[Mapbender-commits] r9307 - trunk/mapbender/tools
svn_mapbender at osgeo.org
Mon Nov 23 06:21:44 PST 2015
Author: armin11
Date: 2015-11-23 06:21:44 -0800 (Mon, 23 Nov 2015)
New Revision: 9307
trunk/mapbender/tools/send_post_curl.php
Option to handle proxy exceptions
Modified: trunk/mapbender/tools/send_post_curl.php
--- trunk/mapbender/tools/send_post_curl.php 2015-11-23 13:07:58 UTC (rev 9306)
+++ trunk/mapbender/tools/send_post_curl.php 2015-11-23 14:21:44 UTC (rev 9307)
@@ -89,9 +89,26 @@
curl_setopt($ch, CURLOPT_FOLLOWLOCATION, 1);
curl_setopt($ch, CURLOPT_POST, 1);
curl_setopt($ch, CURLOPT_POSTFIELDS, $data);
- if(CONNECTION_PROXY != ""){
- curl_setopt($ch, CURLOPT_PROXY,CONNECTION_PROXY.":".CONNECTION_PORT);
+ $NOT_PROXY_HOSTS_array = explode(",", NOT_PROXY_HOSTS);
+ //check if http_proxy is set as env, if yes, unset it for the curl action here, it will be reset somewhere below - normally not needed, cause it will be only available when at execution time of the script http://php.net/manual/en/function.putenv.php
+ if (getenv('http_proxy')) {
+ $e = new mb_notice("class_connector.php: current http_proxy: ".getenv('http_proxy')." will be unset by putenv('http_proxy')");
+ $tmpHttpProxy = getenv('http_proxy');
+ putenv("http_proxy"); //this should unset the variable???
+ } else {
+ $e = new mb_notice("class_connector.php: http_proxy is not set as env variable!");
+ //check if proxy is set and server not in NOT_PROXY_HOSTS
+ if(CONNECTION_PROXY != "" AND (in_array($host, $NOT_PROXY_HOSTS_array)!= true)){
+ curl_setopt($ch, CURLOPT_PROXY,CONNECTION_PROXY.":".CONNECTION_PORT);
+ $e = new mb_notice("class_connector.php: Proxy will be used!");
+ if(CONNECTION_PASSWORD != ""){
+ curl_setopt ($ch, CURLOPT_PROXYUSERPWD, CONNECTION_USER.':'.CONNECTION_PASSWORD);
+ } else {
+ $e = new mb_notice("class_connector.php: Proxy will not be used!");
More information about the Mapbender_commits
