[Mapbender-commits] r9175 - in trunk/mapbender: http/classes http/extensions http/php http/plugins lib
svn_mapbender at osgeo.org
Thu Mar 19 08:14:04 PDT 2015
Author: syed
Date: 2015-03-19 08:14:04 -0700 (Thu, 19 Mar 2015)
New Revision: 9175
trunk/mapbender/http/classes/class_kml_ows.php
trunk/mapbender/http/classes/class_kml_parser_ows.php
trunk/mapbender/http/extensions/togpx.js
trunk/mapbender/http/extensions/tokml.js
trunk/mapbender/http/php/mb_delete_local_data.php
trunk/mapbender/http/php/uploadKml.php
trunk/mapbender/http/plugins/kmlTree.js
trunk/mapbender/http/plugins/mb_digitize_widget.php
trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
add default values for feature_point properties
Modified: trunk/mapbender/http/classes/class_kml_ows.php
--- trunk/mapbender/http/classes/class_kml_ows.php 2015-03-17 14:13:46 UTC (rev 9174)
+++ trunk/mapbender/http/classes/class_kml_ows.php 2015-03-19 15:14:04 UTC (rev 9175)
@@ -320,11 +320,6 @@
$e = new mb_notice("parsing finished...#placemarks: " . count($this->placemarkArray) . " (" . count($parser->placemarkArray) . ")");
$this->placemarkArray = $parser->placemarkArray;
-// new mb_exception(print_r($this, true));
-// $this->kml = $this->__toString();
-// $this->updateInDb($this->kml, $this->id);
return true;
@@ -332,30 +327,10 @@
* @return string the geoJSON representation of the KML.
public function toGeoJSON($str) {
- // var_dump($str);die;
- // $str = "{";
$numberOfPlacemarks = count($this->placemarkArray);
- // if (sizeof($this->featureCollectionMD) > 0) {
- // end($this->featureCollectionMD);
- // $lastKey = key($this->featureCollectionMD);
- // $str .= "\"@context\": { ";
- // foreach ($this->featureCollectionMD as $key => $value) {
- // // var_dump($str);var_dump($key);var_dump($value);
- // // if ($key == end($this->featureCollectionMD)){
- // if ( $key === $lastKey ){
- // $str.= "\"".$key."\": \"".$value."\" },";
- // }else{
- // $str.= "\"".$key."\": \"".$value."\",";
if ($numberOfPlacemarks > 0) {
- $str .= "\"type\": \"FeatureCollection\", \"features\": [";
+ $str .= "\"features\": [";
for ($i=0; $i < $numberOfPlacemarks; $i++) {
if ($i > 0) {
$str .= ",";
@@ -371,31 +346,20 @@
public function createGeoJSON(){
- // var_dump($this->placemarkArray);die;
$str = "{";
+ $str.= "\"type\": \"FeatureCollection\",";
- end($this->featureCollectionMD);
- $lastKey = key($this->featureCollectionMD);
- $str .= "\"@context\": { ";
- // var_dump($str);var_dump($key);var_dump($value);
- // if ($key == end($this->featureCollectionMD)){
- if ( $key === $lastKey ){
- $str.= "\"".$key."\": \"".$value."\" },";
- }else{
$completeString = $this->toGeoJSON($str);
return $completeString;
- // var_dump($completeString);die;
private function updateInDb($kmlDoc, $kmlId) {
$sql = "UPDATE gui_kml SET kml_doc = $1 WHERE kml_id = $2";
Modified: trunk/mapbender/http/classes/class_kml_parser_ows.php
