-kml">KML<input type="radio" name="export-format" value="kml" checked="checked"></input></label>'
+ + '<label class="export-format-gpx">GPX<input type="radio" name="export-format" value="gpx"></input></label>'
+ + '<label class="export-format-geojson">geoJSON<input type="radio" name="export-format" value="geojson"></input></label><br></br>'
+ + '<a download="myfeatures.kml" href="#" class="digitize-image digitize-export" style="float: left;"></a>'
+ + '</form>'
+ + '</div>';
- var digitizeDialog,
+ var digitizeDialog,
editDialog,
attributesDialog,
editStyleDialog,
@@ -188,42 +188,42 @@
editedFeature = null,
status = 'none';
- var btnelem = $('body').append('<img id="kml-digitizer-pseudo" style="display: none;"></img>').find('#kml-digitizer-pseudo');
+ var btnelem = $('body').append('<img id="kml-digitizer-pseudo" style="display: none;"></img>').find('#kml-digitizer-pseudo');
- var btn = new Mapbender.Button({
- domElement: btnelem[0],
- name: 'kml-digitizer-pseudo',
- go: $.noop,
- stop: function() {
- $('#mapframe1').data('mb_digitize').isPaused = true;
+ var btn = new Mapbender.Button({
+ domElement: btnelem[0],
+ name: 'kml-digitizer-pseudo',
+ go: $.noop,
+ stop: function() {
+ $('#mapframe1').data('mb_digitize').isPaused = true;
- $('body > img').bind('click', function() {
- if(!inProgress) {
- return;
- var active = $(this)[0].status == 1 && $(this)[0] != btnelem;
+ $('body > img').bind('click', function() {
+ if(!inProgress) {
+ return;
+ var active = $(this)[0].status == 1 && $(this)[0] != btnelem;
- var dig = $('#mapframe1').data('mb_digitize');
+ var dig = $('#mapframe1').data('mb_digitize');
- if(active && dig) {
- dig.isPaused = false;
- var create = function() {
- $.ajax({
- url: '../extensions/makiicons/selection.json',
- type: 'GET',
- dataType: 'json',
- success: function(data) {
- icons = data;
- var kml = $('#mapframe1').data('kml');
- kml.icons = icons;
+ if(active && dig) {
+ dig.isPaused = false;
+ var create = function() {
+ $.ajax({
+ url: '../extensions/makiicons/selection.json',
+ type: 'GET',
+ dataType: 'json',
+ success: function(data) {
+ icons = data;
+ var kml = $('#mapframe1').data('kml');
+ kml.icons = icons;
// Initialise digitize dialog
@@ -310,7 +310,7 @@
var url = item.url;
$('li[title="' + url + '"] > a').die('contextmenu').live('contextmenu', contextmenuLayer);
$('li[title="' + url + '"] > ul > li').die('contextmenu').live('contextmenu', contextmenuObject)
- .die('click').live('click', function(e) {
+ .die('click').live('click', function(e) {
if($(e.srcElement).is('button,input')) {
return;
@@ -323,15 +323,35 @@
$('li[title="' + url + '"] > .digitize-menu-arrow').die('click').live('click', contextmenuLayer);
$('li[title="' + url + '"] > ul > li > .digitize-menu-arrow').die('click').live('click', contextmenuObject);
- var exportItem = function(data) {
- var dlg = $(exportHtml).dialog({ width: 330, height: 165 });
- $(dlg).find('input').bind('change', function() {
- if(!$(this).is(':checked')) {
- return;
- var fmt = $(this).val();
+var exportItem = function(data) {
+ var dlg = $(exportHtml).dialog({ width: 330, height: 165 });
+ $(dlg).find('input').bind('change', function() {
+ if(!$(this).is(':checked')) {
+ return;
+ var fmt = $(this).val();
+ var url;
+ if(fmt === 'kml') {
+ url = tokml(data, {simplestyle: true});
+ if(fmt === 'gpx') {
+ url = togpx(data, {simplestyle: true});
+ if(fmt === 'geojson') {
+ url = JSON.stringify(data);
+ url = 'data:application/octet-stream,' + encodeURIComponent(url);
+ var lnk = $(dlg).find('.digitize-export')
+ .attr('download', 'myfeatures.' + fmt)
+ .attr('href', url);
+ }).change();
+ $(dlg).find('.digitize-export').bind('click', function() {
+ if(window.chrome) {
+ var fmt = $(dlg).find('input:checked').val();
var url;
if(fmt === 'kml') {
@@ -340,264 +360,244 @@
- url = JSON.stringify(data);
- url = 'data:application/octet-stream,' + encodeURIComponent(url);
+ if (data.type != "Feature") {
- var lnk = $(dlg).find('.digitize-export')
- .attr('download', 'myfeatures.' + fmt)
- .attr('href', url);
- }).change();
+ } else {
- $(dlg).find('.digitize-export').bind('click', function() {
