[Mapbender-commits] r9200 - in trunk/mapbender/http: php plugins
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu May 21 05:16:39 PDT 2015
Author: syed
Date: 2015-05-21 05:16:39 -0700 (Thu, 21 May 2015)
New Revision: 9200
   trunk/mapbender/http/php/mod_CalculateAreaAndLength.php
   trunk/mapbender/http/plugins/mb_digitize_widget.php
add handling for feature-attributes by using json-attributeschema -- minor bugfix
Modified: trunk/mapbender/http/php/mod_CalculateAreaAndLength.php
--- trunk/mapbender/http/php/mod_CalculateAreaAndLength.php	2015-05-21 12:14:28 UTC (rev 9199)
+++ trunk/mapbender/http/php/mod_CalculateAreaAndLength.php	2015-05-21 12:16:39 UTC (rev 9200)
@@ -27,11 +27,9 @@
 // calculate length of a linetring
 // var_dump($geom_data);die;
 if ($geom_type == 'line') {
     $sql = "SELECT st_length(st_GeogFromText( $1 )) as meter";
 } else if ($geom_type == 'polygon') {
     $sql = "SELECT st_area(st_GeogFromText( $1 )) as sqm, st_length(st_GeogFromText( $1 )) as meter ";
@@ -42,15 +40,13 @@
 //fetch the array
 $rslt= array();
-while($row = db_fetch_array($res)){
+while ($row = db_fetch_array($res)) {
+    $rslt[0] = round(floatval($row[0]), 4);
-    $rslt[0] = round(floatval($row[0]),4);
+    if (sizeof($row) > 1) {
+        $rslt[1] = round(floatval($row[1]), 4);
-        if (sizeof($row) > 1) {
-            $rslt[1] = round(floatval($row[1]),4);
Modified: trunk/mapbender/http/plugins/mb_digitize_widget.php
--- trunk/mapbender/http/plugins/mb_digitize_widget.php	2015-05-21 12:14:28 UTC (rev 9199)
+++ trunk/mapbender/http/plugins/mb_digitize_widget.php	2015-05-21 12:16:39 UTC (rev 9200)
@@ -738,7 +738,6 @@
                 attributesDialog.prepend(geometryDiv);
                 attributesDialog.find('.digitize-add').bind('click', function() {
-                    console.log( "click" );
                     var newRow = $('<tr><td><input style="width:81px" type="text"></input></td><td><input style="width:100px" type="text"></input></td></tr>');
                     attributesDialog.find('.ftr-data-tbl.Custom-Data').append(newRow);
                     newRow.find('input').first().bind('change', function() {
More information about the Mapbender_commits mailing list