--- trunk/mapbender/http/classes/class_kml_parser_ows.php 2015-03-17 14:13:46 UTC (rev 9174)
+++ trunk/mapbender/http/classes/class_kml_parser_ows.php 2015-03-19 15:14:04 UTC (rev 9175)
@@ -258,11 +258,9 @@
if ($extendedData->length > 0) { // check for metadata
foreach ($extendedData as $metaData) {
$data = $metaData->getElementsByTagName('Data');
foreach ($data as $metadataValue) {
- $test = $metadataValue->nodeValue;
foreach($metadataValue->attributes as $attribute_name => $attribute_node){
// * @var DOMNode $attribute_node
Modified: trunk/mapbender/http/extensions/togpx.js
--- trunk/mapbender/http/extensions/togpx.js 2015-03-17 14:13:46 UTC (rev 9174)
+++ trunk/mapbender/http/extensions/togpx.js 2015-03-19 15:14:04 UTC (rev 9175)
@@ -2,7 +2,6 @@
var JXON = require("jxon");
function togpx( geojson, options ) {
- console.log(geojson);
options = (function (defaults, options) {
for (var k in defaults) {
if (options.hasOwnProperty(k))
Modified: trunk/mapbender/http/extensions/tokml.js
--- trunk/mapbender/http/extensions/tokml.js 2015-03-17 14:13:46 UTC (rev 9174)
+++ trunk/mapbender/http/extensions/tokml.js 2015-03-19 15:14:04 UTC (rev 9175)
@@ -17,7 +17,7 @@
tag('Document',
documentName(options) +
documentDescription(options) +
- documentMetadata(geojson,options) + // add metadata to feautureCollections
+ documentMetadata(geojson,options) + // add metadata to featureCollections
root(geojson, options)
), [['xmlns', 'http://www.opengis.net/kml/2.2']]);
@@ -66,14 +66,17 @@
function documentMetadata(geojson,options) {
- var metadata = {};
- for(key in geojson['@context']){
+ if (geojson.type != 'Feature') {
- metadata[key]= geojson['@context'][key];
+ var metadata = {};
+ for(var key in geojson){
+ if(key!= 'features'){
+ metadata[key]= geojson[key];
+ extendeddata(metadata);
+ return extendeddata(metadata);
- extendeddata(metadata);
- return extendeddata(metadata);
function documentDescription(options) {
return (options.documentDescription !== undefined) ? tag('description', options.documentDescription) : '';
Modified: trunk/mapbender/http/php/mb_delete_local_data.php
--- trunk/mapbender/http/php/mb_delete_local_data.php 2015-03-17 14:13:46 UTC (rev 9174)
+++ trunk/mapbender/http/php/mb_delete_local_data.php 2015-03-19 15:14:04 UTC (rev 9175)
@@ -27,12 +27,11 @@
$form_target = $self;
-$sql = 'delete from mb_user_wmc where wmc_id = $1 and wmc_has_local_data = 1 and fkey_user_id = $2;';
+$sql = 'Select wmc from mb_user_wmc where wmc_id = $1 and wmc_has_local_data = 1 and fkey_user_id = $2;';
$v = array($wmc_id, $user_id);
$t = array("i", "i");
$res = db_prep_query($sql, $v, $t);
-header("Content-Type: application/json");
// if($row = db_fetch_array($res)){
// $wmc->createFromXml($row['wmc']);
@@ -47,4 +46,26 @@
// echo('{"success":false}');
+if($row = db_fetch_array($res)){
+ //FIXME: Diesnt work!!