- if(window.chrome) {
- var fmt = $(dlg).find('input:checked').val();
- var url;
- if(fmt === 'kml') {
- url = tokml(data, {simplestyle: true});
+ var newFeatureJson = $.extend(true, {}, data);
+ var jsonFeatureHeader = {"type": "FeatureCollection", "features": [newFeatureJson]};
+ url = JSON.stringify(jsonFeatureHeader);
- if(fmt === 'gpx') {
- url = togpx(data, {simplestyle: true});
- if(fmt === 'geojson') {
- if (data.type != "Feature") {
- } else {
- var newFeatureJson = $.extend(true, {}, data);
- var jsonFeatureHeader = {"type": "FeatureCollection", "features": [newFeatureJson]};
- url = JSON.stringify(jsonFeatureHeader);
+ var link = document.createElement("a");
+ link.setAttribute('download', 'myfeatures.' + fmt);
+ link.href = URL.createObjectURL(new Blob([url], {type: 'application/octet-stream'}));
+ link.click();
+ return false;
+ return undefined;
- var link = document.createElement("a");
- link.setAttribute('download', 'myfeatures.' + fmt);
- link.href = URL.createObjectURL(new Blob([url], {type: 'application/octet-stream'}));
- link.click();
+var editStyle = function($link, menu) {
+ var classPrefix = icons.preferences.fontPref.prefix,
+ iconList = [],
+ search = [];
- return false;
- return undefined;
+ $.each(icons.icons, function(i, v) {
+ iconList.push( classPrefix + v.properties.name );
- var editStyle = function($link, menu) {
- var classPrefix = icons.preferences.fontPref.prefix,
- iconList = [],
- search = [];
+ editStyleDialog.find('.digitize-style-predefined input[name="marker-symbol"]').fontIconPicker({source: iconList, hasSearch: false, emptyIcon: false});
- $.each(icons.icons, function(i, v) {
- iconList.push( classPrefix + v.properties.name );
+ return function() {
+ editStyleDialog.dialog('open');
+ var idx = $link.attr('idx');
+ var url = $link.parent().parent().attr('title');
+ var feature = kml._kmls[url].data.features[idx];
+ var isline = false;
+ var ispoint = false;
- editStyleDialog.find('.digitize-style-predefined input[name="marker-symbol"]').fontIconPicker({source: iconList, hasSearch: false, emptyIcon: false});
- return function() {
- editStyleDialog.dialog('open');
- var idx = $link.attr('idx');
- var url = $link.parent().parent().attr('title');
- var feature = kml._kmls[url].data.features[idx];
- var isline = false;
- var ispoint = false;
+ kml.zoomToFeature(url, idx);
+ if(feature.geometry.type.match(/point/i)) {
+ ispoint = true;
+ editStyleDialog.find('input[name*="fill"],input[name*="stroke"],.opacity-slider').parent().parent().css('display', 'none');
+ editStyleDialog.find('input[name*="marker"]').parent().parent().css('display', 'table-row');
+ if(feature.properties['marker-type'] === 'custom') {
+ editStyleDialog.find('.digitize-style-custom,form').css('display', 'block');
+ editStyleDialog.find('.digitize-style-predefined').css('display', 'none');
+ editStyleDialog.find('input[value="custom"]').attr('checked', 'checked');
+ } else {
+ editStyleDialog.find('.digitize-style-predefined,form').css('display', 'block');
+ editStyleDialog.find('.digitize-style-custom').css('display', 'none');
+ editStyleDialog.find('input[value="predefined"]').attr('checked', 'checked');
+ if(feature.geometry.type.match(/line/i)) {
+ isline = true;
+ editStyleDialog.find('input[name*="fill"],input[name*="marker"],.opacity-slider[data-name="fill-opacity"]').parent().parent().css('display', 'none');
+ editStyleDialog.find('input[name*="stroke"],.opacity-slider[data-name="stroke-opacity"]').parent().parent().css('display', 'table-row');
+ editStyleDialog.find('.digitize-style-custom').css('display', 'block');
+ editStyleDialog.find('.digitize-style-predefined,form').css('display', 'none');
+ if(feature.geometry.type.match(/polygon/i)) {
+ editStyleDialog.find('input[name*="fill"],input[name*="stroke"],.opacity-slider').parent().parent().css('display', 'table-row');
+ editStyleDialog.find('input[name*="marker"]').parent().parent().css('display', 'none');
- kml.zoomToFeature(url, idx);
+ $('input[value="predefined"]').bind('click', function() {
+ if($(this).val() == 'predefined') {
+ var cls = $('.digitize-style-predefined .selected-icon i').attr('class');
