[Mapbender-commits] r9163 - in trunk/mapbender: http/classes http/extensions http/javascripts http/php http/plugins lib
svn_mapbender at osgeo.org
Mon Mar 9 05:43:13 PDT 2015
Author: syed
Date: 2015-03-09 05:43:13 -0700 (Mon, 09 Mar 2015)
New Revision: 9163
trunk/mapbender/http/classes/class_connector.php
trunk/mapbender/http/classes/class_kml_ows.php
trunk/mapbender/http/classes/class_kml_parser_ows.php
trunk/mapbender/http/extensions/togeojson.js
trunk/mapbender/http/extensions/togpx.js
trunk/mapbender/http/extensions/tokml.js
trunk/mapbender/http/javascripts/mod_savewmc.js
trunk/mapbender/http/javascripts/mod_savewmc.php
trunk/mapbender/http/php/kmlToGeoJSON.php
trunk/mapbender/http/php/mb_metadata_uploadLayerPreview.php
trunk/mapbender/http/php/mod_GetPublishedData.php
trunk/mapbender/http/php/transformgeojson.php
trunk/mapbender/http/php/uploadKml.php
trunk/mapbender/http/plugins/kmlTree.js
trunk/mapbender/http/plugins/mb_digitize_widget.php
trunk/mapbender/http/plugins/mb_loadkmlgeorss.js
trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
add metadata for featureCollection and fix import-export functionality
Modified: trunk/mapbender/http/classes/class_connector.php
--- trunk/mapbender/http/classes/class_connector.php 2015-03-02 13:27:54 UTC (rev 9162)
+++ trunk/mapbender/http/classes/class_connector.php 2015-03-09 12:43:13 UTC (rev 9163)
@@ -1,7 +1,7 @@
<?php
# $Id$
# http://www.mapbender.org/index.php/class_connector
-# Copyright (C) 2002 CCGIS
+# Copyright (C) 2002 CCGIS
# This program is free software; you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
@@ -21,12 +21,12 @@
* Establishes a connection to a given URL (and loads the content).
* Supports HTTP (GET and POST), cURL and socket connections.
* @class
class connector {
- var $file;
+ var $file;
private $connectionType;
private $timeOut = 20;
private $httpType = "get";
@@ -37,8 +37,8 @@
private $curlSendCustomHeaders = true; //decide to send own headers or not
private $curlCookiesession = true;
private $externalHeaders = "";
* @constructor
* @param String url the URL that will be loaded (optional)
@@ -59,19 +59,20 @@
* Loads content from the given URL.
public function load($url) {
- //some firewalls have problems to allow requests from a server behind it to the same server through
- //an internet connection. It can be that some requests are done thru this class to the urls of
- //HTTP_AUTH_PROXY or OWSPROXY. If some of those are part of the url they must be exchanged with 127.0.0.1 - //which hopefully should work.
- //TODO: check if http is ok for all
+ //some firewalls have problems to allow requests from a server behind it to the same server through
+ //an internet connection. It can be that some requests are done thru this class to the urls of
+ //HTTP_AUTH_PROXY or OWSPROXY. If some of those are part of the url they must be exchanged with 127.0.0.1 - //which hopefully should work.
+ //TODO: check if http is ok for all
$posPROXY = strpos($url,OWSPROXY);
//$e = new mb_exception('class_connector: old url: '.$url);
if($posPROXY !== false && OWSPROXY_USE_LOCALHOST == true){
- $e = new mb_notice('class_connector: old url: '.$url);
+ var_dump('test1');die;
+ $e = new mb_notice('class_connector: old url: '.$url);
$url = str_replace($_SERVER['HTTP_HOST'], "127.0.0.1", $url);
$url = str_replace("https", "http", $url);//localhost no https should needed - it will be faster without
$e = new mb_notice('class_connector: new url: '.$url);
@@ -79,11 +80,13 @@
$e = new mb_notice('class_connector: load url: '.$url);
if (!$url) {
+ var_dump('test2');die;
$e = new mb_exception("connector: no URL given");
return false;
switch ($this->connectionType) {
case "curl":
+ var_dump('test3');die;
if (func_num_args() == 2) {
$auth = func_get_arg(1);
if (isset($auth)) {
@@ -92,26 +95,31 @@
else {
+ var_dump('test4');die;
$e = new mb_notice("connector: curl without auth");
$this->file = $this->getCURL($url);
break;
case "http":
+ // var_dump('test5');
$e = new mb_notice("connector: http");
$this->file = $this->getHTTP($url);
+ // var_dump($this->getHTTP($url));
break;
case "socket":
+ var_dump('test6');die;
$e = new mb_notice("connector: socket");
$this->file = $this->getSOCKET($url);
break;
if(!$this->file){
+ // var_dump('test7');die;
$e = new mb_exception("connector: unable to load: ".$url);
return false;
- return $this->file;
+ return $this->file;
* Sets the environment variables. The following can be set:
* - connectionType ("http", "curl", "socket")
@@ -125,7 +133,7 @@
$this->connectionType = $value;
break;
case "httpVersion":
if (in_array($value, array("1.0", "1.1"))) {
$this->httpVersion = $value;
@@ -134,7 +142,7 @@
$e = new mb_exception("class_connector.php: invalid http type '" . $value . "'");
break;
case "httpType":
if (in_array(mb_strtoupper($value), array("POST", "GET"))) {
$this->httpType = $value;
@@ -143,35 +151,35 @@
break;
case "httpPostData":
$this->httpPostData = $value;
break;
case "httpPostFieldsNumber":
$this->httpPostFieldsNumber = $value;
- break;
+ break;
case "curlSendCustomHeaders":
$this->curlSendCustomHeaders = $value;
break;
case "timeOut":
$this->timeOut = (integer)$value;
- break;
+ break;
case "externalHeaders":
$this->externalHeaders = $value;
- break;
+ break;
case "httpContentType":
if ($this->isValidHttpContentType($value)) {
$this->httpContentType = $value;
break;
private function isValidConnectionType ($value) {
if (in_array(mb_strtoupper($value), array("HTTP", "CURL", "SOCKET"))) {
return true;
@@ -181,7 +189,7 @@
return false;
private function isValidHttpContentType ($value) {
$validHttpContentTypeArray = array("XML","TEXT/XML","APPLICATION/XML","MULTIPART/FORM-DATA");
if (in_array(mb_strtoupper($value), $validHttpContentTypeArray)) {
@@ -197,7 +205,7 @@
return false;
private function getCURL($url){
//urls should begin with http ;-)
$url=ltrim($url);
@@ -205,7 +213,7 @@
$url=str_replace(";","%3B",$url);
- } //auth should be an array of ['username', 'realm', 'password', 'auth_type'] - or false - problem would be, that these are stored without hashing them!
+ } //auth should be an array of ['username', 'realm', 'password', 'auth_type'] - or false - problem would be, that these are stored without hashing them!
$ch = curl_init ($url);
curl_setopt($ch, CURLOPT_BINARYTRANSFER, true); //for images
curl_setopt($ch, CURLOPT_FOLLOWLOCATION, true);
@@ -221,20 +229,20 @@
//$host = parse_url($url,PHP_URL_HOST);
$arURL = parse_url($url);
$host = $arURL["host"];
- $port = $arURL["port"];
+ $port = $arURL["port"];
if($port == ''){
$port = 80;
if($arURL["scheme"] == "https"){
$port = 443;
$path = $arURL["path"];
// fill array (HOSTs not for Proxy)
$e = new mb_notice("class_connector.php: NOT_PROXY_HOSTS:".NOT_PROXY_HOSTS);
$NOT_PROXY_HOSTS_array = explode(",", NOT_PROXY_HOSTS);
//check if http_proxy is set as env, if yes, unset it for the curl action here, it will be reset somewhere below - normally not needed, cause it will be only available when at execution time of the script http://php.net/manual/en/function.putenv.php
if (getenv('http_proxy')) {
$e = new mb_notice("class_connector.php: current http_proxy: ".getenv('http_proxy')." will be unset by putenv('http_proxy')");
@@ -251,26 +259,26 @@
curl_setopt($ch, CURLOPT_PROXY,CONNECTION_PROXY.":".CONNECTION_PORT);
$e = new mb_notice("class_connector.php: Proxy will be used!");
if(CONNECTION_PASSWORD != ""){
- curl_setopt ($ch, CURLOPT_PROXYUSERPWD, CONNECTION_USER.':'.CONNECTION_PASSWORD);
+ curl_setopt ($ch, CURLOPT_PROXYUSERPWD, CONNECTION_USER.':'.CONNECTION_PASSWORD);
} else {
$e = new mb_notice("class_connector.php: Proxy will not be used!");
//TODO maybe allow basic authentication for client, but this will store the passwords in plain text
//TODO: store the passwords as digest hash. Therefor we have to handle the realm which is defined in the 401 header and return it back to the scripts like mod_loadwms.php to store the digest into the database - problem: curl cannot handle digest connection without clear username and password - we have to send our own headers
- if(isset($auth) && $auth != false) {
+ if(isset($auth) && $auth != false) {
curl_setopt($ch, CURLOPT_USERPWD, $auth['username'].':'.$auth['password']);
if ($auth['auth_type'] == 'digest') {
- curl_setopt($ch, CURLOPT_HTTPAUTH, CURLAUTH_DIGEST);
+ curl_setopt($ch, CURLOPT_HTTPAUTH, CURLAUTH_DIGEST);
if ($auth['auth_type'] == 'basic') {
curl_setopt($ch, CURLOPT_HTTPAUTH, CURLAUTH_BASIC);
- //if httpType is POST, set CURLOPT_POST and CURLOPT_POSTFIELDS
+ //if httpType is POST, set CURLOPT_POST and CURLOPT_POSTFIELDS
//and set a usefull http header
if(strtoupper($this->httpType) == 'POST'){
$headers = array(
@@ -279,11 +287,11 @@
"Cache-Control: no-cache",
"Pragma: no-cache",
"Content-length: ".strlen($this->httpPostData)
- $e = new mb_notice("connector: CURL POST: ".$this->httpPostData);
+ $e = new mb_notice("connector: CURL POST: ".$this->httpPostData);
$e = new mb_notice("connector: CURL POST length: ".strlen($this->httpPostData));
- if ($this->curlSendCustomHeaders) {
+ if ($this->curlSendCustomHeaders) {
curl_setopt($ch, CURLOPT_HTTPHEADER, $headers);
if ($this->httpPostFieldsNumber != 1){
@@ -291,7 +299,7 @@
} else {
curl_setopt($ch, CURLOPT_POST, 1);
- curl_setopt($ch, CURLOPT_POSTFIELDS, $this->httpPostData);
+ curl_setopt($ch, CURLOPT_POSTFIELDS, $this->httpPostData);
//$e = new mb_exception($this->httpPostData);
$useragent=CONNECTION_USERAGENT;
@@ -311,11 +319,11 @@
#curl_setopt($ch, CURLOPT_HEADER, true);
- $e = new mb_notice("class_connector.php: CURL connect to:".$url);
+ $e = new mb_notice("class_connector.php: CURL connect to:".$url);
//curl_setopt ($ch,CURLOPT_USERAGENT,$useragent);
curl_setopt($ch,CURLOPT_DNS_USE_GLOBAL_CACHE, false);
curl_setopt($ch,CURLINFO_HEADER_OUT, true);
- curl_setopt($ch, CURLOPT_FORBID_REUSE, false);
+ curl_setopt($ch, CURLOPT_FORBID_REUSE, false);
//curl_setopt ($ch,HTTPPROXYTUNNEL, 1);
//curl_setopt ($ch,CURLOPT_AUTOREFERER, 1);
//curl_setopt ($ch,CURLOPT_VERBOSE, true);
@@ -347,12 +355,13 @@
//reset the env variable http_proxy to the former value
if ($tmpHttpProxy != '') {
putenv("http_proxy=$tmpHttpProxy");
$e = new mb_notice("class_connector.php: CURL give back: ".$file);
- return $file;
+ return $file;
private function getHTTP($url){
+ // var_dump(file_get_contents($url));die;
if ($this->httpType == "get") {
return @file_get_contents($url);
@@ -362,20 +371,20 @@
$urlComponentArray = parse_url($url);
$scheme = $urlComponentArray["scheme"];
$host = $urlComponentArray["host"];
- $port = $urlComponentArray["port"];
+ $port = $urlComponentArray["port"];
if ($port == "") {
if ($scheme == "https") {
$port = 443;
else {
- $port = 80;
+ $port = 80;
$path = $urlComponentArray["path"];
$query = $urlComponentArray["query"];
$buf = '';
- $fp = fsockopen("ssl://". $host, $port, $errno, $errstr);
+ $fp = fsockopen("ssl://". $host, $port, $errno, $errstr);
else {
$fp = fsockopen($host, $port);
@@ -384,11 +393,11 @@
$postPath = "POST " . $path . "?" . $query . " HTTP/".$this->httpVersion . "\r\n";
$postStr .= $postPath;
fputs($fp, $postPath);
$postHost = "Host: " . $host . "\r\n";
$postStr .= $postHost;
fputs($fp, $postHost);
if ($this->isValidHttpContentType($this->httpContentType)) {
$postContentType = "Content-type: " . $this->httpContentType . "\r\n";
$postStr .= $postContentType;
@@ -397,7 +406,7 @@
$postContentLength = "Content-length: " . strlen($this->httpPostData) . "\r\n";
$postStr .= $postContentLength;
fputs($fp, $postContentLength);
$postClose = "Connection: close\r\n\r\n";
$postStr .= $postClose;
fputs($fp, $postClose);
@@ -406,7 +415,7 @@
fputs($fp, $this->httpPostData);
new mb_notice("connector.http.postData: ".$this->httpPostData);
$xmlstr = false;
//@TODO remove possibly infinite loop
while (!feof($fp)) {
@@ -421,7 +430,7 @@
fclose($fp);
// new mb_notice("connector.http.response: ".$buf);
- return $buf;
+ return $buf;
@@ -430,7 +439,7 @@
$fp = fsockopen (CONNECTION_PROXY, CONNECTION_PORT, $errno, $errstr, 30);
if (!$fp) {
echo "$errstr ($errno)<br />\n";
else {
fputs ($fp, "GET ".$url." HTTP/1.0\r\n\r\n");
Modified: trunk/mapbender/http/classes/class_kml_ows.php
--- trunk/mapbender/http/classes/class_kml_ows.php 2015-03-02 13:27:54 UTC (rev 9162)
+++ trunk/mapbender/http/classes/class_kml_ows.php 2015-03-09 12:43:13 UTC (rev 9163)
@@ -1,7 +1,7 @@
<?php
# $Id$
# http://www.mapbender.org/index.php/class_wmc.php
@@ -28,7 +28,7 @@
* Allows parsing a KML file, extracting the placemarks.