+ $wmc->createFromXml($row['wmc']);
+ $wmc->generalExtensionArray['KMLS'] = null;
+ $wmc->wmc_id = $wmc_id;
+ $wmc->has_local_data = 0;
+ $wmc->local_data_public = 0;
+ $wmc->local_data_size = '0';
+ $newWmcXml = $wmc->toXml();
+ // var_dump($wmc->wmc_id);die;
+ if (is_int(intval($wmc->wmc_id))) {
+ $wmc->update_existing($newWmcXml, $wmc->wmc_id);
+ echo('{"success":true}');
+else {
+echo('{"success":false}');
Modified: trunk/mapbender/http/php/uploadKml.php
--- trunk/mapbender/http/php/uploadKml.php 2015-03-17 14:13:46 UTC (rev 9174)
+++ trunk/mapbender/http/php/uploadKml.php 2015-03-19 15:14:04 UTC (rev 9175)
@@ -28,7 +28,7 @@
header("Content-Type: text/plain");
if($kml->parseKml($content)){
$geojson = $kml->createGeoJSON();
- // var_dump($geojson);die;
echo $geojson;
}else{
echo("{}");
@@ -36,7 +36,6 @@
if(preg_match('/.(json|geojson)$/', $_FILES['kml']['name'])) {
- // var_dump($content);die;
echo $content;
if(preg_match('/.(xml|gpx)$/', $_FILES['kml']['name'])) {
Modified: trunk/mapbender/http/plugins/kmlTree.js
--- trunk/mapbender/http/plugins/kmlTree.js 2015-03-17 14:13:46 UTC (rev 9174)
+++ trunk/mapbender/http/plugins/kmlTree.js 2015-03-19 15:14:04 UTC (rev 9175)
@@ -131,7 +131,25 @@
sTitle: 'size'
- }).find('.exportImage').bind('click', function(event) { // add click event to the link image
+ .find('tr').bind('dblclick', function() {
+ var id = $($(this).find('td')[0]).text();
+ $.ajax({
+ type: 'post',
+ url: '../php/mb_load_local_data.php',
+ data: {
+ id: id
+ success: function(data) {
+ var kml = $('#mapframe1').data('kml');
+ $.each(data, function(url, json) {
+ kml.addLayer(url, json.data);
+ $(dlg).dialog('destroy');
+ }).end()
+ .find('.exportImage').bind('click', function(event) { // add click event to the link image
// stop event propagation beacause the following bind has to catch the click events on the 'tr'
event.stopPropagation();
if ($('#dataExportDialog').dialog('isOpen') === true) {
@@ -489,24 +507,24 @@
- .bind('dblclick', function() {
- var id = $($(this).find('td')[0]).text();
- $.ajax({
- type: 'post',
- url: '../php/mb_load_local_data.php',
- data: {
- id: id
- success: function(data) {
- var kml = $('#mapframe1').data('kml');
- $.each(data, function(url, json) {
- kml.addLayer(url, json.data);
- $(dlg).dialog('destroy');
+ // .bind('dblclick', function() {
+ // var id = $($(this).find('td')[0]).text();
+ // $.ajax({
+ // type: 'post',
+ // url: '../php/mb_load_local_data.php',
+ // data: {
+ // id: id
+ // success: function(data) {
+ // var kml = $('#mapframe1').data('kml');
+ // $.each(data, function(url, json) {
+ // kml.addLayer(url, json.data);
+ // $(dlg).dialog('destroy');
$('#kml-load-tabs').tabs();
@@ -519,11 +537,12 @@
$('#kml-load-tabs').find('button.add-kml').bind('click', function() {
var title = $('#kml-load-tabs input[name="kml-new-title"]').val();
+ var version = 'v1'
if (title == '') {
return;
kml.addLayer(title,{
- uuid: UUID.genV4().toString(), created: new Date().toISOString() ,title: title, updated: new Date().toISOString(),
+ uuid: UUID.genV4().toString(), created: new Date().toISOString() ,title: title, updated: new Date().toISOString(), version: version,
type: 'FeatureCollection',
features: []
@@ -544,9 +563,12 @@
var name;
- if(data.hasOwnProperty('@context')){
+ // check the features for properties
+ data = setFeatureAttr(data);
- name = data['@context']['title'];
+ if( data.hasOwnProperty('title') ){
+ name = data['title'];
kml.addLayer(name, data);
}else{
@@ -603,7 +625,7 @@
$featureList = $("<ul />");
$kmlEntry.append($featureList);
- for (var i = obj.data.features.length - 1; i >= 0; --i) {
+ for (var i = obj.data.features.length - 1; i >= 0; --i) { //FIXME: for feature without the "type: FeatureCollection ",change functionallity: if (obj.data.type == "Feature") ...
