Author: syed
Date: 2015-05-04 02:03:49 -0700 (Mon, 04 May 2015)
New Revision: 9186
Added:
   trunk/mapbender/http/php/mb_checkGuest.php
   trunk/mapbender/http/plugins/kmlTree.js
deny wmc-publication for a guest-user
Added: trunk/mapbender/http/php/mb_checkGuest.php
--- trunk/mapbender/http/php/mb_checkGuest.php	                        (rev 0)
+++ trunk/mapbender/http/php/mb_checkGuest.php	2015-05-04 09:03:49 UTC (rev 9186)
@@ -0,0 +1,24 @@
+<?php
+ * @version   Changed: ### 2015-05-04 07:58:43 UTC ###
+ * @author    Raphael.Syed <raphael.syed at WhereGroup.com> http://WhereGroup.com
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+require_once(dirname(__FILE__) . "/../classes/class_user.php");
+// require_once(dirname(__FILE__) . "/../classes/class_wmc.php");
+ * unpublish the the given wmc
+// user_id
+$user_id = Mapbender::session()->get("mb_user_id");
+// create user object
+$currentUser = new User($user_id);
+// var_dump($currentUser->isPublic());
+if ($currentUser->isPublic()) {
+	echo(intval(true));
+} else {
+	echo(intval(false));
Modified: trunk/mapbender/http/plugins/kmlTree.js
--- trunk/mapbender/http/plugins/kmlTree.js	2015-04-27 09:53:49 UTC (rev 9185)
+++ trunk/mapbender/http/plugins/kmlTree.js	2015-05-04 09:03:49 UTC (rev 9186)
@@ -130,6 +130,8 @@
                                 sTitle: 'public'
                                 sTitle: 'size'
+                                sTitle: 'owner'
                         .find('tr').bind('dblclick', function() {
@@ -160,7 +162,7 @@
                             } else {
                                 var title = $(this).parent().siblings().eq(1).html();
-                                var wmc_id = $(this).parent().siblings().eq(0).html();
+                                var wmc_serial_id = $(this).parent().siblings().eq(0).html();
                                 var outputFormat;
                                 var dataExportDlg = $('<div id="dataExportDialog"></div>').dialog({
@@ -182,9 +184,9 @@
                                 //     '<img src="../img/osgeo_graphics/geosilk/link22.png"/>' + '<label class="export-format-gpx">GPX</label>' + '<label class="export-format-geojson">geoJSON</label><br></br>' +
                                 //     '<a download="myfeatures.kml" href="#" class="digitize-image digitize-export" style="float: left;"></a>' + '</form>' + '</div>';
                                 var exportHtml = '<div id="exportHtml"><table><tbody>' +
-                                    '<tr><td>KML:</td><td><label class="export-format-kml exportDatasetIcon" style="padding-top:11px;"></label></td><td class="exportDataLink kml" wmcId="'+wmc_id+'"outputFormat="kml"><img src="../img/osgeo_graphics/geosilk/link22.png"/></td></tr>' +
-                                    '<tr><td>GPX:</td><td><label class="export-format-gpx exportDatasetIcon" style="padding-top:11px;"></label></td><td class="exportDataLink gpx" wmcId="'+wmc_id+'"outputFormat="gpx"><img src="../img/osgeo_graphics/geosilk/link22.png"/></td></tr>' +
-                                    '<tr><td>GeoJson:</td><td><label class="export-format-geojson exportDatasetIcon" style="padding-top:11px;"></label></td><td class="exportDataLink geojson" wmcId="'+wmc_id+'"outputFormat="geojson"><img src="../img/osgeo_graphics/geosilk/link22.png"/></td></tr>' +
+                                    '<tr><td>KML:</td><td><label class="export-format-kml exportDatasetIcon" style="padding-top:11px;"></label></td><td class="exportDataLink kml" wmcId="' + wmc_serial_id + '"outputFormat="kml"><img src="../img/osgeo_graphics/geosilk/link22.png"/></td></tr>' +
+                                    '<tr><td>GPX:</td><td><label class="export-format-gpx exportDatasetIcon" style="padding-top:11px;"></label></td><td class="exportDataLink gpx" wmcId="' + wmc_serial_id + '"outputFormat="gpx"><img src="../img/osgeo_graphics/geosilk/link22.png"/></td></tr>' +
+                                    '<tr><td>GeoJson:</td><td><label class="export-format-geojson exportDatasetIcon" style="padding-top:11px;"></label></td><td class="exportDataLink geojson" wmcId="' + wmc_serial_id + '"outputFormat="geojson"><img src="../img/osgeo_graphics/geosilk/link22.png"/></td></tr>' +
                                     '</tbody></table></div><iframe id="export-DataCollection" style="border:0;height:0; width:0;"></iframe>';
                                 // append the context
                                 $(dataExportDlg).append(exportHtml);
@@ -207,7 +209,7 @@
                                             outputFormat = 'geojson';
                                             break;
-                                    $('#export-DataCollection').attr("src", "../php/mod_GetPublishedData.php?wmc_id=" + wmc_id + "&outputFormat=" + outputFormat);
+                                    $('#export-DataCollection').attr("src", "../php/mod_GetPublishedData.php?wmc_id=" + wmc_serial_id + "&outputFormat=" + outputFormat);
@@ -225,7 +227,7 @@
-                                    var exportDataLinkContent = '<div><label for="exportLinkInput">Link: </label><input id="exportLinkInput" size="35" type="text" value="http://'+window.location.hostname+'/mapbender/php/mod_GetPublishedData.php?wmc_id='+wmc_id+'&outputFormat='+format+'"></div>';
+                                    var exportDataLinkContent = '<div><label for="exportLinkInput">Link: </label><input id="exportLinkInput" size="35" type="text" value="http://' + window.location.hostname + '/mapbender/php/mod_GetPublishedData.php?wmc_id=' + wmc_serial_id + '&outputFormat=' + format + '"></div>';
                                     $(exportDataLinkDlg).append(exportDataLinkContent);
@@ -288,7 +290,7 @@