* @package KML
class KML {
@@ -41,21 +41,21 @@
* The constructor function, currently empty.
public function __construct() {
public function toSingleLineStringKml() {
//KML 2.2 output
$doc = new DOMDocument("1.0", CHARSET);
$doc->preserveWhiteSpace = false;
// attach kml and Document tag
$e_kml = $doc->createElementNS("http://earth.google.com/kml/2.2", "kml");
$e_document = $doc->createElement("Document");
$e_kml->appendChild($e_document);
$doc->appendChild($e_kml);
// attach placemarks
$e = new mb_notice("to string: #placemarks: " . count($this->placemarkArray));
@@ -66,7 +66,7 @@
$lineStyleNode->appendChild($lineStyleColorNode);
$lineStyleNode->appendChild($lineStyleWidthNode);
$e_document->appendChild($lineStyleNode);
// line segments first
@@ -84,7 +84,7 @@
$coordinates .= " ";
$coordinates .= $coordinatesArray[$j]["x"] . "," . $coordinatesArray[$j]["y"] . "," . $coordinatesArray[$j]["z"];
break;
@@ -100,8 +100,8 @@
$e_pl_style = $doc->createElement("styleUrl", "#linestyleExample");
$e_placemark->appendChild($e_pl_style);
$e_document->appendChild($e_placemark);
// now pois
@@ -111,7 +111,7 @@
$currentPlacemark = $this->placemarkArray[$i];
$e = new mb_notice("now: " . $i . " of " . (count($this->placemarkArray)-1) . " (is a " . get_class($currentPlacemark) . ")");
$pl_instructions = $currentPlacemark->getProperty("instruction");
$pl_name_array = array();
$pl_name = false;
@@ -152,31 +152,31 @@
return $doc->saveXML();
* @return string the KML document.
public function __toString() {
if (!$this->kml) {
//KML 2.2 output
for ($i = 0; $i < count($this->placemarkArray); $i++) {
$pl_name = false;
@@ -197,7 +197,7 @@
$e_coordinates = $doc->createElement("coordinates", $coordinates);
$e_geometry->appendChild($e_coordinates);
break;
/* TODO:Polygons
case "KMLPolygon" :
$e_geometry = $doc->createElement("Polygon");
@@ -205,19 +205,19 @@
$e_outer_lr = $doc->createElement("LinearRing");
$outer_coordinates = ""; // TODO: get coords from placemark
$e_outer_coordinates = $doc->createElement("Coordinates", $outer_coordinates);
$e_outer_lr->appendChild($e_outer_coordinates);
$e_outer->appendChild($e_outer_lr);
for ($j = 0; $j < $currentPlacemark; $j++) {
outerBoundaryIs"}->{"LinearRing"}->{"coordinates
break;
case "KMLLine" :
if (count($pl_name_array) > 2) {
$pl_description = $pl_name_array[1];
@@ -230,13 +230,13 @@
break;
-/* TODO: Multigeometries
+/* TODO: Multigeometries
case "KMLMultiGeometry" :
break;
@@ -260,18 +260,18 @@
return $this->kml;
* @return string the ID of this KML.
public function getId () {
return $this->id;
- * parses an incoming KML, creates the object,
+ * parses an incoming KML, creates the object,
* stores the kml in the object and in the database.
* @param string a KML document.
* @return boolean true if the parsing succeded, else false.
@@ -284,11 +284,11 @@
$parser = new KmlOwsParser();
$parser->parseKML($kml, $this->id);
- $this->placemarkArray = $parser->placemarkArray;
+ $this->placemarkArray = $parser->placemarkArray;
+ $this->featureCollectionMD = $parser->featureCollectionMD;
return true;
public function transform($targetEpsg){
$numberOfPlacemarks = count($this->placemarkArray);
if ($numberOfPlacemarks > 0) {
@@ -302,9 +302,9 @@
return true;
- * parses an incoming GeoJSON, creates the object,
+ * parses an incoming GeoJSON, creates the object,
* @param string a geoJSON.
@@ -318,28 +318,48 @@
$parser->parseGeoJSON($geoJSON, $this->id);
$e = new mb_notice("parsing finished...#placemarks: " . count($this->placemarkArray) . " (" . count($parser->placemarkArray) . ")");
// new mb_exception(print_r($this, true));
// $this->kml = $this->__toString();
// $this->updateInDb($this->kml, $this->id);
return true;
* @return string the geoJSON representation of the KML.
- public function toGeoJSON() {
- $str = "";
+ public function toGeoJSON($str) {
+ // var_dump($str);die;
+ // $str = "{";
+ // if (sizeof($this->featureCollectionMD) > 0) {
+ // end($this->featureCollectionMD);
+ // $lastKey = key($this->featureCollectionMD);
+ // $str .= "\"@context\": { ";
+ // foreach ($this->featureCollectionMD as $key => $value) {
+ // // var_dump($str);var_dump($key);var_dump($value);
+ // // if ($key == end($this->featureCollectionMD)){
+ // if ( $key === $lastKey ){
+ // $str.= "\"".$key."\": \"".$value."\" },";
+ // }else{
+ // $str.= "\"".$key."\": \"".$value."\",";
- $str .= "{\"type\": \"FeatureCollection\", \"features\": [";
+ $str .= "\"type\": \"FeatureCollection\", \"features\": [";
for ($i=0; $i < $numberOfPlacemarks; $i++) {
if ($i > 0) {
$str .= ",";
$str .= $this->placemarkArray[$i]->toGeoJSON();
$str .= "]}";
@@ -350,6 +370,33 @@
return $str;
+ public function createGeoJSON(){
+ // var_dump($this->placemarkArray);die;
+ $str = "{";
+ if (sizeof($this->featureCollectionMD) > 0) {
+ end($this->featureCollectionMD);
+ $lastKey = key($this->featureCollectionMD);
+ $str .= "\"@context\": { ";
+ foreach ($this->featureCollectionMD as $key => $value) {
+ // var_dump($str);var_dump($key);var_dump($value);
+ // if ($key == end($this->featureCollectionMD)){
+ if ( $key === $lastKey ){
+ $str.= "\"".$key."\": \"".$value."\" },";
+ }else{
+ $str.= "\"".$key."\": \"".$value."\",";
+ $completeString = $this->toGeoJSON($str);
+ return $completeString;
+ // var_dump($completeString);die;
private function updateInDb($kmlDoc, $kmlId) {
$sql = "UPDATE gui_kml SET kml_doc = $1 WHERE kml_id = $2";
$v = array($kmlDoc, $kmlId);
@@ -363,13 +410,13 @@
public function updateKml ($kmlId, $placemarkId, $geoJSON) {
$kmlFromDb = $this->getKmlDocumentFromDB($kmlId);
if ($kmlFromDb !== NULL) {
// load the KML from the database in the DOM object
$kmlDoc_DOM = new DOMDocument("1.0");
$kmlDoc_DOM->encoding = CHARSET;
$kmlDoc_DOM->preserveWhiteSpace = false;
- $kmlDoc_DOM->loadXML($kmlFromDb);
+ $kmlDoc_DOM->loadXML($kmlFromDb);
//load the geoJSON
$json = new Mapbender_JSON();
@@ -377,7 +424,7 @@
// construct an array that holds all metadata of the placemark
$metadataObj = $geoObj->properties;
// construct an array that holds all geometries of the placemark
$geometryObj = $geoObj->geometry;
$geometryType = $geometryObj->type;
@@ -395,7 +442,7 @@
// apply the changes
$currentPlacemarkArray = $kmlDoc_DOM->getElementsByTagName("Placemark");
$currentPlacemark = $currentPlacemarkArray->item($placemarkId);
@@ -435,17 +482,17 @@
// ------------------------------- private -----------------------------------------------
* Store this KML in the database, and sets the ID.
* @return boolean true, if the KML could be stored in the database; else false.
private function storeInDb () {
if (Mapbender::session()->get("mb_user_id") && Mapbender::session()->get("mb_user_gui")) {
$con = db_connect(DBSERVER,OWNER,PW);
db_select_db(DB,$con);
$sql = "INSERT INTO gui_kml ";
$sql .= "(fkey_mb_user_id, fkey_gui_id, kml_doc, kml_name, kml_description, kml_timestamp) ";
$sql .= "VALUES ";
@@ -457,7 +504,7 @@
$e = new mb_exception("class_kml.php: storeInDb: failed to store KML in database: " . db_error());
return false;
$this->id = db_insert_id($con, "gui_kml", "kml_id");
return true;
@@ -476,7 +523,7 @@
//get KML from database (check if user is allowed to access)
-# for now, do not restrict access
+# for now, do not restrict access
# $sql = "SELECT kml_doc FROM gui_kml WHERE kml_id = $1 AND fkey_mb_user_id = $2 AND fkey_gui_id = $3 LIMIT 1";
# $v = array($kmlId, Mapbender::session()->get("mb_user_id"), Mapbender::session()->get("mb_user_gui"));
# $t = array("i", "i", "s");
@@ -501,7 +548,7 @@
* @return string the tag name without its namespace.
private function sepNameSpace($s){
- $c = mb_strpos($s, ":");
+ $c = mb_strpos($s, ":");
if ($c > 0) {
$s = mb_substr($s, $c+1);
@@ -509,7 +556,7 @@
private function updateGeometries($currentPlacemark, $geometryArray) {
- $cnt = 0;
+ $cnt = 0;
$childNodes = $currentPlacemark->childNodes;
foreach ($childNodes as $childNode) {
@@ -527,13 +574,13 @@
return true;
private function updateGeometry ($currentNode, $geometry) {
$currentNode_SimpleXML = simplexml_import_dom($currentNode);
$currentTypeXml = mb_strtoupper($currentNode->nodeName);
- $currentTypeGeoJson = mb_strtoupper($geometry->type);
+ $currentTypeGeoJson = mb_strtoupper($geometry->type);
if ($currentTypeGeoJson != $currentTypeXml) {
$e = new mb_exception("class_kml: geometry type mismatch: geoJSON: " . $currentTypeGeoJson . "; XML: " . $currentTypeXml);
@@ -582,7 +629,7 @@
private function updateMetadata($currentPlacemark, $metadataObj) {
$metadataExistsAndUpdateSucceeded = true;
$currentPlacemark_SimpleXML = simplexml_import_dom($currentPlacemark);
$extendedDataNode = $currentPlacemark_SimpleXML->{"ExtendedData"};
if ($extendedDataNode) {
@@ -592,12 +639,12 @@
$simpleDataNodes = $extendedDataNode->{"SchemaData"}->{"SimpleData"};
if ($simpleDataNodes) {
foreach ($simpleDataNodes as $simpleDataNode) {
- $tmp = dom_import_simplexml($simpleDataNode);
+ $tmp = dom_import_simplexml($simpleDataNode);
$name = $tmp->getAttribute("name");
// if there is a metadata entry, update it
if (isset($metadataObj->$name)) {
$tmp->nodeValue = $metadataObj->$name;
@@ -612,7 +659,7 @@
@@ -624,15 +671,15 @@
* The KML document.
private $kml;
* The ID of this KML in the database.