var multi = obj.data.features[i].geometry.type.match(/^Multi/i);
var toggle = '';
if (multi) {
@@ -752,6 +774,61 @@
+ var setFeatureAttr = function(data){
+ var simpleStyleDefaults = {
+ "title": "",
+ "description": "",
+ "marker-size": "medium",
+ "marker-symbol": "",
+ "marker-color": "7e7e7e",
+ "stroke": "#555555",
+ "stroke-opacity": 1.0,
+ "stroke-width": 2,
+ "fill": "#555555",
+ "fill-opacity": 0.5
+ if (data.type == 'Feature') {
+ if ( Object.getOwnPropertyNames(data.properties).length === 0 || data.properties === null) {
+ data.properties = simplyStyleDefaults;
+ } else{
+ $.each(simpleStyleDefaults, function(index, val) {
+ if ( !data.properties.hasOwnProperty(index) ){
+ data.properties[index] = value;
+ } else if (data.type == 'FeatureCollection') {
+ // get all features in the featureCollection and set the default properties if they are not set
+ $.each(data.features, function(index, val) {
+ $.each(simpleStyleDefaults, function(prop, propVal) {
+ if ( !val.properties.hasOwnProperty(prop) ){
+ //TODO: get index in this scope
+ data.features[index].properties[prop] = propVal;
+ return data;
Mapbender.events.init.register(function() {
Modified: trunk/mapbender/http/plugins/mb_digitize_widget.php
--- trunk/mapbender/http/plugins/mb_digitize_widget.php 2015-03-17 14:13:46 UTC (rev 9174)
+++ trunk/mapbender/http/plugins/mb_digitize_widget.php 2015-03-19 15:14:04 UTC (rev 9175)
@@ -242,7 +242,7 @@
$('#kmlTree li.kmltree-selected').removeClass('kmltree-selected');
attributesDialog.dialog('close');
editStyleDialog.dialog('close');
- console.log('ende');
attributesDialog = $(editAttributesHtml);
attributesDialog.dialog({
@@ -355,8 +355,16 @@
url = togpx(data, {simplestyle: true});
if(fmt === 'geojson') {
- console.log('dsafasdf');
- url = JSON.stringify(data);
+ if (data.type != "Feature") {
+ url = JSON.stringify(data);
+ } else {
+ var newFeatureJson = $.extend(true, {}, data);
+ var jsonFeatureHeader = {"type": "FeatureCollection", "features": [newFeatureJson]};
+ url = JSON.stringify(jsonFeatureHeader);
var link = document.createElement("a");
@@ -680,10 +688,14 @@
var styleRows = '<h3 style="text-align:center;">Style-Data</h3><div><table class="ftr-data-tbl style-data">';//</table></div>';
// var divider = "<tr><th>divider</th></tr>";
+ console.log(feature.properties);
$.each(feature.properties, function(k, v) {
- if(k.match(/Mapbender:/)) return; // was soll hiermiet passieren?