                                                 url: '../php/mb_unpublish_wmc.php',
                                                 type: 'POST',
                                                 data: {
-                                                    wmc_id: id
+                                                    wmc_serial_id: id
                                                 success: function(data) {
@@ -310,221 +312,239 @@
                                     $(dlg).find('li.kmltree-metadata-publish').bind('click', function() {
-                                        var publishDialog;
-                                        $(dlg).dialog('destroy');
-                                        if ($('#wmcPublishConfirm').dialog('isOpen') === true) {
+                                        // check if the user is public(guest-user) or not
+                                        var isPublic;
+                                        $.ajax({
+                                            url: '../php/mb_checkGuest.php',
+                                            type: 'POST',
+                                            success: function(data) {
+                                                isPublic = data;
+                                                if (isPublic == 1){
-                                            return;
+                        							alert('To publicate a WMC is not allowed for the Guest-User!'+
+                        							      'If you want to use this function, please create an account.');
+                        							return false;
+                                                var publishDialog;
+                                                $(dlg).dialog('destroy');
+                                                if ($('#wmcPublishConfirm').dialog('isOpen') === true) {
-                                        } else {
-                                            publishDialog = $('<div id="wmcPublishConfirm"></div>').dialog({
-                                                title: "Publish datacollection " + d[1],
-                                                width: 373,
-                                                height: 'auto',
-                                                position: {
-                                                    my: "center",
-                                                    at: "top",
-                                                    of: window
-                                                close: function() {
-                                                    // $('#kml-load-tabs').tabs('destroy');
-                                                    // $(this).html('').dialog('destroy');
-                                                    $('#wmcPublishConfirm').dialog('destroy');
-                                                    $('#wmcPublishConfirm').remove();
+                                                    return;
+                                                } else {
+                                                    publishDialog = $('<div id="wmcPublishConfirm"></div>').dialog({
+                                                        title: "Publish datacollection " + d[1],
+                                                        width: 373,
+                                                        height: 'auto',
+                                                        position: {
+                                                            my: "center",
+                                                            at: "top",
+                                                            of: window
+                                                        close: function() {
+                                                            // $('#kml-load-tabs').tabs('destroy');
+                                                            // $(this).html('').dialog('destroy');
+                                                            $('#wmcPublishConfirm').dialog('destroy');
+                                                            $('#wmcPublishConfirm').remove();
+                                                    var publishDlgContent = "<div style='font-size:16px;text-align:justify'>If you want to publish a datacolletcion, you first have to choose a license" +
+                                                        " under which you want to distribute your data. Actually only OpenData compatible" +
+                                                        " licences are supported in this application. Please read the licenses carefully before" +
+                                                        " you activate this option. All of your data will be available for each person in the web" +
+                                                        " in different formats and may be redistributed freely without any copyright. </div>" +
+                                                        "<table style='margin-top:7px' ><tr><th id = 'publishDenied'><img src='../img/button_digitize/geomRemove.png'></img>  No, I dont't want to publish</th>" +
+                                                        "<th style='width:16%;visibility:hidden'>empty</th>" +
+                                                        "<th id = 'publishConfirmed'><img src='../img/osgeo_graphics/check.png'></img>  Yes, I know what I am doing </th></tr></table>";
+                                                    $(publishDialog).append(publishDlgContent);
-                                            var publishDlgContent = "<div style='font-size:16px;text-align:justify'>If you want to publish a datacolletcion, you first have to choose a license" +