private $id;
* An array of {@link KMLPlacemark}
private $placemarkArray = array();
Modified: trunk/mapbender/http/classes/class_kml_parser_ows.php
--- trunk/mapbender/http/classes/class_kml_parser_ows.php 2015-03-02 13:27:54 UTC (rev 9162)
+++ trunk/mapbender/http/classes/class_kml_parser_ows.php 2015-03-09 12:43:13 UTC (rev 9163)
@@ -1,7 +1,7 @@
<?php
# $Id$
@@ -32,20 +32,21 @@
class KmlOwsParser {
var $placemarkArray = array();
+ var $featureCollectionMD = array();
public function parseGeoJSON ($geoJSON, $kmlId) {
// $e = new mb_notice("GEOJSON: " . $geoJSON);
$geometryFromGeoJSON = $json->decode($geoJSON);
$id = 0;
if (gettype($geometryFromGeoJSON) == "object" && $geometryFromGeoJSON->type == "FeatureCollection") {
if ($geometryFromGeoJSON->crs->type == "EPSG" && $geometryFromGeoJSON->crs->properties->code) {
- $epsg = $geometryFromGeoJSON->crs->properties->code;
+ $epsg = $geometryFromGeoJSON->crs->properties->code;
// create Placemarks
for ($i = 0; $i < count($geometryFromGeoJSON->features); $i++) {
@@ -53,14 +54,14 @@
$feature = $geometryFromGeoJSON->features[$i];
if (gettype($feature) == "object" && $feature->type == "Feature") {
if ($feature->geometry->crs->type == "EPSG") {
- $epsg = $feature->geometry->crs->properties->code;
+ $epsg = $feature->geometry->crs->properties->code;
if (!$epsg) {
$e = new mb_notice("EPSG is not set! Aborting...(" . $epsg . ")");
+ $currentGeometry = false;
$geometry = $feature->geometry;
- $currentGeometry = false;
//TODO: missing Polygon and MultiGeometry
switch ($geometry->type) {
case "LineString" :
@@ -78,12 +79,12 @@
$currentGeometry = new KMLPoint($coordinateList, $epsg);
break;
if ($currentGeometry) {
$currentPlacemark = new KMLPlacemark($currentGeometry);
if (gettype($feature->properties) == "object") {
foreach ($feature->properties as $key => $value) {
$currentPlacemark->setProperty($key, $value);
@@ -102,52 +103,53 @@
return true;
public function parseKML ($kml, $kmlId) {
$doc = new DOMDocument("1.0");
$doc->loadXML($kml);
$xpath = new DOMXPath($doc);
$xpath->registerNamespace("kml","http://earth.google.com/kml/2.2");
+ $xpath->registerNamespace("http://www.opengis.net/kml/2.2");
$styles =array();
$styleNodes = $xpath->query("/kml:kml/kml:Document/kml:Style");
//$e = new mb_exception("found this many styles:". $styleNodes->length);
foreach($styleNodes as $styleNode){
- $hrefNodes = $styleNode->getElementsByTagName("href");
+ $hrefNodes = $styleNode->getElementsByTagName("href");
if($hrefNodes->length > 0){
$href = $hrefNodes->item(0)->nodeValue;
$styles[$styleNode->getAttribute("id")] = array(
"href" => $href
$styleMapNodes = $xpath->query("/kml:kml/kml:Document/kml:StyleMap");
//$e = new mb_exception($styleMapNodes->length);
foreach($styleMapNodes as $styleMapNode){
foreach($styleMapNode->children as $child){
$keyNodes = $child->findElementsByTagName("key");
if($keyNodes->length > 0){
if($keyNodes->item(0)->nodeValue == "normal"){
$styleNodes = $child->findElementsByTagName("Style");
if($styleNodes->length > 0){
- $hrefNodes = $styleNodes->item(0)->getElementsByTagName("href");
+ $hrefNodes = $styleNodes->item(0)->getElementsByTagName("href");
$styles[$styleMapNode->getAttribute("id")] = array(
"href" => $href
- continue;
+ continue;
$styleUrlNodes = $child->findElementsByTagName("styleUrl");
if($styleUrlNodes->length > 0){
$id = $styleUrlNodes->item(0)->nodeValue;
@@ -155,11 +157,11 @@
$id = substr($id,1);
"href" => $styles[$id]["href"]
}else{
$e = new mb_exception("External style references not supported in KML parser");
@@ -168,34 +170,30 @@
"href" => $href
* Get geometry information only, store it in placemarkArray
$placemarkTagArray = $doc->getElementsByTagName("Placemark");
if (count($placemarkTagArray) > 0) {
$id = 0;
foreach ($placemarkTagArray as $node) {
$geometryArray = $this->getGeometryArrayFromPlacemarkOrMultigeometryNode($node);
$metadataArray = $this->getMetadataFromPlacemarkNode($node);
* For a placemark, the geometryArray should only contain 1 geometry!
for ($i=0; $i < count($geometryArray); $i++) {
$currentPlacemark = new KMLPlacemark($geometryArray[$i]);
- foreach ($metadataArray as $key => $value) {
- $currentPlacemark->setProperty($key, $value);
$currentPlacemark->setProperty("Mapbender:kml", true);
$currentPlacemark->setProperty("Mapbender:name", "unknown");
$currentPlacemark->setProperty("Mapbender:id", $kmlId);
$currentPlacemark->setProperty("Mapbender:placemarkId", $id);
+ foreach ($metadataArray as $key => $value) {
+ $currentPlacemark->setProperty($key, $value);
// add description and name:
$namesNode = $node->getElementsByTagName('name');
@@ -206,8 +204,9 @@
if($descriptionsNode->length > 0){
$description = trim($descriptionsNode->item(0)->nodeValue);
- $currentPlacemark->setProperty("name", $name);
- $currentPlacemark->setProperty("description", $description);
+ //TODO: dont add the properties twice!
+ // $currentPlacemark->setProperty("name", $name);
+ // $currentPlacemark->setProperty("description", $description);
//get style information for KML point objects
if(get_class($geometryArray[$i]) == "KMLPoint") {
@@ -215,11 +214,11 @@
$styleNodes = $node->getElementsByTagName('Style');
if($styleNodes->length > 0) {
$styleNode = $styleNodes->item(0);
- $currentPlacemark->setProperty("Mapbender:icon",$href);
+ $currentPlacemark->setProperty("Mapbender:icon",$href);
}else{
$styleUrlNodes = $node->getElementsByTagName('styleUrl');
if($styleUrlNodes->length > 0) {
@@ -234,21 +233,47 @@
$e = new mb_notice("Looking up style: $id");
$currentPlacemark->setProperty("Mapbender:icon",$styles[$id]["href"]);
array_push($this->placemarkArray, $currentPlacemark);
- $id ++;
+ $id ++;
else {
$e = new mb_exception("class_kml.php: KMLOWSParser: No placemarks found in KML.");
return false;
+ * add metadata for the feature-collection
+ $extendedData = $xpath->query('//*[local-name() = "kml"]/*[local-name() = "Document"]/*[local-name() = "ExtendedData"]');
+ if ($extendedData->length > 0) { // check for metadata
+ foreach ($extendedData as $metaData) {
+ $data = $metaData->getElementsByTagName('Data');
+ foreach ($data as $metadataValue) {
+ $test = $metadataValue->nodeValue;
+ foreach($metadataValue->attributes as $attribute_name => $attribute_node){
+ // * @var DOMNode $attribute_node
+ $this->featureCollectionMD[$attribute_node->nodeValue] = $metadataValue->nodeValue;
return true;
@@ -257,15 +282,15 @@
private function getMetadataFromPlacemarkNode ($node) {
$children = $node->childNodes;
$metadataArray = array();
// search "ExtendedData" tag
foreach ($children as $child) {
- if (mb_strtoupper($this->sepNameSpace($child->nodeName)) == "EXTENDEDDATA") {
+ if (mb_strtoupper($this->sepNameSpace($child->nodeName)) == "EXTENDEDDATA") {
$extendedDataNode = $child;
- $extDataChildren = $extendedDataNode->childNodes;
+ $extDataChildren = $extendedDataNode->childNodes;
// search "Data" or "SchemaData" tag
foreach ($extDataChildren as $extDataChild) {
if (mb_strtoupper($this->sepNameSpace($extDataChild->nodeName)) == "SCHEMADATA") {
@@ -287,17 +312,17 @@
if(mb_strtoupper($this->sepNameSpace($child->nodeName)) == "STYLE"){
- $hrefNodes = $child->getElementsByTagName("href");
+ $hrefNodes = $child->getElementsByTagName("href");
- $metadataArray["iconurl"] = $href;
+ $metadataArray["iconurl"] = $href;
- return $metadataArray;
+ return $metadataArray;
* Given a "Point" node, this function returns the geometry (KMLPoint)
* from within the node.
@@ -307,7 +332,7 @@
$geomString = $coordinatesNode->nodeValue;
return new KMLPoint($geomString, 4326);
* Given a "LineString" node, this function returns the geometry (KMLLine)
@@ -317,7 +342,7 @@
return new KMLLine($geomString, 4326);
* Given a "Polygon" node, this function returns the geometry (KMLPolygon)
@@ -326,21 +351,21 @@
$polygon = null;
// create new KMLPolygon
- if (mb_strtoupper($this->sepNameSpace($child->nodeName)) == "EXTERIOR" ||
+ if (mb_strtoupper($this->sepNameSpace($child->nodeName)) == "EXTERIOR" ||
mb_strtoupper($this->sepNameSpace($child->nodeName)) == "OUTERBOUNDARYIS") {
// create a new Linear Ring
$outerBoundary = $this->getGeometryFromLinearRingNode($child);
$polygon = new KMLPolygon($outerBoundary);
if ($polygon !== null) {
// append inner boundaries to KMLPolygon
- if (mb_strtoupper($this->sepNameSpace($child->nodeName)) == "INTERIOR" ||
+ if (mb_strtoupper($this->sepNameSpace($child->nodeName)) == "INTERIOR" ||
mb_strtoupper($this->sepNameSpace($child->nodeName)) == "INNERBOUNDARYIS") {
$innerBoundary = $this->getGeometryFromLinearRingNode($child);
@@ -350,9 +375,9 @@
return $polygon;
- * Given a "OuterBoundaryIs" or "InnerBoundaryIs" node, this function
+ * Given a "OuterBoundaryIs" or "InnerBoundaryIs" node, this function
* returns the geometry (KMLLinearRing) within the child node named "linearring"
private function getGeometryFromLinearRingNode ($node) {
@@ -366,14 +391,14 @@
return null;
* Checks if the child nodes of a given KML node contains any geometries and
* returns an array of geometries (KMLPoint, KMLPolygon, KMLLinestring and KMLMultigeometry)
private function getGeometryArrayFromPlacemarkOrMultigeometryNode ($node) {
$geometryArray = array();
foreach($children as $child) {
if (mb_strtoupper($this->sepNameSpace($child->nodeName)) == "POINT") {
@@ -388,9 +413,9 @@
elseif (mb_strtoupper($this->sepNameSpace($child->nodeName)) == "MULTIGEOMETRY") {
$geometryArray = $this->getGeometryArrayFromPlacemarkOrMultigeometryNode($child);
$multigeometry = new KMLMultiGeometry();
- $multigeometry->append($geometryArray[$i]);
+ $multigeometry->append($geometryArray[$i]);
array_push($geometryArray, $multigeometry);
@@ -405,8 +430,8 @@
private function getCoordinatesNode ($node) {
- if (mb_strtoupper($this->sepNameSpace($child->nodeName)) == "POSLIST" ||
- mb_strtoupper($this->sepNameSpace($child->nodeName)) == "POS" ||
+ if (mb_strtoupper($this->sepNameSpace($child->nodeName)) == "POSLIST" ||
+ mb_strtoupper($this->sepNameSpace($child->nodeName)) == "POS" ||
mb_strtoupper($this->sepNameSpace($child->nodeName)) == "COORDINATES") {
return $child;
@@ -415,13 +440,13 @@
- $c = mb_strpos($s,":");
+ $c = mb_strpos($s,":");
if($c>0){
return mb_substr($s,$c+1);
else{
return $s;
Modified: trunk/mapbender/http/extensions/togeojson.js
--- trunk/mapbender/http/extensions/togeojson.js 2015-03-02 13:27:54 UTC (rev 9162)
+++ trunk/mapbender/http/extensions/togeojson.js 2015-03-09 12:43:13 UTC (rev 9163)
@@ -211,6 +211,7 @@
return gj;
gpx: function(doc, o) {
+ // console.log('test');
var i,
tracks = get(doc, 'trk'),
routes = get(doc, 'rte'),
Modified: trunk/mapbender/http/extensions/togpx.js
--- trunk/mapbender/http/extensions/togpx.js 2015-03-02 13:27:54 UTC (rev 9162)
+++ trunk/mapbender/http/extensions/togpx.js 2015-03-09 12:43:13 UTC (rev 9163)
@@ -2,6 +2,7 @@
var JXON = require("jxon");
function togpx( geojson, options ) {
+ console.log(geojson);
options = (function (defaults, options) {
for (var k in defaults) {
if (options.hasOwnProperty(k))
@@ -10,7 +11,6 @@
return defaults;
creator: "togpx",
- metadata: undefined,
featureTitle: get_feature_title,
featureDescription: get_feature_description,
featureLink: undefined
@@ -28,6 +28,8 @@
if (props.name)
return props.name;
+ if (props.title)
+ return props.title;
if (props.ref)
return props.ref;
if (props.id)
@@ -65,7 +67,7 @@
gpx.gpx["@creator"] = options.creator;
if (options.metadata)
gpx.gpx["metadata"] = options.metadata;
var features;
if (geojson.type === "FeatureCollection")
features = geojson.features;
@@ -264,7 +266,7 @@
if (oParentObj instanceof String || oParentObj instanceof Number || oParentObj instanceof Boolean) {
oParentEl.appendChild(oXMLDoc.createTextNode(oParentObj.toString())); /* verbosity level is 0 */
} else if (oParentObj.constructor === Date) {
- oParentEl.appendChild(oXMLDoc.createTextNode(oParentObj.toGMTString()));
+ oParentEl.appendChild(oXMLDoc.createTextNode(oParentObj.toGMTString()));
for (var sName in oParentObj) {
@@ -296,10 +298,10 @@
this.build = function (oXMLParent, nVerbosity /* optional */, bFreeze /* optional */, bNesteAttributes /* optional */) {
var _nVerb = arguments.length > 1 && typeof nVerbosity === "number" ? nVerbosity & 3 : /* put here the default verbosity level: */ 1;
- return createObjTree(oXMLParent, _nVerb, bFreeze || false, arguments.length > 3 ? bNesteAttributes : _nVerb === 3);
+ return createObjTree(oXMLParent, _nVerb, bFreeze || false, arguments.length > 3 ? bNesteAttributes : _nVerb === 3);
- this.unbuild = function (oObjTree) {
+ this.unbuild = function (oObjTree) {
var oNewDoc = document.implementation.createDocument("", "", null);
loadObjTree(oNewDoc, oNewDoc, oObjTree);
return oNewDoc;
@@ -316,4 +318,4 @@
},{}]},{},[1])
(1)
\ No newline at end of file
Modified: trunk/mapbender/http/extensions/tokml.js
--- trunk/mapbender/http/extensions/tokml.js 2015-03-02 13:27:54 UTC (rev 9162)
+++ trunk/mapbender/http/extensions/tokml.js 2015-03-09 12:43:13 UTC (rev 9163)
@@ -4,7 +4,7 @@
encode = strxml.encode;
module.exports = function tokml(geojson, options) {
options = options || {
documentName: undefined,
documentDescription: undefined,
@@ -18,6 +18,7 @@
tag('Document',
documentName(options) +
documentDescription(options) +
+ documentMetadata(geojson,options) + // add metadata to feautureCollections
root(geojson, options)
), [['xmlns', 'http://www.opengis.net/kml/2.2']]);
@@ -64,6 +65,17 @@
return (options.documentName !== undefined) ? tag('name', options.documentName) : '';
+function documentMetadata(geojson,options) {
+ var metadata = {};
+ for(key in geojson['@context']){
+ metadata[key]= geojson['@context'][key];
+ extendeddata(metadata);
+ return extendeddata(metadata);
function documentDescription(options) {
return (options.documentDescription !== undefined) ? tag('description', options.documentDescription) : '';
@@ -139,6 +151,7 @@
// ## Data
function extendeddata(_) {
return tag('ExtendedData', pairs(_).map(data).join(''));
@@ -217,6 +230,15 @@
* @param {string} el element name
+ * @param {array} attributes array of pairs
+ * @returns {string}
+function tagOpen(el, attributes) {
+ return '<' + el + attr(attributes) + '>';
+ * @param {string} el element name
* @param {string} contents innerXML
* @returns {string}
@@ -238,4 +260,4 @@
},{}]},{},[1])
(1)
Modified: trunk/mapbender/http/javascripts/mod_savewmc.js
--- trunk/mapbender/http/javascripts/mod_savewmc.js 2015-03-02 13:27:54 UTC (rev 9162)
+++ trunk/mapbender/http/javascripts/mod_savewmc.js 2015-03-09 12:43:13 UTC (rev 9163)
@@ -219,7 +219,6 @@
// title
$("#" + options.id + "_saveWMCForm").dialog('option', 'title', translatedI18nObj.title);
// form
@@ -440,7 +439,6 @@
Mapbender.events.init.register(function () {
var t = translatedI18nObj;
var savewmcHtml = '<div id="' + options.id + '_saveWMCForm" ' +
'title="' + translatedI18nObj.title + '">' +
@@ -466,6 +464,7 @@
buttons: getButtons()
+ // set uuid
// Mapbender.events.localize.register(function () {
Modified: trunk/mapbender/http/javascripts/mod_savewmc.php
--- trunk/mapbender/http/javascripts/mod_savewmc.php 2015-03-02 13:27:54 UTC (rev 9162)
+++ trunk/mapbender/http/javascripts/mod_savewmc.php 2015-03-09 12:43:13 UTC (rev 9163)
@@ -84,10 +84,7 @@
$labelCategories = $translatedI18nObj["labelCategories"];
echo <<<HTML
-//TODO: add input for uuid,title already there. created and updated need no input.just save it to the database...