- if ( k == "uuid" || k == "created" || k == "updated" ) {
+ console.log(k, v);
+ if(k.match(/Mapbender:/)) return;
+ if ( k == "uuid" || k == "created" || k == "updated" || k == "version" ) {
nonEditableRows += '<tr><td>' + k + '</td><td><input disabled type="text" name="' + k + '" value="' + v + '"></input></td></tr>';
}else if(k == "title" || k == "name" || k == "description"){
@@ -694,7 +706,7 @@
styleRows += '<tr><td>' + k + '</td><td><input type="text" name="' + k + '" value="' + v + '"></input></td></tr>';
- } else if( k == "Area [m²]" || k == "Length [m]" || k == "Boundary-Length [m]" ){
+ } else if( k == "area" || k == "boundary-length" || k == "track-length"){ // || k == "Boundary-Length [m]"
geometryDiv.append('<div><p class = " geometry-p "name="' + k + '">'+ k +' : ' + v + '</p></div>');
@@ -714,23 +726,16 @@
header: "ui-icon-circle-arrow-e",
activeHeader: "ui-icon-circle-arrow-s"
- // $('.attrAccordion').append(nonEditableRows)
- // .append(editableRows)
- // .append(customRows).accordion({
- // collapsible: false
.append(styleRows)
collapsible: false
attributesDialog.prepend(geometryDiv);
- // attributesDialog.find('table').html("'"+editableRows+"'"+nonEditableRows+"'"+customRows);
- // attributesDialog.find('table').append(editableRows);
- // attributesDialog.find('table').append(nonEditableRows);
- // $(divider).after(rows);
- // $( '.attrAccodion' ).accordion();
attributesDialog.find('.digitize-add').bind('click', function() {
var newRow = $('<tr><td><input style="width:81px" type="text"></input></td><td><input style="width:100px" type="text"></input></td></tr>');
attributesDialog.find('.ftr-data-tbl.custom-data').append(newRow);
Modified: trunk/mapbender/lib/mb.ui.displayKmlFeatures.js
--- trunk/mapbender/lib/mb.ui.displayKmlFeatures.js 2015-03-17 14:13:46 UTC (rev 9174)
+++ trunk/mapbender/lib/mb.ui.displayKmlFeatures.js 2015-03-19 15:14:04 UTC (rev 9175)
@@ -423,7 +423,6 @@
for (var i = 0; i < pts.length; ++i) {
var pt = Proj4js.transform(this.targetProj, this.wgs84, pts[i].pos);
geom.addPoint(pt);
- console.log(pt);
geom.geomType = tp;
multi.add(geom);
@@ -471,12 +470,12 @@
if (geom.geomType == 'polygon') {
- multi.e.setElement('Area [m²]', data[0]);
- multi.e.setElement('Boundary-Length [m]', data[1]);
+ multi.e.setElement('area', data[0]);
+ multi.e.setElement('boundary-length', data[1]);
} else {
- multi.e.setElement('Length [m]', data[0]);
+ multi.e.setElement('track-length', data[0]);
@@ -513,10 +512,19 @@
if (icon == "false" || icon === false) {
- multi.e.setElement("Mapbender:iconOffsetX", -10);
- multi.e.setElement("Mapbender:iconOffsetY", -34);
- multi.e.setElement("Mapbender:icon", "../img/marker/red.png");
+ multi.e.setElement("iconOffsetX", -10);
+ multi.e.setElement("iconOffsetY", -34);
+ multi.e.setElement("icon", "../img/marker/red.png");
+ multi.e.setElement("marker-size", 34); // default value 'medium, small, large' is not allowed from canvas
+ multi.e.setElement("marker-symbol", "");
+ multi.e.setElement("marker-color", "#7e7e7e");
+ multi.e.setElement("stroke", "#555555");
+ multi.e.setElement("stroke-opacity", 1.0);
+ multi.e.setElement("stroke-width", 2);
+ multi.e.setElement("fill", "#555555");
+ multi.e.setElement("fill-opacity", 0.5);
var feat = JSON.parse(multi.toString());
itm.data.features.push(feat);
@@ -574,7 +582,6 @@
var json_result;
if (!data) {
- console.log('test');
self.element.trigger('kml:error', "request returned no data");
} else if (data.errorMessage) {
@@ -582,7 +589,6 @@
} else {
//listen to gpx files
try {
- // console.log(data);
json_string = JSON.parse(data);
json_result = JSON.parse(data);
} catch (e) {
@@ -592,9 +598,9 @@
var name;
- if (json_result.hasOwnProperty('@context')) {
+ if (json_result.hasOwnProperty('title')) {
- name = json_result['@context']['title'];
+ name = json_result['title'];
kml.addLayer(name, json_result);
} else {
@@ -685,17 +691,26 @@
getLayerBbox: function(url) {
var self = this;
var itm = this._kmls[url];
- if (itm.data.features.length == 0) {
- return false;
+ var bbox ;
+ if (itm.data.type == "FeatureCollection") {
+ if (itm.data.features.length == 0) {
+ return false;
+ bbox = this.getBbox(itm.data.features[0]);
+ $.each(itm.data.features, function(_, v) {
+ var newbox = self.getBbox(v);
+ bbox[0] = Math.min(bbox[0], newbox[0]);
+ bbox[1] = Math.min(bbox[1], newbox[1]);
+ bbox[2] = Math.max(bbox[2], newbox[2]);
+ bbox[3] = Math.max(bbox[3], newbox[3]);
+ } else if (itm.data.type == "Feature") {
+ bbox = this.getBbox(itm.data);
- var bbox = this.getBbox(itm.data.features[0]);
- $.each(itm.data.features, function(_, v) {
- var newbox = self.getBbox(v);
- bbox[0] = Math.min(bbox[0], newbox[0]);
- bbox[1] = Math.min(bbox[1], newbox[1]);
- bbox[2] = Math.max(bbox[2], newbox[2]);
- bbox[3] = Math.max(bbox[3], newbox[3]);
return bbox;
@@ -751,23 +766,37 @@
if (isNaN(pt.x) || isNaN(pt.y)) return;
// is this the right place and way to fix it?