+ $('.digitize-style-predefined input[name="marker-symbol"]').val(cls).change();
- if(feature.geometry.type.match(/point/i)) {
- ispoint = true;
- editStyleDialog.find('input[name*="fill"],input[name*="stroke"],.opacity-slider').parent().parent().css('display', 'none');
- editStyleDialog.find('input[name*="marker"]').parent().parent().css('display', 'table-row');
- if(feature.properties['marker-type'] === 'custom') {
- editStyleDialog.find('.digitize-style-custom,form').css('display', 'block');
- editStyleDialog.find('.digitize-style-predefined').css('display', 'none');
- editStyleDialog.find('input[value="custom"]').attr('checked', 'checked');
- } else {
- editStyleDialog.find('.digitize-style-predefined,form').css('display', 'block');
- editStyleDialog.find('.digitize-style-custom').css('display', 'none');
- editStyleDialog.find('input[value="predefined"]').attr('checked', 'checked');
+ var preview = editStyleDialog.find('.digitize-preview');
+ preview.html('');
+ preview = preview.get(0);
+ kml.renderPreview(feature, preview);
+ $.each(feature.properties, function(k, v) {
+ if(editStyleDialog.find('input[name="' + k + '"]').is(':radio')) {
+ editStyleDialog.find('input[value="' + k + '"]').attr('checked', 'checked');
+ return;
- if(feature.geometry.type.match(/line/i)) {
- isline = true;
- editStyleDialog.find('input[name*="fill"],input[name*="marker"],.opacity-slider[data-name="fill-opacity"]').parent().parent().css('display', 'none');
- editStyleDialog.find('input[name*="stroke"],.opacity-slider[data-name="stroke-opacity"]').parent().parent().css('display', 'table-row');
- editStyleDialog.find('.digitize-style-custom').css('display', 'block');
- editStyleDialog.find('.digitize-style-predefined,form').css('display', 'none');
+ editStyleDialog.find('input[name="' + k + '"],select[name="' + k + '"]').val(v);
+ if(k === 'stroke-opacity') {
+ editStyleDialog.find('.opacity-slider[data-name="stroke-opacity"]').slider('value', v * 100);
- if(feature.geometry.type.match(/polygon/i)) {
- editStyleDialog.find('input[name*="fill"],input[name*="stroke"],.opacity-slider').parent().parent().css('display', 'table-row');
- editStyleDialog.find('input[name*="marker"]').parent().parent().css('display', 'none');
+ if(k === 'fill-opacity') {
+ editStyleDialog.find('.opacity-slider[data-name="fill-opacity"]').slider('value', v * 100);
+ if(k === 'marker-symbol' && feature.properties['marker-type'] === 'predefined') {
+ editStyleDialog.find('input[name="marker-symbol"]').val('icon-' + v + '-24');
- $('input[value="predefined"]').bind('click', function() {
- if($(this).val() == 'predefined') {
- var cls = $('.digitize-style-predefined .selected-icon i').attr('class');
- $('.digitize-style-predefined input[name="marker-symbol"]').val(cls).change();
+ editStyleDialog.find('form input').bind('change', function() {
+ editStyleDialog.find('.digitize-style-' + $(this).val()).css('display', 'block').siblings('table').css('display', 'none');
- var preview = editStyleDialog.find('.digitize-preview');
- preview.html('');
- preview = preview.get(0);
- kml.renderPreview(feature, preview);
- $.each(feature.properties, function(k, v) {
- if(editStyleDialog.find('input[name="' + k + '"]').is(':radio')) {
- editStyleDialog.find('input[value="' + k + '"]').attr('checked', 'checked');
- return;
- editStyleDialog.find('input[name="' + k + '"],select[name="' + k + '"]').val(v);
- if(k === 'stroke-opacity') {
- editStyleDialog.find('.opacity-slider[data-name="stroke-opacity"]').slider('value', v * 100);
- if(k === 'fill-opacity') {
- editStyleDialog.find('.opacity-slider[data-name="fill-opacity"]').slider('value', v * 100);
- if(k === 'marker-symbol' && feature.properties['marker-type'] === 'predefined') {
- editStyleDialog.find('input[name="marker-symbol"]').val('icon-' + v + '-24');
+ editStyleDialog.find('button[name="digitize-reset-style"]').bind('click', function() {
+ if(ispoint) {
+ editStyleDialog.find('.digitize-style-custom input[name="marker-symbol"]').val('../img/marker/red.png');
+ editStyleDialog.find('.digitize-style-custom input[name="marker-size"]').val(20);