-var wmc_uuid = UUID.genV4().toString();
var wmcSaveFormHtml = '<form><fieldset>' +
'<label for="{$e_id}_wmctype">{$labelNewOrOverwrite}</label>' +
'<select class="ui-corner-all" id="{$e_id}_wmctype">' +
@@ -99,8 +96,6 @@
'<label for="{$e_id}_wmckeywords">{$labelKeywords}</label>' +
'<input id="{$e_id}_wmckeywords" type="text" class="text ui-widget-content ui-corner-all" />' +
'<input id="{$e_id}_wmc_id" type="hidden" />' +
- '<input id="{$e_id}_wmc_id" type="hidden" />' +
- '<input id="{$e_id}_wmc_uuid" value={wmc_uuid} />' +
'</fieldset><fieldset id="{$e_id}_isoTopic_cat"><legend>{$labelCategories}' +
'</legend>' +
'{$saveWmcCategoryString}' +
Modified: trunk/mapbender/http/php/kmlToGeoJSON.php
--- trunk/mapbender/http/php/kmlToGeoJSON.php 2015-03-02 13:27:54 UTC (rev 9162)
+++ trunk/mapbender/http/php/kmlToGeoJSON.php 2015-03-09 12:43:13 UTC (rev 9163)
@@ -1,6 +1,6 @@
<?php
# http://www.mapbender.org/index.php/Administration
@@ -23,32 +23,38 @@
//FIXME: what about projections?
//header("Content-Type: text/x-json");
if(isset($_REQUEST["url"])){
- $url = $_REQUEST["url"];
+ $url = $_REQUEST["url"];
}else{
- echo("{}");
- exit;
+ echo("{}");
+ exit;
$kml = new KML();
$con = new connector();
-$kmlString = $con->load($url);
+$content = $con->load($url);
try {
- if($kml->parseKml($kmlString)){
- $kml->transform($_REQUEST["targetEPSG"]);
- $geojson = $kml->toGeoJSON();
- echo $geojson;
- }else{
- echo("{}");
+ if(preg_match('/.kml$/', $url)) {
+ header("Content-Type: text/plain");
+ if($kml->parseKml($content)){
+ $geojson = $kml->createGeoJSON();
+ echo $geojson;
+ }else{
+ echo("{}");
+ if(preg_match('/.(json|geojson)$/', $url)) {
+ echo $content;
+ if(preg_match('/.(xml|gpx)$/', $url)) {
+ echo $content;
} catch (Exception $e) {
- echo($e);
- die;
+ echo($e);
+ die;
Modified: trunk/mapbender/http/php/mb_metadata_uploadLayerPreview.php
--- trunk/mapbender/http/php/mb_metadata_uploadLayerPreview.php 2015-03-02 13:27:54 UTC (rev 9162)
+++ trunk/mapbender/http/php/mb_metadata_uploadLayerPreview.php 2015-03-09 12:43:13 UTC (rev 9163)
@@ -50,10 +50,12 @@
$images_orig = ImageCreateFromJPEG($image);
break;
case 'jpeg':
break;
case 'png':
$images_orig = ImageCreateFrompng($image);
@@ -78,7 +80,7 @@
// create new image with the calculated size
$images_target = ImageCreateTrueColor(200, 200);
//fill the new image with transparency background
- $color = imagecolorallocatealpha($images_target, 255, 255, 255, 0); //fill transparent back
+ $color = imagecolorallocatealpha($images_target, 255, 255, 255, 0); //fill white background
imagefill($images_target, 0, 0, $color);
imagealphablending( $images_target, false );
imagesavealpha($images_target, true);
@@ -120,7 +122,7 @@
Modified: trunk/mapbender/http/php/mod_GetPublishedData.php
--- trunk/mapbender/http/php/mod_GetPublishedData.php 2015-03-02 13:27:54 UTC (rev 9162)
+++ trunk/mapbender/http/php/mod_GetPublishedData.php 2015-03-09 12:43:13 UTC (rev 9163)
@@ -1,4 +1,6 @@
<?php
+ini_set('display_errors', 'On');
+error_reporting(E_ALL);
* @version Changed: ### 2015-02-23 14:00:42 UTC ###
@@ -46,72 +48,58 @@
// create and numerically indexed array
$kmls = array_values($myWmc->generalExtensionArray["KMLS"]);
-//parse the geojson from the array
-$geoJson = $kmls[0]["data"];
//create the fileName
$file = "myDataCollection.".$outputFormat;
-// set headers to force the download
-header("Content-Disposition: attachment; filename=" . urlencode($file));
-header("Content-Type: application/force-download");
-header("Content-Type: application/octet-stream");
-header("Content-Type: application/download");
+if (sizeof($kmls) > 1) {
+ # create a file for each featureCollection and push them in a zip
-// handle the different outputformat
-if ($outputFormat == 'geojson') {
- // create the json-file
- $geoJsonFile = '../tmp/myDataCollection.geojson';
- // put the contents to the created file
- file_put_contents($geoJsonFile, json_encode($geoJson));
- // create a string from the created file
- $fileString = file_get_contents('../tmp/myDataCollection.geojson');
- // return the string
- echo $fileString;
- die;
+ $zip = new ZipArchive;
+ $zipName = '../tmp/myDataCollection.zip';
+ $fileName = "myDataCollection.zip";
-}elseif ($outputFormat == 'gpx') {
- //convert geojson to kml
+ if ($zip->open($zipName, ZIPARCHIVE::CREATE)=== TRUE) {
+ // counting filenames
+ $fileCounter = 1;
+ // loop over every featureCollection
+ foreach ($kmls as $key => $value) {
- //create the geojson-file temporary
- $temp_geojson = '../tmp/myDataCollection.geojson';
- // write the file
- file_put_contents($temp_geojson,json_encode($geoJson));
- //transform the geojson to kml
- $unique = '../tmp/myDataCollection';
- $fGeojson = $unique.".geojson";
- $fKml = $unique.".kml";
- $pathOgr = '/usr/bin/ogr2ogr';
- // execute ogr2ogr
- $exec = $pathOgr.' -f KML '.$fKml.' '.$fGeojson;
- exec(escapeshellcmd($exec));
- //enter location of KML file here
- $kml = "../tmp/myDataCollection.kml";
- // create gpx from kml
- kml_to_gpx($kml);
- die;
+ $geoJson = $kmls[$fileCounter-1]["data"];
+ $dataFile = createFile($outputFormat,$geoJson);
+ $zip->addFromString('myFeatureCollection_'.$fileCounter.'.'.$outputFormat,$dataFile);
+ // increment the counter
+ $fileCounter +=1;
-}elseif ($outputFormat == 'kml') {
- // write the file
- //transform the file to kml
- //execute ogr2ogr to transfrom json to kml
- // create string from kml-file
- $fileString = file_get_contents('../tmp/myDataCollection.kml');
- //return the string
- echo $fileString;
- die;
+ $zip->close();
+// set the headers to return a zip to the client
+header('Content-Type: application/zip');
+header('Content-Disposition: attachment; filename="'.$filename.'"');
+header('Content-Length: '.filesize($zipName) );
+readfile($zipName);
+//remove zip from harddisk
+exec(escapeshellcmd('rm ../tmp/myDataCollection.zip'));
+die;
+} else {
+ // set headers to force the download for a single file
+ header("Content-Disposition: attachment; filename=" . urlencode($file));
+ header("Content-Type: application/force-download");
+ header("Content-Type: application/octet-stream");
+ header("Content-Type: application/download");
+ //parse the geojson from the array
+ $geoJson = $kmls[0]["data"];
+ echo $dataFile;
* converts a kml-file into a gpx-file
* @param string $u the file location
@@ -171,7 +159,7 @@
// placemarks
$names = array();
foreach ($dom_kml->getElementsByTagName('Placemark') as $placemark) {
- //name
+ // var_dump('sdafsdaf');
foreach ($placemark->getElementsByTagName('name') as $name) {
$name = $name->nodeValue;
//check if the key exists
@@ -276,9 +264,50 @@
+ foreach ($placemark->getElementsByTagName('Polygon') as $lineString) {
+ foreach ($lineString->getElementsByTagName('coordinates') as $coordinates) {
+ //add the new track
+ $gpx_trk = $dom_gpx->createElement('trk');
+ $gpx_trk = $gpx->appendChild($gpx_trk);
+ $gpx_name = $dom_gpx->createElement('name');
+ $gpx_name = $gpx_trk->appendChild($gpx_name);
+ $gpx_name_text = $dom_gpx->createTextNode($name);
+ $gpx_name->appendChild($gpx_name_text);
+ $gpx_trkseg = $dom_gpx->createElement('trkseg');
+ $gpx_trkseg = $gpx_trk->appendChild($gpx_trkseg);
+ $coordinates = $coordinates->nodeValue;
+ $coordinates = preg_split("/[\s\r\n]+/", $coordinates); //split the coords by new line
+ foreach ($coordinates as $coordinate) {
+ $latlng = explode(",", $coordinate);
+ if (($lat = $latlng[1]) && ($lng = $latlng[0])) {
+ $gpx_trkpt = $dom_gpx->createElement('trkpt');
+ $gpx_trkpt = $gpx_trkseg->appendChild($gpx_trkpt);
+ $gpx_trkpt_lat = $dom_gpx->createAttribute('lat');
+ $gpx_trkpt->appendChild($gpx_trkpt_lat);
+ $gpx_trkpt_lat_text = $dom_gpx->createTextNode($lat);
+ $gpx_trkpt_lat->appendChild($gpx_trkpt_lat_text);
+ $gpx_trkpt_lon = $dom_gpx->createAttribute('lon');
+ $gpx_trkpt->appendChild($gpx_trkpt_lon);
+ $gpx_trkpt_lon_text = $dom_gpx->createTextNode($lng);
+ $gpx_trkpt_lon->appendChild($gpx_trkpt_lon_text);
+ $gpx_time = $dom_gpx->createElement('time');
+ $gpx_time = $gpx_trkpt->appendChild($gpx_time);
+ $gpx_time_text = $dom_gpx->createTextNode(utcdate());
+ $gpx_time->appendChild($gpx_time_text);
header("Content-Type: text/xml");
- echo $dom_gpx->saveXML();
+ return $dom_gpx->saveXML();
@@ -291,3 +320,63 @@
function utcdate() {
return gmdate("Y-m-d\Th:i:s\Z");
+function createFile ($outputFormat, $geoJson) {
+ // handle the different outputformat
+if ($outputFormat == 'geojson') {
+ // create the json-file
+ $geoJsonFile = '../tmp/myDataCollection.geojson';
+ // put the contents to the created file
+ file_put_contents($geoJsonFile, json_encode($geoJson));
+ // create a string from the created file
+ $fileString = file_get_contents('../tmp/myDataCollection.geojson');
+ // return the string
+ return $fileString;
+ die;
+}elseif ($outputFormat == 'gpx') {
+ //convert geojson to kml
+ //create the geojson-file temporary
+ $temp_geojson = '../tmp/myDataCollection.geojson';
+ // write the file
+ file_put_contents($temp_geojson,json_encode($geoJson));
+ //transform the geojson to kml
+ $unique = '../tmp/myDataCollection';
+ $fGeojson = $unique.".geojson";
+ $fKml = $unique.".kml";
+ $pathOgr = '/usr/bin/ogr2ogr';
+ // execute ogr2ogr
+ $exec = $pathOgr.' -f KML '.$fKml.' '.$fGeojson;
+ exec(escapeshellcmd($exec));
+ //enter location of KML file here
+ $kml = "../tmp/myDataCollection.kml";
+ // create gpx from kml
+ return kml_to_gpx($kml);
+ die;
+}elseif ($outputFormat == 'kml') {
+ // write the file
+ //transform the file to kml
+ //execute ogr2ogr to transfrom json to kml
+ // create string from kml-file
+ $fileString = file_get_contents('../tmp/myDataCollection.kml');
+ //return the string
+ die;
Modified: trunk/mapbender/http/php/transformgeojson.php
--- trunk/mapbender/http/php/transformgeojson.php 2015-03-02 13:27:54 UTC (rev 9162)
+++ trunk/mapbender/http/php/transformgeojson.php 2015-03-09 12:43:13 UTC (rev 9163)
@@ -21,6 +21,7 @@
header("Content-Type: application/json");
$json = file_get_contents("php://input");
+// var_dump($json);die;
try {
$json = json_decode($json);
Modified: trunk/mapbender/http/php/uploadKml.php
--- trunk/mapbender/http/php/uploadKml.php 2015-03-02 13:27:54 UTC (rev 9162)