- if (feature.properties['Mapbender:icon']) {
- feature.properties['marker-symbol'] = feature.properties['Mapbender:icon'];
+ if (feature.properties['icon']) {
+ feature.properties['marker-symbol'] = feature.properties['icon'];
feature.properties['marker-type'] = 'custom';
- feature.properties['Mapbender:icon'] = null;
+ delete feature.properties['icon'];
- if (feature.properties['Mapbender:iconOffsetX']) {
- feature.properties['marker-offset-x'] = feature.properties['Mapbender:iconOffsetX'];
- feature.properties['Mapbender:iconOffsetX'] = null;
+ if (feature.properties['iconOffsetX']) {
+ feature.properties['marker-offset-x'] = feature.properties['iconOffsetX'];
+ delete feature.properties['iconOffsetX'];
- if (feature.properties['Mapbender:iconOffsetY']) {
- feature.properties['marker-offset-y'] = feature.properties['Mapbender:iconOffsetY'];
- feature.properties['Mapbender:iconOffsetY'] = null;
+ if (feature.properties['iconOffsetY']) {
+ feature.properties['marker-offset-y'] = feature.properties['iconOffsetY'];
+ delete feature.properties['iconOffsetY'];
if (feature.properties['marker-type'] === 'custom') {
var size = 32;
if (feature.properties['marker-size']) {
- size = feature.properties['marker-size'];
+ if (feature.properties['marker-size'] === 'large') {
+ size = 64;
+ else if (feature.properties['marker-size'] === 'small') {
+ size = 16;
+ else if (feature.properties['marker-size'] === 'medium') {
+ size = size;
+ else {
+ size = feature.properties['marker-size'];
var offx = 0,
offy = 0;
@@ -991,22 +1020,45 @@
feats = self.cache[url][map.getSrs()];
if (!feats) {
- $.each(item.data.features, function(_, v) {
- self.fixupFeature(v);
- $.ajax({
- url: '../php/transformgeojson.php?targetEPSG=' + map.getSrs(),
- type: 'POST',
- data: JSON.stringify(item.data.features),
- if (!$.isArray(data)) {
- data = JSON.parse(data);
+ // check if feature or featureCollection
+ // feature: item.data = item.data.features;
+ if (item.data.type != "Feature") {
+ $.each(item.data.features, function(_, v) {
+ self.fixupFeature(v);
+ $.ajax({
+ url: '../php/transformgeojson.php?targetEPSG=' + map.getSrs(),
+ type: 'POST',
+ data: JSON.stringify(item.data.features),
+ if (!$.isArray(data)) {
+ data = JSON.parse(data);
+ self.cache[url][map.getSrs()] = data;
+ self.render();
- self.cache[url][map.getSrs()] = data;
- self.render();
- return;
+ return;
+ } else {
+ self.fixupFeature(item.data);
+ $.ajax({
+ type: 'POST',
+ data: JSON.stringify(item.data),
+ self.render();
+ return;
More information about the Mapbender_commits