-                                                " under which you want to distribute your data. Actually only OpenData compatible" +
-                                                " licences are supported in this application. Please read the licenses carefully before" +
-                                                " you activate this option. All of your data will be available for each person in the web" +
-                                                " in different formats and may be redistributed freely without any copyright. </div>" +
-                                                "<table style='margin-top:7px' ><tr><th id = 'publishDenied'><img src='../img/button_digitize/geomRemove.png'></img>  No, I dont't want to publish</th>" +
-                                                "<th style='width:16%;visibility:hidden'>empty</th>" +
-                                                "<th id = 'publishConfirmed'><img src='../img/osgeo_graphics/check.png'></img>  Yes, I know what I am doing </th></tr></table>";
-                                            $(publishDialog).append(publishDlgContent);
+                                                $(publishDialog).find('#publishConfirmed').bind('click', function() {
+                                                    $(publishDialog).dialog('close');
+                                                    var chooseLicenseDialog = $('<div id="chooseLicenseDialog"></div>').dialog({
+                                                        title: "Choose OpenData license for datacollection " + d[1],
+                                                        width: 720,
+                                                        height: 150,
+                                                        position: {
+                                                            my: "center",
+                                                            at: "top",
+                                                            of: window
+                                                            $('#chooseLicenseDialog').dialog('destroy');
+                                                            $('#chooseLicenseDialog').remove();
+                                                    var chooseLicenseDlgCont = "<div><table id='licenseTbl'style='border-collapse: collapse'>" +
+                                                        "<tr><th>Lizenz</th>" +
+                                                        "<th>Logo</th><th>Beschreibung</th><th>Opendata</th></tr>" +
+                                                        "<tr><td><select id='licenseChooser name='license'>" +
+                                                        "</select></td>" +
+                                                        "<td id='licenseImg'></td>" +
+                                                        "<td id='licenseDescription'></td>" +
+                                                        "<td id='licenseOpen' nowrap></td></tr>" +
+                                                        "<tr id='submitLicense' ><td style='border:none;cursor:pointer; nowrap'><img src='../img/osgeo_graphics/check.png' style='margin-top:10px'/> <span>Publish data</span></td></tr>" +
+                                                        "</table></div>";
+                                                    //  add options for the select box
+                                                    $(chooseLicenseDialog).append(chooseLicenseDlgCont);
-                                        $(publishDialog).find('#publishConfirmed').bind('click', function() {
-                                            $(publishDialog).dialog('close');
-                                            var chooseLicenseDialog = $('<div id="chooseLicenseDialog"></div>').dialog({
-                                                title: "Choose OpenData license for datacollection " + d[1],
-                                                width: 720,
-                                                height: 150,
-                                                position: {
-                                                    my: "center",
-                                                    at: "top",
-                                                    of: window
+                                                    $.ajax({
+                                                        url: '../php/mb_publish_wmc.php',
+                                                        type: 'POST',
+                                                        data: {
+                                                            wmc_serial_id: id,
+                                                            mode: 'getAllLicencesMode',
+                                                            license: 'empty',
+                                                            openData_only: options.openData_only,
-                                                    $('#chooseLicenseDialog').dialog('destroy');
-                                                    $('#chooseLicenseDialog').remove();
-                                            var chooseLicenseDlgCont = "<div><table id='licenseTbl'style='border-collapse: collapse'>" +
-                                                "<tr><th>Lizenz</th>" +
-                                                "<th>Logo</th><th>Beschreibung</th><th>Opendata</th></tr>" +
-                                                "<tr><td><select id='licenseChooser name='license'>" +
-                                                "</select></td>" +
-                                                "<td id='licenseImg'></td>" +