+++ trunk/mapbender/http/php/uploadKml.php 2015-03-09 12:43:13 UTC (rev 9163)
@@ -23,12 +23,12 @@
$kml = new KML();
$content = file_get_contents($_FILES['kml']['tmp_name']);
try {
if(preg_match('/.kml$/', $_FILES['kml']['name'])) {
+ // var_dump($geojson);die;
echo $geojson;
}else{
echo("{}");
@@ -36,9 +36,11 @@
if(preg_match('/.(json|geojson)$/', $_FILES['kml']['name'])) {
+ // var_dump($content);die;
echo $content;
if(preg_match('/.(xml|gpx)$/', $_FILES['kml']['name'])) {
echo $content;
Modified: trunk/mapbender/http/plugins/kmlTree.js
--- trunk/mapbender/http/plugins/kmlTree.js 2015-03-02 13:27:54 UTC (rev 9162)
+++ trunk/mapbender/http/plugins/kmlTree.js 2015-03-09 12:43:13 UTC (rev 9163)
@@ -160,9 +160,9 @@
$('#dataExportDialog').remove();
- var exportHtmlsdfdsf = '<div id="exportHtml">' + '<form>' + '<label class="export-format-kml">KML<input type="radio" name="export-format" value="kml" checked="checked"></input></label>' + '<label class="export-format-kml">KML<input type="radio" name="export-format" value="kml" checked="checked"></input></label>' + '<label class="export-format-kml">KML<input type="radio" name="export-format" value="kml" checked="checked"></input></label><br><br>' +
- '<img src="../img/osgeo_graphics/geosilk/link22.png"/>' + '<label class="export-format-gpx">GPX</label>' + '<label class="export-format-geojson">geoJSON</label><br></br>' +
- '<a download="myfeatures.kml" href="#" class="digitize-image digitize-export" style="float: left;"></a>' + '</form>' + '</div>';
+ // var exportHtmlsdfdsf = '<div id="exportHtml">' + '<form>' + '<label class="export-format-kml">KML<input type="radio" name="export-format" value="kml" checked="checked"></input></label>' + '<label class="export-format-kml">KML<input type="radio" name="export-format" value="kml" checked="checked"></input></label>' + '<label class="export-format-kml">KML<input type="radio" name="export-format" value="kml" checked="checked"></input></label><br><br>' +
+ // '<img src="../img/osgeo_graphics/geosilk/link22.png"/>' + '<label class="export-format-gpx">GPX</label>' + '<label class="export-format-geojson">geoJSON</label><br></br>' +
+ // '<a download="myfeatures.kml" href="#" class="digitize-image digitize-export" style="float: left;"></a>' + '</form>' + '</div>';
var exportHtml = '<div id="exportHtml"><table><tbody>' +
'<tr><td>KML:</td><td><label class="export-format-kml exportDatasetIcon" style="padding-top:11px;"></label></td><td class="exportDataLink kml" wmcId="'+wmc_id+'"outputFormat="kml"><img src="../img/osgeo_graphics/geosilk/link22.png"/></td></tr>' +
'<tr><td>GPX:</td><td><label class="export-format-gpx exportDatasetIcon" style="padding-top:11px;"></label></td><td class="exportDataLink gpx" wmcId="'+wmc_id+'"outputFormat="gpx"><img src="../img/osgeo_graphics/geosilk/link22.png"/></td></tr>' +
@@ -539,10 +539,10 @@
$('#kml-load-tabs').tabs();
$('#kml-load-tabs').find('button.add').bind('click', function() {
- $('#mapframe1').kml({
+ $('#mapframe1').kml({ //TODO: what is happening?
url: $('#kml-load-tabs').find('.kmlurl').val()
- $(dlg).dialog('destroy');
+ // $(dlg).dialog('destroy');
$('#kml-load-tabs').find('button.add-kml').bind('click', function() {
var kml = $('#mapframe1').data('kml');
@@ -550,30 +550,42 @@
if (title == '') {
return;
- kml.addLayer(title, {
- features: [],
- type: 'FeatureCollection'
+ kml.addLayer(title,{
+ "@context": {uuid: UUID.genV4().toString(), created: new Date().toISOString() ,title: title, updated: new Date().toISOString()},
+ type: 'FeatureCollection',
+ features: []
var ifr = $('iframe[name="kml-upload-target"]')[0];
var onloadfun = function() {
ifr.onload = null;
- var txt = $(this).contents().find('pre').text();
+ var txt = $(this).contents().find('pre').text(); // result von uploadKML.php
var data;
try {
data = JSON.parse(txt);
} catch (e) {
var xml = new DOMParser().parseFromString(txt, 'application/xml');
data = toGeoJSON.gpx(xml);
- var name = $('#kml-from-upload input[type="file"]').val();
- if (name.match(/[\\]([^\\]+)/g)) {
- name = name.match(/[\\]([^\\]+)/g);
+ var name;
+ if(data.hasOwnProperty('@context')){
+ name = data['@context']['title'];
+ kml.addLayer(name, data);
+ }else{
+ name = $('#kml-from-upload input[type="file"]').val();
+ if (name.match(/[\\]([^\\]+)/g)) {
+ name = name.match(/[\\]([^\\]+)/g);
+ name = name[name.length - 1];
- name = name[name.length - 1];
- kml.addLayer(name, data);
$('#kml-from-upload form').bind('submit', function() {
@@ -604,7 +616,6 @@
o.$target.bind('kml:loaded', function(e, obj) {
//console.log(obj);
var checked = obj.display ? 'checked="checked"' : '';
title = obj.url;
if (obj.refreshing) {
$KMLfolder.find('ul li[title="' + title + '"]').remove();
@@ -627,7 +638,22 @@
if (multi) {
toggle = '<button class="toggle" name="toggle" value="toggle"></button>';
- title = obj.data.features[i].properties.name;
+ if(obj.data.features[i].properties.name){
+ title = obj.data.features[i].properties.name;
+ } else if(obj.data.features[i].properties.title) {
+ title = obj.data.features[i].properties.title;
+ } else {
+ title = 'Title undefined';
+ // title = obj.data.features[i].properties.name;
abbrevTitle = title.length < 20 ? title : title.substr(0, 17) + "...";
var displ = obj.data.features[i].display === true || obj.data.features[i].display === undefined;
$feature = $('<li idx="' + i + '" title="' + title + '"><button class="digitize-menu-arrow"></button>' + toggle + '<input type="checkbox" ' + (displ ? 'checked="checked"' : '') + '/><div class="style-preview" style="width: 20px; height: 20px; display: inline;"></div><a href="#" >' + abbrevTitle + '</a></li>');
Modified: trunk/mapbender/http/plugins/mb_digitize_widget.php
--- trunk/mapbender/http/plugins/mb_digitize_widget.php 2015-03-02 13:27:54 UTC (rev 9162)
+++ trunk/mapbender/http/plugins/mb_digitize_widget.php 2015-03-09 12:43:13 UTC (rev 9163)
@@ -569,7 +569,8 @@
return function() {
if ($(this).hasClass('editFeatureCollection')) {
+ // kml = $('#mapframe1').data('kml');
+ var oldCollectionName = feature['@context'].title;
var featureCollAttrDlg = $('<div id="featureCollAttrDlg"></div>').dialog({
title: "Featurecollection attributes ",// of "+ url,
width: 400,
@@ -587,17 +588,65 @@
var featureCollectionContent = "<div class='digitize-image digitize-style'></div>"+
"<br><br>"+
- "<div><table>"+
- "<tr><td>uuid</td><td><input type='text' value='test'/></td></tr>"+
- "<tr><td>title</td><td><input type='text' value='test'/></td></tr>"+
- "<tr><td>created</td><td><input type='text' value='test'/></td></tr>"+
- "<tr><td>updated</td><td><input type='text' value='test'/></td></tr>"+
+ "<div><table id='featureCollTbl'>"+
+ // "<tr><td>uuid</td><td><input type='text' name='uuid' value='"+feature['@context'].uuid+"'/></td></tr>"+
+ // "<tr><td>title</td><td><input type='text' name='title' value='"+feature['@context'].title+"'/></td></tr>"+
+ // "<tr><td>created</td><td><input type='text' name='created' value='"+feature['@context'].created+"'/></td></tr>"+
+ // "<tr><td>updated</td><td><input type='text' name='updated' value='"+feature['@context'].updated+"'/></td></tr>"+
"</table></div>"+
"<br><br/>"+
"<div class='digitize-image digitize-add'></div>"+
"<div class='digitize-image digitize-save'></div>";
$('#featureCollAttrDlg').append(featureCollectionContent);
+ $.each(feature['@context'], function(index, val) {
+ $('#featureCollTbl').append("<tr><td>"+index+"</td><td><input type='text' name='"+index+"' value='"+val+"'/></td></tr>");
+ featureCollAttrDlg.find('.digitize-save').bind('click', function() {
+ featureCollAttrDlg.find('table input').each(function() {
+ var k = $(this).attr('name');
+ var v = $(this).val();
+ if(k) {
+ feature['@context'][k] = v;
+ feature['@context'].updated = new Date().toISOString();
+ // save the changed feature in a new object
+ if ( $('#mapframe1').data('kml')._kmls[oldCollectionName].url != $('#mapframe1').data('kml')._kmls[oldCollectionName].data['@context'].title ) {
+ $('#mapframe1').data('kml')._kmls[feature['@context'].title] = $('#mapframe1').data('kml')._kmls[oldCollectionName];
+ $('#mapframe1').data('kml')._kmls[feature['@context'].title].url = $('#mapframe1').data('kml')._kmls[feature['@context'].title].data['@context'].title;
+ kml.remove(url);
+ $("#kmlTree>li>ul>li[title='"+url+"']").remove();
+ url = $('#mapframe1').data('kml')._kmls[feature['@context'].title].url;
+ featureCollAttrDlg.dialog('close');
+ editDialog.dialog('close');
+ kml.refresh(url);
+ } else {
+ kml.refresh(url);
+ // var preview = attributesDialog.find('.digitize-preview').html('').get(0);
+ // kml.renderPreview(feature, preview);
+ // add row
+ featureCollAttrDlg.find('.digitize-add').bind('click', function() {
+ var newRow = $('<tr><td><input type="text"></input></td><td><input class="newInputValue" name="" type="text"></input></td></tr>');
+ $(newRow).find('.newInputValue').bind('keyup',function(){
+ $(this).attr('name',$(this).val());
+ featureCollAttrDlg.find('table').append(newRow);
+ newRow.find('input').first().bind('change', function() {
+ newRow.find('input').last().attr('name', $(this).val());
}else{
attributesDialog.dialog('open');
@@ -628,6 +677,8 @@
feature.properties.updated = new Date().toISOString();
+ //get parent and change updated
+ $('#mapframe1').data('kml')._kmls[url].data['@context'].updated = new Date().toISOString();
attributesDialog.dialog('close');
@@ -773,7 +824,8 @@
// get the featureCollection data
var url = $link.parent().attr('title');
var featureCollection = $('#mapframe1').data('kml')._kmls[url].data;
- digitizeDialog.find('.digitize-attributes').bind('click', editAttributes(featureCollection, kml, url));
+ var kml = $('#mapframe1').data('kml');
+ digitizeDialog.find('.digitize-attributes').bind('click',editAttributes(featureCollection, kml , url));
digitizeDialog.find('.digitize-remove').bind('click', function() {
Modified: trunk/mapbender/http/plugins/mb_loadkmlgeorss.js
--- trunk/mapbender/http/plugins/mb_loadkmlgeorss.js 2015-03-02 13:27:54 UTC (rev 9162)
+++ trunk/mapbender/http/plugins/mb_loadkmlgeorss.js 2015-03-09 12:43:13 UTC (rev 9163)
@@ -2,27 +2,27 @@
* Package: load_georsskml
* Description:
- * This element enables you to load GeoRSS or KML temporary to a Mapbender application.