+ editStyleDialog.find('.digitize-style-predefined input[name="marker-symbol"]').val('icon-airfield-24');
+ editStyleDialog.find('.digitize-style-predefined input[name="marker-size"]').val('medium');
+ editStyleDialog.find('.digitize-style-predefined input[name="marker-color"]').spectrum('set', 'white');
+ editStyleDialog.find('input[name="stroke"]').spectrum('set', '#555555');
+ editStyleDialog.find('.opacity-slider').slider('value', 100);
+ editStyleDialog.find('input[name="stroke-width"]').val(1);
+ editStyleDialog.find('input[name="fill"]').spectrum('set', '#555555');
- editStyleDialog.find('form input').bind('change', function() {
- editStyleDialog.find('.digitize-style-' + $(this).val()).css('display', 'block').siblings('table').css('display', 'none');
+editStyleDialog.find('input,select').bind('change', function() {
+ if(isline && $(this).attr('name').match(/fill/)) {
+ return;
- editStyleDialog.find('button[name="digitize-reset-style"]').bind('click', function() {
- if(ispoint) {
- editStyleDialog.find('.digitize-style-custom input[name="marker-symbol"]').val('../img/marker/red.png');
- editStyleDialog.find('.digitize-style-custom input[name="marker-size"]').val(20);
- editStyleDialog.find('.digitize-style-predefined input[name="marker-symbol"]').val('icon-airfield-24');
- editStyleDialog.find('.digitize-style-predefined input[name="marker-size"]').val('medium');
- editStyleDialog.find('.digitize-style-predefined input[name="marker-color"]').spectrum('set', 'white');
- editStyleDialog.find('input[name="stroke"]').spectrum('set', '#555555');
- editStyleDialog.find('.opacity-slider').slider('value', 100);
- editStyleDialog.find('input[name="stroke-width"]').val(1);
- editStyleDialog.find('input[name="fill"]').spectrum('set', '#555555');
+ if(!ispoint && $(this).attr('name').match(/marker/)) {
+ return;
- editStyleDialog.find('input,select').bind('change', function() {
- if(isline && $(this).attr('name').match(/fill/)) {
- return;
+ if($(this).attr('name') === 'stroke-width') {
+ var val = $(this).val();
+ if(!(!isNaN(parseFloat(val)) && isFinite(val)) || $(this).val() <= 0) {
+ $(this).css('background-color', 'red');
+ $(this).val(feature.properties['stroke-width']);
+ } else {
+ $(this).css('background-color', '');
- if(!ispoint && $(this).attr('name').match(/marker/)) {
- return;
+ feature.properties[$(this).attr('name')] = $(this).val();
- if($(this).attr('name') === 'stroke-width') {
- var val = $(this).val();
- if(!(!isNaN(parseFloat(val)) && isFinite(val)) || $(this).val() <= 0) {
- $(this).css('background-color', 'red');
- $(this).val(feature.properties['stroke-width']);
- } else {
- $(this).css('background-color', '');
+ if($(this).attr('name') === 'marker-symbol' && editStyleDialog.find('input[name="marker-type"]').val() == 'predefined') {
+ var m = $(this).val().match(/^icon-(.+)-24$/);
+ if(m) {
+ feature.properties['marker-symbol'] = m[1];
- feature.properties[$(this).attr('name')] = $(this).val();
+ kml.render();
+ var preview = editStyleDialog.find('.digitize-preview').html('').get(0);
+ preview = editDialog.find('.digitize-preview').html('').get(0);
+ preview = attributesDialog.find('.digitize-preview').html('').get(0);
+$('.opacity-slider').slider('option', 'change', function() {
+ if(isline && $(this).attr('data-name') === 'fill-opacity') {
+ return;
+ feature.properties[$(this).attr('data-name')] = $(this).slider('value') / 100;
+ kml.render();
+editStyleDialog.find('.digitize-save').bind('click', function() {
+ editStyleDialog.dialog('close');
+ feature.properties.updated = new Date().toISOString();
+ kml.refresh(url);
+editStyleDialog.find('input[name="fill"]').spectrum({showInput: true});
+editStyleDialog.find('input[name="stroke"]').spectrum({showInput: true});
+editStyleDialog.find('input[name="marker-color"]').spectrum({showInput: true});
+editStyleDialog.find('input').change();
+if(menu)
+ menu.menu('destroy').remove();
- if($(this).attr('name') === 'marker-symbol' && editStyleDialog.find('input[name="marker-type"]').val() == 'predefined') {
- var m = $(this).val().match(/^icon-(.+)-24$/);
- if(m) {
- feature.properties['marker-symbol'] = m[1];