-                                                "<td id='licenseDescription'></td>" +
-                                                "<td id='licenseOpen' nowrap></td></tr>" +
-                                                "<tr id='submitLicense' ><td style='border:none;cursor:pointer; nowrap'><img src='../img/osgeo_graphics/check.png' style='margin-top:10px'/> <span>Publish data</span></td></tr>" +
-                                                "</table></div>";
+                                                            for (var i = 0; i < data.length; i++) {
-                                            //  add options for the select box
-                                            $(chooseLicenseDialog).append(chooseLicenseDlgCont);
+        $('#licenseTbl select').append("<option>" + data[i].name + "</option>");
-                                            $.ajax({
-                                                url: '../php/mb_publish_wmc.php',
-                                                type: 'POST',
-                                                data: {
-                                                    wmc_id: id,
-                                                    mode: 'getAllLicencesMode',
-                                                    license: 'empty',
-                                                    openData_only: options.openData_only,
-                                                success: function(data) {
-                                                    for (var i = 0; i < data.length; i++) {
-                                                        $('#licenseTbl select').append("<option>" + data[i].name + "</option>");
+                                                    $.ajax({
+                                                        type: 'POST',
+                                                        data: {
+                                                            mode: 'getLicenseMode',
+                                                            license: 'cc-by'
+                                                            $('#licenseImg').html('<img src="' + data.symbollink + '" />');
+                                                            $('#licenseDescription').html('<a href="' + data.description + '" />' + data.description + '</a>');
+                                                            if (data.isopen == 1) {
+        $('#licenseOpen').html('<img src="../img/od_80x15_blue.png" />');
+                                                            } else {
-                                            $.ajax({
-                                                type: 'POST',
-                                                data: {
-                                                    wmc_id: id,
-                                                    mode: 'getLicenseMode',
-                                                    license: 'cc-by'
+        $('#licenseOpen').html('<span>No OpenData</span>');
-                                                    $('#licenseImg').html('<img src="' + data.symbollink + '" />');
-                                                    $('#licenseDescription').html('<a href="' + data.description + '" />' + data.description + '</a>');
-                                                    if (data.isopen == 1) {
-                                                        $('#licenseOpen').html('<img src="../img/od_80x15_blue.png" />');
-                                                    } else {
-                                                        $('#licenseOpen').html('<span>No OpenData</span>');
+                                                    $('#licenseTbl select').bind('change', function(event) {
+                                                        $('#licenseImg').html('');
+                                                        $('#licenseDescription').html('');
+                                                        $.ajax({
+                                                            type: 'POST',
+                                                            data: {
+        license: $('#licenseTbl select').val()
-                                            $('#licenseTbl select').bind('change', function(event) {
-                                                $('#licenseImg').html('');
-                                                $('#licenseDescription').html('');
-                                                $.ajax({
-                                                    type: 'POST',
-                                                    data: {
-                                                        wmc_id: id,
-                                                        license: $('#licenseTbl select').val()
+        } else {
-                                                        } else {
+                                                    $('#submitLicense').bind('click', function(event) {
+                                                        //save the license from the choosed wmc
+                                                        $.ajax({
+                                                            type: 'POST',
+                                                            data: {
+        mode: 'saveLicenseMode',
+        $('#mySpatialData').dialog('destroy');
+        $('#mySpatialData').remove();
+        $($addButton).trigger('click');
-                                            $('#submitLicense').bind('click', function(event) {
-                                                //save the license from the choosed wmc
-                                                $.ajax({