- * The features will be displayed in the mapframe. The result will also be displayed in a result table.
+ * This element enables you to load GeoRSS or KML temporary to a Mapbender application.
+ * The features will be displayed in the mapframe. The result will also be displayed in a result table.
* The module enables you to load more than one GeoRSS/KML. Every resultset will be displayed in a result table.
* As long as the result table is open. The features are shown in the map.
* Files:
* - ../http/plugins/mb_loadkmlgeorss.js>
* SQL:
- * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,
- * > e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content,
+ * > INSERT INTO gui_element(fkey_gui_id, e_id, e_pos, e_public, e_comment, e_title, e_element,
+ * > e_src, e_attributes, e_left, e_top, e_width, e_height, e_z_index, e_more_styles, e_content,
* > e_closetag, e_js_file, e_mb_mod, e_target, e_requires, e_url) VALUES('<application_name>',
* >'load_georsskml',2,1,'','Load GeoRSS or KML','img','../img/georss_logo_off.png','',750,10,
* > 24,24,NULL ,'','','','../plugins/mb_loadkmlgeorss.js','','','','');
- * > INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type)
- * > VALUES('<application_name>', 'load_georsskml', 'buffer', '100',
+ * > INSERT INTO gui_element_vars(fkey_gui_id, fkey_e_id, var_name, var_value, context, var_type)
+ * > VALUES('<application_name>', 'load_georsskml', 'buffer', '100',
* > 'how much space to leave around a feature when zooming to it ' ,'var');
- * > VALUES('<application_name>', 'load_georsskml', 'position', '',
+ * > VALUES('<application_name>', 'load_georsskml', 'position', '',
* > 'position where the result frame is displayed, see the [http://docs.jquery.com/UI/Dialog |jquery UI documentation] for possible values' ,'var');
* Help:
@@ -30,20 +30,20 @@
* Maintainer:
* http://www.mapbender.org/User:Karim_Malhas
* Parameters:
* buffer - *[optional]* var, how much space to leave around a feature when zooming to it
* position - *[optional]* var, position where the result frame is displayed
* Requires:
* License:
* Copyright (c) 2009, Open Source Geospatial Foundation
- * This program is dual licensed under the GNU General Public License
- * and Simplified BSD license.
+ * This program is dual licensed under the GNU General Public License
+ * and Simplified BSD license.
* http://svn.osgeo.org/mapbender/trunk/mapbender/license/license.txt
options.buffer = options.buffer || 0.10;
@@ -85,13 +85,13 @@
autoOpen: false,
height: 240,
width: 400,
- buttons: {
+ buttons: {
"OK" : function(){
var url = $('#' + options.id + '_url').val();
$('#' + options.id + '_url').val("");
var $dialog = $(this);
$dialog.dialog("close");
var format = $("input:checked",$dialog).val();
var endpointURL = "";
if( format == "GeoRSS"){
@@ -104,7 +104,6 @@
type: "POST",
dataType: "json",
success: function(data,textStatus,xhr){
if(data.errorMessage){
$("<div class='labelLoadError'>"+ translatedI18nObject.labelLoadError +"<div>").dialog({ buttons: {"OK":function(){ $(this).dialog("close"); } } } );
return;
@@ -125,8 +124,8 @@
var map = $('#mapframe1').mapbender();
//title = feature.properties.title || feature.properties.name || translatedI18nObject.labelUntitled;
var geomArray = new GeometryArray();
var highlightArray = [];
geomArray.importGeoJSON(data);
@@ -140,10 +139,10 @@
icon = g.e.getElementValueByName("Mapbender:icon");
title = g.e.getElementValueByName("title");
name = g.e.getElementValueByName("name");
if(name != "false" && name !== false){
title = name;
if(icon == "false" || icon === false){
g.e.setElement("Mapbender:iconOffsetX", -10);
g.e.setElement("Mapbender:iconOffsetY", -34);
@@ -203,17 +202,17 @@
$tableDialog.append($table);
$table.dataTable({"bJQueryUI": true ,
"oLanguage":{
"sUrl":"../extensions/dataTables-1.5/lang/"+Mapbender.languageId +".txt"
$dialog.dialog('close');
error: function(xhr, ajaxOptions,error){
- $("<div class='labelLoadError'>"+ translatedI18nObject.labelLoadError +"</div>").dialog({ buttons: {"OK":function(){ $(this).dialog("close"); }} });
+ $("<div class='labelLoadError'>"+ translatedI18nObject.labelLoadError +"</div>").dialog({ buttons: {"OK":function(){ $(this).dialog("close"); }} });
@@ -224,8 +223,8 @@
Mapbender.events.localize.register(function(){
Mapbender.modules.i18n.queue(options.id, originalI18nObject, function(translatedI18nObject){
- $('.labelLoadError').text(translatedI18nObject.labelLoadError);
- $('.labelUrlBox').text(translatedI18nObject.labelUrlBox);
+ $('.labelLoadError').text(translatedI18nObject.labelLoadError);
+ $('.labelUrlBox').text(translatedI18nObject.labelUrlBox);
@@ -235,7 +234,7 @@
$('#mapframe1').click(function(e){
- var pos = map.getMousePosition(e);
+ var pos = map.getMousePosition(e);
var clickPoint = map.convertPixelToReal(new Point(pos.x,pos.y));
var feed = null;
var requestGeometries = [];
@@ -243,7 +242,7 @@
// - Points are represented as icons, so we check if the click is on an icon
// - Polygons don't have a dom Element when not using Rapheljs, so we go ask postgis
// after that's finished the results are merged and displayed in a box
- var pointGeometries = {};
+ var pointGeometries = {};
var g,h,nodes = null;
for (var i in that.feeds){
feed = that.feeds[i] ;
@@ -251,12 +250,12 @@
for(var j = 0; j < feed.geomArray.count(); j++){
g = feed.geomArray.get(j);
- h = feed.highlightArray[j];
+ h = feed.highlightArray[j];
nodes = h.getNodes();
if(g.geomType == geomType.point){
// we only add one point per highlight so we can assume there's only one node
if(!nodes[0]){ continue;}
- var rect = nodes[0].getBoundingClientRect();
+ var rect = nodes[0].getBoundingClientRect();
if(e.clientX >= rect.left && e.clientX <= rect.right &&
e.clientY >= rect.top && e.clientY <= rect.bottom){
// we just need the keys to exist
@@ -264,7 +263,7 @@
// server
pointGeometries[j] = true;
}else{
requestGeometries.push(g.toText());
@@ -287,7 +286,7 @@
return;
$("*",that.$popup).remove();
var $tabs = $("<ul></ul>");
// this iterates over an object where the keys are _not_ the incremential
@@ -318,13 +317,13 @@
if(j > 1){
var $tabcontainer = $("<div><div>");
$tabcontainer.append($tabs);
- $tabcontainer.append($('div',that.$popup));
+ $tabcontainer.append($('div',that.$popup));
that.$popup.append($tabcontainer);
$tabcontainer.tabs();
that.$popup.dialog('open');
}})(feed.geomArray, pointGeometries)
req.send();
Modified: trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
--- trunk/mapbender/lib/mb.ui.displayKmlFeatures.js 2015-03-02 13:27:54 UTC (rev 9162)
+++ trunk/mapbender/lib/mb.ui.displayKmlFeatures.js 2015-03-09 12:43:13 UTC (rev 9163)
@@ -1,26 +1,26 @@
// events
-// geojson:loaded - a georssfeed was loaded from a server and is now available: function(url,geojson)
-// georss:error - a georssfeed failed to load: function(url,error);
+// geojson:loaded - a georssfeed was loaded from a server and is now available: function(url,geojson)
+// georss:error - a georssfeed failed to load: function(url,error);
var originalI18nObject = {
- "labelLoadError" : "Could not load Document",
- "labelName":"Name",
- "labelUntitled":"Untitled",
+ "labelLoadError": "Could not load Document",
+ "labelName": "Name",
+ "labelUntitled": "Untitled",
"labelUrlBox": "Paste URL here",
- "sProcessing": "Processing...",
- "sLengthMenu": "Show _MENU_ entries",
- "sZeroRecords": "No matching records found",
- "sInfo": "SLowing _START_ to _END_ of _TOTAL_ entries",
- "sInfoEmpty": "Showing 0 to 0 of 0 entries",
+ "sProcessing": "Processing...",
+ "sLengthMenu": "Show _MENU_ entries",
+ "sZeroRecords": "No matching records found",
+ "sInfo": "SLowing _START_ to _END_ of _TOTAL_ entries",
+ "sInfoEmpty": "Showing 0 to 0 of 0 entries",
"sInfoFiltered": "(filtered from _MAX_ total entries)",
- "sInfoPostFix": "",
- "sSearch": "Search:",
- "sUrl": "",
+ "sInfoPostFix": "",
+ "sSearch": "Search:",
+ "sUrl": "",
"oPaginate": {
- "sFirst": "First",
+ "sFirst": "First",
"sPrevious": "Previous",
- "sNext": "Next",
- "sLast": "Last"
+ "sNext": "Next",
+ "sLast": "Last"
@@ -45,34 +45,33 @@
_kmls: {},
cache: {},
kmlOrder: [],
- _popup : null,
+ _popup: null,
creatingPhase: true,
selectedFeatures: [],
- selectionDialog: '<div id="selection-dialog" title="Selected features">'
- + '<ul id="selected-features-list">'
- + '</ul>'
- + '<div class="digitize-image digitize-remove"></div>'
- + '<div class="digitize-image digitize-export"></div>'
- + '</div>',
+ selectionDialog: '<div id="selection-dialog" title="Selected features">' + '<ul id="selected-features-list">' + '</ul>' + '<div class="digitize-image digitize-remove"></div>' + '<div class="digitize-image digitize-export"></div>' + '</div>',
- _create: function(){
- var self = this, o = this.options;
- this.element.mapbender().events.afterMapRequest.register(function () {
+ _create: function() {
+ var self = this,
+ o = this.options;
+ this.element.mapbender().events.afterMapRequest.register(function() {
self.render();
this.element.bind('click', function(e) {
- if(self.lastWasBox) {
+ if (self.lastWasBox) {
self.lastWasBox = false;
return;
var map = self.element.mapbender();
- var clickPoint = map.convertPixelToReal(new Point(pos.x,pos.y));
- var wgspt = Proj4js.transform(self.targetProj, self.wgs84, {x: clickPoint.x, y: clickPoint.y});
+ var clickPoint = map.convertPixelToReal(new Point(pos.x, pos.y));
+ var wgspt = Proj4js.transform(self.targetProj, self.wgs84, {
+ x: clickPoint.x,
+ y: clickPoint.y
var res = map.getScale() / mb_resolution / 100;
- if(!self.queriedLayer) return;
+ if (!self.queriedLayer) return;
var matchedIds = self.findFeatures(pos);
@@ -82,63 +81,68 @@
var boxfun;
this.element.bind('mousedown', boxfun = function(e) {
- var box = new Mapbender.Box({
- target: 'mapframe1'
- box.start(e);
- $('#mapframe1').css("cursor", "crosshair")
- .mouseup(function (e) {
- box.stop(e, function (extent) {
- if (typeof extent === "undefined") {
- return;
+ var box = new Mapbender.Box({
+ target: 'mapframe1'
+ box.start(e);
+ $('#mapframe1').css("cursor", "crosshair")
+ .mouseup(function(e) {
+ box.stop(e, function(extent) {
+ if (typeof extent === "undefined") {
+ return;
- var matchedIds = self.findFeatures(extent);
- self.updateSelectedFeatures(matchedIds, e.ctrlKey);
- self.lastWasBox = true;
+ var matchedIds = self.findFeatures(extent);
+ self.updateSelectedFeatures(matchedIds, e.ctrlKey);
+ self.lastWasBox = true;
- $('#mapframe1')
- .css("cursor", "default")
- .unbind("mousedown")
- .unbind("mouseup")
- .unbind("mousemove")
- .bind('mousedown', boxfun);
- return false;
+ $('#mapframe1')
+ .css("cursor", "default")
+ .unbind("mousedown")
+ .unbind("mouseup")
+ .unbind("mousemove")
+ .bind('mousedown', boxfun);
+ return false;
- self.element.bind('kml:loaded',function(event,obj){
- if(o.autoOpen){
+ self.element.bind('kml:loaded', function(event, obj) {
+ if (o.autoOpen) {
self.render();
- self.element.bind('kml:error',function(event,message){