- kml.render();
- var preview = editStyleDialog.find('.digitize-preview').html('').get(0);
- preview = editDialog.find('.digitize-preview').html('').get(0);
- preview = attributesDialog.find('.digitize-preview').html('').get(0);
- $('.opacity-slider').slider('option', 'change', function() {
- if(isline && $(this).attr('data-name') === 'fill-opacity') {
- return;
- feature.properties[$(this).attr('data-name')] = $(this).slider('value') / 100;
- kml.render();
- editStyleDialog.find('.digitize-save').bind('click', function() {
- editStyleDialog.dialog('close');
- feature.properties.updated = new Date().toISOString();
- kml.refresh(url);
- editStyleDialog.find('input[name="fill"]').spectrum({showInput: true});
- editStyleDialog.find('input[name="stroke"]').spectrum({showInput: true});
- editStyleDialog.find('input[name="marker-color"]').spectrum({showInput: true});
- editStyleDialog.find('input').change();
- if(menu)
- menu.menu('destroy').remove();
- var contextmenuObject = function() {
- var $link = $(this);
- if($link.attr('idx') === undefined) {
- $link = $link.parent();
- var menu = $(geomMenu);
- if ( $( '.digitize-contextmenu' ).length != 0 ) {
- return;
- $(document.body).append(menu);
- var pos = $link.offset();
- menu.css({position: 'absolute', top: pos.top, left: pos.left, width: "120px"}).menu()
- .children().addClass('ui-menu-item')
- .hover(function() {$(this).addClass('ui-state-hover'); },
- function() {$(this).removeClass('ui-state-hover'); });
- menu.children('li:has(.digitize-zoomto)').bind('click', function() {
- kml.zoomToFeature(url, $link.attr('idx'));
+var contextmenuObject = function() {
+ var $link = $(this);
+ if($link.attr('idx') === undefined) {
+ $link = $link.parent();
+ var menu = $(geomMenu);
+ if ( $( '.digitize-contextmenu' ).length != 0 ) {
+ return;
+ $(document.body).append(menu);
+ var pos = $link.offset();
+ menu.css({position: 'absolute', top: pos.top, left: pos.left, width: "120px"}).menu()
+ .children().addClass('ui-menu-item')
+ .hover(function() {$(this).addClass('ui-state-hover'); },
+ function() {$(this).removeClass('ui-state-hover'); });
+ menu.children('li:has(.digitize-zoomto)').bind('click', function() {
+ kml.zoomToFeature(url, $link.attr('idx'));
+ menu.children('li:has(.digitize-pencil)').bind('click', editObject($link, menu));
+ menu.children('li:has(.digitize-export)').bind('click', function() {
+ var data = kml._kmls[url];
+ exportItem(data.data.features[idx]);
+ menu.children('li:has(.digitize-remove)').bind('click', function() {
+ var ids = [];
+ var i = 0;
+ $.each($link.siblings(), function(k, v) {
+ ids.push($(v).attr('idx'));
+ $(v).attr('idx', i++);
- menu.children('li:has(.digitize-pencil)').bind('click', editObject($link, menu));
- menu.children('li:has(.digitize-export)').bind('click', function() {
- var data = kml._kmls[url];
- exportItem(data.data.features[idx]);
- menu.children('li:has(.digitize-remove)').bind('click', function() {
- var ids = [];
- var i = 0;
- $.each($link.siblings(), function(k, v) {
- ids.push($(v).attr('idx'));
- $(v).attr('idx', i++);
- $link.remove();
- kml.reorderFeatures(url, ids);
+ $link.remove();
+ kml.reorderFeatures(url, ids);
- menu.children('li:has(.digitize-style)').bind('click', function() {
- editDialog.dialog('close');
- editStyle($link, menu)();
- return false;
+ menu.children('li:has(.digitize-style)').bind('click', function() {
+ editDialog.dialog('close');
+ editStyle($link, menu)();
+ return false;
- var editAttributes = function(feature, kml, url) {
+var editAttributes = function(feature, kml, url) {
- if ($(this).hasClass('editFeatureCollection')) {
+ if ($(this).hasClass('editFeatureCollection')) {
// kml = $('#mapframe1').data('kml');
var oldCollectionName;
if (feature.hasOwnProperty('@context')) {
@@ -626,12 +626,12 @@
var featureCollectionContent = "<div class='digitize-image digitize-style'></div>"+
- "<br><br>"+
- "<div><table id='featureCollTbl'>"+
- "</table></div>"+
- "<br><br/>"+
- "<div class='digitize-image digitize-add'></div>"+
- "<div class='digitize-image digitize-save'></div>";
+ "<br><br>"+
+ "<div><table id='featureCollTbl'>"+