-                                                    type: 'POST',
-                                                    data: {
-                                                        wmc_id: id,
-                                                        mode: 'saveLicenseMode',
-                                                        $('#mySpatialData').dialog('destroy');
-                                                        $('#mySpatialData').remove();
-                                                        $($addButton).trigger('click');
+                                                $(publishDialog).find('#publishDenied').bind('click', function() {
-                                        $(publishDialog).find('#publishDenied').bind('click', function() {
-                        // .bind('dblclick', function() {
-                        //     var id = $($(this).find('td')[0]).text();
-                        //     $.ajax({
-                        //         type: 'post',
-                        //         url: '../php/mb_load_local_data.php',
-                        //         data: {
-                        //             id: id
-                        //         success: function(data) {
-                        //             var kml = $('#mapframe1').data('kml');
-                        //             $.each(data, function(url, json) {
-                        //                 kml.addLayer(url, json.data);
-                        //             $(dlg).dialog('destroy');
+                    // .bind('dblclick', function() {
+                    //     var id = $($(this).find('td')[0]).text();
+                    //     $.ajax({
+                    //         type: 'post',
+                    //         url: '../php/mb_load_local_data.php',
+                    //         data: {
+                    //             id: id
+                    //         success: function(data) {
+                    //             var kml = $('#mapframe1').data('kml');
+                    //             $.each(data, function(url, json) {
+                    //                 kml.addLayer(url, json.data);
+                    //             $(dlg).dialog('destroy');
             $('#kml-load-tabs').tabs();
@@ -541,8 +561,12 @@
                 if (title == '') {
                     return;
-                kml.addLayer(title,{
-                    uuid: UUID.genV4().toString(), created: new Date().toISOString() ,title: title, updated: new Date().toISOString(), version: version,
+                kml.addLayer(title, {
+                    uuid: UUID.genV4().toString(),
+                    created: new Date().toISOString(),
+                    title: title,
+                    updated: new Date().toISOString(),
+                    version: version,
                     type: 'FeatureCollection',
                     features: []
@@ -566,15 +590,18 @@
                 // check the features for properties
                 data = setFeatureAttr(data);
-                if( data.hasOwnProperty('title') ){
+                if (data.hasOwnProperty('title')) {
                     name = data['title'];
                     kml.addLayer(name, data);
-               }else{
+                } else {
                     name = $('#kml-from-upload input[type="file"]').val();
-                    if (name.match(/[\\]([^\\]+)/g)) {
-                        name = name.match(/[\\]([^\\]+)/g);
+                    // test.replace(/\\/g,"/").split("/")
+                    if (name.replace(/\\/g, "/").split("/")) {
+                        // name = name.match(/[\\]([^\\]+)/g);
+                        name = name.replace(/\\/g, "/").split("/");
                     name = name[name.length - 1];
@@ -632,19 +659,19 @@
                 toggle = '<button class="toggle" name="toggle" value="toggle"></button>';
-            if(obj.data.features[i].properties.name){
+            if (obj.data.features[i].properties.name) {
                 title = obj.data.features[i].properties.name;
-            } else if(obj.data.features[i].properties.title) {
+            } else if (obj.data.features[i].properties.title) {
                 title = obj.data.features[i].properties.title;
-            } else  {
+            } else {
                 title = 'Title undefined';
-                // title = obj.data.features[i].properties.name;
+            // title = obj.data.features[i].properties.name;
             abbrevTitle = title.length < 20 ? title : title.substr(0, 17) + "...";
@@ -774,7 +801,7 @@
-    var setFeatureAttr = function(data){
+    var setFeatureAttr = function(data) {
         var simpleStyleDefaults = {
             "title": "",
@@ -791,15 +818,15 @@
         if (data.type == 'Feature') {
-            if ( Object.getOwnPropertyNames(data.properties).length === 0  || data.properties === null) {
+            if (Object.getOwnPropertyNames(data.properties).length === 0 || data.properties === null) {
                 data.properties = simplyStyleDefaults;
-            } else{
+            } else {
                 $.each(simpleStyleDefaults, function(index, val) {
-                    if ( !data.properties.hasOwnProperty(index) ){
+                    if (!data.properties.hasOwnProperty(index)) {
                         data.properties[index] = value;
@@ -814,9 +841,9 @@
                 $.each(simpleStyleDefaults, function(prop, propVal) {
-                    if ( !val.properties.hasOwnProperty(prop) ){
+                    if (!val.properties.hasOwnProperty(prop)) {
-                    //TODO: get index in this scope
+                        //TODO: get index in this scope
                         data.features[index].properties[prop] = propVal;