+ self.element.bind('kml:error', function(event, message) {
alert(message);
var kmls = mb_getWmcExtensionData('KMLORDER');
- if(kmls) {
+ if (kmls) {
this.kmlOrder = JSON.parse(kmls);
kmls = mb_getWmcExtensionData('KMLS');
- if(kmls) {
+ if (kmls) {
kmls = JSON.parse(kmls);
this._kmls = kmls;
- for(var k in this.kmlOrder) {
+ for (var k in this.kmlOrder) {
kmls[this.kmlOrder[k]].loadedOnStartup = true;
- self.element.trigger('kml:loaded',kmls[this.kmlOrder[k]]);
+ self.element.trigger('kml:loaded', kmls[this.kmlOrder[k]]);
this.creatingPhase = false;
this.render();
- _init: function(){
- this._popup = $('<div></div>').dialog({autoOpen: false, height: 500, width: 500});
- if(o.url){
+ _init: function() {
+ var self = this,
+ o = this.options;
+ this._popup = $('<div></div>').dialog({
+ autoOpen: false,
+ height: 500,
+ width: 500
+ if (o.url) {
self._load(o.url);
@@ -150,24 +154,36 @@
var ispoint;
var clickPoint, wgspt, clickBox, min, max;
- if(posOrBox.x) {
- clickPoint = map.convertPixelToReal(new Point(posOrBox.x,posOrBox.y));
- wgspt = Proj4js.transform(self.targetProj, self.wgs84, {x: clickPoint.x, y: clickPoint.y});
+ if (posOrBox.x) {
+ clickPoint = map.convertPixelToReal(new Point(posOrBox.x, posOrBox.y));
+ wgspt = Proj4js.transform(self.targetProj, self.wgs84, {
+ x: clickPoint.x,
+ y: clickPoint.y
ispoint = true;
} else {
clickBox = posOrBox;
- min = Proj4js.transform(self.targetProj, self.wgs84, {x: clickBox.minx, y: clickBox.miny});
- max = Proj4js.transform(self.targetProj, self.wgs84, {x: clickBox.maxx, y: clickBox.maxy});
+ min = Proj4js.transform(self.targetProj, self.wgs84, {
+ x: clickBox.minx,
+ y: clickBox.miny
+ max = Proj4js.transform(self.targetProj, self.wgs84, {
+ x: clickBox.maxx,
+ y: clickBox.maxy
ispoint = false;
$.each(self._kmls, function(_, itm) {
$.each(itm.data.features, function(k, v) {
- if(ispoint) {
+ if (ispoint) {
self.matchFeatureToPoint(v, clickPoint, matchedIds, res, itm, wgspt, k);
} else {
- self.matchFeatureToBox(v, {min: min, max: max}, matchedIds, itm, k);
+ self.matchFeatureToBox(v, {
+ min: min,
+ max: max
+ }, matchedIds, itm, k);
@@ -180,53 +196,72 @@
matchFeatureToPoint: function(feat, clickPoint, matchedIds, res, itm, wgspt, idx) {
- if(feat.geometry.type.match(/point/i)) {
- var pt = Proj4js.transform(this.wgs84, this.targetProj, {x: feat.geometry.coordinates[0], y: feat.geometry.coordinates[1]});
+ if (feat.geometry.type.match(/point/i)) {
+ var pt = Proj4js.transform(this.wgs84, this.targetProj, {
+ x: feat.geometry.coordinates[0],
+ y: feat.geometry.coordinates[1]
var minx = pt.x - 20 * res;
var miny = pt.y - 20 * res;
var maxx = minx + 40 * res;
var maxy = miny + 40 * res;
- if(minx < clickPoint.x && maxx > clickPoint.x && miny < clickPoint.y && maxy > clickPoint.y) {
- matchedIds.push({url: itm.url, id: idx});
+ if (minx < clickPoint.x && maxx > clickPoint.x && miny < clickPoint.y && maxy > clickPoint.y) {
+ matchedIds.push({
+ url: itm.url,
+ id: idx
} else {
var box = this.getBbox(feat);
- if(this.inBox(box[0], box[1], box[2], box[3], wgspt.x, wgspt.y)) {
+ if (this.inBox(box[0], box[1], box[2], box[3], wgspt.x, wgspt.y)) {
+ matchedIds.push({
+ url: itm.url,
+ id: idx
matchFeatureToBox: function(feat, wgsbox, matchedIds, itm, idx) {
- if(this.inBox(wgsbox.min.x, wgsbox.min.y, wgsbox.max.x, wgsbox.max.y, feat.geometry.coordinates[0], feat.geometry.coordinates[1])) {
+ if (this.inBox(wgsbox.min.x, wgsbox.min.y, wgsbox.max.x, wgsbox.max.y, feat.geometry.coordinates[0], feat.geometry.coordinates[1])) {
+ matchedIds.push({
+ url: itm.url,
+ id: idx
} else {
- if(this.inBox(box[0], box[1], box[2], box[3], wgsbox.min.x, wgsbox.min.y)
- || this.inBox(box[0], box[1], box[2], box[3], wgsbox.min.x, wgsbox.max.y)
- || this.inBox(box[0], box[1], box[2], box[3], wgsbox.max.x, wgsbox.max.y)
- || this.inBox(box[0], box[1], box[2], box[3], wgsbox.max.x, wgsbox.min.y)) {
+ if (this.inBox(box[0], box[1], box[2], box[3], wgsbox.min.x, wgsbox.min.y) || this.inBox(box[0], box[1], box[2], box[3], wgsbox.min.x, wgsbox.max.y) || this.inBox(box[0], box[1], box[2], box[3], wgsbox.max.x, wgsbox.max.y) || this.inBox(box[0], box[1], box[2], box[3], wgsbox.max.x, wgsbox.min.y)) {
+ matchedIds.push({
+ url: itm.url,
+ id: idx
return;
- if(wgsbox.min.x < box[0] && wgsbox.max.x > box[2]) {
- if(wgsbox.min.y > box[1] && wgsbox.min.y < box[3]
- || wgsbox.max.y > box[1] && wgsbox.max.y < box[3]) {
+ if (wgsbox.min.x < box[0] && wgsbox.max.x > box[2]) {
+ if (wgsbox.min.y > box[1] && wgsbox.min.y < box[3] || wgsbox.max.y > box[1] && wgsbox.max.y < box[3]) {
+ matchedIds.push({
+ url: itm.url,
+ id: idx
return;
- if(wgsbox.min.y < box[1] && wgsbox.max.y > box[3]) {
- if(wgsbox.min.x > box[0] && wgsbox.min.x < box[2]
- || wgsbox.max.x > box[0] && wgsbox.max.x < box[2]) {
+ if (wgsbox.min.y < box[1] && wgsbox.max.y > box[3]) {
+ if (wgsbox.min.x > box[0] && wgsbox.min.x < box[2] || wgsbox.max.x > box[0] && wgsbox.max.x < box[2]) {
+ matchedIds.push({
+ url: itm.url,
+ id: idx
return;
- if(wgsbox.min.x < box[0] && wgsbox.max.x > box[2] && wgsbox.min.y > box[1] && wgsbox.max.y < box[3]) {
+ if (wgsbox.min.x < box[0] && wgsbox.max.x > box[2] && wgsbox.min.y > box[1] && wgsbox.max.y < box[3]) {
+ matchedIds.push({
+ url: itm.url,
+ id: idx
return;
@@ -235,18 +270,18 @@
updateSelectedFeatures: function(ids, append) {
var self = this;
- if(ids.length == 1 && !append && self.selectedFeatures.length == 0) {
+ if (ids.length == 1 && !append && self.selectedFeatures.length == 0) {
$('li[title="' + ids[0].url + '"] li[idx="' + ids[0].id + '"]').click();
} else {
- if(!append) {
+ if (!append) {
self.selectedFeatures = [];
$.each(ids, function(_, v) {
var contained = false;
$.each(self.selectedFeatures, function(_, sel) {
- if(v.url == sel.url && v.id == sel.id) contained = true;
+ if (v.url == sel.url && v.id == sel.id) contained = true;
- if(!contained) {
+ if (!contained) {
self.selectedFeatures.push(v);
@@ -259,15 +294,15 @@
$('#selection-dialog').dialog('destroy').remove();
- if(self.selectedFeatures.length == 0) {
+ if (self.selectedFeatures.length == 0) {
Mapbender.modules.digitize_widget.closeEditDialog();
- if(self.selectedFeatures.length > 1) {
+ if (self.selectedFeatures.length > 1) {
var dlg = $(self.selectionDialog);
var list = dlg.find('#selected-features-list')
- .html('');
+ .html('');
$.each(self.selectedFeatures, function(_, v) {
var feat = self._kmls[v.url].data.features[v.id];
var title = feat.properties.name;
@@ -283,7 +318,10 @@
dlg.find('.digitize-export').bind('click', function() {
- var data = {type: 'FeatureCollection', features: []};
+ var data = {
+ features: []
data.features.push(feat);
@@ -292,10 +330,10 @@
dlg.dialog('close');
dlg.find('.digitize-remove').bind('click', function() {
- if(confirm('Do you really want to remove all these objects?')) {
+ if (confirm('Do you really want to remove all these objects?')) {
var urls = [];
- if($.inArray(v.url, urls) == -1) {
+ if ($.inArray(v.url, urls) == -1) {
urls.push(v.url);
$('#kmlTree li[title="' + v.url + '"] li[idx="' + v.id + '"]').remove();
@@ -321,8 +359,14 @@
var bbox = this.getBbox(item.data.features[idx]);
- var min = Proj4js.transform(this.wgs84, this.targetProj, {x: bbox[0], y: bbox[1]});
- var max = Proj4js.transform(this.wgs84, this.targetProj, {x: bbox[2], y: bbox[3]});
+ var min = Proj4js.transform(this.wgs84, this.targetProj, {
+ x: bbox[0],
+ y: bbox[1]
+ var max = Proj4js.transform(this.wgs84, this.targetProj, {
+ x: bbox[2],
+ y: bbox[3]
map.calculateExtent(
new Mapbender.Extent(min.x, min.y, max.x, max.y)
@@ -332,13 +376,19 @@
zoomToLayer: function(url) {
var bbox = this.getLayerBbox(url);
- if(!bbox) {
+ if (!bbox) {
return;
+ x: bbox[0],
+ y: bbox[1]
+ x: bbox[2],
+ y: bbox[3]
map.calculateExtent(new Mapbender.Extent(min.x, min.y, max.x, max.y));
map.zoom(true, 0.99999999);
@@ -369,7 +419,7 @@
var geom = new Geometry();
var multi = new MultiGeometry(tp);
- for(var i = 0; i < pts.length; ++i) {
+ for (var i = 0; i < pts.length; ++i) {
var pt = Proj4js.transform(this.targetProj, this.wgs84, pts[i].pos);
geom.addPoint(pt);
@@ -382,21 +432,27 @@
multi.e.setElement('name', 'name');
attributesDialog.find('table input').each(function() {
var name = $(this).attr('name');
- if(name) {
+ if (name) {
multi.e.setElement($(this).attr('name'), $(this).val());
- if(icon == "false" || icon === false){
+ if (icon == "false" || icon === false) {
multi.e.setElement("Mapbender:iconOffsetX", -10);
multi.e.setElement("Mapbender:iconOffsetY", -34);
- multi.e.setElement("Mapbender:icon","../img/marker/red.png");
+ multi.e.setElement("Mapbender:icon", "../img/marker/red.png");
var feat = JSON.parse(multi.toString());
itm.data.features.push(feat);
- this.element.trigger('kml:loaded',{type:"geojson",data:itm.data,url:itm.url,display: itm.display, refreshing: true});
+ this.element.trigger('kml:loaded', {
+ type: "geojson",
+ data: itm.data,
+ url: itm.url,
+ display: itm.display,
+ refreshing: true,
$map.setMapRequest();
@@ -404,55 +460,104 @@
this.cache = {};
var $map = $(this.element).mapbender();
var itm = this._kmls[url];
- if(!itm) {
+ if (!itm) {
return;
+ type: "geojson",
+ data: itm.data,
+ url: itm.url,
+ refreshing: true
- _load: function(url){
+ _load: function(url) {
+ var self = this,
+ o = this.options;
var epsg = $(self.element).mapbender().epsg;
epsg = epsg.split(":")[1];
- if(self._kmls[o.url]){
- //not adding feed twice
+ if (self._kmls[o.url]) {
+ //not adding feed twiced
return;
this.kmlOrder.push(o.url);
- $.ajax({ url: '../php/kmlToGeoJSON.php',
- data: {url: o.url, targetEPSG: 'EPSG:4326'},
- type: 'POST',
- dataType: "json",
- success : function(data,textStatus,xhr){
- if(!data){
- self.element.trigger('kml:error',"request returned no data");
- else if(data.errorMessage){
- self.element.trigger('kml:error',data.errorMessage);
- }else{
- self._kmls[o.url] = {type:"geojson",data:data,url:o.url,display: o.autoDisplay};
- self.zoomToLayer(o.url);
- self.element.trigger('kml:loaded',{type:"geojson",data:data,url:o.url,display: o.autoDisplay});
- error: function(XMLHttpRequest, textStatus, errorThrown){
- self.element.trigger('kml:error',"Problem talking to server: " + errorThrown);
+ $.ajax({
+ url: '../php/kmlToGeoJSON.php',
+ data: {
+ url: o.url,
+ targetEPSG: 'EPSG:4326'
+ type: 'POST',
+ success: function(data, textStatus, xhr) {
+ var json_result;
+ if (!data) {
+ console.log('test');
+ self.element.trigger('kml:error', "request returned no data");
+ } else if (data.errorMessage) {
+ self.element.trigger('kml:error', data.errorMessage);
+ } else {
+ //listen to gpx files
+ try {
+ // console.log(data);
+ json_string = JSON.parse(data);
+ json_result = JSON.parse(data);
+ } catch (e) {
+ var xml = new DOMParser().parseFromString(data, 'application/xml');
+ json_result = toGeoJSON.gpx(xml);
+ var name;
+ if (json_result.hasOwnProperty('@context')) {
+ name = json_result['@context']['title'];