+ "</table></div>"+
+ "<br><br/>"+
+ "<div class='digitize-image digitize-add'></div>"+
+ "<div class='digitize-image digitize-save'></div>";
$('#featureCollAttrDlg').append(featureCollectionContent);
$.each(feature, function(index, val) {
if (index == 'uuid' || index == 'created' || index == 'updated') {
@@ -677,10 +677,10 @@
// var preview = attributesDialog.find('.digitize-preview').html('').get(0);
// kml.renderPreview(feature, preview);
// add row
- featureCollAttrDlg.find('.digitize-add').bind('click', function() {
+ featureCollAttrDlg.find('.digitize-add').bind('click', function() {
var newRow = $('<tr><td><input type="text"></input></td><td><input class="newInputValue" name="" type="text"></input></td></tr>');
$(newRow).find('.newInputValue').bind('keyup',function(){
$(this).attr('name',$(this).val());
@@ -702,17 +702,17 @@
// differentiate between the geometry-type
switch(feature.geometry.type){
case "Point":
- schemaInstance = instantiate( options.pointAttributesSchema );
- geomType = "Point"
- break;
+ schemaInstance = instantiate( options.pointAttributesSchema );
+ geomType = "Point"
+ break;
case "Polygon":
- schemaInstance = instantiate( options.polygonAttributesSchema );
- geomType = "Polygon"
- break;
+ schemaInstance = instantiate( options.polygonAttributesSchema );
+ geomType = "Polygon"
+ break;
case "Polyline":
- schemaInstance = instantiate( options.polylineAttributesSchema );
- geomType = "Polyline"
- break;
+ schemaInstance = instantiate( options.polylineAttributesSchema );
+ geomType = "Polyline"
+ break;
attributesDialog.dialog('open');
attributesDialog.find('*').unbind();
@@ -763,7 +763,7 @@
//get parent and change updated
if($('#mapframe1').data('kml')._kmls[url].data.hasOwnProperty('updated')){
- $('#mapframe1').data('kml')._kmls[url].data.updated = new Date().toISOString();
+ $('#mapframe1').data('kml')._kmls[url].data.updated = new Date().toISOString();
attributesDialog.dialog('close');
@@ -850,8 +850,6 @@
$(this).addClass('active').siblings().removeClass('active');
editDialog.find('.digitize-move-vertex').bind('click', function() {
- console.log( o );
- console.log( o.$target );
o.$target.mb_digitize('moveVertexMode');
@@ -877,9 +875,9 @@
$link.click();
@@ -943,178 +941,196 @@
- return false;
+return false;
- var finishDigitize = function () {
- inProgress = false;
- that.deactivate();
- status = 'created-new';
+var finishDigitize = function () {
+ inProgress = false;
+ that.deactivate();
+ status = 'created-new';
- if(kml) {
- var digit = o.$target.data('mb_digitize');
- var pts = digit._digitizePoints;
+ if(kml) {
+ var digit = o.$target.data('mb_digitize');
+ var pts = digit._digitizePoints;
- attributesDialog.html(editAttributesHtml);
- attributesDialog.dialog('open');
- attributesDialog.find('.digitize-add').bind('click', function() {
- var newRow = $('<tr><td><input type="text"></input></td><td><input type="text"></input></td></tr>');
- attributesDialog.find('table').append(newRow);
- newRow.find('input').first().bind('change', function() {
- newRow.find('input').last().attr('name', $(this).val());
- attributesDialog.find('.digitize-save').bind('click', function() {
- kml.addGeometry(pts, digitizingFor, attributesDialog);
- attributesDialog.find('.digitize-save').unbind('click');
- attributesDialog.dialog('close');
+ attributesDialog.html(editAttributesHtml);
+ attributesDialog.dialog('open');
+ attributesDialog.find('.digitize-add').bind('click', function() {
+ var newRow = $('<tr><td><input type="text"></input></td><td><input type="text"></input></td></tr>');
+ attributesDialog.find('table').append(newRow);
+ newRow.find('input').first().bind('change', function() {
+ newRow.find('input').last().attr('name', $(this).val());
+ attributesDialog.find('.digitize-save').bind('click', function() {
+ kml.addGeometry(pts, digitizingFor, attributesDialog);
+ attributesDialog.find('.digitize-save').unbind('click');
+ attributesDialog.dialog('close');
- var reinitializeDigitize = function () {
- that.activate();
+var reinitializeDigitize = function () {
+ that.activate();
//TODO: exchange the use of proj4js with postgis transform funktion!
