[Mapbender-commits] r9305 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Mon Nov 23 02:41:01 PST 2015
Author: armin11
Date: 2015-11-23 02:41:01 -0800 (Mon, 23 Nov 2015)
New Revision: 9305
trunk/mapbender/http/classes/class_wmc.php
Option to handle new column uuid for wmc
Modified: trunk/mapbender/http/classes/class_wmc.php
--- trunk/mapbender/http/classes/class_wmc.php 2015-11-23 10:39:59 UTC (rev 9304)
+++ trunk/mapbender/http/classes/class_wmc.php 2015-11-23 10:41:01 UTC (rev 9305)
@@ -27,6 +27,7 @@
require_once(dirname(__FILE__) . "/../classes/class_administration.php");
require_once(dirname(__FILE__) . "/../classes/class_wmcToXml.php");
require_once(dirname(__FILE__) . "/../classes/class_user.php");
+require_once(dirname(__FILE__) . "/../classes/class_Uuid.php");
* Implementation of a Web Map Context Document, WMC 1.1.0
@@ -94,9 +95,10 @@
var $userId;
var $timestamp;
var $public;
- var $local_data_public = 0;
- var $has_local_data = 0;
- var $local_data_size = '0';
+ var $local_data_public = 0;
+ var $has_local_data = 0;
+ var $local_data_size = '0';
+ var $uuid;
// set during parsing
var $wmc_version;
@@ -134,6 +136,8 @@
public function __construct () {
$this->userId = Mapbender::session()->get("mb_user_id");
$this->timestamp = time();
+ $this->uuid = new Uuid();
@@ -160,7 +164,7 @@
return false;
$this->createObjFromWMC_xml($doc);
- $sql = "SELECT wmc_timestamp, wmc_title, wmc_public, srs, minx, miny, maxx, maxy, wmc_has_local_data, wmc_local_data_size, wmc_local_data_public " .
+ $sql = "SELECT wmc_timestamp, wmc_title, wmc_public, srs, minx, miny, maxx, maxy, wmc_has_local_data, wmc_local_data_size, wmc_local_data_public, uuid " .
"FROM mb_user_wmc WHERE wmc_serial_id = $1 AND (fkey_user_id = $2 OR wmc_public = 1)";
$v = array($wmcId, Mapbender::session()->get("mb_user_id"));
$t = array("i", "i");
@@ -180,6 +184,7 @@
$this->local_data_public = $row[10];
$this->local_data_size = $row[9];
$this->has_local_data = $row[8];
+ $this->uuid = $row[11];
return true;
return false;
@@ -877,12 +882,12 @@
$sql = "INSERT INTO mb_user_wmc (" .
"wmc_id, fkey_user_id, wmc, wmc_title, wmc_public, wmc_timestamp, wmc_timestamp_create, " .
- "abstract, srs, minx, miny, maxx, maxy, wmc_serial_id, wmc_has_local_data, wmc_local_data_public, wmc_local_data_size".
- ") VALUES ($1, $2, $3, $4, $5, $6, $7, $8, $9, $10, $11, $12, $13, $14, $15, $16, $17);";
+ "abstract, srs, minx, miny, maxx, maxy, wmc_serial_id, wmc_has_local_data, wmc_local_data_public, wmc_local_data_size, uuid".
+ ") VALUES ($1, $2, $3, $4, $5, $6, $7, $8, $9, $10, $11, $12, $13, $14, $15, $16, $17, $18);";
$v = array(time(), $this->userId, $this->xml, administration::convertOutgoingString($this->wmc_title), $this->isPublic()?1:0,time(),time(),
$this->wmc_abstract, $this->wmc_srs, $this->wmc_extent->minx, $this->wmc_extent->miny, $this->wmc_extent->maxx, $this->wmc_extent->maxy, $wmc_DB_ID_new,
- $this->has_local_data, $this->local_data_public, $this->local_data_size);
- $t = array("s", "i", "s", "s", "i", "s","s", "s","s","i","i","i", "i", "i", "i", "i", "s");
+ $this->has_local_data, $this->local_data_public, $this->local_data_size, $this->uuid);
+ $t = array("s", "i", "s", "s", "i", "s","s", "s","s","i","i","i", "i", "i", "i", "i", "s", "s");
$res = db_prep_query($sql, $v, $t);
//$sql = "SELECT max(wmc_serial_id) AS i FROM mb_user_wmc";
@@ -900,13 +905,13 @@
//$e = new mb_exception($sql);
$v = array(time(), $this->userId, $this->xml, administration::convertOutgoingString($this->wmc_title), $this->isPublic()?1:0, time(),time(),
More information about the Mapbender_commits