+ kml.addLayer(name, json_result);
+ } else {
+ name = o.url;
+ if (name.match(/\w*\W(?:kml|gpx|geojson)$/)) {
+ name = name.match(/\w*\W(?:kml|gpx|geojson)$/)[0];
+ }else {
+ name = 'ImportFeatures';
+ error: function(XMLHttpRequest, textStatus, errorThrown) {
+ self.element.trigger('kml:error', "Problem talking to server: " + errorThrown);
addLayer: function(url, data) {
- if($.inArray(url, this.kmlOrder) !== -1) {
+ if ($.inArray(url, this.kmlOrder) !== -1) {
alert('Not adding ' + url + ', a layer with that name is already loaded.');
return;
this.kmlOrder.push(url);
- this._kmls[url] = {type:"geojson",data:data,url:url,display: true};
+ this._kmls[url] = {
+ type: "geojson",
+ data: data,
+ url: url,
+ display: true
this.zoomToLayer(url);
- this.element.trigger('kml:loaded',{type:"geojson",data:data,url:url,display: true});
+ type: "geojson",
+ data: data,
+ url: url,
+ display: true
setOrder: function(order) {
@@ -472,7 +577,7 @@
- show : function(url){
+ show: function(url) {
this._kmls[url].display = true;
var extent = $map.getExtentInfos();
@@ -481,7 +586,7 @@
$(this.element).mapbender().setMapRequest();
- hide : function(url){
+ hide: function(url) {
this._kmls[url].display = false;
@@ -489,7 +594,7 @@
- remove: function(url){
+ remove: function(url) {
delete this._kmls[url];
this.kmlOrder.splice(this.kmlOrder.indexOf(url), 1);
delete this.cache[url];
@@ -502,7 +607,7 @@
getLayerBbox: function(url) {
var self = this;
- if(itm.data.features.length == 0) {
+ if (itm.data.features.length == 0) {
return false;
var bbox = this.getBbox(itm.data.features[0]);
@@ -517,75 +622,78 @@
getBbox: function(feature) {
- switch(feature.geometry.type.toLowerCase()) {
+ switch (feature.geometry.type.toLowerCase()) {
case 'point':
- var map = $(this.element).mapbender();
- var minx = feature.geometry.coordinates[0] - 0.001;
- var miny = feature.geometry.coordinates[1] - 0.001;
- return [minx, miny, minx + 0.002, miny + 0.002];
+ var map = $(this.element).mapbender();
+ var minx = feature.geometry.coordinates[0] - 0.001;
+ var miny = feature.geometry.coordinates[1] - 0.001;
+ return [minx, miny, minx + 0.002, miny + 0.002];
case 'linestring':
- var coords = feature.geometry.coordinates;
- minx = coords[0][0];
- miny = coords[0][1];
- var maxx = minx;
- var maxy = miny;
- $.each(coords, function(_, v) {
- minx = Math.min(minx, v[0]);
- miny = Math.min(miny, v[1]);
- maxx = Math.max(maxx, v[0]);
- maxy = Math.max(maxy, v[1]);
- return [minx, miny, maxx, maxy];
+ var coords = feature.geometry.coordinates;
+ minx = coords[0][0];
+ miny = coords[0][1];
+ var maxx = minx;
+ var maxy = miny;
+ $.each(coords, function(_, v) {
+ minx = Math.min(minx, v[0]);
+ miny = Math.min(miny, v[1]);
+ maxx = Math.max(maxx, v[0]);
+ maxy = Math.max(maxy, v[1]);
+ return [minx, miny, maxx, maxy];
case 'polygon':
- coords = feature.geometry.coordinates;
- minx = coords[0][0][0];
- miny = coords[0][0][1];
- maxx = minx;
- maxy = miny;
- $.each(v, function(_, v2) {
- minx = Math.min(minx, v2[0]);
- miny = Math.min(miny, v2[1]);
- maxx = Math.max(maxx, v2[0]);
- maxy = Math.max(maxy, v2[1]);
+ coords = feature.geometry.coordinates;
+ minx = coords[0][0][0];
+ miny = coords[0][0][1];
+ maxx = minx;
+ maxy = miny;
+ $.each(v, function(_, v2) {
+ minx = Math.min(minx, v2[0]);
+ miny = Math.min(miny, v2[1]);
+ maxx = Math.max(maxx, v2[0]);
+ maxy = Math.max(maxy, v2[1]);
return undefined;
renderPoint: function(canvas, feature) {
- var pt = {x: feature.geometry.coordinates[0],
- y: feature.geometry.coordinates[1]};
- if(isNaN(pt.x) || isNaN(pt.y)) return;
- if(!feature.preview) {
+ var pt = {
+ x: feature.geometry.coordinates[0],
+ y: feature.geometry.coordinates[1]
+ if (isNaN(pt.x) || isNaN(pt.y)) return;
+ if (!feature.preview) {
pt = $('#mapframe1').mapbender().convertRealToPixel(pt);
// is this the right place and way to fix it?
- if(feature.properties['Mapbender:icon']) {
+ if (feature.properties['Mapbender:icon']) {
feature.properties['marker-symbol'] = feature.properties['Mapbender:icon'];
feature.properties['marker-type'] = 'custom';
feature.properties['Mapbender:icon'] = null;
- if(feature.properties['Mapbender:iconOffsetX']) {
+ if (feature.properties['Mapbender:iconOffsetX']) {
feature.properties['marker-offset-x'] = feature.properties['Mapbender:iconOffsetX'];
feature.properties['Mapbender:iconOffsetX'] = null;
- if(feature.properties['Mapbender:iconOffsetY']) {
+ if (feature.properties['Mapbender:iconOffsetY']) {
feature.properties['marker-offset-y'] = feature.properties['Mapbender:iconOffsetY'];
feature.properties['Mapbender:iconOffsetY'] = null;
- if(feature.properties['marker-type'] === 'custom') {
+ if (feature.properties['marker-type'] === 'custom') {
var size = 32;
- if(feature.properties['marker-size']) {
+ if (feature.properties['marker-size']) {
size = feature.properties['marker-size'];
- var offx = 0, offy = 0;
- if(feature.preview) {
+ var offx = 0,
+ offy = 0;
+ if (feature.preview) {
size = 20;
} else {
offx = feature.properties['marker-offset-x'] || 0;
@@ -594,32 +702,32 @@
offy = parseInt(offy);
var img = canvas.image(feature.properties['marker-symbol'], pt.x + offx, pt.y + offy, size, size).node;
- if(img.setAttributeNS) {
- img.setAttributeNS(null, "preserveAspectRatio" , "xMidYMid meet" );
+ if (img.setAttributeNS) {
+ img.setAttributeNS(null, "preserveAspectRatio", "xMidYMid meet");
} else {
var size = 32;
- if(feature.properties['marker-size'] === 'large') {
+ if (feature.properties['marker-size'] === 'large') {
size = 64;
- if(feature.properties['marker-size'] === 'small') {
+ if (feature.properties['marker-size'] === 'small') {
size = 16;
size = 20;
- if(!this.icons) {
- window.setTimeout($.proxy(function(){
+ if (!this.icons) {
+ window.setTimeout($.proxy(function() {
this.renderPoint(canvas, feature);
}, this), 100);
return;
$.each(this.icons.icons, function(_, v) {
- if(v.properties.name === (feature.properties['marker-symbol'] + '-24')) {
+ if (v.properties.name === (feature.properties['marker-symbol'] + '-24')) {
$.each(v.icon.paths, function(_, p) {
var raph = Raphael();
var tmp = raph.path(p);
@@ -629,19 +737,19 @@
var path = canvas.path(p);
var fac;
- if(box.width > box.height) {
+ if (box.width > box.height) {
fac = size / box.width;
} else {
fac = size / box.height;
fac = fac * 0.7;
// center icon on 0/0, then scale to size, then translate to actual point
// for preview, just start at 0/0
path.translate(-box.x, -box.y);
} else {
path.translate(-box.x - box.width / 2, -box.y - box.height / 2);
@@ -649,7 +757,7 @@
// if you get a chrome error 'Invalid value for <path> attribute transform=" "' see:
// http://forum.wakanda.org/showthread.php?6753-error-raphael-min.js-7&p=31624&viewfull=1
path.scale(fac, fac, 0, 0);
path.translate(pt.x, pt.y);
@@ -666,12 +774,15 @@
var self = this;
var path;
$.each(feature.geometry.coordinates, function(_, v) {
- var pt = {x: v[0], y: v[1]};
+ var pt = {
+ x: v[0],
+ y: v[1]
pt = map.convertRealToPixel(pt);
- if(!path) {
+ if (!path) {
path = 'M' + pt.x + ' ' + pt.y;
} else {
path += 'L' + pt.x + ' ' + pt.y;
@@ -686,12 +797,15 @@
var self = this;
var path;
$.each(feature.geometry.coordinates[0], function(_, v) {
+ var pt = {
+ x: v[0],
+ y: v[1]
- if(!path) {
+ if (!path) {
} else {
@@ -703,22 +817,22 @@
renderFeature: function(canvas) {
var self = this;
return function(_, feature) {
- try{
- if(feature.display === false) {
+ try {
+ if (feature.display === false) {
return;
case 'point':
- self.renderPoint(canvas, feature);
- break;
+ self.renderPoint(canvas, feature);
+ break;
case 'linestring':
- self.renderLine(canvas, feature);
- break;
+ self.renderLine(canvas, feature);
+ break;
case 'polygon':
- self.renderPolygon(canvas, feature);
- break;
+ self.renderPolygon(canvas, feature);
+ break;
- }catch(e) {
+ } catch (e) {
console && console.log('Problem rendering feature', feature, e)
@@ -726,7 +840,7 @@
renderPreview: function(feature, target, size) {
var canvas;
- if(size) {
+ if (size) {
canvas = Raphael(target, size, size);
} else {
canvas = Raphael(target, 20, 20);
@@ -743,30 +857,40 @@
var min = size / 8;
var max = size - size / 8;
case 'point':
- feat.geometry.coordinates = [0, 0];
- break;
+ feat.geometry.coordinates = [0, 0];
+ break;
case 'linestring':
- feat.geometry.coordinates = [[min, max], [max, min]];
- break;
+ [min, max],
+ [max, min]
+ break;
case 'polygon':
- feat.geometry.coordinates = [[[min, min], [min, max], [max, max], [max, min]]];
- break;
+ [min, min],
+ [min, max],
+ [max, max],
+ [max, min]
+ break;
this.renderFeature(canvas)(null, feat);
render: function() {
- if(this.creatingPhase) {
+ if (this.creatingPhase) {
return;
var target = $('#kml-rendering-pane');
this.targetProj = new Proj4js.Proj(map.getSrs());
var self = this;
- if(target.length == 0) {
+ if (target.length == 0) {
$('#mapframe1').append('<div id="kml-rendering-pane" style="position: absolute; top: 0px; left: 0px; z-index: 80;"></div>');
target = $('#kml-rendering-pane').html('').get(0);
@@ -777,18 +901,18 @@
$.each(order, function(_, url) {
var item = self._kmls[url];
- if(!item) {
+ if (!item) {
return;
var feats = item.data.features;
- if(!map.getSrs().match(/:4326/)) {
- if(!self.cache[url]) {
+ if (!map.getSrs().match(/:4326/)) {
+ if (!self.cache[url]) {
self.cache[url] = {};
feats = self.cache[url][map.getSrs()];
- if(!feats) {
+ if (!feats) {
$.each(item.data.features, function(_, v) {
self.fixupFeature(v);
@@ -797,7 +921,7 @@
type: 'POST',
data: JSON.stringify(item.data.features),
success: function(data) {
- if(!$.isArray(data)) {
+ if (!$.isArray(data)) {
data = JSON.parse(data);
self.cache[url][map.getSrs()] = data;
@@ -808,38 +932,37 @@
- if(item.display && feats) {
+ if (item.display && feats) {
$.each(feats, $.proxy(self, self.renderFeature(canvas)));
fixupFeature: function(feat) {
- if(feat.geometry.type === 'Polygon') {
+ if (feat.geometry.type === 'Polygon') {
$.each(feat.geometry.coordinates, function(_, coords) {
- if(coords[0][0] !== coords[coords.length-1][0]
- || coords[0][1] !== coords[coords.length-1][1]) {
+ if (coords[0][0] !== coords[coords.length - 1][0] || coords[0][1] !== coords[coords.length - 1][1]) {
coords.push(coords[0]);
- if(!feat.properties.uuid) {
+ if (!feat.properties.uuid) {
feat.properties.uuid = UUID.genV1().toString();
- if(!feat.properties.updated) {
+ if (!feat.properties.updated) {
feat.properties.updated = new Date().toISOString();
- if(!feat.properties.created) {
+ if (!feat.properties.created) {
feat.properties.created = new Date().toISOString();
-var displayKML = $.extend({},displayFeatures, {
+var displayKML = $.extend({}, displayFeatures, {
_endpointURL: "../php/kml2transformedgeojson.php",
- _eventNamespace : "kml"
+ _eventNamespace: "kml"
-$.widget('ui.kml',displayKML);
-$.widget('ui.geojson',displayKML);
+$.widget('ui.kml', displayKML);
+$.widget('ui.geojson', displayKML);
More information about the Mapbender_commits