- var featureModified = function() {
+var featureModified = function() {
- var geom = new Geometry();
- var geomType = editedFeature.geometry.type.toLowerCase();
+ var geom = new Geometry();
+ var geomType = editedFeature.geometry.type.toLowerCase();
//digit.modeOff();
- var pts = $.extend(true, {}, digit._digitizePoints);
- $.each(pts, function(_, v) {
- if(!$.isPlainObject(v.pos)) {
- v.pos = {x: v.pos.x, y: v.pos.y};
+ var pts = $.extend(true, {}, digit._digitizePoints);
+ $.ajax({
+ url: '../php/transformPoint.php',
+ type: 'POST',
+ dataType: 'json',
+ data: {
+ point_pos: JSON.stringify(pts),
+ targetProj: JSON.stringify(kml.targetProj),
+ currentProj: JSON.stringify(kml.wgs84)
+ $.each(data.coordinates, function(index, val) {
+ if(!$.isPlainObject(pts[index].pos)) {
+ pts[index].pos = {x: pts[index].pos.x, y: pts[index].pos.y};
+ pts[index].pos = {x:val[0], y:val[1]};
+ var newPoint = {x:val[0], y:val[1]};
+ geom.addPoint(newPoint);
+ geom.geomType = geomType;
+ var multi = new MultiGeometry(geomType);
+ multi.add(geom);
+ if(status === 'edit-point') {
+ editedFeature.geometry.coordinates = [pts[0].pos.x, pts[0].pos.y];
+ } else if(status === 'edit-line') {
+ editedFeature.geometry.coordinates = [];
+ $.each(pts, function(_, v) {
+ editedFeature.geometry.coordinates.push([v.pos.x, v.pos.y]);
+ } else if(status === 'edit-polygon') {
+ editedFeature.geometry.coordinates = [[]];
+ editedFeature.geometry.coordinates[0].push([v.pos.x, v.pos.y]);
- var newPoint = Proj4js.transform(kml.targetProj, kml.wgs84, v.pos);
- // Proj4js.transform(kml.targetProj, kml.wgs84, v.pos);
- geom.addPoint(newPoint);
- geom.geomType = geomType;
- var multi = new MultiGeometry(geomType);
- multi.add(geom);
+ // cloning the geoms to calculate the area or length
+ var modifiedGeom = $.extend(true, {}, geom);
+ var modifiedData = new MultiGeometry(geomType);
+ if (geomType == 'polygon') {
+ modifiedGeom.addPoint(geom.list[0]); // add first point as last point
+ modifiedData.add(modifiedGeom);
- if(status === 'edit-point') {
- editedFeature.geometry.coordinates = [pts[0].pos.x, pts[0].pos.y];
- } else if(status === 'edit-line') {
- editedFeature.geometry.coordinates = [];
- editedFeature.geometry.coordinates.push([v.pos.x, v.pos.y]);
- } else if(status === 'edit-polygon') {
- editedFeature.geometry.coordinates = [[]];
- editedFeature.geometry.coordinates[0].push([v.pos.x, v.pos.y]);
- // cloning the geoms to calculate the area or length
- var modifiedGeom = $.extend(true, {}, geom);
- var modifiedData = new MultiGeometry(geomType);
+ } else {
- if (geomType == 'polygon') {
- modifiedGeom.addPoint(geom.list[0]); // add first point as last point
- modifiedData.add(modifiedGeom);
+ if (status != 'edit-point') {
- } else {
+ // calculate current area (polygon) or length(linestring)
+ $.ajax({
+ url: '../php/mod_CalculateAreaAndLength.php',
+ type: 'POST',
+ dataType: 'json',
+ data: {
+ geom_type: geomType,
+ wkt_geom: modifiedData.toText()
- if (status != 'edit-point') {
+ if (geom.geomType == 'polygon') {
+ //TODO: use attributes area and length - not complex strings!
+ editedFeature.properties['area'] = data[0];
+ editedFeature.properties['boundary-length'] = data[1];
- // calculate current area (polygon) or length(linestring)
- $.ajax({
- url: '../php/mod_CalculateAreaAndLength.php',
- type: 'POST',
- dataType: 'json',
- data: {
- geom_type: geomType,
- wkt_geom: modifiedData.toText()
+ } else {
- if (geom.geomType == 'polygon') {
- //TODO: use attributes area and length - not complex strings!
- editedFeature.properties['area'] = data[0];
- editedFeature.properties['boundary-length'] = data[1];
+ editedFeature.properties['track-length'] = data[0];
- } else {
+ complete: function() {
- editedFeature.properties['track-length'] = data[0];
- complete: function() {
+ editedFeature.properties.updated = new Date().toISOString();
+ kml.refresh(digitizingFor);
- editedFeature.properties.updated = new Date().toISOString();
- kml.refresh(digitizingFor);
+ }else{
- }else{
+ // Proj4js.transform(kml.targetProj, kml.wgs84, v.pos);
+ // geom.addPoint(newPoint);
- this.activate = function () {
- $('#kml-digitizer-pseudo').click();
- var mode = status.match(/(new|edit)-.+/);
+this.activate = function () {
+ $('#kml-digitizer-pseudo').click();
- if(!mode) {
- return;
+ var mode = status.match(/(new|edit)-.+/);
- mode = mode[1];
+ if(!mode) {
+ return;
- if(mode === 'new') {
- if (o.$target.size() > 0) {
- o.type = status.match(/new-(.+)/)[1];
- o.editedFeature = null;
- o.$target
- .mb_digitize(o)
- .mb_digitize('modeOff')
- .mb_digitize('startDigitizing')
- .unbind('mb_digitizelastpointadded')
- .unbind('mb_digitizereinitialize')
- .bind("mb_digitizelastpointadded", finishDigitize)
- .bind("mb_digitizereinitialize", reinitializeDigitize);
- } else {
- if(o.$target.size() > 0) {
- o.type = status.match(/edit-(.+)/)[1];
- o.editedFeature = editedFeature;
- o.$target
- .mb_digitize(o)
- .unbind('mb_digitizefeaturemodified')
- .bind('mb_digitizefeaturemodified', featureModified);
+ mode = mode[1];
+ if(mode === 'new') {
+ if (o.$target.size() > 0) {
+ o.type = status.match(/new-(.+)/)[1];
+ o.editedFeature = null;
+ o.$target
+ .mb_digitize(o)
+ .mb_digitize('modeOff')
+ .mb_digitize('startDigitizing')
+ .unbind('mb_digitizelastpointadded')
+ .unbind('mb_digitizereinitialize')
+ .bind("mb_digitizelastpointadded", finishDigitize)
+ .bind("mb_digitizereinitialize", reinitializeDigitize);
- if (!inProgress) {
- inProgress = true;
+ } else {
+ if(o.$target.size() > 0) {
+ o.type = status.match(/edit-(.+)/)[1];
+ o.editedFeature = editedFeature;
+ o.$target
+ .mb_digitize(o)
+ .unbind('mb_digitizefeaturemodified')
+ .bind('mb_digitizefeaturemodified', featureModified);
+ if (!inProgress) {
+ inProgress = true;
- this.destroy = function () {
- o.$target.mb_digitize("destroy")
+this.destroy = function () {
+ o.$target.mb_digitize("destroy")
// .unbind("mb_digitizepointadded", newPoint)
- .unbind("mb_digitizelastpointadded", finishDigitize)
- .unbind("mb_digitizereinitialize", reinitializeDigitize);
+ .unbind("mb_digitizelastpointadded", finishDigitize)
+ .unbind("mb_digitizereinitialize", reinitializeDigitize);
if (digitizeDialog.dialog("isOpen")) {
digitizeDialog.dialog("close");
@@ -1145,7 +1161,7 @@
* @param {[type]} mappingSchema [description]
* @return {[type]} [description]
- var mapFeature = function( propertyKey, propertyValue, categories, mappingSchema, geomType, geometryDiv){
+ var mapFeature = function( propertyKey, propertyValue, categories, mappingSchema, geomType, geometryDiv){
if ( propertyKey != "area" && propertyKey != "boundary-length" && propertyKey != "track-length" ) {
// check if property exists in mappingSchema otherwise put it in custom-data
@@ -1157,11 +1173,11 @@
categories[featureCategory] += '<tr><td>' + propertyKey + '</td><td><input disabled type="text" name="' + propertyKey + '" value="' + propertyValue + '"></input></td></tr>';
// else allow to edit the input
- } else {
+ } else {
- categories[featureCategory] += '<tr><td>' + propertyKey + '</td><td><input type="text" name="' + propertyKey + '" value="' + propertyValue + '"></input></td></tr>';
- } else {
+ categories[featureCategory] += '<tr><td>' + propertyKey + '</td><td><input type="text" name="' + propertyKey + '" value="' + propertyValue + '"></input></td></tr>';
+ } else {
// put property in custom-data because it doesn't belong to any category
categories["Custom-Data"] += '<tr><td>' + propertyKey + '</td><td><input type="text" name="' + propertyKey + '" value="' + propertyValue + '"></input></td></tr>';
@@ -1171,14 +1187,14 @@
// differentiate between the geometry-properties
switch(propertyKey) {
case "area":
- header = "<?php echo _mb("Area [m²]");?>";
- break;
+ header = "<?php echo _mb("Area [m²]");?>";
+ break;
case "boundary-length":
- header = "<?php echo _mb("Boundary length [m]");?>";
- break;
+ header = "<?php echo _mb("Boundary length [m]");?>";
+ break;
case "track-length":
- header = "<?php echo _mb("Length [m]");?>";
- break;
+ header = "<?php echo _mb("Length [m]");?>";
+ break;
// append the matchin geometry-property to the geometryDiv
geometryDiv.append('<div><p class = " geometry-p "name="' + propertyKey + '">'+ header +' : ' + propertyValue + '</p></div>');
More information about the Mapbender_commits
